Hallo zusammen, ich habe heute versucht meinen USB Dongle WLAN Adapter von 7Links in Betrieb zu nehemn. Leider ohne Erfolg. Info über das Produkt: https://www.7links.me/USB-3-0-WiFiAC-1200-PX-3753-919.shtml#faqs
Kann mir(noob) jemand helfen? Ich habe wie gewünscht euch sämtliche Informationen hier reinkopiert.
Danke euch schon im Voraus für die Hilfe
Gruss Goofy
goofy@goofy-HPE-440ch:~$ uname -a Linux goofy-HPE-440ch 4.15.0-32-generic #35-Ubuntu SMP Fri Aug 10 17:58:07 UTC 2018 x86_64 x86_64 x86_64 GNU/Linux
goofy@goofy-HPE-440ch:~$ lsusb Bus 002 Device 003: ID 0bda:0151 Realtek Semiconductor Corp. Mass Storage Device (Multicard Reader) Bus 002 Device 002: ID 8087:0020 Intel Corp. Integrated Rate Matching Hub Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub Bus 003 Device 002: ID 0bda:8812 Realtek Semiconductor Corp. RTL8812AU 802.11a/b/g/n/ac WLAN Adapter Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 001 Device 009: ID 13fd:2040 Initio Corporation Bus 001 Device 007: ID 05e3:0608 Genesys Logic, Inc. Hub Bus 001 Device 006: ID 05e3:0608 Genesys Logic, Inc. Hub Bus 001 Device 005: ID 03f0:0862 Hewlett-Packard Bus 001 Device 004: ID 05e3:0608 Genesys Logic, Inc. Hub Bus 001 Device 003: ID 2040:d300 Hauppauge Bus 001 Device 002: ID 8087:0020 Intel Corp. Integrated Rate Matching Hub Bus 001 Device 001: ID 1d6b:0002 Linux Foundat 2.0 root hub
goofy@goofy-HPE-440ch:~$ cat /etc/network/interfaces # interfaces(5) file used by ifup(8) and ifdown(8) auto lo iface lo inet loopback
goofy@goofy-HPE-440ch:~$ cat /etc/resolv.conf # This file is managed by man:systemd-resolved(8). Do not edit. # # This is a dynamic resolv.conf file for connecting local clients to the # internal DNS stub resolver of systemd-resolved. This file lists all # configured search domains. # # Run "systemd-resolve --status" to see details about the uplink DNS servers # currently in use. # # Third party programs must not access this file directly, but only through the # symlink at /etc/resolv.conf. To manage man:resolv.conf(5) in a different way, # replace this symlink by a static file or a different symlink. # # See man:systemd-resolved.service(8) for details about the supported modes of # operation for /etc/resolv.conf. nameserver 127.0.0.53 search home
goofy@goofy-HPE-440ch:~$ cat /etc/hosts 127.0.0.1 localhost 127.0.1.1 goofy-HPE-440ch # The following lines are desirable for IPv6 capable hosts ::1 ip6-localhost ip6-loopback fe00::0 ip6-localnet ff00::0 ip6-mcastprefix ff02::1 ip6-allnodes ff02::2 ip6-allrouters
goofy@goofy-HPE-440ch:~$ ifconfig -a enp2s0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500 ether 6c:62:6d:7e:4b:9c txqueuelen 1000 (Ethernet) RX packets 0 bytes 0 (0.0 B) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 0 bytes 0 (0.0 B) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536 inet 127.0.0.1 netmask 255.0.0.0 inet6 ::1 prefixlen 128 scopeid 0x10<host> loop txqueuelen 1000 (Lokale Schleife) RX packets 1254 bytes 110110 (110.1 KB) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 1254 bytes 110110 (110.1 KB) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 wlp5s0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500 inet 192.168.0.229 netmask 255.255.255.0 broadcast 192.168.0.255 inet6 fe80::eba6:8bea:6c72:8ea0 prefixlen 64 scopeid 0x20<link> ether 1c:65:9d:98:e2:73 txqueuelen 1000 (Ethernet) RX packets 19463 bytes 17871518 (17.8 MB) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 12309 bytes 1712314 (1.7 MB) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
goofy@goofy-HPE-440ch:~$ iwconfig enp2s0 no wireless extensions. wlp5s0 IEEE 802.11 ESSID:"UPCD77DC9F" Mode:Managed Frequency:2.412 GHz Access Point: D8:B6:B7:3C:0F:EC Bit Rate=57.8 Mb/s Tx-Power=20 dBm Retry short long limit:2 RTS thr:off Fragment thr:off Power Management:on Link Quality=61/70 Signal level=-49 dBm Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0 Tx excessive retries:11 Invalid misc:9 Missed beacon:0 lo no wireless extensions.
goofy@goofy-HPE-440ch:~$ route -n Kernel-IP-Routentabelle Ziel Router Genmask Flags Metric Ref Use Iface 0.0.0.0 192.168.0.1 0.0.0.0 UG 600 0 0 wlp5s0 192.168.0.0 0.0.0.0 255.255.255.0 U 600 0 0 wlp5s0
goofy@goofy-HPE-440ch:~$ arp -av upc-ap.home (192.168.0.157) auf d8:b6:b7:3c:0f:e9 [ether] auf wlp5s0 _gateway (192.168.0.1) auf ac:22:05:d0:0b:ba [ether] auf wlp5s0 Einträge: 2 Ignoriert: 0 Gefunden: 2
goofy@goofy-HPE-440ch:~$ ip neigh show 192.168.0.157 dev wlp5s0 lladdr d8:b6:b7:3c:0f:e9 STALE 192.168.0.1 dev wlp5s0 lladdr ac:22:05:d0:0b:ba REACHABLE
goofy@goofy-HPE-440ch:~$ cat /var/lib/NetworkManager/NetworkManager.state [main] NetworkingEnabled=true WirelessEnabled=true WWANEnabled=true
goofy@goofy-HPE-440ch:~$ cat /etc/NetworkManager/NetworkManager.conf [main] plugins=ifupdown,keyfile [ifupdown] managed=false [device] wifi.scan-rand-mac-address=no
goofy@goofy-HPE-440ch:~$ cat /etc/udev/rules.d/70-persistent-net.rules | egrep -i 'device|sub' -A3 cat: /etc/udev/rules.d/70-persistent-net.rules: Datei oder Verzeichnis nicht gefunden
goofy@goofy-HPE-440ch:~$ ping -c 2 $(route -n | grep UG | awk {'print $2'}) PING 192.168.0.1 (192.168.0.1) 56(84) bytes of data. 64 bytes from 192.168.0.1: icmp_seq=1 ttl=64 time=24.0 ms 64 bytes from 192.168.0.1: icmp_seq=2 ttl=64 time=2.52 ms --- 192.168.0.1 ping statistics --- 2 packets transmitted, 2 received, 0% packet loss, time 1001ms rtt min/avg/max/mdev = 2.522/13.276/24.030/10.754 ms
goofy@goofy-HPE-440ch:~$ ping -c 2 www.ubuntuusers.de PING ubuntuusers.de (213.95.41.4) 56(84) bytes of data. 64 bytes from ha.ubuntu-eu.org (213.95.41.4): icmp_seq=1 ttl=53 time=39.1 ms 64 bytes from ha.ubuntu-eu.org (213.95.41.4): icmp_seq=2 ttl=53 time=31.3 ms --- ubuntuusers.de ping statistics --- 2 packets transmitted, 2 received, 0% packet loss, time 1001ms rtt min/avg/max/mdev = 31.368/35.239/39.111/3.876 ms
goofy@goofy-HPE-440ch:~$ ping -c 2 213.95.41.4 PING 213.95.41.4 (213.95.41.4) 56(84) bytes of data. 64 bytes from 213.95.41.4: icmp_seq=1 ttl=53 time=37.5 ms 64 bytes from 213.95.41.4: icmp_seq=2 ttl=53 time=37.5 ms --- 213.95.41.4 ping statistics --- 2 packets transmitted, 2 received, 0% packet loss, time 1001ms rtt min/avg/max/mdev = 37.540/37.554/37.569/0.194 ms
goofy@goofy-HPE-440ch:~$ rfkill list 0: phy0: Wireless LAN Soft blocked: no Hard blocked: no
goofy@goofy-HPE-440ch:~$ lsmod Module Size Used by nls_iso8859_1 16384 0 ccm 20480 3 snd_hda_codec_realtek 94208 1 snd_hda_codec_generic 73728 1 snd_hda_codec_realtek arc4 16384 2 snd_hda_intel 40960 6 rt2800pci 16384 0 snd_hda_codec 126976 3 snd_hda_intel,snd_hda_codec_generic,snd_hda_codec_realtek rt2800mmio 16384 1 rt2800pci snd_hda_core 81920 4 snd_hda_intel,snd_hda_codec,snd_hda_codec_generic,snd_hda_codec_realtek snd_hwdep 20480 1 snd_hda_codec snd_pcm 98304 3 snd_hda_intel,snd_hda_codec,snd_hda_core snd_seq_midi 16384 0 rt2800lib 114688 2 rt2800mmio,rt2800pci rt2x00pci 16384 1 rt2800pci joydev 24576 0 rt2x00mmio 16384 2 rt2800mmio,rt2800pci snd_seq_midi_event 16384 1 snd_seq_midi msi001 16384 1 snd_rawmidi 32768 1 snd_seq_midi msi2500 32768 0 v4l2_common 16384 2 msi001,msi2500 videobuf2_vmalloc 16384 1 msi2500 videobuf2_memops 16384 1 videobuf2_vmalloc videobuf2_v4l2 24576 1 msi2500 videobuf2_core 40960 2 msi2500,videobuf2_v4l2 snd_seq 65536 2 snd_seq_midi_event,snd_seq_midi snd_seq_device 16384 3 snd_seq,snd_rawmidi,snd_seq_midi snd_timer 32768 2 snd_seq,snd_pcm videodev 184320 5 v4l2_common,msi001,msi2500,videobuf2_core,videobuf2_v4l2 intel_powerclamp 16384 0 media 40960 1 videodev snd 81920 22 snd_hda_intel,snd_hwdep,snd_seq,snd_hda_codec,snd_timer,snd_rawmidi,snd_hda_codec_generic,snd_seq_device,snd_hda_codec_realtek,snd_pcm rt2x00lib 53248 5 rt2800lib,rt2x00pci,rt2800mmio,rt2x00mmio,rt2800pci gpio_ich 16384 0 mei_me 40960 0 coretemp 16384 0 mac80211 778240 3 rt2800lib,rt2x00pci,rt2x00lib soundcore 16384 1 snd cfg80211 622592 2 rt2x00lib,mac80211 eeprom_93cx6 16384 1 rt2800pci lpc_ich 24576 0 i7core_edac 24576 0 kvm 593920 0 mei 90112 1 mei_me irqbypass 16384 1 kvm intel_cstate 20480 0 wmi_bmof 16384 0 shpchp 36864 0 mac_hid 16384 0 sch_fq_codel 20480 6 parport_pc 36864 0 ppdev 20480 0 lp 20480 0 parport 49152 3 lp,parport_pc,ppdev ip_tables 28672 0 x_tables 40960 1 ip_tables autofs4 40960 2 hid_generic 16384 0 usbhid 49152 0 hid 118784 2 hid_generic,usbhid uas 24576 0 usb_storage 69632 1 uas nouveau 1716224 14 mxm_wmi 16384 1 nouveau video 45056 1 nouveau i2c_algo_bit 16384 1 nouveau ttm 106496 1 nouveau drm_kms_helper 172032 1 nouveau syscopyarea 16384 1 drm_kms_helper sysfillrect 16384 1 drm_kms_helper sysimgblt 16384 1 drm_kms_helper fb_sys_fops 16384 1 drm_kms_helper drm 401408 17 nouveau,ttm,drm_kms_helper firewire_ohci 40960 0 ahci 36864 2 r8169 86016 0 firewire_core 65536 1 firewire_ohci libahci 32768 1 ahci mii 16384 1 r8169 crc_itu_t 16384 1 firewire_core wmi 24576 3 wmi_bmof,mxm_wmi,nouveau
goofy@goofy-HPE-440ch:~$ iwlist chan enp2s0 no frequency information. wlp5s0 13 channels in total; available frequencies : Channel 01 : 2.412 GHz Channel 02 : 2.417 GHz Channel 03 : 2.422 GHz Channel 04 : 2.427 GHz Channel 05 : 2.432 GHz Channel 06 : 2.437 GHz Channel 07 : 2.442 GHz Channel 08 : 2.447 GHz Channel 09 : 2.452 GHz Channel 10 : 2.457 GHz Channel 11 : 2.462 GHz Channel 12 : 2.467 GHz Channel 13 : 2.472 GHz Current Frequency:2.412 GHz (Channel 1) lo no frequency information.
goofy@goofy-HPE-440ch:~$ sudo iwlist scan [sudo] Passwort für goofy: enp2s0 Interface doesn't support scanning. wlp5s0 Scan completed : Cell 01 - Address: D8:B6:B7:3C:0F:EC Channel:1 Frequency:2.412 GHz (Channel 1) Quality=67/70 Signal level=-43 dBm Encryption key:on ESSID:"UPCD77DC9F" Bit Rates:1 Mb/s; 2 Mb/s; 5.5 Mb/s; 11 Mb/s; 9 Mb/s 18 Mb/s; 36 Mb/s; 54 Mb/s Bit Rates:6 Mb/s; 12 Mb/s; 24 Mb/s; 48 Mb/s Mode:Master Extra:tsf=000001019e21c2d2 Extra: Last beacon: 96ms ago IE: Unknown: 000A55504344373744433946 IE: Unknown: 010882848B961224486C IE: Unknown: 030101 IE: Unknown: 2A0104 IE: Unknown: 32040C183060 IE: Unknown: 2D1A6C0017FFFF000000000000000000000000000000000000000000 IE: Unknown: 3D1601000700000000000000000000000000000000000000 IE: WPA Version 1 Group Cipher : TKIP Pairwise Ciphers (2) : TKIP CCMP Authentication Suites (1) : PSK IE: IEEE 802.11i/WPA2 Version 1 Group Cipher : TKIP Pairwise Ciphers (2) : TKIP CCMP Authentication Suites (1) : PSK IE: Unknown: 7F080000000000000000 IE: Unknown: 0B0502003B127A IE: Unknown: DD180050F2020101800003A4000027A4000042435E0062322F00 IE: Unknown: 0706424520010D10 IE: Unknown: DDA70050F204104A0001101044000102103B000103104700101DA33E801DD211B286014700000000001021001852616C696E6B20546563686E6F6C6F67792C20436F72702E1023001C52616C696E6B20576972656C6573732041636365737320506F696E74102400065254323836301042000831323334353637381054000800060050F20400011011000952616C696E6B415053100800020000103C0001011049000600372A000120 IE: Unknown: DD07000C4300000000 IE: Unknown: DD07000CE700000000 Cell 02 - Address: 54:FA:3E:21:BB:8D Channel:1 Frequency:2.412 GHz (Channel 1) Quality=49/70 Signal level=-61 dBm Encryption key:on ESSID:"HZN241649983" Bit Rates:1 Mb/s; 2 Mb/s; 5.5 Mb/s; 11 Mb/s; 9 Mb/s 18 Mb/s; 36 Mb/s; 54 Mb/s Bit Rates:6 Mb/s; 12 Mb/s; 24 Mb/s; 48 Mb/s Mode:Master Extra:tsf=000000682cf06c5c Extra: Last beacon: 96ms ago IE: Unknown: 000C485A4E323431363439393833 IE: Unknown: 010882848B961224486C IE: Unknown: 030101 IE: Unknown: 2A0104 IE: Unknown: 32040C183060 IE: Unknown: 2D1AEC0103FFFF0000000000000000000000000000000C0000000000 IE: Unknown: 3D1601000000000000000000000000000000000000000000 IE: IEEE 802.11i/WPA2 Version 1 Group Cipher : TKIP Pairwise Ciphers (2) : TKIP CCMP Authentication Suites (1) : PSK IE: Unknown: DD180050F2020101800003A4000027A4000042435E0062322F00 IE: Unknown: 0B05000021127A IE: Unknown: 7F0101 IE: Unknown: DD07000C4307000000 IE: Unknown: 07064E4C20010D10 IE: Unknown: DDA70050F204104A0001101044000102103B00010310470010BC329E001DD811B2860154FA3E21BB8D1021001A43656C656E6F20436F6D6D756E69636174696F6E2C20496E632E1023001743656C656E6F20576972656C65737320415020322E344710240006434C313830301042000831323334353637381054000800060050F20400011011000C43656C656E6F4150322E3447100800024388103C0001011049000600372A000120 Cell 03 - Address: 90:4D:4A:C5:B9:F4 Channel:1 Frequency:2.412 GHz (Channel 1) Quality=37/70 Signal level=-73 dBm Encryption key:on ESSID:"Sunrise_2.4GHz_C5B9F0" Bit Rates:1 Mb/s; 2 Mb/s; 5.5 Mb/s; 11 Mb/s; 18 Mb/s 24 Mb/s; 36 Mb/s; 54 Mb/s Bit Rates:6 Mb/s; 9 Mb/s; 12 Mb/s; 48 Mb/s Mode:Master Extra:tsf=00000010b0cf150c Extra: Last beacon: 96ms ago IE: Unknown: 001553756E726973655F322E3447487A5F433542394630 IE: Unknown: 010882848B962430486C IE: Unknown: 030101 IE: Unknown: 2A0100 IE: Unknown: 32040C121860 IE: IEEE 802.11i/WPA2 Version 1 Group Cipher : TKIP Pairwise Ciphers (2) : CCMP TKIP Authentication Suites (1) : PSK IE: Unknown: 0B050100200000 IE: Unknown: 2D1A2C0017FFFFFF0001000000000000000000000000000000000000 IE: Unknown: 3D1601081500000000000000000000000000000000000000 IE: Unknown: 4A0E14000A002C01C800140005001900 IE: Unknown: 7F080500000000000040 IE: Unknown: DDAF0050F204104A0001101044000102103B000103104700101813C16F8A1251ABE05A80957FC0FA9010210008536167656D636F6D10230018536167656D636F6D46617374353336305F53756E7269736510240007322E312D312E301042000F4C4B313632333644503334313439351054000800060050F20400011011001D536167656D636F6D46617374353336305F53756E726973652D4C4B3136100800022000103C0001011049000600372A000120 IE: Unknown: DD090010180201101C0000 IE: WPA Version 1 Group Cipher : TKIP Pairwise Ciphers (2) : CCMP TKIP Authentication Suites (1) : PSK IE: Unknown: DD180050F2020101800003A4000027A4000042435E0062322F00 Cell 04 - Address: 18:D6:C7:D1:BD:DB Channel:6 Frequency:2.437 GHz (Channel 6) Quality=43/70 Signal level=-67 dBm Encryption key:on ESSID:"TP-LINK_BDDB" Bit Rates:1 Mb/s; 2 Mb/s; 5.5 Mb/s; 11 Mb/s; 6 Mb/s 9 Mb/s; 12 Mb/s; 18 Mb/s Bit Rates:24 Mb/s; 36 Mb/s; 48 Mb/s; 54 Mb/s Mode:Master Extra:tsf=0000023754890016 Extra: Last beacon: 96ms ago IE: Unknown: 000C54502D4C494E4B5F42444442 IE: Unknown: 010882848B960C121824 IE: Unknown: 030106 IE: Unknown: 2A0100 IE: Unknown: 32043048606C IE: Unknown: 2D1AEE111BFFFF000000000000000000000100000000000000000000 IE: Unknown: 3D16060F0600000000000000000000000000000000000000 IE: Unknown: 7F080000000000000040 IE: Unknown: DD180050F2020101800003A4000027A4000042435E0062322F00 IE: Unknown: DD0900037F01010000FF7F IE: IEEE 802.11i/WPA2 Version 1 Group Cipher : CCMP Pairwise Ciphers (1) : CCMP Authentication Suites (1) : PSK IE: WPA Version 1 Group Cipher : CCMP Pairwise Ciphers (1) : CCMP Authentication Suites (1) : PSK Cell 05 - Address: 54:67:51:E7:E8:10 Channel:11 Frequency:2.462 GHz (Channel 11) Quality=37/70 Signal level=-73 dBm Encryption key:on ESSID:"UPCB9F3F17" Bit Rates:1 Mb/s; 2 Mb/s; 5.5 Mb/s; 11 Mb/s; 9 Mb/s 18 Mb/s; 36 Mb/s; 54 Mb/s Bit Rates:6 Mb/s; 12 Mb/s; 24 Mb/s; 48 Mb/s Mode:Master Extra:tsf=000002704d5aa885 Extra: Last beacon: 23028ms ago IE: Unknown: 000A55504342394633463137 IE: Unknown: 010882848B961224486C IE: Unknown: 03010B IE: Unknown: 2A0104 IE: Unknown: 32040C183060 IE: Unknown: 0706455520010D14 IE: Unknown: 2D1AAC0117FFFF000000000000000000000000000000000000000000 IE: Unknown: 3D160B000400000000000000000000000000000000000000 IE: WPA Version 1 Group Cipher : TKIP Pairwise Ciphers (2) : TKIP CCMP Authentication Suites (1) : PSK IE: IEEE 802.11i/WPA2 Version 1 Group Cipher : TKIP Pairwise Ciphers (2) : TKIP CCMP Authentication Suites (1) : PSK IE: Unknown: 7F080100000000000000 IE: Unknown: 0B0501004C127A IE: Unknown: DD180050F2020101000003A4000027A4000042435E0062322F00 IE: Unknown: 7F080100000000000000 IE: Unknown: 0706455520010D10 IE: Unknown: DDA70050F204104A0001101044000102103B000103104700107ECB12001DD211B28601C645A0AAD5451021001852616C696E6B20546563686E6F6C6F67792C20436F72702E1023001C52616C696E6B20576972656C6573732041636365737320506F696E74102400065254323836301042000831323334353637381054000800060050F20400011011000952616C696E6B415053100800020000103C0001011049000600372A000120 IE: Unknown: DD07000C4300000000 Cell 06 - Address: AC:22:05:CF:C3:8F Channel:11 Frequency:2.462 GHz (Channel 11) Quality=39/70 Signal level=-71 dBm Encryption key:on ESSID:"UPCD77DC9F" Bit Rates:1 Mb/s; 2 Mb/s; 5.5 Mb/s; 11 Mb/s; 9 Mb/s 18 Mb/s; 36 Mb/s; 54 Mb/s Bit Rates:6 Mb/s; 12 Mb/s; 24 Mb/s; 48 Mb/s Mode:Master Extra:tsf=0000015d0e20a8de Extra: Last beacon: 96ms ago IE: Unknown: 000A55504344373744433946 IE: Unknown: 010882848B961224486C IE: Unknown: 03010B IE: Unknown: 2A0104 IE: Unknown: 32040C183060 IE: Unknown: 0706455520010D14 IE: Unknown: 2D1AAC0117FFFF000000000000000000000000000000000000000000 IE: Unknown: 3D160B030400000000000000000000000000000000000000 IE: WPA Version 1 Group Cipher : TKIP Pairwise Ciphers (2) : TKIP CCMP Authentication Suites (1) : PSK IE: IEEE 802.11i/WPA2 Version 1 Group Cipher : TKIP Pairwise Ciphers (2) : TKIP CCMP Authentication Suites (1) : PSK IE: Unknown: 7F080100000000000000 IE: Unknown: 0B05020047127A IE: Unknown: DD180050F2020101000003A4000027A4000042435E0062322F00 IE: Unknown: 7F080100000000000000 IE: Unknown: 0706455520010D10 IE: Unknown: DDA70050F204104A0001101044000102103B0001031047001084C0F3001DD211B28601C645A0AAD5451021001852616C696E6B20546563686E6F6C6F67792C20436F72702E1023001C52616C696E6B20576972656C6573732041636365737320506F696E74102400065254323836301042000831323334353637381054000800060050F20400011011000952616C696E6B415053100800020000103C0001011049000600372A000120 IE: Unknown: DD07000C4300000000 Cell 07 - Address: AE:22:15:CF:C3:8F Channel:11 Frequency:2.462 GHz (Channel 11) Quality=39/70 Signal level=-71 dBm Encryption key:on ESSID:"UPC Wi-Free" Bit Rates:1 Mb/s; 2 Mb/s; 5.5 Mb/s; 11 Mb/s; 9 Mb/s 18 Mb/s; 36 Mb/s; 54 Mb/s Bit Rates:6 Mb/s; 12 Mb/s; 24 Mb/s; 48 Mb/s Mode:Master Extra:tsf=0000015d0e20ceb8 Extra: Last beacon: 96ms ago IE: Unknown: 000B5550432057692D46726565 IE: Unknown: 010882848B961224486C IE: Unknown: 03010B IE: Unknown: 2A0104 IE: Unknown: 32040C183060 IE: Unknown: 0706455520010D14 IE: Unknown: 2D1AAC0117FFFF000000000000000000000000000000000000000000 IE: Unknown: 3D160B030400000000000000000000000000000000000000 IE: IEEE 802.11i/WPA2 Version 1 Group Cipher : TKIP Pairwise Ciphers (2) : TKIP CCMP Authentication Suites (1) : 802.1x IE: Unknown: 7F080100000000000000 IE: Unknown: 0B05020047127A IE: Unknown: DD180050F2020101000003A4000027A4000042435E0062322F00 IE: Unknown: 7F080100000000000000 IE: Unknown: 0706455520010D10 IE: Unknown: DD07000C4300000000 Cell 08 - Address: F4:06:8D:86:82:25 Channel:6 Frequency:2.437 GHz (Channel 6) Quality=37/70 Signal level=-73 dBm Encryption key:on ESSID:"@brmg" Bit Rates:1 Mb/s; 2 Mb/s; 5.5 Mb/s; 11 Mb/s; 6 Mb/s 9 Mb/s; 12 Mb/s; 18 Mb/s Bit Rates:24 Mb/s; 36 Mb/s; 48 Mb/s; 54 Mb/s Mode:Master Extra:tsf=000013fb08b642c5 Extra: Last beacon: 4608ms ago IE: Unknown: 00054062726D67 IE: Unknown: 010882848B960C121824 IE: Unknown: 030106 IE: Unknown: 2A0100 IE: Unknown: 32043048606C IE: Unknown: 2D1AAD0103FFFF0000000000000000000001000000000406E6A70C00 IE: Unknown: 3D1606080000000000000000000000000000000000000000 IE: Unknown: 4A0E14000A002C01C800140005001900 IE: Unknown: 7F0801000F0000000040 IE: Unknown: DD180050F2020101000003A4000027A4000042435E0062322F00 IE: Unknown: DD0900037F01010000FF7F IE: Unknown: DD0A00037F04010008000A00 IE: Unknown: DD980050F204104A0001101044000102103B00010310470010B2FCD7DA4BBC546DA7A04594D9C2F0D310210007756E6B6E6F776E10230018486F6D65506C756720415620576972656C6573732041502010240003312E3010420003312E301054000800060050F204000110110017486F6D65506C756720415620576972656C65737320415010080002200C103C0001011049000600372A000120 IE: IEEE 802.11i/WPA2 Version 1 Group Cipher : CCMP Pairwise Ciphers (1) : CCMP Authentication Suites (1) : PSK Cell 09 - Address: 56:67:11:E7:E8:10 Channel:11 Frequency:2.462 GHz (Channel 11) Quality=35/70 Signal level=-75 dBm Encryption key:on ESSID:"UPC Wi-Free" Bit Rates:1 Mb/s; 2 Mb/s; 5.5 Mb/s; 11 Mb/s; 9 Mb/s 18 Mb/s; 36 Mb/s; 54 Mb/s Bit Rates:6 Mb/s; 12 Mb/s; 24 Mb/s; 48 Mb/s Mode:Master Extra:tsf=000002704f7fa1a0 Extra: Last beacon: 5000ms ago IE: Unknown: 000B5550432057692D46726565 IE: Unknown: 010882848B961224486C IE: Unknown: 03010B IE: Unknown: 32040C183060 IE: Unknown: 0706455520010D14 IE: Unknown: 33082001020304050607 IE: Unknown: 33082105060708090A0B IE: Unknown: 050400010000 IE: IEEE 802.11i/WPA2 Version 1 Group Cipher : TKIP Pairwise Ciphers (2) : TKIP CCMP Authentication Suites (1) : 802.1x IE: Unknown: 2A0104 IE: Unknown: 2D1AAC0117FFFF000000000000000000000000000000000000000000 IE: Unknown: 3D160B000400000000000000000000000000000000000000 IE: Unknown: 7F080100000000000000 IE: Unknown: DD180050F2020101000003A4000027A4000042435E0062322F00 IE: Unknown: 0B0501004D127A IE: Unknown: DD07000C4300000000 Cell 10 - Address: F4:F2:6D:FF:DA:03 Channel:1 Frequency:2.412 GHz (Channel 1) Quality=41/70 Signal level=-69 dBm Encryption key:on ESSID:"Linalex" Bit Rates:1 Mb/s; 2 Mb/s; 5.5 Mb/s; 11 Mb/s; 18 Mb/s 24 Mb/s; 36 Mb/s; 54 Mb/s Bit Rates:6 Mb/s; 9 Mb/s; 12 Mb/s; 48 Mb/s Mode:Master Extra:tsf=0000020994cc7405 Extra: Last beacon: 420ms ago IE: Unknown: 00074C696E616C6578 IE: Unknown: 010882848B962430486C IE: Unknown: 030101 IE: Unknown: 050400010000 IE: Unknown: 2A0100 IE: Unknown: 2F0100 IE: IEEE 802.11i/WPA2 Version 1 Group Cipher : TKIP Pairwise Ciphers (2) : CCMP TKIP Authentication Suites (1) : PSK IE: Unknown: 32040C121860 IE: Unknown: 2D1AAD1917FFFFFF0000000000000000000000000000000000000000 IE: Unknown: 3D1601001300000000000000000000000000000000000000 IE: Unknown: 7F080400000000000040 IE: Unknown: DD180050F204104A00011010440001021049000600372A000120 IE: Unknown: DD090010180201001C0000 IE: WPA Version 1 Group Cipher : TKIP Pairwise Ciphers (2) : CCMP TKIP Authentication Suites (1) : PSK IE: Unknown: DD180050F2020101840003A4000027A4000042435E0062322F00 IE: Unknown: 46057208010000 IE: Unknown: DD1E00904C0408BF0CB259820FEAFF0000EAFF0000C0050001000000C3020002 lo Interface doesn't support scanning.
goofy@goofy-HPE-440ch:~$ egrep -i 'net|eth|wlan|firm|reason' /var/log/syslog Aug 18 05:54:07 goofy-HPE-440ch NetworkManager[1007]: <info> [1534564447.6427] dhcp4 (wlp5s0): address 192.168.0.229 Aug 18 05:54:07 goofy-HPE-440ch NetworkManager[1007]: <info> [1534564447.6428] dhcp4 (wlp5s0): plen 24 (255.255.255.0) Aug 18 05:54:07 goofy-HPE-440ch NetworkManager[1007]: <info> [1534564447.6428] dhcp4 (wlp5s0): gateway 192.168.0.1 Aug 18 05:54:07 goofy-HPE-440ch NetworkManager[1007]: <info> [1534564447.6428] dhcp4 (wlp5s0): lease time 3600 Aug 18 05:54:07 goofy-HPE-440ch NetworkManager[1007]: <info> [1534564447.6429] dhcp4 (wlp5s0): hostname 'goofy-HPE-440ch' Aug 18 05:54:07 goofy-HPE-440ch NetworkManager[1007]: <info> [1534564447.6429] dhcp4 (wlp5s0): nameserver '62.2.17.61' Aug 18 05:54:07 goofy-HPE-440ch NetworkManager[1007]: <info> [1534564447.6429] dhcp4 (wlp5s0): nameserver '62.2.24.158' Aug 18 05:54:07 goofy-HPE-440ch NetworkManager[1007]: <info> [1534564447.6430] dhcp4 (wlp5s0): nameserver '62.2.17.60' Aug 18 05:54:07 goofy-HPE-440ch NetworkManager[1007]: <info> [1534564447.6430] dhcp4 (wlp5s0): nameserver '62.2.24.162' Aug 18 05:54:07 goofy-HPE-440ch NetworkManager[1007]: <info> [1534564447.6430] dhcp4 (wlp5s0): domain name 'home' Aug 18 05:54:07 goofy-HPE-440ch NetworkManager[1007]: <info> [1534564447.6431] dhcp4 (wlp5s0): state changed bound -> bound Aug 18 05:54:07 goofy-HPE-440ch dbus-daemon[991]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.16' (uid=0 pid=1007 comm="/usr/sbin/NetworkManager --no-daemon " label="unconfined") Aug 18 05:54:07 goofy-HPE-440ch systemd[1]: Starting Network Manager Script Dispatcher Service... Aug 18 05:54:07 goofy-HPE-440ch systemd[1]: Started Network Manager Script Dispatcher Service. Aug 18 06:01:37 goofy-HPE-440ch 50-motd-news[2462]: something worthwhile there for those crazy EMACS fans ;) Aug 18 06:16:43 goofy-HPE-440ch NetworkManager[1007]: <info> [1534565803.3228] dhcp4 (wlp5s0): address 192.168.0.229 Aug 18 06:16:43 goofy-HPE-440ch NetworkManager[1007]: <info> [1534565803.3228] dhcp4 (wlp5s0): plen 24 (255.255.255.0) Aug 18 06:16:43 goofy-HPE-440ch NetworkManager[1007]: <info> [1534565803.3228] dhcp4 (wlp5s0): gateway 192.168.0.1 Aug 18 06:16:43 goofy-HPE-440ch NetworkManager[1007]: <info> [1534565803.3229] dhcp4 (wlp5s0): lease time 3600 Aug 18 06:16:43 goofy-HPE-440ch NetworkManager[1007]: <info> [1534565803.3229] dhcp4 (wlp5s0): hostname 'goofy-HPE-440ch' Aug 18 06:16:43 goofy-HPE-440ch NetworkManager[1007]: <info> [1534565803.3230] dhcp4 (wlp5s0): nameserver '62.2.17.61' Aug 18 06:16:43 goofy-HPE-440ch NetworkManager[1007]: <info> [1534565803.3230] dhcp4 (wlp5s0): nameserver '62.2.24.158' Aug 18 06:16:43 goofy-HPE-440ch NetworkManager[1007]: <info> [1534565803.3230] dhcp4 (wlp5s0): nameserver '62.2.17.60' Aug 18 06:16:43 goofy-HPE-440ch NetworkManager[1007]: <info> [1534565803.3231] dhcp4 (wlp5s0): nameserver '62.2.24.162' Aug 18 06:16:43 goofy-HPE-440ch NetworkManager[1007]: <info> [1534565803.3231] dhcp4 (wlp5s0): domain name 'home' Aug 18 06:16:43 goofy-HPE-440ch NetworkManager[1007]: <info> [1534565803.3231] dhcp4 (wlp5s0): state changed bound -> bound Aug 18 06:16:43 goofy-HPE-440ch dbus-daemon[991]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.16' (uid=0 pid=1007 comm="/usr/sbin/NetworkManager --no-daemon " label="unconfined") Aug 18 06:16:43 goofy-HPE-440ch systemd[1]: Starting Network Manager Script Dispatcher Service... Aug 18 06:16:43 goofy-HPE-440ch systemd[1]: Started Network Manager Script Dispatcher Service. Aug 18 06:45:19 goofy-HPE-440ch NetworkManager[1007]: <info> [1534567519.2501] dhcp4 (wlp5s0): address 192.168.0.229 Aug 18 06:45:19 goofy-HPE-440ch NetworkManager[1007]: <info> [1534567519.2502] dhcp4 (wlp5s0): plen 24 (255.255.255.0) Aug 18 06:45:19 goofy-HPE-440ch NetworkManager[1007]: <info> [1534567519.2502] dhcp4 (wlp5s0): gateway 192.168.0.1 Aug 18 06:45:19 goofy-HPE-440ch NetworkManager[1007]: <info> [1534567519.2503] dhcp4 (wlp5s0): lease time 3600 Aug 18 06:45:19 goofy-HPE-440ch NetworkManager[1007]: <info> [1534567519.2503] dhcp4 (wlp5s0): hostname 'goofy-HPE-440ch' Aug 18 06:45:19 goofy-HPE-440ch NetworkManager[1007]: <info> [1534567519.2503] dhcp4 (wlp5s0): nameserver '62.2.17.61' Aug 18 06:45:19 goofy-HPE-440ch NetworkManager[1007]: <info> [1534567519.2504] dhcp4 (wlp5s0): nameserver '62.2.24.158' Aug 18 06:45:19 goofy-HPE-440ch NetworkManager[1007]: <info> [1534567519.2504] dhcp4 (wlp5s0): nameserver '62.2.17.60' Aug 18 06:45:19 goofy-HPE-440ch NetworkManager[1007]: <info> [1534567519.2504] dhcp4 (wlp5s0): nameserver '62.2.24.162' Aug 18 06:45:19 goofy-HPE-440ch NetworkManager[1007]: <info> [1534567519.2505] dhcp4 (wlp5s0): domain name 'home' Aug 18 06:45:19 goofy-HPE-440ch NetworkManager[1007]: <info> [1534567519.2505] dhcp4 (wlp5s0): state changed bound -> bound Aug 18 06:45:19 goofy-HPE-440ch dbus-daemon[991]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.16' (uid=0 pid=1007 comm="/usr/sbin/NetworkManager --no-daemon " label="unconfined") Aug 18 06:45:19 goofy-HPE-440ch systemd[1]: Starting Network Manager Script Dispatcher Service... Aug 18 06:45:19 goofy-HPE-440ch systemd[1]: Started Network Manager Script Dispatcher Service. Aug 18 06:51:46 goofy-HPE-440ch wpa_supplicant[1014]: wlp5s0: CTRL-EVENT-DISCONNECTED bssid=ac:22:05:cf:c3:8f reason=4 locally_generated=1 Aug 18 06:51:46 goofy-HPE-440ch NetworkManager[1007]: <warn> [1534567906.5552] sup-iface[0x5571ba355240,wlp5s0]: connection disconnected (reason -4) Aug 18 06:51:46 goofy-HPE-440ch NetworkManager[1007]: <info> [1534567906.5930] device (wlp5s0): supplicant interface state: completed -> disconnected Aug 18 06:51:46 goofy-HPE-440ch NetworkManager[1007]: <info> [1534567906.6607] device (wlp5s0): supplicant interface state: disconnected -> scanning Aug 18 06:51:47 goofy-HPE-440ch NetworkManager[1007]: <info> [1534567907.7019] device (wlp5s0): supplicant interface state: scanning -> authenticating Aug 18 06:51:47 goofy-HPE-440ch NetworkManager[1007]: <info> [1534567907.7107] device (wlp5s0): supplicant interface state: authenticating -> associating Aug 18 06:51:47 goofy-HPE-440ch wpa_supplicant[1014]: wlp5s0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0 Aug 18 06:51:47 goofy-HPE-440ch NetworkManager[1007]: <info> [1534567907.7227] device (wlp5s0): supplicant interface state: associating -> associated Aug 18 06:51:47 goofy-HPE-440ch NetworkManager[1007]: <info> [1534567907.9801] device (wlp5s0): supplicant interface state: associated -> 4-way handshake Aug 18 06:51:48 goofy-HPE-440ch NetworkManager[1007]: <info> [1534567908.0183] device (wlp5s0): supplicant interface state: 4-way handshake -> completed Aug 18 07:00:20 goofy-HPE-440ch NetworkManager[1007]: <info> [1534568420.2147] connectivity: (wlp5s0) timed out Aug 18 07:00:20 goofy-HPE-440ch NetworkManager[1007]: <info> [1534568420.2147] manager: NetworkManager state is now CONNECTED_SITE Aug 18 07:00:20 goofy-HPE-440ch dbus-daemon[991]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.16' (uid=0 pid=1007 comm="/usr/sbin/NetworkManager --no-daemon " label="unconfined") Aug 18 07:00:20 goofy-HPE-440ch systemd[1]: Starting Network Manager Script Dispatcher Service... Aug 18 07:00:20 goofy-HPE-440ch systemd[1]: Started Network Manager Script Dispatcher Service. Aug 18 07:04:54 goofy-HPE-440ch NetworkManager[1007]: <info> [1534568694.5388] manager: NetworkManager state is now CONNECTED_GLOBAL Aug 18 07:04:54 goofy-HPE-440ch dbus-daemon[991]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.16' (uid=0 pid=1007 comm="/usr/sbin/NetworkManager --no-daemon " label="unconfined") Aug 18 07:04:54 goofy-HPE-440ch whoopsie[1259]: [07:04:54] The default IPv4 route is: /org/freedesktop/NetworkManager/ActiveConnection/1 Aug 18 07:04:54 goofy-HPE-440ch systemd[1]: Starting Network Manager Script Dispatcher Service... Aug 18 07:04:54 goofy-HPE-440ch whoopsie[1259]: [07:04:54] Not a paid data plan: /org/freedesktop/NetworkManager/ActiveConnection/1 Aug 18 07:04:54 goofy-HPE-440ch whoopsie[1259]: [07:04:54] Found usable connection: /org/freedesktop/NetworkManager/ActiveConnection/1 Aug 18 07:04:54 goofy-HPE-440ch systemd[1]: Started Network Manager Script Dispatcher Service. Aug 18 07:10:02 goofy-HPE-440ch NetworkManager[1007]: <info> [1534569002.2198] manager: NetworkManager state is now CONNECTED_SITE Aug 18 07:10:02 goofy-HPE-440ch dbus-daemon[991]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.16' (uid=0 pid=1007 comm="/usr/sbin/NetworkManager --no-daemon " label="unconfined") Aug 18 07:10:02 goofy-HPE-440ch systemd[1]: Starting Network Manager Script Dispatcher Service... Aug 18 07:10:02 goofy-HPE-440ch systemd[1]: Started Network Manager Script Dispatcher Service. Aug 18 07:12:20 goofy-HPE-440ch NetworkManager[1007]: <info> [1534569140.4304] dhcp4 (wlp5s0): address 192.168.0.229 Aug 18 07:12:20 goofy-HPE-440ch NetworkManager[1007]: <info> [1534569140.4304] dhcp4 (wlp5s0): plen 24 (255.255.255.0) Aug 18 07:12:20 goofy-HPE-440ch NetworkManager[1007]: <info> [1534569140.4305] dhcp4 (wlp5s0): gateway 192.168.0.1 Aug 18 07:12:20 goofy-HPE-440ch NetworkManager[1007]: <info> [1534569140.4305] dhcp4 (wlp5s0): lease time 3600 Aug 18 07:12:20 goofy-HPE-440ch NetworkManager[1007]: <info> [1534569140.4306] dhcp4 (wlp5s0): hostname 'goofy-HPE-440ch' Aug 18 07:12:20 goofy-HPE-440ch NetworkManager[1007]: <info> [1534569140.4306] dhcp4 (wlp5s0): nameserver '62.2.17.61' Aug 18 07:12:20 goofy-HPE-440ch NetworkManager[1007]: <info> [1534569140.4306] dhcp4 (wlp5s0): nameserver '62.2.24.158' Aug 18 07:12:20 goofy-HPE-440ch NetworkManager[1007]: <info> [1534569140.4307] dhcp4 (wlp5s0): nameserver '62.2.17.60' Aug 18 07:12:20 goofy-HPE-440ch NetworkManager[1007]: <info> [1534569140.4307] dhcp4 (wlp5s0): nameserver '62.2.24.162' Aug 18 07:12:20 goofy-HPE-440ch NetworkManager[1007]: <info> [1534569140.4307] dhcp4 (wlp5s0): domain name 'home' Aug 18 07:12:20 goofy-HPE-440ch NetworkManager[1007]: <info> [1534569140.4308] dhcp4 (wlp5s0): state changed bound -> bound Aug 18 07:12:20 goofy-HPE-440ch dbus-daemon[991]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.16' (uid=0 pid=1007 comm="/usr/sbin/NetworkManager --no-daemon " label="unconfined") Aug 18 07:12:20 goofy-HPE-440ch systemd[1]: Starting Network Manager Script Dispatcher Service... Aug 18 07:12:20 goofy-HPE-440ch systemd[1]: Started Network Manager Script Dispatcher Service. Aug 18 07:15:20 goofy-HPE-440ch NetworkManager[1007]: <info> [1534569320.2153] connectivity: (wlp5s0) timed out Aug 18 07:20:17 goofy-HPE-440ch NetworkManager[1007]: <info> [1534569617.7418] manager: NetworkManager state is now CONNECTED_GLOBAL Aug 18 07:20:17 goofy-HPE-440ch dbus-daemon[991]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.16' (uid=0 pid=1007 comm="/usr/sbin/NetworkManager --no-daemon " label="unconfined") Aug 18 07:20:17 goofy-HPE-440ch whoopsie[1259]: [07:20:17] The default IPv4 route is: /org/freedesktop/NetworkManager/ActiveConnection/1 Aug 18 07:20:17 goofy-HPE-440ch systemd[1]: Starting Network Manager Script Dispatcher Service... Aug 18 07:20:17 goofy-HPE-440ch whoopsie[1259]: [07:20:17] Not a paid data plan: /org/freedesktop/NetworkManager/ActiveConnection/1 Aug 18 07:20:17 goofy-HPE-440ch whoopsie[1259]: [07:20:17] Found usable connection: /org/freedesktop/NetworkManager/ActiveConnection/1 Aug 18 07:20:17 goofy-HPE-440ch systemd[1]: Started Network Manager Script Dispatcher Service. Aug 18 07:25:20 goofy-HPE-440ch NetworkManager[1007]: <info> [1534569920.2157] connectivity: (wlp5s0) timed out Aug 18 07:25:20 goofy-HPE-440ch NetworkManager[1007]: <info> [1534569920.2158] manager: NetworkManager state is now CONNECTED_SITE Aug 18 07:25:20 goofy-HPE-440ch dbus-daemon[991]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.16' (uid=0 pid=1007 comm="/usr/sbin/NetworkManager --no-daemon " label="unconfined") Aug 18 07:25:20 goofy-HPE-440ch systemd[1]: Starting Network Manager Script Dispatcher Service... Aug 18 07:25:20 goofy-HPE-440ch systemd[1]: Started Network Manager Script Dispatcher Service. Aug 18 07:30:20 goofy-HPE-440ch NetworkManager[1007]: <info> [1534570220.2150] connectivity: (wlp5s0) timed out Aug 18 07:34:55 goofy-HPE-440ch NetworkManager[1007]: <info> [1534570495.9715] manager: NetworkManager state is now CONNECTED_GLOBAL Aug 18 07:34:55 goofy-HPE-440ch dbus-daemon[991]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.16' (uid=0 pid=1007 comm="/usr/sbin/NetworkManager --no-daemon " label="unconfined") Aug 18 07:34:55 goofy-HPE-440ch whoopsie[1259]: [07:34:55] The default IPv4 route is: /org/freedesktop/NetworkManager/ActiveConnection/1 Aug 18 07:34:55 goofy-HPE-440ch systemd[1]: Starting Network Manager Script Dispatcher Service... Aug 18 07:34:55 goofy-HPE-440ch whoopsie[1259]: [07:34:55] Not a paid data plan: /org/freedesktop/NetworkManager/ActiveConnection/1 Aug 18 07:34:55 goofy-HPE-440ch whoopsie[1259]: [07:34:55] Found usable connection: /org/freedesktop/NetworkManager/ActiveConnection/1 Aug 18 07:34:55 goofy-HPE-440ch systemd[1]: Started Network Manager Script Dispatcher Service. Aug 18 07:41:38 goofy-HPE-440ch NetworkManager[1007]: <info> [1534570898.7842] dhcp4 (wlp5s0): address 192.168.0.229 Aug 18 07:41:38 goofy-HPE-440ch NetworkManager[1007]: <info> [1534570898.7843] dhcp4 (wlp5s0): plen 24 (255.255.255.0) Aug 18 07:41:38 goofy-HPE-440ch NetworkManager[1007]: <info> [1534570898.7843] dhcp4 (wlp5s0): gateway 192.168.0.1 Aug 18 07:41:38 goofy-HPE-440ch NetworkManager[1007]: <info> [1534570898.7843] dhcp4 (wlp5s0): lease time 3600 Aug 18 07:41:38 goofy-HPE-440ch NetworkManager[1007]: <info> [1534570898.7844] dhcp4 (wlp5s0): hostname 'goofy-HPE-440ch' Aug 18 07:41:38 goofy-HPE-440ch NetworkManager[1007]: <info> [1534570898.7844] dhcp4 (wlp5s0): nameserver '62.2.17.61' Aug 18 07:41:38 goofy-HPE-440ch NetworkManager[1007]: <info> [1534570898.7844] dhcp4 (wlp5s0): nameserver '62.2.24.158' Aug 18 07:41:38 goofy-HPE-440ch NetworkManager[1007]: <info> [1534570898.7845] dhcp4 (wlp5s0): nameserver '62.2.17.60' Aug 18 07:41:38 goofy-HPE-440ch NetworkManager[1007]: <info> [1534570898.7845] dhcp4 (wlp5s0): nameserver '62.2.24.162' Aug 18 07:41:38 goofy-HPE-440ch NetworkManager[1007]: <info> [1534570898.7845] dhcp4 (wlp5s0): domain name 'home' Aug 18 07:41:38 goofy-HPE-440ch NetworkManager[1007]: <info> [1534570898.7846] dhcp4 (wlp5s0): state changed bound -> bound Aug 18 07:41:38 goofy-HPE-440ch dbus-daemon[991]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.16' (uid=0 pid=1007 comm="/usr/sbin/NetworkManager --no-daemon " label="unconfined") Aug 18 07:41:38 goofy-HPE-440ch systemd[1]: Starting Network Manager Script Dispatcher Service... Aug 18 07:41:38 goofy-HPE-440ch systemd[1]: Started Network Manager Script Dispatcher Service. Aug 18 08:11:00 goofy-HPE-440ch NetworkManager[1007]: <info> [1534572660.4241] dhcp4 (wlp5s0): address 192.168.0.229 Aug 18 08:11:00 goofy-HPE-440ch NetworkManager[1007]: <info> [1534572660.4242] dhcp4 (wlp5s0): plen 24 (255.255.255.0) Aug 18 08:11:00 goofy-HPE-440ch NetworkManager[1007]: <info> [1534572660.4242] dhcp4 (wlp5s0): gateway 192.168.0.1 Aug 18 08:11:00 goofy-HPE-440ch NetworkManager[1007]: <info> [1534572660.4242] dhcp4 (wlp5s0): lease time 3600 Aug 18 08:11:00 goofy-HPE-440ch NetworkManager[1007]: <info> [1534572660.4243] dhcp4 (wlp5s0): hostname 'goofy-HPE-440ch' Aug 18 08:11:00 goofy-HPE-440ch NetworkManager[1007]: <info> [1534572660.4243] dhcp4 (wlp5s0): nameserver '62.2.17.61' Aug 18 08:11:00 goofy-HPE-440ch NetworkManager[1007]: <info> [1534572660.4243] dhcp4 (wlp5s0): nameserver '62.2.24.158' Aug 18 08:11:00 goofy-HPE-440ch NetworkManager[1007]: <info> [1534572660.4244] dhcp4 (wlp5s0): nameserver '62.2.17.60' Aug 18 08:11:00 goofy-HPE-440ch NetworkManager[1007]: <info> [1534572660.4244] dhcp4 (wlp5s0): nameserver '62.2.24.162' Aug 18 08:11:00 goofy-HPE-440ch NetworkManager[1007]: <info> [1534572660.4244] dhcp4 (wlp5s0): domain name 'home' Aug 18 08:11:00 goofy-HPE-440ch NetworkManager[1007]: <info> [1534572660.4245] dhcp4 (wlp5s0): state changed bound -> bound Aug 18 08:11:00 goofy-HPE-440ch dbus-daemon[991]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.16' (uid=0 pid=1007 comm="/usr/sbin/NetworkManager --no-daemon " label="unconfined") Aug 18 08:11:00 goofy-HPE-440ch systemd[1]: Starting Network Manager Script Dispatcher Service... Aug 18 08:11:00 goofy-HPE-440ch systemd[1]: Started Network Manager Script Dispatcher Service. Aug 18 08:25:04 goofy-HPE-440ch NetworkManager[1007]: <info> [1534573504.5269] manager: NetworkManager state is now CONNECTED_SITE Aug 18 08:25:04 goofy-HPE-440ch dbus-daemon[991]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.16' (uid=0 pid=1007 comm="/usr/sbin/NetworkManager --no-daemon " label="unconfined") Aug 18 08:25:04 goofy-HPE-440ch systemd[1]: Starting Network Manager Script Dispatcher Service... Aug 18 08:25:04 goofy-HPE-440ch systemd[1]: Started Network Manager Script Dispatcher Service. Aug 18 08:29:51 goofy-HPE-440ch NetworkManager[1007]: <info> [1534573791.6085] manager: NetworkManager state is now CONNECTED_GLOBAL Aug 18 08:29:51 goofy-HPE-440ch dbus-daemon[991]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.16' (uid=0 pid=1007 comm="/usr/sbin/NetworkManager --no-daemon " label="unconfined") Aug 18 08:29:51 goofy-HPE-440ch whoopsie[1259]: [08:29:51] The default IPv4 route is: /org/freedesktop/NetworkManager/ActiveConnection/1 Aug 18 08:29:51 goofy-HPE-440ch systemd[1]: Starting Network Manager Script Dispatcher Service... Aug 18 08:29:51 goofy-HPE-440ch whoopsie[1259]: [08:29:51] Not a paid data plan: /org/freedesktop/NetworkManager/ActiveConnection/1 Aug 18 08:29:51 goofy-HPE-440ch whoopsie[1259]: [08:29:51] Found usable connection: /org/freedesktop/NetworkManager/ActiveConnection/1 Aug 18 08:29:51 goofy-HPE-440ch systemd[1]: Started Network Manager Script Dispatcher Service. Aug 18 08:38:40 goofy-HPE-440ch NetworkManager[1007]: <info> [1534574320.9864] dhcp4 (wlp5s0): address 192.168.0.229 Aug 18 08:38:40 goofy-HPE-440ch NetworkManager[1007]: <info> [1534574320.9865] dhcp4 (wlp5s0): plen 24 (255.255.255.0) Aug 18 08:38:40 goofy-HPE-440ch NetworkManager[1007]: <info> [1534574320.9866] dhcp4 (wlp5s0): gateway 192.168.0.1 Aug 18 08:38:40 goofy-HPE-440ch NetworkManager[1007]: <info> [1534574320.9866] dhcp4 (wlp5s0): lease time 3600 Aug 18 08:38:40 goofy-HPE-440ch NetworkManager[1007]: <info> [1534574320.9867] dhcp4 (wlp5s0): hostname 'goofy-HPE-440ch' Aug 18 08:38:40 goofy-HPE-440ch NetworkManager[1007]: <info> [1534574320.9867] dhcp4 (wlp5s0): nameserver '62.2.17.61' Aug 18 08:38:40 goofy-HPE-440ch NetworkManager[1007]: <info> [1534574320.9867] dhcp4 (wlp5s0): nameserver '62.2.24.158' Aug 18 08:38:40 goofy-HPE-440ch NetworkManager[1007]: <info> [1534574320.9868] dhcp4 (wlp5s0): nameserver '62.2.17.60' Aug 18 08:38:40 goofy-HPE-440ch NetworkManager[1007]: <info> [1534574320.9868] dhcp4 (wlp5s0): nameserver '62.2.24.162' Aug 18 08:38:40 goofy-HPE-440ch NetworkManager[1007]: <info> [1534574320.9868] dhcp4 (wlp5s0): domain name 'home' Aug 18 08:38:40 goofy-HPE-440ch NetworkManager[1007]: <info> [1534574320.9869] dhcp4 (wlp5s0): state changed bound -> bound Aug 18 08:38:40 goofy-HPE-440ch dbus-daemon[991]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.16' (uid=0 pid=1007 comm="/usr/sbin/NetworkManager --no-daemon " label="unconfined") Aug 18 08:38:40 goofy-HPE-440ch systemd[1]: Starting Network Manager Script Dispatcher Service... Aug 18 08:38:41 goofy-HPE-440ch systemd[1]: Started Network Manager Script Dispatcher Service. Aug 18 09:01:57 goofy-HPE-440ch NetworkManager[1007]: <info> [1534575717.5147] dhcp4 (wlp5s0): address 192.168.0.229 Aug 18 09:01:57 goofy-HPE-440ch NetworkManager[1007]: <info> [1534575717.5147] dhcp4 (wlp5s0): plen 24 (255.255.255.0) Aug 18 09:01:57 goofy-HPE-440ch NetworkManager[1007]: <info> [1534575717.5148] dhcp4 (wlp5s0): gateway 192.168.0.1 Aug 18 09:01:57 goofy-HPE-440ch NetworkManager[1007]: <info> [1534575717.5148] dhcp4 (wlp5s0): lease time 3600 Aug 18 09:01:57 goofy-HPE-440ch NetworkManager[1007]: <info> [1534575717.5149] dhcp4 (wlp5s0): hostname 'goofy-HPE-440ch' Aug 18 09:01:57 goofy-HPE-440ch NetworkManager[1007]: <info> [1534575717.5149] dhcp4 (wlp5s0): nameserver '62.2.17.61' Aug 18 09:01:57 goofy-HPE-440ch NetworkManager[1007]: <info> [1534575717.5149] dhcp4 (wlp5s0): nameserver '62.2.24.158' Aug 18 09:01:57 goofy-HPE-440ch NetworkManager[1007]: <info> [1534575717.5150] dhcp4 (wlp5s0): nameserver '62.2.17.60' Aug 18 09:01:57 goofy-HPE-440ch NetworkManager[1007]: <info> [1534575717.5150] dhcp4 (wlp5s0): nameserver '62.2.24.162' Aug 18 09:01:57 goofy-HPE-440ch NetworkManager[1007]: <info> [1534575717.5150] dhcp4 (wlp5s0): domain name 'home' Aug 18 09:01:57 goofy-HPE-440ch NetworkManager[1007]: <info> [1534575717.5150] dhcp4 (wlp5s0): state changed bound -> bound Aug 18 09:01:57 goofy-HPE-440ch dbus-daemon[991]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.16' (uid=0 pid=1007 comm="/usr/sbin/NetworkManager --no-daemon " label="unconfined") Aug 18 09:01:57 goofy-HPE-440ch systemd[1]: Starting Network Manager Script Dispatcher Service... Aug 18 09:01:57 goofy-HPE-440ch systemd[1]: Started Network Manager Script Dispatcher Service. Aug 18 09:26:10 goofy-HPE-440ch NetworkManager[1007]: <info> [1534577170.1685] dhcp4 (wlp5s0): address 192.168.0.229 Aug 18 09:26:10 goofy-HPE-440ch NetworkManager[1007]: <info> [1534577170.1686] dhcp4 (wlp5s0): plen 24 (255.255.255.0) Aug 18 09:26:10 goofy-HPE-440ch NetworkManager[1007]: <info> [1534577170.1686] dhcp4 (wlp5s0): gateway 192.168.0.1 Aug 18 09:26:10 goofy-HPE-440ch NetworkManager[1007]: <info> [1534577170.1687] dhcp4 (wlp5s0): lease time 3600 Aug 18 09:26:10 goofy-HPE-440ch NetworkManager[1007]: <info> [1534577170.1687] dhcp4 (wlp5s0): hostname 'goofy-HPE-440ch' Aug 18 09:26:10 goofy-HPE-440ch NetworkManager[1007]: <info> [1534577170.1687] dhcp4 (wlp5s0): nameserver '62.2.17.61' Aug 18 09:26:10 goofy-HPE-440ch NetworkManager[1007]: <info> [1534577170.1688] dhcp4 (wlp5s0): nameserver '62.2.24.158' Aug 18 09:26:10 goofy-HPE-440ch NetworkManager[1007]: <info> [1534577170.1688] dhcp4 (wlp5s0): nameserver '62.2.17.60' Aug 18 09:26:10 goofy-HPE-440ch NetworkManager[1007]: <info> [1534577170.1688] dhcp4 (wlp5s0): nameserver '62.2.24.162' Aug 18 09:26:10 goofy-HPE-440ch NetworkManager[1007]: <info> [1534577170.1689] dhcp4 (wlp5s0): domain name 'home' Aug 18 09:26:10 goofy-HPE-440ch NetworkManager[1007]: <info> [1534577170.1689] dhcp4 (wlp5s0): state changed bound -> bound Aug 18 09:26:10 goofy-HPE-440ch dbus-daemon[991]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.16' (uid=0 pid=1007 comm="/usr/sbin/NetworkManager --no-daemon " label="unconfined") Aug 18 09:26:10 goofy-HPE-440ch systemd[1]: Starting Network Manager Script Dispatcher Service... Aug 18 09:26:10 goofy-HPE-440ch systemd[1]: Started Network Manager Script Dispatcher Service. Aug 18 09:49:07 goofy-HPE-440ch NetworkManager[1007]: <info> [1534578547.7876] dhcp4 (wlp5s0): address 192.168.0.229 Aug 18 09:49:07 goofy-HPE-440ch NetworkManager[1007]: <info> [1534578547.7876] dhcp4 (wlp5s0): plen 24 (255.255.255.0) Aug 18 09:49:07 goofy-HPE-440ch NetworkManager[1007]: <info> [1534578547.7877] dhcp4 (wlp5s0): gateway 192.168.0.1 Aug 18 09:49:07 goofy-HPE-440ch NetworkManager[1007]: <info> [1534578547.7877] dhcp4 (wlp5s0): lease time 3600 Aug 18 09:49:07 goofy-HPE-440ch NetworkManager[1007]: <info> [1534578547.7878] dhcp4 (wlp5s0): hostname 'goofy-HPE-440ch' Aug 18 09:49:07 goofy-HPE-440ch NetworkManager[1007]: <info> [1534578547.7878] dhcp4 (wlp5s0): nameserver '62.2.17.61' Aug 18 09:49:07 goofy-HPE-440ch NetworkManager[1007]: <info> [1534578547.7879] dhcp4 (wlp5s0): nameserver '62.2.24.158' Aug 18 09:49:07 goofy-HPE-440ch NetworkManager[1007]: <info> [1534578547.7879] dhcp4 (wlp5s0): nameserver '62.2.17.60' Aug 18 09:49:07 goofy-HPE-440ch NetworkManager[1007]: <info> [1534578547.7880] dhcp4 (wlp5s0): nameserver '62.2.24.162' Aug 18 09:49:07 goofy-HPE-440ch NetworkManager[1007]: <info> [1534578547.7880] dhcp4 (wlp5s0): domain name 'home' Aug 18 09:49:07 goofy-HPE-440ch NetworkManager[1007]: <info> [1534578547.7881] dhcp4 (wlp5s0): state changed bound -> bound Aug 18 09:49:07 goofy-HPE-440ch dbus-daemon[991]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.16' (uid=0 pid=1007 comm="/usr/sbin/NetworkManager --no-daemon " label="unconfined") Aug 18 09:49:07 goofy-HPE-440ch systemd[1]: Starting Network Manager Script Dispatcher Service... Aug 18 09:49:07 goofy-HPE-440ch systemd[1]: Started Network Manager Script Dispatcher Service. Aug 18 10:18:31 goofy-HPE-440ch NetworkManager[1007]: <info> [1534580311.5309] dhcp4 (wlp5s0): address 192.168.0.229 Aug 18 10:18:31 goofy-HPE-440ch NetworkManager[1007]: <info> [1534580311.5310] dhcp4 (wlp5s0): plen 24 (255.255.255.0) Aug 18 10:18:31 goofy-HPE-440ch NetworkManager[1007]: <info> [1534580311.5310] dhcp4 (wlp5s0): gateway 192.168.0.1 Aug 18 10:18:31 goofy-HPE-440ch NetworkManager[1007]: <info> [1534580311.5311] dhcp4 (wlp5s0): lease time 3600 Aug 18 10:18:31 goofy-HPE-440ch NetworkManager[1007]: <info> [1534580311.5311] dhcp4 (wlp5s0): hostname 'goofy-HPE-440ch' Aug 18 10:18:31 goofy-HPE-440ch NetworkManager[1007]: <info> [1534580311.5312] dhcp4 (wlp5s0): nameserver '62.2.17.61' Aug 18 10:18:31 goofy-HPE-440ch NetworkManager[1007]: <info> [1534580311.5312] dhcp4 (wlp5s0): nameserver '62.2.24.158' Aug 18 10:18:31 goofy-HPE-440ch NetworkManager[1007]: <info> [1534580311.5312] dhcp4 (wlp5s0): nameserver '62.2.17.60' Aug 18 10:18:31 goofy-HPE-440ch NetworkManager[1007]: <info> [1534580311.5312] dhcp4 (wlp5s0): nameserver '62.2.24.162' Aug 18 10:18:31 goofy-HPE-440ch NetworkManager[1007]: <info> [1534580311.5313] dhcp4 (wlp5s0): domain name 'home' Aug 18 10:18:31 goofy-HPE-440ch NetworkManager[1007]: <info> [1534580311.5313] dhcp4 (wlp5s0): state changed bound -> bound Aug 18 10:18:31 goofy-HPE-440ch dbus-daemon[991]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.16' (uid=0 pid=1007 comm="/usr/sbin/NetworkManager --no-daemon " label="unconfined") Aug 18 10:18:31 goofy-HPE-440ch systemd[1]: Starting Network Manager Script Dispatcher Service... Aug 18 10:18:31 goofy-HPE-440ch systemd[1]: Started Network Manager Script Dispatcher Service. Aug 18 10:45:47 goofy-HPE-440ch NetworkManager[1007]: <info> [1534581947.4911] dhcp4 (wlp5s0): address 192.168.0.229 Aug 18 10:45:47 goofy-HPE-440ch NetworkManager[1007]: <info> [1534581947.4911] dhcp4 (wlp5s0): plen 24 (255.255.255.0) Aug 18 10:45:47 goofy-HPE-440ch dbus-daemon[991]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.16' (uid=0 pid=1007 comm="/usr/sbin/NetworkManager --no-daemon " label="unconfined") Aug 18 10:45:47 goofy-HPE-440ch NetworkManager[1007]: <info> [1534581947.4911] dhcp4 (wlp5s0): gateway 192.168.0.1 Aug 18 10:45:47 goofy-HPE-440ch NetworkManager[1007]: <info> [1534581947.4911] dhcp4 (wlp5s0): lease time 3600 Aug 18 10:45:47 goofy-HPE-440ch NetworkManager[1007]: <info> [1534581947.4911] dhcp4 (wlp5s0): hostname 'goofy-HPE-440ch' Aug 18 10:45:47 goofy-HPE-440ch NetworkManager[1007]: <info> [1534581947.4912] dhcp4 (wlp5s0): nameserver '62.2.17.61' Aug 18 10:45:47 goofy-HPE-440ch NetworkManager[1007]: <info> [1534581947.4912] dhcp4 (wlp5s0): nameserver '62.2.24.158' Aug 18 10:45:47 goofy-HPE-440ch NetworkManager[1007]: <info> [1534581947.4912] dhcp4 (wlp5s0): nameserver '62.2.17.60' Aug 18 10:45:47 goofy-HPE-440ch NetworkManager[1007]: <info> [1534581947.4912] dhcp4 (wlp5s0): nameserver '62.2.24.162' Aug 18 10:45:47 goofy-HPE-440ch NetworkManager[1007]: <info> [1534581947.4912] dhcp4 (wlp5s0): domain name 'home' Aug 18 10:45:47 goofy-HPE-440ch NetworkManager[1007]: <info> [1534581947.4912] dhcp4 (wlp5s0): state changed bound -> bound Aug 18 10:45:47 goofy-HPE-440ch systemd[1]: Starting Network Manager Script Dispatcher Service... Aug 18 10:45:47 goofy-HPE-440ch systemd[1]: Started Network Manager Script Dispatcher Service. Aug 18 11:11:36 goofy-HPE-440ch NetworkManager[1007]: <info> [1534583496.2261] dhcp4 (wlp5s0): address 192.168.0.229 Aug 18 11:11:36 goofy-HPE-440ch NetworkManager[1007]: <info> [1534583496.2261] dhcp4 (wlp5s0): plen 24 (255.255.255.0) Aug 18 11:11:36 goofy-HPE-440ch dbus-daemon[991]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.16' (uid=0 pid=1007 comm="/usr/sbin/NetworkManager --no-daemon " label="unconfined") Aug 18 11:11:36 goofy-HPE-440ch NetworkManager[1007]: <info> [1534583496.2262] dhcp4 (wlp5s0): gateway 192.168.0.1 Aug 18 11:11:36 goofy-HPE-440ch NetworkManager[1007]: <info> [1534583496.2262] dhcp4 (wlp5s0): lease time 3600 Aug 18 11:11:36 goofy-HPE-440ch NetworkManager[1007]: <info> [1534583496.2262] dhcp4 (wlp5s0): hostname 'goofy-HPE-440ch' Aug 18 11:11:36 goofy-HPE-440ch NetworkManager[1007]: <info> [1534583496.2263] dhcp4 (wlp5s0): nameserver '62.2.17.61' Aug 18 11:11:36 goofy-HPE-440ch NetworkManager[1007]: <info> [1534583496.2263] dhcp4 (wlp5s0): nameserver '62.2.24.158' Aug 18 11:11:36 goofy-HPE-440ch NetworkManager[1007]: <info> [1534583496.2263] dhcp4 (wlp5s0): nameserver '62.2.17.60' Aug 18 11:11:36 goofy-HPE-440ch NetworkManager[1007]: <info> [1534583496.2264] dhcp4 (wlp5s0): nameserver '62.2.24.162' Aug 18 11:11:36 goofy-HPE-440ch NetworkManager[1007]: <info> [1534583496.2264] dhcp4 (wlp5s0): domain name 'home' Aug 18 11:11:36 goofy-HPE-440ch NetworkManager[1007]: <info> [1534583496.2264] dhcp4 (wlp5s0): state changed bound -> bound Aug 18 11:11:36 goofy-HPE-440ch systemd[1]: Starting Network Manager Script Dispatcher Service... Aug 18 11:11:36 goofy-HPE-440ch systemd[1]: Started Network Manager Script Dispatcher Service. Aug 18 11:34:13 goofy-HPE-440ch NetworkManager[1007]: <info> [1534584853.2418] dhcp4 (wlp5s0): address 192.168.0.229 Aug 18 11:34:13 goofy-HPE-440ch NetworkManager[1007]: <info> [1534584853.2419] dhcp4 (wlp5s0): plen 24 (255.255.255.0) Aug 18 11:34:13 goofy-HPE-440ch dbus-daemon[991]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.16' (uid=0 pid=1007 comm="/usr/sbin/NetworkManager --no-daemon " label="unconfined") Aug 18 11:34:13 goofy-HPE-440ch NetworkManager[1007]: <info> [1534584853.2419] dhcp4 (wlp5s0): gateway 192.168.0.1 Aug 18 11:34:13 goofy-HPE-440ch NetworkManager[1007]: <info> [1534584853.2419] dhcp4 (wlp5s0): lease time 3600 Aug 18 11:34:13 goofy-HPE-440ch NetworkManager[1007]: <info> [1534584853.2420] dhcp4 (wlp5s0): hostname 'goofy-HPE-440ch' Aug 18 11:34:13 goofy-HPE-440ch NetworkManager[1007]: <info> [1534584853.2420] dhcp4 (wlp5s0): nameserver '62.2.17.61' Aug 18 11:34:13 goofy-HPE-440ch NetworkManager[1007]: <info> [1534584853.2421] dhcp4 (wlp5s0): nameserver '62.2.24.158' Aug 18 11:34:13 goofy-HPE-440ch NetworkManager[1007]: <info> [1534584853.2421] dhcp4 (wlp5s0): nameserver '62.2.17.60' Aug 18 11:34:13 goofy-HPE-440ch NetworkManager[1007]: <info> [1534584853.2421] dhcp4 (wlp5s0): nameserver '62.2.24.162' Aug 18 11:34:13 goofy-HPE-440ch NetworkManager[1007]: <info> [1534584853.2421] dhcp4 (wlp5s0): domain name 'home' Aug 18 11:34:13 goofy-HPE-440ch NetworkManager[1007]: <info> [1534584853.2422] dhcp4 (wlp5s0): state changed bound -> bound Aug 18 11:34:13 goofy-HPE-440ch systemd[1]: Starting Network Manager Script Dispatcher Service... Aug 18 11:34:13 goofy-HPE-440ch systemd[1]: Started Network Manager Script Dispatcher Service. Aug 18 12:02:45 goofy-HPE-440ch NetworkManager[1007]: <info> [1534586565.7643] dhcp4 (wlp5s0): address 192.168.0.229 Aug 18 12:02:45 goofy-HPE-440ch NetworkManager[1007]: <info> [1534586565.7643] dhcp4 (wlp5s0): plen 24 (255.255.255.0) Aug 18 12:02:45 goofy-HPE-440ch NetworkManager[1007]: <info> [1534586565.7644] dhcp4 (wlp5s0): gateway 192.168.0.1 Aug 18 12:02:45 goofy-HPE-440ch NetworkManager[1007]: <info> [1534586565.7644] dhcp4 (wlp5s0): lease time 3600 Aug 18 12:02:45 goofy-HPE-440ch NetworkManager[1007]: <info> [1534586565.7644] dhcp4 (wlp5s0): hostname 'goofy-HPE-440ch' Aug 18 12:02:45 goofy-HPE-440ch NetworkManager[1007]: <info> [1534586565.7645] dhcp4 (wlp5s0): nameserver '62.2.17.61' Aug 18 12:02:45 goofy-HPE-440ch NetworkManager[1007]: <info> [1534586565.7645] dhcp4 (wlp5s0): nameserver '62.2.24.158' Aug 18 12:02:45 goofy-HPE-440ch NetworkManager[1007]: <info> [1534586565.7645] dhcp4 (wlp5s0): nameserver '62.2.17.60' Aug 18 12:02:45 goofy-HPE-440ch NetworkManager[1007]: <info> [1534586565.7646] dhcp4 (wlp5s0): nameserver '62.2.24.162' Aug 18 12:02:45 goofy-HPE-440ch NetworkManager[1007]: <info> [1534586565.7646] dhcp4 (wlp5s0): domain name 'home' Aug 18 12:02:45 goofy-HPE-440ch NetworkManager[1007]: <info> [1534586565.7646] dhcp4 (wlp5s0): state changed bound -> bound Aug 18 12:02:45 goofy-HPE-440ch dbus-daemon[991]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.16' (uid=0 pid=1007 comm="/usr/sbin/NetworkManager --no-daemon " label="unconfined") Aug 18 12:02:45 goofy-HPE-440ch systemd[1]: Starting Network Manager Script Dispatcher Service... Aug 18 12:02:45 goofy-HPE-440ch systemd[1]: Started Network Manager Script Dispatcher Service. Aug 18 12:05:04 goofy-HPE-440ch NetworkManager[1007]: <info> [1534586704.6549] manager: NetworkManager state is now CONNECTED_SITE Aug 18 12:05:04 goofy-HPE-440ch dbus-daemon[991]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.16' (uid=0 pid=1007 comm="/usr/sbin/NetworkManager --no-daemon " label="unconfined") Aug 18 12:05:04 goofy-HPE-440ch systemd[1]: Starting Network Manager Script Dispatcher Service... Aug 18 12:05:04 goofy-HPE-440ch systemd[1]: Started Network Manager Script Dispatcher Service. Aug 18 12:09:51 goofy-HPE-440ch NetworkManager[1007]: <info> [1534586991.7731] manager: NetworkManager state is now CONNECTED_GLOBAL Aug 18 12:09:52 goofy-HPE-440ch dbus-daemon[991]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.16' (uid=0 pid=1007 comm="/usr/sbin/NetworkManager --no-daemon " label="unconfined") Aug 18 12:09:52 goofy-HPE-440ch systemd[1]: Starting Network Manager Script Dispatcher Service... Aug 18 12:09:52 goofy-HPE-440ch whoopsie[1259]: [12:09:51] The default IPv4 route is: /org/freedesktop/NetworkManager/ActiveConnection/1 Aug 18 12:09:52 goofy-HPE-440ch whoopsie[1259]: [12:09:51] Not a paid data plan: /org/freedesktop/NetworkManager/ActiveConnection/1 Aug 18 12:09:52 goofy-HPE-440ch whoopsie[1259]: [12:09:51] Found usable connection: /org/freedesktop/NetworkManager/ActiveConnection/1 Aug 18 12:09:52 goofy-HPE-440ch systemd[1]: Started Network Manager Script Dispatcher Service. Aug 18 12:30:14 goofy-HPE-440ch NetworkManager[1007]: <info> [1534588214.9178] dhcp4 (wlp5s0): address 192.168.0.229 Aug 18 12:30:14 goofy-HPE-440ch NetworkManager[1007]: <info> [1534588214.9179] dhcp4 (wlp5s0): plen 24 (255.255.255.0) Aug 18 12:30:14 goofy-HPE-440ch NetworkManager[1007]: <info> [1534588214.9179] dhcp4 (wlp5s0): gateway 192.168.0.1 Aug 18 12:30:14 goofy-HPE-440ch NetworkManager[1007]: <info> [1534588214.9180] dhcp4 (wlp5s0): lease time 3600 Aug 18 12:30:14 goofy-HPE-440ch NetworkManager[1007]: <info> [1534588214.9180] dhcp4 (wlp5s0): hostname 'goofy-HPE-440ch' Aug 18 12:30:14 goofy-HPE-440ch NetworkManager[1007]: <info> [1534588214.9180] dhcp4 (wlp5s0): nameserver '62.2.17.61' Aug 18 12:30:14 goofy-HPE-440ch NetworkManager[1007]: <info> [1534588214.9181] dhcp4 (wlp5s0): nameserver '62.2.24.158' Aug 18 12:30:14 goofy-HPE-440ch NetworkManager[1007]: <info> [1534588214.9181] dhcp4 (wlp5s0): nameserver '62.2.17.60' Aug 18 12:30:14 goofy-HPE-440ch NetworkManager[1007]: <info> [1534588214.9181] dhcp4 (wlp5s0): nameserver '62.2.24.162' Aug 18 12:30:14 goofy-HPE-440ch NetworkManager[1007]: <info> [1534588214.9181] dhcp4 (wlp5s0): domain name 'home' Aug 18 12:30:14 goofy-HPE-440ch NetworkManager[1007]: <info> [1534588214.9182] dhcp4 (wlp5s0): state changed bound -> bound Aug 18 12:30:14 goofy-HPE-440ch dbus-daemon[991]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.16' (uid=0 pid=1007 comm="/usr/sbin/NetworkManager --no-daemon " label="unconfined") Aug 18 12:30:14 goofy-HPE-440ch systemd[1]: Starting Network Manager Script Dispatcher Service... Aug 18 12:30:14 goofy-HPE-440ch systemd[1]: Started Network Manager Script Dispatcher Service. Aug 18 12:47:42 goofy-HPE-440ch gnome-shell[1193]: Removing a network device that was not added Aug 18 12:47:42 goofy-HPE-440ch ModemManager[995]: <info> (net/irda0): released by modem /sys/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.3/1-1.3.3/1-1.3.3.3 Aug 18 12:47:42 goofy-HPE-440ch NetworkManager[1007]: <info> [1534589261.8125] devices removed (path: /sys/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.3/1-1.3.3/1-1.3.3.3/1-1.3.3.3:1.0/net/irda0, iface: irda0) Aug 18 12:59:07 goofy-HPE-440ch NetworkManager[1007]: <info> [1534589947.2509] dhcp4 (wlp5s0): address 192.168.0.229 Aug 18 12:59:07 goofy-HPE-440ch NetworkManager[1007]: <info> [1534589947.2509] dhcp4 (wlp5s0): plen 24 (255.255.255.0) Aug 18 12:59:07 goofy-HPE-440ch dbus-daemon[991]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.16' (uid=0 pid=1007 comm="/usr/sbin/NetworkManager --no-daemon " label="unconfined") Aug 18 12:59:07 goofy-HPE-440ch NetworkManager[1007]: <info> [1534589947.2510] dhcp4 (wlp5s0): gateway 192.168.0.1 Aug 18 12:59:07 goofy-HPE-440ch NetworkManager[1007]: <info> [1534589947.2510] dhcp4 (wlp5s0): lease time 3600 Aug 18 12:59:07 goofy-HPE-440ch NetworkManager[1007]: <info> [1534589947.2511] dhcp4 (wlp5s0): hostname 'goofy-HPE-440ch' Aug 18 12:59:07 goofy-HPE-440ch NetworkManager[1007]: <info> [1534589947.2511] dhcp4 (wlp5s0): nameserver '62.2.17.61' Aug 18 12:59:07 goofy-HPE-440ch NetworkManager[1007]: <info> [1534589947.2511] dhcp4 (wlp5s0): nameserver '62.2.24.158' Aug 18 12:59:07 goofy-HPE-440ch NetworkManager[1007]: <info> [1534589947.2512] dhcp4 (wlp5s0): nameserver '62.2.17.60' Aug 18 12:59:07 goofy-HPE-440ch NetworkManager[1007]: <info> [1534589947.2512] dhcp4 (wlp5s0): nameserver '62.2.24.162' Aug 18 12:59:07 goofy-HPE-440ch NetworkManager[1007]: <info> [1534589947.2512] dhcp4 (wlp5s0): domain name 'home' Aug 18 12:59:07 goofy-HPE-440ch NetworkManager[1007]: <info> [1534589947.2513] dhcp4 (wlp5s0): state changed bound -> bound Aug 18 12:59:07 goofy-HPE-440ch systemd[1]: Starting Network Manager Script Dispatcher Service... Aug 18 12:59:07 goofy-HPE-440ch systemd[1]: Started Network Manager Script Dispatcher Service. Aug 18 13:28:30 goofy-HPE-440ch keyboard-setup.sh[342]: Datei /tmp/tmpkbd.8KyGaS kann nicht geöffnet werden. Aug 18 13:28:30 goofy-HPE-440ch kernel: [ 0.056439] NET: Registered protocol family 16 Aug 18 13:28:30 goofy-HPE-440ch kernel: [ 0.056439] audit: initializing netlink subsys (disabled) Aug 18 13:28:30 goofy-HPE-440ch systemd[1]: Starting Raise network interfaces... Aug 18 13:28:30 goofy-HPE-440ch systemd[1]: Started Raise network interfaces. Aug 18 13:28:30 goofy-HPE-440ch systemd[1]: Starting Network Time Synchronization... Aug 18 13:28:30 goofy-HPE-440ch systemd[1]: Starting Network Name Resolution... Aug 18 13:28:30 goofy-HPE-440ch kernel: [ 0.148958] NetLabel: Initializing Aug 18 13:28:30 goofy-HPE-440ch kernel: [ 0.148958] NetLabel: domain hash size = 128 Aug 18 13:28:30 goofy-HPE-440ch kernel: [ 0.148959] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO Aug 18 13:28:30 goofy-HPE-440ch kernel: [ 0.148973] NetLabel: unlabeled traffic allowed by default Aug 18 13:28:30 goofy-HPE-440ch systemd-resolved[980]: Negative trust anchors: 10.in-addr.arpa 16.172.in-addr.arpa 17.172.in-addr.arpa 18.172.in-addr.arpa 19.172.in-addr.arpa 20.172.in-addr.arpa 21.172.in-addr.arpa 22.172.in-addr.arpa 23.172.in-addr.arpa 24.172.in-addr.arpa 25.172.in-addr.arpa 26.172.in-addr.arpa 27.172.in-addr.arpa 28.172.in-addr.arpa 29.172.in-addr.arpa 30.172.in-addr.arpa 31.172.in-addr.arpa 168.192.in-addr.arpa d.f.ip6.arpa corp home internal intranet lan local private test Aug 18 13:28:30 goofy-HPE-440ch systemd[1]: Started Network Time Synchronization. Aug 18 13:28:30 goofy-HPE-440ch systemd[1]: Started Network Name Resolution. Aug 18 13:28:30 goofy-HPE-440ch systemd[1]: Starting Dispatcher daemon for systemd-networkd... Aug 18 13:28:30 goofy-HPE-440ch systemd[1]: Starting Anonymizing overlay network for TCP (multi-instance-master)... Aug 18 13:28:30 goofy-HPE-440ch kernel: [ 0.170824] NET: Registered protocol family 2 Aug 18 13:28:30 goofy-HPE-440ch kernel: [ 0.171400] NET: Registered protocol family 1 Aug 18 13:28:30 goofy-HPE-440ch acpid: starting up with netlink and the input layer Aug 18 13:28:30 goofy-HPE-440ch systemd[1]: Starting Network Manager... Aug 18 13:28:30 goofy-HPE-440ch systemd[1]: Reached target Host and Network Name Lookups. Aug 18 13:28:30 goofy-HPE-440ch systemd[1]: Started Anonymizing overlay network for TCP (multi-instance-master). Aug 18 13:28:30 goofy-HPE-440ch kernel: [ 0.962089] NET: Registered protocol family 10 Aug 18 13:28:30 goofy-HPE-440ch kernel: [ 0.967093] NET: Registered protocol family 17 Aug 18 13:28:30 goofy-HPE-440ch avahi-daemon[986]: Network interface enumeration completed. Aug 18 13:28:30 goofy-HPE-440ch kernel: [ 1.101681] r8169 Gigabit Ethernet driver 2.3LK-NAPI loaded Aug 18 13:28:30 goofy-HPE-440ch kernel: [ 1.102266] r8169 0000:02:00.0 eth0: RTL8168d/8111d at 0x (ptrval), 6c:62:6d:7e:4b:9c, XID 081000c0 IRQ 37 Aug 18 13:28:30 goofy-HPE-440ch kernel: [ 1.102268] r8169 0000:02:00.0 eth0: jumbo features [frames: 9200 bytes, tx checksumming: ko] Aug 18 13:28:30 goofy-HPE-440ch kernel: [ 1.119874] r8169 0000:02:00.0 enp2s0: renamed from eth0 Aug 18 13:28:30 goofy-HPE-440ch kernel: [ 16.046430] ip_tables: (C) 2000-2006 Netfilter Core Team Aug 18 13:28:30 goofy-HPE-440ch kernel: [ 36.103184] rt2800pci 0000:05:00.0 wlp5s0: renamed from wlan0 Aug 18 13:28:30 goofy-HPE-440ch kernel: [ 36.534772] audit: type=1400 audit(1534591703.051:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/NetworkManager/nm-dhcp-client.action" pid=829 comm="apparmor_parser" Aug 18 13:28:30 goofy-HPE-440ch kernel: [ 36.534776] audit: type=1400 audit(1534591703.051:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/NetworkManager/nm-dhcp-helper" pid=829 comm="apparmor_parser" Aug 18 13:28:31 goofy-HPE-440ch networkd-dispatcher[984]: WARNING: systemd-networkd is not running, output will be incomplete. Aug 18 13:28:31 goofy-HPE-440ch systemd[1]: Started Dispatcher daemon for systemd-networkd. Aug 18 13:28:32 goofy-HPE-440ch NetworkManager[1008]: <info> [1534591712.4784] NetworkManager (version 1.10.6) is starting... (for the first time) Aug 18 13:28:32 goofy-HPE-440ch NetworkManager[1008]: <info> [1534591712.4784] Read config: /etc/NetworkManager/NetworkManager.conf (lib: 10-dns-resolved.conf, 20-connectivity-ubuntu.conf, no-mac-addr-change.conf) (run: 10-globally-managed-devices.conf) (etc: default-wifi-powersave-on.conf) Aug 18 13:28:32 goofy-HPE-440ch NetworkManager[1008]: <info> [1534591712.5362] manager[0x560240680060]: monitoring kernel firmware directory '/lib/firmware'. Aug 18 13:28:32 goofy-HPE-440ch NetworkManager[1008]: <info> [1534591712.5362] monitoring ifupdown state file '/run/network/ifstate'. Aug 18 13:28:32 goofy-HPE-440ch dbus-daemon[1006]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service' requested by ':1.13' (uid=0 pid=1008 comm="/usr/sbin/NetworkManager --no-daemon " label="unconfined") Aug 18 13:28:32 goofy-HPE-440ch NetworkManager[1008]: <info> [1534591712.7596] hostname: hostname: using hostnamed Aug 18 13:28:32 goofy-HPE-440ch NetworkManager[1008]: <info> [1534591712.7596] hostname: hostname changed from (none) to "goofy-HPE-440ch" Aug 18 13:28:32 goofy-HPE-440ch NetworkManager[1008]: <info> [1534591712.7599] dns-mgr[0x56024069c140]: init: dns=systemd-resolved, rc-manager=symlink, plugin=systemd-resolved Aug 18 13:28:32 goofy-HPE-440ch NetworkManager[1008]: <info> [1534591712.7608] rfkill0: found WiFi radio killswitch (at /sys/devices/pci0000:00/0000:00:1c.5/0000:05:00.0/ieee80211/phy0/rfkill0) (driver rt2800pci) Aug 18 13:28:32 goofy-HPE-440ch NetworkManager[1008]: <info> [1534591712.7609] manager[0x560240680060]: rfkill: WiFi hardware radio set enabled Aug 18 13:28:32 goofy-HPE-440ch NetworkManager[1008]: <info> [1534591712.7610] manager[0x560240680060]: rfkill: WWAN hardware radio set enabled Aug 18 13:28:32 goofy-HPE-440ch systemd[1]: Started Network Manager. Aug 18 13:28:32 goofy-HPE-440ch systemd[1]: Reached target Network. Aug 18 13:28:32 goofy-HPE-440ch systemd[1]: Starting Anonymizing overlay network for TCP... Aug 18 13:28:32 goofy-HPE-440ch systemd[1]: Starting Network Manager Wait Online... Aug 18 13:28:32 goofy-HPE-440ch dbus-daemon[1006]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.13' (uid=0 pid=1008 comm="/usr/sbin/NetworkManager --no-daemon " label="unconfined") Aug 18 13:28:32 goofy-HPE-440ch systemd[1]: Starting Network Manager Script Dispatcher Service... Aug 18 13:28:33 goofy-HPE-440ch systemd[1]: Started Network Manager Script Dispatcher Service. Aug 18 13:28:33 goofy-HPE-440ch NetworkManager[1008]: <info> [1534591713.1040] init! Aug 18 13:28:33 goofy-HPE-440ch NetworkManager[1008]: <info> [1534591713.1042] interface-parser: parsing file /etc/network/interfaces Aug 18 13:28:33 goofy-HPE-440ch NetworkManager[1008]: <info> [1534591713.1042] interface-parser: finished parsing file /etc/network/interfaces Aug 18 13:28:33 goofy-HPE-440ch NetworkManager[1008]: <info> [1534591713.1042] management mode: unmanaged Aug 18 13:28:33 goofy-HPE-440ch NetworkManager[1008]: <info> [1534591713.1047] devices added (path: /sys/devices/pci0000:00/0000:00:1c.0/0000:02:00.0/net/enp2s0, iface: enp2s0) Aug 18 13:28:33 goofy-HPE-440ch NetworkManager[1008]: <info> [1534591713.1047] device added (path: /sys/devices/pci0000:00/0000:00:1c.0/0000:02:00.0/net/enp2s0, iface: enp2s0): no ifupdown configuration found. Aug 18 13:28:33 goofy-HPE-440ch NetworkManager[1008]: <info> [1534591713.1048] devices added (path: /sys/devices/pci0000:00/0000:00:1c.5/0000:05:00.0/net/wlp5s0, iface: wlp5s0) Aug 18 13:28:33 goofy-HPE-440ch NetworkManager[1008]: <info> [1534591713.1048] device added (path: /sys/devices/pci0000:00/0000:00:1c.5/0000:05:00.0/net/wlp5s0, iface: wlp5s0): no ifupdown configuration found. Aug 18 13:28:33 goofy-HPE-440ch NetworkManager[1008]: <info> [1534591713.1048] devices added (path: /sys/devices/virtual/net/lo, iface: lo) Aug 18 13:28:33 goofy-HPE-440ch NetworkManager[1008]: <info> [1534591713.1048] device added (path: /sys/devices/virtual/net/lo, iface: lo): no ifupdown configuration found. Aug 18 13:28:33 goofy-HPE-440ch NetworkManager[1008]: <info> [1534591713.1049] end _init. Aug 18 13:28:33 goofy-HPE-440ch NetworkManager[1008]: <info> [1534591713.1049] settings: loaded plugin ifupdown: (C) 2008 Canonical Ltd. To report bugs please use the NetworkManager mailing list. (/usr/lib/x86_64-linux-gnu/NetworkManager/libnm-settings-plugin-ifupdown.so) Aug 18 13:28:33 goofy-HPE-440ch NetworkManager[1008]: <info> [1534591713.1049] settings: loaded plugin keyfile: (c) 2007 - 2016 Red Hat, Inc. To report bugs please use the NetworkManager mailing list. Aug 18 13:28:33 goofy-HPE-440ch NetworkManager[1008]: <info> [1534591713.1049] (1080794368) ... get_connections. Aug 18 13:28:33 goofy-HPE-440ch NetworkManager[1008]: <info> [1534591713.1049] (1080794368) ... get_connections (managed=false): return empty list. Aug 18 13:28:33 goofy-HPE-440ch NetworkManager[1008]: <info> [1534591713.1112] keyfile: new connection /etc/NetworkManager/system-connections/UPCD77DC9F (cdc552d2-ea16-4ebd-8203-3f46fb80cc3c,"UPCD77DC9F") Aug 18 13:28:33 goofy-HPE-440ch NetworkManager[1008]: <info> [1534591713.1115] get unmanaged devices count: 0 Aug 18 13:28:33 goofy-HPE-440ch NetworkManager[1008]: <info> [1534591713.1115] manager: rfkill: WiFi enabled by radio killswitch; enabled by state file Aug 18 13:28:33 goofy-HPE-440ch NetworkManager[1008]: <info> [1534591713.1116] manager: rfkill: WWAN enabled by radio killswitch; enabled by state file Aug 18 13:28:33 goofy-HPE-440ch NetworkManager[1008]: <info> [1534591713.1116] manager: Networking is enabled by state file Aug 18 13:28:33 goofy-HPE-440ch NetworkManager[1008]: <info> [1534591713.1117] dhcp-init: Using DHCP client 'dhclient' Aug 18 13:28:33 goofy-HPE-440ch NetworkManager[1008]: <info> [1534591713.1118] Loaded device plugin: NMBondDeviceFactory (internal) Aug 18 13:28:33 goofy-HPE-440ch NetworkManager[1008]: <info> [1534591713.1118] Loaded device plugin: NMBridgeDeviceFactory (internal) Aug 18 13:28:33 goofy-HPE-440ch NetworkManager[1008]: <info> [1534591713.1118] Loaded device plugin: NMDummyDeviceFactory (internal) Aug 18 13:28:33 goofy-HPE-440ch NetworkManager[1008]: <info> [1534591713.1118] Loaded device plugin: NMEthernetDeviceFactory (internal) Aug 18 13:28:33 goofy-HPE-440ch NetworkManager[1008]: <info> [1534591713.1119] Loaded device plugin: NMInfinibandDeviceFactory (internal) Aug 18 13:28:33 goofy-HPE-440ch NetworkManager[1008]: <info> [1534591713.1119] Loaded device plugin: NMIPTunnelDeviceFactory (internal) Aug 18 13:28:33 goofy-HPE-440ch NetworkManager[1008]: <info> [1534591713.1119] Loaded device plugin: NMMacsecDeviceFactory (internal) Aug 18 13:28:33 goofy-HPE-440ch NetworkManager[1008]: <info> [1534591713.1120] Loaded device plugin: NMMacvlanDeviceFactory (internal) Aug 18 13:28:33 goofy-HPE-440ch NetworkManager[1008]: <info> [1534591713.1120] Loaded device plugin: NMPppDeviceFactory (internal) Aug 18 13:28:33 goofy-HPE-440ch NetworkManager[1008]: <info> [1534591713.1120] Loaded device plugin: NMTunDeviceFactory (internal) Aug 18 13:28:33 goofy-HPE-440ch NetworkManager[1008]: <info> [1534591713.1120] Loaded device plugin: NMVethDeviceFactory (internal) Aug 18 13:28:33 goofy-HPE-440ch NetworkManager[1008]: <info> [1534591713.1120] Loaded device plugin: NMVlanDeviceFactory (internal) Aug 18 13:28:33 goofy-HPE-440ch NetworkManager[1008]: <info> [1534591713.1121] Loaded device plugin: NMVxlanDeviceFactory (internal) Aug 18 13:28:33 goofy-HPE-440ch NetworkManager[1008]: <info> [1534591713.1993] Loaded device plugin: NMTeamFactory (/usr/lib/x86_64-linux-gnu/NetworkManager/libnm-device-plugin-team.so) Aug 18 13:28:33 goofy-HPE-440ch NetworkManager[1008]: <info> [1534591713.1996] Loaded device plugin: NMWifiFactory (/usr/lib/x86_64-linux-gnu/NetworkManager/libnm-device-plugin-wifi.so) Aug 18 13:28:33 goofy-HPE-440ch NetworkManager[1008]: <info> [1534591713.2003] Loaded device plugin: NMWwanFactory (/usr/lib/x86_64-linux-gnu/NetworkManager/libnm-device-plugin-wwan.so) Aug 18 13:28:33 goofy-HPE-440ch NetworkManager[1008]: <info> [1534591713.2917] Loaded device plugin: NMBluezManager (/usr/lib/x86_64-linux-gnu/NetworkManager/libnm-device-plugin-bluetooth.so) Aug 18 13:28:33 goofy-HPE-440ch NetworkManager[1008]: <info> [1534591713.2920] Loaded device plugin: NMAtmManager (/usr/lib/x86_64-linux-gnu/NetworkManager/libnm-device-plugin-adsl.so) Aug 18 13:28:33 goofy-HPE-440ch NetworkManager[1008]: <info> [1534591713.2927] device (lo): carrier: link connected Aug 18 13:28:33 goofy-HPE-440ch NetworkManager[1008]: <info> [1534591713.2933] manager: (lo): new Generic device (/org/freedesktop/NetworkManager/Devices/1) Aug 18 13:28:33 goofy-HPE-440ch NetworkManager[1008]: <info> [1534591713.2944] manager: (enp2s0): new Ethernet device (/org/freedesktop/NetworkManager/Devices/2) Aug 18 13:28:33 goofy-HPE-440ch NetworkManager[1008]: <info> [1534591713.2955] keyfile: add connection in-memory (eeeef268-4618-373e-b5b1-6f205339662a,"Kabelgebundene Verbindung 1") Aug 18 13:28:33 goofy-HPE-440ch NetworkManager[1008]: <info> [1534591713.2960] settings: (enp2s0): created default wired connection 'Kabelgebundene Verbindung 1' Aug 18 13:28:33 goofy-HPE-440ch NetworkManager[1008]: <info> [1534591713.2968] device (enp2s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external') Aug 18 13:28:33 goofy-HPE-440ch kernel: [ 46.774082] IPv6: ADDRCONF(NETDEV_UP): enp2s0: link is not ready Aug 18 13:28:33 goofy-HPE-440ch kernel: [ 46.909612] IPv6: ADDRCONF(NETDEV_UP): enp2s0: link is not ready Aug 18 13:28:33 goofy-HPE-440ch NetworkManager[1008]: <info> [1534591713.5813] wifi-nl80211: (wlp5s0): using nl80211 for WiFi device control Aug 18 13:28:33 goofy-HPE-440ch NetworkManager[1008]: <info> [1534591713.5815] device (wlp5s0): driver supports Access Point (AP) mode Aug 18 13:28:33 goofy-HPE-440ch NetworkManager[1008]: <info> [1534591713.5823] manager: (wlp5s0): new 802.11 WiFi device (/org/freedesktop/NetworkManager/Devices/3) Aug 18 13:28:33 goofy-HPE-440ch NetworkManager[1008]: <info> [1534591713.5832] device (wlp5s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external') Aug 18 13:28:33 goofy-HPE-440ch kernel: [ 47.060491] IPv6: ADDRCONF(NETDEV_UP): wlp5s0: link is not ready Aug 18 13:28:33 goofy-HPE-440ch kernel: [ 47.060547] ieee80211 phy0: rt2x00lib_request_firmware: Info - Loading firmware file 'rt2860.bin' Aug 18 13:28:33 goofy-HPE-440ch kernel: [ 47.193192] ieee80211 phy0: rt2x00lib_request_firmware: Info - Firmware detected - version: 0.40 Aug 18 13:28:33 goofy-HPE-440ch kernel: [ 47.377468] IPv6: ADDRCONF(NETDEV_UP): wlp5s0: link is not ready Aug 18 13:28:33 goofy-HPE-440ch NetworkManager[1008]: <info> [1534591713.9101] modem-manager: ModemManager available Aug 18 13:28:33 goofy-HPE-440ch NetworkManager[1008]: <info> [1534591713.9111] supplicant: wpa_supplicant running Aug 18 13:28:33 goofy-HPE-440ch NetworkManager[1008]: <info> [1534591713.9111] device (wlp5s0): supplicant interface state: init -> starting Aug 18 13:28:34 goofy-HPE-440ch NetworkManager[1008]: <info> [1534591714.1459] device (wlp5s0): supplicant interface state: starting -> ready Aug 18 13:28:34 goofy-HPE-440ch NetworkManager[1008]: <info> [1534591714.1460] device (wlp5s0): state change: unavailable -> disconnected (reason 'supplicant-available', sys-iface-state: 'managed') Aug 18 13:28:34 goofy-HPE-440ch kernel: [ 47.623236] IPv6: ADDRCONF(NETDEV_UP): wlp5s0: link is not ready Aug 18 13:28:35 goofy-HPE-440ch NetworkManager[1008]: <info> [1534591715.1996] policy: auto-activating connection 'UPCD77DC9F' Aug 18 13:28:35 goofy-HPE-440ch NetworkManager[1008]: <info> [1534591715.2006] device (wlp5s0): Activation: starting connection 'UPCD77DC9F' (cdc552d2-ea16-4ebd-8203-3f46fb80cc3c) Aug 18 13:28:35 goofy-HPE-440ch NetworkManager[1008]: <info> [1534591715.2009] device (wlp5s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed') Aug 18 13:28:35 goofy-HPE-440ch NetworkManager[1008]: <info> [1534591715.2011] manager: NetworkManager state is now CONNECTING Aug 18 13:28:35 goofy-HPE-440ch NetworkManager[1008]: <info> [1534591715.2017] device (wlp5s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed') Aug 18 13:28:35 goofy-HPE-440ch NetworkManager[1008]: <info> [1534591715.2019] device (wlp5s0): Activation: (wifi) access point 'UPCD77DC9F' has security, but secrets are required. Aug 18 13:28:35 goofy-HPE-440ch NetworkManager[1008]: <info> [1534591715.2019] device (wlp5s0): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed') Aug 18 13:28:35 goofy-HPE-440ch NetworkManager[1008]: <info> [1534591715.2021] sup-iface[0x560240653240,wlp5s0]: wps: type pbc start... Aug 18 13:28:35 goofy-HPE-440ch NetworkManager[1008]: <info> [1534591715.2052] device (wlp5s0): state change: need-auth -> prepare (reason 'none', sys-iface-state: 'managed') Aug 18 13:28:35 goofy-HPE-440ch NetworkManager[1008]: <info> [1534591715.2057] device (wlp5s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed') Aug 18 13:28:35 goofy-HPE-440ch NetworkManager[1008]: <info> [1534591715.2059] device (wlp5s0): Activation: (wifi) connection 'UPCD77DC9F' has security, and secrets exist. No new secrets needed. Aug 18 13:28:35 goofy-HPE-440ch NetworkManager[1008]: <info> [1534591715.2060] Config: added 'ssid' value 'UPCD77DC9F' Aug 18 13:28:35 goofy-HPE-440ch NetworkManager[1008]: <info> [1534591715.2060] Config: added 'scan_ssid' value '1' Aug 18 13:28:35 goofy-HPE-440ch NetworkManager[1008]: <info> [1534591715.2060] Config: added 'bgscan' value 'simple:30:-80:86400' Aug 18 13:28:35 goofy-HPE-440ch NetworkManager[1008]: <info> [1534591715.2060] Config: added 'key_mgmt' value 'WPA-PSK' Aug 18 13:28:35 goofy-HPE-440ch NetworkManager[1008]: <info> [1534591715.2060] Config: added 'auth_alg' value 'OPEN' Aug 18 13:28:35 goofy-HPE-440ch NetworkManager[1008]: <info> [1534591715.2061] Config: added 'psk' value '<hidden>' Aug 18 13:28:35 goofy-HPE-440ch NetworkManager[1008]: <info> [1534591715.2199] device (wlp5s0): supplicant interface state: ready -> authenticating Aug 18 13:28:35 goofy-HPE-440ch NetworkManager[1008]: <info> [1534591715.2275] device (wlp5s0): supplicant interface state: authenticating -> associating Aug 18 13:28:35 goofy-HPE-440ch wpa_supplicant[1009]: wlp5s0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0 Aug 18 13:28:35 goofy-HPE-440ch NetworkManager[1008]: <info> [1534591715.2369] device (wlp5s0): supplicant interface state: associating -> associated Aug 18 13:28:35 goofy-HPE-440ch NetworkManager[1008]: <info> [1534591715.4578] device (wlp5s0): supplicant interface state: associated -> completed Aug 18 13:28:35 goofy-HPE-440ch NetworkManager[1008]: <info> [1534591715.4578] device (wlp5s0): Activation: (wifi) Stage 2 of 5 (Device Configure) successful. Connected to wireless network 'UPCD77DC9F'. Aug 18 13:28:35 goofy-HPE-440ch NetworkManager[1008]: <info> [1534591715.4580] device (wlp5s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed') Aug 18 13:28:35 goofy-HPE-440ch kernel: [ 48.934092] IPv6: ADDRCONF(NETDEV_CHANGE): wlp5s0: link becomes ready Aug 18 13:28:35 goofy-HPE-440ch NetworkManager[1008]: <info> [1534591715.5122] dhcp4 (wlp5s0): activation: beginning transaction (timeout in 45 seconds) Aug 18 13:28:35 goofy-HPE-440ch NetworkManager[1008]: <info> [1534591715.6619] dhcp4 (wlp5s0): dhclient started with pid 1166 Aug 18 13:28:36 goofy-HPE-440ch Tor[1143]: Bootstrapped 80%: Connecting to the Tor network Aug 18 13:28:36 goofy-HPE-440ch systemd[1]: Started Anonymizing overlay network for TCP. Aug 18 13:28:36 goofy-HPE-440ch systemd[1142]: Listening on GnuPG network certificate management daemon. Aug 18 13:28:36 goofy-HPE-440ch Tor[1143]: Problem bootstrapping. Stuck at 80%: Connecting to the Tor network. (Network is unreachable; NOROUTE; count 1; recommendation warn; host 8FD3BAF5E14EBE1124D6253D59882AFE1C2B9B8E at 217.182.196.65:443) Aug 18 13:28:36 goofy-HPE-440ch Tor[1143]: Problem bootstrapping. Stuck at 80%: Connecting to the Tor network. (Network is unreachable; NOROUTE; count 2; recommendation warn; host 8FD3BAF5E14EBE1124D6253D59882AFE1C2B9B8E at 217.182.196.65:443) Aug 18 13:28:36 goofy-HPE-440ch Tor[1143]: Problem bootstrapping. Stuck at 80%: Connecting to the Tor network. (Network is unreachable; NOROUTE; count 3; recommendation warn; host 0266B0660F3F20A7D1F3D8335931C95EF50F6C6B at 62.210.92.11:9001) Aug 18 13:28:36 goofy-HPE-440ch NetworkManager[1008]: <info> [1534591716.1556] dhcp4 (wlp5s0): address 192.168.0.229 Aug 18 13:28:36 goofy-HPE-440ch NetworkManager[1008]: <info> [1534591716.1556] dhcp4 (wlp5s0): plen 24 (255.255.255.0) Aug 18 13:28:36 goofy-HPE-440ch NetworkManager[1008]: <info> [1534591716.1556] dhcp4 (wlp5s0): gateway 192.168.0.1 Aug 18 13:28:36 goofy-HPE-440ch NetworkManager[1008]: <info> [1534591716.1557] dhcp4 (wlp5s0): lease time 3600 Aug 18 13:28:36 goofy-HPE-440ch NetworkManager[1008]: <info> [1534591716.1557] dhcp4 (wlp5s0): hostname 'goofy-HPE-440ch' Aug 18 13:28:36 goofy-HPE-440ch NetworkManager[1008]: <info> [1534591716.1558] dhcp4 (wlp5s0): nameserver '62.2.17.61' Aug 18 13:28:36 goofy-HPE-440ch NetworkManager[1008]: <info> [1534591716.1558] dhcp4 (wlp5s0): nameserver '62.2.24.158' Aug 18 13:28:36 goofy-HPE-440ch NetworkManager[1008]: <info> [1534591716.1559] dhcp4 (wlp5s0): nameserver '62.2.17.60' Aug 18 13:28:36 goofy-HPE-440ch NetworkManager[1008]: <info> [1534591716.1559] dhcp4 (wlp5s0): nameserver '62.2.24.162' Aug 18 13:28:36 goofy-HPE-440ch NetworkManager[1008]: <info> [1534591716.1559] dhcp4 (wlp5s0): domain name 'home' Aug 18 13:28:36 goofy-HPE-440ch NetworkManager[1008]: <info> [1534591716.1560] dhcp4 (wlp5s0): state changed unknown -> bound Aug 18 13:28:36 goofy-HPE-440ch NetworkManager[1008]: <info> [1534591716.1585] device (wlp5s0): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed') Aug 18 13:28:36 goofy-HPE-440ch NetworkManager[1008]: <info> [1534591716.1592] device (wlp5s0): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed') Aug 18 13:28:36 goofy-HPE-440ch NetworkManager[1008]: <info> [1534591716.1595] device (wlp5s0): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed') Aug 18 13:28:36 goofy-HPE-440ch NetworkManager[1008]: <info> [1534591716.1597] manager: NetworkManager state is now CONNECTED_LOCAL Aug 18 13:28:36 goofy-HPE-440ch NetworkManager[1008]: <info> [1534591716.2977] manager: NetworkManager state is now CONNECTED_SITE Aug 18 13:28:36 goofy-HPE-440ch NetworkManager[1008]: <info> [1534591716.2978] policy: set 'UPCD77DC9F' (wlp5s0) as default for IPv4 routing and DNS Aug 18 13:28:36 goofy-HPE-440ch NetworkManager[1008]: <info> [1534591716.2982] device (wlp5s0): Activation: successful, device activated. Aug 18 13:28:37 goofy-HPE-440ch NetworkManager[1008]: <info> [1534591717.6074] manager: NetworkManager state is now CONNECTED_GLOBAL Aug 18 13:28:39 goofy-HPE-440ch NetworkManager[1008]: <info> [1534591719.4344] manager: startup complete Aug 18 13:28:39 goofy-HPE-440ch systemd[1]: Started Network Manager Wait Online. Aug 18 13:28:39 goofy-HPE-440ch systemd[1]: Reached target Network is Online. Aug 18 13:28:40 goofy-HPE-440ch whoopsie[1243]: [13:28:40] The default IPv4 route is: /org/freedesktop/NetworkManager/ActiveConnection/1 Aug 18 13:28:40 goofy-HPE-440ch whoopsie[1243]: [13:28:40] Not a paid data plan: /org/freedesktop/NetworkManager/ActiveConnection/1 Aug 18 13:28:40 goofy-HPE-440ch whoopsie[1243]: [13:28:40] Found usable connection: /org/freedesktop/NetworkManager/ActiveConnection/1 Aug 18 13:29:02 goofy-HPE-440ch systemd[1627]: Listening on GnuPG network certificate management daemon. Aug 18 13:29:03 goofy-HPE-440ch /usr/lib/gdm3/gdm-x-session[1645]: (WW) Falling back to old probe method for modesetting Aug 18 13:29:03 goofy-HPE-440ch /usr/lib/gdm3/gdm-x-session[1645]: (WW) Falling back to old probe method for fbdev Aug 18 13:29:03 goofy-HPE-440ch /usr/lib/gdm3/gdm-x-session[1645]: (WW) Falling back to old probe method for vesa Aug 18 13:29:04 goofy-HPE-440ch /usr/lib/gdm3/gdm-x-session[1645]: dbus-update-activation-environment: setting LC_MONETARY=de_CH.UTF-8 Aug 18 13:29:14 goofy-HPE-440ch gsd-color[1912]: failed to set screen _ICC_PROFILE: Datei »/var/lib/gdm3/.local/share/icc/edid-b431be1d4b354b2c22b0bc9237b6e8ab.icc« konnte nicht geöffnet werden: Keine Berechtigung Aug 18 13:29:21 goofy-HPE-440ch systemd[1]: Starting Firmware update daemon... Aug 18 13:29:23 goofy-HPE-440ch fwupd[2109]: disabling plugin because: failed to startup dell: Firmware updating not supported Aug 18 13:29:23 goofy-HPE-440ch fwupd[2109]: disabling plugin because: failed to startup uefi: UEFI firmware updating not supported Aug 18 13:29:23 goofy-HPE-440ch fwupd[2109]: disabling plugin because: failed to coldplug synapticsmst: MST firmware updating not supported by OEM Aug 18 13:29:24 goofy-HPE-440ch systemd[1]: Started Firmware update daemon. Aug 18 13:29:47 goofy-HPE-440ch gnome-shell[1760]: Object St.Widget (0x5595f245f790), has been already deallocated - impossible to access to it. This might be caused by the fact that the object has been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs Aug 18 13:29:47 goofy-HPE-440ch org.gnome.Shell.desktop[1760]: #3 0x5595f0c38440 i resource:///org/gnome/shell/ui/status/network.js:781 (0x7fc3b9011f78 @ 409) Aug 18 13:31:23 goofy-HPE-440ch nautilus[2474]: Called "net usershare info" but it failed: Kindprozess »net« konnte nicht ausgeführt werden (No such file or directory) Aug 18 13:33:36 goofy-HPE-440ch gnome-shell[1760]: Object St.Widget (0x5595f1ec2ed0), has been already deallocated - impossible to access to it. This might be caused by the fact that the object has been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs Aug 18 13:33:36 goofy-HPE-440ch org.gnome.Shell.desktop[1760]: #3 0x5595f0c382b8 i resource:///org/gnome/shell/ui/status/network.js:781 (0x7fc3b9011f78 @ 409) Aug 18 13:34:04 goofy-HPE-440ch org.gnome.Shell.desktop[1760]: Window manager warning: Buggy client sent a _NET_ACTIVE_WINDOW message with a timestamp of 0 for 0x280000f (Einstellun) Aug 18 13:40:18 goofy-HPE-440ch org.gnome.Shell.desktop[1760]: Window manager warning: Buggy client sent a _NET_ACTIVE_WINDOW message with a timestamp of 0 for 0x280000f (Einstellun) Aug 18 13:47:35 goofy-HPE-440ch org.gnome.Shell.desktop[1760]: Window manager warning: Buggy client sent a _NET_ACTIVE_WINDOW message with a timestamp of 0 for 0x280000f (Einstellun) Aug 18 13:48:12 goofy-HPE-440ch NetworkManager[1008]: <info> [1534592892.0682] keyfile: add connection in-memory (7952796c-6d88-4292-9ecb-fab012977407,"TP-LINK_BDDB") Aug 18 13:48:12 goofy-HPE-440ch NetworkManager[1008]: <info> [1534592892.0973] device (wlp5s0): disconnecting for new activation request. Aug 18 13:48:12 goofy-HPE-440ch NetworkManager[1008]: <info> [1534592892.0974] device (wlp5s0): state change: activated -> deactivating (reason 'new-activation', sys-iface-state: 'managed') Aug 18 13:48:12 goofy-HPE-440ch NetworkManager[1008]: <info> [1534592892.0975] manager: NetworkManager state is now DISCONNECTING Aug 18 13:48:12 goofy-HPE-440ch dbus-daemon[1006]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.13' (uid=0 pid=1008 comm="/usr/sbin/NetworkManager --no-daemon " label="unconfined") Aug 18 13:48:12 goofy-HPE-440ch NetworkManager[1008]: <info> [1534592892.2704] settings-connection[0x56024064bd20,7952796c-6d88-4292-9ecb-fab012977407]: write: successfully commited (keyfile: update /etc/NetworkManager/system-connections/TP-LINK_BDDB (7952796c-6d88-4292-9ecb-fab012977407,"TP-LINK_BDDB") and persist connection) Aug 18 13:48:12 goofy-HPE-440ch NetworkManager[1008]: <info> [1534592892.2706] audit: op="connection-add-activate" uuid="7952796c-6d88-4292-9ecb-fab012977407" name="TP-LINK_BDDB" pid=3140 uid=1000 result="success" Aug 18 13:48:12 goofy-HPE-440ch NetworkManager[1008]: <info> [1534592892.2895] device (wlp5s0): state change: deactivating -> disconnected (reason 'new-activation', sys-iface-state: 'managed') Aug 18 13:48:12 goofy-HPE-440ch systemd[1]: Starting Network Manager Script Dispatcher Service... Aug 18 13:48:12 goofy-HPE-440ch systemd[1]: Started Network Manager Script Dispatcher Service. Aug 18 13:48:12 goofy-HPE-440ch NetworkManager[1008]: <info> [1534592892.3551] dhcp4 (wlp5s0): canceled DHCP transaction, DHCP client pid 1166 Aug 18 13:48:12 goofy-HPE-440ch NetworkManager[1008]: <info> [1534592892.3551] dhcp4 (wlp5s0): state changed bound -> done Aug 18 13:48:12 goofy-HPE-440ch kernel: [ 1226.067594] wlp5s0: deauthenticating from d8:b6:b7:3c:0f:ec by local choice (Reason: 3=DEAUTH_LEAVING) Aug 18 13:48:12 goofy-HPE-440ch wpa_supplicant[1009]: wlp5s0: CTRL-EVENT-DISCONNECTED bssid=d8:b6:b7:3c:0f:ec reason=3 locally_generated=1 Aug 18 13:48:12 goofy-HPE-440ch NetworkManager[1008]: <info> [1534592892.4212] manager: NetworkManager state is now DISCONNECTED Aug 18 13:48:12 goofy-HPE-440ch NetworkManager[1008]: <info> [1534592892.4214] device (wlp5s0): Activation: starting connection 'TP-LINK_BDDB' (7952796c-6d88-4292-9ecb-fab012977407) Aug 18 13:48:12 goofy-HPE-440ch NetworkManager[1008]: <warn> [1534592892.4224] sup-iface[0x560240653240,wlp5s0]: connection disconnected (reason -3) Aug 18 13:48:12 goofy-HPE-440ch NetworkManager[1008]: <info> [1534592892.4225] device (wlp5s0): supplicant interface state: completed -> disconnected Aug 18 13:48:12 goofy-HPE-440ch NetworkManager[1008]: <info> [1534592892.4243] device (wlp5s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed') Aug 18 13:48:12 goofy-HPE-440ch NetworkManager[1008]: <info> [1534592892.4245] manager: NetworkManager state is now CONNECTING Aug 18 13:48:12 goofy-HPE-440ch NetworkManager[1008]: <info> [1534592892.4251] device (wlp5s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed') Aug 18 13:48:12 goofy-HPE-440ch NetworkManager[1008]: <info> [1534592892.4254] device (wlp5s0): Activation: (wifi) access point 'TP-LINK_BDDB' has security, but secrets are required. Aug 18 13:48:12 goofy-HPE-440ch NetworkManager[1008]: <info> [1534592892.4254] device (wlp5s0): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed') Aug 18 13:48:16 goofy-HPE-440ch NetworkManager[1008]: <warn> [1534592896.7532] device (wlp5s0): User canceled the secrets request. Aug 18 13:48:16 goofy-HPE-440ch NetworkManager[1008]: <info> [1534592896.7533] device (wlp5s0): state change: need-auth -> failed (reason 'no-secrets', sys-iface-state: 'managed') Aug 18 13:48:16 goofy-HPE-440ch NetworkManager[1008]: <info> [1534592896.7536] manager: NetworkManager state is now DISCONNECTED Aug 18 13:48:16 goofy-HPE-440ch NetworkManager[1008]: <warn> [1534592896.7543] device (wlp5s0): Activation: failed for connection 'TP-LINK_BDDB' Aug 18 13:48:16 goofy-HPE-440ch NetworkManager[1008]: <info> [1534592896.8047] device (wlp5s0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed') Aug 18 13:48:16 goofy-HPE-440ch kernel: [ 1230.516745] IPv6: ADDRCONF(NETDEV_UP): wlp5s0: link is not ready Aug 18 13:48:17 goofy-HPE-440ch NetworkManager[1008]: <info> [1534592897.8684] policy: auto-activating connection 'UPCD77DC9F' Aug 18 13:48:17 goofy-HPE-440ch NetworkManager[1008]: <info> [1534592897.8707] device (wlp5s0): Activation: starting connection 'UPCD77DC9F' (cdc552d2-ea16-4ebd-8203-3f46fb80cc3c) Aug 18 13:48:17 goofy-HPE-440ch NetworkManager[1008]: <info> [1534592897.8713] device (wlp5s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed') Aug 18 13:48:17 goofy-HPE-440ch NetworkManager[1008]: <info> [1534592897.8717] manager: NetworkManager state is now CONNECTING Aug 18 13:48:17 goofy-HPE-440ch NetworkManager[1008]: <info> [1534592897.8728] device (wlp5s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed') Aug 18 13:48:17 goofy-HPE-440ch NetworkManager[1008]: <info> [1534592897.8732] device (wlp5s0): Activation: (wifi) access point 'UPCD77DC9F' has security, but secrets are required. Aug 18 13:48:17 goofy-HPE-440ch NetworkManager[1008]: <info> [1534592897.8733] device (wlp5s0): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed') Aug 18 13:48:17 goofy-HPE-440ch NetworkManager[1008]: <info> [1534592897.8735] sup-iface[0x560240653240,wlp5s0]: wps: type pbc start... Aug 18 13:48:17 goofy-HPE-440ch NetworkManager[1008]: <info> [1534592897.8799] device (wlp5s0): state change: need-auth -> prepare (reason 'none', sys-iface-state: 'managed') Aug 18 13:48:17 goofy-HPE-440ch NetworkManager[1008]: <info> [1534592897.8805] device (wlp5s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed') Aug 18 13:48:17 goofy-HPE-440ch NetworkManager[1008]: <info> [1534592897.8808] device (wlp5s0): Activation: (wifi) connection 'UPCD77DC9F' has security, and secrets exist. No new secrets needed. Aug 18 13:48:17 goofy-HPE-440ch NetworkManager[1008]: <info> [1534592897.8809] Config: added 'ssid' value 'UPCD77DC9F' Aug 18 13:48:17 goofy-HPE-440ch NetworkManager[1008]: <info> [1534592897.8809] Config: added 'scan_ssid' value '1' Aug 18 13:48:17 goofy-HPE-440ch NetworkManager[1008]: <info> [1534592897.8809] Config: added 'bgscan' value 'simple:30:-80:86400' Aug 18 13:48:17 goofy-HPE-440ch NetworkManager[1008]: <info> [1534592897.8809] Config: added 'key_mgmt' value 'WPA-PSK' Aug 18 13:48:17 goofy-HPE-440ch NetworkManager[1008]: <info> [1534592897.8810] Config: added 'auth_alg' value 'OPEN' Aug 18 13:48:17 goofy-HPE-440ch NetworkManager[1008]: <info> [1534592897.8810] Config: added 'psk' value '<hidden>' Aug 18 13:48:17 goofy-HPE-440ch NetworkManager[1008]: <info> [1534592897.9076] device (wlp5s0): supplicant interface state: disconnected -> authenticating Aug 18 13:48:18 goofy-HPE-440ch NetworkManager[1008]: <info> [1534592898.1207] device (wlp5s0): supplicant interface state: authenticating -> disconnected Aug 18 13:48:18 goofy-HPE-440ch NetworkManager[1008]: <info> [1534592898.2207] device (wlp5s0): supplicant interface state: disconnected -> scanning Aug 18 13:48:18 goofy-HPE-440ch NetworkManager[1008]: <info> [1534592898.2865] device (wlp5s0): supplicant interface state: scanning -> authenticating Aug 18 13:48:18 goofy-HPE-440ch NetworkManager[1008]: <info> [1534592898.3151] device (wlp5s0): supplicant interface state: authenticating -> associating Aug 18 13:48:18 goofy-HPE-440ch wpa_supplicant[1009]: wlp5s0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0 Aug 18 13:48:18 goofy-HPE-440ch NetworkManager[1008]: <info> [1534592898.3388] device (wlp5s0): supplicant interface state: associating -> associated Aug 18 13:48:18 goofy-HPE-440ch NetworkManager[1008]: <info> [1534592898.4796] device (wlp5s0): supplicant interface state: associated -> 4-way handshake Aug 18 13:48:21 goofy-HPE-440ch kernel: [ 1235.195313] wlp5s0: deauthenticated from ac:22:05:cf:c3:8f (Reason: 15=4WAY_HANDSHAKE_TIMEOUT) Aug 18 13:48:21 goofy-HPE-440ch wpa_supplicant[1009]: wlp5s0: CTRL-EVENT-DISCONNECTED bssid=ac:22:05:cf:c3:8f reason=15 Aug 18 13:48:21 goofy-HPE-440ch wpa_supplicant[1009]: wlp5s0: CTRL-EVENT-SSID-TEMP-DISABLED id=0 ssid="UPCD77DC9F" auth_failures=1 duration=10 reason=WRONG_KEY Aug 18 13:48:21 goofy-HPE-440ch NetworkManager[1008]: <warn> [1534592901.5275] sup-iface[0x560240653240,wlp5s0]: connection disconnected (reason 15) Aug 18 13:48:21 goofy-HPE-440ch NetworkManager[1008]: <info> [1534592901.5325] device (wlp5s0): supplicant interface state: 4-way handshake -> disconnected Aug 18 13:48:21 goofy-HPE-440ch NetworkManager[1008]: <info> [1534592901.5341] device (wlp5s0): Activation: (wifi) disconnected during association, asking for new key Aug 18 13:48:21 goofy-HPE-440ch NetworkManager[1008]: <info> [1534592901.5343] device (wlp5s0): state change: config -> need-auth (reason 'supplicant-disconnect', sys-iface-state: 'managed') Aug 18 13:48:21 goofy-HPE-440ch gnome-shell[1760]: JS ERROR: Error: Expected type guint8 for Argument 'ssid' but got type 'object'#012_showNotification@resource:///org/gnome/shell/ui/components/networkAgent.js:658:24#012wrapper@resource:///org/gnome/gjs/modules/_legacy.js:82:22#012_newRequest@resource:///org/gnome/shell/ui/components/networkAgent.js:709:13#012wrapper@resource:///org/gnome/gjs/modules/_legacy.js:82:22 Aug 18 13:48:21 goofy-HPE-440ch NetworkManager[1008]: <info> [1534592901.6328] device (wlp5s0): supplicant interface state: disconnected -> inactive Aug 18 13:48:25 goofy-HPE-440ch NetworkManager[1008]: <info> [1534592905.8103] device (wlp5s0): disconnecting connection 'UPCD77DC9F' for new activation request Aug 18 13:48:25 goofy-HPE-440ch NetworkManager[1008]: <info> [1534592905.8104] device (wlp5s0): state change: need-auth -> deactivating (reason 'new-activation', sys-iface-state: 'managed') Aug 18 13:48:25 goofy-HPE-440ch NetworkManager[1008]: <info> [1534592905.8107] manager: NetworkManager state is now DISCONNECTING Aug 18 13:48:25 goofy-HPE-440ch NetworkManager[1008]: <info> [1534592905.8121] device (wlp5s0): disconnecting for new activation request. Aug 18 13:48:25 goofy-HPE-440ch NetworkManager[1008]: <info> [1534592905.8123] audit: op="connection-activate" uuid="cdc552d2-ea16-4ebd-8203-3f46fb80cc3c" name="UPCD77DC9F" pid=1760 uid=1000 result="success" Aug 18 13:48:25 goofy-HPE-440ch NetworkManager[1008]: <info> [1534592905.8131] device (wlp5s0): state change: deactivating -> disconnected (reason 'new-activation', sys-iface-state: 'managed') Aug 18 13:48:25 goofy-HPE-440ch NetworkManager[1008]: <info> [1534592905.8141] manager: NetworkManager state is now DISCONNECTED Aug 18 13:48:25 goofy-HPE-440ch NetworkManager[1008]: <info> [1534592905.8145] device (wlp5s0): Activation: starting connection 'UPCD77DC9F' (cdc552d2-ea16-4ebd-8203-3f46fb80cc3c) Aug 18 13:48:25 goofy-HPE-440ch kernel: [ 1239.524961] IPv6: ADDRCONF(NETDEV_UP): wlp5s0: link is not ready Aug 18 13:48:25 goofy-HPE-440ch NetworkManager[1008]: <info> [1534592905.8159] device (wlp5s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed') Aug 18 13:48:25 goofy-HPE-440ch NetworkManager[1008]: <info> [1534592905.8161] manager: NetworkManager state is now CONNECTING Aug 18 13:48:25 goofy-HPE-440ch NetworkManager[1008]: <info> [1534592905.8165] device (wlp5s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed') Aug 18 13:48:25 goofy-HPE-440ch NetworkManager[1008]: <info> [1534592905.8167] device (wlp5s0): Activation: (wifi) access point 'UPCD77DC9F' has security, but secrets are required. Aug 18 13:48:25 goofy-HPE-440ch NetworkManager[1008]: <info> [1534592905.8168] device (wlp5s0): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed') Aug 18 13:48:25 goofy-HPE-440ch NetworkManager[1008]: <info> [1534592905.8169] sup-iface[0x560240653240,wlp5s0]: wps: type pbc start... Aug 18 13:48:25 goofy-HPE-440ch dbus-daemon[1006]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.13' (uid=0 pid=1008 comm="/usr/sbin/NetworkManager --no-daemon " label="unconfined") Aug 18 13:48:25 goofy-HPE-440ch systemd[1]: Starting Network Manager Script Dispatcher Service... Aug 18 13:48:25 goofy-HPE-440ch NetworkManager[1008]: <info> [1534592905.8211] device (wlp5s0): state change: need-auth -> prepare (reason 'none', sys-iface-state: 'managed') Aug 18 13:48:25 goofy-HPE-440ch NetworkManager[1008]: <info> [1534592905.8217] device (wlp5s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed') Aug 18 13:48:25 goofy-HPE-440ch NetworkManager[1008]: <info> [1534592905.8220] device (wlp5s0): Activation: (wifi) connection 'UPCD77DC9F' has security, and secrets exist. No new secrets needed. Aug 18 13:48:25 goofy-HPE-440ch NetworkManager[1008]: <info> [1534592905.8220] Config: added 'ssid' value 'UPCD77DC9F' Aug 18 13:48:25 goofy-HPE-440ch NetworkManager[1008]: <info> [1534592905.8220] Config: added 'scan_ssid' value '1' Aug 18 13:48:25 goofy-HPE-440ch NetworkManager[1008]: <info> [1534592905.8221] Config: added 'bgscan' value 'simple:30:-80:86400' Aug 18 13:48:25 goofy-HPE-440ch NetworkManager[1008]: <info> [1534592905.8221] Config: added 'key_mgmt' value 'WPA-PSK' Aug 18 13:48:25 goofy-HPE-440ch NetworkManager[1008]: <info> [1534592905.8221] Config: added 'auth_alg' value 'OPEN' Aug 18 13:48:25 goofy-HPE-440ch NetworkManager[1008]: <info> [1534592905.8221] Config: added 'psk' value '<hidden>' Aug 18 13:48:25 goofy-HPE-440ch systemd[1]: Started Network Manager Script Dispatcher Service. Aug 18 13:48:25 goofy-HPE-440ch gnome-shell[1760]: Object St.Widget (0x5595f25970b0), has been already deallocated - impossible to access to it. This might be caused by the fact that the object has been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs Aug 18 13:48:25 goofy-HPE-440ch org.gnome.Shell.desktop[1760]: #3 0x5595f0c382b8 i resource:///org/gnome/shell/ui/status/network.js:781 (0x7fc3b9011f78 @ 409) Aug 18 13:48:27 goofy-HPE-440ch NetworkManager[1008]: <info> [1534592907.8479] device (wlp5s0): supplicant interface state: inactive -> scanning Aug 18 13:48:28 goofy-HPE-440ch NetworkManager[1008]: <info> [1534592908.8943] device (wlp5s0): supplicant interface state: scanning -> authenticating Aug 18 13:48:28 goofy-HPE-440ch NetworkManager[1008]: <info> [1534592908.8971] device (wlp5s0): supplicant interface state: authenticating -> associating Aug 18 13:48:28 goofy-HPE-440ch wpa_supplicant[1009]: wlp5s0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0 Aug 18 13:48:28 goofy-HPE-440ch NetworkManager[1008]: <info> [1534592908.9223] device (wlp5s0): supplicant interface state: associating -> associated Aug 18 13:48:29 goofy-HPE-440ch NetworkManager[1008]: <info> [1534592909.0350] device (wlp5s0): supplicant interface state: associated -> 4-way handshake Aug 18 13:48:29 goofy-HPE-440ch kernel: [ 1242.751018] IPv6: ADDRCONF(NETDEV_CHANGE): wlp5s0: link becomes ready Aug 18 13:48:29 goofy-HPE-440ch NetworkManager[1008]: <info> [1534592909.0453] device (wlp5s0): supplicant interface state: 4-way handshake -> completed Aug 18 13:48:29 goofy-HPE-440ch NetworkManager[1008]: <info> [1534592909.0453] device (wlp5s0): Activation: (wifi) Stage 2 of 5 (Device Configure) successful. Connected to wireless network 'UPCD77DC9F'. Aug 18 13:48:29 goofy-HPE-440ch NetworkManager[1008]: <info> [1534592909.0456] device (wlp5s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed') Aug 18 13:48:29 goofy-HPE-440ch NetworkManager[1008]: <info> [1534592909.0463] dhcp4 (wlp5s0): activation: beginning transaction (timeout in 45 seconds) Aug 18 13:48:29 goofy-HPE-440ch NetworkManager[1008]: <info> [1534592909.0654] dhcp4 (wlp5s0): dhclient started with pid 3230 Aug 18 13:48:29 goofy-HPE-440ch NetworkManager[1008]: <info> [1534592909.2638] dhcp4 (wlp5s0): address 192.168.0.229 Aug 18 13:48:29 goofy-HPE-440ch NetworkManager[1008]: <info> [1534592909.2639] dhcp4 (wlp5s0): plen 24 (255.255.255.0) Aug 18 13:48:29 goofy-HPE-440ch NetworkManager[1008]: <info> [1534592909.2639] dhcp4 (wlp5s0): gateway 192.168.0.1 Aug 18 13:48:29 goofy-HPE-440ch NetworkManager[1008]: <info> [1534592909.2639] dhcp4 (wlp5s0): lease time 3600 Aug 18 13:48:29 goofy-HPE-440ch NetworkManager[1008]: <info> [1534592909.2640] dhcp4 (wlp5s0): hostname 'goofy-HPE-440ch' Aug 18 13:48:29 goofy-HPE-440ch NetworkManager[1008]: <info> [1534592909.2640] dhcp4 (wlp5s0): nameserver '62.2.17.61' Aug 18 13:48:29 goofy-HPE-440ch NetworkManager[1008]: <info> [1534592909.2640] dhcp4 (wlp5s0): nameserver '62.2.24.158' Aug 18 13:48:29 goofy-HPE-440ch NetworkManager[1008]: <info> [1534592909.2640] dhcp4 (wlp5s0): nameserver '62.2.17.60' Aug 18 13:48:29 goofy-HPE-440ch NetworkManager[1008]: <info> [1534592909.2641] dhcp4 (wlp5s0): nameserver '62.2.24.162' Aug 18 13:48:29 goofy-HPE-440ch NetworkManager[1008]: <info> [1534592909.2641] dhcp4 (wlp5s0): domain name 'home' Aug 18 13:48:29 goofy-HPE-440ch NetworkManager[1008]: <info> [1534592909.2641] dhcp4 (wlp5s0): state changed unknown -> bound Aug 18 13:48:29 goofy-HPE-440ch NetworkManager[1008]: <info> [1534592909.2681] device (wlp5s0): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed') Aug 18 13:48:29 goofy-HPE-440ch NetworkManager[1008]: <info> [1534592909.2693] device (wlp5s0): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed') Aug 18 13:48:29 goofy-HPE-440ch NetworkManager[1008]: <info> [1534592909.2698] device (wlp5s0): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed') Aug 18 13:48:29 goofy-HPE-440ch NetworkManager[1008]: <info> [1534592909.2701] manager: NetworkManager state is now CONNECTED_LOCAL Aug 18 13:48:29 goofy-HPE-440ch NetworkManager[1008]: <info> [1534592909.4227] manager: NetworkManager state is now CONNECTED_SITE Aug 18 13:48:29 goofy-HPE-440ch NetworkManager[1008]: <info> [1534592909.4229] policy: set 'UPCD77DC9F' (wlp5s0) as default for IPv4 routing and DNS Aug 18 13:48:29 goofy-HPE-440ch NetworkManager[1008]: <info> [1534592909.4237] device (wlp5s0): Activation: successful, device activated. Aug 18 13:48:30 goofy-HPE-440ch NetworkManager[1008]: <info> [1534592910.9666] manager: NetworkManager state is now CONNECTED_GLOBAL Aug 18 13:48:30 goofy-HPE-440ch whoopsie[1243]: [13:48:30] The default IPv4 route is: /org/freedesktop/NetworkManager/ActiveConnection/4 Aug 18 13:48:30 goofy-HPE-440ch whoopsie[1243]: [13:48:30] Not a paid data plan: /org/freedesktop/NetworkManager/ActiveConnection/4 Aug 18 13:48:30 goofy-HPE-440ch whoopsie[1243]: [13:48:30] Found usable connection: /org/freedesktop/NetworkManager/ActiveConnection/4 Aug 18 14:05:58 goofy-HPE-440ch gnome-shell[1760]: Object St.Widget (0x5595f2b15a90), has been already deallocated - impossible to access to it. This might be caused by the fact that the object has been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs Aug 18 14:05:58 goofy-HPE-440ch org.gnome.Shell.desktop[1760]: #3 0x5595f0c384e0 i resource:///org/gnome/shell/ui/status/network.js:781 (0x7fc3b9011f78 @ 409) Aug 18 14:08:42 goofy-HPE-440ch NetworkManager[1008]: <info> [1534594122.7045] audit: op="connection-delete" uuid="7952796c-6d88-4292-9ecb-fab012977407" name="TP-LINK_BDDB" pid=3926 uid=1000 result="success" Aug 18 14:12:15 goofy-HPE-440ch gsd-color[1912]: failed to set screen _ICC_PROFILE: Datei »/var/lib/gdm3/.local/share/icc/edid-b431be1d4b354b2c22b0bc9237b6e8ab.icc« konnte nicht geöffnet werden: Keine Berechtigung Aug 18 14:12:18 goofy-HPE-440ch systemd[1]: Stopping Anonymizing overlay network for TCP... Aug 18 14:12:18 goofy-HPE-440ch canonical-livepatch[1242]: while starting HTTP server: accept unix /var/snap/canonical-livepatch/42/livepatchd.sock: use of closed network connection Aug 18 14:12:18 goofy-HPE-440ch systemd[1]: Stopped Anonymizing overlay network for TCP (multi-instance-master). Aug 18 14:12:18 goofy-HPE-440ch canonical-livepatch[1242]: while starting HTTP server: accept unix /var/snap/canonical-livepatch/42/livepatchd-priv.sock: use of closed network connection Aug 18 14:13:27 goofy-HPE-440ch keyboard-setup.sh[329]: Datei /tmp/tmpkbd.KdaFSP kann nicht geöffnet werden. Aug 18 14:13:27 goofy-HPE-440ch kernel: [ 0.056438] NET: Registered protocol family 16 Aug 18 14:13:27 goofy-HPE-440ch kernel: [ 0.056438] audit: initializing netlink subsys (disabled) Aug 18 14:13:27 goofy-HPE-440ch systemd[1]: Starting Network Name Resolution... Aug 18 14:13:27 goofy-HPE-440ch systemd[1]: Starting Network Time Synchronization... Aug 18 14:13:27 goofy-HPE-440ch systemd[1]: Started Network Time Synchronization. Aug 18 14:13:27 goofy-HPE-440ch systemd-resolved[854]: Negative trust anchors: 10.in-addr.arpa 16.172.in-addr.arpa 17.172.in-addr.arpa 18.172.in-addr.arpa 19.172.in-addr.arpa 20.172.in-addr.arpa 21.172.in-addr.arpa 22.172.in-addr.arpa 23.172.in-addr.arpa 24.172.in-addr.arpa 25.172.in-addr.arpa 26.172.in-addr.arpa 27.172.in-addr.arpa 28.172.in-addr.arpa 29.172.in-addr.arpa 30.172.in-addr.arpa 31.172.in-addr.arpa 168.192.in-addr.arpa d.f.ip6.arpa corp home internal intranet lan local private test Aug 18 14:13:27 goofy-HPE-440ch systemd[1]: Started Network Name Resolution. Aug 18 14:13:27 goofy-HPE-440ch systemd[1]: Reached target Host and Network Name Lookups. Aug 18 14:13:27 goofy-HPE-440ch systemd[1]: Starting Raise network interfaces... Aug 18 14:13:27 goofy-HPE-440ch systemd[1]: Started Raise network interfaces. Aug 18 14:13:27 goofy-HPE-440ch kernel: [ 0.148993] NetLabel: Initializing Aug 18 14:13:27 goofy-HPE-440ch kernel: [ 0.148994] NetLabel: domain hash size = 128 Aug 18 14:13:27 goofy-HPE-440ch kernel: [ 0.148995] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO Aug 18 14:13:27 goofy-HPE-440ch kernel: [ 0.149008] NetLabel: unlabeled traffic allowed by default Aug 18 14:13:27 goofy-HPE-440ch systemd[1]: Starting Network Manager... Aug 18 14:13:27 goofy-HPE-440ch systemd[1]: Starting Anonymizing overlay network for TCP (multi-instance-master)... Aug 18 14:13:27 goofy-HPE-440ch systemd[1]: Starting Dispatcher daemon for systemd-networkd... Aug 18 14:13:27 goofy-HPE-440ch kernel: [ 0.170831] NET: Registered protocol family 2 Aug 18 14:13:27 goofy-HPE-440ch acpid: starting up with netlink and the input layer Aug 18 14:13:27 goofy-HPE-440ch kernel: [ 0.171406] NET: Registered protocol family 1 Aug 18 14:13:27 goofy-HPE-440ch avahi-daemon[1002]: Network interface enumeration completed. Aug 18 14:13:27 goofy-HPE-440ch systemd[1]: Started Anonymizing overlay network for TCP (multi-instance-master). Aug 18 14:13:27 goofy-HPE-440ch kernel: [ 0.962104] NET: Registered protocol family 10 Aug 18 14:13:27 goofy-HPE-440ch kernel: [ 0.967575] NET: Registered protocol family 17 Aug 18 14:13:27 goofy-HPE-440ch kernel: [ 1.098611] r8169 Gigabit Ethernet driver 2.3LK-NAPI loaded Aug 18 14:13:27 goofy-HPE-440ch kernel: [ 1.099032] r8169 0000:02:00.0 eth0: RTL8168d/8111d at 0x (ptrval), 6c:62:6d:7e:4b:9c, XID 081000c0 IRQ 37 Aug 18 14:13:27 goofy-HPE-440ch kernel: [ 1.099035] r8169 0000:02:00.0 eth0: jumbo features [frames: 9200 bytes, tx checksumming: ko] Aug 18 14:13:27 goofy-HPE-440ch kernel: [ 1.116692] r8169 0000:02:00.0 enp2s0: renamed from eth0 Aug 18 14:13:27 goofy-HPE-440ch kernel: [ 5.741729] ip_tables: (C) 2000-2006 Netfilter Core Team Aug 18 14:13:27 goofy-HPE-440ch kernel: [ 15.336389] rt2800pci 0000:05:00.0 wlp5s0: renamed from wlan0 Aug 18 14:13:29 goofy-HPE-440ch NetworkManager[991]: <info> [1534594409.0265] NetworkManager (version 1.10.6) is starting... (for the first time) Aug 18 14:13:29 goofy-HPE-440ch NetworkManager[991]: <info> [1534594409.0265] Read config: /etc/NetworkManager/NetworkManager.conf (lib: 10-dns-resolved.conf, 20-connectivity-ubuntu.conf, no-mac-addr-change.conf) (run: 10-globally-managed-devices.conf) (etc: default-wifi-powersave-on.conf) Aug 18 14:13:29 goofy-HPE-440ch NetworkManager[991]: <info> [1534594409.1647] manager[0x55c003cc5060]: monitoring kernel firmware directory '/lib/firmware'. Aug 18 14:13:29 goofy-HPE-440ch NetworkManager[991]: <info> [1534594409.1648] monitoring ifupdown state file '/run/network/ifstate'. Aug 18 14:13:29 goofy-HPE-440ch dbus-daemon[986]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service' requested by ':1.10' (uid=0 pid=991 comm="/usr/sbin/NetworkManager --no-daemon " label="unconfined") Aug 18 14:13:29 goofy-HPE-440ch NetworkManager[991]: <info> [1534594409.6884] hostname: hostname: using hostnamed Aug 18 14:13:29 goofy-HPE-440ch NetworkManager[991]: <info> [1534594409.6884] hostname: hostname changed from (none) to "goofy-HPE-440ch" Aug 18 14:13:29 goofy-HPE-440ch NetworkManager[991]: <info> [1534594409.6888] dns-mgr[0x55c003ce1140]: init: dns=systemd-resolved, rc-manager=symlink, plugin=systemd-resolved Aug 18 14:13:29 goofy-HPE-440ch NetworkManager[991]: <info> [1534594409.6896] rfkill0: found WiFi radio killswitch (at /sys/devices/pci0000:00/0000:00:1c.5/0000:05:00.0/ieee80211/phy0/rfkill0) (driver rt2800pci) Aug 18 14:13:29 goofy-HPE-440ch NetworkManager[991]: <info> [1534594409.6898] manager[0x55c003cc5060]: rfkill: WiFi hardware radio set enabled Aug 18 14:13:29 goofy-HPE-440ch NetworkManager[991]: <info> [1534594409.6898] manager[0x55c003cc5060]: rfkill: WWAN hardware radio set enabled Aug 18 14:13:29 goofy-HPE-440ch systemd[1]: Started Network Manager. Aug 18 14:13:29 goofy-HPE-440ch systemd[1]: Reached target Network. Aug 18 14:13:29 goofy-HPE-440ch systemd[1]: Starting Anonymizing overlay network for TCP... Aug 18 14:13:29 goofy-HPE-440ch systemd[1]: Starting Network Manager Wait Online... Aug 18 14:13:30 goofy-HPE-440ch dbus-daemon[986]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.10' (uid=0 pid=991 comm="/usr/sbin/NetworkManager --no-daemon " label="unconfined") Aug 18 14:13:30 goofy-HPE-440ch systemd[1]: Starting Network Manager Script Dispatcher Service... Aug 18 14:13:30 goofy-HPE-440ch systemd[1]: Started Network Manager Script Dispatcher Service. Aug 18 14:13:30 goofy-HPE-440ch NetworkManager[991]: <info> [1534594410.9261] init! Aug 18 14:13:30 goofy-HPE-440ch NetworkManager[991]: <info> [1534594410.9263] interface-parser: parsing file /etc/network/interfaces Aug 18 14:13:30 goofy-HPE-440ch NetworkManager[991]: <info> [1534594410.9263] interface-parser: finished parsing file /etc/network/interfaces Aug 18 14:13:30 goofy-HPE-440ch NetworkManager[991]: <info> [1534594410.9264] management mode: unmanaged Aug 18 14:13:30 goofy-HPE-440ch NetworkManager[991]: <info> [1534594410.9270] devices added (path: /sys/devices/pci0000:00/0000:00:1c.0/0000:02:00.0/net/enp2s0, iface: enp2s0) Aug 18 14:13:30 goofy-HPE-440ch NetworkManager[991]: <info> [1534594410.9270] device added (path: /sys/devices/pci0000:00/0000:00:1c.0/0000:02:00.0/net/enp2s0, iface: enp2s0): no ifupdown configuration found. Aug 18 14:13:30 goofy-HPE-440ch NetworkManager[991]: <info> [1534594410.9271] devices added (path: /sys/devices/pci0000:00/0000:00:1c.5/0000:05:00.0/net/wlp5s0, iface: wlp5s0) Aug 18 14:13:30 goofy-HPE-440ch NetworkManager[991]: <info> [1534594410.9271] device added (path: /sys/devices/pci0000:00/0000:00:1c.5/0000:05:00.0/net/wlp5s0, iface: wlp5s0): no ifupdown configuration found. Aug 18 14:13:30 goofy-HPE-440ch NetworkManager[991]: <info> [1534594410.9272] devices added (path: /sys/devices/virtual/net/lo, iface: lo) Aug 18 14:13:30 goofy-HPE-440ch NetworkManager[991]: <info> [1534594410.9272] device added (path: /sys/devices/virtual/net/lo, iface: lo): no ifupdown configuration found. Aug 18 14:13:31 goofy-HPE-440ch NetworkManager[991]: <info> [1534594410.9272] end _init. Aug 18 14:13:31 goofy-HPE-440ch NetworkManager[991]: <info> [1534594410.9272] settings: loaded plugin ifupdown: (C) 2008 Canonical Ltd. To report bugs please use the NetworkManager mailing list. (/usr/lib/x86_64-linux-gnu/NetworkManager/libnm-settings-plugin-ifupdown.so) Aug 18 14:13:31 goofy-HPE-440ch NetworkManager[991]: <info> [1534594410.9273] settings: loaded plugin keyfile: (c) 2007 - 2016 Red Hat, Inc. To report bugs please use the NetworkManager mailing list. Aug 18 14:13:31 goofy-HPE-440ch NetworkManager[991]: <info> [1534594410.9273] (63958208) ... get_connections. Aug 18 14:13:31 goofy-HPE-440ch NetworkManager[991]: <info> [1534594410.9273] (63958208) ... get_connections (managed=false): return empty list. Aug 18 14:13:31 goofy-HPE-440ch NetworkManager[991]: <info> [1534594410.9891] keyfile: new connection /etc/NetworkManager/system-connections/UPCD77DC9F (cdc552d2-ea16-4ebd-8203-3f46fb80cc3c,"UPCD77DC9F") Aug 18 14:13:31 goofy-HPE-440ch NetworkManager[991]: <info> [1534594411.0667] get unmanaged devices count: 0 Aug 18 14:13:31 goofy-HPE-440ch NetworkManager[991]: <info> [1534594411.0668] manager: rfkill: WiFi enabled by radio killswitch; enabled by state file Aug 18 14:13:31 goofy-HPE-440ch NetworkManager[991]: <info> [1534594411.0668] manager: rfkill: WWAN enabled by radio killswitch; enabled by state file Aug 18 14:13:31 goofy-HPE-440ch NetworkManager[991]: <info> [1534594411.0669] manager: Networking is enabled by state file Aug 18 14:13:31 goofy-HPE-440ch NetworkManager[991]: <info> [1534594411.0670] dhcp-init: Using DHCP client 'dhclient' Aug 18 14:13:31 goofy-HPE-440ch NetworkManager[991]: <info> [1534594411.0875] Loaded device plugin: NMBondDeviceFactory (internal) Aug 18 14:13:31 goofy-HPE-440ch NetworkManager[991]: <info> [1534594411.0876] Loaded device plugin: NMBridgeDeviceFactory (internal) Aug 18 14:13:31 goofy-HPE-440ch NetworkManager[991]: <info> [1534594411.0876] Loaded device plugin: NMDummyDeviceFactory (internal) Aug 18 14:13:31 goofy-HPE-440ch NetworkManager[991]: <info> [1534594411.0876] Loaded device plugin: NMEthernetDeviceFactory (internal) Aug 18 14:13:31 goofy-HPE-440ch NetworkManager[991]: <info> [1534594411.0876] Loaded device plugin: NMInfinibandDeviceFactory (internal) Aug 18 14:13:31 goofy-HPE-440ch NetworkManager[991]: <info> [1534594411.0877] Loaded device plugin: NMIPTunnelDeviceFactory (internal) Aug 18 14:13:31 goofy-HPE-440ch NetworkManager[991]: <info> [1534594411.0877] Loaded device plugin: NMMacsecDeviceFactory (internal) Aug 18 14:13:31 goofy-HPE-440ch NetworkManager[991]: <info> [1534594411.0877] Loaded device plugin: NMMacvlanDeviceFactory (internal) Aug 18 14:13:31 goofy-HPE-440ch NetworkManager[991]: <info> [1534594411.0877] Loaded device plugin: NMPppDeviceFactory (internal) Aug 18 14:13:31 goofy-HPE-440ch NetworkManager[991]: <info> [1534594411.0877] Loaded device plugin: NMTunDeviceFactory (internal) Aug 18 14:13:31 goofy-HPE-440ch NetworkManager[991]: <info> [1534594411.0878] Loaded device plugin: NMVethDeviceFactory (internal) Aug 18 14:13:31 goofy-HPE-440ch NetworkManager[991]: <info> [1534594411.0878] Loaded device plugin: NMVlanDeviceFactory (internal) Aug 18 14:13:31 goofy-HPE-440ch NetworkManager[991]: <info> [1534594411.0878] Loaded device plugin: NMVxlanDeviceFactory (internal) Aug 18 14:13:31 goofy-HPE-440ch NetworkManager[991]: <info> [1534594411.5425] Loaded device plugin: NMTeamFactory (/usr/lib/x86_64-linux-gnu/NetworkManager/libnm-device-plugin-team.so) Aug 18 14:13:31 goofy-HPE-440ch networkd-dispatcher[997]: WARNING: systemd-networkd is not running, output will be incomplete. Aug 18 14:13:31 goofy-HPE-440ch systemd[1]: Started Dispatcher daemon for systemd-networkd. Aug 18 14:13:31 goofy-HPE-440ch NetworkManager[991]: <info> [1534594411.6214] Loaded device plugin: NMWifiFactory (/usr/lib/x86_64-linux-gnu/NetworkManager/libnm-device-plugin-wifi.so) Aug 18 14:13:31 goofy-HPE-440ch NetworkManager[991]: <info> [1534594411.8530] Loaded device plugin: NMWwanFactory (/usr/lib/x86_64-linux-gnu/NetworkManager/libnm-device-plugin-wwan.so) Aug 18 14:13:32 goofy-HPE-440ch NetworkManager[991]: <info> [1534594412.0680] Loaded device plugin: NMBluezManager (/usr/lib/x86_64-linux-gnu/NetworkManager/libnm-device-plugin-bluetooth.so) Aug 18 14:13:32 goofy-HPE-440ch NetworkManager[991]: <info> [1534594412.1060] Loaded device plugin: NMAtmManager (/usr/lib/x86_64-linux-gnu/NetworkManager/libnm-device-plugin-adsl.so) Aug 18 14:13:32 goofy-HPE-440ch NetworkManager[991]: <info> [1534594412.1070] device (lo): carrier: link connected Aug 18 14:13:32 goofy-HPE-440ch NetworkManager[991]: <info> [1534594412.1076] manager: (lo): new Generic device (/org/freedesktop/NetworkManager/Devices/1) Aug 18 14:13:32 goofy-HPE-440ch NetworkManager[991]: <info> [1534594412.1087] manager: (enp2s0): new Ethernet device (/org/freedesktop/NetworkManager/Devices/2) Aug 18 14:13:32 goofy-HPE-440ch NetworkManager[991]: <info> [1534594412.1097] keyfile: add connection in-memory (eeeef268-4618-373e-b5b1-6f205339662a,"Kabelgebundene Verbindung 1") Aug 18 14:13:32 goofy-HPE-440ch NetworkManager[991]: <info> [1534594412.1101] settings: (enp2s0): created default wired connection 'Kabelgebundene Verbindung 1' Aug 18 14:13:32 goofy-HPE-440ch NetworkManager[991]: <info> [1534594412.1109] device (enp2s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external') Aug 18 14:13:32 goofy-HPE-440ch kernel: [ 37.588052] IPv6: ADDRCONF(NETDEV_UP): enp2s0: link is not ready Aug 18 14:13:32 goofy-HPE-440ch kernel: [ 37.865357] IPv6: ADDRCONF(NETDEV_UP): enp2s0: link is not ready Aug 18 14:13:32 goofy-HPE-440ch NetworkManager[991]: <info> [1534594412.4287] wifi-nl80211: (wlp5s0): using nl80211 for WiFi device control Aug 18 14:13:32 goofy-HPE-440ch NetworkManager[991]: <info> [1534594412.4289] device (wlp5s0): driver supports Access Point (AP) mode Aug 18 14:13:32 goofy-HPE-440ch NetworkManager[991]: <info> [1534594412.4297] manager: (wlp5s0): new 802.11 WiFi device (/org/freedesktop/NetworkManager/Devices/3) Aug 18 14:13:32 goofy-HPE-440ch NetworkManager[991]: <info> [1534594412.4303] device (wlp5s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external') Aug 18 14:13:32 goofy-HPE-440ch kernel: [ 37.907478] IPv6: ADDRCONF(NETDEV_UP): wlp5s0: link is not ready Aug 18 14:13:32 goofy-HPE-440ch kernel: [ 37.907531] ieee80211 phy0: rt2x00lib_request_firmware: Info - Loading firmware file 'rt2860.bin' Aug 18 14:13:32 goofy-HPE-440ch kernel: [ 37.920612] ieee80211 phy0: rt2x00lib_request_firmware: Info - Firmware detected - version: 0.40 Aug 18 14:13:32 goofy-HPE-440ch kernel: [ 38.097623] IPv6: ADDRCONF(NETDEV_UP): wlp5s0: link is not ready Aug 18 14:13:32 goofy-HPE-440ch NetworkManager[991]: <info> [1534594412.7426] modem-manager: ModemManager available Aug 18 14:13:32 goofy-HPE-440ch NetworkManager[991]: <info> [1534594412.7452] supplicant: wpa_supplicant running Aug 18 14:13:32 goofy-HPE-440ch NetworkManager[991]: <info> [1534594412.7452] device (wlp5s0): supplicant interface state: init -> starting Aug 18 14:13:33 goofy-HPE-440ch NetworkManager[991]: <info> [1534594413.2785] device (wlp5s0): supplicant interface state: starting -> ready Aug 18 14:13:33 goofy-HPE-440ch NetworkManager[991]: <info> [1534594413.2786] device (wlp5s0): state change: unavailable -> disconnected (reason 'supplicant-available', sys-iface-state: 'managed') Aug 18 14:13:33 goofy-HPE-440ch kernel: [ 38.755795] IPv6: ADDRCONF(NETDEV_UP): wlp5s0: link is not ready Aug 18 14:13:34 goofy-HPE-440ch NetworkManager[991]: <info> [1534594414.3743] policy: auto-activating connection 'UPCD77DC9F' Aug 18 14:13:34 goofy-HPE-440ch NetworkManager[991]: <info> [1534594414.3754] device (wlp5s0): Activation: starting connection 'UPCD77DC9F' (cdc552d2-ea16-4ebd-8203-3f46fb80cc3c) Aug 18 14:13:34 goofy-HPE-440ch NetworkManager[991]: <info> [1534594414.3756] device (wlp5s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed') Aug 18 14:13:34 goofy-HPE-440ch NetworkManager[991]: <info> [1534594414.3758] manager: NetworkManager state is now CONNECTING Aug 18 14:13:34 goofy-HPE-440ch NetworkManager[991]: <info> [1534594414.3762] device (wlp5s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed') Aug 18 14:13:34 goofy-HPE-440ch NetworkManager[991]: <info> [1534594414.3764] device (wlp5s0): Activation: (wifi) access point 'UPCD77DC9F' has security, but secrets are required. Aug 18 14:13:34 goofy-HPE-440ch NetworkManager[991]: <info> [1534594414.3764] device (wlp5s0): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed') Aug 18 14:13:34 goofy-HPE-440ch NetworkManager[991]: <info> [1534594414.3766] sup-iface[0x55c003c98240,wlp5s0]: wps: type pbc start... Aug 18 14:13:34 goofy-HPE-440ch NetworkManager[991]: <info> [1534594414.3794] device (wlp5s0): state change: need-auth -> prepare (reason 'none', sys-iface-state: 'managed') Aug 18 14:13:34 goofy-HPE-440ch NetworkManager[991]: <info> [1534594414.3798] device (wlp5s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed') Aug 18 14:13:34 goofy-HPE-440ch NetworkManager[991]: <info> [1534594414.3800] device (wlp5s0): Activation: (wifi) connection 'UPCD77DC9F' has security, and secrets exist. No new secrets needed. Aug 18 14:13:34 goofy-HPE-440ch NetworkManager[991]: <info> [1534594414.3801] Config: added 'ssid' value 'UPCD77DC9F' Aug 18 14:13:34 goofy-HPE-440ch NetworkManager[991]: <info> [1534594414.3801] Config: added 'scan_ssid' value '1' Aug 18 14:13:34 goofy-HPE-440ch NetworkManager[991]: <info> [1534594414.3801] Config: added 'bgscan' value 'simple:30:-80:86400' Aug 18 14:13:34 goofy-HPE-440ch NetworkManager[991]: <info> [1534594414.3801] Config: added 'key_mgmt' value 'WPA-PSK' Aug 18 14:13:34 goofy-HPE-440ch NetworkManager[991]: <info> [1534594414.3801] Config: added 'auth_alg' value 'OPEN' Aug 18 14:13:34 goofy-HPE-440ch NetworkManager[991]: <info> [1534594414.3802] Config: added 'psk' value '<hidden>' Aug 18 14:13:34 goofy-HPE-440ch NetworkManager[991]: <info> [1534594414.3936] device (wlp5s0): supplicant interface state: ready -> authenticating Aug 18 14:13:34 goofy-HPE-440ch NetworkManager[991]: <info> [1534594414.3994] device (wlp5s0): supplicant interface state: authenticating -> associating Aug 18 14:13:34 goofy-HPE-440ch wpa_supplicant[1003]: wlp5s0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0 Aug 18 14:13:34 goofy-HPE-440ch NetworkManager[991]: <info> [1534594414.4283] device (wlp5s0): supplicant interface state: associating -> associated Aug 18 14:13:35 goofy-HPE-440ch NetworkManager[991]: <info> [1534594415.6850] device (wlp5s0): supplicant interface state: associated -> completed Aug 18 14:13:35 goofy-HPE-440ch NetworkManager[991]: <info> [1534594415.6851] device (wlp5s0): Activation: (wifi) Stage 2 of 5 (Device Configure) successful. Connected to wireless network 'UPCD77DC9F'. Aug 18 14:13:35 goofy-HPE-440ch NetworkManager[991]: <info> [1534594415.6853] device (wlp5s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed') Aug 18 14:13:35 goofy-HPE-440ch kernel: [ 41.161242] IPv6: ADDRCONF(NETDEV_CHANGE): wlp5s0: link becomes ready Aug 18 14:13:35 goofy-HPE-440ch NetworkManager[991]: <info> [1534594415.7036] dhcp4 (wlp5s0): activation: beginning transaction (timeout in 45 seconds) Aug 18 14:13:35 goofy-HPE-440ch NetworkManager[991]: <info> [1534594415.9837] dhcp4 (wlp5s0): dhclient started with pid 1138 Aug 18 14:13:37 goofy-HPE-440ch Tor[1112]: Bootstrapped 80%: Connecting to the Tor network Aug 18 14:13:37 goofy-HPE-440ch systemd[1]: Started Anonymizing overlay network for TCP. Aug 18 14:13:37 goofy-HPE-440ch Tor[1112]: Problem bootstrapping. Stuck at 80%: Connecting to the Tor network. (Network is unreachable; NOROUTE; count 1; recommendation warn; host 0266B0660F3F20A7D1F3D8335931C95EF50F6C6B at 62.210.92.11:9001) Aug 18 14:13:37 goofy-HPE-440ch systemd[1131]: Listening on GnuPG network certificate management daemon. Aug 18 14:13:38 goofy-HPE-440ch Tor[1112]: Problem bootstrapping. Stuck at 80%: Connecting to the Tor network. (Network is unreachable; NOROUTE; count 2; recommendation warn; host 0266B0660F3F20A7D1F3D8335931C95EF50F6C6B at 62.210.92.11:9001) Aug 18 14:13:38 goofy-HPE-440ch Tor[1112]: Problem bootstrapping. Stuck at 80%: Connecting to the Tor network. (Network is unreachable; NOROUTE; count 3; recommendation warn; host 0266B0660F3F20A7D1F3D8335931C95EF50F6C6B at 62.210.92.11:9001) Aug 18 14:13:39 goofy-HPE-440ch Tor[1112]: Problem bootstrapping. Stuck at 80%: Connecting to the Tor network. (Network is unreachable; NOROUTE; count 4; recommendation warn; host D1C5F5F8FAFA2F98A84753416BF83B83F1282137 at 81.7.9.33:443) Aug 18 14:13:42 goofy-HPE-440ch NetworkManager[991]: <info> [1534594420.0711] dhcp4 (wlp5s0): address 192.168.0.229 Aug 18 14:13:42 goofy-HPE-440ch Tor[1112]: Problem bootstrapping. Stuck at 80%: Connecting to the Tor network. (Network is unreachable; NOROUTE; count 5; recommendation warn; host 8FD3BAF5E14EBE1124D6253D59882AFE1C2B9B8E at 217.182.196.65:443) Aug 18 14:13:42 goofy-HPE-440ch NetworkManager[991]: <info> [1534594420.0711] dhcp4 (wlp5s0): plen 24 (255.255.255.0) Aug 18 14:13:42 goofy-HPE-440ch NetworkManager[991]: <info> [1534594420.0711] dhcp4 (wlp5s0): gateway 192.168.0.1 Aug 18 14:13:42 goofy-HPE-440ch NetworkManager[991]: <info> [1534594420.0711] dhcp4 (wlp5s0): lease time 3600 Aug 18 14:13:42 goofy-HPE-440ch NetworkManager[991]: <info> [1534594420.0712] dhcp4 (wlp5s0): hostname 'goofy-HPE-440ch' Aug 18 14:13:42 goofy-HPE-440ch NetworkManager[991]: <info> [1534594420.0712] dhcp4 (wlp5s0): nameserver '62.2.17.61' Aug 18 14:13:42 goofy-HPE-440ch NetworkManager[991]: <info> [1534594420.0712] dhcp4 (wlp5s0): nameserver '62.2.24.158' Aug 18 14:13:42 goofy-HPE-440ch NetworkManager[991]: <info> [1534594420.0712] dhcp4 (wlp5s0): nameserver '62.2.17.60' Aug 18 14:13:42 goofy-HPE-440ch NetworkManager[991]: <info> [1534594420.0712] dhcp4 (wlp5s0): nameserver '62.2.24.162' Aug 18 14:13:42 goofy-HPE-440ch NetworkManager[991]: <info> [1534594420.0712] dhcp4 (wlp5s0): domain name 'home' Aug 18 14:13:42 goofy-HPE-440ch NetworkManager[991]: <info> [1534594420.0713] dhcp4 (wlp5s0): state changed unknown -> bound Aug 18 14:13:42 goofy-HPE-440ch NetworkManager[991]: <info> [1534594420.0724] device (wlp5s0): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed') Aug 18 14:13:42 goofy-HPE-440ch NetworkManager[991]: <info> [1534594420.0728] device (wlp5s0): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed') Aug 18 14:13:42 goofy-HPE-440ch NetworkManager[991]: <info> [1534594420.0731] device (wlp5s0): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed') Aug 18 14:13:42 goofy-HPE-440ch NetworkManager[991]: <info> [1534594420.0732] manager: NetworkManager state is now CONNECTED_LOCAL Aug 18 14:13:42 goofy-HPE-440ch NetworkManager[991]: <info> [1534594422.6938] manager: NetworkManager state is now CONNECTED_SITE Aug 18 14:13:42 goofy-HPE-440ch NetworkManager[991]: <info> [1534594422.6939] policy: set 'UPCD77DC9F' (wlp5s0) as default for IPv4 routing and DNS Aug 18 14:13:42 goofy-HPE-440ch NetworkManager[991]: <info> [1534594422.6942] device (wlp5s0): Activation: successful, device activated. Aug 18 14:13:42 goofy-HPE-440ch NetworkManager[991]: <info> [1534594422.6949] manager: startup complete Aug 18 14:13:42 goofy-HPE-440ch systemd[1]: Started Network Manager Wait Online. Aug 18 14:13:42 goofy-HPE-440ch systemd[1]: Reached target Network is Online. Aug 18 14:13:44 goofy-HPE-440ch NetworkManager[991]: <info> [1534594424.1672] manager: NetworkManager state is now CONNECTED_GLOBAL Aug 18 14:13:44 goofy-HPE-440ch dbus-daemon[986]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.10' (uid=0 pid=991 comm="/usr/sbin/NetworkManager --no-daemon " label="unconfined") Aug 18 14:13:44 goofy-HPE-440ch whoopsie[1220]: [14:13:44] The default IPv4 route is: /org/freedesktop/NetworkManager/ActiveConnection/1 Aug 18 14:13:44 goofy-HPE-440ch whoopsie[1220]: [14:13:44] Not a paid data plan: /org/freedesktop/NetworkManager/ActiveConnection/1 Aug 18 14:13:44 goofy-HPE-440ch whoopsie[1220]: [14:13:44] Found usable connection: /org/freedesktop/NetworkManager/ActiveConnection/1 Aug 18 14:13:44 goofy-HPE-440ch systemd[1]: Starting Network Manager Script Dispatcher Service... Aug 18 14:13:44 goofy-HPE-440ch systemd[1]: Started Network Manager Script Dispatcher Service. Aug 18 14:14:08 goofy-HPE-440ch systemd[1532]: Listening on GnuPG network certificate management daemon. Aug 18 14:14:08 goofy-HPE-440ch /usr/lib/gdm3/gdm-x-session[1550]: (WW) Falling back to old probe method for modesetting Aug 18 14:14:08 goofy-HPE-440ch /usr/lib/gdm3/gdm-x-session[1550]: (WW) Falling back to old probe method for fbdev Aug 18 14:14:08 goofy-HPE-440ch /usr/lib/gdm3/gdm-x-session[1550]: (WW) Falling back to old probe method for vesa Aug 18 14:14:09 goofy-HPE-440ch /usr/lib/gdm3/gdm-x-session[1550]: dbus-update-activation-environment: setting LC_MONETARY=de_CH.UTF-8 Aug 18 14:14:20 goofy-HPE-440ch gsd-color[1815]: failed to set screen _ICC_PROFILE: Datei »/var/lib/gdm3/.local/share/icc/edid-b431be1d4b354b2c22b0bc9237b6e8ab.icc« konnte nicht geöffnet werden: Keine Berechtigung Aug 18 14:14:27 goofy-HPE-440ch systemd[1]: Starting Firmware update daemon... Aug 18 14:14:28 goofy-HPE-440ch fwupd[2068]: disabling plugin because: failed to startup dell: Firmware updating not supported Aug 18 14:14:28 goofy-HPE-440ch fwupd[2068]: disabling plugin because: failed to startup uefi: UEFI firmware updating not supported Aug 18 14:14:28 goofy-HPE-440ch fwupd[2068]: disabling plugin because: failed to coldplug synapticsmst: MST firmware updating not supported by OEM Aug 18 14:14:29 goofy-HPE-440ch systemd[1]: Started Firmware update daemon. Aug 18 14:14:47 goofy-HPE-440ch ureadahead[336]: ureadahead:net: Relativer Pfad wurde ignoriert Aug 18 14:14:47 goofy-HPE-440ch ureadahead[336]: ureadahead:net: Relativer Pfad wurde ignoriert Aug 18 14:14:47 goofy-HPE-440ch ureadahead[336]: ureadahead:net: Relativer Pfad wurde ignoriert Aug 18 14:14:47 goofy-HPE-440ch ureadahead[336]: ureadahead:net: Relativer Pfad wurde ignoriert Aug 18 14:14:47 goofy-HPE-440ch ureadahead[336]: ureadahead:net: Relativer Pfad wurde ignoriert Aug 18 14:14:47 goofy-HPE-440ch ureadahead[336]: ureadahead:net: Relativer Pfad wurde ignoriert Aug 18 14:14:47 goofy-HPE-440ch ureadahead[336]: ureadahead:net: Relativer Pfad wurde ignoriert Aug 18 14:14:47 goofy-HPE-440ch ureadahead[336]: ureadahead:net: Relativer Pfad wurde ignoriert Aug 18 14:14:47 goofy-HPE-440ch ureadahead[336]: ureadahead:net: Relativer Pfad wurde ignoriert Aug 18 14:14:47 goofy-HPE-440ch ureadahead[336]: ureadahead:net: Relativer Pfad wurde ignoriert Aug 18 14:14:47 goofy-HPE-440ch ureadahead[336]: ureadahead:net: Relativer Pfad wurde ignoriert Aug 18 14:14:47 goofy-HPE-440ch ureadahead[336]: ureadahead:net: Relativer Pfad wurde ignoriert Aug 18 14:14:47 goofy-HPE-440ch ureadahead[336]: ureadahead:net: Relativer Pfad wurde ignoriert Aug 18 14:14:47 goofy-HPE-440ch ureadahead[336]: ureadahead:net: Relativer Pfad wurde ignoriert Aug 18 14:14:47 goofy-HPE-440ch ureadahead[336]: ureadahead:net: Relativer Pfad wurde ignoriert Aug 18 14:14:48 goofy-HPE-440ch ureadahead[336]: ureadahead:network: Relativer Pfad wurde ignoriert Aug 18 14:14:48 goofy-HPE-440ch ureadahead[336]: ureadahead:net: Relativer Pfad wurde ignoriert Aug 18 14:14:48 goofy-HPE-440ch ureadahead[336]: ureadahead:net: Relativer Pfad wurde ignoriert Aug 18 14:14:48 goofy-HPE-440ch ureadahead[336]: ureadahead:net: Relativer Pfad wurde ignoriert Aug 18 14:14:48 goofy-HPE-440ch ureadahead[336]: ureadahead:net: Relativer Pfad wurde ignoriert Aug 18 14:14:48 goofy-HPE-440ch ureadahead[336]: ureadahead:net: Relativer Pfad wurde ignoriert Aug 18 14:14:48 goofy-HPE-440ch ureadahead[336]: ureadahead:net: Relativer Pfad wurde ignoriert Aug 18 14:14:48 goofy-HPE-440ch ureadahead[336]: ureadahead:net: Relativer Pfad wurde ignoriert Aug 18 14:14:48 goofy-HPE-440ch ureadahead[336]: ureadahead:net: Relativer Pfad wurde ignoriert Aug 18 14:14:48 goofy-HPE-440ch ureadahead[336]: ureadahead:net: Relativer Pfad wurde ignoriert Aug 18 14:14:48 goofy-HPE-440ch ureadahead[336]: ureadahead:net: Relativer Pfad wurde ignoriert Aug 18 14:14:48 goofy-HPE-440ch ureadahead[336]: ureadahead:net: Relativer Pfad wurde ignoriert Aug 18 14:14:48 goofy-HPE-440ch ureadahead[336]: ureadahead:net: Relativer Pfad wurde ignoriert Aug 18 14:14:48 goofy-HPE-440ch ureadahead[336]: ureadahead:net: Relativer Pfad wurde ignoriert Aug 18 14:14:48 goofy-HPE-440ch ureadahead[336]: ureadahead:net: Relativer Pfad wurde ignoriert Aug 18 14:14:48 goofy-HPE-440ch ureadahead[336]: ureadahead:net: Relativer Pfad wurde ignoriert Aug 18 14:14:48 goofy-HPE-440ch ureadahead[336]: ureadahead:net: Relativer Pfad wurde ignoriert Aug 18 14:14:48 goofy-HPE-440ch ureadahead[336]: ureadahead:net: Relativer Pfad wurde ignoriert Aug 18 14:14:48 goofy-HPE-440ch ureadahead[336]: ureadahead:net: Relativer Pfad wurde ignoriert Aug 18 14:14:48 goofy-HPE-440ch ureadahead[336]: ureadahead:net: Relativer Pfad wurde ignoriert Aug 18 14:14:48 goofy-HPE-440ch ureadahead[336]: ureadahead:net: Relativer Pfad wurde ignoriert Aug 18 14:14:48 goofy-HPE-440ch ureadahead[336]: ureadahead:net: Relativer Pfad wurde ignoriert Aug 18 14:14:48 goofy-HPE-440ch ureadahead[336]: ureadahead:net: Relativer Pfad wurde ignoriert Aug 18 14:14:48 goofy-HPE-440ch ureadahead[336]: ureadahead:net: Relativer Pfad wurde ignoriert Aug 18 14:14:48 goofy-HPE-440ch ureadahead[336]: ureadahead:net: Relativer Pfad wurde ignoriert Aug 18 14:14:48 goofy-HPE-440ch ureadahead[336]: ureadahead:net: Relativer Pfad wurde ignoriert Aug 18 14:14:48 goofy-HPE-440ch ureadahead[336]: ureadahead:net: Relativer Pfad wurde ignoriert Aug 18 14:14:48 goofy-HPE-440ch ureadahead[336]: ureadahead:net: Relativer Pfad wurde ignoriert Aug 18 14:14:51 goofy-HPE-440ch ureadahead[336]: ureadahead:network-online.target.wants: Relativer Pfad wurde ignoriert Aug 18 14:14:51 goofy-HPE-440ch ureadahead[336]: ureadahead:network-online.target.wants: Relativer Pfad wurde ignoriert Aug 18 14:37:55 goofy-HPE-440ch NetworkManager[991]: <info> [1534595875.6903] dhcp4 (wlp5s0): address 192.168.0.229 Aug 18 14:37:55 goofy-HPE-440ch NetworkManager[991]: <info> [1534595875.6904] dhcp4 (wlp5s0): plen 24 (255.255.255.0) Aug 18 14:37:55 goofy-HPE-440ch NetworkManager[991]: <info> [1534595875.6904] dhcp4 (wlp5s0): gateway 192.168.0.1 Aug 18 14:37:55 goofy-HPE-440ch NetworkManager[991]: <info> [1534595875.6905] dhcp4 (wlp5s0): lease time 3600 Aug 18 14:37:55 goofy-HPE-440ch NetworkManager[991]: <info> [1534595875.6905] dhcp4 (wlp5s0): hostname 'goofy-HPE-440ch' Aug 18 14:37:55 goofy-HPE-440ch NetworkManager[991]: <info> [1534595875.6906] dhcp4 (wlp5s0): nameserver '62.2.17.61' Aug 18 14:37:55 goofy-HPE-440ch NetworkManager[991]: <info> [1534595875.6906] dhcp4 (wlp5s0): nameserver '62.2.24.158' Aug 18 14:37:55 goofy-HPE-440ch NetworkManager[991]: <info> [1534595875.6906] dhcp4 (wlp5s0): nameserver '62.2.17.60' Aug 18 14:37:55 goofy-HPE-440ch NetworkManager[991]: <info> [1534595875.6907] dhcp4 (wlp5s0): nameserver '62.2.24.162' Aug 18 14:37:55 goofy-HPE-440ch NetworkManager[991]: <info> [1534595875.6907] dhcp4 (wlp5s0): domain name 'home' Aug 18 14:37:55 goofy-HPE-440ch NetworkManager[991]: <info> [1534595875.6907] dhcp4 (wlp5s0): state changed bound -> bound Aug 18 14:37:55 goofy-HPE-440ch dbus-daemon[986]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.10' (uid=0 pid=991 comm="/usr/sbin/NetworkManager --no-daemon " label="unconfined") Aug 18 14:37:55 goofy-HPE-440ch systemd[1]: Starting Network Manager Script Dispatcher Service... Aug 18 14:37:55 goofy-HPE-440ch systemd[1]: Started Network Manager Script Dispatcher Service. Aug 18 14:47:24 goofy-HPE-440ch wpa_supplicant[1003]: wlp5s0: CTRL-EVENT-DISCONNECTED bssid=ac:22:05:cf:c3:8f reason=4 locally_generated=1 Aug 18 14:47:24 goofy-HPE-440ch NetworkManager[991]: <warn> [1534596444.9396] sup-iface[0x55c003c98240,wlp5s0]: connection disconnected (reason -4) Aug 18 14:47:24 goofy-HPE-440ch NetworkManager[991]: <info> [1534596444.9656] device (wlp5s0): supplicant interface state: completed -> disconnected Aug 18 14:47:25 goofy-HPE-440ch NetworkManager[991]: <info> [1534596445.0448] device (wlp5s0): supplicant interface state: disconnected -> scanning Aug 18 14:47:25 goofy-HPE-440ch NetworkManager[991]: <info> [1534596445.1110] device (wlp5s0): supplicant interface state: scanning -> authenticating Aug 18 14:47:25 goofy-HPE-440ch NetworkManager[991]: <info> [1534596445.1397] device (wlp5s0): supplicant interface state: authenticating -> associating Aug 18 14:47:25 goofy-HPE-440ch wpa_supplicant[1003]: wlp5s0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0 Aug 18 14:47:25 goofy-HPE-440ch NetworkManager[991]: <info> [1534596445.1501] device (wlp5s0): supplicant interface state: associating -> associated Aug 18 14:47:25 goofy-HPE-440ch NetworkManager[991]: <info> [1534596445.3518] device (wlp5s0): supplicant interface state: associated -> 4-way handshake Aug 18 14:47:25 goofy-HPE-440ch NetworkManager[991]: <info> [1534596445.3572] device (wlp5s0): supplicant interface state: 4-way handshake -> completed Aug 18 14:52:41 goofy-HPE-440ch 50-motd-news[5232]: something worthwhile there for those crazy EMACS fans ;) Aug 18 15:04:04 goofy-HPE-440ch NetworkManager[991]: <info> [1534597444.1721] dhcp4 (wlp5s0): address 192.168.0.229 Aug 18 15:04:04 goofy-HPE-440ch NetworkManager[991]: <info> [1534597444.1721] dhcp4 (wlp5s0): plen 24 (255.255.255.0) Aug 18 15:04:04 goofy-HPE-440ch NetworkManager[991]: <info> [1534597444.1721] dhcp4 (wlp5s0): gateway 192.168.0.1 Aug 18 15:04:04 goofy-HPE-440ch NetworkManager[991]: <info> [1534597444.1721] dhcp4 (wlp5s0): lease time 3600 Aug 18 15:04:04 goofy-HPE-440ch NetworkManager[991]: <info> [1534597444.1721] dhcp4 (wlp5s0): hostname 'goofy-HPE-440ch' Aug 18 15:04:04 goofy-HPE-440ch NetworkManager[991]: <info> [1534597444.1722] dhcp4 (wlp5s0): nameserver '62.2.17.61' Aug 18 15:04:04 goofy-HPE-440ch NetworkManager[991]: <info> [1534597444.1722] dhcp4 (wlp5s0): nameserver '62.2.24.158' Aug 18 15:04:04 goofy-HPE-440ch NetworkManager[991]: <info> [1534597444.1722] dhcp4 (wlp5s0): nameserver '62.2.17.60' Aug 18 15:04:04 goofy-HPE-440ch NetworkManager[991]: <info> [1534597444.1722] dhcp4 (wlp5s0): nameserver '62.2.24.162' Aug 18 15:04:04 goofy-HPE-440ch NetworkManager[991]: <info> [1534597444.1722] dhcp4 (wlp5s0): domain name 'home' Aug 18 15:04:04 goofy-HPE-440ch dbus-daemon[986]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.10' (uid=0 pid=991 comm="/usr/sbin/NetworkManager --no-daemon " label="unconfined") Aug 18 15:04:04 goofy-HPE-440ch NetworkManager[991]: <info> [1534597444.1722] dhcp4 (wlp5s0): state changed bound -> bound Aug 18 15:04:04 goofy-HPE-440ch systemd[1]: Starting Network Manager Script Dispatcher Service... Aug 18 15:04:04 goofy-HPE-440ch systemd[1]: Started Network Manager Script Dispatcher Service.
goofy@goofy-HPE-440ch:~$ dmesg | egrep 'net|eth|sky|sun|sis|via|3c3|3c5|e100|8139|8169|acx|air|ath|atl|ar9|carl|atme|at7|herm|iwl|ipw|rtl8|r81|rt2|rt3|rt6|rt7|tg3|ssb|wl|b43|b44|ori|pri|p5|zd|ndis|wmi|ns8|FW|key|rtl|country' [ 0.000000] DMI: Hewlett-Packard HPE-440ch/2A9C, BIOS 6.14 11/05/2010 [ 0.000000] BRK [0x5ab43000, 0x5ab43fff] PGTABLE [ 0.000000] percpu: Embedded 46 pages/cpu @ (ptrval) s151552 r8192 d28672 u262144 [ 0.000000] pcpu-alloc: s151552 r8192 d28672 u262144 alloc=1*2097152 [ 0.000000] Calgary: detecting Calgary via BIOS EBDA area [ 0.028089] CPU0: Thermal monitoring enabled (TM1) [ 0.056438] audit: initializing netlink subsys (disabled) [ 0.081112] acpi PNP0A08:00: ignoring host bridge window [mem 0x000d0000-0x000dffff window] (conflicts with Adapter ROM [mem 0x000cf000-0x000d63ff]) [ 0.907959] Initialise system trusted keyrings [ 0.910797] Asymmetric key parser 'x509' registered [ 0.960294] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM. [ 0.971982] Loaded X.509 cert 'Build time autogenerated kernel key: cfed0c3f90bc86a77e51937f71922b89c4c6bbd5' [ 0.975011] Key type big_key registered [ 1.098611] r8169 Gigabit Ethernet driver 2.3LK-NAPI loaded [ 1.098619] r8169 0000:02:00.0: can't disable ASPM; OS doesn't have ASPM control [ 1.099032] r8169 0000:02:00.0 eth0: RTL8168d/8111d at 0x (ptrval), 6c:62:6d:7e:4b:9c, XID 081000c0 IRQ 37 [ 1.099035] r8169 0000:02:00.0 eth0: jumbo features [frames: 9200 bytes, tx checksumming: ko] [ 1.116692] r8169 0000:02:00.0 enp2s0: renamed from eth0 [ 1.452191] fbcon: nouveaufb (fb0) is primary device [ 9.102304] Adding 2097148k swap on /swapfile. Priority:-2 extents:6 across:2260988k FS [ 15.186826] ieee80211 phy0: rt2x00_set_rt: Info - RT chipset 3090, rev 3213 detected [ 15.190287] ieee80211 phy0: rt2x00_set_rf: Info - RF chipset 0005 detected [ 15.248435] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht' [ 15.336389] rt2800pci 0000:05:00.0 wlp5s0: renamed from wlan0 [ 37.865286] r8169 0000:02:00.0 enp2s0: link down [ 37.907478] IPv6: ADDRCONF(NETDEV_UP): wlp5s0: link is not ready [ 37.907531] ieee80211 phy0: rt2x00lib_request_firmware: Info - Loading firmware file 'rt2860.bin' [ 37.920612] ieee80211 phy0: rt2x00lib_request_firmware: Info - Firmware detected - version: 0.40 [ 38.097623] IPv6: ADDRCONF(NETDEV_UP): wlp5s0: link is not ready [ 38.755795] IPv6: ADDRCONF(NETDEV_UP): wlp5s0: link is not ready [ 39.865149] wlp5s0: authenticate with ac:22:05:cf:c3:8f [ 39.868646] wlp5s0: send auth to ac:22:05:cf:c3:8f (try 1/3) [ 39.870794] wlp5s0: authenticated [ 39.870898] wlp5s0: associating with AP with corrupt probe response [ 39.876016] wlp5s0: associate with ac:22:05:cf:c3:8f (try 1/3) [ 39.899105] wlp5s0: RX AssocResp from ac:22:05:cf:c3:8f (capab=0x411 status=0 aid=1) [ 39.899159] wlp5s0: associated [ 41.161242] IPv6: ADDRCONF(NETDEV_CHANGE): wlp5s0: link becomes ready [ 2070.929138] wlp5s0: authenticate with d8:b6:b7:3c:0f:ec [ 2070.934633] wlp5s0: send auth to d8:b6:b7:3c:0f:ec (try 1/3) [ 2070.958729] wlp5s0: authenticated [ 2070.959793] wlp5s0: associate with d8:b6:b7:3c:0f:ec (try 1/3) [ 2070.968835] wlp5s0: RX AssocResp from d8:b6:b7:3c:0f:ec (capab=0xc11 status=0 aid=1) [ 2070.968885] wlp5s0: associated
