Ich habe auf meinem HP EliteBook 8570w unter Ubuntu 24.04.02 LTS leider Probleme mit dem W-Lan. Immer wieder wird zwischen verschiedenen APs hin und her gewechselt.
"dmesg" spukt folgendes aus:
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 | [11939.187672] wlo1: disconnect from AP xx:xx:xx:xx:xx:a2 for new auth to xx:xx:xx:xx:xx:a1 [11939.263615] wlo1: 80 MHz not supported, disabling VHT [11939.267434] wlo1: authenticate with xx:xx:xx:xx:xx:a1 (local address=xx:xx:xx:xx:xx:50) [11939.267441] wlo1: send auth to xx:xx:xx:xx:xx:a1 (try 1/3) [11939.275765] wlo1: xx:xx:xx:xx:xx:a1 denied authentication (status 37) [11939.477182] wlo1: authenticate with xx:xx:xx:xx:xx:a2 (local address=xx:xx:xx:xx:xx:50) [11939.477190] wlo1: send auth to xx:xx:xx:xx:xx:a2 (try 1/3) [11939.494160] wlo1: authenticated [11939.495430] wlo1: associate with xx:xx:xx:xx:xx:a2 (try 1/3) [11939.529167] wlo1: RX ReassocResp from xx:xx:xx:xx:xx:a2 (capab=0x1111 status=0 aid=5) [11939.548769] wlo1: associated [11939.548830] wlo1: Limiting TX power to 23 (23 - 0) dBm as advertised by xx:xx:xx:xx:xx:a2 [11973.254749] wlo1: disconnect from AP xx:xx:xx:xx:xx:a2 for new auth to xx:xx:xx:xx:xx:a1 [11973.303433] wlo1: 80 MHz not supported, disabling VHT [11973.311578] wlo1: authenticate with xx:xx:xx:xx:xx:a1 (local address=xx:xx:xx:xx:xx:50) [11973.311586] wlo1: send auth to xx:xx:xx:xx:xx:a1 (try 1/3) [11973.330305] wlo1: authenticated [11973.332534] wlo1: associate with xx:xx:xx:xx:xx:a1 (try 1/3) [11973.373228] wlo1: RX ReassocResp from xx:xx:xx:xx:xx:a1 (capab=0x1431 status=0 aid=2) [11973.402528] wlo1: associated [11973.460405] wlo1: Limiting TX power to 20 (20 - 0) dBm as advertised by xx:xx:xx:xx:xx:a1 [12018.597599] wlo1: deauthenticating from xx:xx:xx:xx:xx:a1 by local choice (Reason: 2=PREV_AUTH_NOT_VALID) [12018.645852] wlo1: 80 MHz not supported, disabling VHT [12018.647851] wlo1: authenticate with xx:xx:xx:xx:xx:a1 (local address=xx:xx:xx:xx:xx:50) [12018.647857] wlo1: send auth to xx:xx:xx:xx:xx:a1 (try 1/3) [12018.684632] wlo1: authenticated [12018.685500] wlo1: associate with xx:xx:xx:xx:xx:a1 (try 1/3) [12018.716047] wlo1: RX AssocResp from xx:xx:xx:xx:xx:a1 (capab=0x1431 status=0 aid=2) [12018.748916] wlo1: associated [12018.749007] wlo1: Limiting TX power to 20 (20 - 0) dBm as advertised by xx:xx:xx:xx:xx:a1 [12018.837421] wlo1: deauthenticating from xx:xx:xx:xx:xx:a1 by local choice (Reason: 1=UNSPECIFIED) [12024.051740] intel_powerclamp: Stop forced idle injection [13131.021555] wlo1: authenticate with xx:xx:xx:xx:xx:a1 (local address=xx:xx:xx:xx:xx:50) [13131.021564] wlo1: send auth to xx:xx:xx:xx:xx:a1 (try 1/3) [13131.024585] wlo1: xx:xx:xx:xx:xx:a1 denied authentication (status 37) [13137.738979] wlo1: authenticate with xx:xx:xx:xx:xx:a1 (local address=xx:xx:xx:xx:xx:50) [13137.738998] wlo1: send auth to xx:xx:xx:xx:xx:a1 (try 1/3) [13137.748282] wlo1: xx:xx:xx:xx:xx:a1 denied authentication (status 37) [13147.855187] wlo1: authenticate with xx:xx:xx:xx:xx:a2 (local address=xx:xx:xx:xx:xx:50) [13147.855203] wlo1: send auth to xx:xx:xx:xx:xx:a2 (try 1/3) [13147.927010] wlo1: authenticated [13147.927576] wlo1: associate with xx:xx:xx:xx:xx:a2 (try 1/3) [13147.973512] wlo1: RX AssocResp from xx:xx:xx:xx:xx:a2 (capab=0x1111 status=0 aid=5) [13147.993804] wlo1: associated [13148.021917] wlo1: Limiting TX power to 23 (23 - 0) dBm as advertised by xx:xx:xx:xx:xx:a2 |
Ich werde nur leider nicht wirklich schlau daraus und würde mich über eine Erklärung, was hier vor sich geht, sehr freuen.
Anscheinend soll man im Netzwerkadapter einstellen können, wie schnell eine neue Verbindung gesucht wird bwz. wie stark an einer bestehenden gehaftet werden soll. Leider konnte ich nicht herausfinden wie das gehen soll.
Über Eure Ratschläge zur weiteren Fehlersuche und möglichen Lösungen würde ich mich sehr freuen.
Viele Grüße Michael
