Matlab 2014 - Installation auf Xubuntu 14.04 bricht ab.
Status: Ungelöst | Ubuntu-Version: Xubuntu 14.04 (Trusty Tahr)
jacopo-belbo
19. Mai 2012
die Installation von Matlab 2014 bricht nach allen Konfigurationen in der install-gui (./install), also mit dem Start der eigentlichen Installation ab und wird folgende Fehlermeldung:
The application encountered an unexpected error and needs to close. You may want to try re-installing your product(s). More information can be found at /tmp/mathworks_root.log
Ím Log findet sich folgendes zu dem Fehler:
(May 22, 2014 16:02:42) java.lang.NullPointerException
	at com.mathworks.install.ComponentSizeAggregator.add(ComponentSizeAggregator.java:13)
	at com.mathworks.install.ProductInstallerImpl.downloadProducts(ProductInstallerImpl.java:96)
	at com.mathworks.install.ProductInstallerImpl.installProducts(ProductInstallerImpl.java:57)
	at com.mathworks.install.InstallerImpl.install(InstallerImpl.java:96)
	at com.mathworks.installwizard.model.InstallTask.execute(InstallTask.java:46)
	at com.mathworks.installwizard.model.AbstractBackgroundTask.execute(AbstractBackgroundTask.java:38)
	at com.mathworks.installwizard.model.AbstractTask.call(AbstractTask.java:73)
	at com.mathworks.installwizard.model.AbstractTask.call(AbstractTask.java:23)
	at com.mathworks.wizard.worker.WorkerImpl.doInBackground(WorkerImpl.java:24)
	at javax.swing.SwingWorker$1.call(Unknown Source)
	at java.util.concurrent.FutureTask$Sync.innerRun(Unknown Source)
	at java.util.concurrent.FutureTask.run(Unknown Source)
	at javax.swing.SwingWorker.run(Unknown Source)
	at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
	at java.lang.Thread.run(Unknown Source)
(May 22, 2014 16:02:42) Error: The application encountered an unexpected error and needs to close.  You may want to try re-installing your product(s).  More information can be found at /tmp/mathworks_root.log
(May 22, 2014 16:02:46) Exiting with status -1
(May 22, 2014 16:02:46) End - Unsuccessful
(May 22, 2014 16:09:51) ##################################################################
Kann jemand hierin sehen, wie ich den Fehler beheben kann?
Vielen Dank im Voraus,
Jacopo
