Hallo, ich habe ein Problem mit dem Wlan Hotspot im Networkmanager nach einem Hardwarewechsel. Kann mich nicht verbinden. Hier die Ausgabe des kaputten:
root@raspberrypi:/etc# egrep -i 'wlan|firm|reason' /var/log/syslog May 4 15:46:03 raspberrypi avahi-daemon[7853]: Joining mDNS multicast group on interface wlan0.IPv4 with address 10.42.0.1. May 4 15:46:03 raspberrypi avahi-daemon[7853]: New relevant interface wlan0.IPv4 for mDNS. May 4 15:46:03 raspberrypi avahi-daemon[7853]: Registering new address record for 10.42.0.1 on wlan0.IPv4. May 4 15:46:42 raspberrypi NetworkManager[1318]: <info> [1683208002.5416] device (wlan0): state change: activated -> deactivating (reason 'user-requested', sys-iface-state: 'managed') May 4 15:46:42 raspberrypi wpa_supplicant[1367]: wlan0: interface state ENABLED->DISABLED May 4 15:46:42 raspberrypi wpa_supplicant[1367]: wlan0: AP-DISABLED May 4 15:46:43 raspberrypi wpa_supplicant[1367]: wlan0: CTRL-EVENT-DISCONNECTED bssid=e4:5f:01:56:67:37 reason=3 locally_generated=1 May 4 15:46:43 raspberrypi wpa_supplicant[1367]: wlan0: CTRL-EVENT-DSCP-POLICY clear_all May 4 15:46:43 raspberrypi NetworkManager[1318]: <info> [1683208003.0751] device (wlan0): supplicant interface state: completed -> disconnected May 4 15:46:43 raspberrypi NetworkManager[1318]: <info> [1683208003.0752] device (p2p-dev-wlan0): supplicant management interface state: completed -> disconnected May 4 15:46:43 raspberrypi NetworkManager[1318]: <info> [1683208003.0754] device (wlan0): state change: deactivating -> disconnected (reason 'user-requested', sys-iface-state: 'managed') May 4 15:46:43 raspberrypi wpa_supplicant[1367]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD May 4 15:46:43 raspberrypi avahi-daemon[7853]: Withdrawing address record for 10.42.0.1 on wlan0. May 4 15:46:43 raspberrypi avahi-daemon[7853]: Leaving mDNS multicast group on interface wlan0.IPv4 with address 10.42.0.1. May 4 15:46:43 raspberrypi avahi-daemon[7853]: Interface wlan0.IPv4 no longer relevant for mDNS. May 4 15:46:43 raspberrypi wpa_supplicant[1367]: wlan0: Reject scan trigger since one is already pending May 4 15:46:54 raspberrypi NetworkManager[1318]: <info> [1683208014.6631] device (wlan0): Activation: starting connection 'test' (aa393fd4-7a8d-4902-9add-ee1e6c7ead12) May 4 15:46:54 raspberrypi NetworkManager[1318]: <info> [1683208014.6645] device (wlan0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed') May 4 15:46:54 raspberrypi NetworkManager[1318]: <info> [1683208014.6666] device (wlan0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed') May 4 15:46:54 raspberrypi NetworkManager[1318]: <info> [1683208014.6843] device (wlan0): Activation: (wifi) access point 'test' has security, but secrets are required. May 4 15:46:54 raspberrypi NetworkManager[1318]: <info> [1683208014.6845] device (wlan0): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed') May 4 15:46:54 raspberrypi NetworkManager[1318]: <info> [1683208014.6913] device (wlan0): state change: need-auth -> prepare (reason 'none', sys-iface-state: 'managed') May 4 15:46:54 raspberrypi NetworkManager[1318]: <info> [1683208014.6970] device (wlan0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed') May 4 15:46:54 raspberrypi NetworkManager[1318]: <info> [1683208014.7027] device (wlan0): Activation: (wifi) connection 'test' has security, and secrets exist. No new secrets needed. May 4 15:46:55 raspberrypi wpa_supplicant[1367]: wlan0: interface state UNINITIALIZED->ENABLED May 4 15:46:55 raspberrypi wpa_supplicant[1367]: wlan0: AP-ENABLED May 4 15:46:55 raspberrypi wpa_supplicant[1367]: wlan0: CTRL-EVENT-CONNECTED - Connection to e4:5f:01:56:67:37 completed [id=0 id_str=] May 4 15:46:55 raspberrypi NetworkManager[1318]: <info> [1683208015.1399] device (wlan0): supplicant interface state: disconnected -> completed May 4 15:46:55 raspberrypi NetworkManager[1318]: <info> [1683208015.1401] device (wlan0): Activation: (wifi) Stage 2 of 5 (Device Configure) successful. Started Wi-Fi Hotspot "test" May 4 15:46:55 raspberrypi NetworkManager[1318]: <info> [1683208015.1402] device (p2p-dev-wlan0): supplicant management interface state: disconnected -> completed May 4 15:46:55 raspberrypi NetworkManager[1318]: <info> [1683208015.1407] device (wlan0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed') May 4 15:46:55 raspberrypi avahi-daemon[7853]: Joining mDNS multicast group on interface wlan0.IPv4 with address 10.42.0.1. May 4 15:46:55 raspberrypi avahi-daemon[7853]: New relevant interface wlan0.IPv4 for mDNS. May 4 15:46:55 raspberrypi avahi-daemon[7853]: Registering new address record for 10.42.0.1 on wlan0.IPv4. May 4 15:46:55 raspberrypi NetworkManager[1318]: <info> [1683208015.3069] device (wlan0): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed') May 4 15:46:55 raspberrypi dnsmasq[8021]: chown of PID file /run/nm-dnsmasq-wlan0.pid failed: Vorgang nicht zulässig May 4 15:46:55 raspberrypi NetworkManager[1318]: <info> [1683208015.3873] device (wlan0): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed') May 4 15:46:55 raspberrypi NetworkManager[1318]: <info> [1683208015.3881] device (wlan0): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed') May 4 15:46:55 raspberrypi NetworkManager[1318]: <info> [1683208015.3913] device (wlan0): Activation: successful, device activated.
Und hier auf dem zweiten wo es geht:
root@studiopi2:/etc# egrep -i 'wlan|firm|reason' /var/log/syslog May 4 15:31:38 PiStudio2 NetworkManager[703]: <info> [1683207098.9983] device (wlan0): Activation: starting connection 'Hotspot' (bd5e6841-2272-416a-9c02-61ed60f56dcb) May 4 15:31:39 PiStudio2 NetworkManager[703]: <info> [1683207098.9996] device (wlan0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed') May 4 15:31:39 PiStudio2 NetworkManager[703]: <info> [1683207099.0022] device (wlan0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed') May 4 15:31:39 PiStudio2 NetworkManager[703]: <info> [1683207099.0033] device (wlan0): Activation: (wifi) access point 'Hotspot' has security, but secrets are required. May 4 15:31:39 PiStudio2 NetworkManager[703]: <info> [1683207099.0034] device (wlan0): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed') May 4 15:31:39 PiStudio2 NetworkManager[703]: <info> [1683207099.0334] device (wlan0): state change: need-auth -> prepare (reason 'none', sys-iface-state: 'managed') May 4 15:31:39 PiStudio2 NetworkManager[703]: <info> [1683207099.0360] device (wlan0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed') May 4 15:31:39 PiStudio2 NetworkManager[703]: <info> [1683207099.0383] device (wlan0): Activation: (wifi) connection 'Hotspot' has security, and secrets exist. No new secrets needed. May 4 15:31:39 PiStudio2 kernel: [ 564.771487] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready May 4 15:31:39 PiStudio2 NetworkManager[703]: <info> [1683207099.4675] device (wlan0): supplicant interface state: disconnected -> completed May 4 15:31:39 PiStudio2 wpa_supplicant[749]: wlan0: interface state UNINITIALIZED->ENABLED May 4 15:31:39 PiStudio2 NetworkManager[703]: <info> [1683207099.4676] device (wlan0): Activation: (wifi) Stage 2 of 5 (Device Configure) successful. Started Wi-Fi Hotspot "PiStudio2" May 4 15:31:39 PiStudio2 wpa_supplicant[749]: wlan0: AP-ENABLED May 4 15:31:39 PiStudio2 NetworkManager[703]: <info> [1683207099.4677] device (p2p-dev-wlan0): supplicant management interface state: disconnected -> completed May 4 15:31:39 PiStudio2 wpa_supplicant[749]: wlan0: CTRL-EVENT-CONNECTED - Connection to e4:5f:01:49:ae:e4 completed [id=0 id_str=] May 4 15:31:39 PiStudio2 NetworkManager[703]: <info> [1683207099.4682] device (wlan0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed') May 4 15:31:40 PiStudio2 avahi-daemon[706]: Joining mDNS multicast group on interface wlan0.IPv4 with address 10.42.0.1. May 4 15:31:40 PiStudio2 avahi-daemon[706]: New relevant interface wlan0.IPv4 for mDNS. May 4 15:31:40 PiStudio2 avahi-daemon[706]: Registering new address record for 10.42.0.1 on wlan0.IPv4. May 4 15:31:40 PiStudio2 NetworkManager[703]: <info> [1683207100.0699] device (wlan0): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed') May 4 15:31:40 PiStudio2 avahi-daemon[706]: Joining mDNS multicast group on interface wlan0.IPv6 with address fe80::cf12:e06a:3e61:9a22. May 4 15:31:40 PiStudio2 avahi-daemon[706]: New relevant interface wlan0.IPv6 for mDNS. May 4 15:31:40 PiStudio2 avahi-daemon[706]: Registering new address record for fe80::cf12:e06a:3e61:9a22 on wlan0.*. May 4 15:31:40 PiStudio2 dnsmasq[9464]: chown of PID file /run/nm-dnsmasq-wlan0.pid failed: Operation not permitted May 4 15:31:40 PiStudio2 NetworkManager[703]: <info> [1683207100.1225] device (wlan0): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed') May 4 15:31:40 PiStudio2 NetworkManager[703]: <info> [1683207100.1237] device (wlan0): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed') May 4 15:31:40 PiStudio2 NetworkManager[703]: <info> [1683207100.1273] device (wlan0): Activation: successful, device activated. May 4 15:32:20 PiStudio2 wpa_supplicant[749]: wlan0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0 May 4 15:32:20 PiStudio2 wpa_supplicant[749]: wlan0: AP-STA-CONNECTED 4a:ab:4c:a4:fa:b2 May 4 15:32:20 PiStudio2 wpa_supplicant[749]: wlan0: EAPOL-4WAY-HS-COMPLETED 4a:ab:4c:a4:fa:b2 May 4 15:32:23 PiStudio2 dnsmasq-dhcp[9464]: DHCPDISCOVER(wlan0) 4a:ab:4c:a4:fa:b2 May 4 15:32:23 PiStudio2 dnsmasq-dhcp[9464]: DHCPOFFER(wlan0) 10.42.0.70 4a:ab:4c:a4:fa:b2 May 4 15:32:23 PiStudio2 dnsmasq-dhcp[9464]: DHCPDISCOVER(wlan0) 4a:ab:4c:a4:fa:b2 May 4 15:32:23 PiStudio2 dnsmasq-dhcp[9464]: DHCPOFFER(wlan0) 10.42.0.70 4a:ab:4c:a4:fa:b2 May 4 15:32:23 PiStudio2 dnsmasq-dhcp[9464]: DHCPREQUEST(wlan0) 10.42.0.70 4a:ab:4c:a4:fa:b2
die Dateien unter /etc/NetworkManager sehen gleich aus. Der Hardwarewechsel bezieht sich auf: von einem Pi400 auf einen anderen PI400. Hat jmd eine Idee?
Moderiert von kB:
Aus dem Forum „Netzwerk und Internetzugang einrichten“ in einen besser passenden Forenbereich verschoben. Bitte beachte die als wichtig markierten Themen („Welche Themen gehören hier her und welche nicht?“) im jeweiligen Forum! Danke.
