Mplayer will nicht ???
osmanovic100
20. Oktober 2004
wenn ich mplayer starte kommt diese fehler:
Reading config file /etc/mplayer/mplayer.conf
Ungültiger Maschinenbefehl
pero@ubuntu:~ $ cd /etc/mplayer
pero@ubuntu:/etc/mplayer $ nano mplayer.conf
pero@ubuntu:/etc/mplayer $ mplayer
MPlayer 1.0pre5-3.3.4 (C) 2000-2004 MPlayer Team
CPU: Advanced Micro Devices Duron MG Morgan 1200 MHz (Family: 6, Stepping: 1)
Detected cache-line size is 64 bytes
3DNow supported but disabled
3DNowExt supported but disabled
CPUflags:  MMX: 1 MMX2: 1 3DNow: 0 3DNow2: 0 SSE: 1 SSE2: 0
Compiled for x86 CPU with extensions: MMX MMX2 SSE SSE2
## MPlayer config file
## This file can be copied to /etc/mplayer.conf and/or ~/.mplayer/config .
## If both exist, the ~/.mplayer/config's settings override the
## /etc/mplayer.conf ones. And, of course command line overrides all.
## The options are the same as in the command line, but they can be specified
## more flexibly here. See below.
vo=x11,                 # To specify default video driver (see -vo help for
                        # list)
ao=alsa,                # To specify default audio driver (see -ao help for
                        # list)
fs=no                   # Enlarges movie window to your desktop's size.
                        # Used by drivers: all
vm=no                   # Tries to change to a different videomode
                        # Used by drivers: dga2, x11, sdl
bpp=0                   # Force changing display depth.
                        # Valid settings are: 0, 15, 16, 24, 32
                        # may need 'vm=yes' too.
                        # Used by drivers: fbdev, dga2, svga
zoom=no                 # Enable software scaling (powerful CPU needed)
                        # Used by drivers: svga, aalib
double=yes              # use double-buffering (recommended for xv with
                        # SUB/OSD usage)
# x=800                 # scale movie to <x> pixels width
# y=600                 # scale movie to <y> pixels height
osdlevel=1              # don't display OSD at stratup
monitoraspect=4:3       # standard monitor size, with square pixels
# monitoraspect=16:9    # use this for widescreen monitor! non-square pixels
cache = 1024            # Disk cache 1 MB
## Specify your preferred default skin here
## (skins are searched in /usr/share/mplayer/Skin/yourskin
##  and ~/.mplayer/Skin/yourskin)
skin = default
## Multiple languages are available :)
## Hungarian    igen    nem
## English      yes     no
## German       ja      nein
## Spanish      si      no
## Binary       1       0
## You can also use spaces and/or tabs.
#sound          = 1
#nosound        = nein
#mixer          = /dev/mixer
## resample the fonts' alphamap
## 0    plain white fonts
## 0.75 very narrow black outline (default)
## 1    narrow black outline
## 10   bold black outline
#ffactor = 0.75
## FBdev driver:
# fb = /dev/fb0                         # framebuffer device to use
# fbmode = 640x480-120                  # use this mode (read from fb.modes!)
# fbmodeconfig = /etc/fb.modes          # the fb.modes file
## VESA and FBdev driver: specify your monitor's timings
## (see for example /etc/X11/XF86Config for timings!)
## ** CAUTION! IF YOUR DISPLAY DOESN'T SUPPORT AUTOMATICALLY TURNING OFF WHEN
##    OVERDRIVED (AND EVEN IF IT DOES), THIS MAY CAUSE DAMAGE TO YOUR DISPLAY!
##    WE AREN'T RESPONSIBLE, IT'S YOUR DECISION! **
## k, K : means multiply by 1000
## m, M : means multiply by 1.000.000
# monitor_hfreq = 31.5k-50k,70k         # horizontal frequency range
# monitor_vfreq = 50-90                 # vertical frequency range
# monitor_dotclock = 30M-300M           # dotclock (or pixelclock) range
## SDL driver
# vo = sdl:aalib        # use SDL video driver by default
                        # use "vo = sdl:aalib" or "vo sdl:dga" and so on,
                        # for specifying SDL subdrivers
# ao = sdl:esd          # use SDL audio driver by default
                        # use "ao = sdl:esd" to use SDL's ESD driver
# noxv = no             # whether to use XVideo hardware acceleration or not
# forcexv = yes         # force XVideo even if not detected
## Other (preferred to be default from configfile) switches
framedrop=no            # drop frames, when not in sync (slow CPU, videocard,
                        # etc)
#vfm=ffmpeg             # use FFmpeg's libavcodec video codec family
                        # See "mplayer -vfm help" for all available codecs
#bps=yes                # use this method for playing AVIs (if have problems,
                        # try removing this)
# slang= en             # DVD : display english subtitles if available
# alang= en             # DVD : play english audio tracks if available
## This is the correct way to use "subconfig" type options in the
## configuration file. In the command line you use :
## -aop list=resample:fout=44100 , but here it is :
# aop=list=resample:fout=44100
# From Fedora
# the default mpeg audio decoder is currently broken, let's try libmad
# first:
afm=libmad
# get a default OSD font from fontconfig
#fontconfig = yes
#font = "Sans"
#subfont-text-scale = 3
ich wollte auch empfolene pakete installieren aber:
root@ubuntu:/etc/mplayer # apt-get install libggi-target-x libggi-target
mplayer-fonts
Abhängigkeitsbaum wird aufgebaut... Fertig
libggi-target-x ist schon die neueste Version.
Pakete libggi-target ist ein virtuelles Pakete, das bereitgestellt wird von:
  libggi-target-vcsa 1:2.0.4-3
  libggi-target-terminfo 1:2.0.4-3
  libggi-target-svgalib 1:2.0.4-3
  libggi-target-glide 1:2.0.4-3
  libggi-target-fbdev 1:2.0.4-3
  libggi-target-aa 1:2.0.4-3
  libggi-target-x 1:2.0.4-3
Sie sollten eines explizit zum Installieren auswählen.
E: Paket libggi-target hat keinen Installationskandidaten
komme nicht weiter ☹
Danke im vorraus für antwort
noiZe.dj
Avatar von noiZe.dj
23. Oktober 2004
Der Mplayer ist leider falsch kompiliert. Das Paket läuft nur auf einem P4. Musst dich gedulden bist das Paket neu kompiliert wird oder du machst es selbst.
cyco Team-Icon
Avatar von cyco
18. Oktober 2004
Hi,
wenn du auf einem Athlon oder Duron den mplayer benutzten willst, solltest du folgendes Paket benutzen:
mplayer-k6 (und zwar in der Version 1:1.0-pre5-sarge0.3)
Dann wird das ganze auch funzen.
Aber das vorherige deinstallieren des alten Pakets nicht vergessen. 😉
cya,
cyco ☺
Badcel
Avatar von Badcel
25. Oktober 2004
Und ich wundere mich warum der mplayer nicht geht 😳
naja jetzt geht ja alles 8)
MfG
Badcel
