Hallo zusammen! Nach einem Update von 10.10 werde ich laut der syslog ziemlich genau alle 10 Minuten aus dem WLAN geworfen: [13802.952710] wlan0: deauthenticated from bc:05:43:88:a1:3d (Reason: 6)
Vielen Dank für eure Hilfe =😮)
Folgende ausgaben gibts dazu:
uname -a
Linux Animal 2.6.38-8-generic #42-Ubuntu SMP Mon Apr 11 03:31:24 UTC 2011 x86_64 x86_64 x86_64 GNU/Linux
lspci -nnk | grep -i net -A2
00:07.0 Bridge [0680]: nVidia Corporation MCP61 Ethernet [10de:03ef] (rev a2) Subsystem: Giga-byte Technology Device [1458:e000] Kernel driver in use: forcedeth
lsusb
Bus 002 Device 002: ID 046d:c03e Logitech, Inc. Premium Optical Wheel Mouse (M-BT58) Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 001 Device 008: ID 07d1:3c0f D-Link System AirPlus G DWL-G122 Wireless Adapter(rev.E) [Ralink RT2870] Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
egrep -v "^$|^#" /etc/network/interfaces
auto lo iface lo inet loopback
grep -v "^$|^#" /etc/resolv.conf
domain fritz.box search fritz.box nameserver 192.168.178.1
egrep -v "^$|^#" /etc/hosts
127.0.0.1 localhost.localdomain localhost ::1 Animal localhost6.localdomain6 localhost6 ::1 localhost ip6-localhost ip6-loopback fe00::0 ip6-localnet ff00::0 ip6-mcastprefix ff02::1 ip6-allnodes ff02::2 ip6-allrouters ff02::3 ip6-allhosts
cat /etc/udev/rules.d/70-persistent-net.rules
# This file maintains persistent names for network interfaces. # See udev(7) for syntax. # # Entries are automatically added by the 75-persistent-net-generator.rules # file; however you are also free to add your own entries. # PCI device 0x10de:0x03ef (forcedeth) SUBSYSTEM=="net", ACTION=="add", DRIVERS=="?*", ATTR{address}=="00:24:1d:6a:ec:3a", ATTR{dev_id}=="0x0", ATTR{type}=="1", KERNEL=="eth*", NAME="eth0" # USB device 0x07d1:0x3c0f (usb) SUBSYSTEM=="net", ACTION=="add", DRIVERS=="?*", ATTR{address}=="f0:7d:68:6c:ab:7a", ATTR{dev_id}=="0x0", ATTR{type}=="1", KERNEL=="wlan*", NAME="wlan0"
ifconfig
eth0 Link encap:Ethernet Hardware Adresse 00:24:1d:6a:ec:3a UP BROADCAST MULTICAST MTU:1500 Metrik:1 RX packets:0 errors:0 dropped:0 overruns:0 frame:0 TX packets:0 errors:0 dropped:0 overruns:0 carrier:0 Kollisionen:0 Sendewarteschlangenlänge:1000 RX bytes:0 (0.0 B) TX bytes:0 (0.0 B) Interrupt:41 Basisadresse:0x8000 lo Link encap:Lokale Schleife inet Adresse:127.0.0.1 Maske:255.0.0.0 inet6-Adresse: ::1/128 Gültigkeitsbereich:Maschine UP LOOPBACK RUNNING MTU:16436 Metrik:1 RX packets:1513 errors:0 dropped:0 overruns:0 frame:0 TX packets:1513 errors:0 dropped:0 overruns:0 carrier:0 Kollisionen:0 Sendewarteschlangenlänge:0 RX bytes:97002 (97.0 KB) TX bytes:97002 (97.0 KB) wlan0 Link encap:Ethernet Hardware Adresse f0:7d:68:6c:ab:7a inet Adresse:192.168.178.23 Bcast:192.168.178.255 Maske:255.255.255.0 inet6-Adresse: fe80::f27d:68ff:fe6c:ab7a/64 Gültigkeitsbereich:Verbindung UP BROADCAST RUNNING MULTICAST MTU:1500 Metrik:1 RX packets:11148 errors:0 dropped:0 overruns:0 frame:0 TX packets:7012 errors:0 dropped:0 overruns:0 carrier:0 Kollisionen:0 Sendewarteschlangenlänge:1000 RX bytes:14981674 (14.9 MB) TX bytes:822940 (822.9 KB)
route -n
Kernel-IP-Routentabelle Ziel Router Genmask Flags Metric Ref Use Iface 192.168.178.0 0.0.0.0 255.255.255.0 U 2 0 0 wlan0 169.254.0.0 0.0.0.0 255.255.0.0 U 1000 0 0 wlan0 0.0.0.0 192.168.178.1 0.0.0.0 UG 0 0 0 wlan0
iwconfig
lo no wireless extensions. eth0 no wireless extensions. vboxnet0 no wireless extensions. wlan0 IEEE 802.11bg ESSID:"Milliways" Mode:Managed Frequency:2.457 GHz Access Point: BC:05:43:88:A1:3D Bit Rate=54 Mb/s Tx-Power=20 dBm Retry long limit:7 RTS thr:off Fragment thr:off Power Management:on Link Quality=69/70 Signal level=-41 dBm Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0 Tx excessive retries:63 Invalid misc:0 Missed beacon:0
ping -c 4 www.ubuntuusers.de
PING ubuntuusers.de (213.95.41.13) 56(84) bytes of data. 64 bytes from lisa.ubuntu-eu.org (213.95.41.13): icmp_req=1 ttl=58 time=26.1 ms 64 bytes from lisa.ubuntu-eu.org (213.95.41.13): icmp_req=2 ttl=58 time=26.3 ms 64 bytes from lisa.ubuntu-eu.org (213.95.41.13): icmp_req=3 ttl=58 time=27.4 ms 64 bytes from lisa.ubuntu-eu.org (213.95.41.13): icmp_req=4 ttl=58 time=28.2 ms --- ubuntuusers.de ping statistics --- 4 packets transmitted, 4 received, 0% packet loss, time 3003ms rtt min/avg/max/mdev = 26.116/27.032/28.212/0.857 ms
ping -c 4 213.95.41.11
PING 213.95.41.11 (213.95.41.11) 56(84) bytes of data. 64 bytes from 213.95.41.11: icmp_req=1 ttl=58 time=23.9 ms 64 bytes from 213.95.41.11: icmp_req=2 ttl=58 time=89.6 ms 64 bytes from 213.95.41.11: icmp_req=4 ttl=58 time=26.3 ms --- 213.95.41.11 ping statistics --- 4 packets transmitted, 3 received, 25% packet loss, time 3007ms rtt min/avg/max/mdev = 23.954/46.654/89.691/30.447 ms
iwlist chan
lo no frequency information. eth0 no frequency information. vboxnet0 no frequency information. wlan0 14 channels in total; available frequencies : Channel 01 : 2.412 GHz Channel 02 : 2.417 GHz Channel 03 : 2.422 GHz Channel 04 : 2.427 GHz Channel 05 : 2.432 GHz Channel 06 : 2.437 GHz Channel 07 : 2.442 GHz Channel 08 : 2.447 GHz Channel 09 : 2.452 GHz Channel 10 : 2.457 GHz Channel 11 : 2.462 GHz Channel 12 : 2.467 GHz Channel 13 : 2.472 GHz Channel 14 : 2.484 GHz Current Frequency:2.457 GHz (Channel 10)
iwlist scan
lo Interface doesn't support scanning. eth0 Interface doesn't support scanning. vboxnet0 Interface doesn't support scanning. wlan0 Scan completed : Cell 01 - Address: BC:05:43:88:A1:3D Channel:10 Frequency:2.457 GHz (Channel 10) Quality=70/70 Signal level=-37 dBm Encryption key:on ESSID:"Milliways" Bit Rates:1 Mb/s; 2 Mb/s; 5.5 Mb/s; 11 Mb/s; 6 Mb/s 9 Mb/s; 12 Mb/s; 18 Mb/s Bit Rates:24 Mb/s; 36 Mb/s; 48 Mb/s; 54 Mb/s Mode:Master Extra:tsf=00000004d8ac8afb Extra: Last beacon: 510ms ago IE: Unknown: 00094D696C6C6977617973 IE: Unknown: 010882848B960C121824 IE: Unknown: 03010A IE: IEEE 802.11i/WPA2 Version 1 Group Cipher : TKIP Pairwise Ciphers (1) : CCMP Authentication Suites (1) : PSK IE: WPA Version 1 Group Cipher : TKIP Pairwise Ciphers (1) : TKIP Authentication Suites (1) : PSK IE: Unknown: 2A0100 IE: Unknown: 32043048606C IE: Unknown: DD180050F2020101830003A4000027A4000042435E0062322F00 IE: Unknown: 2D1ACE131B0000000000000000000000000000000000000000000000 IE: Unknown: 3D160A071B00000000000000000000000000000000000000 IE: Unknown: DD0900037F01010000FF7F IE: Unknown: DD0A00037F04010020000000 IE: Unknown: DD6F0050F204104A0001101044000102103B000100104700100000000A000000000000BC054388A13D1021000341564D10230009465249545A21426F781024000430303030104200043030303010540008000000000000000010110009465249545A21426F78100800020188103C000103
rfkill list
1: phy1: Wireless LAN Soft blocked: no Hard blocked: no
lsmod
Module Size Used by ssb 51945 0 cryptd 20510 0 aes_x86_64 17208 1 aes_generic 38279 1 aes_x86_64 nls_iso8859_1 12713 0 nls_cp437 16991 0 vfat 21708 0 fat 61374 1 vfat dm_crypt 22993 0 binfmt_misc 17565 1 vboxnetadp 13340 0 vboxnetflt 28297 0 vboxdrv 252684 2 vboxnetadp,vboxnetflt snd_hda_codec_realtek 336693 1 saa7134_alsa 18551 0 mt20xx 17878 1 gspca_zc3xx 52441 0 gspca_main 36853 1 gspca_zc3xx tea5767 13298 0 tda9887 18263 1 tda8290 22627 0 tuner 27386 2 rt2870sta 450556 0 arc4 12529 2 ir_lirc_codec 12898 0 lirc_dev 19232 1 ir_lirc_codec ir_sony_decoder 12549 0 ir_jvc_decoder 12546 0 ir_rc6_decoder 12546 0 nvidia 10709116 48 rt2800usb 18235 0 rt2800lib 45181 1 rt2800usb crc_ccitt 12667 2 rt2870sta,rt2800lib rt2x00usb 20330 1 rt2800usb rt2x00lib 49235 3 rt2800usb,rt2800lib,rt2x00usb mac80211 294370 3 rt2800lib,rt2x00usb,rt2x00lib cfg80211 178528 2 rt2x00lib,mac80211 snd_hda_intel 33211 4 snd_hda_codec 103804 2 snd_hda_codec_realtek,snd_hda_intel snd_hwdep 13604 1 snd_hda_codec ppdev 17113 0 snd_pcm 96625 4 saa7134_alsa,snd_hda_intel,snd_hda_codec saa7134 177094 1 saa7134_alsa ir_rc5_decoder 12546 0 snd_seq_midi 13324 0 ir_nec_decoder 12546 0 snd_rawmidi 30486 1 snd_seq_midi rc_core 26918 7 ir_lirc_codec,ir_sony_decoder,ir_jvc_decoder,ir_rc6_decoder,saa7134,ir_rc5_decoder,ir_nec_decoder parport_pc 36959 1 snd_seq_midi_event 14899 1 snd_seq_midi snd_seq 61621 2 snd_seq_midi,snd_seq_midi_event k10temp 13119 0 snd_timer 29602 2 snd_pcm,snd_seq edac_core 53845 0 snd_seq_device 14462 3 snd_seq_midi,snd_rawmidi,snd_seq edac_mce_amd 23464 0 v4l2_common 17647 2 tuner,saa7134 videodev 82052 4 gspca_main,tuner,saa7134,v4l2_common v4l2_compat_ioctl32 17078 1 videodev videobuf_dma_sg 19307 2 saa7134_alsa,saa7134 videobuf_core 26135 2 saa7134,videobuf_dma_sg tveeprom 21249 1 saa7134 snd 67382 17 snd_hda_codec_realtek,saa7134_alsa,snd_hda_intel,snd_hda_codec,snd_hwdep,snd_pcm,snd_rawmidi,snd_seq,snd_timer,snd_seq_device soundcore 12680 1 snd i2c_nforce2 13058 0 snd_page_alloc 18529 2 snd_hda_intel,snd_pcm lp 17825 0 parport 46458 3 ppdev,parport_pc,lp vesafb 13761 1 usbhid 46956 0 hid 91020 1 usbhid usb_storage 53538 0 uas 17996 0 floppy 74120 0 forcedeth 63555 0 pata_amd 14130 0 sata_nv 32054 4
dmesg | egrep 'net|eth|sky|sis|via|3c3|3c5|e100|8139|8169|acx|air|ath|ar91|atme|at7|herm|iwl|ipw|rtl8|r81|rt2|rt6|rt7|tg3|ssb|wl|b43|b44|ori|pri|p5|zd|ndis|wmi'
[ 0.000000] PERCPU: Embedded 28 pages/cpu @ffff8800dfc00000 s84416 r8192 d22080 u524288 [ 0.000000] pcpu-alloc: s84416 r8192 d22080 u524288 alloc=1*2097152 [ 0.000000] Aperture beyond 4GB. Ignoring. [ 0.013235] Initializing cgroup subsys net_cls [ 0.630963] print_constraints: dummy: [ 0.684975] wmi: Mapper loaded [ 0.716424] pnp 00:01: [mem 0xfefe1000-0xfefe10ff] [ 0.716499] system 00:01: [mem 0xfefe1000-0xfefe10ff] has been reserved [ 0.760130] audit: initializing netlink socket (disabled) [ 1.191992] i2c-core: driver [adp5520] using legacy suspend method [ 1.191994] i2c-core: driver [adp5520] using legacy resume method [ 1.192881] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com> [ 1.450316] device-mapper: multipath: version 1.2.0 loaded [ 1.450318] device-mapper: multipath round-robin: version 1.0.0 loaded [ 1.515151] forcedeth: Reverse Engineered nForce ethernet driver. Version 0.64. [ 1.515316] forcedeth 0000:00:07.0: PCI INT A -> Link[APCH] -> GSI 20 (level, low) -> IRQ 20 [ 1.515321] forcedeth 0000:00:07.0: setting latency timer to 64 [ 2.040847] forcedeth 0000:00:07.0: ifname eth0, PHY OUI 0x732 @ 1, addr 00:24:1d:6a:ec:3a [ 2.040851] forcedeth 0000:00:07.0: highdma pwrctl mgmt lnktim msi desc-v3 [ 2.389904] ata4: port disabled. ignoring. [ 18.679733] Adding 2104476k swap on /dev/sda5. Priority:-1 extents:1 across:2104476k [ 18.785576] k10temp 0000:00:18.3: unreliable CPU thermal sensor; monitoring disabled [ 18.860161] parport0: Printer, Hewlett-Packard HP LaserJet 1100 [ 19.034592] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht' [ 19.035116] Registered led device: rt2800usb-phy0::radio [ 19.035136] Registered led device: rt2800usb-phy0::assoc [ 19.035156] Registered led device: rt2800usb-phy0::quality [ 19.035379] usbcore: registered new interface driver rt2800usb [ 19.036589] rt2870sta: module is from the staging directory, the quality is unknown, you have been warned. [ 19.040889] usbcore: registered new interface driver rt2870 [ 19.192065] i2c-core: driver [tuner] using legacy suspend method [ 19.192069] i2c-core: driver [tuner] using legacy resume method [ 20.830794] ADDRCONF(NETDEV_UP): wlan0: link is not ready [ 21.463045] forcedeth 0000:00:07.0: irq 41 for MSI/MSI-X [ 21.463234] forcedeth 0000:00:07.0: eth0: no link during initialization [ 21.464091] ADDRCONF(NETDEV_UP): eth0: link is not ready [ 56.984362] wlan0: authenticate with bc:05:43:88:a1:3d (try 1) [ 56.987113] wlan0: authenticated [ 59.014106] wlan0: associate with bc:05:43:88:a1:3d (try 1) [ 59.017618] wlan0: RX AssocResp from bc:05:43:88:a1:3d (capab=0x431 status=0 aid=1) [ 59.017621] wlan0: associated [ 59.026160] ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready [ 69.150007] wlan0: no IPv6 routers present [ 414.413493] process `skype' is using obsolete setsockopt SO_BSDCOMPAT [ 1208.032191] wlan0: deauthenticated from bc:05:43:88:a1:3d (Reason: 6) [ 1208.240807] cfg80211: Restoring regulatory settings [ 1211.696185] wlan0: authenticate with bc:05:43:88:a1:3d (try 1) [ 1211.698965] wlan0: authenticated [ 1213.696933] wlan0: associate with bc:05:43:88:a1:3d (try 1) [ 1213.702690] wlan0: RX AssocResp from bc:05:43:88:a1:3d (capab=0x431 status=0 aid=1) [ 1213.702695] wlan0: associated [ 1804.284794] wlan0: deauthenticated from bc:05:43:88:a1:3d (Reason: 6) [ 1806.450861] cfg80211: Restoring regulatory settings [ 1809.947298] wlan0: authenticate with bc:05:43:88:a1:3d (try 1) [ 1809.949938] wlan0: authenticated [ 1811.946912] wlan0: associate with bc:05:43:88:a1:3d (try 1) [ 1811.952792] wlan0: RX AssocResp from bc:05:43:88:a1:3d (capab=0x431 status=0 aid=1) [ 1811.952797] wlan0: associated [ 2412.961412] wlan0: deauthenticated from bc:05:43:88:a1:3d (Reason: 6) [ 2413.140757] cfg80211: Restoring regulatory settings [ 2416.594514] wlan0: authenticate with bc:05:43:88:a1:3d (try 1) [ 2416.597294] wlan0: authenticated [ 2418.596890] wlan0: associate with bc:05:43:88:a1:3d (try 1) [ 2418.602783] wlan0: RX AssocResp from bc:05:43:88:a1:3d (capab=0x431 status=0 aid=1) [ 2418.602789] wlan0: associated [ 3003.012784] wlan0: deauthenticated from bc:05:43:88:a1:3d (Reason: 6) [ 3005.150716] cfg80211: Restoring regulatory settings [ 3008.604625] wlan0: authenticate with bc:05:43:88:a1:3d (try 1) [ 3008.608028] wlan0: authenticated [ 3010.604119] wlan0: associate with bc:05:43:88:a1:3d (try 1) [ 3010.606882] wlan0: RX AssocResp from bc:05:43:88:a1:3d (capab=0x431 status=0 aid=1) [ 3010.606887] wlan0: associated [ 3598.048747] wlan0: deauthenticated from bc:05:43:88:a1:3d (Reason: 6) [ 3600.210834] cfg80211: Restoring regulatory settings [ 3603.664603] wlan0: authenticate with bc:05:43:88:a1:3d (try 1) [ 3603.667507] wlan0: authenticated [ 3605.674224] wlan0: associate with bc:05:43:88:a1:3d (try 1) [ 3605.676852] wlan0: RX AssocResp from bc:05:43:88:a1:3d (capab=0x431 status=0 aid=1) [ 3605.676857] wlan0: associated [ 4202.803844] wlan0: deauthenticated from bc:05:43:88:a1:3d (Reason: 6) [ 4202.990837] cfg80211: Restoring regulatory settings [ 4206.455829] wlan0: authenticate with bc:05:43:88:a1:3d (try 1) [ 4206.458598] wlan0: authenticated [ 4208.466946] wlan0: associate with bc:05:43:88:a1:3d (try 1) [ 4208.472738] wlan0: RX AssocResp from bc:05:43:88:a1:3d (capab=0x431 status=0 aid=1) [ 4208.472750] wlan0: associated [ 5405.984415] wlan0: deauthenticated from bc:05:43:88:a1:3d (Reason: 6) [ 5406.170751] cfg80211: Restoring regulatory settings [ 5409.625020] wlan0: authenticate with bc:05:43:88:a1:3d (try 1) [ 5409.627784] wlan0: authenticated [ 5411.636903] wlan0: associate with bc:05:43:88:a1:3d (try 1) [ 5411.642789] wlan0: RX AssocResp from bc:05:43:88:a1:3d (capab=0x431 status=0 aid=1) [ 5411.642795] wlan0: associated [ 6000.217775] wlan0: deauthenticated from bc:05:43:88:a1:3d (Reason: 6) [ 6000.390747] cfg80211: Restoring regulatory settings [ 6003.844890] wlan0: authenticate with bc:05:43:88:a1:3d (try 1) [ 6003.847655] wlan0: authenticated [ 6005.846882] wlan0: associate with bc:05:43:88:a1:3d (try 1) [ 6005.852679] wlan0: RX AssocResp from bc:05:43:88:a1:3d (capab=0x431 status=0 aid=1) [ 6005.852686] wlan0: associated [ 7198.048501] wlan0: deauthenticated from bc:05:43:88:a1:3d (Reason: 2) [ 7202.151560] cfg80211: Restoring regulatory settings [ 7205.606468] wlan0: authenticate with bc:05:43:88:a1:3d (try 1) [ 7205.609232] wlan0: authenticated [ 7207.604842] wlan0: associate with bc:05:43:88:a1:3d (try 1) [ 7207.611620] wlan0: RX AssocResp from bc:05:43:88:a1:3d (capab=0x431 status=0 aid=1) [ 7207.611626] wlan0: associated [ 7798.048354] wlan0: deauthenticated from bc:05:43:88:a1:3d (Reason: 6) [ 7800.280792] cfg80211: Restoring regulatory settings [ 7803.765819] wlan0: authenticate with bc:05:43:88:a1:3d (try 1) [ 7803.768594] wlan0: authenticated [ 7805.764564] wlan0: associate with bc:05:43:88:a1:3d (try 1) [ 7805.767582] wlan0: RX AssocResp from bc:05:43:88:a1:3d (capab=0x431 status=0 aid=1) [ 7805.767587] wlan0: associated [ 9009.012814] wlan0: deauthenticated from bc:05:43:88:a1:3d (Reason: 6) [ 9011.180859] cfg80211: Restoring regulatory settings [ 9014.635272] wlan0: authenticate with bc:05:43:88:a1:3d (try 1) [ 9014.639797] wlan0: authenticated [ 9016.634519] wlan0: associate with bc:05:43:88:a1:3d (try 1) [ 9016.637152] wlan0: RX AssocResp from bc:05:43:88:a1:3d (capab=0x431 status=0 aid=1) [ 9016.637158] wlan0: associated [ 9602.310752] wlan0: deauthenticated from bc:05:43:88:a1:3d (Reason: 6) [ 9604.456714] cfg80211: Restoring regulatory settings [ 9611.905497] wlan0: authenticate with bc:05:43:88:a1:3d (try 1) [ 9611.908274] wlan0: authenticated [ 9613.906871] wlan0: associate with bc:05:43:88:a1:3d (try 1) [ 9613.912631] wlan0: RX AssocResp from bc:05:43:88:a1:3d (capab=0x431 status=0 aid=1) [ 9613.912637] wlan0: associated [11412.951701] wlan0: deauthenticated from bc:05:43:88:a1:3d (Reason: 6) [11413.100801] cfg80211: Restoring regulatory settings [11416.554931] wlan0: authenticate with bc:05:43:88:a1:3d (try 1) [11416.557709] wlan0: authenticated [11418.556928] wlan0: associate with bc:05:43:88:a1:3d (try 1) [11418.562810] wlan0: RX AssocResp from bc:05:43:88:a1:3d (capab=0x431 status=0 aid=1) [11418.562815] wlan0: associated [12000.379300] wlan0: deauthenticated from bc:05:43:88:a1:3d (Reason: 6) [12002.528731] cfg80211: Restoring regulatory settings [12005.987242] wlan0: authenticate with bc:05:43:88:a1:3d (try 1) [12005.990079] wlan0: authenticated [12007.996904] wlan0: associate with bc:05:43:88:a1:3d (try 1) [12008.003787] wlan0: RX AssocResp from bc:05:43:88:a1:3d (capab=0x431 status=0 aid=1) [12008.003793] wlan0: associated [12605.468155] wlan0: deauthenticated from bc:05:43:88:a1:3d (Reason: 6) [12605.750757] cfg80211: Restoring regulatory settings [12609.210514] wlan0: authenticate with bc:05:43:88:a1:3d (try 1) [12609.213283] wlan0: authenticated [12611.216883] wlan0: associate with bc:05:43:88:a1:3d (try 1) [12611.222801] wlan0: RX AssocResp from bc:05:43:88:a1:3d (capab=0x431 status=0 aid=1) [12611.222808] wlan0: associated [13205.983007] wlan0: deauthenticated from bc:05:43:88:a1:3d (Reason: 6) [13206.111393] cfg80211: Restoring regulatory settings [13209.569939] wlan0: authenticate with bc:05:43:88:a1:3d (try 1) [13209.572778] wlan0: authenticated [13211.586864] wlan0: associate with bc:05:43:88:a1:3d (try 1) [13211.592629] wlan0: RX AssocResp from bc:05:43:88:a1:3d (capab=0x431 status=0 aid=1) [13211.592634] wlan0: associated [13242.763494] wlan0: deauthenticating from bc:05:43:88:a1:3d by local choice (reason=3) [13242.830201] cfg80211: Restoring regulatory settings [13248.533181] ieee80211 phy1: Selected rate control algorithm 'minstrel_ht' [13248.534132] Registered led device: rt2800usb-phy1::radio [13248.534166] Registered led device: rt2800usb-phy1::assoc [13248.534199] Registered led device: rt2800usb-phy1::quality [13249.001043] ADDRCONF(NETDEV_UP): wlan0: link is not ready [13259.914722] wlan0: authenticate with bc:05:43:88:a1:3d (try 1) [13259.917617] wlan0: authenticated [13261.914220] wlan0: associate with bc:05:43:88:a1:3d (try 1) [13261.916978] wlan0: RX AssocResp from bc:05:43:88:a1:3d (capab=0x431 status=0 aid=1) [13261.916983] wlan0: associated [13261.925912] ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready [13272.840015] wlan0: no IPv6 routers present [13802.952710] wlan0: deauthenticated from bc:05:43:88:a1:3d (Reason: 6) [13803.100776] cfg80211: Restoring regulatory settings [13806.557065] wlan0: authenticate with bc:05:43:88:a1:3d (try 1) [13806.559826] wlan0: authenticated [13808.557061] wlan0: associate with bc:05:43:88:a1:3d (try 1) [13808.562966] wlan0: RX AssocResp from bc:05:43:88:a1:3d (capab=0x431 status=0 aid=1) [13808.562972] wlan0: associated
