Ich habe daselbe Problem mit dem Ruhezustand.
Hat jemand schon eine Lösung gefunden?
Ich habe in dem oben genannten File mehrere Kernelzeilen:
# grub-install(8), grub-floppy(8),
# grub-md5-crypt, /usr/share/doc/grub
# and /usr/share/doc/grub-doc/.
# Set the default entry to the entry number NUM. Numbering starts from 0, and
# the entry number 0 is the default if the command is not used.
# You can specify 'saved' instead of a number. In this case, the default entry
# is the entry saved with the command 'savedefault'.
# array will desync and will not let you boot your system.
default 0
# Set a timeout, in SEC seconds, before automatically booting the default entry
# (normally the first entry defined).
timeout 3
# Hides the menu by default (press ESC to see the menu)
hiddenmenu
# Pretty colours
#color cyan/blue white/blue
# If used in the first section of a menu file, disable all interactive editing
# control (menu entry editor and command-line) and entries protected by the
# command 'lock'
# e.g. password topsecret
# password --md5 $1$gLhU0/$aW78kHK1QfV3P2b2znUoe/
# password topsecret
# examples
# title Windows 95/98/NT/2000
# root (hd0,0)
# makeactive
# chainloader +1
# title Linux
# root (hd0,1)
# kernel /vmlinuz root=/dev/hda2 ro
# Put static boot stanzas before and/or after AUTOMAGIC KERNEL LIST
# kopt=root=UUID=1326a44f-9796-46f0-8d0d-a023ae3c01dd ro
# crashdump=0
# groot=(hd0,0)
# alternative=true
# lockalternative=false
# defoptions=quiet splash locale=de_DE
# lockold=false
# xenhopt=
# xenkopt=console=tty0
# altoptions=(recovery mode) single
# howmany=all
# memtest86=true
# updatedefaultentry=false
title Ubuntu 7.10, kernel 2.6.22-14-generic
root (hd0,0)
kernel /boot/vmlinuz-2.6.22-14-generic root=UUID=1326a44f-9796-46f0-8d0d-a023ae3c01dd ro quiet splash locale=de_DE
initrd /boot/initrd.img-2.6.22-14-generic
quiet
title Ubuntu 7.10, kernel 2.6.22-14-generic (recovery mode)
root (hd0,0)
kernel /boot/vmlinuz-2.6.22-14-generic root=UUID=1326a44f-9796-46f0-8d0d-a023ae3c01dd ro single
title Ubuntu 7.10, memtest86+
root (hd0,0)
kernel /boot/memtest86+.bin
quiet
Wo muss ich das force einfügen oder ersetzen?
