Du musst den Treiber manuell und sinnvollerweise mittels DKMS installieren → https://github.com/gordboy/rtl8812au
Wichtiger Nachtrag: Die hier verwendete Geräte-ID ist bisher noch unbekannt, kann aber in der ../rtl8812au/os_dep/linux/usb_intf.c hinzugefügt werden.
#ifdef CONFIG_RTL8812A
/*=== Realtek demoboard ===*/
{USB_DEVICE(USB_VENDER_ID_REALTEK, 0x8812), .driver_info = RTL8812}, /* Default ID */
{USB_DEVICE(USB_VENDER_ID_REALTEK, 0x881A), .driver_info = RTL8812}, /* Default ID */
{USB_DEVICE(USB_VENDER_ID_REALTEK, 0x881B), .driver_info = RTL8812}, /* Default ID */
{USB_DEVICE(USB_VENDER_ID_REALTEK, 0x881C), .driver_info = RTL8812}, /* Default ID */
/*=== Customer ID ===*/
{USB_DEVICE(0x0BDA, 0xA811), .driver_info = RTL8812}, /* unbekannt */
{USB_DEVICE(0x0409, 0x0408), .driver_info = RTL8812}, /* NEC - */
{USB_DEVICE(0x0411, 0x025D), .driver_info = RTL8812}, /* Buffalo - WI-U3-866D */
{USB_DEVICE(0x04BB, 0x0952), .driver_info = RTL8812}, /* I-O DATA - Edimax */
{USB_DEVICE(0x050D, 0x1106), .driver_info = RTL8812}, /* Belkin - Sercomm */
{USB_DEVICE(0x050D, 0x1109), .driver_info = RTL8812}, /* Belkin - SerComm F9L1109 */
{USB_DEVICE(0x0586, 0x3426), .driver_info = RTL8812}, /* ZyXEL - */
{USB_DEVICE(0x0789, 0x016E), .driver_info = RTL8812}, /* Logitec - Edimax */
{USB_DEVICE(0x07B8, 0x8812), .driver_info = RTL8812}, /* Abocom - Abocom */
{USB_DEVICE(0x0846, 0x9051), .driver_info = RTL8812}, /* Netgear A6200 v2 */
{USB_DEVICE(0x0B05, 0x17D2), .driver_info = RTL8812}, /* ASUS - Edimax */
{USB_DEVICE(0x0BDA, 0x8812), .driver_info = RTL8812}, /* KOOTEK */
{USB_DEVICE(0x0BDA, 0x881A), .driver_info = RTL8812}, /* Unex DAUK-W8812 */
{USB_DEVICE(0x0DF6, 0x0074), .driver_info = RTL8812}, /* Sitecom - Edimax */
{USB_DEVICE(0x0E66, 0x0022), .driver_info = RTL8812}, /* HAWKING - Edimax */
{USB_DEVICE(0x1058, 0x0632), .driver_info = RTL8812}, /* WD - Cybertan */
{USB_DEVICE(0x13B1, 0x003F), .driver_info = RTL8812}, /* Linksys - WUSB6300 */
{USB_DEVICE(0x148F, 0x9097), .driver_info = RTL8812}, /* Amped Wireless - ACA1 */
{USB_DEVICE(0x1740, 0x0100), .driver_info = RTL8812}, /* EnGenius - EnGenius */
{USB_DEVICE(0x2001, 0x330E), .driver_info = RTL8812}, /* D-Link - ALPHA */
{USB_DEVICE(0x2001, 0x3313), .driver_info = RTL8812}, /* D-Link - ALPHA */
{USB_DEVICE(0x2001, 0x3315), .driver_info = RTL8812}, /* D-Link - Cameo */
{USB_DEVICE(0x2001, 0x3316), .driver_info = RTL8812}, /* D-Link - Cameo */
{USB_DEVICE(0x2019, 0xAB30), .driver_info = RTL8812}, /* Planex - Abocom */
{USB_DEVICE(0x20F4, 0x805B), .driver_info = RTL8812}, /* TRENDnet - Cameo */
{USB_DEVICE(0x2357, 0x0101), .driver_info = RTL8812}, /* TP-Link - Archer T4U */
{USB_DEVICE(0x2357, 0x0103), .driver_info = RTL8812}, /* TP-Link - Archer T4UH */
{USB_DEVICE(0x2357, 0x010D), .driver_info = RTL8812}, /* TP-Link - Archer T4U AC1300 */
{USB_DEVICE(0x2357, 0x010E), .driver_info = RTL8812}, /* TP-Link - Archer T4UH AC1300 */
{USB_DEVICE(0x2357, 0x010F), .driver_info = RTL8812}, /* TP-Link - T4UHP */
{USB_DEVICE(0x2357, 0x0122), .driver_info = RTL8812}, /* TP-Link - Archer T4UHP(US) v1 AC1300 */
{USB_DEVICE(0x2604, 0x0012), .driver_info = RTL8812}, /* Tenda - U12 */
{USB_DEVICE(0x7392, 0xA812), .driver_info = RTL8812}, /* Edimax - EW-7811UTC */
{USB_DEVICE(0x7392, 0xA822), .driver_info = RTL8812}, /* Edimax - Edimax */
#endif
Achtung: da das Modul nicht signiert ist, muss dazu Secure-Boot des BIOS/UEFI abgeschaltet werden! Ansonsten lädt das System das Treibermodul nicht in den Kernel.
Zu SB siehe z.B. ...
Wer Secure-Boot nicht im BIOS/UEFI deaktivieren will oder kann, hat alternativ auch die Möglichkeit den Boot-Check durch Shim unter Linux zu deaktivieren. Secure-Boot des UEFI bleibt dabei aktiviert, allerdings werden Bootloader (GRUB), Kernel und Kernelmodule nicht mehr durch den Shim-Bootloader überprüft!
Nur unter Linux den SB Status abfragen/abschalten:
| sudo apt install mokutil
sudo mokutil --sb-state
sudo mokutil --disable-validation
EFI-Modus wird verwendet?
(Ordner existiert nicht bei Installation im CFM-Modus/Kompatibilitätsmodus)
Module selbst signieren
Modulinfo:
filename: ../rtl8812au/8812au.ko
version: v5.2.20.2_28373.20180619
author: Realtek Semiconductor Corp.
description: Realtek Wireless Lan Driver
license: GPL
srcversion: 146166D495E40DB85221FFB
alias: usb:v0BDApA811d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v7392pA822d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v7392pA812d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v2604p0012d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v2357p0122d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v2357p010Fd*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v2357p010Ed*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v2357p010Dd*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v2357p0103d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v2357p0101d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v20F4p805Bd*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v2019pAB30d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v2001p3316d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v2001p3315d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v2001p3313d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v2001p330Ed*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v1740p0100d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v148Fp9097d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v13B1p003Fd*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v1058p0632d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v0E66p0022d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v0DF6p0074d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v0BDAp881Ad*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v0BDAp8812d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v0B05p17D2d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v0846p9051d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v07B8p8812d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v0789p016Ed*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v0586p3426d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v050Dp1109d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v050Dp1106d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v04BBp0952d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v0411p025Dd*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v0409p0408d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v0BDAp881Cd*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v0BDAp881Bd*dc*dsc*dp*ic*isc*ip*in*
depends: cfg80211
retpoline: Y
vermagic: 4.15.0-33-generic SMP mod_unload
parm: rtw_ips_mode:The default IPS mode (int)
parm: rtw_lps_level:The default LPS level (int)
parm: rtw_usb_rxagg_mode:int
parm: rtw_dynamic_agg_enable:int
parm: rtw_drv_log_level:set log level when insert driver module, default log level is _DRV_INFO_ = 4 (uint)
parm: rtw_tx_bw_mode:The max tx bw for 2.4G and 5G. format is the same as rtw_bw_mode (uint)
parm: rtw_rx_ampdu_sz_limit_1ss:RX AMPDU size limit for 1SS link of each BW, 0xFF: no limitation (array of uint)
parm: rtw_rx_ampdu_sz_limit_2ss:RX AMPDU size limit for 2SS link of each BW, 0xFF: no limitation (array of uint)
parm: rtw_rx_ampdu_sz_limit_3ss:RX AMPDU size limit for 3SS link of each BW, 0xFF: no limitation (array of uint)
parm: rtw_rx_ampdu_sz_limit_4ss:RX AMPDU size limit for 4SS link of each BW, 0xFF: no limitation (array of uint)
parm: rtw_vht_enable:int
parm: rtw_vht_rx_mcs_map:VHT RX MCS map (uint)
parm: rtw_rf_config:int
parm: rtw_country_code:The default country code (in alpha2) (charp)
parm: rtw_channel_plan:The default chplan ID when rtw_alpha2 is not specified or valid (int)
parm: rtw_excl_chs:exclusive channel array (array of uint)
parm: rtw_qos_opt_enable:int
parm: ifname:The default name to allocate for first interface (charp)
parm: if2name:The default name to allocate for second interface (charp)
parm: rtw_pwrtrim_enable:int
parm: rtw_initmac:charp
parm: rtw_special_rf_path:int
parm: rtw_chip_version:int
parm: rtw_rfintfs:int
parm: rtw_lbkmode:int
parm: rtw_network_mode:int
parm: rtw_channel:int
parm: rtw_mp_mode:int
parm: rtw_wmm_enable:int
parm: rtw_vrtl_carrier_sense:int
parm: rtw_vcs_type:int
parm: rtw_busy_thresh:int
parm: rtw_ht_enable:int
parm: rtw_bw_mode:int
parm: rtw_ampdu_enable:int
parm: rtw_rx_stbc:int
parm: rtw_rx_ampdu_amsdu:int
parm: rtw_tx_ampdu_amsdu:int
parm: rtw_beamform_cap:int
parm: rtw_lowrate_two_xmit:int
parm: rtw_power_mgnt:int
parm: rtw_smart_ps:int
parm: rtw_low_power:int
parm: rtw_wifi_spec:int
parm: rtw_full_ch_in_p2p_handshake:int
parm: rtw_antdiv_cfg:int
parm: rtw_antdiv_type:int
parm: rtw_drv_ant_band_switch:int
parm: rtw_single_ant_path:int
parm: rtw_switch_usb_mode:int
parm: rtw_enusbss:int
parm: rtw_hwpdn_mode:int
parm: rtw_hwpwrp_detect:int
parm: rtw_hw_wps_pbc:int
parm: rtw_check_hw_status:int
parm: rtw_max_roaming_times:The max roaming times to try (uint)
parm: rtw_mc2u_disable:int
parm: rtw_80211d:Enable 802.11d mechanism (int)
parm: rtw_notch_filter:0:Disable, 1:Enable, 2:Enable only for P2P (uint)
parm: rtw_hiq_filter:0:allow all, 1:allow special, 2:deny all (uint)
parm: rtw_adaptivity_en:0:disable, 1:enable (uint)
parm: rtw_adaptivity_mode:0:normal, 1:carrier sense (uint)
parm: rtw_adaptivity_dml:0:disable, 1:enable (uint)
parm: rtw_adaptivity_dc_backoff:DC backoff for Adaptivity (uint)
parm: rtw_adaptivity_th_l2h_ini:th_l2h_ini for Adaptivity (int)
parm: rtw_adaptivity_th_edcca_hl_diff:th_edcca_hl_diff for Adaptivity (int)
parm: rtw_amplifier_type_2g:BIT3:2G ext-PA, BIT4:2G ext-LNA (uint)
parm: rtw_amplifier_type_5g:BIT6:5G ext-PA, BIT7:5G ext-LNA (uint)
parm: rtw_RFE_type:default init value:64 (uint)
parm: rtw_powertracking_type:default init value:64 (uint)
parm: rtw_GLNA_type:default init value:0 (uint)
parm: rtw_TxBBSwing_2G:default init value:0xFF (uint)
parm: rtw_TxBBSwing_5G:default init value:0xFF (uint)
parm: rtw_OffEfuseMask:default open Efuse Mask value:0 (uint)
parm: rtw_FileMaskEfuse:default drv Mask Efuse value:0 (uint)
parm: rtw_rxgain_offset_2g:default RF Gain 2G Offset value:0 (uint)
parm: rtw_rxgain_offset_5gl:default RF Gain 5GL Offset value:0 (uint)
parm: rtw_rxgain_offset_5gh:uint
parm: rtw_rxgain_offset_5gm:default RF Gain 5GM Offset value:0 (uint)
parm: rtw_pll_ref_clk_sel:force pll_ref_clk_sel, 0xF:use autoload value (uint)
parm: rtw_tx_pwr_by_rate:0:Disable, 1:Enable, 2: Depend on efuse (int)
parm: rtw_target_tx_pwr_2g_a:2.4G target tx power (unit:dBm) of RF path A for each rate section, should match the real calibrate power, -1: undefined (array of int)
parm: rtw_target_tx_pwr_2g_b:2.4G target tx power (unit:dBm) of RF path B for each rate section, should match the real calibrate power, -1: undefined (array of int)
parm: rtw_target_tx_pwr_2g_c:2.4G target tx power (unit:dBm) of RF path C for each rate section, should match the real calibrate power, -1: undefined (array of int)
parm: rtw_target_tx_pwr_2g_d:2.4G target tx power (unit:dBm) of RF path D for each rate section, should match the real calibrate power, -1: undefined (array of int)
parm: rtw_target_tx_pwr_5g_a:5G target tx power (unit:dBm) of RF path A for each rate section, should match the real calibrate power, -1: undefined (array of int)
parm: rtw_target_tx_pwr_5g_b:5G target tx power (unit:dBm) of RF path B for each rate section, should match the real calibrate power, -1: undefined (array of int)
parm: rtw_target_tx_pwr_5g_c:5G target tx power (unit:dBm) of RF path C for each rate section, should match the real calibrate power, -1: undefined (array of int)
parm: rtw_target_tx_pwr_5g_d:5G target tx power (unit:dBm) of RF path D for each rate section, should match the real calibrate power, -1: undefined (array of int)
parm: rtw_phy_file_path:The path of phy parameter (charp)
parm: rtw_load_phy_file:PHY File Bit Map (int)
parm: rtw_decrypt_phy_file:Enable Decrypt PHY File (int)
parm: rtw_en_napi:int
parm: rtw_en_gro:int
parm: rtw_iqk_fw_offload:int
parm: rtw_led_enable:Enable status LED (int)
