Problem proFTP
drnicolas
31. Oktober 2010
Guten Morgen!
ich scheitere mit der Konfiguration vpn proFTPd:
Ich scheine mich anmelden zu können, dann aber stockt es. WinSCP landet immer wieder bei der Anmeldung anstatt das Verzeichnis zu lesen
. 2021-10-23 11:21:38.755 Session name: vpn.xyz.cc (Site)
. 2021-10-23 11:21:38.755 Host name: vpn.xyz.cc (Port: 2100)
. 2021-10-23 11:21:38.755 User name:  (Password: No, Key file: No, Passphrase: No)
. 2021-10-23 11:21:38.755 Transfer Protocol: FTP
. 2021-10-23 11:21:38.755 Ping type: Dummy, Ping interval: 30 sec; Timeout: 15 sec
. 2021-10-23 11:21:38.755 Disable Nagle: No
. 2021-10-23 11:21:38.755 Proxy: None
. 2021-10-23 11:21:38.755 Send buffer: 262144
. 2021-10-23 11:21:38.755 UTF: Auto
. 2021-10-23 11:21:38.755 FTPS: None [Client certificate: No]
. 2021-10-23 11:21:38.755 FTP: Passive: Yes [Force IP: Auto]; MLSD: Auto [List all: Auto]; HOST: Auto
. 2021-10-23 11:21:38.755 Local directory: default, Remote directory: home, Update: Yes, Cache: Yes
. 2021-10-23 11:21:38.755 Cache directory changes: Yes, Permanent: Yes
. 2021-10-23 11:21:38.755 Recycle bin: Delete to: No, Overwritten to: No, Bin path:
. 2021-10-23 11:21:38.755 Timezone offset: 0h 0m
. 2021-10-23 11:21:38.755 --------------------------------------------------------------------------
. 2021-10-23 11:21:38.755 Username prompt (no username provided)
. 2021-10-23 11:21:42.945 Verbindung mit vpn.xyz.cc:2100 wird hergestellt …
. 2021-10-23 11:21:42.975 Verbunden mit vpn.xyz.cc:2100. Willkommensnachricht wird erwartet …
< 2021-10-23 11:21:43.005 220 ::ffff:192.168.1.27 FTP server ready
> 2021-10-23 11:21:43.005 USER nico
< 2021-10-23 11:21:43.035 331 Password required for nico
> 2021-10-23 11:21:46.255 PASS **********
< 2021-10-23 11:21:46.315 230 Zugriff gestattet für nico
> 2021-10-23 11:21:46.315 SYST
< 2021-10-23 11:21:46.345 215 UNIX Type: L8
> 2021-10-23 11:21:46.345 FEAT
< 2021-10-23 11:21:46.375 211-Features:
< 2021-10-23 11:21:46.375  CLNT
< 2021-10-23 11:21:46.375  EPRT
< 2021-10-23 11:21:46.375  EPSV
< 2021-10-23 11:21:46.375  HOST
< 2021-10-23 11:21:46.375  LANG de-DE.UTF-8*
< 2021-10-23 11:21:46.375  MDTM
< 2021-10-23 11:21:46.375  MFF modify;UNIX.group;UNIX.mode;
< 2021-10-23 11:21:46.375  MFMT
< 2021-10-23 11:21:46.375  MLST modify*;perm*;size*;type*;unique*;UNIX.group*;UNIX.groupname*;UNIX.mode*;UNIX.owner*;UNIX.ownername*;
< 2021-10-23 11:21:46.405  REST STREAM
< 2021-10-23 11:21:46.405  SIZE
< 2021-10-23 11:21:46.405  TVFS
< 2021-10-23 11:21:46.405  UTF8
< 2021-10-23 11:21:46.405 211 End
> 2021-10-23 11:21:46.405 CLNT WinSCP-release-5.19.2
< 2021-10-23 11:21:46.435 200 OK
> 2021-10-23 11:21:46.435 OPTS UTF8 ON
< 2021-10-23 11:21:46.475 200 UTF8 set to on
. 2021-10-23 11:21:46.505 Verbunden
. 2021-10-23 11:21:46.505 --------------------------------------------------------------------------
. 2021-10-23 11:21:46.505 Using FTP protocol.
. 2021-10-23 11:21:46.505 Doing startup conversation with host.
> 2021-10-23 11:21:46.515 PWD
< 2021-10-23 11:21:46.545 257 "/" is the current directory
. 2021-10-23 11:21:46.545 Getting current directory name.
. 2021-10-23 11:21:46.595 Verzeichnisinhalt wird abgerufen …
> 2021-10-23 11:21:46.595 TYPE A
< 2021-10-23 11:21:46.625 200 Type set to A
> 2021-10-23 11:21:46.625 PASV
< 2021-10-23 11:21:46.655 227 Entering Passive Mode (192,168,1,27,211,43).
. 2021-10-23 11:21:46.655 Server sent passive reply with unroutable address 192.168.1.27, using host address instead.
> 2021-10-23 11:21:46.655 MLSD
. 2021-10-23 11:21:46.655 Verbindung mit 188.97.243.133:54059 wird hergestellt …
1. Ich vermisse eine Willkommensnachricht. Die sollte eigentlich mit AccessGrantMsg konfiguriert sein 2. Und dann eben die fehlende Nutzbarkeit
Kann mir jemand helfen?
