Nautilus systemdateien werden nicht angezeigt
Status: Ungelöst | Ubuntu-Version: Ubuntu 24.10 (Oracular Oriole)
Spacetaxi
24. Februar 2014
Auf meinem msi Laptop
System:
  Kernel: 6.11.0-13-generic arch: x86_64 bits: 64
  Desktop: GNOME v: 47.0 Distro: Ubuntu 24.10 (Oracular Oriole)
Machine:
  Type: Laptop System: Micro-Star product: Modern 15 B7M v: REV:1.0
    serial: <superuser required>
  Mobo: Micro-Star model: MS-15HK v: REV:1.0 serial: <superuser required>
    UEFI: American Megatrends LLC. v: E15HKAMS.30B date: 08/13/2024
Battery:
  ID-1: BAT1 charge: 36.1 Wh (94.8%) condition: 38.1/37.8 Wh (100.7%)
CPU:
  Info: 6-core model: AMD Ryzen 5 7530U with Radeon Graphics bits: 64
    type: MT MCP cache: L2: 3 MiB
  Speed (MHz): avg: 1271 min/max: 400/4546 cores: 1: 1914 2: 1575 3: 1095
    4: 1095 5: 1095 6: 1095 7: 1095 8: 1095 9: 1909 10: 1095 11: 1095 12: 1095
Graphics:
  Device-1: AMD Barcelo driver: amdgpu v: kernel
  Device-2: Luxvisions Innotech Integrated Camera driver: uvcvideo type: USB
  Display: wayland server: X.Org v: 24.1.2 with: Xwayland v: 24.1.2
    compositor: gnome-shell driver: dri: radeonsi gpu: amdgpu
    resolution: 1920x1080~60Hz
  API: EGL v: 1.5 drivers: kms_swrast,radeonsi,swrast
    platforms: gbm,wayland,x11,surfaceless,device
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.2.3-1ubuntu1
    renderer: AMD Radeon Graphics (radeonsi renoir LLVM 19.1.0 DRM 3.58
    6.11.0-13-generic)
Audio:
  Device-1: AMD Renoir Radeon High Definition Audio driver: snd_hda_intel
  Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor driver: snd_rn_pci_acp3x
  Device-3: AMD Family 17h/19h HD Audio driver: snd_hda_intel
  API: ALSA v: k6.11.0-13-generic status: kernel-api
  Server-1: PipeWire v: 1.2.4 status: active
Network:
  Device-1: MEDIATEK MT7922 802.11ax PCI Express Wireless Network Adapter
    driver: mt7921e
  IF: wlp1s0 state: up mac: <filter>
Bluetooth:
  Device-1: MediaTek Wireless_Device driver: btusb type: USB
  Report: hciconfig ID: hci0 state: up address: <filter> bt-v: 5.2
Drives:
  Local Storage: total: 476.94 GiB used: 99.69 GiB (20.9%)
  ID-1: /dev/nvme0n1 vendor: Samsung model: MZVL4512HBLU-00BTW
Partition:
  ID-1: / size: 75.8 GiB used: 15.44 GiB (20.4%) fs: ext4 dev: /dev/nvme0n1p8
  ID-2: /boot/efi size: 296 MiB used: 37.2 MiB (12.6%) fs: vfat
    dev: /dev/nvme0n1p1
Swap:
  ID-1: swap-1 type: file size: 4 GiB used: 0 KiB (0.0%) file: /swap.img
  ID-2: swap-2 type: partition size: 16.68 GiB used: 0 KiB (0.0%)
    dev: /dev/nvme0n1p4
Sensors:
  System Temperatures: cpu: 48.2 C mobo: 36.0 C gpu: amdgpu temp: 40.0 C
  Fan Speeds (rpm): N/A
Info:
  Memory: total: 16 GiB note: est. available: 14.5 GiB used: 2.47 GiB (17.0%)
  Processes: 343 Uptime: 16m Shell: Bash inxi: 3.3.35
werden in Nautilus meine eigenen Dateien gar nicht angezeigt (Dieser PC) (z.b. "usr" "var", ec.
Auf meinem 24.04 heißt es dort "Andere Orte" - Ubuntu untendrunter dann andere Betriebssysteme.
Hier sehe ich nur das installierte Windows und 24.04 auf der anderen Partition.
Siehe Bild unten links.
Wo stelle ich das ein?
Moderiert von schwarzheit:
Berlin_1946 Team-Icon
18. September 2009
  1. die 3 Punkte > Ort bearbeiten
  2. / eintragen und
  3. "usr" "var", ec. sind da 😎
Spacetaxi
24. Februar 2014
  2. / eintragen und
Vielen dank.
Musste das bisher noch nie einstellen (war sonst immer da)
Vielleicht hab ich da rumgefingert, aber danke!!
18. September 2009
Nee, hast du nicht oder ich habe das gleiche rumgefingert, was aber ein großer Zufall wäre. 😉
Spacetaxi
24. Februar 2014
Nochmal korrektur.
nein, ich hab immer noch unter 24.10 mein Kerndateien versteckt.
Siehe Screenshot.
da ist weder "mein Rechner" noch der Datenträger meiner derzeitigen Partition. Nur das Ubuntu 1 (24.04) und windows sind zu bearbeiten!!??
(Datenträger4 ist ein Stick)
Ich kann also "mein Rechner" gar nicht bearbeiten. Hierzu müsste ich 24.04 wechseln. Was geht da ab?
Spacetaxi
24. Februar 2014
Hier der selber Rrechner, andere Partition mit Ubuntu 24.04 So SOLLTE es aussehen, siehe Screenshot.
Was ist da los??
Andere Orte fehlt bei 24.10 völlig. Das eigene system nicht zu bearbeiten.
/etc/fstab hab ich mir angesehen. Sehe aber keien Unterschiede zu 24.04
Spacetaxi
24. Februar 2014
  2. / eintragen und
Vielen dank.
OK
Das geht zwar aber wieso ist der eigene Datenträger auf meinem Desktop PC automatisch eingebunden?? Oder hier auf dem MSI unter 24.04 unter "Andere Orte" zu finden?
Ist das Zufallsprinzip?
18. September 2009
Nein diese Ausgabe von Nautilus Nr. 47.0 startet immer im "Persönlichen Ordner". In die root (/) ("usr" "var", ec.) kommst du so, wie ich geschrieben habe.
Bitte ab jetzt richtig zitieren.
Siehe Zitat, komplette Beitragen zu zitieren ist unerwünscht.
Bitte unterlasse Fullquote.
Spacetaxi
24. Februar 2014
Das ist also neu. Ich bin auf dem Desktop PC auf dem gleichen Stand wie auf dem Laptop.
Warum die Unterschiede?
Ist wohl auch dieselbe Version.
Nochmal 24.04 auf dem gleichen Laptop ebenso
Das kann ja nicht sein.
tomtomtom Team-Icon
Avatar von tomtomtom
22. August 2008
Weil die Systempartition gemountet sein muss, damit das System startet.
Spacetaxi
24. Februar 2014
Ich habe Ubuntu genauso installiert wie alle anderen.
Woran lags/liegts dann das die Systempartition ausgerechnet hier nicht gemounted ist beim Start?
tomtomtom Team-Icon
22. August 2008
Das ist technisch schlichtweg nicht möglich.
Spacetaxi
24. Februar 2014
Was soll ich denn anders gemacht haben?
Spacetaxi
24. Februar 2014
Wie kann ich das wieder einbinden. Mit gparted geht das auch?
Spacetaxi
24. Februar 2014
Ich hab unter Laufwerke die Einhängeoption geändert, jetzt startet der Desktop nicht mehr failed....
Hab das auf der anderen Partition rückgängig gemacht, immer noch das selbe
Ich hab kein Bock mehr...
