Guten Tag! Ich habe Probleme mit meinem WLAN an einem Thinkpad T440s. Das Problem habe ich nicht nur bei uns daheim, sondern auch an der Arbeitsstelle. Ich habe hier ein LTE WLAN, das an sich nicht wirklich gut empfängt, jedoch können alle anderen aus der WG problemlos WLAN empfangen. Alle Handys abenfalls.
uname -a Linux flo-ThinkPad-T440s 4.13.0-37-generic #42-Ubuntu SMP Wed Mar 7 14:13:23 UTC 2018 x86_64 x86_64 x86_64 GNU/Linux
lspci -nnk | grep -i net -A2 00:19.0 Ethernet controller [0200]: Intel Corporation Ethernet Connection I218-LM [8086:155a] (rev 04) Subsystem: Lenovo ThinkPad X240 [17aa:2214] Kernel driver in use: e1000e -- 03:00.0 Network controller [0280]: Intel Corporation Wireless 7260 [8086:08b2] (rev 83) Subsystem: Intel Corporation Dual Band Wireless-AC 7260 [8086:c270] Kernel driver in use: iwlwifi
cat /etc/network/interfaces # interfaces(5) file used by ifup(8) and ifdown(8) auto lo iface lo inet loopback
cat /etc/resolv.conf # This file is managed by man:systemd-resolved(8). Do not edit. # # 127.0.0.53 is the systemd-resolved stub resolver. # run "systemd-resolve --status" to see details about the actual nameservers. nameserver 127.0.0.53
cat /etc/hosts
ifconfig -a enp0s25: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500 ether 68:f7:28:12:e9:25 txqueuelen 1000 (Ethernet) RX packets 0 bytes 0 (0.0 B) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 0 bytes 0 (0.0 B) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 device interrupt 20 memory 0xf0600000-f0620000 lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536 inet 127.0.0.1 netmask 255.0.0.0 inet6 ::1 prefixlen 128 scopeid 0x10<host> loop txqueuelen 1000 (Lokale Schleife) RX packets 10765 bytes 834624 (834.6 KB) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 10765 bytes 834624 (834.6 KB) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 wlp3s0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500 inet 192.168.8.142 netmask 255.255.255.0 broadcast 192.168.8.255 inet6 fdc4:86e9:77c3:100:e8ab:1904:be3a:deb7 prefixlen 64 scopeid 0x0<global> inet6 fe80::494:9035:1d7e:a prefixlen 64 scopeid 0x20<link> inet6 fdc4:86e9:77c3:100:43ee:6f98:5767:2d5a prefixlen 64 scopeid 0x0<global> ether 28:b2:bd:73:96:87 txqueuelen 1000 (Ethernet) RX packets 133011 bytes 173149192 (173.1 MB) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 80600 bytes 12403873 (12.4 MB) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 wwp0s20u4i6: flags=4226<BROADCAST,NOARP,MULTICAST> mtu 1500 ether fa:02:1c:52:38:7b txqueuelen 1000 (Ethernet) RX packets 0 bytes 0 (0.0 B) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 0 bytes 0 (0.0 B) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
iwconfig enp0s25 no wireless extensions. wlp3s0 IEEE 802.11 ESSID:"gigacube_5G-C302" Mode:Managed Frequency:5.5 GHz Access Point: C4:86:E9:77:C3:04 Bit Rate=18 Mb/s Tx-Power=22 dBm Retry short limit:7 RTS thr:off Fragment thr:off Power Management:on Link Quality=39/70 Signal level=-71 dBm Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0 Tx excessive retries:0 Invalid misc:95 Missed beacon:0 wwp0s20u4i6 no wireless extensions. lo no wireless extensions.
route -n Kernel-IP-Routentabelle Ziel Router Genmask Flags Metric Ref Use Iface 0.0.0.0 192.168.8.1 0.0.0.0 UG 600 0 0 wlp3s0 169.254.0.0 0.0.0.0 255.255.0.0 U 1000 0 0 wlp3s0 192.168.8.0 0.0.0.0 255.255.255.0 U 600 0 0 wlp3s0
arp -av giga.cube (192.168.8.1) auf c4:86:e9:77:c3:01 [ether] auf wlp3s0 Einträge: 1 Ignoriert: 0 Gefunden: 1
ip neigh show 192.168.8.1 dev wlp3s0 lladdr c4:86:e9:77:c3:01 REACHABLE fe80::c686:e9ff:fe77:c301 dev wlp3s0 lladdr c4:86:e9:77:c3:01 router STALE
cat /var/lib/NetworkManager/NetworkManager.state [main] NetworkingEnabled=true WirelessEnabled=true WWANEnabled=false
cat /etc/NetworkManager/NetworkManager.conf [main] plugins=ifupdown,keyfile [ifupdown] managed=false [device] wifi.scan-rand-mac-address=no
cat /etc/udev/rules.d/70-persistent-net.rules | egrep -i 'device|sub' -A3 cat: /etc/udev/rules.d/70-persistent-net.rules: Datei oder Verzeichnis nicht gefunden
ping -c 2 $(route -n | grep UG | awk {'print $2'}) PING 192.168.8.1 (192.168.8.1) 56(84) bytes of data. 64 bytes from 192.168.8.1: icmp_seq=1 ttl=64 time=2.11 ms 64 bytes from 192.168.8.1: icmp_seq=2 ttl=64 time=1.77 ms --- 192.168.8.1 ping statistics --- 2 packets transmitted, 2 received, 0% packet loss, time 1001ms rtt min/avg/max/mdev = 1.777/1.947/2.117/0.170 ms
ping -c 2 www.ubuntuusers.de PING ubuntuusers.de (213.95.41.4) 56(84) bytes of data. 64 bytes from ha.ubuntu-eu.org (213.95.41.4): icmp_seq=1 ttl=54 time=32.3 ms 64 bytes from ha.ubuntu-eu.org (213.95.41.4): icmp_seq=2 ttl=54 time=35.5 ms --- ubuntuusers.de ping statistics --- 2 packets transmitted, 2 received, 0% packet loss, time 1001ms rtt min/avg/max/mdev = 32.341/33.935/35.529/1.594 ms
rfkill list 0: tpacpi_bluetooth_sw: Bluetooth Soft blocked: no Hard blocked: no 1: tpacpi_wwan_sw: Wireless WAN Soft blocked: yes Hard blocked: no 2: phy0: Wireless LAN Soft blocked: no Hard blocked: no 6: hci0: Bluetooth Soft blocked: no Hard blocked: no
lsmod Module Size Used by uas 24576 0 usb_storage 69632 1 uas usblp 20480 0 ccm 20480 6 rfcomm 77824 14 acpi_call 16384 0 msr 16384 0 cmac 16384 1 bnep 20480 2 cdc_mbim 16384 0 cdc_ncm 36864 1 cdc_mbim usbnet 45056 2 cdc_mbim,cdc_ncm cdc_wdm 20480 2 cdc_mbim cdc_acm 32768 0 mii 16384 1 usbnet uvcvideo 90112 0 videobuf2_vmalloc 16384 1 uvcvideo videobuf2_memops 16384 1 videobuf2_vmalloc videobuf2_v4l2 24576 1 uvcvideo videobuf2_core 40960 2 uvcvideo,videobuf2_v4l2 videodev 176128 3 uvcvideo,videobuf2_core,videobuf2_v4l2 media 40960 2 uvcvideo,videodev pci_stub 16384 1 vboxpci 24576 0 vboxnetadp 28672 0 vboxnetflt 28672 0 btusb 45056 0 btrtl 16384 1 btusb btbcm 16384 1 btusb btintel 16384 1 btusb bluetooth 544768 41 btrtl,btintel,bnep,btbcm,rfcomm,btusb ecdh_generic 24576 1 bluetooth vboxdrv 471040 3 vboxnetadp,vboxnetflt,vboxpci nls_iso8859_1 16384 1 arc4 16384 2 intel_rapl 20480 0 x86_pkg_temp_thermal 16384 0 intel_powerclamp 16384 0 coretemp 16384 0 kvm_intel 200704 0 kvm 585728 1 kvm_intel irqbypass 16384 1 kvm crct10dif_pclmul 16384 0 crc32_pclmul 16384 0 snd_seq_midi 16384 0 ghash_clmulni_intel 16384 0 snd_seq_midi_event 16384 1 snd_seq_midi pcbc 16384 0 snd_hda_codec_hdmi 49152 1 aesni_intel 188416 6 iwlmvm 385024 0 snd_rawmidi 32768 1 snd_seq_midi aes_x86_64 20480 1 aesni_intel crypto_simd 16384 1 aesni_intel snd_hda_codec_realtek 94208 1 glue_helper 16384 1 aesni_intel snd_hda_codec_generic 73728 1 snd_hda_codec_realtek input_leds 16384 0 mac80211 782336 1 iwlmvm joydev 20480 0 cryptd 24576 3 crypto_simd,ghash_clmulni_intel,aesni_intel snd_seq 65536 2 snd_seq_midi_event,snd_seq_midi serio_raw 16384 0 snd_hda_intel 40960 4 intel_cstate 20480 0 intel_rapl_perf 16384 0 iwlwifi 253952 1 iwlmvm thinkpad_acpi 94208 1 wmi_bmof 16384 0 rtsx_pci_ms 20480 0 snd_hda_codec 126976 4 snd_hda_intel,snd_hda_codec_hdmi,snd_hda_codec_generic,snd_hda_codec_realtek memstick 16384 1 rtsx_pci_ms nvram 16384 1 thinkpad_acpi snd_hda_core 81920 5 snd_hda_intel,snd_hda_codec,snd_hda_codec_hdmi,snd_hda_codec_generic,snd_hda_codec_realtek snd_hwdep 20480 1 snd_hda_codec cfg80211 614400 3 iwlmvm,iwlwifi,mac80211 snd_seq_device 16384 3 snd_seq,snd_rawmidi,snd_seq_midi lpc_ich 24576 0 snd_pcm 98304 4 snd_hda_intel,snd_hda_codec,snd_hda_core,snd_hda_codec_hdmi mei_me 40960 0 mei 102400 1 mei_me shpchp 36864 0 snd_timer 32768 2 snd_seq,snd_pcm snd 81920 20 snd_hda_intel,snd_hwdep,snd_seq,snd_hda_codec,snd_timer,thinkpad_acpi,snd_rawmidi,snd_hda_codec_hdmi,snd_hda_codec_generic,snd_seq_device,snd_hda_codec_realtek,snd_pcm soundcore 16384 1 snd mac_hid 16384 0 parport_pc 32768 0 ppdev 20480 0 lp 20480 0 parport 49152 3 lp,parport_pc,ppdev ip_tables 24576 0 x_tables 40960 1 ip_tables autofs4 40960 2 hid_generic 16384 0 usbhid 49152 0 hid 118784 2 hid_generic,usbhid rtsx_pci_sdmmc 24576 0 i915 1822720 20 psmouse 147456 0 i2c_algo_bit 16384 1 i915 ahci 36864 4 drm_kms_helper 167936 1 i915 e1000e 249856 0 libahci 32768 1 ahci rtsx_pci 57344 2 rtsx_pci_sdmmc,rtsx_pci_ms syscopyarea 16384 1 drm_kms_helper sysfillrect 16384 1 drm_kms_helper ptp 20480 1 e1000e sysimgblt 16384 1 drm_kms_helper fb_sys_fops 16384 1 drm_kms_helper pps_core 20480 1 ptp drm 360448 9 i915,drm_kms_helper wmi 24576 1 wmi_bmof video 40960 2 thinkpad_acpi,i915
iwlist chan enp0s25 no frequency information. wlp3s0 32 channels in total; available frequencies : Channel 01 : 2.412 GHz Channel 02 : 2.417 GHz Channel 03 : 2.422 GHz Channel 04 : 2.427 GHz Channel 05 : 2.432 GHz Channel 06 : 2.437 GHz Channel 07 : 2.442 GHz Channel 08 : 2.447 GHz Channel 09 : 2.452 GHz Channel 10 : 2.457 GHz Channel 11 : 2.462 GHz Channel 12 : 2.467 GHz Channel 13 : 2.472 GHz Channel 36 : 5.18 GHz Channel 40 : 5.2 GHz Channel 44 : 5.22 GHz Channel 48 : 5.24 GHz Channel 52 : 5.26 GHz Channel 56 : 5.28 GHz Channel 60 : 5.3 GHz Channel 64 : 5.32 GHz Channel 100 : 5.5 GHz Channel 104 : 5.52 GHz Channel 108 : 5.54 GHz Channel 112 : 5.56 GHz Channel 116 : 5.58 GHz Channel 120 : 5.6 GHz Channel 124 : 5.62 GHz Channel 128 : 5.64 GHz Channel 132 : 5.66 GHz Channel 136 : 5.68 GHz Channel 140 : 5.7 GHz Current Frequency:5.5 GHz (Channel 100) wwp0s20u4i6 no frequency information. lo no frequency information.
sudo iwlist scan enp0s25 Interface doesn't support scanning. wlp3s0 Scan completed : Cell 01 - Address: C4:86:E9:77:C3:04 Channel:100 Frequency:5.5 GHz (Channel 100) Quality=33/70 Signal level=-77 dBm Encryption key:on ESSID:"gigacube_5G-C302" Bit Rates:6 Mb/s; 9 Mb/s; 12 Mb/s; 18 Mb/s; 24 Mb/s 36 Mb/s; 48 Mb/s; 54 Mb/s Mode:Master Extra:tsf=0000002130d8303b Extra: Last beacon: 65932ms ago IE: Unknown: 001067696761637562655F35472D43333032 IE: Unknown: 01088C129824B048606C IE: Unknown: 050400010000 IE: Unknown: 07344445202401172801172C01173001173401173801173C011740011764011E68011E6C011E70011E74011E84011E88011E8C011E00 IE: Unknown: 200100 IE: Unknown: 23021400 IE: IEEE 802.11i/WPA2 Version 1 Group Cipher : CCMP Pairwise Ciphers (1) : CCMP Authentication Suites (1) : PSK IE: Unknown: 0B050100010000 IE: Unknown: 46053208010000 IE: Unknown: 2D1AEF0917FFFF000000000000000000000000000000000000000000 IE: Unknown: 3D16640D0400000000000000000000000000000000000000 IE: Unknown: 7F080400080000000040 IE: Unknown: BF0CB259810FFAFF0000FAFF0000 IE: Unknown: C005016A000000 IE: Unknown: C30402020202 IE: Unknown: DD310050F204104A000110104400010210470010D96C7EFC2F8938F1EFBD6E5148BFA812103C0001031049000600372A000120 IE: Unknown: DD090010180201001C0000 IE: Unknown: DD180050F2020101840003A4000027A4000042435E0062322F00 wwp0s20u4i6 Interface doesn't support scanning. lo Interface doesn't support scanning.
egrep -i 'net|eth|wlan|firm|reason' /var/log/syslog Mar 26 11:31:52 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522056712.2094] manager: sleep requested (sleeping: no enabled: yes) Mar 26 11:31:52 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522056712.2095] manager: sleeping... Mar 26 11:31:52 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522056712.2096] device (enp0s25): state change: unavailable -> unmanaged (reason 'sleeping', internal state 'managed') Mar 26 11:31:52 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522056712.5692] device (cdc-wdm3): state change: unavailable -> unmanaged (reason 'sleeping', internal state 'external') Mar 26 11:31:52 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522056712.5700] manager: NetworkManager state is now ASLEEP Mar 26 11:31:52 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522056712.5711] device (wlp3s0): state change: activated -> deactivating (reason 'sleeping', internal state 'managed') Mar 26 11:31:52 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522056712.5766] device (wlp3s0): state change: deactivating -> disconnected (reason 'sleeping', internal state 'managed') Mar 26 11:31:52 flo-ThinkPad-T440s systemd[1]: Starting Network Manager Script Dispatcher Service... Mar 26 11:31:52 flo-ThinkPad-T440s systemd[1]: Started Network Manager Script Dispatcher Service. Mar 26 11:31:52 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522056712.6111] dhcp4 (wlp3s0): canceled DHCP transaction, DHCP client pid 1919 Mar 26 11:31:52 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522056712.6112] dhcp4 (wlp3s0): state changed bound -> done Mar 26 11:31:52 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522056712.6115] dhcp6 (wlp3s0): canceled DHCP transaction Mar 26 11:31:52 flo-ThinkPad-T440s kernel: [ 2270.998214] wlp3s0: deauthenticating from c4:86:e9:77:c3:04 by local choice (Reason: 3=DEAUTH_LEAVING) Mar 26 11:31:52 flo-ThinkPad-T440s wpa_supplicant[1041]: wlp3s0: CTRL-EVENT-DISCONNECTED bssid=c4:86:e9:77:c3:04 reason=3 locally_generated=1 Mar 26 11:31:52 flo-ThinkPad-T440s NetworkManager[895]: <warn> [1522056712.6300] sup-iface[0x7fd79c007350,wlp3s0]: connection disconnected (reason -3) Mar 26 11:31:52 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522056712.6305] device (wlp3s0): supplicant interface state: completed -> disconnected Mar 26 11:31:52 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522056712.6371] device (wlp3s0): state change: disconnected -> unmanaged (reason 'sleeping', internal state 'managed') Mar 26 12:50:14 flo-ThinkPad-T440s kernel: [ 2274.365550] usb 2-4: device firmware changed Mar 26 12:50:14 flo-ThinkPad-T440s kernel: [ 2275.176263] Bluetooth: hci0: Intel Bluetooth firmware file: intel/ibt-hw-37.7.10-fw-1.80.2.3.d.bseq Mar 26 12:50:14 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061414.4216] devices removed (path: /sys/devices/pci0000:00/0000:00:14.0/usb2/2-4/2-4:1.6/net/wwp0s20u4i6, iface: wwp0s20u4i6) Mar 26 12:50:14 flo-ThinkPad-T440s kernel: [ 2275.228371] IPv6: ADDRCONF(NETDEV_UP): enp0s25: link is not ready Mar 26 12:50:14 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061414.4483] manager: wake requested (sleeping: yes enabled: yes) Mar 26 12:50:14 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061414.4484] manager: waking up... Mar 26 12:50:14 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061414.4484] device (enp0s25): state change: unmanaged -> unavailable (reason 'managed', internal state 'managed') Mar 26 12:50:14 flo-ThinkPad-T440s kernel: [ 2275.306034] Bluetooth: hci0: Intel Bluetooth firmware patch completed and activated Mar 26 12:50:14 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061414.6396] device (wlp3s0): state change: unmanaged -> unavailable (reason 'managed', internal state 'managed') Mar 26 12:50:14 flo-ThinkPad-T440s kernel: [ 2275.417629] IPv6: ADDRCONF(NETDEV_UP): enp0s25: link is not ready Mar 26 12:50:14 flo-ThinkPad-T440s kernel: [ 2275.419645] IPv6: ADDRCONF(NETDEV_UP): wlp3s0: link is not ready Mar 26 12:50:14 flo-ThinkPad-T440s kernel: [ 2275.673617] IPv6: ADDRCONF(NETDEV_UP): wlp3s0: link is not ready Mar 26 12:50:14 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061414.8993] manager: NetworkManager state is now DISCONNECTED Mar 26 12:50:14 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061414.9378] audit: op="radio-control" arg="wwan-enabled:0" pid=4333 uid=0 result="success" Mar 26 12:50:14 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061414.9619] device (wlp3s0): supplicant interface state: starting -> ready Mar 26 12:50:14 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061414.9620] device (wlp3s0): state change: unavailable -> disconnected (reason 'supplicant-available', internal state 'managed') Mar 26 12:50:14 flo-ThinkPad-T440s kernel: [ 2275.741809] IPv6: ADDRCONF(NETDEV_UP): wlp3s0: link is not ready Mar 26 12:50:16 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061416.3453] devices added (path: /sys/devices/pci0000:00/0000:00:14.0/usb2/2-4/2-4:1.6/net/wwp0s20u4i6, iface: wwp0s20u4i6) Mar 26 12:50:16 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061416.3454] device added (path: /sys/devices/pci0000:00/0000:00:14.0/usb2/2-4/2-4:1.6/net/wwp0s20u4i6, iface: wwp0s20u4i6): no ifupdown configuration found. Mar 26 12:50:18 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061418.2169] device (wlp3s0): supplicant interface state: ready -> inactive Mar 26 12:50:31 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061431.2378] device (cdc-wdm2): state change: unmanaged -> unavailable (reason 'none', internal state 'external') Mar 26 12:50:31 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061431.2379] device (cdc-wdm2): modem state 'failed' Mar 26 12:50:31 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061431.2385] manager: (cdc-wdm2): new Broadband device (/org/freedesktop/NetworkManager/Devices/5) Mar 26 12:50:31 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061431.2389] modem-broadband[cdc-wdm2]: failed to retrieve SIM object: No SIM object available Mar 26 12:50:44 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061444.4908] device (wlp3s0): supplicant interface state: inactive -> scanning Mar 26 12:51:21 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061481.8213] policy: auto-activating connection 'gigacube_5G-C302' Mar 26 12:51:21 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061481.8248] device (wlp3s0): Activation: starting connection 'gigacube_5G-C302' (cc70faae-f0dc-437f-a09c-a4a9a0ed07ae) Mar 26 12:51:21 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061481.8256] device (wlp3s0): state change: disconnected -> prepare (reason 'none', internal state 'managed') Mar 26 12:51:21 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061481.8259] manager: NetworkManager state is now CONNECTING Mar 26 12:51:21 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061481.8266] device (wlp3s0): state change: prepare -> config (reason 'none', internal state 'managed') Mar 26 12:51:21 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061481.8268] device (wlp3s0): Activation: (wifi) access point 'gigacube_5G-C302' has security, but secrets are required. Mar 26 12:51:21 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061481.8268] device (wlp3s0): state change: config -> need-auth (reason 'none', internal state 'managed') Mar 26 12:51:21 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061481.8395] device (wlp3s0): state change: need-auth -> prepare (reason 'none', internal state 'managed') Mar 26 12:51:21 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061481.8399] device (wlp3s0): state change: prepare -> config (reason 'none', internal state 'managed') Mar 26 12:51:21 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061481.8404] device (wlp3s0): Activation: (wifi) connection 'gigacube_5G-C302' has security, and secrets exist. No new secrets needed. Mar 26 12:51:21 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061481.8404] Config: added 'ssid' value 'gigacube_5G-C302' Mar 26 12:51:21 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061481.8405] Config: added 'scan_ssid' value '1' Mar 26 12:51:21 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061481.8405] Config: added 'key_mgmt' value 'WPA-PSK' Mar 26 12:51:21 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061481.8405] Config: added 'auth_alg' value 'OPEN' Mar 26 12:51:21 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061481.8405] Config: added 'psk' value '<hidden>' Mar 26 12:51:21 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061481.8550] device (wlp3s0): supplicant interface state: scanning -> authenticating Mar 26 12:51:21 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061481.8611] device (wlp3s0): supplicant interface state: authenticating -> associating Mar 26 12:51:21 flo-ThinkPad-T440s kernel: [ 2342.645485] IPv6: ADDRCONF(NETDEV_CHANGE): wlp3s0: link becomes ready Mar 26 12:51:21 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061481.8713] device (wlp3s0): supplicant interface state: associating -> associated Mar 26 12:51:21 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061481.8782] device (wlp3s0): supplicant interface state: associated -> 4-way handshake Mar 26 12:51:21 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061481.8887] device (wlp3s0): supplicant interface state: 4-way handshake -> completed Mar 26 12:51:21 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061481.8888] device (wlp3s0): Activation: (wifi) Stage 2 of 5 (Device Configure) successful. Connected to wireless network 'gigacube_5G-C302'. Mar 26 12:51:21 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061481.8888] device (wlp3s0): state change: config -> ip-config (reason 'none', internal state 'managed') Mar 26 12:51:21 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061481.8893] dhcp4 (wlp3s0): activation: beginning transaction (timeout in 45 seconds) Mar 26 12:51:21 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061481.8911] dhcp4 (wlp3s0): dhclient started with pid 4513 Mar 26 12:51:24 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061484.2318] dhcp6 (wlp3s0): activation: beginning transaction (timeout in 45 seconds) Mar 26 12:51:24 flo-ThinkPad-T440s NetworkManager[895]: <warn> [1522061484.2319] dhcp6 (wlp3s0): hostname is not a FQDN, it will be ignored Mar 26 12:51:24 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061484.2350] dhcp6 (wlp3s0): dhclient started with pid 4522 Mar 26 12:51:24 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061484.3691] dhcp6 (wlp3s0): nameserver 'fe80::c686:e9ff:fe77:c301' Mar 26 12:51:24 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061484.3692] dhcp6 (wlp3s0): state changed unknown -> bound Mar 26 12:51:24 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061484.3709] dhcp6 (wlp3s0): client pid 4522 exited with status 0 Mar 26 12:51:24 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061484.3709] dhcp6 (wlp3s0): state changed bound -> done Mar 26 12:51:24 flo-ThinkPad-T440s systemd[1]: Starting Network Manager Script Dispatcher Service... Mar 26 12:51:24 flo-ThinkPad-T440s systemd[1]: Started Network Manager Script Dispatcher Service. Mar 26 12:51:25 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061485.0095] dhcp4 (wlp3s0): address 192.168.8.142 Mar 26 12:51:25 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061485.0095] dhcp4 (wlp3s0): plen 24 (255.255.255.0) Mar 26 12:51:25 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061485.0096] dhcp4 (wlp3s0): gateway 192.168.8.1 Mar 26 12:51:25 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061485.0096] dhcp4 (wlp3s0): lease time 86400 Mar 26 12:51:25 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061485.0096] dhcp4 (wlp3s0): nameserver '192.168.8.1' Mar 26 12:51:25 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061485.0096] dhcp4 (wlp3s0): state changed unknown -> bound Mar 26 12:51:25 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061485.0122] device (wlp3s0): state change: ip-config -> ip-check (reason 'none', internal state 'managed') Mar 26 12:51:25 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061485.0128] device (wlp3s0): state change: ip-check -> secondaries (reason 'none', internal state 'managed') Mar 26 12:51:25 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061485.0131] device (wlp3s0): state change: secondaries -> activated (reason 'none', internal state 'managed') Mar 26 12:51:25 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061485.0133] manager: NetworkManager state is now CONNECTED_LOCAL Mar 26 12:51:25 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061485.0170] manager: NetworkManager state is now CONNECTED_GLOBAL Mar 26 12:51:25 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061485.0171] policy: set 'gigacube_5G-C302' (wlp3s0) as default for IPv4 routing and DNS Mar 26 12:51:25 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061485.0175] device (wlp3s0): Activation: successful, device activated. Mar 26 12:51:25 flo-ThinkPad-T440s whoopsie[1110]: [12:51:25] The default IPv4 route is: /org/freedesktop/NetworkManager/ActiveConnection/2 Mar 26 12:51:25 flo-ThinkPad-T440s whoopsie[1110]: [12:51:25] Not a paid data plan: /org/freedesktop/NetworkManager/ActiveConnection/2 Mar 26 12:51:25 flo-ThinkPad-T440s whoopsie[1110]: [12:51:25] Found usable connection: /org/freedesktop/NetworkManager/ActiveConnection/2 Mar 26 13:16:31 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522062991.4714] manager: sleep requested (sleeping: no enabled: yes) Mar 26 13:16:31 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522062991.4714] manager: sleeping... Mar 26 13:16:31 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522062991.4715] device (enp0s25): state change: unavailable -> unmanaged (reason 'sleeping', internal state 'managed') Mar 26 13:16:31 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522062991.8378] device (cdc-wdm2): state change: unavailable -> unmanaged (reason 'sleeping', internal state 'external') Mar 26 13:16:31 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522062991.8382] manager: NetworkManager state is now ASLEEP Mar 26 13:16:31 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522062991.8400] device (wlp3s0): state change: activated -> deactivating (reason 'sleeping', internal state 'managed') Mar 26 13:16:31 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522062991.8460] device (wlp3s0): state change: deactivating -> disconnected (reason 'sleeping', internal state 'managed') Mar 26 13:16:31 flo-ThinkPad-T440s systemd[1]: Starting Network Manager Script Dispatcher Service... Mar 26 13:16:31 flo-ThinkPad-T440s systemd[1]: Started Network Manager Script Dispatcher Service. Mar 26 13:16:31 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522062991.8800] dhcp4 (wlp3s0): canceled DHCP transaction, DHCP client pid 4513 Mar 26 13:16:31 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522062991.8800] dhcp4 (wlp3s0): state changed bound -> done Mar 26 13:16:31 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522062991.8803] dhcp6 (wlp3s0): canceled DHCP transaction Mar 26 13:16:31 flo-ThinkPad-T440s kernel: [ 3852.665045] wlp3s0: deauthenticating from c4:86:e9:77:c3:04 by local choice (Reason: 3=DEAUTH_LEAVING) Mar 26 13:16:31 flo-ThinkPad-T440s wpa_supplicant[1041]: wlp3s0: CTRL-EVENT-DISCONNECTED bssid=c4:86:e9:77:c3:04 reason=3 locally_generated=1 Mar 26 13:16:31 flo-ThinkPad-T440s NetworkManager[895]: <warn> [1522062991.8971] sup-iface[0x562039bd8ab0,wlp3s0]: connection disconnected (reason -3) Mar 26 13:16:31 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522062991.8973] device (wlp3s0): supplicant interface state: completed -> disconnected Mar 26 13:16:31 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522062991.9016] device (wlp3s0): state change: disconnected -> unmanaged (reason 'sleeping', internal state 'managed') Mar 26 19:59:02 flo-ThinkPad-T440s kernel: [ 3855.476508] usb 2-4: device firmware changed Mar 26 19:59:02 flo-ThinkPad-T440s kernel: [ 3856.553155] Bluetooth: hci0: Intel Bluetooth firmware file: intel/ibt-hw-37.7.10-fw-1.80.2.3.d.bseq Mar 26 19:59:02 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087142.4657] manager: wake requested (sleeping: yes enabled: yes) Mar 26 19:59:02 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087142.4658] manager: waking up... Mar 26 19:59:02 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087142.4659] device (enp0s25): state change: unmanaged -> unavailable (reason 'managed', internal state 'managed') Mar 26 19:59:02 flo-ThinkPad-T440s kernel: [ 3856.616673] IPv6: ADDRCONF(NETDEV_UP): enp0s25: link is not ready Mar 26 19:59:02 flo-ThinkPad-T440s kernel: [ 3856.690018] Bluetooth: hci0: Intel Bluetooth firmware patch completed and activated Mar 26 19:59:02 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087142.6549] device (wlp3s0): state change: unmanaged -> unavailable (reason 'managed', internal state 'managed') Mar 26 19:59:02 flo-ThinkPad-T440s kernel: [ 3856.804526] IPv6: ADDRCONF(NETDEV_UP): enp0s25: link is not ready Mar 26 19:59:02 flo-ThinkPad-T440s kernel: [ 3856.805727] IPv6: ADDRCONF(NETDEV_UP): wlp3s0: link is not ready Mar 26 19:59:02 flo-ThinkPad-T440s kernel: [ 3857.062880] IPv6: ADDRCONF(NETDEV_UP): wlp3s0: link is not ready Mar 26 19:59:02 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087142.9136] manager: NetworkManager state is now DISCONNECTED Mar 26 19:59:02 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087142.9144] devices removed (path: /sys/devices/pci0000:00/0000:00:14.0/usb2/2-4/2-4:1.6/net/wwp0s20u4i6, iface: wwp0s20u4i6) Mar 26 19:59:02 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087142.9366] audit: op="radio-control" arg="wwan-enabled:0" pid=5616 uid=0 result="success" Mar 26 19:59:02 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087142.9765] device (wlp3s0): supplicant interface state: starting -> ready Mar 26 19:59:02 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087142.9766] device (wlp3s0): state change: unavailable -> disconnected (reason 'supplicant-available', internal state 'managed') Mar 26 19:59:02 flo-ThinkPad-T440s kernel: [ 3857.127297] IPv6: ADDRCONF(NETDEV_UP): wlp3s0: link is not ready Mar 26 19:59:04 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087144.3456] devices added (path: /sys/devices/pci0000:00/0000:00:14.0/usb2/2-4/2-4:1.6/net/wwp0s20u4i6, iface: wwp0s20u4i6) Mar 26 19:59:04 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087144.3456] device added (path: /sys/devices/pci0000:00/0000:00:14.0/usb2/2-4/2-4:1.6/net/wwp0s20u4i6, iface: wwp0s20u4i6): no ifupdown configuration found. Mar 26 19:59:06 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087146.2307] device (wlp3s0): supplicant interface state: ready -> inactive Mar 26 19:59:19 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087159.8782] device (cdc-wdm2): state change: unmanaged -> unavailable (reason 'none', internal state 'external') Mar 26 19:59:19 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087159.8785] device (cdc-wdm2): modem state 'failed' Mar 26 19:59:19 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087159.8809] manager: (cdc-wdm2): new Broadband device (/org/freedesktop/NetworkManager/Devices/6) Mar 26 19:59:19 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087159.8819] modem-broadband[cdc-wdm2]: failed to retrieve SIM object: No SIM object available Mar 26 19:59:43 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087183.1071] device (wlp3s0): supplicant interface state: inactive -> scanning Mar 26 19:59:43 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087183.1098] policy: auto-activating connection 'gigacube_5G-C302' Mar 26 19:59:43 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087183.1111] device (wlp3s0): Activation: starting connection 'gigacube_5G-C302' (cc70faae-f0dc-437f-a09c-a4a9a0ed07ae) Mar 26 19:59:43 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087183.1114] device (wlp3s0): state change: disconnected -> prepare (reason 'none', internal state 'managed') Mar 26 19:59:43 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087183.1115] manager: NetworkManager state is now CONNECTING Mar 26 19:59:43 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087183.1120] device (wlp3s0): state change: prepare -> config (reason 'none', internal state 'managed') Mar 26 19:59:43 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087183.1122] device (wlp3s0): Activation: (wifi) access point 'gigacube_5G-C302' has security, but secrets are required. Mar 26 19:59:43 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087183.1122] device (wlp3s0): state change: config -> need-auth (reason 'none', internal state 'managed') Mar 26 19:59:43 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087183.1244] device (wlp3s0): state change: need-auth -> prepare (reason 'none', internal state 'managed') Mar 26 19:59:43 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087183.1247] device (wlp3s0): state change: prepare -> config (reason 'none', internal state 'managed') Mar 26 19:59:43 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087183.1249] device (wlp3s0): Activation: (wifi) connection 'gigacube_5G-C302' has security, and secrets exist. No new secrets needed. Mar 26 19:59:43 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087183.1250] Config: added 'ssid' value 'gigacube_5G-C302' Mar 26 19:59:43 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087183.1250] Config: added 'scan_ssid' value '1' Mar 26 19:59:43 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087183.1250] Config: added 'key_mgmt' value 'WPA-PSK' Mar 26 19:59:43 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087183.1250] Config: added 'auth_alg' value 'OPEN' Mar 26 19:59:43 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087183.1250] Config: added 'psk' value '<hidden>' Mar 26 19:59:43 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087183.1396] device (wlp3s0): supplicant interface state: scanning -> authenticating Mar 26 19:59:43 flo-ThinkPad-T440s kernel: [ 3897.295673] IPv6: ADDRCONF(NETDEV_CHANGE): wlp3s0: link becomes ready Mar 26 19:59:43 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087183.1467] device (wlp3s0): supplicant interface state: authenticating -> associated Mar 26 19:59:43 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087183.1560] device (wlp3s0): supplicant interface state: associated -> 4-way handshake Mar 26 19:59:43 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087183.1694] device (wlp3s0): supplicant interface state: 4-way handshake -> completed Mar 26 19:59:43 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087183.1694] device (wlp3s0): Activation: (wifi) Stage 2 of 5 (Device Configure) successful. Connected to wireless network 'gigacube_5G-C302'. Mar 26 19:59:43 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087183.1695] device (wlp3s0): state change: config -> ip-config (reason 'none', internal state 'managed') Mar 26 19:59:43 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087183.1699] dhcp4 (wlp3s0): activation: beginning transaction (timeout in 45 seconds) Mar 26 19:59:43 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087183.1714] dhcp4 (wlp3s0): dhclient started with pid 5773 Mar 26 19:59:45 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087185.0748] dhcp6 (wlp3s0): activation: beginning transaction (timeout in 45 seconds) Mar 26 19:59:45 flo-ThinkPad-T440s NetworkManager[895]: <warn> [1522087185.0749] dhcp6 (wlp3s0): hostname is not a FQDN, it will be ignored Mar 26 19:59:45 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087185.0762] dhcp6 (wlp3s0): dhclient started with pid 5802 Mar 26 19:59:45 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087185.8772] dhcp6 (wlp3s0): nameserver 'fe80::c686:e9ff:fe77:c301' Mar 26 19:59:45 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087185.8772] dhcp6 (wlp3s0): state changed unknown -> bound Mar 26 19:59:45 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087185.8797] dhcp6 (wlp3s0): client pid 5802 exited with status 0 Mar 26 19:59:45 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087185.8797] dhcp6 (wlp3s0): state changed bound -> done Mar 26 19:59:45 flo-ThinkPad-T440s systemd[1]: Starting Network Manager Script Dispatcher Service... Mar 26 19:59:45 flo-ThinkPad-T440s systemd[1]: Started Network Manager Script Dispatcher Service. Mar 26 19:59:46 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087186.1504] device (wlp3s0): state change: ip-config -> ip-check (reason 'none', internal state 'managed') Mar 26 19:59:46 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087186.1518] device (wlp3s0): state change: ip-check -> secondaries (reason 'none', internal state 'managed') Mar 26 19:59:46 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087186.1532] device (wlp3s0): state change: secondaries -> activated (reason 'none', internal state 'managed') Mar 26 19:59:46 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087186.1538] manager: NetworkManager state is now CONNECTED_LOCAL Mar 26 19:59:46 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087186.1641] device (wlp3s0): Activation: successful, device activated. Mar 26 19:59:46 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087186.8327] dhcp4 (wlp3s0): address 192.168.8.142 Mar 26 19:59:46 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087186.8327] dhcp4 (wlp3s0): plen 24 (255.255.255.0) Mar 26 19:59:46 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087186.8327] dhcp4 (wlp3s0): gateway 192.168.8.1 Mar 26 19:59:46 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087186.8327] dhcp4 (wlp3s0): lease time 86400 Mar 26 19:59:46 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087186.8327] dhcp4 (wlp3s0): nameserver '192.168.8.1' Mar 26 19:59:46 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087186.8327] dhcp4 (wlp3s0): state changed unknown -> bound Mar 26 19:59:46 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087186.8353] manager: NetworkManager state is now CONNECTED_GLOBAL Mar 26 19:59:46 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087186.8354] policy: set 'gigacube_5G-C302' (wlp3s0) as default for IPv4 routing and DNS Mar 26 19:59:46 flo-ThinkPad-T440s whoopsie[1110]: [19:59:46] The default IPv4 route is: /org/freedesktop/NetworkManager/ActiveConnection/3 Mar 26 19:59:46 flo-ThinkPad-T440s whoopsie[1110]: [19:59:46] Not a paid data plan: /org/freedesktop/NetworkManager/ActiveConnection/3 Mar 26 19:59:46 flo-ThinkPad-T440s whoopsie[1110]: [19:59:46] Found usable connection: /org/freedesktop/NetworkManager/ActiveConnection/3 Mar 26 20:12:05 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087925.1646] manager: sleep requested (sleeping: no enabled: yes) Mar 26 20:12:05 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087925.1646] manager: sleeping... Mar 26 20:12:05 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087925.1647] device (enp0s25): state change: unavailable -> unmanaged (reason 'sleeping', internal state 'managed') Mar 26 20:12:05 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087925.5221] device (cdc-wdm2): state change: unavailable -> unmanaged (reason 'sleeping', internal state 'external') Mar 26 20:12:05 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087925.5223] manager: NetworkManager state is now ASLEEP Mar 26 20:12:05 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087925.5239] device (wlp3s0): state change: activated -> deactivating (reason 'sleeping', internal state 'managed') Mar 26 20:12:05 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087925.5272] device (wlp3s0): state change: deactivating -> disconnected (reason 'sleeping', internal state 'managed') Mar 26 20:12:05 flo-ThinkPad-T440s systemd[1]: Starting Network Manager Script Dispatcher Service... Mar 26 20:12:05 flo-ThinkPad-T440s systemd[1]: Started Network Manager Script Dispatcher Service. Mar 26 20:12:05 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087925.5615] dhcp4 (wlp3s0): canceled DHCP transaction, DHCP client pid 5773 Mar 26 20:12:05 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087925.5615] dhcp4 (wlp3s0): state changed bound -> done Mar 26 20:12:05 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087925.5620] dhcp6 (wlp3s0): canceled DHCP transaction Mar 26 20:12:05 flo-ThinkPad-T440s kernel: [ 4639.715520] wlp3s0: deauthenticating from c4:86:e9:77:c3:04 by local choice (Reason: 3=DEAUTH_LEAVING) Mar 26 20:12:05 flo-ThinkPad-T440s wpa_supplicant[1041]: wlp3s0: CTRL-EVENT-DISCONNECTED bssid=c4:86:e9:77:c3:04 reason=3 locally_generated=1 Mar 26 20:12:05 flo-ThinkPad-T440s NetworkManager[895]: <warn> [1522087925.5748] sup-iface[0x562039bd8f10,wlp3s0]: connection disconnected (reason -3) Mar 26 20:12:05 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087925.5764] device (wlp3s0): state change: disconnected -> unmanaged (reason 'sleeping', internal state 'managed') Mar 26 20:41:28 flo-ThinkPad-T440s kernel: [ 4645.240705] Bluetooth: hci0: Intel Bluetooth firmware file: intel/ibt-hw-37.7.10-fw-1.80.2.3.d.bseq Mar 26 20:41:28 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089688.4629] manager: wake requested (sleeping: yes enabled: yes) Mar 26 20:41:28 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089688.4629] manager: waking up... Mar 26 20:41:28 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089688.4630] device (enp0s25): state change: unmanaged -> unavailable (reason 'managed', internal state 'managed') Mar 26 20:41:28 flo-ThinkPad-T440s kernel: [ 4645.346474] IPv6: ADDRCONF(NETDEV_UP): enp0s25: link is not ready Mar 26 20:41:28 flo-ThinkPad-T440s kernel: [ 4645.416114] Bluetooth: hci0: Intel Bluetooth firmware patch completed and activated Mar 26 20:41:28 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089688.6507] device (wlp3s0): state change: unmanaged -> unavailable (reason 'managed', internal state 'managed') Mar 26 20:41:28 flo-ThinkPad-T440s kernel: [ 4645.533186] IPv6: ADDRCONF(NETDEV_UP): enp0s25: link is not ready Mar 26 20:41:28 flo-ThinkPad-T440s kernel: [ 4645.534082] IPv6: ADDRCONF(NETDEV_UP): wlp3s0: link is not ready Mar 26 20:41:28 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089688.9123] manager: NetworkManager state is now DISCONNECTED Mar 26 20:41:28 flo-ThinkPad-T440s kernel: [ 4645.794011] IPv6: ADDRCONF(NETDEV_UP): wlp3s0: link is not ready Mar 26 20:41:28 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089688.9636] audit: op="radio-control" arg="wwan-enabled:0" pid=6719 uid=0 result="success" Mar 26 20:41:28 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089688.9879] device (wlp3s0): supplicant interface state: starting -> ready Mar 26 20:41:28 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089688.9879] device (wlp3s0): state change: unavailable -> disconnected (reason 'supplicant-available', internal state 'managed') Mar 26 20:41:28 flo-ThinkPad-T440s kernel: [ 4645.871330] IPv6: ADDRCONF(NETDEV_UP): wlp3s0: link is not ready Mar 26 20:41:32 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089692.2438] device (wlp3s0): supplicant interface state: ready -> inactive Mar 26 20:41:49 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089709.1464] device (cdc-wdm2): state change: unmanaged -> unavailable (reason 'none', internal state 'external') Mar 26 20:41:49 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089709.1467] device (cdc-wdm2): modem state 'failed' Mar 26 20:41:49 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089709.1487] manager: (cdc-wdm2): new Broadband device (/org/freedesktop/NetworkManager/Devices/7) Mar 26 20:41:49 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089709.1502] modem-broadband[cdc-wdm2]: failed to retrieve SIM object: No SIM object available Mar 26 20:42:08 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089728.4043] device (wlp3s0): supplicant interface state: inactive -> scanning Mar 26 20:43:11 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089791.9806] manager: rfkill: WiFi hardware radio set disabled Mar 26 20:43:11 flo-ThinkPad-T440s wpa_supplicant[1041]: rfkill: WLAN soft blocked Mar 26 20:43:11 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089791.9806] device (wlp3s0): state change: disconnected -> unavailable (reason 'none', internal state 'managed') Mar 26 20:43:11 flo-ThinkPad-T440s wpa_supplicant[1041]: rfkill: WLAN soft blocked Mar 26 20:43:11 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089791.9819] audit: op="radio-control" arg="wireless-enabled:0" pid=1433 uid=1000 result="success" Mar 26 20:43:11 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089791.9845] manager: rfkill: WiFi now disabled by radio killswitch Mar 26 20:43:13 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089793.1673] manager: rfkill: WiFi hardware radio set enabled Mar 26 20:43:13 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089793.4148] audit: op="radio-control" arg="wireless-enabled:1" pid=1433 uid=1000 result="success" Mar 26 20:43:13 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089793.4154] manager: rfkill: WiFi now enabled by radio killswitch Mar 26 20:43:13 flo-ThinkPad-T440s kernel: [ 4750.297909] IPv6: ADDRCONF(NETDEV_UP): wlp3s0: link is not ready Mar 26 20:43:13 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089793.4802] device (wlp3s0): supplicant interface state: starting -> ready Mar 26 20:43:13 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089793.4803] device (wlp3s0): state change: unavailable -> disconnected (reason 'supplicant-available', internal state 'managed') Mar 26 20:43:13 flo-ThinkPad-T440s kernel: [ 4750.364001] IPv6: ADDRCONF(NETDEV_UP): wlp3s0: link is not ready Mar 26 20:43:16 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089796.7368] device (wlp3s0): supplicant interface state: ready -> inactive Mar 26 20:43:35 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089815.3953] device (wlp3s0): supplicant interface state: inactive -> scanning Mar 26 20:43:39 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089819.7256] policy: auto-activating connection 'gigacube_5G-C302' Mar 26 20:43:39 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089819.7272] device (wlp3s0): Activation: starting connection 'gigacube_5G-C302' (cc70faae-f0dc-437f-a09c-a4a9a0ed07ae) Mar 26 20:43:39 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089819.7279] device (wlp3s0): state change: disconnected -> prepare (reason 'none', internal state 'managed') Mar 26 20:43:39 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089819.7281] manager: NetworkManager state is now CONNECTING Mar 26 20:43:39 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089819.7288] device (wlp3s0): state change: prepare -> config (reason 'none', internal state 'managed') Mar 26 20:43:39 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089819.7290] device (wlp3s0): Activation: (wifi) access point 'gigacube_5G-C302' has security, but secrets are required. Mar 26 20:43:39 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089819.7291] device (wlp3s0): state change: config -> need-auth (reason 'none', internal state 'managed') Mar 26 20:43:39 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089819.7437] device (wlp3s0): state change: need-auth -> prepare (reason 'none', internal state 'managed') Mar 26 20:43:39 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089819.7440] device (wlp3s0): state change: prepare -> config (reason 'none', internal state 'managed') Mar 26 20:43:39 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089819.7441] device (wlp3s0): Activation: (wifi) connection 'gigacube_5G-C302' has security, and secrets exist. No new secrets needed. Mar 26 20:43:39 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089819.7442] Config: added 'ssid' value 'gigacube_5G-C302' Mar 26 20:43:39 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089819.7442] Config: added 'scan_ssid' value '1' Mar 26 20:43:39 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089819.7442] Config: added 'key_mgmt' value 'WPA-PSK' Mar 26 20:43:39 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089819.7442] Config: added 'auth_alg' value 'OPEN' Mar 26 20:43:39 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089819.7442] Config: added 'psk' value '<hidden>' Mar 26 20:43:39 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089819.7569] device (wlp3s0): supplicant interface state: scanning -> authenticating Mar 26 20:43:39 flo-ThinkPad-T440s kernel: [ 4776.645120] IPv6: ADDRCONF(NETDEV_CHANGE): wlp3s0: link becomes ready Mar 26 20:43:39 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089819.7631] device (wlp3s0): supplicant interface state: authenticating -> associated Mar 26 20:43:39 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089819.7733] device (wlp3s0): supplicant interface state: associated -> 4-way handshake Mar 26 20:43:39 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089819.7830] device (wlp3s0): supplicant interface state: 4-way handshake -> completed Mar 26 20:43:39 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089819.7830] device (wlp3s0): Activation: (wifi) Stage 2 of 5 (Device Configure) successful. Connected to wireless network 'gigacube_5G-C302'. Mar 26 20:43:39 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089819.7831] device (wlp3s0): state change: config -> ip-config (reason 'none', internal state 'managed') Mar 26 20:43:39 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089819.7835] dhcp4 (wlp3s0): activation: beginning transaction (timeout in 45 seconds) Mar 26 20:43:39 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089819.7849] dhcp4 (wlp3s0): dhclient started with pid 7161 Mar 26 20:43:41 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089821.1409] dhcp6 (wlp3s0): activation: beginning transaction (timeout in 45 seconds) Mar 26 20:43:41 flo-ThinkPad-T440s NetworkManager[895]: <warn> [1522089821.1410] dhcp6 (wlp3s0): hostname is not a FQDN, it will be ignored Mar 26 20:43:41 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089821.1420] dhcp6 (wlp3s0): dhclient started with pid 7170 Mar 26 20:43:41 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089821.7927] dhcp6 (wlp3s0): nameserver 'fe80::c686:e9ff:fe77:c301' Mar 26 20:43:41 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089821.7927] dhcp6 (wlp3s0): state changed unknown -> bound Mar 26 20:43:41 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089821.7952] dhcp6 (wlp3s0): client pid 7170 exited with status 0 Mar 26 20:43:41 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089821.7952] dhcp6 (wlp3s0): state changed bound -> done Mar 26 20:43:41 flo-ThinkPad-T440s systemd[1]: Starting Network Manager Script Dispatcher Service... Mar 26 20:43:41 flo-ThinkPad-T440s systemd[1]: Started Network Manager Script Dispatcher Service. Mar 26 20:43:42 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089822.3055] dhcp4 (wlp3s0): address 192.168.8.142 Mar 26 20:43:42 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089822.3056] dhcp4 (wlp3s0): plen 24 (255.255.255.0) Mar 26 20:43:42 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089822.3056] dhcp4 (wlp3s0): gateway 192.168.8.1 Mar 26 20:43:42 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089822.3056] dhcp4 (wlp3s0): lease time 86400 Mar 26 20:43:42 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089822.3057] dhcp4 (wlp3s0): nameserver '192.168.8.1' Mar 26 20:43:42 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089822.3057] dhcp4 (wlp3s0): state changed unknown -> bound Mar 26 20:43:42 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089822.3092] device (wlp3s0): state change: ip-config -> ip-check (reason 'none', internal state 'managed') Mar 26 20:43:42 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089822.3102] device (wlp3s0): state change: ip-check -> secondaries (reason 'none', internal state 'managed') Mar 26 20:43:42 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089822.3105] device (wlp3s0): state change: secondaries -> activated (reason 'none', internal state 'managed') Mar 26 20:43:42 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089822.3106] manager: NetworkManager state is now CONNECTED_LOCAL Mar 26 20:43:42 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089822.3141] manager: NetworkManager state is now CONNECTED_GLOBAL Mar 26 20:43:42 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089822.3143] policy: set 'gigacube_5G-C302' (wlp3s0) as default for IPv4 routing and DNS Mar 26 20:43:42 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089822.3156] device (wlp3s0): Activation: successful, device activated. Mar 26 20:43:42 flo-ThinkPad-T440s whoopsie[1110]: [20:43:42] The default IPv4 route is: /org/freedesktop/NetworkManager/ActiveConnection/4 Mar 26 20:43:42 flo-ThinkPad-T440s whoopsie[1110]: [20:43:42] Not a paid data plan: /org/freedesktop/NetworkManager/ActiveConnection/4 Mar 26 20:43:42 flo-ThinkPad-T440s whoopsie[1110]: [20:43:42] Found usable connection: /org/freedesktop/NetworkManager/ActiveConnection/4
egrep -i 'net|eth|wlan|firm|reason' /var/log/syslog Mar 26 11:31:52 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522056712.2094] manager: sleep requested (sleeping: no enabled: yes) Mar 26 11:31:52 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522056712.2095] manager: sleeping... Mar 26 11:31:52 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522056712.2096] device (enp0s25): state change: unavailable -> unmanaged (reason 'sleeping', internal state 'managed') Mar 26 11:31:52 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522056712.5692] device (cdc-wdm3): state change: unavailable -> unmanaged (reason 'sleeping', internal state 'external') Mar 26 11:31:52 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522056712.5700] manager: NetworkManager state is now ASLEEP Mar 26 11:31:52 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522056712.5711] device (wlp3s0): state change: activated -> deactivating (reason 'sleeping', internal state 'managed') Mar 26 11:31:52 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522056712.5766] device (wlp3s0): state change: deactivating -> disconnected (reason 'sleeping', internal state 'managed') Mar 26 11:31:52 flo-ThinkPad-T440s systemd[1]: Starting Network Manager Script Dispatcher Service... Mar 26 11:31:52 flo-ThinkPad-T440s systemd[1]: Started Network Manager Script Dispatcher Service. Mar 26 11:31:52 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522056712.6111] dhcp4 (wlp3s0): canceled DHCP transaction, DHCP client pid 1919 Mar 26 11:31:52 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522056712.6112] dhcp4 (wlp3s0): state changed bound -> done Mar 26 11:31:52 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522056712.6115] dhcp6 (wlp3s0): canceled DHCP transaction Mar 26 11:31:52 flo-ThinkPad-T440s kernel: [ 2270.998214] wlp3s0: deauthenticating from c4:86:e9:77:c3:04 by local choice (Reason: 3=DEAUTH_LEAVING) Mar 26 11:31:52 flo-ThinkPad-T440s wpa_supplicant[1041]: wlp3s0: CTRL-EVENT-DISCONNECTED bssid=c4:86:e9:77:c3:04 reason=3 locally_generated=1 Mar 26 11:31:52 flo-ThinkPad-T440s NetworkManager[895]: <warn> [1522056712.6300] sup-iface[0x7fd79c007350,wlp3s0]: connection disconnected (reason -3) Mar 26 11:31:52 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522056712.6305] device (wlp3s0): supplicant interface state: completed -> disconnected Mar 26 11:31:52 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522056712.6371] device (wlp3s0): state change: disconnected -> unmanaged (reason 'sleeping', internal state 'managed') Mar 26 12:50:14 flo-ThinkPad-T440s kernel: [ 2274.365550] usb 2-4: device firmware changed Mar 26 12:50:14 flo-ThinkPad-T440s kernel: [ 2275.176263] Bluetooth: hci0: Intel Bluetooth firmware file: intel/ibt-hw-37.7.10-fw-1.80.2.3.d.bseq Mar 26 12:50:14 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061414.4216] devices removed (path: /sys/devices/pci0000:00/0000:00:14.0/usb2/2-4/2-4:1.6/net/wwp0s20u4i6, iface: wwp0s20u4i6) Mar 26 12:50:14 flo-ThinkPad-T440s kernel: [ 2275.228371] IPv6: ADDRCONF(NETDEV_UP): enp0s25: link is not ready Mar 26 12:50:14 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061414.4483] manager: wake requested (sleeping: yes enabled: yes) Mar 26 12:50:14 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061414.4484] manager: waking up... Mar 26 12:50:14 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061414.4484] device (enp0s25): state change: unmanaged -> unavailable (reason 'managed', internal state 'managed') Mar 26 12:50:14 flo-ThinkPad-T440s kernel: [ 2275.306034] Bluetooth: hci0: Intel Bluetooth firmware patch completed and activated Mar 26 12:50:14 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061414.6396] device (wlp3s0): state change: unmanaged -> unavailable (reason 'managed', internal state 'managed') Mar 26 12:50:14 flo-ThinkPad-T440s kernel: [ 2275.417629] IPv6: ADDRCONF(NETDEV_UP): enp0s25: link is not ready Mar 26 12:50:14 flo-ThinkPad-T440s kernel: [ 2275.419645] IPv6: ADDRCONF(NETDEV_UP): wlp3s0: link is not ready Mar 26 12:50:14 flo-ThinkPad-T440s kernel: [ 2275.673617] IPv6: ADDRCONF(NETDEV_UP): wlp3s0: link is not ready Mar 26 12:50:14 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061414.8993] manager: NetworkManager state is now DISCONNECTED Mar 26 12:50:14 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061414.9378] audit: op="radio-control" arg="wwan-enabled:0" pid=4333 uid=0 result="success" Mar 26 12:50:14 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061414.9619] device (wlp3s0): supplicant interface state: starting -> ready Mar 26 12:50:14 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061414.9620] device (wlp3s0): state change: unavailable -> disconnected (reason 'supplicant-available', internal state 'managed') Mar 26 12:50:14 flo-ThinkPad-T440s kernel: [ 2275.741809] IPv6: ADDRCONF(NETDEV_UP): wlp3s0: link is not ready Mar 26 12:50:16 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061416.3453] devices added (path: /sys/devices/pci0000:00/0000:00:14.0/usb2/2-4/2-4:1.6/net/wwp0s20u4i6, iface: wwp0s20u4i6) Mar 26 12:50:16 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061416.3454] device added (path: /sys/devices/pci0000:00/0000:00:14.0/usb2/2-4/2-4:1.6/net/wwp0s20u4i6, iface: wwp0s20u4i6): no ifupdown configuration found. Mar 26 12:50:18 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061418.2169] device (wlp3s0): supplicant interface state: ready -> inactive Mar 26 12:50:31 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061431.2378] device (cdc-wdm2): state change: unmanaged -> unavailable (reason 'none', internal state 'external') Mar 26 12:50:31 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061431.2379] device (cdc-wdm2): modem state 'failed' Mar 26 12:50:31 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061431.2385] manager: (cdc-wdm2): new Broadband device (/org/freedesktop/NetworkManager/Devices/5) Mar 26 12:50:31 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061431.2389] modem-broadband[cdc-wdm2]: failed to retrieve SIM object: No SIM object available Mar 26 12:50:44 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061444.4908] device (wlp3s0): supplicant interface state: inactive -> scanning Mar 26 12:51:21 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061481.8213] policy: auto-activating connection 'gigacube_5G-C302' Mar 26 12:51:21 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061481.8248] device (wlp3s0): Activation: starting connection 'gigacube_5G-C302' (cc70faae-f0dc-437f-a09c-a4a9a0ed07ae) Mar 26 12:51:21 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061481.8256] device (wlp3s0): state change: disconnected -> prepare (reason 'none', internal state 'managed') Mar 26 12:51:21 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061481.8259] manager: NetworkManager state is now CONNECTING Mar 26 12:51:21 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061481.8266] device (wlp3s0): state change: prepare -> config (reason 'none', internal state 'managed') Mar 26 12:51:21 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061481.8268] device (wlp3s0): Activation: (wifi) access point 'gigacube_5G-C302' has security, but secrets are required. Mar 26 12:51:21 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061481.8268] device (wlp3s0): state change: config -> need-auth (reason 'none', internal state 'managed') Mar 26 12:51:21 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061481.8395] device (wlp3s0): state change: need-auth -> prepare (reason 'none', internal state 'managed') Mar 26 12:51:21 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061481.8399] device (wlp3s0): state change: prepare -> config (reason 'none', internal state 'managed') Mar 26 12:51:21 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061481.8404] device (wlp3s0): Activation: (wifi) connection 'gigacube_5G-C302' has security, and secrets exist. No new secrets needed. Mar 26 12:51:21 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061481.8404] Config: added 'ssid' value 'gigacube_5G-C302' Mar 26 12:51:21 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061481.8405] Config: added 'scan_ssid' value '1' Mar 26 12:51:21 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061481.8405] Config: added 'key_mgmt' value 'WPA-PSK' Mar 26 12:51:21 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061481.8405] Config: added 'auth_alg' value 'OPEN' Mar 26 12:51:21 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061481.8405] Config: added 'psk' value '<hidden>' Mar 26 12:51:21 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061481.8550] device (wlp3s0): supplicant interface state: scanning -> authenticating Mar 26 12:51:21 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061481.8611] device (wlp3s0): supplicant interface state: authenticating -> associating Mar 26 12:51:21 flo-ThinkPad-T440s kernel: [ 2342.645485] IPv6: ADDRCONF(NETDEV_CHANGE): wlp3s0: link becomes ready Mar 26 12:51:21 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061481.8713] device (wlp3s0): supplicant interface state: associating -> associated Mar 26 12:51:21 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061481.8782] device (wlp3s0): supplicant interface state: associated -> 4-way handshake Mar 26 12:51:21 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061481.8887] device (wlp3s0): supplicant interface state: 4-way handshake -> completed Mar 26 12:51:21 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061481.8888] device (wlp3s0): Activation: (wifi) Stage 2 of 5 (Device Configure) successful. Connected to wireless network 'gigacube_5G-C302'. Mar 26 12:51:21 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061481.8888] device (wlp3s0): state change: config -> ip-config (reason 'none', internal state 'managed') Mar 26 12:51:21 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061481.8893] dhcp4 (wlp3s0): activation: beginning transaction (timeout in 45 seconds) Mar 26 12:51:21 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061481.8911] dhcp4 (wlp3s0): dhclient started with pid 4513 Mar 26 12:51:24 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061484.2318] dhcp6 (wlp3s0): activation: beginning transaction (timeout in 45 seconds) Mar 26 12:51:24 flo-ThinkPad-T440s NetworkManager[895]: <warn> [1522061484.2319] dhcp6 (wlp3s0): hostname is not a FQDN, it will be ignored Mar 26 12:51:24 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061484.2350] dhcp6 (wlp3s0): dhclient started with pid 4522 Mar 26 12:51:24 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061484.3691] dhcp6 (wlp3s0): nameserver 'fe80::c686:e9ff:fe77:c301' Mar 26 12:51:24 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061484.3692] dhcp6 (wlp3s0): state changed unknown -> bound Mar 26 12:51:24 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061484.3709] dhcp6 (wlp3s0): client pid 4522 exited with status 0 Mar 26 12:51:24 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061484.3709] dhcp6 (wlp3s0): state changed bound -> done Mar 26 12:51:24 flo-ThinkPad-T440s systemd[1]: Starting Network Manager Script Dispatcher Service... Mar 26 12:51:24 flo-ThinkPad-T440s systemd[1]: Started Network Manager Script Dispatcher Service. Mar 26 12:51:25 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061485.0095] dhcp4 (wlp3s0): address 192.168.8.142 Mar 26 12:51:25 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061485.0095] dhcp4 (wlp3s0): plen 24 (255.255.255.0) Mar 26 12:51:25 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061485.0096] dhcp4 (wlp3s0): gateway 192.168.8.1 Mar 26 12:51:25 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061485.0096] dhcp4 (wlp3s0): lease time 86400 Mar 26 12:51:25 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061485.0096] dhcp4 (wlp3s0): nameserver '192.168.8.1' Mar 26 12:51:25 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061485.0096] dhcp4 (wlp3s0): state changed unknown -> bound Mar 26 12:51:25 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061485.0122] device (wlp3s0): state change: ip-config -> ip-check (reason 'none', internal state 'managed') Mar 26 12:51:25 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061485.0128] device (wlp3s0): state change: ip-check -> secondaries (reason 'none', internal state 'managed') Mar 26 12:51:25 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061485.0131] device (wlp3s0): state change: secondaries -> activated (reason 'none', internal state 'managed') Mar 26 12:51:25 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061485.0133] manager: NetworkManager state is now CONNECTED_LOCAL Mar 26 12:51:25 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061485.0170] manager: NetworkManager state is now CONNECTED_GLOBAL Mar 26 12:51:25 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061485.0171] policy: set 'gigacube_5G-C302' (wlp3s0) as default for IPv4 routing and DNS Mar 26 12:51:25 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522061485.0175] device (wlp3s0): Activation: successful, device activated. Mar 26 12:51:25 flo-ThinkPad-T440s whoopsie[1110]: [12:51:25] The default IPv4 route is: /org/freedesktop/NetworkManager/ActiveConnection/2 Mar 26 12:51:25 flo-ThinkPad-T440s whoopsie[1110]: [12:51:25] Not a paid data plan: /org/freedesktop/NetworkManager/ActiveConnection/2 Mar 26 12:51:25 flo-ThinkPad-T440s whoopsie[1110]: [12:51:25] Found usable connection: /org/freedesktop/NetworkManager/ActiveConnection/2 Mar 26 13:16:31 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522062991.4714] manager: sleep requested (sleeping: no enabled: yes) Mar 26 13:16:31 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522062991.4714] manager: sleeping... Mar 26 13:16:31 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522062991.4715] device (enp0s25): state change: unavailable -> unmanaged (reason 'sleeping', internal state 'managed') Mar 26 13:16:31 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522062991.8378] device (cdc-wdm2): state change: unavailable -> unmanaged (reason 'sleeping', internal state 'external') Mar 26 13:16:31 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522062991.8382] manager: NetworkManager state is now ASLEEP Mar 26 13:16:31 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522062991.8400] device (wlp3s0): state change: activated -> deactivating (reason 'sleeping', internal state 'managed') Mar 26 13:16:31 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522062991.8460] device (wlp3s0): state change: deactivating -> disconnected (reason 'sleeping', internal state 'managed') Mar 26 13:16:31 flo-ThinkPad-T440s systemd[1]: Starting Network Manager Script Dispatcher Service... Mar 26 13:16:31 flo-ThinkPad-T440s systemd[1]: Started Network Manager Script Dispatcher Service. Mar 26 13:16:31 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522062991.8800] dhcp4 (wlp3s0): canceled DHCP transaction, DHCP client pid 4513 Mar 26 13:16:31 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522062991.8800] dhcp4 (wlp3s0): state changed bound -> done Mar 26 13:16:31 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522062991.8803] dhcp6 (wlp3s0): canceled DHCP transaction Mar 26 13:16:31 flo-ThinkPad-T440s kernel: [ 3852.665045] wlp3s0: deauthenticating from c4:86:e9:77:c3:04 by local choice (Reason: 3=DEAUTH_LEAVING) Mar 26 13:16:31 flo-ThinkPad-T440s wpa_supplicant[1041]: wlp3s0: CTRL-EVENT-DISCONNECTED bssid=c4:86:e9:77:c3:04 reason=3 locally_generated=1 Mar 26 13:16:31 flo-ThinkPad-T440s NetworkManager[895]: <warn> [1522062991.8971] sup-iface[0x562039bd8ab0,wlp3s0]: connection disconnected (reason -3) Mar 26 13:16:31 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522062991.8973] device (wlp3s0): supplicant interface state: completed -> disconnected Mar 26 13:16:31 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522062991.9016] device (wlp3s0): state change: disconnected -> unmanaged (reason 'sleeping', internal state 'managed') Mar 26 19:59:02 flo-ThinkPad-T440s kernel: [ 3855.476508] usb 2-4: device firmware changed Mar 26 19:59:02 flo-ThinkPad-T440s kernel: [ 3856.553155] Bluetooth: hci0: Intel Bluetooth firmware file: intel/ibt-hw-37.7.10-fw-1.80.2.3.d.bseq Mar 26 19:59:02 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087142.4657] manager: wake requested (sleeping: yes enabled: yes) Mar 26 19:59:02 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087142.4658] manager: waking up... Mar 26 19:59:02 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087142.4659] device (enp0s25): state change: unmanaged -> unavailable (reason 'managed', internal state 'managed') Mar 26 19:59:02 flo-ThinkPad-T440s kernel: [ 3856.616673] IPv6: ADDRCONF(NETDEV_UP): enp0s25: link is not ready Mar 26 19:59:02 flo-ThinkPad-T440s kernel: [ 3856.690018] Bluetooth: hci0: Intel Bluetooth firmware patch completed and activated Mar 26 19:59:02 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087142.6549] device (wlp3s0): state change: unmanaged -> unavailable (reason 'managed', internal state 'managed') Mar 26 19:59:02 flo-ThinkPad-T440s kernel: [ 3856.804526] IPv6: ADDRCONF(NETDEV_UP): enp0s25: link is not ready Mar 26 19:59:02 flo-ThinkPad-T440s kernel: [ 3856.805727] IPv6: ADDRCONF(NETDEV_UP): wlp3s0: link is not ready Mar 26 19:59:02 flo-ThinkPad-T440s kernel: [ 3857.062880] IPv6: ADDRCONF(NETDEV_UP): wlp3s0: link is not ready Mar 26 19:59:02 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087142.9136] manager: NetworkManager state is now DISCONNECTED Mar 26 19:59:02 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087142.9144] devices removed (path: /sys/devices/pci0000:00/0000:00:14.0/usb2/2-4/2-4:1.6/net/wwp0s20u4i6, iface: wwp0s20u4i6) Mar 26 19:59:02 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087142.9366] audit: op="radio-control" arg="wwan-enabled:0" pid=5616 uid=0 result="success" Mar 26 19:59:02 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087142.9765] device (wlp3s0): supplicant interface state: starting -> ready Mar 26 19:59:02 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087142.9766] device (wlp3s0): state change: unavailable -> disconnected (reason 'supplicant-available', internal state 'managed') Mar 26 19:59:02 flo-ThinkPad-T440s kernel: [ 3857.127297] IPv6: ADDRCONF(NETDEV_UP): wlp3s0: link is not ready Mar 26 19:59:04 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087144.3456] devices added (path: /sys/devices/pci0000:00/0000:00:14.0/usb2/2-4/2-4:1.6/net/wwp0s20u4i6, iface: wwp0s20u4i6) Mar 26 19:59:04 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087144.3456] device added (path: /sys/devices/pci0000:00/0000:00:14.0/usb2/2-4/2-4:1.6/net/wwp0s20u4i6, iface: wwp0s20u4i6): no ifupdown configuration found. Mar 26 19:59:06 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087146.2307] device (wlp3s0): supplicant interface state: ready -> inactive Mar 26 19:59:19 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087159.8782] device (cdc-wdm2): state change: unmanaged -> unavailable (reason 'none', internal state 'external') Mar 26 19:59:19 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087159.8785] device (cdc-wdm2): modem state 'failed' Mar 26 19:59:19 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087159.8809] manager: (cdc-wdm2): new Broadband device (/org/freedesktop/NetworkManager/Devices/6) Mar 26 19:59:19 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087159.8819] modem-broadband[cdc-wdm2]: failed to retrieve SIM object: No SIM object available Mar 26 19:59:43 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087183.1071] device (wlp3s0): supplicant interface state: inactive -> scanning Mar 26 19:59:43 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087183.1098] policy: auto-activating connection 'gigacube_5G-C302' Mar 26 19:59:43 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087183.1111] device (wlp3s0): Activation: starting connection 'gigacube_5G-C302' (cc70faae-f0dc-437f-a09c-a4a9a0ed07ae) Mar 26 19:59:43 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087183.1114] device (wlp3s0): state change: disconnected -> prepare (reason 'none', internal state 'managed') Mar 26 19:59:43 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087183.1115] manager: NetworkManager state is now CONNECTING Mar 26 19:59:43 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087183.1120] device (wlp3s0): state change: prepare -> config (reason 'none', internal state 'managed') Mar 26 19:59:43 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087183.1122] device (wlp3s0): Activation: (wifi) access point 'gigacube_5G-C302' has security, but secrets are required. Mar 26 19:59:43 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087183.1122] device (wlp3s0): state change: config -> need-auth (reason 'none', internal state 'managed') Mar 26 19:59:43 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087183.1244] device (wlp3s0): state change: need-auth -> prepare (reason 'none', internal state 'managed') Mar 26 19:59:43 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087183.1247] device (wlp3s0): state change: prepare -> config (reason 'none', internal state 'managed') Mar 26 19:59:43 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087183.1249] device (wlp3s0): Activation: (wifi) connection 'gigacube_5G-C302' has security, and secrets exist. No new secrets needed. Mar 26 19:59:43 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087183.1250] Config: added 'ssid' value 'gigacube_5G-C302' Mar 26 19:59:43 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087183.1250] Config: added 'scan_ssid' value '1' Mar 26 19:59:43 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087183.1250] Config: added 'key_mgmt' value 'WPA-PSK' Mar 26 19:59:43 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087183.1250] Config: added 'auth_alg' value 'OPEN' Mar 26 19:59:43 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087183.1250] Config: added 'psk' value '<hidden>' Mar 26 19:59:43 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087183.1396] device (wlp3s0): supplicant interface state: scanning -> authenticating Mar 26 19:59:43 flo-ThinkPad-T440s kernel: [ 3897.295673] IPv6: ADDRCONF(NETDEV_CHANGE): wlp3s0: link becomes ready Mar 26 19:59:43 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087183.1467] device (wlp3s0): supplicant interface state: authenticating -> associated Mar 26 19:59:43 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087183.1560] device (wlp3s0): supplicant interface state: associated -> 4-way handshake Mar 26 19:59:43 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087183.1694] device (wlp3s0): supplicant interface state: 4-way handshake -> completed Mar 26 19:59:43 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087183.1694] device (wlp3s0): Activation: (wifi) Stage 2 of 5 (Device Configure) successful. Connected to wireless network 'gigacube_5G-C302'. Mar 26 19:59:43 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087183.1695] device (wlp3s0): state change: config -> ip-config (reason 'none', internal state 'managed') Mar 26 19:59:43 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087183.1699] dhcp4 (wlp3s0): activation: beginning transaction (timeout in 45 seconds) Mar 26 19:59:43 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087183.1714] dhcp4 (wlp3s0): dhclient started with pid 5773 Mar 26 19:59:45 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087185.0748] dhcp6 (wlp3s0): activation: beginning transaction (timeout in 45 seconds) Mar 26 19:59:45 flo-ThinkPad-T440s NetworkManager[895]: <warn> [1522087185.0749] dhcp6 (wlp3s0): hostname is not a FQDN, it will be ignored Mar 26 19:59:45 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087185.0762] dhcp6 (wlp3s0): dhclient started with pid 5802 Mar 26 19:59:45 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087185.8772] dhcp6 (wlp3s0): nameserver 'fe80::c686:e9ff:fe77:c301' Mar 26 19:59:45 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087185.8772] dhcp6 (wlp3s0): state changed unknown -> bound Mar 26 19:59:45 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087185.8797] dhcp6 (wlp3s0): client pid 5802 exited with status 0 Mar 26 19:59:45 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087185.8797] dhcp6 (wlp3s0): state changed bound -> done Mar 26 19:59:45 flo-ThinkPad-T440s systemd[1]: Starting Network Manager Script Dispatcher Service... Mar 26 19:59:45 flo-ThinkPad-T440s systemd[1]: Started Network Manager Script Dispatcher Service. Mar 26 19:59:46 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087186.1504] device (wlp3s0): state change: ip-config -> ip-check (reason 'none', internal state 'managed') Mar 26 19:59:46 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087186.1518] device (wlp3s0): state change: ip-check -> secondaries (reason 'none', internal state 'managed') Mar 26 19:59:46 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087186.1532] device (wlp3s0): state change: secondaries -> activated (reason 'none', internal state 'managed') Mar 26 19:59:46 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087186.1538] manager: NetworkManager state is now CONNECTED_LOCAL Mar 26 19:59:46 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087186.1641] device (wlp3s0): Activation: successful, device activated. Mar 26 19:59:46 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087186.8327] dhcp4 (wlp3s0): address 192.168.8.142 Mar 26 19:59:46 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087186.8327] dhcp4 (wlp3s0): plen 24 (255.255.255.0) Mar 26 19:59:46 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087186.8327] dhcp4 (wlp3s0): gateway 192.168.8.1 Mar 26 19:59:46 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087186.8327] dhcp4 (wlp3s0): lease time 86400 Mar 26 19:59:46 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087186.8327] dhcp4 (wlp3s0): nameserver '192.168.8.1' Mar 26 19:59:46 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087186.8327] dhcp4 (wlp3s0): state changed unknown -> bound Mar 26 19:59:46 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087186.8353] manager: NetworkManager state is now CONNECTED_GLOBAL Mar 26 19:59:46 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087186.8354] policy: set 'gigacube_5G-C302' (wlp3s0) as default for IPv4 routing and DNS Mar 26 19:59:46 flo-ThinkPad-T440s whoopsie[1110]: [19:59:46] The default IPv4 route is: /org/freedesktop/NetworkManager/ActiveConnection/3 Mar 26 19:59:46 flo-ThinkPad-T440s whoopsie[1110]: [19:59:46] Not a paid data plan: /org/freedesktop/NetworkManager/ActiveConnection/3 Mar 26 19:59:46 flo-ThinkPad-T440s whoopsie[1110]: [19:59:46] Found usable connection: /org/freedesktop/NetworkManager/ActiveConnection/3 Mar 26 20:12:05 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087925.1646] manager: sleep requested (sleeping: no enabled: yes) Mar 26 20:12:05 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087925.1646] manager: sleeping... Mar 26 20:12:05 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087925.1647] device (enp0s25): state change: unavailable -> unmanaged (reason 'sleeping', internal state 'managed') Mar 26 20:12:05 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087925.5221] device (cdc-wdm2): state change: unavailable -> unmanaged (reason 'sleeping', internal state 'external') Mar 26 20:12:05 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087925.5223] manager: NetworkManager state is now ASLEEP Mar 26 20:12:05 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087925.5239] device (wlp3s0): state change: activated -> deactivating (reason 'sleeping', internal state 'managed') Mar 26 20:12:05 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087925.5272] device (wlp3s0): state change: deactivating -> disconnected (reason 'sleeping', internal state 'managed') Mar 26 20:12:05 flo-ThinkPad-T440s systemd[1]: Starting Network Manager Script Dispatcher Service... Mar 26 20:12:05 flo-ThinkPad-T440s systemd[1]: Started Network Manager Script Dispatcher Service. Mar 26 20:12:05 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087925.5615] dhcp4 (wlp3s0): canceled DHCP transaction, DHCP client pid 5773 Mar 26 20:12:05 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087925.5615] dhcp4 (wlp3s0): state changed bound -> done Mar 26 20:12:05 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087925.5620] dhcp6 (wlp3s0): canceled DHCP transaction Mar 26 20:12:05 flo-ThinkPad-T440s kernel: [ 4639.715520] wlp3s0: deauthenticating from c4:86:e9:77:c3:04 by local choice (Reason: 3=DEAUTH_LEAVING) Mar 26 20:12:05 flo-ThinkPad-T440s wpa_supplicant[1041]: wlp3s0: CTRL-EVENT-DISCONNECTED bssid=c4:86:e9:77:c3:04 reason=3 locally_generated=1 Mar 26 20:12:05 flo-ThinkPad-T440s NetworkManager[895]: <warn> [1522087925.5748] sup-iface[0x562039bd8f10,wlp3s0]: connection disconnected (reason -3) Mar 26 20:12:05 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522087925.5764] device (wlp3s0): state change: disconnected -> unmanaged (reason 'sleeping', internal state 'managed') Mar 26 20:41:28 flo-ThinkPad-T440s kernel: [ 4645.240705] Bluetooth: hci0: Intel Bluetooth firmware file: intel/ibt-hw-37.7.10-fw-1.80.2.3.d.bseq Mar 26 20:41:28 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089688.4629] manager: wake requested (sleeping: yes enabled: yes) Mar 26 20:41:28 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089688.4629] manager: waking up... Mar 26 20:41:28 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089688.4630] device (enp0s25): state change: unmanaged -> unavailable (reason 'managed', internal state 'managed') Mar 26 20:41:28 flo-ThinkPad-T440s kernel: [ 4645.346474] IPv6: ADDRCONF(NETDEV_UP): enp0s25: link is not ready Mar 26 20:41:28 flo-ThinkPad-T440s kernel: [ 4645.416114] Bluetooth: hci0: Intel Bluetooth firmware patch completed and activated Mar 26 20:41:28 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089688.6507] device (wlp3s0): state change: unmanaged -> unavailable (reason 'managed', internal state 'managed') Mar 26 20:41:28 flo-ThinkPad-T440s kernel: [ 4645.533186] IPv6: ADDRCONF(NETDEV_UP): enp0s25: link is not ready Mar 26 20:41:28 flo-ThinkPad-T440s kernel: [ 4645.534082] IPv6: ADDRCONF(NETDEV_UP): wlp3s0: link is not ready Mar 26 20:41:28 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089688.9123] manager: NetworkManager state is now DISCONNECTED Mar 26 20:41:28 flo-ThinkPad-T440s kernel: [ 4645.794011] IPv6: ADDRCONF(NETDEV_UP): wlp3s0: link is not ready Mar 26 20:41:28 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089688.9636] audit: op="radio-control" arg="wwan-enabled:0" pid=6719 uid=0 result="success" Mar 26 20:41:28 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089688.9879] device (wlp3s0): supplicant interface state: starting -> ready Mar 26 20:41:28 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089688.9879] device (wlp3s0): state change: unavailable -> disconnected (reason 'supplicant-available', internal state 'managed') Mar 26 20:41:28 flo-ThinkPad-T440s kernel: [ 4645.871330] IPv6: ADDRCONF(NETDEV_UP): wlp3s0: link is not ready Mar 26 20:41:32 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089692.2438] device (wlp3s0): supplicant interface state: ready -> inactive Mar 26 20:41:49 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089709.1464] device (cdc-wdm2): state change: unmanaged -> unavailable (reason 'none', internal state 'external') Mar 26 20:41:49 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089709.1467] device (cdc-wdm2): modem state 'failed' Mar 26 20:41:49 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089709.1487] manager: (cdc-wdm2): new Broadband device (/org/freedesktop/NetworkManager/Devices/7) Mar 26 20:41:49 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089709.1502] modem-broadband[cdc-wdm2]: failed to retrieve SIM object: No SIM object available Mar 26 20:42:08 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089728.4043] device (wlp3s0): supplicant interface state: inactive -> scanning Mar 26 20:43:11 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089791.9806] manager: rfkill: WiFi hardware radio set disabled Mar 26 20:43:11 flo-ThinkPad-T440s wpa_supplicant[1041]: rfkill: WLAN soft blocked Mar 26 20:43:11 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089791.9806] device (wlp3s0): state change: disconnected -> unavailable (reason 'none', internal state 'managed') Mar 26 20:43:11 flo-ThinkPad-T440s wpa_supplicant[1041]: rfkill: WLAN soft blocked Mar 26 20:43:11 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089791.9819] audit: op="radio-control" arg="wireless-enabled:0" pid=1433 uid=1000 result="success" Mar 26 20:43:11 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089791.9845] manager: rfkill: WiFi now disabled by radio killswitch Mar 26 20:43:13 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089793.1673] manager: rfkill: WiFi hardware radio set enabled Mar 26 20:43:13 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089793.4148] audit: op="radio-control" arg="wireless-enabled:1" pid=1433 uid=1000 result="success" Mar 26 20:43:13 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089793.4154] manager: rfkill: WiFi now enabled by radio killswitch Mar 26 20:43:13 flo-ThinkPad-T440s kernel: [ 4750.297909] IPv6: ADDRCONF(NETDEV_UP): wlp3s0: link is not ready Mar 26 20:43:13 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089793.4802] device (wlp3s0): supplicant interface state: starting -> ready Mar 26 20:43:13 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089793.4803] device (wlp3s0): state change: unavailable -> disconnected (reason 'supplicant-available', internal state 'managed') Mar 26 20:43:13 flo-ThinkPad-T440s kernel: [ 4750.364001] IPv6: ADDRCONF(NETDEV_UP): wlp3s0: link is not ready Mar 26 20:43:16 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089796.7368] device (wlp3s0): supplicant interface state: ready -> inactive Mar 26 20:43:35 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089815.3953] device (wlp3s0): supplicant interface state: inactive -> scanning Mar 26 20:43:39 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089819.7256] policy: auto-activating connection 'gigacube_5G-C302' Mar 26 20:43:39 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089819.7272] device (wlp3s0): Activation: starting connection 'gigacube_5G-C302' (cc70faae-f0dc-437f-a09c-a4a9a0ed07ae) Mar 26 20:43:39 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089819.7279] device (wlp3s0): state change: disconnected -> prepare (reason 'none', internal state 'managed') Mar 26 20:43:39 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089819.7281] manager: NetworkManager state is now CONNECTING Mar 26 20:43:39 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089819.7288] device (wlp3s0): state change: prepare -> config (reason 'none', internal state 'managed') Mar 26 20:43:39 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089819.7290] device (wlp3s0): Activation: (wifi) access point 'gigacube_5G-C302' has security, but secrets are required. Mar 26 20:43:39 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089819.7291] device (wlp3s0): state change: config -> need-auth (reason 'none', internal state 'managed') Mar 26 20:43:39 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089819.7437] device (wlp3s0): state change: need-auth -> prepare (reason 'none', internal state 'managed') Mar 26 20:43:39 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089819.7440] device (wlp3s0): state change: prepare -> config (reason 'none', internal state 'managed') Mar 26 20:43:39 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089819.7441] device (wlp3s0): Activation: (wifi) connection 'gigacube_5G-C302' has security, and secrets exist. No new secrets needed. Mar 26 20:43:39 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089819.7442] Config: added 'ssid' value 'gigacube_5G-C302' Mar 26 20:43:39 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089819.7442] Config: added 'scan_ssid' value '1' Mar 26 20:43:39 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089819.7442] Config: added 'key_mgmt' value 'WPA-PSK' Mar 26 20:43:39 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089819.7442] Config: added 'auth_alg' value 'OPEN' Mar 26 20:43:39 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089819.7442] Config: added 'psk' value '<hidden>' Mar 26 20:43:39 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089819.7569] device (wlp3s0): supplicant interface state: scanning -> authenticating Mar 26 20:43:39 flo-ThinkPad-T440s kernel: [ 4776.645120] IPv6: ADDRCONF(NETDEV_CHANGE): wlp3s0: link becomes ready Mar 26 20:43:39 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089819.7631] device (wlp3s0): supplicant interface state: authenticating -> associated Mar 26 20:43:39 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089819.7733] device (wlp3s0): supplicant interface state: associated -> 4-way handshake Mar 26 20:43:39 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089819.7830] device (wlp3s0): supplicant interface state: 4-way handshake -> completed Mar 26 20:43:39 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089819.7830] device (wlp3s0): Activation: (wifi) Stage 2 of 5 (Device Configure) successful. Connected to wireless network 'gigacube_5G-C302'. Mar 26 20:43:39 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089819.7831] device (wlp3s0): state change: config -> ip-config (reason 'none', internal state 'managed') Mar 26 20:43:39 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089819.7835] dhcp4 (wlp3s0): activation: beginning transaction (timeout in 45 seconds) Mar 26 20:43:39 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089819.7849] dhcp4 (wlp3s0): dhclient started with pid 7161 Mar 26 20:43:41 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089821.1409] dhcp6 (wlp3s0): activation: beginning transaction (timeout in 45 seconds) Mar 26 20:43:41 flo-ThinkPad-T440s NetworkManager[895]: <warn> [1522089821.1410] dhcp6 (wlp3s0): hostname is not a FQDN, it will be ignored Mar 26 20:43:41 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089821.1420] dhcp6 (wlp3s0): dhclient started with pid 7170 Mar 26 20:43:41 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089821.7927] dhcp6 (wlp3s0): nameserver 'fe80::c686:e9ff:fe77:c301' Mar 26 20:43:41 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089821.7927] dhcp6 (wlp3s0): state changed unknown -> bound Mar 26 20:43:41 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089821.7952] dhcp6 (wlp3s0): client pid 7170 exited with status 0 Mar 26 20:43:41 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089821.7952] dhcp6 (wlp3s0): state changed bound -> done Mar 26 20:43:41 flo-ThinkPad-T440s systemd[1]: Starting Network Manager Script Dispatcher Service... Mar 26 20:43:41 flo-ThinkPad-T440s systemd[1]: Started Network Manager Script Dispatcher Service. Mar 26 20:43:42 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089822.3055] dhcp4 (wlp3s0): address 192.168.8.142 Mar 26 20:43:42 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089822.3056] dhcp4 (wlp3s0): plen 24 (255.255.255.0) Mar 26 20:43:42 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089822.3056] dhcp4 (wlp3s0): gateway 192.168.8.1 Mar 26 20:43:42 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089822.3056] dhcp4 (wlp3s0): lease time 86400 Mar 26 20:43:42 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089822.3057] dhcp4 (wlp3s0): nameserver '192.168.8.1' Mar 26 20:43:42 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089822.3057] dhcp4 (wlp3s0): state changed unknown -> bound Mar 26 20:43:42 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089822.3092] device (wlp3s0): state change: ip-config -> ip-check (reason 'none', internal state 'managed') Mar 26 20:43:42 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089822.3102] device (wlp3s0): state change: ip-check -> secondaries (reason 'none', internal state 'managed') Mar 26 20:43:42 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089822.3105] device (wlp3s0): state change: secondaries -> activated (reason 'none', internal state 'managed') Mar 26 20:43:42 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089822.3106] manager: NetworkManager state is now CONNECTED_LOCAL Mar 26 20:43:42 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089822.3141] manager: NetworkManager state is now CONNECTED_GLOBAL Mar 26 20:43:42 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089822.3143] policy: set 'gigacube_5G-C302' (wlp3s0) as default for IPv4 routing and DNS Mar 26 20:43:42 flo-ThinkPad-T440s NetworkManager[895]: <info> [1522089822.3156] device (wlp3s0): Activation: successful, device activated. Mar 26 20:43:42 flo-ThinkPad-T440s whoopsie[1110]: [20:43:42] The default IPv4 route is: /org/freedesktop/NetworkManager/ActiveConnection/4 Mar 26 20:43:42 flo-ThinkPad-T440s whoopsie[1110]: [20:43:42] Not a paid data plan: /org/freedesktop/NetworkManager/ActiveConnection/4 Mar 26 20:43:42 flo-ThinkPad-T440s whoopsie[1110]: [20:43:42] Found usable connection: /org/freedesktop/NetworkManager/ActiveConnection/4 flo@flo-ThinkPad-T440s:~$ dmesg | egrep 'net|eth|sky|sun|sis|via|3c3|3c5|e100|8139|8169|acx|air|ath|atl|ar9|carl|atme|at7|herm|iwl|ipw|rtl8|r81|rt2|rt3|rt6|rt7|tg3|ssb|wl|b43|b44|ori|pri|p5|zd|ndis|wmi|ns8|FW|key|rtl|country' [ 0.000000] PM: Registered nosave memory: [mem 0xf80f9000-0xfe100fff] [ 0.000000] percpu: Embedded 45 pages/cpu @ffff92505e200000 s146520 r8192 d29608 u262144 [ 0.000000] pcpu-alloc: s146520 r8192 d29608 u262144 alloc=1*2097152 [ 0.000000] Calgary: detecting Calgary via BIOS EBDA area [ 0.027492] CPU0: Thermal monitoring enabled (TM1) [ 0.089955] ACPI Error: Method parse/execution failed \_PR.CPU0._PDC, AE_AML_OPERAND_TYPE (20170531/psparse-550) [ 1.061796] audit: initializing netlink subsys (disabled) [ 1.062217] Initialise system trusted keyrings [ 1.065368] Asymmetric key parser 'x509' registered [ 1.067945] thermal LNXTHERM:00: registered as thermal_zone0 [ 1.067947] ACPI: Thermal Zone [THM0] (37 C) [ 1.231500] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input3 [ 1.243568] Loaded X.509 cert 'Build time autogenerated kernel key: 9218bc7883ae724da525bf512c131e327778035c' [ 1.243779] Loaded UEFI:db cert 'Microsoft Corporation UEFI CA 2011: 13adbf4309bd82709c8cd54f316ed522988a1bd4' linked to secondary sys keyring [ 1.243794] Loaded UEFI:db cert 'Microsoft Windows Production PCA 2011: a92902398e16c49778cd90f99e4f9ae17c55af53' linked to secondary sys keyring [ 1.243805] Loaded UEFI:db cert 'Lenovo Ltd.: ThinkPad Product CA 2012: 838b1f54c1550463f45f98700640f11069265949' linked to secondary sys keyring [ 1.245320] Loaded UEFI:MokListRT cert 'Canonical Ltd. Master Certificate Authority: ad91990bc22ab1f517048c23b6655a268e345a63' linked to secondary sys keyring [ 1.247922] Key type big_key registered [ 1.565253] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k [ 1.565254] e1000e: Copyright(c) 1999 - 2015 Intel Corporation. [ 1.565394] e1000e 0000:00:19.0: Interrupt Throttling Rate (ints/sec) set to dynamic conservative mode [ 1.748466] e1000e 0000:00:19.0 0000:00:19.0 (uninitialized): registered PHC clock [ 1.811096] e1000e 0000:00:19.0 eth0: (PCI Express:2.5GT/s:Width x1) 68:f7:28:12:e9:25 [ 1.811097] e1000e 0000:00:19.0 eth0: Intel(R) PRO/1000 Network Connection [ 1.811124] e1000e 0000:00:19.0 eth0: MAC: 11, PHY: 12, PBA No: 1000FF-0FF [ 1.811663] e1000e 0000:00:19.0 enp0s25: renamed from eth0 [ 2.138200] ata1.00: ATA-9: Samsung SSD 850 EVO 500GB, EMT03B6Q, max UDMA/133 [ 2.143015] scsi 0:0:0:0: Direct-Access ATA Samsung SSD 850 3B6Q PQ: 0 ANSI: 5 [ 2.220268] fbcon: inteldrmfb (fb0) is primary device [ 4.857542] thinkpad_acpi: http://ibm-acpi.sf.net/ [ 4.894337] iwlwifi 0000:03:00.0: loaded firmware version 17.608620.0 op_mode iwlmvm [ 4.929837] iwlwifi 0000:03:00.0: Detected Intel(R) Dual Band Wireless AC 7260, REV=0x144 [ 4.952741] iwlwifi 0000:03:00.0: base HW address: 28:b2:bd:73:96:87 [ 5.170894] ieee80211 phy0: Selected rate control algorithm 'iwl-mvm-rs' [ 5.209927] iwlwifi 0000:03:00.0 wlp3s0: renamed from wlan0 [ 5.297958] Adding 12304380k swap on /dev/sda3. Priority:-1 extents:1 across:12304380k SSFS [ 5.739164] vboxdrv: module verification failed: signature and/or required key missing - tainting kernel [ 6.149330] Bluetooth: BNEP (Ethernet Emulation) ver 1.3 [ 6.567762] IPv6: ADDRCONF(NETDEV_UP): wlp3s0: link is not ready [ 6.839057] IPv6: ADDRCONF(NETDEV_UP): wlp3s0: link is not ready [ 6.917926] IPv6: ADDRCONF(NETDEV_UP): wlp3s0: link is not ready [ 77.092237] IPv6: ADDRCONF(NETDEV_UP): wlp3s0: link is not ready [ 77.160704] IPv6: ADDRCONF(NETDEV_UP): wlp3s0: link is not ready [ 96.396808] thinkpad_acpi: EC reports that Thermal Table has changed [ 104.636991] wlp3s0: authenticate with c4:86:e9:77:c3:04 [ 104.643401] wlp3s0: send auth to c4:86:e9:77:c3:04 (try 1/3) [ 104.645387] wlp3s0: authenticated [ 104.648049] wlp3s0: associate with c4:86:e9:77:c3:04 (try 1/3) [ 104.649735] wlp3s0: RX AssocResp from c4:86:e9:77:c3:04 (capab=0x1011 status=0 aid=1) [ 104.651201] wlp3s0: associated [ 104.651242] IPv6: ADDRCONF(NETDEV_CHANGE): wlp3s0: link becomes ready [ 104.715263] wlp3s0: Limiting TX power to 30 (30 - 0) dBm as advertised by c4:86:e9:77:c3:04 [ 2270.954351] e1000e: enp0s25 NIC Link is Down [ 2270.998214] wlp3s0: deauthenticating from c4:86:e9:77:c3:04 by local choice (Reason: 3=DEAUTH_LEAVING) [ 2271.006087] wlp3s0: failed to remove key (1, ff:ff:ff:ff:ff:ff) from hardware (-22) [ 2271.719580] e1000e: EEE TX LPI TIMER: 00000011 [ 2272.779207] PM: Restoring platform NVS memory [ 2275.419645] IPv6: ADDRCONF(NETDEV_UP): wlp3s0: link is not ready [ 2275.673617] IPv6: ADDRCONF(NETDEV_UP): wlp3s0: link is not ready [ 2275.741809] IPv6: ADDRCONF(NETDEV_UP): wlp3s0: link is not ready [ 2342.629210] wlp3s0: authenticate with c4:86:e9:77:c3:04 [ 2342.633885] wlp3s0: send auth to c4:86:e9:77:c3:04 (try 1/3) [ 2342.635323] wlp3s0: authenticated [ 2342.641590] wlp3s0: associate with c4:86:e9:77:c3:04 (try 1/3) [ 2342.643967] wlp3s0: RX AssocResp from c4:86:e9:77:c3:04 (capab=0x1011 status=0 aid=1) [ 2342.645448] wlp3s0: associated [ 2342.645485] IPv6: ADDRCONF(NETDEV_CHANGE): wlp3s0: link becomes ready [ 2342.724381] wlp3s0: Limiting TX power to 30 (30 - 0) dBm as advertised by c4:86:e9:77:c3:04 [ 3852.621301] e1000e: enp0s25 NIC Link is Down [ 3852.665045] wlp3s0: deauthenticating from c4:86:e9:77:c3:04 by local choice (Reason: 3=DEAUTH_LEAVING) [ 3852.672413] wlp3s0: failed to remove key (1, ff:ff:ff:ff:ff:ff) from hardware (-22) [ 3853.402476] e1000e: EEE TX LPI TIMER: 00000011 [ 3854.150133] PM: Restoring platform NVS memory [ 3856.805727] IPv6: ADDRCONF(NETDEV_UP): wlp3s0: link is not ready [ 3857.062880] IPv6: ADDRCONF(NETDEV_UP): wlp3s0: link is not ready [ 3857.127297] IPv6: ADDRCONF(NETDEV_UP): wlp3s0: link is not ready [ 3897.284894] wlp3s0: authenticate with c4:86:e9:77:c3:04 [ 3897.289520] wlp3s0: send auth to c4:86:e9:77:c3:04 (try 1/3) [ 3897.290608] wlp3s0: authenticated [ 3897.292499] wlp3s0: associate with c4:86:e9:77:c3:04 (try 1/3) [ 3897.294159] wlp3s0: RX AssocResp from c4:86:e9:77:c3:04 (capab=0x1011 status=0 aid=1) [ 3897.295633] wlp3s0: associated [ 3897.295673] IPv6: ADDRCONF(NETDEV_CHANGE): wlp3s0: link becomes ready [ 3897.369773] wlp3s0: Limiting TX power to 30 (30 - 0) dBm as advertised by c4:86:e9:77:c3:04 [ 3899.485481] usblp 2-2:1.1: usblp4: USB Bidirectional printer dev 9 if 1 alt 0 proto 2 vid 0x04A9 pid 0x173D [ 4084.112540] usblp 2-2:1.1: usblp4: USB Bidirectional printer dev 9 if 1 alt 0 proto 2 vid 0x04A9 pid 0x173D [ 4314.663397] usblp 2-2:1.1: usblp4: USB Bidirectional printer dev 9 if 1 alt 0 proto 2 vid 0x04A9 pid 0x173D [ 4501.438564] usblp 2-2:1.1: usblp4: USB Bidirectional printer dev 9 if 1 alt 0 proto 2 vid 0x04A9 pid 0x173D [ 4639.673930] e1000e: enp0s25 NIC Link is Down [ 4639.715520] wlp3s0: deauthenticating from c4:86:e9:77:c3:04 by local choice (Reason: 3=DEAUTH_LEAVING) [ 4639.723395] wlp3s0: failed to remove key (1, ff:ff:ff:ff:ff:ff) from hardware (-22) [ 4640.415040] e1000e: EEE TX LPI TIMER: 00000011 [ 4640.882796] PM: Restoring platform NVS memory [ 4641.841408] thinkpad_acpi: EC reports that Thermal Table has changed [ 4645.534082] IPv6: ADDRCONF(NETDEV_UP): wlp3s0: link is not ready [ 4645.794011] IPv6: ADDRCONF(NETDEV_UP): wlp3s0: link is not ready [ 4645.871330] IPv6: ADDRCONF(NETDEV_UP): wlp3s0: link is not ready [ 4722.686330] thinkpad_acpi: EC reports that Thermal Table has changed [ 4750.297909] IPv6: ADDRCONF(NETDEV_UP): wlp3s0: link is not ready [ 4750.364001] IPv6: ADDRCONF(NETDEV_UP): wlp3s0: link is not ready [ 4770.430380] thinkpad_acpi: EC reports that Thermal Table has changed [ 4776.634765] wlp3s0: authenticate with c4:86:e9:77:c3:04 [ 4776.639497] wlp3s0: send auth to c4:86:e9:77:c3:04 (try 1/3) [ 4776.641193] wlp3s0: authenticated [ 4776.641390] wlp3s0: associate with c4:86:e9:77:c3:04 (try 1/3) [ 4776.643515] wlp3s0: RX AssocResp from c4:86:e9:77:c3:04 (capab=0x1011 status=0 aid=1) [ 4776.645082] wlp3s0: associated [ 4776.645120] IPv6: ADDRCONF(NETDEV_CHANGE): wlp3s0: link becomes ready [ 4776.691677] wlp3s0: Limiting TX power to 30 (30 - 0) dBm as advertised by c4:86:e9:77:c3:04
Das war jetzt ganz schön viel und sicher viel unnötiges. Ich hoffe ihr könnt mir helfen. Viele Grüße, Flo
