dejot
Anmeldungsdatum: 23. Oktober 2004
so, ich schon wieder ☹ also, jetzt kann ich zwar den X Server beenden, um die Grafiktreiber zu installieren, allerdings meckert jetzt der NVIDIA Installer. Er findet keine KernelSources, die er aber braucht, um irgendwas für die Treiber zu kompilieren ❓ ❓ Kennt sich mit dem Ding jemand aus? Und eigentlich habe ich extra mit Synaptic die Kernel-Header und Sources installiert. Komisch. 😢 ❓ edit: hier noch der Inhalt der nvidia-installer.log:
monvidia-installer log file '/var/log/nvidia-installer.log'
creation time: Sun Oct 24 18:51:12 2004
option status:
license pre-accepted : false
update : false
force update : false
expert : false
uninstall : false
driver info : false
no precompiled interface: false
no ncurses color : false
query latest driver ver : false
OpenGL header files : false
no questions : false
silent : false
X install prefix : /usr/X11R6
OpenGL install prefix : /usr
Installer install prefix: /usr
kernel source path : (not specified)
kernel install path : (not specified)
proc mount point : /proc
ui : (not specified)
tmpdir : /tmp
ftp site : ftp://download.nvidia.com
Using: nvidia-installer ncurses user interface
-> License accepted.
-> No precompiled kernel interface was found to match your kernel; would you li
ke the installer to attempt to download a kernel interface for your kernel f
rom the NVIDIA ftp site (ftp://download.nvidia.com)? (Answer: Yes)
-> No matching precompiled kernel interface was found on the NVIDIA ftp site;
this means that the installer will need to compile a kernel interface for
your kernel.
ERROR: Unable to find the kernel source tree for the currently running kernel.
Please make sure you have installed the kernel source files for your
kernel; on Red Hat Linux systems, for example, be sure you have the
'kernel-source' rpm installed. If you know the correct kernel source
files are installed, you may specify the kernel source path with the
'--kernel-source-path' commandline option.
ERROR: Installation has failed. Please see the file
'/var/log/nvidia-installer.log' for details. You may find suggestions
on fixing installation problems in the README available on the Linux
driver download page at www.nvidia.com.
Sid_Burn
Hmm, benutze mein eigenen selbstkompilierten Kernel, da habe ich das Problem nicht wirklich, daher kann ich dir nicht ganz genau sagen was du alles an Paketen brauchst bei den Standard initrd Kernel. Asnosnten: Installiere mal bei dir das Paket linux-source-2.6.8.1 Es sollte dann unter /usr/src ein entsprechender Komprimierter Kernel liegen. Diesen musst du dann mit tar entpacken. Danach nochmal den installer ausführen. Wenn die selbe Meldung kommt dann führe den Treiber mal mit der Option. --kernel-source-path=/usr/src/linux-2.6.8.1 aus. Oder halt eben so, wie der Path sonst heißt.
Apollon
Anmeldungsdatum: 27. Oktober 2004
Folgendes sollte helfen: sudo apt-get install linux-headers-2.6.8.1-3-i386 Danach den nVidia Installer starten und es solte funktionieren.
dejot
habs schon hinbekommen, trotzdem danke! ☺
chrusu
Anmeldungsdatum: 2. November 2004
Wie hast Du es denn am Ende geschaft? Ich habe nämlich dasselbe Problem, habe mir die linux-sources-2.6.8.1 installiert(linux-sources-2.6.8.1-3-386 gibt kann man nicht apten) aber der installer meckert immernoch. Hättest Du mir vielleicht einen Tipp? mfg chrusu
Sid_Burn
chrusu hat geschrieben: Wie hast Du es denn am Ende geschaft? Ich habe nämlich dasselbe Problem, habe mir die linux-sources-2.6.8.1 installiert(linux-sources-2.6.8.1-3-386 gibt kann man nicht apten) aber der installer meckert immernoch. Hättest Du mir vielleicht einen Tipp? mfg chrusu
Hast du auch HEaders, gcc etc. installiert? Poste doch mal die Fehlermeldung, raten was du für ein Problem hast, wird schwer. 😉
chrusu
Fehlermeldung:
nvidia-installer log file '/var/log/nvidia-installer.log' creation time: Tue Nov 2 17:13:28 2004 option status: license pre-accepted : false update : false force update : false expert : false uninstall : false driver info : false no precompiled interface: false no ncurses color : false query latest driver ver : false OpenGL header files : false no questions : false silent : false X install prefix : /usr/X11R6 OpenGL install prefix : /usr Installer install prefix: /usr kernel source path : /usr/src/linux-source-2.6.8.1 kernel install path : (not specified) proc mount point : /proc ui : (not specified) tmpdir : /tmp ftp site : ftp://download.nvidia.com Using: nvidia-installer ncurses user interface → License accepted. → No precompiled kernel interface was found to match your kernel; would you li ke the installer to attempt to download a kernel interface for your kernel f rom the NVIDIA ftp site (ftp://download.nvidia.com)? (Answer: No) → No precompiled kernel interface was found to match your kernel; this means that the installer will need to compile a new kernel interface. → Using the kernel source path '/usr/src/linux-source-2.6.8.1' as specified by the '--kernel-source-path' commandline option. → Kernel source path: '/usr/src/linux-source-2.6.8.1' → Performing cc_version_check with CC="cc". ERROR: If you are using a Linux 2.4 kernel, please make sure you either have configured kernel sources matching your kernel or the correct set of kernel headers installed on your system. If you are using a Linux 2.6 kernel, please make sure you have configured kernel sources matching your kernel installed on your system. If you specified a separate output directory using either the "KBUILD_OUTPUT" or the "O" KBUILD parameter, make sure to specify this directory with the SYSOUT environment variable or with the appropriate nvidia-installer command line option. ERROR: Installation has failed. Please see the file '/var/log/nvidia-installer.log' for details. You may find suggestions on fixing installation problems in the README available on the Linux driver download page at www.nvidia.com.
Was ist denn HEaders? gcc habe ich installiert
Apollon
Hallo! Also die Lösung habe ich schon vor 4 Einträgen gepostet. Sieht wie folgt aus:
sudo apt-get install linux-headers-2.6.8.1-3-i386 Danach in das Verzeichniss mit dem nVidia-Installer wechseln und dort folgendes eingeben:
sh ./NVIDIA-Linux-x86-1.0-6111-pkg1.run --kernel-source-path=/usr/src/linux-headers-2.6.8.1-3-386 Sollte funktionieren. Hat bei mir zumindest.
chrusu
Danke, hat funktionniert, habe statt linux-headers-2.6.8.1-3-386 versucht die linux-source-2.6.8.1-3-386 zu installieren, was natürlich nicht funktionniert hat. Nun meckert der Installer aber wegen einem rivafb-modul. Kann ich das problemlos deinstallieren?
chrusu
Und weisst Du ev. wie das geht?
dejot
hab das einfach ignoriert, hab bisher keine Probleme, da steht ja auch, dass das nur unter gewissen Umständen Probleme machen kann ... ☺ Die NVIDIA Treiber habe ich inzwischen per apt installiert ... ich glaube
apt-get install nvidia-glx
chrusu
Danke, nun geht es, weiss auch nicht was vorhin nicht gegangen ist! und der treiber von apt funktionniert bei dir genausogut?
dejot
jap, funktioniert wunderbar, weiß zwar nciht wo der unterschied ist, aber so ists bequemer, und es geht. Kannst deine 3d Leistung mit glxgears testen.
chrusu
Ich habe nun ein interessantes Problem, es hat funktionniert, ich konnte auch den x-server abschiessen und neustarten sooft ich wollte, wenn ich dann aber den computer neustarte will x mit dem nvidia-treiber nicht mehr starten. dann habe ich den nvidia-treiber neu installiert –> funktionniert. dann wieder neu gestartet –> funktionniert nicht nvidia-treiber neu installiert –> funktionniert immer noch nicht! woran kann das liegen?
Apollon
Hallo! Das nvidia Modul wird einfach nicht automatisch geladen. Das Problem löst Du indem du die Datei /etc/modules anpasst. Trage einfach "nvidia" in die Liste ein. Lass die Datei z.B. so aussehen: # /etc/modules: kernel modules to load at boot time.
# This file should contain the names of kernel modules that are
# to be loaded at boot time, one per line. Comments begin with
# a "#", and everything on the line after them are ignored.
psmouse
mousedev
ide-cd
ide-disk
ide-generic
lp
nvidia Nun wird das nvidia Modul beim booten geladen.
