Java Apllets gehen nicht und Firefoy stürzt ab
Status: Ungelöst | Ubuntu-Version: Ubuntu 8.10 (Intrepid Ibex)
Floschen
Avatar von Floschen
22. September 2005
In FF funktionieren Java-Applets nicht und gelegentlich stürzt der Browser dabei auch ab ☹
Hier der Auszug aus der Konsole:
 31
 32
 33
 34
 35
 36
 37
 38
 39
 40
 41
 42
 43
 44
 45
 46
 47
 48
 49
 50
 51
 52
 53
 54
 55
 56
 57
 58
 59
 60
 61
 62
 63
 64
 65
 66
 67
 68
 69
 70
 71
 72
 73
 74
 75
 76
 77
 78
 79
 80
 81
 82
 83
 84
 85
 86
 87
 88
 89
 90
 91
 92
 93
 94
 95
 96
 97
 98
 99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
~$firefox
Gtk-Message: (for origin information, set GTK_DEBUG): failed to retrieve property `GtkTreeView::odd-row-color' of type `GdkColor' from rc file value "((GString*) 0x2578500)" of type `GString'
GCJ PLUGIN: thread 0x23c8870: NP_Initialize
GCJ PLUGIN: thread 0x23c8870: NP_Initialize: using /usr/lib/classpath/gappletviewer.
GCJ PLUGIN: thread 0x23c8870: NP_Initialize return
GCJ PLUGIN: thread 0x23c8870: GCJ_New
GCJ PLUGIN: thread 0x23c8870: plugin_data_new
GCJ PLUGIN: thread 0x23c8870: plugin_data_new return
GCJ PLUGIN: thread 0x23c8870: plugin_get_documentbase
GCJ PLUGIN: thread 0x23c8870: plugin_get_documentbase return
GCJ PLUGIN: thread 0x23c8870: plugin_start_appletviewer
GCJ PLUGIN: thread 0x23c8870: plugin_start_appletviewer return
GCJ PLUGIN: thread 0x23c8870: GCJ_New: got confirmation that appletviewer is running.
GCJ PLUGIN: thread 0x23c8870: plugin_create_applet_tag
GCJ PLUGIN: thread 0x23c8870: plugin_create_applet_tag return
GCJ PLUGIN: thread 0x23c8870: plugin_send_message_to_appletviewer
  PIPE: plugin wrote instance-14768-0
GCJ PLUGIN: thread 0x23c8870: plugin_send_message_to_appletviewer return
  PIPE: plugin wrote tag http://www.ingrammicro.de/ec/imorder/ <EMBED CODE="App_IMOrder.class" ARCHIVE="http://ec.ingrammicro.de/java/obs/app_imorder.jar" HEIGHT="198" WIDTH="468" ><PARAM NAME="LogoText" VALUE="INGRAM MICRO GERMANY  IM.ORDER 2005"><PARAM NAME="Company" VALUE="DE"><PARAM NAME="BranchNr" VALUE="44"><PARAM NAME="UserID" VALUE="000"><PARAM NAME="Language" VALUE="DE"><PARAM NAME="TabPanel" VALUE="0"><PARAM NAME="SKU" VALUE=""><PARAM NAME="cgi" VALUE="http://ec.ingrammicro.de/cgi-bin/imorder/"><PARAM NAME="cgissl" VALUE="https://ec.ingrammicro.de/cgi-bin/imorder/"><PARAM NAME="PicUrl" VALUE="http://ec.ingrammicro.de/obs/promo_de/"><PARAM NAME="JpgUrl" VALUE="http://ec.ingrammicro.de/jpg/"><PARAM NAME="PdfUrl" VALUE="http://ec.ingrammicro.de/pdf/"><PARAM NAME="progressbar" VALUE="true"><PARAM NAME="progresscolor" VALUE="#EBEBEB"><PARAM NAME="boxbgcolor" VALUE="#81AAD7"><PARAM NAME="boxfgcolor" VALUE="#000000"></EMBED>
GCJ PLUGIN: thread 0x23c8870: GCJ_New return
GCJ PLUGIN: thread 0x23c8870: NP_GetValue
GCJ PLUGIN: thread 0x23c8870: NP_GetValue: returning plugin description.
GCJ PLUGIN: thread 0x23c8870: NP_GetValue return
GCJ PLUGIN: thread 0x23c8870: GCJ_GetValue
GCJ PLUGIN: thread 0x23c8870: GCJ_GetValue: returning TRUE for NeedsXEmbed.
GCJ PLUGIN: thread 0x23c8870: GCJ_GetValue return
GCJ PLUGIN: thread 0x23c8870: GCJ_SetWindow
GCJ PLUGIN: thread 0x23c8870: GCJ_SetWindow: setting window.
  PIPE: plugin wrote handle 71304746
GCJ PLUGIN: thread 0x23c8870: GCJ_SetWindow return
gcjwebplugin.cc:601: thread 0x23c8870: Error: Unknown plugin value requested.
GCJ PLUGIN: thread 0x23c8870: GCJ_SetWindow: window already exists.
GCJ PLUGIN: thread 0x23c8870: GCJ_SetWindow: window width changed.
  PIPE: plugin wrote width 468
GCJ PLUGIN: thread 0x23c8870: GCJ_SetWindow: window height changed.
  PIPE: plugin wrote height 198
  PIPE: applet viewer wrote:running
  PIPE: applet viewer read:instance-14768-0
gcjwebplugin.cc:978: thread 0x23c8870: Error: Failed to read line from whitelist file.
  PIPE: applet viewer read:tag http://www.ingrammicro.de/ec/imorder/ <EMBED CODE="App_IMOrder.class" ARCHIVE="http://ec.ingrammicro.de/java/obs/app_imorder.jar" HEIGHT="198" WIDTH="468" ><PARAM NAME="LogoText" VALUE="INGRAM MICRO GERMANY  IM.ORDER 2005"><PARAM NAME="Company" VALUE="DE"><PARAM NAME="BranchNr" VALUE="44"><PARAM NAME="UserID" VALUE="000"><PARAM NAME="Language" VALUE="DE"><PARAM NAME="TabPanel" VALUE="0"><PARAM NAME="SKU" VALUE=""><PARAM NAME="cgi" VALUE="http://ec.ingrammicro.de/cgi-bin/imorder/"><PARAM NAME="cgissl" VALUE="https://ec.ingrammicro.de/cgi-bin/imorder/"><PARAM NAME="PicUrl" VALUE="http://ec.ingrammicro.de/obs/promo_de/"><PARAM NAME="JpgUrl" VALUE="http://ec.ingrammicro.de/jpg/"><PARAM NAME="PdfUrl" VALUE="http://ec.ingrammicro.de/pdf/"><PARAM NAME="progressbar" VALUE="true"><PARAM NAME="progresscolor" VALUE="#EBEBEB"><PARAM NAME="boxbgcolor" VALUE="#81AAD7"><PARAM NAME="boxfgcolor" VALUE="#000000"></EMBED>
  PIPE: applet viewer read:handle 71304746
(firefox:14768): Gdk-CRITICAL **: gdk_window_get_user_data: assertion `window != NULL' failed
(firefox:14768): Gtk-CRITICAL **: gtk_container_add: assertion `GTK_IS_CONTAINER (container)' failed
(firefox:14768): Gtk-CRITICAL **: gtk_widget_realize: assertion `GTK_WIDGET_ANCHORED (widget) || GTK_IS_INVISIBLE (widget)' failed
(firefox:14768): Gtk-CRITICAL **: gtk_socket_get_id: assertion `GTK_WIDGET_ANCHORED (socket)' failed
(.:14800): Gdk-WARNING **: GdkWindow 0x5400003 unexpectedly destroyed
Exception in thread "GTK main thread" java.lang.InternalError: Gdk: GdkWindow 0x5400003 unexpectedly destroyed
   at gnu.java.awt.peer.gtk.GtkToolkit.gtkMain(Native Method)
   at gnu.java.awt.peer.gtk.GtkMainThread.run(GtkMainThread.java:102)
   at java.lang.VMThread.run(VMThread.java:120)
Segmentation fault
jochen@T611:2019~$
(.:14800): GLib-GObject-WARNING **: invalid unclassed pointer in cast to `GtkWidget'
Exception in thread "main" java.lang.InternalError: GLib-GObject: invalid unclassed pointer in cast to `GtkWidget'
   at gnu.java.awt.peer.gtk.GtkComponentPeer.gtkWidgetSetParent(Native Method)
   at gnu.java.awt.peer.gtk.GtkComponentPeer.setParent(GtkComponentPeer.java:188)
   at gnu.java.awt.peer.gtk.GtkComponentPeer.setParentAndBounds(GtkComponentPeer.java:169)
   at gnu.java.awt.peer.gtk.GtkComponentPeer.<init>(GtkComponentPeer.java:154)
   at gnu.java.awt.peer.gtk.GtkContainerPeer.<init>(GtkContainerPeer.java:55)
   at gnu.java.awt.peer.gtk.GtkPanelPeer.<init>(GtkPanelPeer.java:53)
   at gnu.java.awt.peer.gtk.GtkToolkit.createPanel(GtkToolkit.java:540)
   at java.awt.Panel.addNotify(Panel.java:108)
   at java.awt.Container.addImpl(Container.java:374)
   at java.awt.Container.add(Container.java:228)
   at gnu.classpath.tools.appletviewer.PluginAppletWindow.setHandle(PluginAppletWindow.java:429)
   at gnu.classpath.tools.appletviewer.PluginAppletViewer.start(PluginAppletViewer.java:106)
   at gnu.classpath.tools.appletviewer.Main.main(Main.java:263)
(.:14800): GLib-GObject-WARNING **: invalid unclassed pointer in cast to `GtkFixed'
Exception in thread "main" java.lang.InternalError: GLib-GObject: invalid unclassed pointer in cast to `GtkFixed'
(.:14800): Gtk-CRITICAL **: gtk_fixed_put: assertion `GTK_IS_FIXED (fixed)' failed
Exception in thread "main" java.lang.InternalError: Gtk: gtk_fixed_put: assertion `GTK_IS_FIXED (fixed)' failed
(.:14800): Gtk-CRITICAL **: gtk_widget_realize: assertion `GTK_WIDGET_ANCHORED (widget) || GTK_IS_INVISIBLE (widget)' failed
Exception in thread "main" java.lang.InternalError: Gtk: gtk_widget_realize: assertion `GTK_WIDGET_ANCHORED (widget) || GTK_IS_INVISIBLE (widget)' failed
   at gnu.java.awt.peer.gtk.GtkComponentPeer.realize(Native Method)
   at gnu.java.awt.peer.gtk.GtkComponentPeer.<init>(GtkComponentPeer.java:161)
aptitude search jre
p   cacao-oj6-jre                                                           - OpenJDK Java runtime, using CacaoVM JIT
p   cacao-oj6-jre-headless                                                  - OpenJDK Java runtime, using CacaoVM JIT (headless)
p   cacao-oj6-jre-lib                                                       - OpenJDK Java runtime (architecture independent libraries)
p   default-jre                                                             - Standard Java or Java compatible Runtime
p   default-jre-headless                                                    - Standard Java or Java compatible Runtime (headless)
p   docbook-jrefentry                                                       - DocBook XML JRefEntry DTD
p   libjrexx-java                                                           - automaton based regular expression API for java
i A openjdk-6-jre                                                           - OpenJDK Java runtime, using Hotspot JIT
i A openjdk-6-jre-headless                                                  - OpenJDK Java runtime, using Hotspot JIT (headless)
i A openjdk-6-jre-lib                                                       - OpenJDK Java runtime (architecture independent libraries)
c   sun-java5-jre                                                           - Sun Java(TM) Runtime Environment (JRE) 5.0 (architecture independent files)
i   sun-java6-jre                                                           - Sun Java(TM) Runtime Environment (JRE) 6 (architecture independent files)
openjdk und sun-java6 sind installiert.
