Problem mit java bei Börsensoftware stock
Status: Gelöst | Ubuntu-Version: Lubuntu 24.04 (Noble Numbat)
Stabsgefreiter
Avatar von Stabsgefreiter
27. Juli 2008
hallo,
ich benutze seit langem die Börsensoftware jstock, die bisher problemlos lief. Jetzt ließen sch die Kurse nicht mehr aktualieren, somit habe ich eine Neuinstallation gemacht
wget https://github.com/yccheok/jstock/releases/download/release_1-0-7-44/jstock-1.0.7.44-bin.zip
unzip jstock-1.0.7.44-bin.zip
cd jstock/
chmod 755 jstock.sh
./jstock.sh
saturn@lenovo3000n200:~/jstock$ java -version
java version "24" 2025-03-18
Java(TM) SE Runtime Environment (build 24+36-3646)
Java HotSpot(TM) 64-Bit Server VM (build 24+36-3646, mixed mode, sharing)
bei starten des progs bekomme ich eine fehlermeldung von java, mit der ich leider nicht viel anfangen kann
saturn@lenovo3000n200:~/jstock$ ./jstock.sh
WARNING: A terminally deprecated method in sun.misc.Unsafe has been called
WARNING: sun.misc.Unsafe::objectFieldOffset has been called by com.thoughtworks.xstream.converters.reflection.SunUnsafeReflectionProvider (file:/home/saturn/jstock/lib/xstream-1.4.11.1.jar)
WARNING: Please consider reporting this to the maintainers of class com.thoughtworks.xstream.converters.reflection.SunUnsafeReflectionProvider
WARNING: sun.misc.Unsafe::objectFieldOffset will be removed in a future release
Exception in thread "main" java.lang.ExceptionInInitializerError
        at com.thoughtworks.xstream.XStream.setupConverters(XStream.java:990)
        at com.thoughtworks.xstream.XStream.<init>(XStream.java:593)
        at com.thoughtworks.xstream.XStream.<init>(XStream.java:515)
        at com.thoughtworks.xstream.XStream.<init>(XStream.java:484)
        at com.thoughtworks.xstream.XStream.<init>(XStream.java:430)
        at com.thoughtworks.xstream.XStream.<init>(XStream.java:369)
        at org.yccheok.jstock.gui.Utils.fromXML(Utils.java:1800)
        at org.yccheok.jstock.gui.JStock.getJStockOptionsViaXML(JStock.java:1803)
        at org.yccheok.jstock.gui.JStock.main(JStock.java:1819)
Caused by: java.lang.reflect.InaccessibleObjectException: Unable to make field private final java.util.Comparator java.util.TreeMap.comparator accessible: module java.base does not "opens java.util" to unnamed module @edf4efb
        at java.base/java.lang.reflect.AccessibleObject.throwInaccessibleObjectException(AccessibleObject.java:353)
        at java.base/java.lang.reflect.AccessibleObject.checkCanSetAccessible(AccessibleObject.java:329)
        at java.base/java.lang.reflect.AccessibleObject.checkCanSetAccessible(AccessibleObject.java:277)
        at java.base/java.lang.reflect.Field.checkCanSetAccessible(Field.java:179)
        at java.base/java.lang.reflect.Field.setAccessible(Field.java:173)
        at com.thoughtworks.xstream.core.util.Fields.locate(Fields.java:40)
        at com.thoughtworks.xstream.converters.collections.TreeMapConverter.<clinit>(TreeMapConverter.java:50)
        ... 9 more
kann mr hier jemand weiterhelfen?
homer65
Avatar von homer65
8. November 2005
Das heißt das das Programm nicht mit der von Dir eingesetzten Java Version laufen wird. Eventuell ist es möglich eine ältere Java Version zu benutzen?
homer65
Avatar von homer65
8. November 2005
Habe mal die zip Datei von jstock.org heruntergeladen und entpackt. Dann jstock.sh mit chmod a+x versehen. Und es läuft bei mir. Habe Java 17 installiert.
Stabsgefreiter
27. Juli 2008
zum Laufen hab ich es auch bekommen, nur die Aktienkurse werden nicht aktualisiert bezw. geladen, d.h.das prog kann wohl keine verbibdung zu den yahoo Aktienkursen aufbauen bzw diese in das Prog einladen, und dieses Problem besteht erst seit ca 1 Woche.
Seebär
Avatar von Seebär
2. Mai 2009
Verwende Java 11 und nicht einfach irgendwas (hier Java24), zumindest ist das die Version welche sich im changelog.txt des Repos findet. Einfach dazu ein passendes Adopt-JRE als zip entpacken und vor Aufruf der .sh export JAVA_HOME="/pfad/zu/deinjre11" machen. Falls das nicht genügt muss --add-opens java.base/java.util=ALL-UNNAMED dem Javaprozess mitgegeben werden. Da es ein Laufzeitfehler ist, ist die Aussage "gestartet bekommen " nicht hinreichend.
Eine gescheite Doku über Systemvoraussetzungen der Software sehe ich leider nicht.
Stabsgefreiter
27. Juli 2008
ich hab jetzt openjdk 11 installiert, das Programm startet zwar aber die Aktienkurse werden nicht installiert
#!/bin/bash
# Normally, editing this script should not be required.
# Only case is to set up JAVA_HOME if it's not already defined.
# To specify an alternative JVM, edit and uncomment the following
# line and change the path accordingly.
#JAVA_HOME=/usr/lib/java
JAVA_HOME=/usr/lib/jvm/java-11-openjdk-amd64
_JAVA_EXEC="java"
if [ -n $JAVA_HOME ] ; then
    _TMP="$JAVA_HOME/bin/java"
    if [ -f "$_TMP" ] ; then
        if [ -x "$_TMP" ] ; then
            _JAVA_EXEC="$_TMP"
        else
            echo "Warning: $_TMP is not executable"
        fi
    else
        echo "Warning: $_TMP does not exist"
    fi
fi
if ! which "$_JAVA_EXEC" >/dev/null ; then
    echo "Error: No Java Runtime Environment found"
    echo "Please set the environment variable JAVA_HOME to the root directory of your SUN Java installation, e.g. by editing the 7th line in this launcher script."
    exit 1
fi
# Resolve the location of the JStock installation.
# This includes resolving any symlinks.
PRG=$0
while [ -h "$PRG" ]; do
    ls=`ls -ld "$PRG"`
    link=`expr "$ls" : '^.*-> \(.*\)$' 2>/dev/null`
    if expr "$link" : '^/' 2> /dev/null >/dev/null; then
        PRG="$link"
    else
        PRG="`dirname "$PRG"`/$link"
    fi
done
JSTOCK_BIN=`dirname "$PRG"`
cd "${JSTOCK_BIN}"
_VMOPTIONS="-Xms64m -Xmx512m"
_JAVAFXPATH="/usr/share/openjfx/lib"
if [[ (-d "$_JAVAFXPATH") && (-f "$_JAVAFXPATH/javafx.base.jar") ]] ; then
    _JAVAFXOPTIONS="--module-path $_JAVAFXPATH --add-modules=javafx.base,javafx.controls,javafx.fxml,javafx.graphics,javafx.media,javafx.swing,javafx.web"
else
    _JAVAFXOPTIONS=""
fi
$_JAVA_EXEC $_VMOPTIONS $_JAVAFXOPTIONS -jar jstock.jar
folgende Fehler
WARNING: An illegal reflective access operation has occurred
WARNING: Illegal reflective access by com.thoughtworks.xstream.core.util.Fields (file:/home/saturn/jstock/lib/xstream-1.4.11.1.jar) to field java.util.TreeMap.comparator
WARNING: Please consider reporting this to the maintainers of com.thoughtworks.xstream.core.util.Fields
WARNING: Use --illegal-access=warn to enable warnings of further illegal reflective access operations
WARNING: All illegal access operations will be denied in a future release
Security framework of XStream not initialized, XStream is probably vulnerable.
was ich nicht so ganz verstehe, es gibt 2 jstock varianten, eine gleich mit java im Ordner, die andere ohne java. Eigentlich müsste die version mit java ja auch das abgestimmte java haben.
ergänzend hab ich mal java oracle 8 runtergeladen um es hier mit zu versuchen
dazu habe ich den java ordner jdk1.8.0_202 in den Ordner Programme im Homeverzeichnis kopiert und den pfad entsprechend abgeändert
JAVA_HOME= /home/Programme/jdk1.8.0_202/
_JAVA_EXEC="java"
            _JAVA_EXEC="$_TMP"
        else
        fi
    else
    fi
fi
    exit 1
fi
PRG=$0
    ls=`ls -ld "$PRG"`
        PRG="$link"
    else
    fi
done
cd "${JSTOCK_BIN}"
else
    _JAVAFXOPTIONS=""
fi
beim Starten des Progs erscheint dann die fehlermeldung
saturn@lenovo3000n200:~/Programme/jstock$ ./jstock.sh
Warning: /saturn/Programme/jstock/jdk1.8.0_202 does not exist
WARNING: sun.misc.Unsafe::objectFieldOffset has been called by com.thoughtworks.xstream.converters.reflection.SunUnsafeReflectionProvider (file:/home/saturn/.local/share/Trash/files/jstock.6/lib/xstream-1.4.11.1.jar)
        at org.yccheok.jstock.gui.Utils.getXStream(Utils.java:1785)
        at org.yccheok.jstock.gui.Utils.fromXML(Utils.java:1819)
Caused by: java.lang.reflect.InaccessibleObjectException: Unable to make field private final java.util.Comparator java.util.TreeMap.comparator accessible: module java.base does not "opens java.util" to unnamed module @4411d970
        ... 10 more
jetzt weiss ich auch nicht mehr weiter, zumal vorher alles funktioniert hat
Mankind75 Team-Icon
Lokalisierungsteam
Avatar von Mankind75
4. Juni 2007
Ich nutze dafür auch Yahoo! Finance aber greife über das Portal und den Browser darauf zu. In meinem Safari-Browser klappt das auch nicht, dass da automatisiert wird. Ist zwar nicht Linux aber vielleicht liegt es wirklich an Yahoo! momentan.
Gibt sicherlich bessere Finanzportale mittlerweile aber ich nutze es schon seit 1999 und man hat sich einfach daran gewöhnt.
Stabsgefreiter
27. Juli 2008
ich weiss nicht so recht woran das fehlende Aktualisieren nun wirklich liegt, könnte durchaus an yahoo finance liegen. Aber man muss eben Plan B haben, so nutze ich jetzt PortfolioPerformance, macht einen guten Eindruck und aktualisiert auch zeitnah. Ich habe in meiner Ferienwohnung noch einen alten Notebook mit mxlinux und java oracle drauf, auf dem bis zuletzt jstock lief mit Aktualisierung der Börsenkurse, wenn das dort jezt auch nicht mehr funktioniert ist die Sache dann ziemlich klar.
Stabsgefreiter
27. Juli 2008
das Problem ist kein linux oder java spezif. Problem sondern es liegt am Programm selbst. Auf der facebook seite des Programms gibt es ahnliche Meldungen bzgl. der fehlenden Kursaktualisierung. Von den Entwicklern bisher keine Reaktion. Damit ist das Prog. letztendlich nutzlos
