Hello,
Ich habe Internet durch Wlan (USB Stick) und wollte einen Router, NAS Server in auf meinen Computer einbinden. Mein LAN stellt keine Verbindung zu Router oder NAS Server um den zu Konfigurieren.
sudo lspci -nnk | grep -A3 -i net
sudo lspci -nnk | grep -A3 -i net 04:00.0 Ethernet controller [0200]: Intel Corporation I211 Gigabit Network Connection [8086:1539] (rev 03) Subsystem: Gigabyte Technology Co., Ltd I211 Gigabit Network Connection [1458:e000] Kernel driver in use: igb Kernel modules: igb 05:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Reserved SPP [1022:1485]
ip addr show
ip addr show 1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000 link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00 inet 127.0.0.1/8 scope host lo valid_lft forever preferred_lft forever inet6 ::1/128 scope host valid_lft forever preferred_lft forever 2: enp4s0: <BROADCAST,MULTICAST,ALLMULTI,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000 link/ether 18:c0:4d:01:6f:38 brd ff:ff:ff:ff:ff:ff 3: wlx10bf485b893c: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000 link/ether 10:bf:48:5b:89:3c brd ff:ff:ff:ff:ff:ff inet 192.168.150.55/24 brd 192.168.150.255 scope global dynamic noprefixroute wlx10bf485b893c valid_lft 2773sec preferred_lft 2773sec inet6 fe80::2d5a:7d44:c360:61e1/64 scope link noprefixroute valid_lft forever preferred_lft forever 4: virbr0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state DOWN group default qlen 1000 link/ether 52:54:00:41:1e:5a brd ff:ff:ff:ff:ff:ff inet 192.168.122.1/24 brd 192.168.122.255 scope global virbr0 valid_lft forever preferred_lft forever
systemctl status NetworkManager.service
systemctl status NetworkManager.service ● NetworkManager.service - Network Manager Loaded: loaded (/lib/systemd/system/NetworkManager.service; enabled; vendor preset: enabled) Active: active (running) since Mon 2023-02-06 05:53:17 CET; 1h 45min ago Docs: man:NetworkManager(8) Main PID: 1189 (NetworkManager) Tasks: 3 (limit: 28611) Memory: 9.9M CPU: 7.214s CGroup: /system.slice/NetworkManager.service └─1189 /usr/sbin/NetworkManager --no-daemon
sudo journalctl -b 0 -u NetworkManager
sudo journalctl -b 0 -u NetworkManager Feb 06 05:53:17 deb systemd[1]: Starting Network Manager... Feb 06 05:53:17 deb NetworkManager[1189]: <info> [1675659197.1569] NetworkManager (version 1.36.6) is starting... (for the first time) Feb 06 05:53:17 deb NetworkManager[1189]: <info> [1675659197.1572] Read config: /etc/NetworkManager/NetworkManager.conf (lib: 10-dns-resolved.conf, no-mac-addr-change.conf) (run: 10-globally-managed-devices.conf) (etc: default-wifi-powersave-on.conf) Feb 06 05:53:17 deb NetworkManager[1189]: <info> [1675659197.1763] bus-manager: acquired D-Bus service "org.freedesktop.NetworkManager" Feb 06 05:53:17 deb NetworkManager[1189]: <info> [1675659197.1790] manager[0x55991505d040]: monitoring kernel firmware directory '/lib/firmware'. Feb 06 05:53:17 deb NetworkManager[1189]: <info> [1675659197.1790] monitoring ifupdown state file '/run/network/ifstate'. Feb 06 05:53:17 deb systemd[1]: Started Network Manager. Feb 06 05:53:17 deb NetworkManager[1189]: <info> [1675659197.2638] hostname: hostname: using hostnamed Feb 06 05:53:17 deb NetworkManager[1189]: <info> [1675659197.2639] hostname: static hostname changed from (none) to "deb" Feb 06 05:53:17 deb NetworkManager[1189]: <info> [1675659197.2643] dns-mgr[0x55991503c2a0]: init: dns=systemd-resolved rc-manager=unmanaged (auto), plugin=systemd-resolved Feb 06 05:53:17 deb NetworkManager[1189]: <info> [1675659197.2648] manager[0x55991505d040]: rfkill: Wi-Fi hardware radio set enabled Feb 06 05:53:17 deb NetworkManager[1189]: <info> [1675659197.2649] manager[0x55991505d040]: rfkill: WWAN hardware radio set enabled Feb 06 05:53:17 deb NetworkManager[1189]: <info> [1675659197.2671] Loaded device plugin: NMBluezManager (/usr/lib/x86_64-linux-gnu/NetworkManager/1.36.6/libnm-device-plugin-bluetooth.so) Feb 06 05:53:17 deb NetworkManager[1189]: <info> [1675659197.2675] Loaded device plugin: NMAtmManager (/usr/lib/x86_64-linux-gnu/NetworkManager/1.36.6/libnm-device-plugin-adsl.so) Feb 06 05:53:17 deb NetworkManager[1189]: <info> [1675659197.2692] Loaded device plugin: NMTeamFactory (/usr/lib/x86_64-linux-gnu/NetworkManager/1.36.6/libnm-device-plugin-team.so) Feb 06 05:53:17 deb NetworkManager[1189]: <info> [1675659197.2699] Loaded device plugin: NMWifiFactory (/usr/lib/x86_64-linux-gnu/NetworkManager/1.36.6/libnm-device-plugin-wifi.so) Feb 06 05:53:17 deb NetworkManager[1189]: <info> [1675659197.2703] Loaded device plugin: NMWwanFactory (/usr/lib/x86_64-linux-gnu/NetworkManager/1.36.6/libnm-device-plugin-wwan.so) Feb 06 05:53:17 deb NetworkManager[1189]: <info> [1675659197.2705] manager: rfkill: Wi-Fi enabled by radio killswitch; enabled by state file Feb 06 05:53:17 deb NetworkManager[1189]: <info> [1675659197.2706] manager: rfkill: WWAN enabled by radio killswitch; enabled by state file Feb 06 05:53:17 deb NetworkManager[1189]: <info> [1675659197.2706] manager: Networking is enabled by state file Feb 06 05:53:17 deb NetworkManager[1189]: <info> [1675659197.2716] settings: Loaded settings plugin: ifupdown ("/usr/lib/x86_64-linux-gnu/NetworkManager/1.36.6/libnm-settings-plugin-ifupdown.so") Feb 06 05:53:17 deb NetworkManager[1189]: <info> [1675659197.2717] settings: Loaded settings plugin: keyfile (internal) Feb 06 05:53:17 deb NetworkManager[1189]: <info> [1675659197.2717] ifupdown: management mode: unmanaged Feb 06 05:53:17 deb NetworkManager[1189]: <info> [1675659197.2718] ifupdown: interface-parser: parsing file /etc/network/interfaces Feb 06 05:53:17 deb NetworkManager[1189]: <info> [1675659197.2720] ifupdown: interface-parser: source line includes interfaces file(s) /etc/network/interfaces.d/* Feb 06 05:53:17 deb NetworkManager[1189]: <info> [1675659197.2720] ifupdown: interfaces file /etc/network/interfaces.d/* doesn't exist Feb 06 05:53:17 deb NetworkManager[1189]: <info> [1675659197.2720] ifupdown: interface-parser: finished parsing file /etc/network/interfaces Feb 06 05:53:17 deb NetworkManager[1189]: <info> [1675659197.2769] dhcp-init: Using DHCP client 'internal' Feb 06 05:53:17 deb NetworkManager[1189]: <info> [1675659197.2769] device (lo): carrier: link connected Feb 06 05:53:17 deb NetworkManager[1189]: <info> [1675659197.2771] manager: (lo): new Generic device (/org/freedesktop/NetworkManager/Devices/1) Feb 06 05:53:17 deb NetworkManager[1189]: <info> [1675659197.2777] manager: (enp4s0): new Ethernet device (/org/freedesktop/NetworkManager/Devices/2) Feb 06 05:53:17 deb NetworkManager[1189]: <info> [1675659197.2779] device (enp4s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external') Feb 06 05:53:17 deb NetworkManager[1189]: <info> [1675659197.3033] failed to open /run/network/ifstate Feb 06 05:53:17 deb NetworkManager[1189]: <info> [1675659197.3069] modem-manager: ModemManager available Feb 06 05:53:17 deb NetworkManager[1189]: <info> [1675659197.3077] manager: (AC:1E:9E:07:7F:FF): new Bluetooth device (/org/freedesktop/NetworkManager/Devices/3) Feb 06 05:53:17 deb NetworkManager[1189]: <info> [1675659197.3079] device (AC:1E:9E:07:7F:FF): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external') Feb 06 05:53:17 deb NetworkManager[1189]: <info> [1675659197.3083] device (AC:1E:9E:07:7F:FF): state change: unavailable -> disconnected (reason 'none', sys-iface-state: 'managed') Feb 06 05:53:17 deb NetworkManager[1189]: <info> [1675659197.3608] device (wlan0): driver supports Access Point (AP) mode Feb 06 05:53:17 deb NetworkManager[1189]: <info> [1675659197.3615] manager: (wlan0): new 802.11 Wi-Fi device (/org/freedesktop/NetworkManager/Devices/4) Feb 06 05:53:17 deb NetworkManager[1189]: <info> [1675659197.3993] rfkill1: found Wi-Fi radio killswitch (at /sys/devices/pci0000:00/0000:00:08.1/0000:0c:00.3/usb5/5-4/5-4:1.0/ieee80211/phy0/rfkill1) (driver rt2800usb) Feb 06 05:53:17 deb NetworkManager[1189]: <info> [1675659197.4521] device (wlan0): interface index 3 renamed iface from 'wlan0' to 'wlx10bf485b893c' Feb 06 05:53:17 deb NetworkManager[1189]: <info> [1675659197.4549] device (wlx10bf485b893c): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external') Feb 06 05:53:18 deb NetworkManager[1189]: <info> [1675659198.3698] manager: (virbr0): new Bridge device (/org/freedesktop/NetworkManager/Devices/5) Feb 06 05:53:18 deb NetworkManager[1189]: <info> [1675659198.3854] device (wlx10bf485b893c): supplicant interface state: internal-starting -> disconnected Feb 06 05:53:18 deb NetworkManager[1189]: <info> [1675659198.3855] device (wlx10bf485b893c): state change: unavailable -> disconnected (reason 'supplicant-available', sys-iface-state: 'managed') Feb 06 05:53:18 deb NetworkManager[1189]: <info> [1675659198.7905] device (virbr0): state change: unmanaged -> unavailable (reason 'connection-assumed', sys-iface-state: 'external') Feb 06 05:53:18 deb NetworkManager[1189]: <info> [1675659198.7907] device (virbr0): state change: unavailable -> disconnected (reason 'connection-assumed', sys-iface-state: 'external') Feb 06 05:53:18 deb NetworkManager[1189]: <info> [1675659198.7910] device (virbr0): Activation: starting connection 'virbr0' (a8f55baf-d62c-464e-aa73-19bfd3f28527) Feb 06 05:53:18 deb NetworkManager[1189]: <info> [1675659198.7911] device (virbr0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'external') Feb 06 05:53:18 deb NetworkManager[1189]: <info> [1675659198.7912] device (virbr0): state change: prepare -> config (reason 'none', sys-iface-state: 'external') Feb 06 05:53:18 deb NetworkManager[1189]: <info> [1675659198.7914] device (virbr0): state change: config -> ip-config (reason 'none', sys-iface-state: 'external') Feb 06 05:53:18 deb NetworkManager[1189]: <info> [1675659198.7921] device (virbr0): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'external') Feb 06 05:53:18 deb NetworkManager[1189]: <info> [1675659198.7931] device (virbr0): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'external') Feb 06 05:53:18 deb NetworkManager[1189]: <info> [1675659198.7932] device (virbr0): state change: secondaries -> activated (reason 'none', sys-iface-state: 'external') Feb 06 05:53:18 deb NetworkManager[1189]: <info> [1675659198.7934] manager: NetworkManager state is now CONNECTED_LOCAL Feb 06 05:53:18 deb NetworkManager[1189]: <info> [1675659198.7936] device (virbr0): Activation: successful, device activated. Feb 06 05:53:19 deb NetworkManager[1189]: <info> [1675659199.1569] device (enp4s0): carrier: link connected Feb 06 05:53:19 deb NetworkManager[1189]: <info> [1675659199.1570] device (enp4s0): state change: unavailable -> disconnected (reason 'carrier-changed', sys-iface-state: 'managed') Feb 06 05:53:19 deb NetworkManager[1189]: <info> [1675659199.1581] policy: auto-activating connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 05:53:19 deb NetworkManager[1189]: <info> [1675659199.1583] device (enp4s0): Activation: starting connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 05:53:19 deb NetworkManager[1189]: <info> [1675659199.1584] device (enp4s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed') Feb 06 05:53:19 deb NetworkManager[1189]: <info> [1675659199.1585] manager: NetworkManager state is now CONNECTING Feb 06 05:53:19 deb NetworkManager[1189]: <info> [1675659199.1585] device (enp4s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed') Feb 06 05:53:19 deb NetworkManager[1189]: <info> [1675659199.1593] device (enp4s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed') Feb 06 05:53:19 deb NetworkManager[1189]: <info> [1675659199.1603] dhcp4 (enp4s0): activation: beginning transaction (timeout in 45 seconds) Feb 06 05:53:21 deb NetworkManager[1189]: <info> [1675659201.0600] failed to open /run/network/ifstate Feb 06 05:53:24 deb NetworkManager[1189]: <info> [1675659204.6759] agent-manager: agent[7b575bb7357f0c4d,:1.68/org.kde.plasma.networkmanagement/1000]: agent registered Feb 06 05:53:25 deb NetworkManager[1189]: <info> [1675659205.0035] audit: op="statistics" interface="enp4s0" ifindex=2 args="500" pid=2422 uid=1000 result="success" Feb 06 05:53:25 deb NetworkManager[1189]: <info> [1675659205.0094] audit: op="statistics" interface="AC:1E:9E:07:7F:FF" args="500" pid=2422 uid=1000 result="success" Feb 06 05:53:25 deb NetworkManager[1189]: <info> [1675659205.0107] audit: op="statistics" interface="wlx10bf485b893c" ifindex=3 args="500" pid=2422 uid=1000 result="success" Feb 06 05:53:25 deb NetworkManager[1189]: <info> [1675659205.0463] audit: op="statistics" interface="AC:1E:9E:07:7F:FF" args="500" pid=2422 uid=1000 result="success" Feb 06 05:53:25 deb NetworkManager[1189]: <info> [1675659205.0476] audit: op="statistics" interface="AC:1E:9E:07:7F:FF" args="500" pid=2422 uid=1000 result="success" Feb 06 05:53:26 deb NetworkManager[1189]: <info> [1675659206.4581] policy: auto-activating connection 'NETGEAR57-5G' (c4360aa6-da0a-4f7c-b0a6-27d04ec4c041) Feb 06 05:53:26 deb NetworkManager[1189]: <info> [1675659206.4586] device (wlx10bf485b893c): Activation: starting connection 'NETGEAR57-5G' (c4360aa6-da0a-4f7c-b0a6-27d04ec4c041) Feb 06 05:53:26 deb NetworkManager[1189]: <info> [1675659206.4589] device (wlx10bf485b893c): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed') Feb 06 05:53:26 deb NetworkManager[1189]: <info> [1675659206.4593] device (wlx10bf485b893c): state change: prepare -> config (reason 'none', sys-iface-state: 'managed') Feb 06 05:53:26 deb NetworkManager[1189]: <info> [1675659206.4596] device (wlx10bf485b893c): Activation: (wifi) access point 'NETGEAR57-5G' has security, but secrets are required. Feb 06 05:53:26 deb NetworkManager[1189]: <info> [1675659206.4598] device (wlx10bf485b893c): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed') Feb 06 05:53:26 deb NetworkManager[1189]: <info> [1675659206.4600] sup-iface[a76d91eefb3e4511,0,wlx10bf485b893c]: wps: type pbc start... Feb 06 05:53:26 deb NetworkManager[1189]: <info> [1675659206.5308] device (wlx10bf485b893c): supplicant interface state: disconnected -> scanning Feb 06 05:53:26 deb NetworkManager[1189]: <info> [1675659206.5750] device (wlx10bf485b893c): state change: need-auth -> prepare (reason 'none', sys-iface-state: 'managed') Feb 06 05:53:26 deb NetworkManager[1189]: <info> [1675659206.5753] device (wlx10bf485b893c): state change: prepare -> config (reason 'none', sys-iface-state: 'managed') Feb 06 05:53:26 deb NetworkManager[1189]: <info> [1675659206.5755] device (wlx10bf485b893c): Activation: (wifi) connection 'NETGEAR57-5G' has security, and secrets exist. No new secrets needed. Feb 06 05:53:26 deb NetworkManager[1189]: <info> [1675659206.5755] Config: added 'ssid' value 'NETGEAR57-5G' Feb 06 05:53:26 deb NetworkManager[1189]: <info> [1675659206.5755] Config: added 'scan_ssid' value '1' Feb 06 05:53:26 deb NetworkManager[1189]: <info> [1675659206.5755] Config: added 'bgscan' value 'simple:30:-70:86400' Feb 06 05:53:26 deb NetworkManager[1189]: <info> [1675659206.5756] Config: added 'key_mgmt' value 'WPA-PSK WPA-PSK-SHA256 FT-PSK SAE FT-SAE' Feb 06 05:53:26 deb NetworkManager[1189]: <info> [1675659206.5756] Config: added 'auth_alg' value 'OPEN' Feb 06 05:53:26 deb NetworkManager[1189]: <info> [1675659206.5756] Config: added 'psk' value '<hidden>' Feb 06 05:53:26 deb NetworkManager[1189]: <info> [1675659206.7794] device (wlx10bf485b893c): supplicant interface state: scanning -> authenticating Feb 06 05:53:26 deb NetworkManager[1189]: <info> [1675659206.7812] device (wlx10bf485b893c): supplicant interface state: authenticating -> associating Feb 06 05:53:26 deb NetworkManager[1189]: <info> [1675659206.8978] device (wlx10bf485b893c): supplicant interface state: associating -> associated Feb 06 05:53:27 deb NetworkManager[1189]: <info> [1675659207.0781] device (wlx10bf485b893c): supplicant interface state: associated -> completed Feb 06 05:53:27 deb NetworkManager[1189]: <info> [1675659207.0781] device (wlx10bf485b893c): Activation: (wifi) Stage 2 of 5 (Device Configure) successful. Connected to wireless network "NETGEAR57-5G" Feb 06 05:53:27 deb NetworkManager[1189]: <info> [1675659207.0782] device (wlx10bf485b893c): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed') Feb 06 05:53:27 deb NetworkManager[1189]: <info> [1675659207.0787] dhcp4 (wlx10bf485b893c): activation: beginning transaction (timeout in 45 seconds) Feb 06 05:53:39 deb NetworkManager[1189]: <info> [1675659219.7843] device (wlx10bf485b893c): state change: ip-config -> deactivating (reason 'user-requested', sys-iface-state: 'managed') Feb 06 05:53:39 deb NetworkManager[1189]: <info> [1675659219.7847] audit: op="device-disconnect" interface="wlx10bf485b893c" ifindex=3 pid=2293 uid=1000 result="success" Feb 06 05:53:39 deb NetworkManager[1189]: <info> [1675659219.9932] device (wlx10bf485b893c): state change: deactivating -> disconnected (reason 'user-requested', sys-iface-state: 'managed') Feb 06 05:53:40 deb NetworkManager[1189]: <info> [1675659220.0198] dhcp4 (wlx10bf485b893c): canceled DHCP transaction Feb 06 05:53:40 deb NetworkManager[1189]: <info> [1675659220.0207] device (wlx10bf485b893c): supplicant interface state: completed -> disconnected Feb 06 05:54:04 deb NetworkManager[1189]: <info> [1675659244.0562] device (enp4s0): state change: ip-config -> failed (reason 'ip-config-unavailable', sys-iface-state: 'managed') Feb 06 05:54:04 deb NetworkManager[1189]: <info> [1675659244.0564] manager: NetworkManager state is now CONNECTED_LOCAL Feb 06 05:54:04 deb NetworkManager[1189]: <warn> [1675659244.0565] device (enp4s0): Activation: failed for connection 'Wired connection 1' Feb 06 05:54:04 deb NetworkManager[1189]: <info> [1675659244.0568] device (enp4s0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed') Feb 06 05:54:04 deb NetworkManager[1189]: <info> [1675659244.0594] dhcp4 (enp4s0): canceled DHCP transaction Feb 06 05:54:04 deb NetworkManager[1189]: <info> [1675659244.0603] policy: auto-activating connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 05:54:04 deb NetworkManager[1189]: <info> [1675659244.0605] device (enp4s0): Activation: starting connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 05:54:04 deb NetworkManager[1189]: <info> [1675659244.0606] device (enp4s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed') Feb 06 05:54:04 deb NetworkManager[1189]: <info> [1675659244.0607] manager: NetworkManager state is now CONNECTING Feb 06 05:54:04 deb NetworkManager[1189]: <info> [1675659244.0608] device (enp4s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed') Feb 06 05:54:04 deb NetworkManager[1189]: <info> [1675659244.0614] device (enp4s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed') Feb 06 05:54:04 deb NetworkManager[1189]: <info> [1675659244.0624] dhcp4 (enp4s0): activation: beginning transaction (timeout in 45 seconds) Feb 06 05:54:10 deb NetworkManager[1189]: <info> [1675659250.9569] device (wlx10bf485b893c): Activation: starting connection '..olo..' (0ffc8222-7f4e-4249-97dd-bccdf536f246) Feb 06 05:54:10 deb NetworkManager[1189]: <info> [1675659250.9570] audit: op="connection-activate" uuid="0ffc8222-7f4e-4249-97dd-bccdf536f246" name="..olo.." pid=2293 uid=1000 result="success" Feb 06 05:54:10 deb NetworkManager[1189]: <info> [1675659250.9571] device (wlx10bf485b893c): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed') Feb 06 05:54:10 deb NetworkManager[1189]: <info> [1675659250.9575] device (wlx10bf485b893c): state change: prepare -> config (reason 'none', sys-iface-state: 'managed') Feb 06 05:54:10 deb NetworkManager[1189]: <info> [1675659250.9577] device (wlx10bf485b893c): Activation: (wifi) access point '..olo..' has security, but secrets are required. Feb 06 05:54:10 deb NetworkManager[1189]: <info> [1675659250.9578] device (wlx10bf485b893c): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed') Feb 06 05:54:10 deb NetworkManager[1189]: <info> [1675659250.9706] device (wlx10bf485b893c): state change: need-auth -> prepare (reason 'none', sys-iface-state: 'managed') Feb 06 05:54:10 deb NetworkManager[1189]: <info> [1675659250.9709] device (wlx10bf485b893c): state change: prepare -> config (reason 'none', sys-iface-state: 'managed') Feb 06 05:54:10 deb NetworkManager[1189]: <info> [1675659250.9712] device (wlx10bf485b893c): Activation: (wifi) connection '..olo..' has security, and secrets exist. No new secrets needed. Feb 06 05:54:10 deb NetworkManager[1189]: <info> [1675659250.9713] Config: added 'ssid' value '..olo..' Feb 06 05:54:10 deb NetworkManager[1189]: <info> [1675659250.9713] Config: added 'scan_ssid' value '1' Feb 06 05:54:10 deb NetworkManager[1189]: <info> [1675659250.9713] Config: added 'bgscan' value 'simple:30:-70:86400' Feb 06 05:54:10 deb NetworkManager[1189]: <info> [1675659250.9713] Config: added 'key_mgmt' value 'WPA-PSK WPA-PSK-SHA256 FT-PSK SAE FT-SAE' Feb 06 05:54:10 deb NetworkManager[1189]: <info> [1675659250.9713] Config: added 'auth_alg' value 'OPEN' Feb 06 05:54:10 deb NetworkManager[1189]: <info> [1675659250.9713] Config: added 'psk' value '<hidden>' Feb 06 05:54:11 deb NetworkManager[1189]: <info> [1675659251.9815] device (wlx10bf485b893c): supplicant interface state: disconnected -> scanning Feb 06 05:54:19 deb NetworkManager[1189]: <info> [1675659259.9239] device (wlx10bf485b893c): supplicant interface state: scanning -> authenticating Feb 06 05:54:19 deb NetworkManager[1189]: <info> [1675659259.9254] device (wlx10bf485b893c): supplicant interface state: authenticating -> associating Feb 06 05:54:19 deb NetworkManager[1189]: <info> [1675659259.9601] device (wlx10bf485b893c): supplicant interface state: associating -> associated Feb 06 05:54:20 deb NetworkManager[1189]: <info> [1675659260.0667] device (wlx10bf485b893c): supplicant interface state: associated -> completed Feb 06 05:54:20 deb NetworkManager[1189]: <info> [1675659260.0667] device (wlx10bf485b893c): Activation: (wifi) Stage 2 of 5 (Device Configure) successful. Connected to wireless network "..olo.." Feb 06 05:54:20 deb NetworkManager[1189]: <info> [1675659260.0668] device (wlx10bf485b893c): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed') Feb 06 05:54:20 deb NetworkManager[1189]: <info> [1675659260.0673] dhcp4 (wlx10bf485b893c): activation: beginning transaction (timeout in 45 seconds) Feb 06 05:54:22 deb NetworkManager[1189]: <info> [1675659262.1032] dhcp4 (wlx10bf485b893c): state changed new lease, address=192.168.150.55 Feb 06 05:54:22 deb NetworkManager[1189]: <info> [1675659262.1049] device (wlx10bf485b893c): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed') Feb 06 05:54:22 deb NetworkManager[1189]: <info> [1675659262.1110] device (wlx10bf485b893c): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed') Feb 06 05:54:22 deb NetworkManager[1189]: <info> [1675659262.1112] device (wlx10bf485b893c): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed') Feb 06 05:54:22 deb NetworkManager[1189]: <info> [1675659262.1118] manager: NetworkManager state is now CONNECTED_SITE Feb 06 05:54:22 deb NetworkManager[1189]: <info> [1675659262.1119] policy: set '..olo..' (wlx10bf485b893c) as default for IPv4 routing and DNS Feb 06 05:54:22 deb NetworkManager[1189]: <info> [1675659262.1124] device (wlx10bf485b893c): Activation: successful, device activated. Feb 06 05:54:22 deb NetworkManager[1189]: <info> [1675659262.1128] manager: NetworkManager state is now CONNECTED_GLOBAL Feb 06 05:54:22 deb NetworkManager[1189]: <info> [1675659262.1225] audit: op="statistics" interface="wlx10bf485b893c" ifindex=3 args="2000" pid=2293 uid=1000 result="success" Feb 06 05:54:22 deb NetworkManager[1189]: <info> [1675659262.1266] audit: op="statistics" interface="wlx10bf485b893c" ifindex=3 args="500" pid=2422 uid=1000 result="success" Feb 06 05:54:30 deb NetworkManager[1189]: <info> [1675659270.4684] audit: op="statistics" interface="wlx10bf485b893c" ifindex=3 args="0" pid=2293 uid=1000 result="success" Feb 06 05:54:30 deb NetworkManager[1189]: <info> [1675659270.4714] audit: op="statistics" interface="wlx10bf485b893c" ifindex=3 args="500" pid=2422 uid=1000 result="success" Feb 06 05:54:41 deb NetworkManager[1189]: <info> [1675659281.6732] audit: op="statistics" interface="wlx10bf485b893c" ifindex=3 args="2000" pid=2293 uid=1000 result="success" Feb 06 05:54:41 deb NetworkManager[1189]: <info> [1675659281.6753] audit: op="statistics" interface="wlx10bf485b893c" ifindex=3 args="500" pid=2422 uid=1000 result="success" Feb 06 05:54:49 deb NetworkManager[1189]: <info> [1675659289.0581] device (enp4s0): state change: ip-config -> failed (reason 'ip-config-unavailable', sys-iface-state: 'managed') Feb 06 05:54:49 deb NetworkManager[1189]: <warn> [1675659289.0585] device (enp4s0): Activation: failed for connection 'Wired connection 1' Feb 06 05:54:49 deb NetworkManager[1189]: <info> [1675659289.0588] device (enp4s0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed') Feb 06 05:54:49 deb NetworkManager[1189]: <info> [1675659289.0960] dhcp4 (enp4s0): canceled DHCP transaction Feb 06 05:54:49 deb NetworkManager[1189]: <info> [1675659289.0970] policy: auto-activating connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 05:54:49 deb NetworkManager[1189]: <info> [1675659289.0974] device (enp4s0): Activation: starting connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 05:54:49 deb NetworkManager[1189]: <info> [1675659289.0975] device (enp4s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed') Feb 06 05:54:49 deb NetworkManager[1189]: <info> [1675659289.0978] device (enp4s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed') Feb 06 05:54:49 deb NetworkManager[1189]: <info> [1675659289.0987] device (enp4s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed') Feb 06 05:54:49 deb NetworkManager[1189]: <info> [1675659289.1000] dhcp4 (enp4s0): activation: beginning transaction (timeout in 45 seconds) Feb 06 05:54:58 deb NetworkManager[1189]: <info> [1675659298.2419] audit: op="statistics" interface="wlx10bf485b893c" ifindex=3 args="0" pid=2293 uid=1000 result="success" Feb 06 05:54:58 deb NetworkManager[1189]: <info> [1675659298.2444] audit: op="statistics" interface="wlx10bf485b893c" ifindex=3 args="500" pid=2422 uid=1000 result="success" Feb 06 05:55:34 deb NetworkManager[1189]: <info> [1675659334.0571] device (enp4s0): state change: ip-config -> failed (reason 'ip-config-unavailable', sys-iface-state: 'managed') Feb 06 05:55:34 deb NetworkManager[1189]: <warn> [1675659334.0575] device (enp4s0): Activation: failed for connection 'Wired connection 1' Feb 06 05:55:34 deb NetworkManager[1189]: <info> [1675659334.0577] device (enp4s0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed') Feb 06 05:55:34 deb NetworkManager[1189]: <info> [1675659334.0610] dhcp4 (enp4s0): canceled DHCP transaction Feb 06 05:55:34 deb NetworkManager[1189]: <info> [1675659334.0620] policy: auto-activating connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 05:55:34 deb NetworkManager[1189]: <info> [1675659334.0624] device (enp4s0): Activation: starting connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 05:55:34 deb NetworkManager[1189]: <info> [1675659334.0625] device (enp4s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed') Feb 06 05:55:34 deb NetworkManager[1189]: <info> [1675659334.0627] device (enp4s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed') Feb 06 05:55:34 deb NetworkManager[1189]: <info> [1675659334.0636] device (enp4s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed') Feb 06 05:55:34 deb NetworkManager[1189]: <info> [1675659334.0649] dhcp4 (enp4s0): activation: beginning transaction (timeout in 45 seconds) Feb 06 05:56:19 deb NetworkManager[1189]: <info> [1675659379.0571] device (enp4s0): state change: ip-config -> failed (reason 'ip-config-unavailable', sys-iface-state: 'managed') Feb 06 05:56:19 deb NetworkManager[1189]: <warn> [1675659379.0575] device (enp4s0): Activation: failed for connection 'Wired connection 1' Feb 06 05:56:19 deb NetworkManager[1189]: <info> [1675659379.0577] device (enp4s0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed') Feb 06 05:56:19 deb NetworkManager[1189]: <info> [1675659379.0918] dhcp4 (enp4s0): canceled DHCP transaction Feb 06 05:56:19 deb NetworkManager[1189]: <info> [1675659379.0930] manager: startup complete Feb 06 05:56:32 deb NetworkManager[1189]: <info> [1675659392.5404] audit: op="statistics" interface="wlx10bf485b893c" ifindex=3 args="2000" pid=2293 uid=1000 result="success" Feb 06 05:56:32 deb NetworkManager[1189]: <info> [1675659392.5424] audit: op="statistics" interface="wlx10bf485b893c" ifindex=3 args="500" pid=2422 uid=1000 result="success" Feb 06 05:56:41 deb NetworkManager[1189]: <info> [1675659401.9878] audit: op="statistics" interface="wlx10bf485b893c" ifindex=3 args="0" pid=2293 uid=1000 result="success" Feb 06 05:56:41 deb NetworkManager[1189]: <info> [1675659401.9893] audit: op="statistics" interface="wlx10bf485b893c" ifindex=3 args="500" pid=2422 uid=1000 result="success" Feb 06 05:56:48 deb NetworkManager[1189]: <info> [1675659408.8938] audit: op="connection-update" uuid="4e387eb2-fafa-3c7c-95a7-cc67067748e6" name="Wired connection 1" args="802-3-ethernet.cloned-mac-address" pid=4051 uid=1000 result="success" Feb 06 05:56:48 deb NetworkManager[1189]: <info> [1675659408.8942] policy: auto-activating connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 05:56:48 deb NetworkManager[1189]: <info> [1675659408.8965] device (enp4s0): Activation: starting connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 05:56:48 deb NetworkManager[1189]: <info> [1675659408.8966] device (enp4s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed') Feb 06 05:56:48 deb NetworkManager[1189]: <info> [1675659408.8975] device (enp4s0): set-hw-addr: set-cloned MAC address to 82:FC:83:1C:A3:59 (82:FC:83:1C:A3:59) Feb 06 05:56:48 deb NetworkManager[1189]: <info> [1675659408.8975] device (enp4s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed') Feb 06 05:56:48 deb NetworkManager[1189]: <info> [1675659408.8984] device (enp4s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed') Feb 06 05:56:48 deb NetworkManager[1189]: <info> [1675659408.8996] dhcp4 (enp4s0): activation: beginning transaction (timeout in 45 seconds) Feb 06 05:56:53 deb NetworkManager[1189]: <info> [1675659413.0999] audit: op="statistics" interface="wlx10bf485b893c" ifindex=3 args="2000" pid=2293 uid=1000 result="success" Feb 06 05:56:53 deb NetworkManager[1189]: <info> [1675659413.1028] audit: op="statistics" interface="wlx10bf485b893c" ifindex=3 args="500" pid=2422 uid=1000 result="success" Feb 06 05:57:25 deb NetworkManager[1189]: <info> [1675659445.1286] audit: op="statistics" interface="wlx10bf485b893c" ifindex=3 args="0" pid=2293 uid=1000 result="success" Feb 06 05:57:25 deb NetworkManager[1189]: <info> [1675659445.1310] audit: op="statistics" interface="wlx10bf485b893c" ifindex=3 args="500" pid=2422 uid=1000 result="success" Feb 06 05:57:34 deb NetworkManager[1189]: <info> [1675659454.0565] device (enp4s0): state change: ip-config -> failed (reason 'ip-config-unavailable', sys-iface-state: 'managed') Feb 06 05:57:34 deb NetworkManager[1189]: <warn> [1675659454.0567] device (enp4s0): Activation: failed for connection 'Wired connection 1' Feb 06 05:57:34 deb NetworkManager[1189]: <info> [1675659454.0568] device (enp4s0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed') Feb 06 05:57:34 deb NetworkManager[1189]: <info> [1675659454.0998] dhcp4 (enp4s0): canceled DHCP transaction Feb 06 05:57:34 deb NetworkManager[1189]: <info> [1675659454.1005] device (enp4s0): set-hw-addr: reset MAC address to 18:C0:4D:01:6F:38 (deactivate) Feb 06 05:57:34 deb NetworkManager[1189]: <info> [1675659454.1008] policy: auto-activating connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 05:57:34 deb NetworkManager[1189]: <info> [1675659454.1010] device (enp4s0): Activation: starting connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 05:57:34 deb NetworkManager[1189]: <info> [1675659454.1010] device (enp4s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed') Feb 06 05:57:34 deb NetworkManager[1189]: <info> [1675659454.1016] device (enp4s0): set-hw-addr: set-cloned MAC address to 82:FC:83:1C:A3:59 (82:FC:83:1C:A3:59) Feb 06 05:57:34 deb NetworkManager[1189]: <info> [1675659454.1016] device (enp4s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed') Feb 06 05:57:34 deb NetworkManager[1189]: <info> [1675659454.1022] device (enp4s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed') Feb 06 05:57:34 deb NetworkManager[1189]: <info> [1675659454.1034] dhcp4 (enp4s0): activation: beginning transaction (timeout in 45 seconds) Feb 06 05:58:19 deb NetworkManager[1189]: <info> [1675659499.0563] device (enp4s0): state change: ip-config -> failed (reason 'ip-config-unavailable', sys-iface-state: 'managed') Feb 06 05:58:19 deb NetworkManager[1189]: <warn> [1675659499.0565] device (enp4s0): Activation: failed for connection 'Wired connection 1' Feb 06 05:58:19 deb NetworkManager[1189]: <info> [1675659499.0566] device (enp4s0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed') Feb 06 05:58:19 deb NetworkManager[1189]: <info> [1675659499.1038] dhcp4 (enp4s0): canceled DHCP transaction Feb 06 05:58:19 deb NetworkManager[1189]: <info> [1675659499.1045] device (enp4s0): set-hw-addr: reset MAC address to 18:C0:4D:01:6F:38 (deactivate) Feb 06 05:58:19 deb NetworkManager[1189]: <info> [1675659499.1049] policy: auto-activating connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 05:58:19 deb NetworkManager[1189]: <info> [1675659499.1051] device (enp4s0): Activation: starting connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 05:58:19 deb NetworkManager[1189]: <info> [1675659499.1051] device (enp4s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed') Feb 06 05:58:19 deb NetworkManager[1189]: <info> [1675659499.1057] device (enp4s0): set-hw-addr: set-cloned MAC address to 82:FC:83:1C:A3:59 (82:FC:83:1C:A3:59) Feb 06 05:58:19 deb NetworkManager[1189]: <info> [1675659499.1057] device (enp4s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed') Feb 06 05:58:19 deb NetworkManager[1189]: <info> [1675659499.1063] device (enp4s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed') Feb 06 05:58:19 deb NetworkManager[1189]: <info> [1675659499.1073] dhcp4 (enp4s0): activation: beginning transaction (timeout in 45 seconds) Feb 06 05:58:58 deb NetworkManager[1189]: <info> [1675659538.8874] audit: op="statistics" interface="wlx10bf485b893c" ifindex=3 args="2000" pid=2293 uid=1000 result="success" Feb 06 05:58:58 deb NetworkManager[1189]: <info> [1675659538.8906] audit: op="statistics" interface="wlx10bf485b893c" ifindex=3 args="500" pid=2422 uid=1000 result="success" Feb 06 05:59:01 deb NetworkManager[1189]: <info> [1675659541.1924] audit: op="statistics" interface="wlx10bf485b893c" ifindex=3 args="0" pid=2293 uid=1000 result="success" Feb 06 05:59:01 deb NetworkManager[1189]: <info> [1675659541.1943] audit: op="statistics" interface="wlx10bf485b893c" ifindex=3 args="500" pid=2422 uid=1000 result="success" Feb 06 05:59:04 deb NetworkManager[1189]: <info> [1675659544.0568] device (enp4s0): state change: ip-config -> failed (reason 'ip-config-unavailable', sys-iface-state: 'managed') Feb 06 05:59:04 deb NetworkManager[1189]: <warn> [1675659544.0572] device (enp4s0): Activation: failed for connection 'Wired connection 1' Feb 06 05:59:04 deb NetworkManager[1189]: <info> [1675659544.0574] device (enp4s0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed') Feb 06 05:59:04 deb NetworkManager[1189]: <info> [1675659544.0601] dhcp4 (enp4s0): canceled DHCP transaction Feb 06 05:59:04 deb NetworkManager[1189]: <info> [1675659544.0611] device (enp4s0): set-hw-addr: reset MAC address to 18:C0:4D:01:6F:38 (deactivate) Feb 06 05:59:04 deb NetworkManager[1189]: <info> [1675659544.0618] policy: auto-activating connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 05:59:04 deb NetworkManager[1189]: <info> [1675659544.0623] device (enp4s0): Activation: starting connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 05:59:04 deb NetworkManager[1189]: <info> [1675659544.0624] device (enp4s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed') Feb 06 05:59:04 deb NetworkManager[1189]: <info> [1675659544.0632] device (enp4s0): set-hw-addr: set-cloned MAC address to 82:FC:83:1C:A3:59 (82:FC:83:1C:A3:59) Feb 06 05:59:04 deb NetworkManager[1189]: <info> [1675659544.0632] device (enp4s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed') Feb 06 05:59:04 deb NetworkManager[1189]: <info> [1675659544.0642] device (enp4s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed') Feb 06 05:59:04 deb NetworkManager[1189]: <info> [1675659544.0654] dhcp4 (enp4s0): activation: beginning transaction (timeout in 45 seconds) Feb 06 05:59:12 deb NetworkManager[1189]: <info> [1675659552.1352] audit: op="connection-update" uuid="4e387eb2-fafa-3c7c-95a7-cc67067748e6" name="Wired connection 1" args="802-3-ethernet.cloned-mac-address" pid=4557 uid=1000 result="success" Feb 06 05:59:49 deb NetworkManager[1189]: <info> [1675659589.0570] device (enp4s0): state change: ip-config -> failed (reason 'ip-config-unavailable', sys-iface-state: 'managed') Feb 06 05:59:49 deb NetworkManager[1189]: <warn> [1675659589.0573] device (enp4s0): Activation: failed for connection 'Wired connection 1' Feb 06 05:59:49 deb NetworkManager[1189]: <info> [1675659589.0574] device (enp4s0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed') Feb 06 05:59:49 deb NetworkManager[1189]: <info> [1675659589.0598] dhcp4 (enp4s0): canceled DHCP transaction Feb 06 05:59:49 deb NetworkManager[1189]: <info> [1675659589.0607] device (enp4s0): set-hw-addr: reset MAC address to 18:C0:4D:01:6F:38 (deactivate) Feb 06 05:59:49 deb NetworkManager[1189]: <info> [1675659589.0612] policy: auto-activating connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 05:59:49 deb NetworkManager[1189]: <info> [1675659589.0616] device (enp4s0): Activation: starting connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 05:59:49 deb NetworkManager[1189]: <info> [1675659589.0616] device (enp4s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed') Feb 06 05:59:49 deb NetworkManager[1189]: <info> [1675659589.0618] device (enp4s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed') Feb 06 05:59:49 deb NetworkManager[1189]: <info> [1675659589.0627] device (enp4s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed') Feb 06 05:59:49 deb NetworkManager[1189]: <info> [1675659589.0638] dhcp4 (enp4s0): activation: beginning transaction (timeout in 45 seconds) Feb 06 06:00:34 deb NetworkManager[1189]: <info> [1675659634.0564] device (enp4s0): state change: ip-config -> failed (reason 'ip-config-unavailable', sys-iface-state: 'managed') Feb 06 06:00:34 deb NetworkManager[1189]: <warn> [1675659634.0569] device (enp4s0): Activation: failed for connection 'Wired connection 1' Feb 06 06:00:34 deb NetworkManager[1189]: <info> [1675659634.0570] device (enp4s0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed') Feb 06 06:00:34 deb NetworkManager[1189]: <info> [1675659634.0597] dhcp4 (enp4s0): canceled DHCP transaction Feb 06 06:00:34 deb NetworkManager[1189]: <info> [1675659634.0609] policy: auto-activating connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 06:00:34 deb NetworkManager[1189]: <info> [1675659634.0614] device (enp4s0): Activation: starting connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 06:00:34 deb NetworkManager[1189]: <info> [1675659634.0615] device (enp4s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed') Feb 06 06:00:34 deb NetworkManager[1189]: <info> [1675659634.0618] device (enp4s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed') Feb 06 06:00:34 deb NetworkManager[1189]: <info> [1675659634.0627] device (enp4s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed') Feb 06 06:00:34 deb NetworkManager[1189]: <info> [1675659634.0639] dhcp4 (enp4s0): activation: beginning transaction (timeout in 45 seconds) Feb 06 06:01:19 deb NetworkManager[1189]: <info> [1675659679.0565] device (enp4s0): state change: ip-config -> failed (reason 'ip-config-unavailable', sys-iface-state: 'managed') Feb 06 06:01:19 deb NetworkManager[1189]: <warn> [1675659679.0568] device (enp4s0): Activation: failed for connection 'Wired connection 1' Feb 06 06:01:19 deb NetworkManager[1189]: <info> [1675659679.0570] device (enp4s0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed') Feb 06 06:01:19 deb NetworkManager[1189]: <info> [1675659679.0798] dhcp4 (enp4s0): canceled DHCP transaction Feb 06 06:01:19 deb NetworkManager[1189]: <info> [1675659679.0803] policy: auto-activating connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 06:01:19 deb NetworkManager[1189]: <info> [1675659679.0806] device (enp4s0): Activation: starting connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 06:01:19 deb NetworkManager[1189]: <info> [1675659679.0806] device (enp4s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed') Feb 06 06:01:19 deb NetworkManager[1189]: <info> [1675659679.0807] device (enp4s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed') Feb 06 06:01:19 deb NetworkManager[1189]: <info> [1675659679.0815] device (enp4s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed') Feb 06 06:01:19 deb NetworkManager[1189]: <info> [1675659679.0826] dhcp4 (enp4s0): activation: beginning transaction (timeout in 45 seconds) Feb 06 06:01:59 deb NetworkManager[1189]: <info> [1675659719.4947] audit: op="statistics" interface="wlx10bf485b893c" ifindex=3 args="2000" pid=2293 uid=1000 result="success" Feb 06 06:01:59 deb NetworkManager[1189]: <info> [1675659719.4973] audit: op="statistics" interface="wlx10bf485b893c" ifindex=3 args="500" pid=2422 uid=1000 result="success" Feb 06 06:02:03 deb NetworkManager[1189]: <info> [1675659723.8258] audit: op="statistics" interface="wlx10bf485b893c" ifindex=3 args="0" pid=2293 uid=1000 result="success" Feb 06 06:02:03 deb NetworkManager[1189]: <info> [1675659723.8279] audit: op="statistics" interface="wlx10bf485b893c" ifindex=3 args="500" pid=2422 uid=1000 result="success" Feb 06 06:02:04 deb NetworkManager[1189]: <info> [1675659724.0566] device (enp4s0): state change: ip-config -> failed (reason 'ip-config-unavailable', sys-iface-state: 'managed') Feb 06 06:02:04 deb NetworkManager[1189]: <warn> [1675659724.0568] device (enp4s0): Activation: failed for connection 'Wired connection 1' Feb 06 06:02:04 deb NetworkManager[1189]: <info> [1675659724.0569] device (enp4s0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed') Feb 06 06:02:04 deb NetworkManager[1189]: <info> [1675659724.0598] dhcp4 (enp4s0): canceled DHCP transaction Feb 06 06:02:47 deb NetworkManager[1189]: <info> [1675659767.5313] audit: op="statistics" interface="wlx10bf485b893c" ifindex=3 args="2000" pid=2293 uid=1000 result="success" Feb 06 06:02:47 deb NetworkManager[1189]: <info> [1675659767.5340] audit: op="statistics" interface="wlx10bf485b893c" ifindex=3 args="500" pid=2422 uid=1000 result="success" Feb 06 06:02:50 deb NetworkManager[1189]: <info> [1675659770.6175] audit: op="statistics" interface="wlx10bf485b893c" ifindex=3 args="0" pid=2293 uid=1000 result="success" Feb 06 06:02:50 deb NetworkManager[1189]: <info> [1675659770.6198] audit: op="statistics" interface="wlx10bf485b893c" ifindex=3 args="500" pid=2422 uid=1000 result="success" Feb 06 06:07:02 deb NetworkManager[1189]: <info> [1675660022.1484] audit: op="statistics" interface="wlx10bf485b893c" ifindex=3 args="2000" pid=2293 uid=1000 result="success" Feb 06 06:07:02 deb NetworkManager[1189]: <info> [1675660022.1513] audit: op="statistics" interface="wlx10bf485b893c" ifindex=3 args="500" pid=2422 uid=1000 result="success" Feb 06 06:07:04 deb NetworkManager[1189]: <info> [1675660024.0567] policy: auto-activating connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 06:07:04 deb NetworkManager[1189]: <info> [1675660024.0571] device (enp4s0): Activation: starting connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 06:07:04 deb NetworkManager[1189]: <info> [1675660024.0572] device (enp4s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed') Feb 06 06:07:04 deb NetworkManager[1189]: <info> [1675660024.0574] device (enp4s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed') Feb 06 06:07:04 deb NetworkManager[1189]: <info> [1675660024.0583] device (enp4s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed') Feb 06 06:07:04 deb NetworkManager[1189]: <info> [1675660024.0596] dhcp4 (enp4s0): activation: beginning transaction (timeout in 45 seconds) Feb 06 06:07:08 deb NetworkManager[1189]: <info> [1675660028.6543] audit: op="statistics" interface="wlx10bf485b893c" ifindex=3 args="0" pid=2293 uid=1000 result="success" Feb 06 06:07:08 deb NetworkManager[1189]: <info> [1675660028.6562] audit: op="statistics" interface="wlx10bf485b893c" ifindex=3 args="500" pid=2422 uid=1000 result="success" Feb 06 06:07:49 deb NetworkManager[1189]: <info> [1675660069.0565] device (enp4s0): state change: ip-config -> failed (reason 'ip-config-unavailable', sys-iface-state: 'managed') Feb 06 06:07:49 deb NetworkManager[1189]: <warn> [1675660069.0569] device (enp4s0): Activation: failed for connection 'Wired connection 1' Feb 06 06:07:49 deb NetworkManager[1189]: <info> [1675660069.0571] device (enp4s0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed') Feb 06 06:07:49 deb NetworkManager[1189]: <info> [1675660069.0918] dhcp4 (enp4s0): canceled DHCP transaction Feb 06 06:07:49 deb NetworkManager[1189]: <info> [1675660069.0928] policy: auto-activating connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 06:07:49 deb NetworkManager[1189]: <info> [1675660069.0932] device (enp4s0): Activation: starting connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 06:07:49 deb NetworkManager[1189]: <info> [1675660069.0932] device (enp4s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed') Feb 06 06:07:49 deb NetworkManager[1189]: <info> [1675660069.0935] device (enp4s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed') Feb 06 06:07:49 deb NetworkManager[1189]: <info> [1675660069.0944] device (enp4s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed') Feb 06 06:07:49 deb NetworkManager[1189]: <info> [1675660069.0955] dhcp4 (enp4s0): activation: beginning transaction (timeout in 45 seconds) Feb 06 06:08:34 deb NetworkManager[1189]: <info> [1675660114.0572] device (enp4s0): state change: ip-config -> failed (reason 'ip-config-unavailable', sys-iface-state: 'managed') Feb 06 06:08:34 deb NetworkManager[1189]: <warn> [1675660114.0576] device (enp4s0): Activation: failed for connection 'Wired connection 1' Feb 06 06:08:34 deb NetworkManager[1189]: <info> [1675660114.0578] device (enp4s0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed') Feb 06 06:08:34 deb NetworkManager[1189]: <info> [1675660114.0610] dhcp4 (enp4s0): canceled DHCP transaction Feb 06 06:08:34 deb NetworkManager[1189]: <info> [1675660114.0616] policy: auto-activating connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 06:08:34 deb NetworkManager[1189]: <info> [1675660114.0618] device (enp4s0): Activation: starting connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 06:08:34 deb NetworkManager[1189]: <info> [1675660114.0619] device (enp4s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed') Feb 06 06:08:34 deb NetworkManager[1189]: <info> [1675660114.0620] device (enp4s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed') Feb 06 06:08:34 deb NetworkManager[1189]: <info> [1675660114.0627] device (enp4s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed') Feb 06 06:08:34 deb NetworkManager[1189]: <info> [1675660114.0637] dhcp4 (enp4s0): activation: beginning transaction (timeout in 45 seconds) Feb 06 06:09:19 deb NetworkManager[1189]: <info> [1675660159.0573] device (enp4s0): state change: ip-config -> failed (reason 'ip-config-unavailable', sys-iface-state: 'managed') Feb 06 06:09:19 deb NetworkManager[1189]: <warn> [1675660159.0575] device (enp4s0): Activation: failed for connection 'Wired connection 1' Feb 06 06:09:19 deb NetworkManager[1189]: <info> [1675660159.0576] device (enp4s0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed') Feb 06 06:09:19 deb NetworkManager[1189]: <info> [1675660159.0878] dhcp4 (enp4s0): canceled DHCP transaction Feb 06 06:09:19 deb NetworkManager[1189]: <info> [1675660159.0884] policy: auto-activating connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 06:09:19 deb NetworkManager[1189]: <info> [1675660159.0886] device (enp4s0): Activation: starting connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 06:09:19 deb NetworkManager[1189]: <info> [1675660159.0887] device (enp4s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed') Feb 06 06:09:19 deb NetworkManager[1189]: <info> [1675660159.0888] device (enp4s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed') Feb 06 06:09:19 deb NetworkManager[1189]: <info> [1675660159.0896] device (enp4s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed') Feb 06 06:09:19 deb NetworkManager[1189]: <info> [1675660159.0906] dhcp4 (enp4s0): activation: beginning transaction (timeout in 45 seconds) Feb 06 06:10:04 deb NetworkManager[1189]: <info> [1675660204.0564] device (enp4s0): state change: ip-config -> failed (reason 'ip-config-unavailable', sys-iface-state: 'managed') Feb 06 06:10:04 deb NetworkManager[1189]: <warn> [1675660204.0568] device (enp4s0): Activation: failed for connection 'Wired connection 1' Feb 06 06:10:04 deb NetworkManager[1189]: <info> [1675660204.0569] device (enp4s0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed') Feb 06 06:10:04 deb NetworkManager[1189]: <info> [1675660204.0918] dhcp4 (enp4s0): canceled DHCP transaction Feb 06 06:11:28 deb NetworkManager[1189]: <info> [1675660288.2079] audit: op="statistics" interface="wlx10bf485b893c" ifindex=3 args="2000" pid=2293 uid=1000 result="success" Feb 06 06:11:28 deb NetworkManager[1189]: <info> [1675660288.2105] audit: op="statistics" interface="wlx10bf485b893c" ifindex=3 args="500" pid=2422 uid=1000 result="success" Feb 06 06:11:32 deb NetworkManager[1189]: <info> [1675660292.1294] device (enp4s0): Activation: starting connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 06:11:32 deb NetworkManager[1189]: <info> [1675660292.1295] audit: op="connection-activate" uuid="4e387eb2-fafa-3c7c-95a7-cc67067748e6" name="Wired connection 1" pid=2293 uid=1000 result="success" Feb 06 06:11:32 deb NetworkManager[1189]: <info> [1675660292.1295] device (enp4s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed') Feb 06 06:11:32 deb NetworkManager[1189]: <info> [1675660292.1297] device (enp4s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed') Feb 06 06:11:32 deb NetworkManager[1189]: <info> [1675660292.1304] device (enp4s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed') Feb 06 06:11:32 deb NetworkManager[1189]: <info> [1675660292.1314] dhcp4 (enp4s0): activation: beginning transaction (timeout in 45 seconds) Feb 06 06:12:09 deb NetworkManager[1189]: <info> [1675660329.1742] audit: op="statistics" interface="wlx10bf485b893c" ifindex=3 args="0" pid=2293 uid=1000 result="success" Feb 06 06:12:09 deb NetworkManager[1189]: <info> [1675660329.1765] audit: op="statistics" interface="wlx10bf485b893c" ifindex=3 args="500" pid=2422 uid=1000 result="success" Feb 06 06:12:17 deb NetworkManager[1189]: <info> [1675660337.0573] device (enp4s0): state change: ip-config -> failed (reason 'ip-config-unavailable', sys-iface-state: 'managed') Feb 06 06:12:17 deb NetworkManager[1189]: <warn> [1675660337.0576] device (enp4s0): Activation: failed for connection 'Wired connection 1' Feb 06 06:12:17 deb NetworkManager[1189]: <info> [1675660337.0577] device (enp4s0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed') Feb 06 06:12:17 deb NetworkManager[1189]: <info> [1675660337.1078] dhcp4 (enp4s0): canceled DHCP transaction Feb 06 06:12:51 deb NetworkManager[1189]: <info> [1675660371.3517] audit: op="statistics" interface="wlx10bf485b893c" ifindex=3 args="2000" pid=2293 uid=1000 result="success" Feb 06 06:12:51 deb NetworkManager[1189]: <info> [1675660371.3538] audit: op="statistics" interface="wlx10bf485b893c" ifindex=3 args="500" pid=2422 uid=1000 result="success" Feb 06 06:12:53 deb NetworkManager[1189]: <info> [1675660373.5691] audit: op="statistics" interface="wlx10bf485b893c" ifindex=3 args="0" pid=2293 uid=1000 result="success" Feb 06 06:12:53 deb NetworkManager[1189]: <info> [1675660373.5712] audit: op="statistics" interface="wlx10bf485b893c" ifindex=3 args="500" pid=2422 uid=1000 result="success" Feb 06 06:15:04 deb NetworkManager[1189]: <info> [1675660504.0570] policy: auto-activating connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 06:15:04 deb NetworkManager[1189]: <info> [1675660504.0573] device (enp4s0): Activation: starting connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 06:15:04 deb NetworkManager[1189]: <info> [1675660504.0573] device (enp4s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed') Feb 06 06:15:04 deb NetworkManager[1189]: <info> [1675660504.0575] device (enp4s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed') Feb 06 06:15:04 deb NetworkManager[1189]: <info> [1675660504.0582] device (enp4s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed') Feb 06 06:15:04 deb NetworkManager[1189]: <info> [1675660504.0594] dhcp4 (enp4s0): activation: beginning transaction (timeout in 45 seconds) Feb 06 06:15:49 deb NetworkManager[1189]: <info> [1675660549.0570] device (enp4s0): state change: ip-config -> failed (reason 'ip-config-unavailable', sys-iface-state: 'managed') Feb 06 06:15:49 deb NetworkManager[1189]: <warn> [1675660549.0573] device (enp4s0): Activation: failed for connection 'Wired connection 1' Feb 06 06:15:49 deb NetworkManager[1189]: <info> [1675660549.0574] device (enp4s0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed') Feb 06 06:15:49 deb NetworkManager[1189]: <info> [1675660549.1158] dhcp4 (enp4s0): canceled DHCP transaction Feb 06 06:15:49 deb NetworkManager[1189]: <info> [1675660549.1165] policy: auto-activating connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 06:15:49 deb NetworkManager[1189]: <info> [1675660549.1167] device (enp4s0): Activation: starting connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 06:15:49 deb NetworkManager[1189]: <info> [1675660549.1168] device (enp4s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed') Feb 06 06:15:49 deb NetworkManager[1189]: <info> [1675660549.1169] device (enp4s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed') Feb 06 06:15:49 deb NetworkManager[1189]: <info> [1675660549.1176] device (enp4s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed') Feb 06 06:15:49 deb NetworkManager[1189]: <info> [1675660549.1187] dhcp4 (enp4s0): activation: beginning transaction (timeout in 45 seconds) Feb 06 06:16:34 deb NetworkManager[1189]: <info> [1675660594.0571] device (enp4s0): state change: ip-config -> failed (reason 'ip-config-unavailable', sys-iface-state: 'managed') Feb 06 06:16:34 deb NetworkManager[1189]: <warn> [1675660594.0575] device (enp4s0): Activation: failed for connection 'Wired connection 1' Feb 06 06:16:34 deb NetworkManager[1189]: <info> [1675660594.0577] device (enp4s0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed') Feb 06 06:16:34 deb NetworkManager[1189]: <info> [1675660594.0758] dhcp4 (enp4s0): canceled DHCP transaction Feb 06 06:16:34 deb NetworkManager[1189]: <info> [1675660594.0763] policy: auto-activating connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 06:16:34 deb NetworkManager[1189]: <info> [1675660594.0765] device (enp4s0): Activation: starting connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 06:16:34 deb NetworkManager[1189]: <info> [1675660594.0765] device (enp4s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed') Feb 06 06:16:34 deb NetworkManager[1189]: <info> [1675660594.0767] device (enp4s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed') Feb 06 06:16:34 deb NetworkManager[1189]: <info> [1675660594.0775] device (enp4s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed') Feb 06 06:16:34 deb NetworkManager[1189]: <info> [1675660594.0784] dhcp4 (enp4s0): activation: beginning transaction (timeout in 45 seconds) Feb 06 06:17:19 deb NetworkManager[1189]: <info> [1675660639.0568] device (enp4s0): state change: ip-config -> failed (reason 'ip-config-unavailable', sys-iface-state: 'managed') Feb 06 06:17:19 deb NetworkManager[1189]: <warn> [1675660639.0570] device (enp4s0): Activation: failed for connection 'Wired connection 1' Feb 06 06:17:19 deb NetworkManager[1189]: <info> [1675660639.0571] device (enp4s0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed') Feb 06 06:17:19 deb NetworkManager[1189]: <info> [1675660639.0600] dhcp4 (enp4s0): canceled DHCP transaction Feb 06 06:17:19 deb NetworkManager[1189]: <info> [1675660639.0607] policy: auto-activating connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 06:17:19 deb NetworkManager[1189]: <info> [1675660639.0609] device (enp4s0): Activation: starting connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 06:17:19 deb NetworkManager[1189]: <info> [1675660639.0609] device (enp4s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed') Feb 06 06:17:19 deb NetworkManager[1189]: <info> [1675660639.0610] device (enp4s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed') Feb 06 06:17:19 deb NetworkManager[1189]: <info> [1675660639.0617] device (enp4s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed') Feb 06 06:17:19 deb NetworkManager[1189]: <info> [1675660639.0627] dhcp4 (enp4s0): activation: beginning transaction (timeout in 45 seconds) Feb 06 06:17:25 deb NetworkManager[1189]: <info> [1675660645.6819] audit: op="statistics" interface="wlx10bf485b893c" ifindex=3 args="2000" pid=2293 uid=1000 result="success" Feb 06 06:17:25 deb NetworkManager[1189]: <info> [1675660645.6848] audit: op="statistics" interface="wlx10bf485b893c" ifindex=3 args="500" pid=2422 uid=1000 result="success" Feb 06 06:17:30 deb NetworkManager[1189]: <info> [1675660650.0457] audit: op="statistics" interface="wlx10bf485b893c" ifindex=3 args="0" pid=2293 uid=1000 result="success" Feb 06 06:17:30 deb NetworkManager[1189]: <info> [1675660650.0479] audit: op="statistics" interface="wlx10bf485b893c" ifindex=3 args="500" pid=2422 uid=1000 result="success" Feb 06 06:18:04 deb NetworkManager[1189]: <info> [1675660684.0567] device (enp4s0): state change: ip-config -> failed (reason 'ip-config-unavailable', sys-iface-state: 'managed') Feb 06 06:18:04 deb NetworkManager[1189]: <warn> [1675660684.0569] device (enp4s0): Activation: failed for connection 'Wired connection 1' Feb 06 06:18:04 deb NetworkManager[1189]: <info> [1675660684.0570] device (enp4s0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed') Feb 06 06:18:04 deb NetworkManager[1189]: <info> [1675660684.0599] dhcp4 (enp4s0): canceled DHCP transaction Feb 06 06:23:04 deb NetworkManager[1189]: <info> [1675660984.0569] policy: auto-activating connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 06:23:04 deb NetworkManager[1189]: <info> [1675660984.0574] device (enp4s0): Activation: starting connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 06:23:04 deb NetworkManager[1189]: <info> [1675660984.0575] device (enp4s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed') Feb 06 06:23:04 deb NetworkManager[1189]: <info> [1675660984.0578] device (enp4s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed') Feb 06 06:23:04 deb NetworkManager[1189]: <info> [1675660984.0588] device (enp4s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed') Feb 06 06:23:04 deb NetworkManager[1189]: <info> [1675660984.0601] dhcp4 (enp4s0): activation: beginning transaction (timeout in 45 seconds) Feb 06 06:23:49 deb NetworkManager[1189]: <info> [1675661029.0570] device (enp4s0): state change: ip-config -> failed (reason 'ip-config-unavailable', sys-iface-state: 'managed') Feb 06 06:23:49 deb NetworkManager[1189]: <warn> [1675661029.0573] device (enp4s0): Activation: failed for connection 'Wired connection 1' Feb 06 06:23:49 deb NetworkManager[1189]: <info> [1675661029.0574] device (enp4s0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed') Feb 06 06:23:49 deb NetworkManager[1189]: <info> [1675661029.0600] dhcp4 (enp4s0): canceled DHCP transaction Feb 06 06:23:49 deb NetworkManager[1189]: <info> [1675661029.0609] policy: auto-activating connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 06:23:49 deb NetworkManager[1189]: <info> [1675661029.0611] device (enp4s0): Activation: starting connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 06:23:49 deb NetworkManager[1189]: <info> [1675661029.0612] device (enp4s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed') Feb 06 06:23:49 deb NetworkManager[1189]: <info> [1675661029.0613] device (enp4s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed') Feb 06 06:23:49 deb NetworkManager[1189]: <info> [1675661029.0620] device (enp4s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed') Feb 06 06:23:49 deb NetworkManager[1189]: <info> [1675661029.0631] dhcp4 (enp4s0): activation: beginning transaction (timeout in 45 seconds) Feb 06 06:24:21 deb NetworkManager[1189]: <info> [1675661061.1253] dhcp4 (wlx10bf485b893c): state changed new lease, address=192.168.150.55 Feb 06 06:24:34 deb NetworkManager[1189]: <info> [1675661074.0568] device (enp4s0): state change: ip-config -> failed (reason 'ip-config-unavailable', sys-iface-state: 'managed') Feb 06 06:24:34 deb NetworkManager[1189]: <warn> [1675661074.0572] device (enp4s0): Activation: failed for connection 'Wired connection 1' Feb 06 06:24:34 deb NetworkManager[1189]: <info> [1675661074.0574] device (enp4s0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed') Feb 06 06:24:34 deb NetworkManager[1189]: <info> [1675661074.0603] dhcp4 (enp4s0): canceled DHCP transaction Feb 06 06:24:34 deb NetworkManager[1189]: <info> [1675661074.0615] policy: auto-activating connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 06:24:34 deb NetworkManager[1189]: <info> [1675661074.0617] device (enp4s0): Activation: starting connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 06:24:34 deb NetworkManager[1189]: <info> [1675661074.0618] device (enp4s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed') Feb 06 06:24:34 deb NetworkManager[1189]: <info> [1675661074.0619] device (enp4s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed') Feb 06 06:24:34 deb NetworkManager[1189]: <info> [1675661074.0626] device (enp4s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed') Feb 06 06:24:34 deb NetworkManager[1189]: <info> [1675661074.0637] dhcp4 (enp4s0): activation: beginning transaction (timeout in 45 seconds) Feb 06 06:25:19 deb NetworkManager[1189]: <info> [1675661119.0573] device (enp4s0): state change: ip-config -> failed (reason 'ip-config-unavailable', sys-iface-state: 'managed') Feb 06 06:25:19 deb NetworkManager[1189]: <warn> [1675661119.0576] device (enp4s0): Activation: failed for connection 'Wired connection 1' Feb 06 06:25:19 deb NetworkManager[1189]: <info> [1675661119.0577] device (enp4s0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed') Feb 06 06:25:19 deb NetworkManager[1189]: <info> [1675661119.0600] dhcp4 (enp4s0): canceled DHCP transaction Feb 06 06:25:19 deb NetworkManager[1189]: <info> [1675661119.0609] policy: auto-activating connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 06:25:19 deb NetworkManager[1189]: <info> [1675661119.0611] device (enp4s0): Activation: starting connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 06:25:19 deb NetworkManager[1189]: <info> [1675661119.0611] device (enp4s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed') Feb 06 06:25:19 deb NetworkManager[1189]: <info> [1675661119.0613] device (enp4s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed') Feb 06 06:25:19 deb NetworkManager[1189]: <info> [1675661119.0620] device (enp4s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed') Feb 06 06:25:19 deb NetworkManager[1189]: <info> [1675661119.0632] dhcp4 (enp4s0): activation: beginning transaction (timeout in 45 seconds) Feb 06 06:26:04 deb NetworkManager[1189]: <info> [1675661164.0574] device (enp4s0): state change: ip-config -> failed (reason 'ip-config-unavailable', sys-iface-state: 'managed') Feb 06 06:26:04 deb NetworkManager[1189]: <warn> [1675661164.0577] device (enp4s0): Activation: failed for connection 'Wired connection 1' Feb 06 06:26:04 deb NetworkManager[1189]: <info> [1675661164.0578] device (enp4s0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed') Feb 06 06:26:04 deb NetworkManager[1189]: <info> [1675661164.0610] dhcp4 (enp4s0): canceled DHCP transaction Feb 06 06:31:04 deb NetworkManager[1189]: <info> [1675661464.0570] policy: auto-activating connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 06:31:04 deb NetworkManager[1189]: <info> [1675661464.0575] device (enp4s0): Activation: starting connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 06:31:04 deb NetworkManager[1189]: <info> [1675661464.0575] device (enp4s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed') Feb 06 06:31:04 deb NetworkManager[1189]: <info> [1675661464.0578] device (enp4s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed') Feb 06 06:31:04 deb NetworkManager[1189]: <info> [1675661464.0587] device (enp4s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed') Feb 06 06:31:04 deb NetworkManager[1189]: <info> [1675661464.0601] dhcp4 (enp4s0): activation: beginning transaction (timeout in 45 seconds) Feb 06 06:31:49 deb NetworkManager[1189]: <info> [1675661509.0571] device (enp4s0): state change: ip-config -> failed (reason 'ip-config-unavailable', sys-iface-state: 'managed') Feb 06 06:31:49 deb NetworkManager[1189]: <warn> [1675661509.0576] device (enp4s0): Activation: failed for connection 'Wired connection 1' Feb 06 06:31:49 deb NetworkManager[1189]: <info> [1675661509.0578] device (enp4s0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed') Feb 06 06:31:49 deb NetworkManager[1189]: <info> [1675661509.0878] dhcp4 (enp4s0): canceled DHCP transaction Feb 06 06:31:49 deb NetworkManager[1189]: <info> [1675661509.0889] policy: auto-activating connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 06:31:49 deb NetworkManager[1189]: <info> [1675661509.0894] device (enp4s0): Activation: starting connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 06:31:49 deb NetworkManager[1189]: <info> [1675661509.0895] device (enp4s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed') Feb 06 06:31:49 deb NetworkManager[1189]: <info> [1675661509.0897] device (enp4s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed') Feb 06 06:31:49 deb NetworkManager[1189]: <info> [1675661509.0906] device (enp4s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed') Feb 06 06:31:49 deb NetworkManager[1189]: <info> [1675661509.0939] dhcp4 (enp4s0): activation: beginning transaction (timeout in 45 seconds) Feb 06 06:32:34 deb NetworkManager[1189]: <info> [1675661554.0569] device (enp4s0): state change: ip-config -> failed (reason 'ip-config-unavailable', sys-iface-state: 'managed') Feb 06 06:32:34 deb NetworkManager[1189]: <warn> [1675661554.0572] device (enp4s0): Activation: failed for connection 'Wired connection 1' Feb 06 06:32:34 deb NetworkManager[1189]: <info> [1675661554.0574] device (enp4s0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed') Feb 06 06:32:34 deb NetworkManager[1189]: <info> [1675661554.0596] dhcp4 (enp4s0): canceled DHCP transaction Feb 06 06:32:34 deb NetworkManager[1189]: <info> [1675661554.0606] policy: auto-activating connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 06:32:34 deb NetworkManager[1189]: <info> [1675661554.0609] device (enp4s0): Activation: starting connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 06:32:34 deb NetworkManager[1189]: <info> [1675661554.0609] device (enp4s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed') Feb 06 06:32:34 deb NetworkManager[1189]: <info> [1675661554.0611] device (enp4s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed') Feb 06 06:32:34 deb NetworkManager[1189]: <info> [1675661554.0618] device (enp4s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed') Feb 06 06:32:34 deb NetworkManager[1189]: <info> [1675661554.0628] dhcp4 (enp4s0): activation: beginning transaction (timeout in 45 seconds) Feb 06 06:33:19 deb NetworkManager[1189]: <info> [1675661599.0569] device (enp4s0): state change: ip-config -> failed (reason 'ip-config-unavailable', sys-iface-state: 'managed') Feb 06 06:33:19 deb NetworkManager[1189]: <warn> [1675661599.0572] device (enp4s0): Activation: failed for connection 'Wired connection 1' Feb 06 06:33:19 deb NetworkManager[1189]: <info> [1675661599.0573] device (enp4s0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed') Feb 06 06:33:19 deb NetworkManager[1189]: <info> [1675661599.0599] dhcp4 (enp4s0): canceled DHCP transaction Feb 06 06:33:19 deb NetworkManager[1189]: <info> [1675661599.0607] policy: auto-activating connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 06:33:19 deb NetworkManager[1189]: <info> [1675661599.0609] device (enp4s0): Activation: starting connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 06:33:19 deb NetworkManager[1189]: <info> [1675661599.0610] device (enp4s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed') Feb 06 06:33:19 deb NetworkManager[1189]: <info> [1675661599.0611] device (enp4s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed') Feb 06 06:33:19 deb NetworkManager[1189]: <info> [1675661599.0619] device (enp4s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed') Feb 06 06:33:19 deb NetworkManager[1189]: <info> [1675661599.0630] dhcp4 (enp4s0): activation: beginning transaction (timeout in 45 seconds) Feb 06 06:34:04 deb NetworkManager[1189]: <info> [1675661644.0576] device (enp4s0): state change: ip-config -> failed (reason 'ip-config-unavailable', sys-iface-state: 'managed') Feb 06 06:34:04 deb NetworkManager[1189]: <warn> [1675661644.0581] device (enp4s0): Activation: failed for connection 'Wired connection 1' Feb 06 06:34:04 deb NetworkManager[1189]: <info> [1675661644.0583] device (enp4s0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed') Feb 06 06:34:04 deb NetworkManager[1189]: <info> [1675661644.0799] dhcp4 (enp4s0): canceled DHCP transaction Feb 06 06:39:04 deb NetworkManager[1189]: <info> [1675661944.0572] policy: auto-activating connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 06:39:04 deb NetworkManager[1189]: <info> [1675661944.0576] device (enp4s0): Activation: starting connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 06:39:04 deb NetworkManager[1189]: <info> [1675661944.0576] device (enp4s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed') Feb 06 06:39:04 deb NetworkManager[1189]: <info> [1675661944.0578] device (enp4s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed') Feb 06 06:39:04 deb NetworkManager[1189]: <info> [1675661944.0586] device (enp4s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed') Feb 06 06:39:04 deb NetworkManager[1189]: <info> [1675661944.0597] dhcp4 (enp4s0): activation: beginning transaction (timeout in 45 seconds) Feb 06 06:39:49 deb NetworkManager[1189]: <info> [1675661989.0575] device (enp4s0): state change: ip-config -> failed (reason 'ip-config-unavailable', sys-iface-state: 'managed') Feb 06 06:39:49 deb NetworkManager[1189]: <warn> [1675661989.0578] device (enp4s0): Activation: failed for connection 'Wired connection 1' Feb 06 06:39:49 deb NetworkManager[1189]: <info> [1675661989.0579] device (enp4s0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed') Feb 06 06:39:49 deb NetworkManager[1189]: <info> [1675661989.0610] dhcp4 (enp4s0): canceled DHCP transaction Feb 06 06:39:49 deb NetworkManager[1189]: <info> [1675661989.0617] policy: auto-activating connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 06:39:49 deb NetworkManager[1189]: <info> [1675661989.0620] device (enp4s0): Activation: starting connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 06:39:49 deb NetworkManager[1189]: <info> [1675661989.0620] device (enp4s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed') Feb 06 06:39:49 deb NetworkManager[1189]: <info> [1675661989.0621] device (enp4s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed') Feb 06 06:39:49 deb NetworkManager[1189]: <info> [1675661989.0629] device (enp4s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed') Feb 06 06:39:49 deb NetworkManager[1189]: <info> [1675661989.0640] dhcp4 (enp4s0): activation: beginning transaction (timeout in 45 seconds) Feb 06 06:40:34 deb NetworkManager[1189]: <info> [1675662034.0574] device (enp4s0): state change: ip-config -> failed (reason 'ip-config-unavailable', sys-iface-state: 'managed') Feb 06 06:40:34 deb NetworkManager[1189]: <warn> [1675662034.0578] device (enp4s0): Activation: failed for connection 'Wired connection 1' Feb 06 06:40:34 deb NetworkManager[1189]: <info> [1675662034.0580] device (enp4s0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed') Feb 06 06:40:34 deb NetworkManager[1189]: <info> [1675662034.0998] dhcp4 (enp4s0): canceled DHCP transaction Feb 06 06:40:34 deb NetworkManager[1189]: <info> [1675662034.1005] policy: auto-activating connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 06:40:34 deb NetworkManager[1189]: <info> [1675662034.1007] device (enp4s0): Activation: starting connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 06:40:34 deb NetworkManager[1189]: <info> [1675662034.1008] device (enp4s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed') Feb 06 06:40:34 deb NetworkManager[1189]: <info> [1675662034.1009] device (enp4s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed') Feb 06 06:40:34 deb NetworkManager[1189]: <info> [1675662034.1017] device (enp4s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed') Feb 06 06:40:34 deb NetworkManager[1189]: <info> [1675662034.1028] dhcp4 (enp4s0): activation: beginning transaction (timeout in 45 seconds) Feb 06 06:41:19 deb NetworkManager[1189]: <info> [1675662079.0575] device (enp4s0): state change: ip-config -> failed (reason 'ip-config-unavailable', sys-iface-state: 'managed') Feb 06 06:41:19 deb NetworkManager[1189]: <warn> [1675662079.0578] device (enp4s0): Activation: failed for connection 'Wired connection 1' Feb 06 06:41:19 deb NetworkManager[1189]: <info> [1675662079.0579] device (enp4s0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed') Feb 06 06:41:19 deb NetworkManager[1189]: <info> [1675662079.1038] dhcp4 (enp4s0): canceled DHCP transaction Feb 06 06:41:19 deb NetworkManager[1189]: <info> [1675662079.1047] policy: auto-activating connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 06:41:19 deb NetworkManager[1189]: <info> [1675662079.1050] device (enp4s0): Activation: starting connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 06:41:19 deb NetworkManager[1189]: <info> [1675662079.1050] device (enp4s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed') Feb 06 06:41:19 deb NetworkManager[1189]: <info> [1675662079.1052] device (enp4s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed') Feb 06 06:41:19 deb NetworkManager[1189]: <info> [1675662079.1060] device (enp4s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed') Feb 06 06:41:19 deb NetworkManager[1189]: <info> [1675662079.1074] dhcp4 (enp4s0): activation: beginning transaction (timeout in 45 seconds) Feb 06 06:42:04 deb NetworkManager[1189]: <info> [1675662124.0566] device (enp4s0): state change: ip-config -> failed (reason 'ip-config-unavailable', sys-iface-state: 'managed') Feb 06 06:42:04 deb NetworkManager[1189]: <warn> [1675662124.0570] device (enp4s0): Activation: failed for connection 'Wired connection 1' Feb 06 06:42:04 deb NetworkManager[1189]: <info> [1675662124.0572] device (enp4s0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed') Feb 06 06:42:04 deb NetworkManager[1189]: <info> [1675662124.0595] dhcp4 (enp4s0): canceled DHCP transaction Feb 06 06:47:04 deb NetworkManager[1189]: <info> [1675662424.0574] policy: auto-activating connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 06:47:04 deb NetworkManager[1189]: <info> [1675662424.0579] device (enp4s0): Activation: starting connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 06:47:04 deb NetworkManager[1189]: <info> [1675662424.0580] device (enp4s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed') Feb 06 06:47:04 deb NetworkManager[1189]: <info> [1675662424.0583] device (enp4s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed') Feb 06 06:47:04 deb NetworkManager[1189]: <info> [1675662424.0592] device (enp4s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed') Feb 06 06:47:04 deb NetworkManager[1189]: <info> [1675662424.0605] dhcp4 (enp4s0): activation: beginning transaction (timeout in 45 seconds) Feb 06 06:47:49 deb NetworkManager[1189]: <info> [1675662469.0570] device (enp4s0): state change: ip-config -> failed (reason 'ip-config-unavailable', sys-iface-state: 'managed') Feb 06 06:47:49 deb NetworkManager[1189]: <warn> [1675662469.0574] device (enp4s0): Activation: failed for connection 'Wired connection 1' Feb 06 06:47:49 deb NetworkManager[1189]: <info> [1675662469.0575] device (enp4s0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed') Feb 06 06:47:49 deb NetworkManager[1189]: <info> [1675662469.0605] dhcp4 (enp4s0): canceled DHCP transaction Feb 06 06:47:49 deb NetworkManager[1189]: <info> [1675662469.0614] policy: auto-activating connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 06:47:49 deb NetworkManager[1189]: <info> [1675662469.0617] device (enp4s0): Activation: starting connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 06:47:49 deb NetworkManager[1189]: <info> [1675662469.0617] device (enp4s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed') Feb 06 06:47:49 deb NetworkManager[1189]: <info> [1675662469.0619] device (enp4s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed') Feb 06 06:47:49 deb NetworkManager[1189]: <info> [1675662469.0626] device (enp4s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed') Feb 06 06:47:49 deb NetworkManager[1189]: <info> [1675662469.0637] dhcp4 (enp4s0): activation: beginning transaction (timeout in 45 seconds) Feb 06 06:48:34 deb NetworkManager[1189]: <info> [1675662514.0572] device (enp4s0): state change: ip-config -> failed (reason 'ip-config-unavailable', sys-iface-state: 'managed') Feb 06 06:48:34 deb NetworkManager[1189]: <warn> [1675662514.0576] device (enp4s0): Activation: failed for connection 'Wired connection 1' Feb 06 06:48:34 deb NetworkManager[1189]: <info> [1675662514.0579] device (enp4s0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed') Feb 06 06:48:34 deb NetworkManager[1189]: <info> [1675662514.0606] dhcp4 (enp4s0): canceled DHCP transaction Feb 06 06:48:34 deb NetworkManager[1189]: <info> [1675662514.0618] policy: auto-activating connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 06:48:34 deb NetworkManager[1189]: <info> [1675662514.0623] device (enp4s0): Activation: starting connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 06:48:34 deb NetworkManager[1189]: <info> [1675662514.0624] device (enp4s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed') Feb 06 06:48:34 deb NetworkManager[1189]: <info> [1675662514.0626] device (enp4s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed') Feb 06 06:48:34 deb NetworkManager[1189]: <info> [1675662514.0636] device (enp4s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed') Feb 06 06:48:34 deb NetworkManager[1189]: <info> [1675662514.0649] dhcp4 (enp4s0): activation: beginning transaction (timeout in 45 seconds) Feb 06 06:49:19 deb NetworkManager[1189]: <info> [1675662559.0576] device (enp4s0): state change: ip-config -> failed (reason 'ip-config-unavailable', sys-iface-state: 'managed') Feb 06 06:49:19 deb NetworkManager[1189]: <warn> [1675662559.0579] device (enp4s0): Activation: failed for connection 'Wired connection 1' Feb 06 06:49:19 deb NetworkManager[1189]: <info> [1675662559.0580] device (enp4s0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed') Feb 06 06:49:19 deb NetworkManager[1189]: <info> [1675662559.0998] dhcp4 (enp4s0): canceled DHCP transaction Feb 06 06:49:19 deb NetworkManager[1189]: <info> [1675662559.1008] policy: auto-activating connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 06:49:19 deb NetworkManager[1189]: <info> [1675662559.1011] device (enp4s0): Activation: starting connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 06:49:19 deb NetworkManager[1189]: <info> [1675662559.1011] device (enp4s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed') Feb 06 06:49:19 deb NetworkManager[1189]: <info> [1675662559.1013] device (enp4s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed') Feb 06 06:49:19 deb NetworkManager[1189]: <info> [1675662559.1021] device (enp4s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed') Feb 06 06:49:19 deb NetworkManager[1189]: <info> [1675662559.1031] dhcp4 (enp4s0): activation: beginning transaction (timeout in 45 seconds) Feb 06 06:50:04 deb NetworkManager[1189]: <info> [1675662604.0576] device (enp4s0): state change: ip-config -> failed (reason 'ip-config-unavailable', sys-iface-state: 'managed') Feb 06 06:50:04 deb NetworkManager[1189]: <warn> [1675662604.0581] device (enp4s0): Activation: failed for connection 'Wired connection 1' Feb 06 06:50:04 deb NetworkManager[1189]: <info> [1675662604.0583] device (enp4s0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed') Feb 06 06:50:04 deb NetworkManager[1189]: <info> [1675662604.0611] dhcp4 (enp4s0): canceled DHCP transaction Feb 06 06:54:20 deb NetworkManager[1189]: <info> [1675662860.0818] dhcp4 (wlx10bf485b893c): state changed new lease, address=192.168.150.55 Feb 06 06:55:04 deb NetworkManager[1189]: <info> [1675662904.0568] policy: auto-activating connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 06:55:04 deb NetworkManager[1189]: <info> [1675662904.0575] device (enp4s0): Activation: starting connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 06:55:04 deb NetworkManager[1189]: <info> [1675662904.0576] device (enp4s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed') Feb 06 06:55:04 deb NetworkManager[1189]: <info> [1675662904.0579] device (enp4s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed') Feb 06 06:55:04 deb NetworkManager[1189]: <info> [1675662904.0588] device (enp4s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed') Feb 06 06:55:04 deb NetworkManager[1189]: <info> [1675662904.0601] dhcp4 (enp4s0): activation: beginning transaction (timeout in 45 seconds) Feb 06 06:55:49 deb NetworkManager[1189]: <info> [1675662949.0574] device (enp4s0): state change: ip-config -> failed (reason 'ip-config-unavailable', sys-iface-state: 'managed') Feb 06 06:55:49 deb NetworkManager[1189]: <warn> [1675662949.0578] device (enp4s0): Activation: failed for connection 'Wired connection 1' Feb 06 06:55:49 deb NetworkManager[1189]: <info> [1675662949.0579] device (enp4s0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed') Feb 06 06:55:49 deb NetworkManager[1189]: <info> [1675662949.0918] dhcp4 (enp4s0): canceled DHCP transaction Feb 06 06:55:49 deb NetworkManager[1189]: <info> [1675662949.0925] policy: auto-activating connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 06:55:49 deb NetworkManager[1189]: <info> [1675662949.0928] device (enp4s0): Activation: starting connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 06:55:49 deb NetworkManager[1189]: <info> [1675662949.0928] device (enp4s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed') Feb 06 06:55:49 deb NetworkManager[1189]: <info> [1675662949.0929] device (enp4s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed') Feb 06 06:55:49 deb NetworkManager[1189]: <info> [1675662949.0937] device (enp4s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed') Feb 06 06:55:49 deb NetworkManager[1189]: <info> [1675662949.0950] dhcp4 (enp4s0): activation: beginning transaction (timeout in 45 seconds) Feb 06 06:56:34 deb NetworkManager[1189]: <info> [1675662994.0570] device (enp4s0): state change: ip-config -> failed (reason 'ip-config-unavailable', sys-iface-state: 'managed') Feb 06 06:56:34 deb NetworkManager[1189]: <warn> [1675662994.0573] device (enp4s0): Activation: failed for connection 'Wired connection 1' Feb 06 06:56:34 deb NetworkManager[1189]: <info> [1675662994.0574] device (enp4s0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed') Feb 06 06:56:34 deb NetworkManager[1189]: <info> [1675662994.0878] dhcp4 (enp4s0): canceled DHCP transaction Feb 06 06:56:34 deb NetworkManager[1189]: <info> [1675662994.0886] policy: auto-activating connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 06:56:34 deb NetworkManager[1189]: <info> [1675662994.0888] device (enp4s0): Activation: starting connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 06:56:34 deb NetworkManager[1189]: <info> [1675662994.0889] device (enp4s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed') Feb 06 06:56:34 deb NetworkManager[1189]: <info> [1675662994.0890] device (enp4s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed') Feb 06 06:56:34 deb NetworkManager[1189]: <info> [1675662994.0898] device (enp4s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed') Feb 06 06:56:34 deb NetworkManager[1189]: <info> [1675662994.0909] dhcp4 (enp4s0): activation: beginning transaction (timeout in 45 seconds) Feb 06 06:57:19 deb NetworkManager[1189]: <info> [1675663039.0571] device (enp4s0): state change: ip-config -> failed (reason 'ip-config-unavailable', sys-iface-state: 'managed') Feb 06 06:57:19 deb NetworkManager[1189]: <warn> [1675663039.0576] device (enp4s0): Activation: failed for connection 'Wired connection 1' Feb 06 06:57:19 deb NetworkManager[1189]: <info> [1675663039.0578] device (enp4s0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed') Feb 06 06:57:19 deb NetworkManager[1189]: <info> [1675663039.0878] dhcp4 (enp4s0): canceled DHCP transaction Feb 06 06:57:19 deb NetworkManager[1189]: <info> [1675663039.0886] policy: auto-activating connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 06:57:19 deb NetworkManager[1189]: <info> [1675663039.0888] device (enp4s0): Activation: starting connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 06:57:19 deb NetworkManager[1189]: <info> [1675663039.0888] device (enp4s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed') Feb 06 06:57:19 deb NetworkManager[1189]: <info> [1675663039.0890] device (enp4s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed') Feb 06 06:57:19 deb NetworkManager[1189]: <info> [1675663039.0898] device (enp4s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed') Feb 06 06:57:19 deb NetworkManager[1189]: <info> [1675663039.0909] dhcp4 (enp4s0): activation: beginning transaction (timeout in 45 seconds) Feb 06 06:58:04 deb NetworkManager[1189]: <info> [1675663084.0573] device (enp4s0): state change: ip-config -> failed (reason 'ip-config-unavailable', sys-iface-state: 'managed') Feb 06 06:58:04 deb NetworkManager[1189]: <warn> [1675663084.0575] device (enp4s0): Activation: failed for connection 'Wired connection 1' Feb 06 06:58:04 deb NetworkManager[1189]: <info> [1675663084.0576] device (enp4s0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed') Feb 06 06:58:04 deb NetworkManager[1189]: <info> [1675663084.0758] dhcp4 (enp4s0): canceled DHCP transaction Feb 06 07:03:04 deb NetworkManager[1189]: <info> [1675663384.0565] policy: auto-activating connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 07:03:04 deb NetworkManager[1189]: <info> [1675663384.0570] device (enp4s0): Activation: starting connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 07:03:04 deb NetworkManager[1189]: <info> [1675663384.0571] device (enp4s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed') Feb 06 07:03:04 deb NetworkManager[1189]: <info> [1675663384.0574] device (enp4s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed') Feb 06 07:03:04 deb NetworkManager[1189]: <info> [1675663384.0583] device (enp4s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed') Feb 06 07:03:04 deb NetworkManager[1189]: <info> [1675663384.0596] dhcp4 (enp4s0): activation: beginning transaction (timeout in 45 seconds) Feb 06 07:03:49 deb NetworkManager[1189]: <info> [1675663429.0563] device (enp4s0): state change: ip-config -> failed (reason 'ip-config-unavailable', sys-iface-state: 'managed') Feb 06 07:03:49 deb NetworkManager[1189]: <warn> [1675663429.0566] device (enp4s0): Activation: failed for connection 'Wired connection 1' Feb 06 07:03:49 deb NetworkManager[1189]: <info> [1675663429.0567] device (enp4s0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed') Feb 06 07:03:49 deb NetworkManager[1189]: <info> [1675663429.0588] dhcp4 (enp4s0): canceled DHCP transaction Feb 06 07:03:49 deb NetworkManager[1189]: <info> [1675663429.0595] policy: auto-activating connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 07:03:49 deb NetworkManager[1189]: <info> [1675663429.0598] device (enp4s0): Activation: starting connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 07:03:49 deb NetworkManager[1189]: <info> [1675663429.0599] device (enp4s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed') Feb 06 07:03:49 deb NetworkManager[1189]: <info> [1675663429.0600] device (enp4s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed') Feb 06 07:03:49 deb NetworkManager[1189]: <info> [1675663429.0607] device (enp4s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed') Feb 06 07:03:49 deb NetworkManager[1189]: <info> [1675663429.0620] dhcp4 (enp4s0): activation: beginning transaction (timeout in 45 seconds) Feb 06 07:04:34 deb NetworkManager[1189]: <info> [1675663474.0570] device (enp4s0): state change: ip-config -> failed (reason 'ip-config-unavailable', sys-iface-state: 'managed') Feb 06 07:04:34 deb NetworkManager[1189]: <warn> [1675663474.0573] device (enp4s0): Activation: failed for connection 'Wired connection 1' Feb 06 07:04:34 deb NetworkManager[1189]: <info> [1675663474.0574] device (enp4s0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed') Feb 06 07:04:34 deb NetworkManager[1189]: <info> [1675663474.0839] dhcp4 (enp4s0): canceled DHCP transaction Feb 06 07:04:34 deb NetworkManager[1189]: <info> [1675663474.0850] policy: auto-activating connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 07:04:34 deb NetworkManager[1189]: <info> [1675663474.0854] device (enp4s0): Activation: starting connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 07:04:34 deb NetworkManager[1189]: <info> [1675663474.0855] device (enp4s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed') Feb 06 07:04:34 deb NetworkManager[1189]: <info> [1675663474.0857] device (enp4s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed') Feb 06 07:04:34 deb NetworkManager[1189]: <info> [1675663474.0868] device (enp4s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed') Feb 06 07:04:34 deb NetworkManager[1189]: <info> [1675663474.0882] dhcp4 (enp4s0): activation: beginning transaction (timeout in 45 seconds) Feb 06 07:05:19 deb NetworkManager[1189]: <info> [1675663519.0565] device (enp4s0): state change: ip-config -> failed (reason 'ip-config-unavailable', sys-iface-state: 'managed') Feb 06 07:05:19 deb NetworkManager[1189]: <warn> [1675663519.0568] device (enp4s0): Activation: failed for connection 'Wired connection 1' Feb 06 07:05:19 deb NetworkManager[1189]: <info> [1675663519.0569] device (enp4s0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed') Feb 06 07:05:19 deb NetworkManager[1189]: <info> [1675663519.0593] dhcp4 (enp4s0): canceled DHCP transaction Feb 06 07:05:19 deb NetworkManager[1189]: <info> [1675663519.0601] policy: auto-activating connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 07:05:19 deb NetworkManager[1189]: <info> [1675663519.0604] device (enp4s0): Activation: starting connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 07:05:19 deb NetworkManager[1189]: <info> [1675663519.0604] device (enp4s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed') Feb 06 07:05:19 deb NetworkManager[1189]: <info> [1675663519.0606] device (enp4s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed') Feb 06 07:05:19 deb NetworkManager[1189]: <info> [1675663519.0614] device (enp4s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed') Feb 06 07:05:19 deb NetworkManager[1189]: <info> [1675663519.0626] dhcp4 (enp4s0): activation: beginning transaction (timeout in 45 seconds) Feb 06 07:06:04 deb NetworkManager[1189]: <info> [1675663564.0566] device (enp4s0): state change: ip-config -> failed (reason 'ip-config-unavailable', sys-iface-state: 'managed') Feb 06 07:06:04 deb NetworkManager[1189]: <warn> [1675663564.0571] device (enp4s0): Activation: failed for connection 'Wired connection 1' Feb 06 07:06:04 deb NetworkManager[1189]: <info> [1675663564.0572] device (enp4s0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed') Feb 06 07:06:04 deb NetworkManager[1189]: <info> [1675663564.0879] dhcp4 (enp4s0): canceled DHCP transaction Feb 06 07:11:04 deb NetworkManager[1189]: <info> [1675663864.0572] policy: auto-activating connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 07:11:04 deb NetworkManager[1189]: <info> [1675663864.0575] device (enp4s0): Activation: starting connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 07:11:04 deb NetworkManager[1189]: <info> [1675663864.0576] device (enp4s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed') Feb 06 07:11:04 deb NetworkManager[1189]: <info> [1675663864.0577] device (enp4s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed') Feb 06 07:11:04 deb NetworkManager[1189]: <info> [1675663864.0584] device (enp4s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed') Feb 06 07:11:04 deb NetworkManager[1189]: <info> [1675663864.0598] dhcp4 (enp4s0): activation: beginning transaction (timeout in 45 seconds) Feb 06 07:11:49 deb NetworkManager[1189]: <info> [1675663909.0570] device (enp4s0): state change: ip-config -> failed (reason 'ip-config-unavailable', sys-iface-state: 'managed') Feb 06 07:11:49 deb NetworkManager[1189]: <warn> [1675663909.0575] device (enp4s0): Activation: failed for connection 'Wired connection 1' Feb 06 07:11:49 deb NetworkManager[1189]: <info> [1675663909.0577] device (enp4s0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed') Feb 06 07:11:49 deb NetworkManager[1189]: <info> [1675663909.1118] dhcp4 (enp4s0): canceled DHCP transaction Feb 06 07:11:49 deb NetworkManager[1189]: <info> [1675663909.1125] policy: auto-activating connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 07:11:49 deb NetworkManager[1189]: <info> [1675663909.1127] device (enp4s0): Activation: starting connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 07:11:49 deb NetworkManager[1189]: <info> [1675663909.1128] device (enp4s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed') Feb 06 07:11:49 deb NetworkManager[1189]: <info> [1675663909.1129] device (enp4s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed') Feb 06 07:11:49 deb NetworkManager[1189]: <info> [1675663909.1137] device (enp4s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed') Feb 06 07:11:49 deb NetworkManager[1189]: <info> [1675663909.1147] dhcp4 (enp4s0): activation: beginning transaction (timeout in 45 seconds) Feb 06 07:12:34 deb NetworkManager[1189]: <info> [1675663954.0572] device (enp4s0): state change: ip-config -> failed (reason 'ip-config-unavailable', sys-iface-state: 'managed') Feb 06 07:12:34 deb NetworkManager[1189]: <warn> [1675663954.0576] device (enp4s0): Activation: failed for connection 'Wired connection 1' Feb 06 07:12:34 deb NetworkManager[1189]: <info> [1675663954.0578] device (enp4s0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed') Feb 06 07:12:34 deb NetworkManager[1189]: <info> [1675663954.0609] dhcp4 (enp4s0): canceled DHCP transaction Feb 06 07:12:34 deb NetworkManager[1189]: <info> [1675663954.0623] policy: auto-activating connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 07:12:34 deb NetworkManager[1189]: <info> [1675663954.0626] device (enp4s0): Activation: starting connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 07:12:34 deb NetworkManager[1189]: <info> [1675663954.0627] device (enp4s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed') Feb 06 07:12:34 deb NetworkManager[1189]: <info> [1675663954.0630] device (enp4s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed') Feb 06 07:12:34 deb NetworkManager[1189]: <info> [1675663954.0638] device (enp4s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed') Feb 06 07:12:34 deb NetworkManager[1189]: <info> [1675663954.0650] dhcp4 (enp4s0): activation: beginning transaction (timeout in 45 seconds) Feb 06 07:13:19 deb NetworkManager[1189]: <info> [1675663999.0563] device (enp4s0): state change: ip-config -> failed (reason 'ip-config-unavailable', sys-iface-state: 'managed') Feb 06 07:13:19 deb NetworkManager[1189]: <warn> [1675663999.0566] device (enp4s0): Activation: failed for connection 'Wired connection 1' Feb 06 07:13:19 deb NetworkManager[1189]: <info> [1675663999.0567] device (enp4s0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed') Feb 06 07:13:19 deb NetworkManager[1189]: <info> [1675663999.0591] dhcp4 (enp4s0): canceled DHCP transaction Feb 06 07:13:19 deb NetworkManager[1189]: <info> [1675663999.0598] policy: auto-activating connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 07:13:19 deb NetworkManager[1189]: <info> [1675663999.0600] device (enp4s0): Activation: starting connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 07:13:19 deb NetworkManager[1189]: <info> [1675663999.0601] device (enp4s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed') Feb 06 07:13:19 deb NetworkManager[1189]: <info> [1675663999.0602] device (enp4s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed') Feb 06 07:13:19 deb NetworkManager[1189]: <info> [1675663999.0609] device (enp4s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed') Feb 06 07:13:19 deb NetworkManager[1189]: <info> [1675663999.0622] dhcp4 (enp4s0): activation: beginning transaction (timeout in 45 seconds) Feb 06 07:14:04 deb NetworkManager[1189]: <info> [1675664044.0573] device (enp4s0): state change: ip-config -> failed (reason 'ip-config-unavailable', sys-iface-state: 'managed') Feb 06 07:14:04 deb NetworkManager[1189]: <warn> [1675664044.0576] device (enp4s0): Activation: failed for connection 'Wired connection 1' Feb 06 07:14:04 deb NetworkManager[1189]: <info> [1675664044.0577] device (enp4s0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed') Feb 06 07:14:04 deb NetworkManager[1189]: <info> [1675664044.0607] dhcp4 (enp4s0): canceled DHCP transaction Feb 06 07:19:04 deb NetworkManager[1189]: <info> [1675664344.0574] policy: auto-activating connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 07:19:04 deb NetworkManager[1189]: <info> [1675664344.0579] device (enp4s0): Activation: starting connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 07:19:04 deb NetworkManager[1189]: <info> [1675664344.0580] device (enp4s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed') Feb 06 07:19:04 deb NetworkManager[1189]: <info> [1675664344.0582] device (enp4s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed') Feb 06 07:19:04 deb NetworkManager[1189]: <info> [1675664344.0591] device (enp4s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed') Feb 06 07:19:04 deb NetworkManager[1189]: <info> [1675664344.0605] dhcp4 (enp4s0): activation: beginning transaction (timeout in 45 seconds) Feb 06 07:19:49 deb NetworkManager[1189]: <info> [1675664389.0566] device (enp4s0): state change: ip-config -> failed (reason 'ip-config-unavailable', sys-iface-state: 'managed') Feb 06 07:19:49 deb NetworkManager[1189]: <warn> [1675664389.0570] device (enp4s0): Activation: failed for connection 'Wired connection 1' Feb 06 07:19:49 deb NetworkManager[1189]: <info> [1675664389.0572] device (enp4s0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed') Feb 06 07:19:49 deb NetworkManager[1189]: <info> [1675664389.0605] dhcp4 (enp4s0): canceled DHCP transaction Feb 06 07:19:49 deb NetworkManager[1189]: <info> [1675664389.0615] policy: auto-activating connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 07:19:49 deb NetworkManager[1189]: <info> [1675664389.0618] device (enp4s0): Activation: starting connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 07:19:49 deb NetworkManager[1189]: <info> [1675664389.0618] device (enp4s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed') Feb 06 07:19:49 deb NetworkManager[1189]: <info> [1675664389.0619] device (enp4s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed') Feb 06 07:19:49 deb NetworkManager[1189]: <info> [1675664389.0627] device (enp4s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed') Feb 06 07:19:49 deb NetworkManager[1189]: <info> [1675664389.0638] dhcp4 (enp4s0): activation: beginning transaction (timeout in 45 seconds) Feb 06 07:20:34 deb NetworkManager[1189]: <info> [1675664434.0573] device (enp4s0): state change: ip-config -> failed (reason 'ip-config-unavailable', sys-iface-state: 'managed') Feb 06 07:20:34 deb NetworkManager[1189]: <warn> [1675664434.0576] device (enp4s0): Activation: failed for connection 'Wired connection 1' Feb 06 07:20:34 deb NetworkManager[1189]: <info> [1675664434.0577] device (enp4s0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed') Feb 06 07:20:34 deb NetworkManager[1189]: <info> [1675664434.0608] dhcp4 (enp4s0): canceled DHCP transaction Feb 06 07:20:34 deb NetworkManager[1189]: <info> [1675664434.0622] policy: auto-activating connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 07:20:34 deb NetworkManager[1189]: <info> [1675664434.0627] device (enp4s0): Activation: starting connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 07:20:34 deb NetworkManager[1189]: <info> [1675664434.0628] device (enp4s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed') Feb 06 07:20:34 deb NetworkManager[1189]: <info> [1675664434.0631] device (enp4s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed') Feb 06 07:20:34 deb NetworkManager[1189]: <info> [1675664434.0642] device (enp4s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed') Feb 06 07:20:34 deb NetworkManager[1189]: <info> [1675664434.0656] dhcp4 (enp4s0): activation: beginning transaction (timeout in 45 seconds) Feb 06 07:21:19 deb NetworkManager[1189]: <info> [1675664479.0566] device (enp4s0): state change: ip-config -> failed (reason 'ip-config-unavailable', sys-iface-state: 'managed') Feb 06 07:21:19 deb NetworkManager[1189]: <warn> [1675664479.0570] device (enp4s0): Activation: failed for connection 'Wired connection 1' Feb 06 07:21:19 deb NetworkManager[1189]: <info> [1675664479.0571] device (enp4s0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed') Feb 06 07:21:19 deb NetworkManager[1189]: <info> [1675664479.0838] dhcp4 (enp4s0): canceled DHCP transaction Feb 06 07:21:19 deb NetworkManager[1189]: <info> [1675664479.0846] policy: auto-activating connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 07:21:19 deb NetworkManager[1189]: <info> [1675664479.0848] device (enp4s0): Activation: starting connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 07:21:19 deb NetworkManager[1189]: <info> [1675664479.0848] device (enp4s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed') Feb 06 07:21:19 deb NetworkManager[1189]: <info> [1675664479.0850] device (enp4s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed') Feb 06 07:21:19 deb NetworkManager[1189]: <info> [1675664479.0857] device (enp4s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed') Feb 06 07:21:19 deb NetworkManager[1189]: <info> [1675664479.0868] dhcp4 (enp4s0): activation: beginning transaction (timeout in 45 seconds) Feb 06 07:22:04 deb NetworkManager[1189]: <info> [1675664524.0572] device (enp4s0): state change: ip-config -> failed (reason 'ip-config-unavailable', sys-iface-state: 'managed') Feb 06 07:22:04 deb NetworkManager[1189]: <warn> [1675664524.0575] device (enp4s0): Activation: failed for connection 'Wired connection 1' Feb 06 07:22:04 deb NetworkManager[1189]: <info> [1675664524.0576] device (enp4s0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed') Feb 06 07:22:04 deb NetworkManager[1189]: <info> [1675664524.0918] dhcp4 (enp4s0): canceled DHCP transaction Feb 06 07:24:19 deb NetworkManager[1189]: <info> [1675664659.1684] dhcp4 (wlx10bf485b893c): state changed new lease, address=192.168.150.55 Feb 06 07:25:13 deb NetworkManager[1189]: <info> [1675664713.0818] audit: op="statistics" interface="wlx10bf485b893c" ifindex=3 args="2000" pid=2293 uid=1000 result="success" Feb 06 07:25:13 deb NetworkManager[1189]: <info> [1675664713.0838] audit: op="statistics" interface="wlx10bf485b893c" ifindex=3 args="500" pid=2422 uid=1000 result="success" Feb 06 07:25:16 deb NetworkManager[1189]: <info> [1675664716.3925] device (enp4s0): Activation: starting connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 07:25:16 deb NetworkManager[1189]: <info> [1675664716.3925] audit: op="connection-activate" uuid="4e387eb2-fafa-3c7c-95a7-cc67067748e6" name="Wired connection 1" pid=2293 uid=1000 result="success" Feb 06 07:25:16 deb NetworkManager[1189]: <info> [1675664716.3925] device (enp4s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed') Feb 06 07:25:16 deb NetworkManager[1189]: <info> [1675664716.3927] device (enp4s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed') Feb 06 07:25:16 deb NetworkManager[1189]: <info> [1675664716.3934] device (enp4s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed') Feb 06 07:25:16 deb NetworkManager[1189]: <info> [1675664716.3944] dhcp4 (enp4s0): activation: beginning transaction (timeout in 45 seconds) Feb 06 07:25:32 deb NetworkManager[1189]: <info> [1675664732.5187] audit: op="statistics" interface="wlx10bf485b893c" ifindex=3 args="0" pid=2293 uid=1000 result="success" Feb 06 07:25:32 deb NetworkManager[1189]: <info> [1675664732.5213] audit: op="statistics" interface="wlx10bf485b893c" ifindex=3 args="500" pid=2422 uid=1000 result="success" Feb 06 07:26:02 deb NetworkManager[1189]: <info> [1675664762.0567] device (enp4s0): state change: ip-config -> failed (reason 'ip-config-unavailable', sys-iface-state: 'managed') Feb 06 07:26:02 deb NetworkManager[1189]: <warn> [1675664762.0571] device (enp4s0): Activation: failed for connection 'Wired connection 1' Feb 06 07:26:02 deb NetworkManager[1189]: <info> [1675664762.0573] device (enp4s0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed') Feb 06 07:26:02 deb NetworkManager[1189]: <info> [1675664762.0602] dhcp4 (enp4s0): canceled DHCP transaction Feb 06 07:27:04 deb NetworkManager[1189]: <info> [1675664824.0565] policy: auto-activating connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 07:27:04 deb NetworkManager[1189]: <info> [1675664824.0569] device (enp4s0): Activation: starting connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 07:27:04 deb NetworkManager[1189]: <info> [1675664824.0570] device (enp4s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed') Feb 06 07:27:04 deb NetworkManager[1189]: <info> [1675664824.0573] device (enp4s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed') Feb 06 07:27:04 deb NetworkManager[1189]: <info> [1675664824.0581] device (enp4s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed') Feb 06 07:27:04 deb NetworkManager[1189]: <info> [1675664824.0594] dhcp4 (enp4s0): activation: beginning transaction (timeout in 45 seconds) Feb 06 07:27:28 deb NetworkManager[1189]: <info> [1675664848.9544] audit: op="statistics" interface="wlx10bf485b893c" ifindex=3 args="2000" pid=2293 uid=1000 result="success" Feb 06 07:27:28 deb NetworkManager[1189]: <info> [1675664848.9572] audit: op="statistics" interface="wlx10bf485b893c" ifindex=3 args="500" pid=2422 uid=1000 result="success" Feb 06 07:27:45 deb NetworkManager[1189]: <info> [1675664865.9593] audit: op="statistics" interface="wlx10bf485b893c" ifindex=3 args="0" pid=2293 uid=1000 result="success" Feb 06 07:27:45 deb NetworkManager[1189]: <info> [1675664865.9619] audit: op="statistics" interface="wlx10bf485b893c" ifindex=3 args="500" pid=2422 uid=1000 result="success" Feb 06 07:27:49 deb NetworkManager[1189]: <info> [1675664869.0570] device (enp4s0): state change: ip-config -> failed (reason 'ip-config-unavailable', sys-iface-state: 'managed') Feb 06 07:27:49 deb NetworkManager[1189]: <warn> [1675664869.0572] device (enp4s0): Activation: failed for connection 'Wired connection 1' Feb 06 07:27:49 deb NetworkManager[1189]: <info> [1675664869.0573] device (enp4s0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed') Feb 06 07:27:49 deb NetworkManager[1189]: <info> [1675664869.0918] dhcp4 (enp4s0): canceled DHCP transaction Feb 06 07:27:49 deb NetworkManager[1189]: <info> [1675664869.0928] policy: auto-activating connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 07:27:49 deb NetworkManager[1189]: <info> [1675664869.0931] device (enp4s0): Activation: starting connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 07:27:49 deb NetworkManager[1189]: <info> [1675664869.0932] device (enp4s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed') Feb 06 07:27:49 deb NetworkManager[1189]: <info> [1675664869.0933] device (enp4s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed') Feb 06 07:27:49 deb NetworkManager[1189]: <info> [1675664869.0937] device (enp4s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed') Feb 06 07:27:49 deb NetworkManager[1189]: <info> [1675664869.0940] dhcp4 (enp4s0): activation: beginning transaction (timeout in 45 seconds) Feb 06 07:28:34 deb NetworkManager[1189]: <info> [1675664914.0563] device (enp4s0): state change: ip-config -> failed (reason 'ip-config-unavailable', sys-iface-state: 'managed') Feb 06 07:28:34 deb NetworkManager[1189]: <warn> [1675664914.0566] device (enp4s0): Activation: failed for connection 'Wired connection 1' Feb 06 07:28:34 deb NetworkManager[1189]: <info> [1675664914.0567] device (enp4s0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed') Feb 06 07:28:34 deb NetworkManager[1189]: <info> [1675664914.0878] dhcp4 (enp4s0): canceled DHCP transaction Feb 06 07:28:34 deb NetworkManager[1189]: <info> [1675664914.0884] policy: auto-activating connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 07:28:34 deb NetworkManager[1189]: <info> [1675664914.0886] device (enp4s0): Activation: starting connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 07:28:34 deb NetworkManager[1189]: <info> [1675664914.0887] device (enp4s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed') Feb 06 07:28:34 deb NetworkManager[1189]: <info> [1675664914.0888] device (enp4s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed') Feb 06 07:28:34 deb NetworkManager[1189]: <info> [1675664914.0892] device (enp4s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed') Feb 06 07:28:34 deb NetworkManager[1189]: <info> [1675664914.0895] dhcp4 (enp4s0): activation: beginning transaction (timeout in 45 seconds) Feb 06 07:29:19 deb NetworkManager[1189]: <info> [1675664959.0570] device (enp4s0): state change: ip-config -> failed (reason 'ip-config-unavailable', sys-iface-state: 'managed') Feb 06 07:29:19 deb NetworkManager[1189]: <warn> [1675664959.0573] device (enp4s0): Activation: failed for connection 'Wired connection 1' Feb 06 07:29:19 deb NetworkManager[1189]: <info> [1675664959.0573] device (enp4s0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed') Feb 06 07:29:19 deb NetworkManager[1189]: <info> [1675664959.0581] dhcp4 (enp4s0): canceled DHCP transaction Feb 06 07:29:19 deb NetworkManager[1189]: <info> [1675664959.0590] policy: auto-activating connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 07:29:19 deb NetworkManager[1189]: <info> [1675664959.0592] device (enp4s0): Activation: starting connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 07:29:19 deb NetworkManager[1189]: <info> [1675664959.0592] device (enp4s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed') Feb 06 07:29:19 deb NetworkManager[1189]: <info> [1675664959.0594] device (enp4s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed') Feb 06 07:29:19 deb NetworkManager[1189]: <info> [1675664959.0597] device (enp4s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed') Feb 06 07:29:19 deb NetworkManager[1189]: <info> [1675664959.0600] dhcp4 (enp4s0): activation: beginning transaction (timeout in 45 seconds) Feb 06 07:30:04 deb NetworkManager[1189]: <info> [1675665004.0573] device (enp4s0): state change: ip-config -> failed (reason 'ip-config-unavailable', sys-iface-state: 'managed') Feb 06 07:30:04 deb NetworkManager[1189]: <warn> [1675665004.0576] device (enp4s0): Activation: failed for connection 'Wired connection 1' Feb 06 07:30:04 deb NetworkManager[1189]: <info> [1675665004.0577] device (enp4s0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed') Feb 06 07:30:04 deb NetworkManager[1189]: <info> [1675665004.0585] dhcp4 (enp4s0): canceled DHCP transaction Feb 06 07:34:15 deb NetworkManager[1189]: <info> [1675665255.7643] audit: op="statistics" interface="wlx10bf485b893c" ifindex=3 args="2000" pid=2293 uid=1000 result="success" Feb 06 07:34:15 deb NetworkManager[1189]: <info> [1675665255.7666] audit: op="statistics" interface="wlx10bf485b893c" ifindex=3 args="500" pid=2422 uid=1000 result="success" Feb 06 07:34:18 deb NetworkManager[1189]: <info> [1675665258.0425] device (enp4s0): Activation: starting connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 07:34:18 deb NetworkManager[1189]: <info> [1675665258.0426] audit: op="connection-activate" uuid="4e387eb2-fafa-3c7c-95a7-cc67067748e6" name="Wired connection 1" pid=2293 uid=1000 result="success" Feb 06 07:34:18 deb NetworkManager[1189]: <info> [1675665258.0427] device (enp4s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed') Feb 06 07:34:18 deb NetworkManager[1189]: <info> [1675665258.0430] device (enp4s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed') Feb 06 07:34:18 deb NetworkManager[1189]: <info> [1675665258.0435] device (enp4s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed') Feb 06 07:34:18 deb NetworkManager[1189]: <info> [1675665258.0442] dhcp4 (enp4s0): activation: beginning transaction (timeout in 45 seconds) Feb 06 07:34:19 deb NetworkManager[1189]: <info> [1675665259.4595] audit: op="statistics" interface="wlx10bf485b893c" ifindex=3 args="0" pid=2293 uid=1000 result="success" Feb 06 07:34:19 deb NetworkManager[1189]: <info> [1675665259.4612] audit: op="statistics" interface="wlx10bf485b893c" ifindex=3 args="500" pid=2422 uid=1000 result="success" Feb 06 07:35:03 deb NetworkManager[1189]: <info> [1675665303.0569] device (enp4s0): state change: ip-config -> failed (reason 'ip-config-unavailable', sys-iface-state: 'managed') Feb 06 07:35:03 deb NetworkManager[1189]: <warn> [1675665303.0573] device (enp4s0): Activation: failed for connection 'Wired connection 1' Feb 06 07:35:03 deb NetworkManager[1189]: <info> [1675665303.0575] device (enp4s0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed') Feb 06 07:35:03 deb NetworkManager[1189]: <info> [1675665303.0918] dhcp4 (enp4s0): canceled DHCP transaction Feb 06 07:35:04 deb NetworkManager[1189]: <info> [1675665304.0570] policy: auto-activating connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 07:35:04 deb NetworkManager[1189]: <info> [1675665304.0574] device (enp4s0): Activation: starting connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 07:35:04 deb NetworkManager[1189]: <info> [1675665304.0575] device (enp4s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed') Feb 06 07:35:04 deb NetworkManager[1189]: <info> [1675665304.0578] device (enp4s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed') Feb 06 07:35:04 deb NetworkManager[1189]: <info> [1675665304.0584] device (enp4s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed') Feb 06 07:35:04 deb NetworkManager[1189]: <info> [1675665304.0588] dhcp4 (enp4s0): activation: beginning transaction (timeout in 45 seconds) Feb 06 07:35:49 deb NetworkManager[1189]: <info> [1675665349.0567] device (enp4s0): state change: ip-config -> failed (reason 'ip-config-unavailable', sys-iface-state: 'managed') Feb 06 07:35:49 deb NetworkManager[1189]: <warn> [1675665349.0570] device (enp4s0): Activation: failed for connection 'Wired connection 1' Feb 06 07:35:49 deb NetworkManager[1189]: <info> [1675665349.0571] device (enp4s0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed') Feb 06 07:35:49 deb NetworkManager[1189]: <info> [1675665349.0758] dhcp4 (enp4s0): canceled DHCP transaction Feb 06 07:35:49 deb NetworkManager[1189]: <info> [1675665349.0765] policy: auto-activating connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 07:35:49 deb NetworkManager[1189]: <info> [1675665349.0768] device (enp4s0): Activation: starting connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 07:35:49 deb NetworkManager[1189]: <info> [1675665349.0768] device (enp4s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed') Feb 06 07:35:49 deb NetworkManager[1189]: <info> [1675665349.0770] device (enp4s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed') Feb 06 07:35:49 deb NetworkManager[1189]: <info> [1675665349.0774] device (enp4s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed') Feb 06 07:35:49 deb NetworkManager[1189]: <info> [1675665349.0776] dhcp4 (enp4s0): activation: beginning transaction (timeout in 45 seconds) Feb 06 07:36:34 deb NetworkManager[1189]: <info> [1675665394.0564] device (enp4s0): state change: ip-config -> failed (reason 'ip-config-unavailable', sys-iface-state: 'managed') Feb 06 07:36:34 deb NetworkManager[1189]: <warn> [1675665394.0567] device (enp4s0): Activation: failed for connection 'Wired connection 1' Feb 06 07:36:34 deb NetworkManager[1189]: <info> [1675665394.0568] device (enp4s0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed') Feb 06 07:36:34 deb NetworkManager[1189]: <info> [1675665394.0838] dhcp4 (enp4s0): canceled DHCP transaction Feb 06 07:36:34 deb NetworkManager[1189]: <info> [1675665394.0844] policy: auto-activating connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 07:36:34 deb NetworkManager[1189]: <info> [1675665394.0846] device (enp4s0): Activation: starting connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 07:36:34 deb NetworkManager[1189]: <info> [1675665394.0847] device (enp4s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed') Feb 06 07:36:34 deb NetworkManager[1189]: <info> [1675665394.0848] device (enp4s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed') Feb 06 07:36:34 deb NetworkManager[1189]: <info> [1675665394.0852] device (enp4s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed') Feb 06 07:36:34 deb NetworkManager[1189]: <info> [1675665394.0854] dhcp4 (enp4s0): activation: beginning transaction (timeout in 45 seconds) Feb 06 07:37:19 deb NetworkManager[1189]: <info> [1675665439.0571] device (enp4s0): state change: ip-config -> failed (reason 'ip-config-unavailable', sys-iface-state: 'managed') Feb 06 07:37:19 deb NetworkManager[1189]: <warn> [1675665439.0574] device (enp4s0): Activation: failed for connection 'Wired connection 1' Feb 06 07:37:19 deb NetworkManager[1189]: <info> [1675665439.0576] device (enp4s0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed') Feb 06 07:37:19 deb NetworkManager[1189]: <info> [1675665439.1038] dhcp4 (enp4s0): canceled DHCP transaction Feb 06 07:37:19 deb NetworkManager[1189]: <info> [1675665439.1046] policy: auto-activating connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 07:37:19 deb NetworkManager[1189]: <info> [1675665439.1049] device (enp4s0): Activation: starting connection 'Wired connection 1' (4e387eb2-fafa-3c7c-95a7-cc67067748e6) Feb 06 07:37:19 deb NetworkManager[1189]: <info> [1675665439.1049] device (enp4s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed') Feb 06 07:37:19 deb NetworkManager[1189]: <info> [1675665439.1051] device (enp4s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed') Feb 06 07:37:19 deb NetworkManager[1189]: <info> [1675665439.1054] device (enp4s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed') Feb 06 07:37:19 deb NetworkManager[1189]: <info> [1675665439.1058] dhcp4 (enp4s0): activation: beginning transaction (timeout in 45 seconds) Feb 06 07:38:04 deb NetworkManager[1189]: <info> [1675665484.0570] device (enp4s0): state change: ip-config -> failed (reason 'ip-config-unavailable', sys-iface-state: 'managed') Feb 06 07:38:04 deb NetworkManager[1189]: <warn> [1675665484.0574] device (enp4s0): Activation: failed for connection 'Wired connection 1' Feb 06 07:38:04 deb NetworkManager[1189]: <info> [1675665484.0576] device (enp4s0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed') Feb 06 07:38:04 deb NetworkManager[1189]: <info> [1675665484.0958] dhcp4 (enp4s0): canceled DHCP transaction
Hat jemand eine Idee warum das nicht funktioniert?
LG.
