Bluetooth Mikrofon Problem
Status: Ungelöst | Ubuntu-Version: Kubuntu 19.10 (Eoan Ermine)
Paintmaster
4. Januar 2020
Hallo Zusammen,
leider bekomme ich mein Mikrofon vom Sony mdr-xb650bt nicht zum laufen. Hat jemand eine Idee?
● bluetooth.service - Bluetooth service
   Loaded: loaded (/lib/systemd/system/bluetooth.service; enabled; vendor preset: enabled)
   Active: active (running) since Mon 2020-01-27 10:33:27 CET; 4h 24min ago
     Docs: man:bluetoothd(8)
 Main PID: 1032 (bluetoothd)
   Status: "Running"
    Tasks: 1 (limit: 4915)
   Memory: 2.4M
   CGroup: /system.slice/bluetooth.service
           └─1032 /usr/lib/bluetooth/bluetoothd
Jan 27 10:33:27 matthias-P7624 systemd[1]: Starting Bluetooth service...
Jan 27 10:33:27 matthias-P7624 bluetoothd[1032]: Bluetooth daemon 5.50
Jan 27 10:33:27 matthias-P7624 bluetoothd[1032]: Starting SDP server
Jan 27 10:33:27 matthias-P7624 bluetoothd[1032]: Bluetooth management interface 1.14 initialized
Jan 27 10:33:27 matthias-P7624 systemd[1]: Started Bluetooth service.
Jan 27 10:33:35 matthias-P7624 bluetoothd[1032]: Endpoint registered: sender=:1.66 path=/MediaEndpoint/A2DPSink/sbc
Jan 27 10:33:35 matthias-P7624 bluetoothd[1032]: Endpoint registered: sender=:1.66 path=/MediaEndpoint/A2DPSource/sbc
Jan 27 11:34:40 matthias-P7624 bluetoothd[1032]: Unable to get Headset Voice gateway SDP record: Host is down
Jan 27 11:34:49 matthias-P7624 bluetoothd[1032]: /org/bluez/hci0/dev_00_18_09_F5_65_92/fd0: fd(35) ready
31
32
33
34
35
36
37
38
39
40
[MDR-XB650BT]# show
Controller 4C:80:93:04:F1:6D (public)
        Alias: matthias-P7624
        Class: 0x001c010c
        Powered: yes
        Discoverable: yes
        Pairable: yes
        UUID: A/V Remote Control        (0000110e-0000-1000-8000-00805f9b34fb)
        UUID: Audio Source              (0000110a-0000-1000-8000-00805f9b34fb)
        UUID: PnP Information           (00001200-0000-1000-8000-00805f9b34fb)
        UUID: Headset AG                (00001112-0000-1000-8000-00805f9b34fb)
        UUID: Headset                   (00001108-0000-1000-8000-00805f9b34fb)
        UUID: Message Notification Se.. (00001133-0000-1000-8000-00805f9b34fb)
        UUID: A/V Remote Control Target (0000110c-0000-1000-8000-00805f9b34fb)
        UUID: Phonebook Access Server   (0000112f-0000-1000-8000-00805f9b34fb)
        UUID: Message Access Server     (00001132-0000-1000-8000-00805f9b34fb)
        UUID: Audio Sink                (0000110b-0000-1000-8000-00805f9b34fb)
        UUID: OBEX File Transfer        (00001106-0000-1000-8000-00805f9b34fb)
        UUID: IrMC Sync                 (00001104-0000-1000-8000-00805f9b34fb)
        UUID: OBEX Object Push          (00001105-0000-1000-8000-00805f9b34fb)
        UUID: Vendor specific           (00005005-0000-1000-8000-0002ee000001)
        Modalias: usb:v1D6Bp0246d0532
        Discovering: no
[MDR-XB650BT]# info
Device 00:18:09:F5:65:92 (public)
        Alias: MDR-XB650BT
        Class: 0x00240404
        Icon: audio-card
        Paired: yes
        Trusted: yes
        Blocked: no
        Connected: yes
        LegacyPairing: no
        UUID: Handsfree                 (0000111e-0000-1000-8000-00805f9b34fb)
dask2
Avatar von dask2
13. April 2006
Hi Paintmaster, kann deine Erfahrung nur bestätigen: auch bei mir (20.04. LTS aktuell) geht dieser Kopfhörer unter ubuntu/pulseaudio nicht bi-direktional. Man kann zwar den Kopfhörer benutzen, aber sobald man den Kopfhörer auf reduziert auf Mono/Einkanalig um das Mikrophon zu bekommen, hängt die weitere Auswahl bei der Erkennung des Mikros und springt am Hörer wieder auf die Standard Audioquelle. Bei Blueman kommt bei der Auswahl des Profiles "Headset" eine unspezifische Fehlermeldung und springt wieder auf Stereokopfhörer.
Grüße, dask2
marant...
2. Februar 2021
Unterstützt das Teil HSP(Headset). Im blueman unter Geräte/<Gerät>/Info zu sehen.
Trotz Dessen Nachfrage.
dask2
Avatar von dask2
13. April 2006
Hi marant...,
Ja, das Headset kann HSP:
laut dieser webseite: https://www.preis.de/produkte/Sony-MDR-XB650BT/4053635.html
Unterstützt es diese Bluetooth-Profile:
A2DP (Advanced Audio Distribution Profile), HFP (Hands Free Profile), AVRCP (Audio Video Remote Control Profile), HSP (Headset Profile)
Berlin_1946 Team-Icon
18. September 2009
Hallo in die Runde,
ich hatte bei ubuntu, kubuntu und xubuntu bei mehreren Bluetooth- Geräten Probleme. Jetzt nutze ich MATE 20.04 und alle Geräte funktionieren (warum es bei MATE so ist ???).
Meine Idee: mit einem Live- System MATE 20.04 mal probieren, ob es auch mit dem Sony mdr-xb650bt zum Erfolg kommt.
marant...
2. Februar 2021
@dask2
Anzeigen lassen, hatte Hier schon den Fall das die Docu(selbst direkt v. einem Hersteller) falsch war.
