abgehackter Sound
weholei
7. Februar 2019
Hallo
Bei mir klingt der Sound abgehackt und stottert
das, denke ich, sagt das log:
Apr  5 21:26:10 ubu-20-home org.kde.kdeconnect.daemon.desktop[2738]: org.kde.pulseaudio: No object for name "alsa_output.pci-0000_00_1f.3.hdmi-stereo-extra1"
Apr  5 21:26:16 ubu-20-home gsd-media-keys[2658]: Unable to get default sink
und das kommt, wenn ich einen Befehl aus diesem Forum verwende:
werner@ubu-20-home:~$ pulseaudio -k; sleep 4; pulseaudio -vv
I: [pulseaudio] main.c: setrlimit(RLIMIT_NICE, (31, 31)) failed: Vorgang nicht zulässig
I: [pulseaudio] main.c: setrlimit(RLIMIT_RTPRIO, (9, 9)) failed: Vorgang nicht zulässig
D: [pulseaudio] core-rtclock.c: Timer slack is set to 50 us.
I: [pulseaudio] core-util.c: Failed to acquire high-priority scheduling: Datei oder Verzeichnis nicht gefunden
I: [pulseaudio] main.c: This is PulseAudio 13.99.1
D: [pulseaudio] main.c: Compilation host: x86_64-pc-linux-gnu
D: [pulseaudio] main.c: Compilation CFLAGS: -g -O2 -fdebug-prefix-map=/build/pulseaudio-iKJeff/pulseaudio-13.99.1=. -fstack-protector-strong -Wformat -Werror=format-security -Wall -W -Wextra -pipe -Wno-long-long -Wno-overlength-strings -Wunsafe-loop-optimizations -Wundef -Wformat=2 -Wlogical-op -Wsign-compare -Wformat-security -Wmissing-include-dirs -Wformat-nonliteral -Wpointer-arith -Winit-self -Wdeclaration-after-statement -Wfloat-equal -Wmissing-prototypes -Wredundant-decls -Wmissing-declarations -Wmissing-noreturn -Wshadow -Wendif-labels -Wcast-align -Wstrict-aliasing -Wwrite-strings -Wno-unused-parameter -fno-common -fdiagnostics-show-option -fdiagnostics-color=auto
D: [pulseaudio] main.c: Running on host: Linux x86_64 5.8.0-43-generic #49~20.04.1-Ubuntu SMP Fri Feb 5 09:57:56 UTC 2021
D: [pulseaudio] main.c: Found 8 CPUs.
I: [pulseaudio] main.c: Page size is 4096 bytes
D: [pulseaudio] main.c: Compiled with Valgrind support: no
D: [pulseaudio] main.c: Running in valgrind mode: no
D: [pulseaudio] main.c: Running in VM: no
D: [pulseaudio] main.c: Running from build tree: no
D: [pulseaudio] main.c: Optimized build: yes
D: [pulseaudio] main.c: FASTPATH defined, only fast path asserts disabled.
I: [pulseaudio] main.c: Machine ID is 179f3d3c69514ed79ff5423bd88fe9e0.
I: [pulseaudio] main.c: Using runtime directory /run/user/1000/pulse.
I: [pulseaudio] main.c: Using state directory /home/werner/.config/pulse.
I: [pulseaudio] main.c: Using modules directory /usr/lib/pulse-13.99.1/modules.
I: [pulseaudio] main.c: Running in system mode: no
E: [pulseaudio] pid.c: Daemon already running.
E: [pulseaudio] main.c: pa_pid_file_create() fehlgeschlagen.
marant...
2. Februar 2021
poste mal die Ausgaben
sudo dmesg | egrep -i "BOOT_IMAGE|Linux version|DMI:|snd|sound|audio|codec|hda|'/input'|fail"
sudo cat /proc/asound/cards
lspci -nnk | grep -A2 Audio
fuser -v /dev/snd/*
pactl info
pacmd list-cards
weholei
7. Februar 2019
Besten Dank für die Hilfe
wirlich alles posten?
root@ubu-20-home:~# sudo dmesg | egrep -i "BOOT_IMAGE|Linux version|DMI:|snd|sound|audio|codec|hda|'/input'|fail"
[    0.000000] Linux version 5.8.0-43-generic (buildd@lcy01-amd64-018) (gcc (Ubuntu 9.3.0-17ubuntu1~20.04) 9.3.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #49~20.04.1-Ubuntu SMP Fri Feb 5 09:57:56 UTC 2021 (Ubuntu 5.8.0-43.49~20.04.1-generic 5.8.18)
[    0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-5.8.0-43-generic root=UUID=e63c8d8d-a580-43fe-af7b-dca14163f296 ro quiet splash
[    0.000000] DMI: To Be Filled By O.E.M. To Be Filled By O.E.M./Z390 Pro4, BIOS P4.30 08/12/2019
[    0.042605] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.8.0-43-generic root=UUID=e63c8d8d-a580-43fe-af7b-dca14163f296 ro quiet splash
[    0.168571] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[    0.709394]     BOOT_IMAGE=/boot/vmlinuz-5.8.0-43-generic
[    5.516483] ata1.00: failed command: WRITE FPDMA QUEUED
[    5.516487] ata1.00: failed command: WRITE FPDMA QUEUED
[    5.516490] ata1.00: failed command: WRITE FPDMA QUEUED
[    5.516493] ata1.00: failed command: READ FPDMA QUEUED
[    5.516496] ata1.00: failed command: READ FPDMA QUEUED
[    5.839635] sd 0:0:0:0: [sda] tag#18 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
[    5.876476] ata1.00: failed command: READ FPDMA QUEUED
[    5.876480] ata1.00: failed command: READ FPDMA QUEUED
[    5.876498] ata1.00: failed command: READ FPDMA QUEUED
[    5.876501] ata1.00: failed command: READ FPDMA QUEUED
[    5.876504] ata1.00: failed command: WRITE FPDMA QUEUED
[    5.876507] ata1.00: failed command: WRITE FPDMA QUEUED
[    5.876509] ata1.00: failed command: WRITE FPDMA QUEUED
[    5.876512] ata1.00: failed command: WRITE FPDMA QUEUED
[    5.876515] ata1.00: failed command: READ FPDMA QUEUED
[    6.198465] sd 0:0:0:0: [sda] tag#4 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
[    6.198475] sd 0:0:0:0: [sda] tag#6 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
[    6.198497] sd 0:0:0:0: [sda] tag#21 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
[    6.260490] ata1.00: failed command: WRITE FPDMA QUEUED
[    6.260493] ata1.00: failed command: WRITE FPDMA QUEUED
[    6.260496] ata1.00: failed command: READ FPDMA QUEUED
[    6.260499] ata1.00: failed command: READ FPDMA QUEUED
[    6.260523] ata1.00: failed command: READ FPDMA QUEUED
[    6.583725] sd 0:0:0:0: [sda] tag#23 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
[    6.583738] sd 0:0:0:0: [sda] tag#24 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
[    6.583761] sd 0:0:0:0: [sda] tag#25 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
[    6.624483] ata1.00: failed command: READ FPDMA QUEUED
[    6.624487] ata1.00: failed command: READ FPDMA QUEUED
[    6.624490] ata1.00: failed command: READ FPDMA QUEUED
[    6.624493] ata1.00: failed command: WRITE FPDMA QUEUED
[    6.624496] ata1.00: failed command: READ FPDMA QUEUED
[    6.624498] ata1.00: failed command: READ FPDMA QUEUED
[    6.624501] ata1.00: failed command: READ FPDMA QUEUED
[    6.949309] sd 0:0:0:0: [sda] tag#8 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
[    6.949368] sd 0:0:0:0: [sda] tag#9 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
[    6.949402] sd 0:0:0:0: [sda] tag#14 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
[    7.008565] ata1.00: failed command: WRITE FPDMA QUEUED
[    7.008585] ata1.00: failed command: READ FPDMA QUEUED
[    7.008601] ata1.00: failed command: READ FPDMA QUEUED
[    7.008618] ata1.00: failed command: READ FPDMA QUEUED
[    7.384577] ata1.00: failed command: READ FPDMA QUEUED
[    7.384596] ata1.00: failed command: READ FPDMA QUEUED
[    7.384613] ata1.00: failed command: READ FPDMA QUEUED
[    7.384629] ata1.00: failed command: WRITE FPDMA QUEUED
[    7.384645] ata1.00: failed command: WRITE FPDMA QUEUED
[    7.384661] ata1.00: failed command: READ FPDMA QUEUED
[    7.384677] ata1.00: failed command: READ FPDMA QUEUED
[    7.384692] ata1.00: failed command: READ FPDMA QUEUED
[    7.742238] snd_hda_intel 0000:00:1f.3: enabling device (0000 -> 0002)
[    7.742448] snd_hda_intel 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[    7.773008] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC892: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:line
[    7.773009] snd_hda_codec_realtek hdaudioC0D0:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[    7.773010] snd_hda_codec_realtek hdaudioC0D0:    hp_outs=1 (0x1b/0x0/0x0/0x0/0x0)
[    7.773011] snd_hda_codec_realtek hdaudioC0D0:    mono: mono_out=0x0
[    7.773011] snd_hda_codec_realtek hdaudioC0D0:    inputs:
[    7.773012] snd_hda_codec_realtek hdaudioC0D0:      Front Mic=0x19
[    7.773013] snd_hda_codec_realtek hdaudioC0D0:      Rear Mic=0x18
[    7.773014] snd_hda_codec_realtek hdaudioC0D0:      Line=0x1a
[    7.800665] input: HDA Intel PCH Front Mic as /devices/pci0000:00/0000:00:1f.3/sound/card0/input6
[    7.800696] input: HDA Intel PCH Rear Mic as /devices/pci0000:00/0000:00:1f.3/sound/card0/input7
[    7.800720] input: HDA Intel PCH Line as /devices/pci0000:00/0000:00:1f.3/sound/card0/input8
[    7.800744] input: HDA Intel PCH Line Out as /devices/pci0000:00/0000:00:1f.3/sound/card0/input9
[    7.800775] input: HDA Intel PCH Front Headphone as /devices/pci0000:00/0000:00:1f.3/sound/card0/input10
[    7.800802] input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input11
[    7.800834] input: HDA Intel PCH HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input12
[    7.800865] input: HDA Intel PCH HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input13
[    7.800896] input: HDA Intel PCH HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input14
[    7.800922] input: HDA Intel PCH HDMI/DP,pcm=10 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input15
[    7.964591] ata1.00: failed command: READ FPDMA QUEUED
[    7.964610] ata1.00: failed command: READ FPDMA QUEUED
[    7.964627] ata1.00: failed command: READ FPDMA QUEUED
[    7.964643] ata1.00: failed command: READ FPDMA QUEUED
[    7.964659] ata1.00: failed command: READ FPDMA QUEUED
[    7.964674] ata1.00: failed command: READ FPDMA QUEUED
[    7.964690] ata1.00: failed command: READ FPDMA QUEUED
[    7.964706] ata1.00: failed command: READ FPDMA QUEUED
[    7.964721] ata1.00: failed command: READ FPDMA QUEUED
[    7.964736] ata1.00: failed command: READ FPDMA QUEUED
[    7.964751] ata1.00: failed command: READ FPDMA QUEUED
[    7.964767] ata1.00: failed command: READ FPDMA QUEUED
[    7.964782] ata1.00: failed command: READ FPDMA QUEUED
[    7.964797] ata1.00: failed command: READ FPDMA QUEUED
[    7.964812] ata1.00: failed command: READ FPDMA QUEUED
[    8.443892] vboxdrv: module verification failed: signature and/or required key missing - tainting kernel
[   10.664594] ata1.00: failed command: READ FPDMA QUEUED
[   10.989390] sd 0:0:0:0: [sda] tag#14 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
[   25.532249] CIFS: VFS: cifs_mount failed w/return code = -2
r
ich denk mal da habe ich schon einen Fehler
weitere logs gerne, wenn benötigt
leider kann ich mit den Fehlermeldungen nicht viel anfangen
was mir aufgefallen ist, auf einer min19 installation auf gleichem Rechner stottert der Ton auch
marant...
2. Februar 2021
hiermit
kann ich Dir nicht helfen. Erstmal abklären, was mit der HD los ist. Wenn sich Hier Keiner dazu meldet mache ein Thema im entsprechenden Bereich auf.
weholei
7. Februar 2019
Herzlichen Dank für den Hinweis
Ich denke mal, mit Hd meinst du die SSD-Festplatte
Ich habe mal meine alte SSD mit Ubuntu 16.04 gebootet um zu vergleichen
werner@ubu-16:~$ sudo dmesg | egrep -i "BOOT_IMAGE|Linux version|DMI:|snd|sound|audio|codec|hda|'/input'|fail"
[sudo] Passwort für werner:
[    0.000000] Linux version 4.15.0-107-generic (buildd@lcy01-amd64-010) (gcc version 5.4.0 20160609 (Ubuntu 5.4.0-6ubuntu1~16.04.12)) #108~16.04.1-Ubuntu SMP Fri Jun 12 02:57:13 UTC 2020 (Ubuntu 4.15.0-107.108~16.04.1-generic 4.15.18)
[    0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-4.15.0-107-generic root=UUID=bf314b45-6b4d-4c20-828b-b5d7a46135a7 ro quiet splash
[    0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.15.0-107-generic root=UUID=bf314b45-6b4d-4c20-828b-b5d7a46135a7 ro quiet splash
[    0.052959] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[    5.727552] snd_hda_intel 0000:00:1f.3: enabling device (0000 -> 0002)
[    5.727700] snd_hda_intel 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[    5.758819] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC892: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:line
[    5.758820] snd_hda_codec_realtek hdaudioC0D0:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[    5.758821] snd_hda_codec_realtek hdaudioC0D0:    hp_outs=1 (0x1b/0x0/0x0/0x0/0x0)
[    5.758822] snd_hda_codec_realtek hdaudioC0D0:    mono: mono_out=0x0
[    5.758822] snd_hda_codec_realtek hdaudioC0D0:    inputs:
[    5.758823] snd_hda_codec_realtek hdaudioC0D0:      Front Mic=0x19
[    5.758824] snd_hda_codec_realtek hdaudioC0D0:      Rear Mic=0x18
[    5.758824] snd_hda_codec_realtek hdaudioC0D0:      Line=0x1a
[    5.784626] input: HDA Intel PCH Front Mic as /devices/pci0000:00/0000:00:1f.3/sound/card0/input6
[    5.784691] input: HDA Intel PCH Rear Mic as /devices/pci0000:00/0000:00:1f.3/sound/card0/input7
[    5.784746] input: HDA Intel PCH Line as /devices/pci0000:00/0000:00:1f.3/sound/card0/input8
[    5.784802] input: HDA Intel PCH Line Out as /devices/pci0000:00/0000:00:1f.3/sound/card0/input9
[    5.784853] input: HDA Intel PCH Front Headphone as /devices/pci0000:00/0000:00:1f.3/sound/card0/input10
[    5.784874] input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input11
[    5.784893] input: HDA Intel PCH HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input12
[    5.784912] input: HDA Intel PCH HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input13
[    5.784931] input: HDA Intel PCH HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input14
[    5.784951] input: HDA Intel PCH HDMI/DP,pcm=10 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input15
[   13.891815] CIFS VFS: cifs_mount failed w/return code = -112
[   16.012226] vboxdrv: module verification failed: signature and/or required key missing - tainting kernel
Fehlermeldungen kann ich nicht erkennen.
allerdings stottert auch hier der Ton und die Anzeige für Lautstärke flackert.
Hatte aber da noch eine externe, ältere Grafikkarte drin, da Ubuntu16 die interne nicht erkannt hat.
Diese habe ich aber ausgebaut als ich Ubuntu20 installiert habe
marant...
2. Februar 2021
entwirre das mal.. 🙄
Also jetzt ist eine andere SSD drin. Heißt das Du hast das BS auf die Neuere gespielt und dann geupdatet auf 20.04.?
weholei
7. Februar 2019
Das habe schon befürchtet, dass es jetzt kompliziert wird
Ich habe einen Wechselschacht für die SSD, da ich gerne mal was ausprobiere.
die Ubuntu 16 Installation ist älter und auf einer separaten SSD
die Ubuntu 20 Version ebenfalls, neu installiert vor ca. 2 Monaten
aber ich habe jetzt nochmal das Bios kontrolliert und die (nicht mehr vorhandene) PCI Grafikkarte abgeschaltet und auf intern umgestellt
jetzt schaut die Ausgabe schon besser aus:
werner@ubu-20-home:~$ sudo dmesg | egrep -i "BOOT_IMAGE|Linux version|DMI:|snd|sound|audio|codec|hda|'/input'|fail"
[    0.042509] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.8.0-43-generic root=UUID=e63c8d8d-a580-43fe-af7b-dca14163f296 ro quiet splash
[    0.168565] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[    0.678726]     BOOT_IMAGE=/boot/vmlinuz-5.8.0-43-generic
[    5.531928] snd_hda_intel 0000:00:1f.3: enabling device (0000 -> 0002)
[    5.532135] snd_hda_intel 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[    5.601426] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC892: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:line
[    5.601427] snd_hda_codec_realtek hdaudioC0D0:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[    5.601428] snd_hda_codec_realtek hdaudioC0D0:    hp_outs=1 (0x1b/0x0/0x0/0x0/0x0)
[    5.601428] snd_hda_codec_realtek hdaudioC0D0:    mono: mono_out=0x0
[    5.601429] snd_hda_codec_realtek hdaudioC0D0:    inputs:
[    5.601430] snd_hda_codec_realtek hdaudioC0D0:      Front Mic=0x19
[    5.601430] snd_hda_codec_realtek hdaudioC0D0:      Rear Mic=0x18
[    5.601431] snd_hda_codec_realtek hdaudioC0D0:      Line=0x1a
[    5.626246] input: HDA Intel PCH Front Mic as /devices/pci0000:00/0000:00:1f.3/sound/card0/input6
[    5.626274] input: HDA Intel PCH Rear Mic as /devices/pci0000:00/0000:00:1f.3/sound/card0/input7
[    5.626294] input: HDA Intel PCH Line as /devices/pci0000:00/0000:00:1f.3/sound/card0/input8
[    5.626314] input: HDA Intel PCH Line Out as /devices/pci0000:00/0000:00:1f.3/sound/card0/input9
[    5.626336] input: HDA Intel PCH Front Headphone as /devices/pci0000:00/0000:00:1f.3/sound/card0/input10
[    5.626356] input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input11
[    5.626375] input: HDA Intel PCH HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input12
[    5.626394] input: HDA Intel PCH HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input13
[    5.626413] input: HDA Intel PCH HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input14
[    5.626432] input: HDA Intel PCH HDMI/DP,pcm=10 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input15
[    5.764029] vboxdrv: module verification failed: signature and/or required key missing - tainting kernel
[   28.909966] CIFS: VFS: cifs_mount failed w/return code = -2
Aber Aussetzer hat der Sound immer noch, reproduzierbar, wenn ich eine Anwendung öffne
./. edit Rechtschreibung korrigiert
marant...
2. Februar 2021
OK, dann war's wohl der Wechselschacht/Kabel. Die SMART Werte würde ich ansehen und festhalten.(um tatsächliche Fehler später festzustellen)
Sound. Wenn Dies sowohl bei 16.04 als auch 20.04 auftritt würde Das eher für Hardware sprechen.
Es braucht noch ein paar Infos. Etwa ab welchem Zeitpunkt trat Das auf? Lief Das bisher auf diesem Rechner? Wurde /home übernommen, oder ist auch neu installiert? Windows vorh., läuft es da?
Testen kannst Du mal Folgendes:
Stecker, der jetzt im Line out ist mit Smarrnphone verbinden, ist Sound OK?
Das testen:
speaker-test -Dplug:front -c2 -twav
Im BIOS Soundeinst., gibt's da was?
weholei
7. Februar 2019
Besten Dank daß Du mir hilfst
hm, schwer zu sagen, normalerweise mache ich den Ton stumm wenn ich arbeite
davon gehe ich aus, habe ja Ton stumm, da mich der Klang bei Start einer Win-VM nervte
definitiv nicht, ist eine andere Festplatte
Windows ist nur als VM drauf, mein Händler sagte, daß man auf den Rechner mein win7 nicht mehr installieren kann (keine Treiber, kein CD-Rom) und win10 Lizenz habe ich mir gespart, Rechner ist ca. 1 1/2 Jahre alt
Smartphone hab ich nicht, habe aber meinen Fernseh Kofhörer in allen 3 Buchsen auf der Rückseite probiert, kein Ton
Wenn ich die grüne Buchse in der Mitte verwende, wird in Einstellungen ein Line-Ausgang-Eingebautes Tongerät angezeigt, zusätzlich zu Hdmi port, und die Anzeige flackert.
Ich denke inzwischen auch in Richtung Hardwaredefekt, vor allem weil bereits 2 x beim Arbeiten die VM abstürzte und sogar der Ubuntu Host nicht mehr reagierte
aber wie die Fehlersuche anfangen?
Nicht daß ich wüsste, aber ich schau gerne ich mal, wenn ich mit Arbeit fertig bin und Rechner herunterfahren kann
