jetzt versuche ich hier mal mein Glück.
Ich möchte iSCSI via Kubernetes in einen Container zu bringen, was leider nicht wie erwartet funktioniert.
$ kubectl describe pod iscsi-web Name: iscsi-web Namespace: default Node: k2/192.168.253.52 Start Time: Fri, 22 Jun 2018 09:26:14 +0200 Labels: <none> Annotations: <none> Status: Pending IP: Containers: web: Container ID: Image: nginx Image ID: Port: <none> Host Port: <none> State: Waiting Reason: ContainerCreating Ready: False Restart Count: 0 Environment: <none> Mounts: /usr/share/nginx/html from www (rw) /var/run/secrets/kubernetes.io/serviceaccount from default-token-tccr2 (ro) Conditions: Type Status Initialized True Ready False PodScheduled True Volumes: www: Type: ISCSI (an ISCSI Disk resource that is attached to a kubelet's host machine and then exposed to the pod) TargetPortal: 172.9.10.254:3260 IQN: iqn.2004-04.com.qnap:ts-212:iscsi.mbr.d55afc Lun: 0 ISCSIInterface default FSType: ext4 ReadOnly: false Portals: [] DiscoveryCHAPAuth: false SessionCHAPAuth: false SecretRef: <nil> InitiatorName: <none> default-token-tccr2: Type: Secret (a volume populated by a Secret) SecretName: default-token-tccr2 Optional: false QoS Class: BestEffort Node-Selectors: <none> Tolerations: node.kubernetes.io/not-ready:NoExecute for 300s node.kubernetes.io/unreachable:NoExecute for 300s Events: Type Reason Age From Message ---- ------ ---- ---- ------- Normal Scheduled 2m default-scheduler Successfully assigned iscsi-web to k2 Normal SuccessfulAttachVolume 2m attachdetach-controller AttachVolume.Attach succeeded for volume "www" Normal SuccessfulMountVolume 2m kubelet, k2 MountVolume.SetUp succeeded for volume "default-token-tccr2" Warning FailedMount 32s kubelet, k2 Unable to mount volumes for pod "iscsi-web_default(8bb6a069-75ed-11e8-9e95-000c2965b974)": timeout expired waiting for volumes to attach or mount for pod "default"/"iscsi-web". list of unmounted volumes=[www]. list of unattached volumes=[www default-token-tccr2] Warning FailedMount 1s (x7 over 32s) kubelet, k2 MountVolume.WaitForAttach failed for volume "www" : executable file not found in $PATH
Wenn ich das richtig verstehe, funktioniert die iSCSI-connection, aber das anschließende mounten in den Container nicht.
Hier mein yml-File:
$ cat iscsi.yml apiVersion: v1 kind: Pod metadata: name: iscsi-web spec: volumes: - name: www iscsi: targetPortal: "172.9.10.254:3260" iqn: "iqn.2004-04.com.qnap:ts-212:iscsi.mbr.d55afc" lun: 0 fsType: ext4 readOnly: false containers: - name: web image: nginx volumeMounts: - mountPath: "/usr/share/nginx/html" name: www
Gruß BillMaier
