Hi,
ich möchte das im Container "<div class="row mt-5 mb-2" id="informations">" die Kundennummer anzeigt wird. Leider erscheint Sie nicht. Überall im Formular funktioniert es, nur in diesem einen Container nicht. Warum? Die Kundennummer soll unter Salesperson genau erscheinen.
<t t-name="sale.report_saleorder_document">
<t t-call="web.external_layout">
<t t-set="doc" t-value="doc.with_context(lang=doc.partner_id.lang)"/>
<t t-set="forced_vat" t-value="doc.fiscal_position_id.foreign_vat"/> <!-- So that it appears in the footer of the report instead of the company VAT if it's set -->
<t t-set="address">
<div class="address">
<div t-field="doc.partner_id" t-options="{"widget": "contact", "fields": ["address", "name"], "no_marker": True}"/>
</div>
</t>
<p/>
<p/>
<p/>
<p/>
<div style="text-align: right;">
<strong>Kundennummer:</strong>
<span t-field="doc.partner_id.ref">1692</span>
</div>
<div class="page">
<div class="oe_structure"/>
<h2 class="mt-4">
<span t-if="env.context.get('proforma', False) or is_pro_forma">Pro-Forma Invoice # </span>
<span t-elif="doc.state in ['draft','sent']">Quotation # </span>
<span t-else="">Order # </span>
<span t-field="doc.name">SO0000</span>
</h2>
<span>Debug vor Container: </span>
<span t-esc="doc.partner_id.ref"/>
<div t-if="doc.client_order_ref" class="col-auto col-3 mw-100 mb-2" name="informations_reference">
<strong>Your Reference:</strong><br/>
<span class="m-0" t-field="doc.client_order_ref">SO0000</span>
</div>
<div class="IhrContainer">
<span>Debug im Container: </span>
<!-- Ihre bestehenden Container-Elemente -->
</div>
<div t-esc="doc.date_order" class="col-auto col-3 mw-100 mb-2" name="informations_date">
<strong t-if="doc.state in ['draft', 'sent']">Quotation Date:</strong>
<strong t-else="">Order Date:</strong><br/>
<span class="m-0" t-field="doc.date_order" t-options="{"widget": "date"}">2023-12-31</span>
</div>
<div t-esc="doc.validity_date and doc.state in ['draft', 'sent']" class="col-auto col-3 mw-100 mb-2" name="expiration_date">
<strong>Expiration:</strong><br/>
<span class="m-0" t-field="doc.validity_date">2023-12-31</span>
</div>
<div t-esc="doc.user_id.name" class="col-auto col-6 mw-100 mb-2">
<strong>Salesperson:</strong><br/>
<span class="m-0" t-field="doc.user_id">Mitchell Admin</span>
</div>
<div class="col-md-6 mb-2 text-right">
<strong>Kundennummer:</strong><br/>
<span class="m-0" t-field="doc.partner_id.ref">1692</span>
</div>
<div class="col-12 mb-3">
</div>
<div>
<span>Debug doc.partner_id.ref: </span>
</div>
</div>
<div>
<span>Test Kundennummer: </span>
</div>
<!-- Is there a discount on at least one line? -->
<t t-set="lines_to_report" t-value="doc._get_order_lines_to_report()"/>
<t t-set="display_discount" t-value="any(l.discount for l in lines_to_report)"/>
<table class="table table-sm o_main_table table-borderless mt-4">
<!-- In case we want to repeat the header, remove "display: table-row-group" -->
<thead style="display: table-row-group">
<tr>
<th name="th_description" class="text-start">Description</th>
<th name="th_quantity" class="text-end">Quantity</th>
<th name="th_priceunit" class="text-end">Unit Price</th>
<th name="th_discount" t-if="display_discount" class="text-end">
<span>Disc.%</span>
</th>
<th name="th_taxes" class="text-end">Taxes</th>
<th name="th_subtotal" class="text-end">
<span>Tax excl.</span>
</th>
<th t-if="doc.company_id.tax_calculation_rounding_method == 'round_per_line'" name="th_total" class="text-end">
<span>Tax incl.</span>
</th>
</tr>
</thead>
<tbody class="sale_tbody">
<t t-set="current_subtotal" t-value="0"/>
<t t-foreach="lines_to_report" t-as="line">
<t t-set="current_subtotal" t-value="current_subtotal + line.price_subtotal"/>
<t t-set="current_total" t-value="current_subtotal + line.price_total" t-if="doc.company_id.tax_calculation_rounding_method == 'round_per_line'"/>
<tr t-att-class="'bg-200 fw-bold o_line_section' if line.display_type == 'line_section' else 'fst-italic o_line_note' if line.display_type == 'line_note' else ''">
<t t-if="not line.display_type">
<td name="td_name"><span t-field="line.name">Bacon Burger</span></td>
<td name="td_quantity" class="text-end">
<span t-field="line.product_uom_qty">3</span>
<span t-field="line.product_uom">units</span>
</td>
<td name="td_priceunit" class="text-end">
<span t-field="line.price_unit">3</span>
</td>
<td t-if="display_discount" class="text-end">
<span t-field="line.discount">-</span>
</td>
<td name="td_taxes" class="text-end">
<span t-out="', '.join(map(lambda x: (x.description or x.name), line.tax_id))">
Tax 15%
</span>
</td>
<td t-if="not line.is_downpayment" name="td_subtotal" class="text-end o_price_total">
<span t-field="line.price_subtotal">27.00</span>
</td>
<td name="td_total" class="text-end o_price_total" t-if="doc.company_id.tax_calculation_rounding_method == 'round_per_line'">
<span t-field="line.price_total">31.05</span>
</td>
</t>
<t t-elif="line.display_type == 'line_section'">
<td name="td_section_line" colspan="99">
<span t-field="line.name">A section title</span>
</td>
<t t-set="current_section" t-value="line"/>
</t>
<t t-elif="line.display_type == 'line_note'">
<td name="td_note_line" colspan="99">
<span t-field="line.name">A note, whose content usually applies to the section or product above.</span>
</td>
</t>
</tr>
<t t-if="current_section and (line_last or doc.order_line[line_index+1].display_type == 'line_section') and not line.is_downpayment">
<tr class="is-subtotal text-end">
<td name="td_section_subtotal" colspan="99">
<strong class="mr16">Subtotal</strong>
<span t-out="current_subtotal" t-options="{"widget": "monetary", "display_currency": doc.currency_id}">31.05</span>
</td>
</tr>
</t>
</t>
</tbody>
</table>
<div class="clearfix" name="so_total_summary">
<div id="total" class="row" name="total">
<div t-attf-class="#{'col-6' if report_type != 'html' else 'col-sm-7 col-md-6'} ms-auto">
<table class="table table-sm table-borderless">
<!-- Tax totals -->
<t t-set="tax_totals" t-value="doc.tax_totals"/>
<t t-call="sale.document_tax_totals"/>
</table>
</div>
</div>
</div>
<div t-if="not doc.signature" class="oe_structure"/>
<div t-else="" class="mt-4 ml64 mr4" name="signature">
<div class="offset-8">
<strong>Signature</strong>
</div>
<img t-att-src="image_data_uri(doc.signature)" style="max-height: 4cm; max-width: 8cm;"/>
</div>
<div class="offset-8 text-center">
<span t-field="doc.signed_by">Oscar Morgan</span>
</div>
</div>
<div>
<span t-field="doc.note" name="order_note"/>
<p t-if="not is_html_empty(doc.payment_term_id.note)">
<span t-field="doc.payment_term_id.note">The payment should also be transmitted with love</span>
</p>
<p t-if="doc.fiscal_position_id and not is_html_empty(doc.fiscal_position_id.sudo().note)" id="fiscal_position_remark">
<strong>Fiscal Position Remark:</strong>
<span t-field="doc.fiscal_position_id.sudo().note">No further requirements for this payment</span>
</p>
</div>
</div>
</t>
</t>
