Nach Neuinstallation kein USB mehr
bstoeve
23. Oktober 2022
nachdem ich mein System neu auf meinem Rechner isntalliert habe (schlimm genug), funktioniert keine USB Verbindung mehr. Hier die Informationen:
uname -a
Linux bs1 6.8.0-63-generic #66-Ubuntu SMP PREEMPT_DYNAMIC Fri Jun 13 20:25:30 UTC 2025 x86_64 x86_64 x86_64 GNU/Linux
Which is the system and the usb-output of dmesg is:
sudo dmesg |grep -i USB
[sudo] Passwort für bs1:
[    0.394961] ACPI: bus type USB registered
[    0.395016] usbcore: registered new interface driver usbfs
[    0.395091] usbcore: registered new interface driver hub
[    0.395161] usbcore: registered new device driver usb
[    0.566668] ehci-pci 0000:00:1a.0: new USB bus registered, assigned bus number 1
[    0.577261] ehci-pci 0000:00:1a.0: USB 2.0 started, EHCI 1.00
[    0.577447] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.08
[    0.577600] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.577751] usb usb1: Product: EHCI Host Controller
[    0.577753] usb usb1: Manufacturer: Linux 6.8.0-63-generic ehci_hcd
[    0.577875] usb usb1: SerialNumber: 0000:00:1a.0
[    0.578261] hub 1-0:1.0: USB hub found
[    0.579028] ehci-pci 0000:00:1d.0: new USB bus registered, assigned bus number 2
[    0.590431] ehci-pci 0000:00:1d.0: USB 2.0 started, EHCI 1.00
[    0.590764] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.08
[    0.590878] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.590985] usb usb2: Product: EHCI Host Controller
[    0.591059] usb usb2: Manufacturer: Linux 6.8.0-63-generic ehci_hcd
[    0.591140] usb usb2: SerialNumber: 0000:00:1d.0
[    0.591702] hub 2-0:1.0: USB hub found
[    0.823389] usb 1-1: new high-speed USB device number 2 using ehci-pci
[    0.824031] Workqueue: usb_hub_wq hub_event
[    0.825934]  usb_hcd_map_urb_for_dma+0x1a9/0x4d0
[    0.826681]  usb_hcd_submit_urb+0x16b/0x2d0
[    0.826753]  usb_submit_urb+0x258/0x670
[    0.826825]  usb_start_wait_urb+0x8f/0x1a0
[    0.826896]  usb_control_msg+0x117/0x190
[    0.830356] usb 2-1: new high-speed USB device number 2 using ehci-pci
[    1.007290] usb 1-1: device descriptor read/64, error -11
[    1.007371] usb 2-1: device descriptor read/64, error -11
[    1.225809] usb 1-1: device descriptor read/64, error -11
[    1.225901] usb 2-1: device descriptor read/64, error -11
[    1.444879] usb 1-1: new high-speed USB device number 3 using ehci-pci
[    1.444994] usb 2-1: new high-speed USB device number 3 using ehci-pci
[    1.558880] usb 1-1: device descriptor read/64, error -11
[    1.558970] usb 2-1: device descriptor read/64, error -11
[    1.780851] usb 1-1: device descriptor read/64, error -11
[    1.780943] usb 2-1: device descriptor read/64, error -11
[    1.882830] usb usb2-port1: attempt power cycle
[    1.882924] usb usb1-port1: attempt power cycle
[    2.060851] usb 2-1: new high-speed USB device number 4 using ehci-pci
[    2.060952] usb 1-1: new high-speed USB device number 4 using ehci-pci
[    2.474846] usb 1-1: device not accepting address 4, error -11
[    2.474950] usb 2-1: device not accepting address 4, error -11
[    2.588845] usb 1-1: new high-speed USB device number 5 using ehci-pci
[    2.589007] usb 2-1: new high-speed USB device number 5 using ehci-pci
[    3.002853] usb 2-1: device not accepting address 5, error -11
[    3.002973] usb 1-1: device not accepting address 5, error -11
[    3.003077] usb usb2-port1: unable to enumerate USB device
[    3.003166] usb usb1-port1: unable to enumerate USB device
Es ist also der Fehler -11. Dazu habe ich aber kaum etwas gefunden. Es liegt nicht am Stick oder der Device. Es geht nichts. Im BIOS ist USB angeschaltet. Im Moment weiß ich nicht, wo ich suchen muss. Weiß eins was?
Moderiert von redknight:
Verschoben.
Knarf68
Avatar von Knarf68
14. Mai 2013
Mit einem Live System funktioniert USB?
Nach dem Update besteht das Problem noch?
bstoeve
23. Oktober 2022
Hab upgrade gemacht. Jetzt ist das System by
uname -a
Linux bs1 6.8.0-71-generic #71-Ubuntu SMP PREEMPT_DYNAMIC Tue Jul 22 16:52:38 UTC 2025 x86_64 x86_64 x86_64 GNU/Linux
Keine Änderung. Wenn ich 24.04.2 vom Stick boote, funktionieren die USB-Sticks.
schwarzheit Team-Icon
Avatar von schwarzheit
31. Dezember 2007
Was genau hast du installiert?
Weil wenn du wie gesagt Ubuntu 24.04 sauber neu installiert hättest hättest du den HWE Kernel und der ist bei 6.14.
Bitte zeige uns, hier im Forum als Codeblock formatiert, die vollständige Ein- und Ausgabe dieses Befehls:
inxi -Fz
(Benutze Kopieren Strg + C und Einfügen Strg + V . Im Terminal braucht es zusätzlich die -Taste.)
trollsportverein
Avatar von trollsportverein
21. Oktober 2010
Mal die Hardware Datenbanken aktualisieren:
sudo /usr/sbin/update-pciids
sudo wget -t1 -T 20 -O /var/lib/usbutils/usb.ids 'https://usb-ids.gowdy.us/usb.ids'
Gegebenenfalls dann usbreset benutzen:
Oder alles, was in USB-Ports drinsteckt, abstöpseln und wieder einstöpseln. Wenn das nicht reicht, System runterfahren und neustarten. Reicht auch das nicht, dann das System runterfahren, stromlos machen, etwas warten, und dann wieder mit Strom versorgen und booten.
bstoeve
23. Oktober 2022
@schwarzheit
Hier die Infos zum System:
inxi -Fz
System:
  Kernel: 6.8.0-71-generic arch: x86_64 bits: 64
  Desktop: GNOME v: 46.0 Distro: Ubuntu 24.04.2 LTS (Noble Numbat)
Machine:
  Type: Laptop System: LENOVO product: 2537UEZ v: ThinkPad T410
    serial: <superuser required>
  Mobo: LENOVO model: 2537UEZ serial: <superuser required> BIOS: LENOVO
    v: 6IET85WW (1.45 ) date: 02/14/2013
Battery:
  ID-1: BAT0 charge: 52.7 Wh (99.8%) condition: 52.8/71.3 Wh (74.1%)
CPU:
  Info: dual core model: Intel Core i5 M 560 bits: 64 type: MT MCP cache:
    L2: 512 KiB
  Speed (MHz): avg: 1265 min/max: 1199/2667 cores: 1: 1199 2: 1199 3: 1199
    4: 1463
Graphics:
  Device-1: Intel Core Processor Integrated Graphics driver: i915 v: kernel
  Display: wayland server: X.Org v: 23.2.6 with: Xwayland v: 23.2.6
    compositor: gnome-shell driver: X: loaded: vesa unloaded: fbdev,modesetting
    dri: crocus gpu: i915 resolution: 1280x800~60Hz
  API: EGL v: 1.5 drivers: crocus,swrast
    platforms: gbm,wayland,x11,surfaceless,device
  API: OpenGL v: 4.5 compat-v: 2.1 vendor: intel mesa
    v: 24.2.8-1ubuntu1~24.04.1 renderer: Mesa Intel HD Graphics (ILK)
Audio:
  Device-1: Intel 5 Series/3400 Series High Definition Audio
    driver: snd_hda_intel
  API: ALSA v: k6.8.0-71-generic status: kernel-api
  Server-1: PipeWire v: 1.0.5 status: active
Network:
  Device-1: Intel 82577LM Gigabit Network driver: e1000e
  IF: enp0s25 state: down mac: <filter>
  Device-2: Intel Centrino Advanced-N 6200 driver: iwlwifi
  IF: wlp3s0 state: up mac: <filter>
Drives:
  Local Storage: total: 931.51 GiB used: 542.53 GiB (58.2%)
  ID-1: /dev/sda vendor: HGST (Hitachi) model: HTS541010A9E680
Partition:
  ID-1: / size: 18.16 GiB used: 213.1 MiB (1.1%) fs: ext4 dev: /dev/sda7
  ID-2: /boot/efi size: 950.8 MiB used: 6.1 MiB (0.6%) fs: vfat
    dev: /dev/sda3
  ID-3: /home size: 744.17 GiB used: 505.57 GiB (67.9%) fs: ext4
    dev: /dev/sda11
  ID-4: /opt size: 22.75 GiB used: 422 MiB (1.8%) fs: ext4 dev: /dev/sda8
  ID-5: /usr size: 41.87 GiB used: 6.06 GiB (14.5%) fs: ext4 dev: /dev/sda6
  ID-6: /var size: 10.9 GiB used: 3.55 GiB (32.6%) fs: ext4 dev: /dev/sda9
Swap:
  ID-1: swap-1 type: partition size: 14.9 GiB used: 0 KiB (0.0%)
    dev: /dev/sda5
Sensors:
  System Temperatures: cpu: 40.0 C mobo: N/A
  Fan Speeds (rpm): fan-1: 1797
Info:
  Memory: total: 4 GiB note: est. available: 3.37 GiB used: 1.58 GiB (46.8%)
  Processes: 259 Uptime: 12h 26m Shell: Bash inxi: 3.3.34
Bearbeitet von schwarzheit:
Fullquote entfernt. Bitte benutze keine kompletten Zitate.
bstoeve
23. Oktober 2022
trollsportverein
Also das scheitert schon bei
/var/lib/usbutils/usb.ids: Datei oder Verzeichnis nicht gefunden
Also /var/lib/usbutils gibt es als Verzeichnis bei mir nicht, obwohl ich das Paket installiert habe.
Alles ausstöpseln, Neustart hatte ich schon. Ich kann mal versuchen runterzufahren und die Batterie rauszunehmen. Aber ich fürchte, es liegt an etwas anderem.
Ubunux
12. Juni 2006
Versuche es so:
sudo wget -t1 -T 20 -O /usr/share/misc/usb.ids 'https://usb-ids.gowdy.us/usb.ids'
trollsportverein
21. Oktober 2010
Seit dem haben die usbutils Veränderungen erfahren. Die usb.ids gibt es jetzt als Extrapaket in einem DEB-Paket.
sudo apt-get install usb.ids
Direkt von Stephen J. Gowdy sind die natürlich aktueller:
31. Dezember 2007
Deine Angaben passen nach wie vor nicht zusammen. Weil wie oben bereits erläutert eine saubere Neuinstallation den HWE Kernel 6.14 installiert hätte der bei dir nicht vorhanden zu sein scheint.
Also was genau hast du wirklich gemacht?
Und wenn ich eine Frage stelle möchte ich die auch beantwortet haben und nicht nur die Terminalausgabe vorgeworfen kriegen!
Ausserdem:
Bitte unterlasse Fullquotes. Sie blähen den Thread nur sinnlos auf.
Lies dazu Zitate.
Da steht eindeutig:
Hier wird ausdrücklich von "Teile eines vorherigen Beitrags" gesprochen, gesamte -also komplette- Beitragen zu zitieren ist unerwünscht.
Und wenn man direkt antwortet reicht ein @[user:Benutzername:] da braucht es garkein Zitat.
Knarf68
Avatar von Knarf68
14. Mai 2013
Poste mal ein:
lsb_release -a
Bei mir oben der Rechner hat auch noch 24.04.2 drauf und macht kein Release Upgrade. Mit Kernel 6.8.0-71. Mein Rechner hat automatisch auf Version 24.04.3 upgedatet, is auch neuer.
P.S. im Wiki im download Bereich ist noch Version 24.04.2 verlinkt zum Teil nicht mehr Download fähig.
Der link wäre: Ubuntu Noble 24.04.03 download
trollsportverein
21. Oktober 2010
Probiere mal eine Bootoption aus.
Einfügen in die Kernel Bootoptionen:
nohz=off
