UlfZibis
Anmeldungsdatum: 13. Juli 2011
Hallo, ich habe hier den oben genannten Drucker. Wenn ich die grüne Taste länger drücke, druckt er die Druckerinterne Testseite, wunderbar. Wenn ich von Ubuntu aus eine Testseite drucken will, passiert einfach nichts: $ hp-testpage -i
HP Linux Imaging and Printing System (ver. 3.17.10)
Testpage Print Utility ver. 6.0
Copyright (c) 2001-15 HP Development Company, LP
| SELECT PRINTER |
Num CUPS Printer
0* hp-LaserJet-1320-series_USB
1 hp_LaserJet_1320
Enter number 0...1 for printer (q=quit, <enter>=default: *0) ?0
Printing test page to printer hp-LaserJet-1320-series_USB...
Test page has been sent to printer.
note: If an error occured, or the test page failed to print, refer to the HPLIP website
note: at: http://hplip.sourceforge.net for troubleshooting and support.
Done.
$ hp-testpage -i
| SELECT PRINTER |
Num CUPS Printer
1 hp_LaserJet_1320
Enter number 0...1 for printer (q=quit, <enter>=default: *0) ?1
Printing test page to printer hp_LaserJet_1320...
Done.
Hir noch die Druckerinfo: $ hp-info -i
Device Information Utility ver. 5.2
hp:/usb/hp_LaserJet_1320_series?serial=00CNHW55TGZ5
Device Parameters (dynamic data):
Parameter Value(s)
agent1-ack False
agent1-desc Black toner cartridge
agent1-dvc 0
agent1-health 0
agent1-health-desc Good/OK
agent1-hp-ink False
agent1-id 0
agent1-kind 4
agent1-known False
agent1-level 72
agent1-level-trigger 0
agent1-sku Q5949A/Q5949X
agent1-type 1
agent1-virgin False
back-end hp
cups-printers ['hp-LaserJet-1320-series_USB', 'hp_LaserJet_1320']
cups-uri hp:/usb/hp_LaserJet_1320_series?serial=00CNHW55TGZ5
dev-file
device-state 1
device-uri hp:/usb/hp_LaserJet_1320_series?serial=00CNHW55TGZ5
deviceid MFG:Hewlett-Packard;CMD:PJL,MLC,BIDI-ECP,PCL,POSTSCRIPT,PC
LXL;MDL:hp LaserJet 1320
series;CLS:PRINTER;DES:Hewlett-Packard LaserJet 1320
series;MEM:9MB;COMMENT:R=1200x1;1;
duplexer 1
error-state 0
host
in-tray1 1
in-tray2 1
is-hp True
media-path 1
panel 1
panel-line1 b'Ready'
panel-line2 b''
photo-tray 0
port 1
r 0
revision 254
rg 000
rr 000000
rs 000000000
serial 00CNHW55TGZ5
status-code 1000
status-desc Idle
supply-door 1
top-door 4
Model Parameters (static data):
Parameter Value(s)
align-type 0
clean-type 0
color-cal-type 0
copy-type 0
embedded-server-type 1
fax-type 0
fw-download False
io-mfp-mode 6
io-mode 1
io-support 6
job-storage 0
linefeed-cal-type 0
model hp_LaserJet_1320_series
model-ui HP LaserJet 1320 Series
model1 HP LaserJet 1320 Series Printer
monitor-type 0
panel-check-type 1
pcard-type 0
plugin 0
plugin-reason 0
power-settings 0
pq-diag-type 0
r-type 0
r0-agent1-kind 4
r0-agent1-sku Q5949A/Q5949X
r0-agent1-type 1
scan-src 0
scan-type 0
status-battery-check 0
status-dynamic-counters 0
status-type 3
support-released True
support-subtype 14852
support-type 2
support-ver 0.9.5
tech-class ['LJMono', 'Postscript']
tech-subclass ['Normal']
tech-type 3
usb-pid 7447
usb-vid 1008
wifi-config 0
Status History (most recent first):
Date/Time Code Status Description User Job ID
10/10/19 00:27:07 1000 Idle ich 0
10/10/19 00:25:58 501 Print job has completed ich 132
10/10/19 00:25:57 500 Started a print job ich 132
10/10/19 00:23:16 501 Print job has completed ich 135
10/10/19 00:23:16 500 Started a print job ich 135
10/10/19 00:23:15 1000 Idle ich 0
10/10/19 00:22:55 501 Print job has completed ich 134
10/10/19 00:22:55 500 Started a print job ich 134
10/10/19 00:22:54 1000 Idle ich 0
10/10/19 00:22:22 501 Print job has completed ich 133
10/10/19 00:22:22 500 Started a print job ich 133
10/10/19 00:22:22 1000 Idle ich 0
10/10/19 00:20:56 501 Print job has completed ich 132
10/10/19 00:20:56 500 Started a print job ich 132
10/10/19 00:15:46 501 Print job has completed ich 132
10/10/19 00:15:46 500 Started a print job ich 132
10/10/19 00:15:45 1000 Idle ich 0
Done.
Was kann ich tun? Ist der Drucker evtl. kaputt?
kB
Ist der Drucker eingeschaltet? Ist er ordnungsgemäß angeschlossen? Läuft der Druckserver CUPS? Ist der Drucker in CUPS eingerichtet? Akzeptiert die Warteschlange für den Drucker Aufträge? Werden auch Druckaufträge aus der Warteschlange abgearbeitet?
Die Fragen 3-6 beantwortet dieser Befehl: lpstat -t
Kellerkind_2009
Der Drucker wird nicht mehr von HP unterstützt (End of Support) Er sollte aber Postscript können tech-class ['LJMono', 'Postscript'] Stelle den Treiber mal auf Postscript um in system-config-printer und probiere es aus.
UlfZibis
kB schrieb: Ist der Drucker eingeschaltet?
Meinst Du die Frage wirklich ernst? Ist er ordnungsgemäß angeschlossen?
Was könnte denn an meiner Anschließung nicht der Ordnung gemäß sein? Läuft der Druckserver CUPS? Ist der Drucker in CUPS eingerichtet? Akzeptiert die Warteschlange für den Drucker Aufträge?
Ja. Werden auch Druckaufträge aus der Warteschlange abgearbeitet?
Nein. Die Fragen 3-6 beantwortet dieser Befehl: lpstat -t
Ich denke, die werden auch schon von den oben beigefügten Ausgaben beantwortet, aber bitteschön: $ lpstat -t
Zeitplandienst läuft
systemvoreingestelltes Ziel: Epson-WF-2630_USB
Gerät für Canon-MX880-3.50-1_FRITZ!Box: socket://fritz.box:9100
Gerät für Canon-MX880-3.50-1_USB: cnijusb:/dev/usb/lp0
Gerät für Canon-MX880-3.90_FRITZ!Box: socket://fritz.box:9100
Gerät für Canon-MX880-3.90_USB: usb://Canon/MX880%20series?serial=10283A&interface=1
Gerät für Epson-WF-2630_USB: usb://EPSON/WF-2630%20Series?serial=554D43593237333652&interface=1
Gerät für hp_LaserJet_1320: hp:/usb/hp_LaserJet_1320_series?serial=00CNHW55TGZ5
Gerät für MX880-series_FRITZ!Box: socket://fritz.box:9100
Gerät für MX880-series_USB: usb://Canon/MX880%20series?serial=10283A&interface=1
Canon-MX880-3.50-1_FRITZ!Box akzeptiert anfragen seit So 23 Sep 2018 04:08:10 CEST
Canon-MX880-3.50-1_USB akzeptiert anfragen seit So 23 Sep 2018 04:00:16 CEST
Canon-MX880-3.90_FRITZ!Box akzeptiert anfragen seit Do 08 Nov 2018 14:55:34 CET
Canon-MX880-3.90_USB akzeptiert anfragen seit So 23 Sep 2018 02:49:32 CEST
Epson-WF-2630_USB akzeptiert anfragen seit Do 13 Jun 2019 23:44:31 CEST
hp_LaserJet_1320 akzeptiert anfragen seit Do 10 Okt 2019 11:37:28 CEST
MX880-series_FRITZ!Box akzeptiert anfragen seit So 23 Sep 2018 04:10:31 CEST
MX880-series_USB akzeptiert anfragen seit So 23 Sep 2018 02:06:02 CEST
Drucker Canon-MX880-3.50-1_FRITZ!Box ist im Leerlauf. Aktiviert seit So 23 Sep 2018 04:08:10 CEST
Drucker Canon-MX880-3.50-1_USB ist im Leerlauf. Aktiviert seit So 23 Sep 2018 04:00:16 CEST
Drucker Canon-MX880-3.90_FRITZ!Box ist im Leerlauf. Aktiviert seit Do 08 Nov 2018 14:55:34 CET
Drucker Canon-MX880-3.90_USB ist im Leerlauf. Aktiviert seit So 23 Sep 2018 02:49:32 CEST
Drucker Epson-WF-2630_USB ist im Leerlauf. Aktiviert seit Do 13 Jun 2019 23:44:31 CEST
Drucker hp_LaserJet_1320 ist im Leerlauf. Aktiviert seit Do 10 Okt 2019 11:37:28 CEST
Drucker MX880-series_FRITZ!Box ist im Leerlauf. Aktiviert seit So 23 Sep 2018 04:10:31 CEST
Drucker MX880-series_USB ist im Leerlauf. Aktiviert seit So 23 Sep 2018 02:06:02 CEST
hp_LaserJet_1320-136 ich 1024 Do 10 Okt 2019 11:37:28 CEST
UlfZibis
Kellerkind_2009 schrieb: Der Drucker wird nicht mehr von HP unterstützt (End of Support) Er sollte aber Postscript können tech-class ['LJMono', 'Postscript']
Könnte das heißen, dass HP den Drucker aus den neueren Treiber-Versionen rausgeschmissen hat, ich also einen älteren HPLIP-Treiber brauche? Stelle den Treiber mal auf Postscript um in system-config-printer
Meinst Du das? : Geräteadresse: hp:/usb/hp_LaserJet_1320_series?serial=00CNHW55TGZ5
Marke und Modell: HP LaserJet 1320 series Postscript (recommended)
Hatte ich schon so eingestellt, nutzt aber nichts. EDIT: Folgende Treiber habe ich zur Auswahl und alle schon ausprobiert:
- Bilder
Kellerkind_2009
Richtig
Ja,das war der erste Versuch.Wähle mal den "Generic" (Screenshot)Treiber aus – ebenfalls PostScript,sowie neue PPD. Canon und Epson laufen normal?
- Bilder
UlfZibis
Kellerkind_2009 schrieb: Könnte das heißen, dass HP den Drucker aus den neueren Treiber-Versionen rausgeschmissen hat, ich also einen älteren HPLIP-Treiber brauche?
Richtig
Ich frage mich dann aber doch, warum er vom aktuellen Treiber mittels hp-info erkannt wird. Ja,das war der erste Versuch.Wähle mal den "Generic" (Screenshot)Treiber aus – ebenfalls PostScript,sowie neue PPD.
Da habe ich die Auswahl mit und ohne "Foomatic", mit ersterem bekomme ich kurzzeitig "Druckerstatus: Untätig - Filter failed", aber beide gehen nicht. EDIT: Im Warteschlangendialog werden alle Jobs mit "Angehalten" angegeben. Ein erneuter Start bringt nichts. Die von hplip-gui erzeugten Onscreen-Blasen sagen immer: "Print job has completed". Canon und Epson laufen normal?
Ja. Bitte auch meinen anderen EDIT weiter oben beachten!
- Bilder
Kellerkind_2009
Hmm,wie sieht denn die log aus? Wähle zuerst wieder den HP Treiber.Dann Druckversuch,dann Ausgabe von tail -n 150 /var/log/cups/error_log sowie hp-check -r systemctl --no-pager status cups*
UlfZibis
Hups, bist Du schnell, komme ja gar nicht mit 😉 (siehe meine EDITs) Kellerkind_2009 schrieb: Hmm,wie sieht denn die log aus? Wähle zuerst wieder den HP Treiber.Dann Druckversuch,dann Ausgabe von
$ tail -n 150 /var/log/cups/error_log
D [10/Oct/2019:12:35:56 +0200] [Job 138] envp[23]="DEVICE_URI=hp:/usb/hp_LaserJet_1320_series?serial=00CNHW55TGZ5"
D [10/Oct/2019:12:35:56 +0200] [Job 138] envp[24]="PRINTER_INFO="
D [10/Oct/2019:12:35:56 +0200] [Job 138] envp[25]="PRINTER_LOCATION="
D [10/Oct/2019:12:35:56 +0200] [Job 138] envp[26]="PRINTER=hp_LaserJet_1320"
D [10/Oct/2019:12:35:56 +0200] [Job 138] envp[27]="PRINTER_STATE_REASONS=none"
D [10/Oct/2019:12:35:56 +0200] [Job 138] envp[28]="CUPS_FILETYPE=document"
D [10/Oct/2019:12:35:56 +0200] [Job 138] envp[29]="FINAL_CONTENT_TYPE=application/vnd.cups-pdf"
D [10/Oct/2019:12:35:56 +0200] [Job 138] envp[30]="AUTH_I****"
D [10/Oct/2019:12:35:56 +0200] [Job 138] Started filter /usr/lib/cups/filter/bannertopdf (PID 18211)
D [10/Oct/2019:12:35:56 +0200] [Job 138] Started filter /usr/lib/cups/filter/pdftopdf (PID 18212)
D [10/Oct/2019:12:35:56 +0200] [Job 138] Started filter /usr/lib/cups/filter/foomatic-rip (PID 18213)
D [10/Oct/2019:12:35:56 +0200] [Job 138] Started backend /usr/lib/cups/backend/hp (PID 18214)
D [10/Oct/2019:12:35:56 +0200] [Job 138] pdftopdf: Last filter determined by the PPD: foomatic-rip; FINAL_CONTENT_TYPE: application/vnd.cups-pdf => pdftopdf will log pages in page_log.
D [10/Oct/2019:12:35:56 +0200] [Job 138] PDF template file doesn\'t have form. It\'s okay.
D [10/Oct/2019:12:35:56 +0200] [Job 138] PID 18211 (/usr/lib/cups/filter/bannertopdf) exited with no errors.
D [10/Oct/2019:12:35:56 +0200] [Job 138] PAGE: 1 1
D [10/Oct/2019:12:35:56 +0200] [Job 138] PID 18212 (/usr/lib/cups/filter/pdftopdf) exited with no errors.
D [10/Oct/2019:12:35:56 +0200] [Job 138] Calling FindDeviceById(cups-hp_LaserJet_1320)
D [10/Oct/2019:12:35:56 +0200] [Job 138] Found device /org/freedesktop/ColorManager/devices/cups_hp_LaserJet_1320
D [10/Oct/2019:12:35:56 +0200] [Job 138] Calling org.freedesktop.ColorManager.Device.Get(ProfilingInhibitors)
D [10/Oct/2019:12:35:56 +0200] [Job 138] \'CM Color Calibration\' Mode in SPOOLER-LESS: Off
D [10/Oct/2019:12:35:56 +0200] [Job 138] Getting input from file
D [10/Oct/2019:12:35:56 +0200] [Job 138] foomatic-rip version 1.20.2 running...
D [10/Oct/2019:12:35:56 +0200] [Job 138] Parsing PPD file ...
D [10/Oct/2019:12:35:56 +0200] [Job 138] Added option ColorSpace
D [10/Oct/2019:12:35:56 +0200] [Job 138] Added option PageSize
D [10/Oct/2019:12:35:56 +0200] [Job 138] Added option ImageableArea
D [10/Oct/2019:12:35:56 +0200] [Job 138] Added option PaperDimension
D [10/Oct/2019:12:35:56 +0200] [Job 138] Added option InputSlot
D [10/Oct/2019:12:35:56 +0200] [Job 138] Added option Duplex
D [10/Oct/2019:12:35:56 +0200] [Job 138] Added option Resolution
D [10/Oct/2019:12:35:56 +0200] [Job 138] Added option Font
D [10/Oct/2019:12:35:56 +0200] [Job 138] Parameter Summary
D [10/Oct/2019:12:35:56 +0200] [Job 138] -----------------
D [10/Oct/2019:12:35:56 +0200] [Job 138] Spooler: cups
D [10/Oct/2019:12:35:56 +0200] [Job 138] Printer: hp_LaserJet_1320
D [10/Oct/2019:12:35:56 +0200] [Job 138] Shell: /bin/sh
D [10/Oct/2019:12:35:56 +0200] [Job 138] PPD file: /etc/cups/ppd/hp_LaserJet_1320.ppd
D [10/Oct/2019:12:35:56 +0200] [Job 138] ATTR file:
D [10/Oct/2019:12:35:56 +0200] [Job 138] Printer model: Generic PostScript Printer Foomatic/Postscript (recommended)
D [10/Oct/2019:12:35:56 +0200] [Job 138] Job title: Test Page
D [10/Oct/2019:12:35:56 +0200] [Job 138] File(s) to be printed:
D [10/Oct/2019:12:35:56 +0200] [Job 138] <STDIN>
D [10/Oct/2019:12:35:56 +0200] [Job 138] Ghostscript extra search path (\'GS_LIB\'): /usr/share/cups/fonts
D [10/Oct/2019:12:35:56 +0200] [Job 138] Printing system options:
D [10/Oct/2019:12:35:56 +0200] [Job 138] Pondering option \'job-uuid=urn:uuid:36d8e77c-b696-3cd3-6e87-779a1ff35dba\'
D [10/Oct/2019:12:35:56 +0200] [Job 138] Unknown option job-uuid=urn:uuid:36d8e77c-b696-3cd3-6e87-779a1ff35dba.
D [10/Oct/2019:12:35:56 +0200] [Job 138] Pondering option \'job-originating-host-name=localhost\'
D [10/Oct/2019:12:35:56 +0200] [Job 138] Unknown option job-originating-host-name=localhost.
D [10/Oct/2019:12:35:56 +0200] [Job 138] Pondering option \'date-time-at-creation=\'
D [10/Oct/2019:12:35:56 +0200] [Job 138] Unknown option date-time-at-creation=.
D [10/Oct/2019:12:35:56 +0200] [Job 138] Pondering option \'date-time-at-processing=\'
D [10/Oct/2019:12:35:56 +0200] [Job 138] Unknown option date-time-at-processing=.
D [10/Oct/2019:12:35:56 +0200] [Job 138] Pondering option \'time-at-creation=1570702436\'
D [10/Oct/2019:12:35:56 +0200] [Job 138] Unknown option time-at-creation=1570702436.
D [10/Oct/2019:12:35:56 +0200] [Job 138] Pondering option \'time-at-processing=1570703739\'
D [10/Oct/2019:12:35:56 +0200] [Job 138] Unknown option time-at-processing=1570703739.
D [10/Oct/2019:12:35:56 +0200] [Job 138] CM Color Calibration Mode in CUPS: Off
D [10/Oct/2019:12:35:56 +0200] [Job 138] Options from the PPD file:
D [10/Oct/2019:12:35:56 +0200] [Job 138] ================================================
D [10/Oct/2019:12:35:56 +0200] [Job 138] File: <STDIN>
D [10/Oct/2019:12:35:56 +0200] [Job 138] Filetype: PDF
D [10/Oct/2019:12:35:56 +0200] [Job 138] PostScript option found: PageSize=Letter: \"<</PageSize[612 792]/ImagingBBox null>>setpagedevice\"
D [10/Oct/2019:12:35:56 +0200] [Job 138] Driver does not understand PDF input, converting to PostScript
D [10/Oct/2019:12:35:56 +0200] [Job 138] Storing temporary files in /tmp
D [10/Oct/2019:12:35:56 +0200] [Job 138] Starting process \"pdf-to-ps\" (generation 1)
D [10/Oct/2019:12:35:56 +0200] [Job 138] Printer make and model: Generic PostScript Printer
D [10/Oct/2019:12:35:56 +0200] [Job 138] Running command line for pstops: pstops 138 ich \'Test Page\' 1 \' job-uuid=urn:uuid:36d8e77c-b696-3cd3-6e87-779a1ff35dba job-originating-host-name=localhost date-time-at-creation= date-time-at-processing= time-at-creation=1570702436 time-at-processing=1570703739\'
D [10/Oct/2019:12:35:56 +0200] [Job 138] Using image rendering resolution 600 dpi
D [10/Oct/2019:12:35:56 +0200] [Job 138] Running command line for gs: gs -q -dNOPAUSE -dBATCH -dSAFER -dNOMEDIAATTRS -sDEVICE=ps2write -dShowAcroForm -sOUTPUTFILE=%stdout -dLanguageLevel=3 -r600 -dCompressFonts=false -dNoT3CCITT -dNOINTERPOLATE -c \'save pop\' -f /tmp/foomatic-bJGqcH
D [10/Oct/2019:12:35:56 +0200] [Job 138] Started filter gs (PID 18217)
D [10/Oct/2019:12:35:56 +0200] [Job 138] Started filter pstops (PID 18218)
D [10/Oct/2019:12:35:56 +0200] [Job 138] Page = 595x842; 18,36 to 577,806
D [10/Oct/2019:12:35:56 +0200] [Job 138] slow_collate=0, slow_duplex=0, slow_order=0
D [10/Oct/2019:12:35:56 +0200] [Job 138] Before copy_comments - %!PS-Adobe-3.0
D [10/Oct/2019:12:35:56 +0200] [Job 138] %!PS-Adobe-3.0
D [10/Oct/2019:12:35:56 +0200] [Job 138] %%BoundingBox: 0 0 595 842
D [10/Oct/2019:12:35:56 +0200] [Job 138] %%HiResBoundingBox: 0 0 595.00 842.00
D [10/Oct/2019:12:35:56 +0200] [Job 138] %%Creator: GPL Ghostscript 926 (ps2write)
D [10/Oct/2019:12:35:56 +0200] [Job 138] %%LanguageLevel: 2
D [10/Oct/2019:12:35:56 +0200] [Job 138] %%CreationDate: D:20191010123539+02\'00\'
D [10/Oct/2019:12:35:56 +0200] [Job 138] %%Pages: 1
D [10/Oct/2019:12:35:56 +0200] [Job 138] %%EndComments
D [10/Oct/2019:12:35:56 +0200] [Job 138] Before copy_prolog - %%BeginProlog
D [10/Oct/2019:12:35:56 +0200] [Job 138] Filetype: PostScript
D [10/Oct/2019:12:35:56 +0200] [Job 138] Reading PostScript input ...
D [10/Oct/2019:12:35:56 +0200] [Job 138] --> This document is DSC-conforming!
D [10/Oct/2019:12:35:56 +0200] [Job 138] Found %RBINumCopies: 1
D [10/Oct/2019:12:35:56 +0200] [Job 138] Found: %%BeginProlog
D [10/Oct/2019:12:35:56 +0200] [Job 138] Inserting option code into \"Prolog\" section.
D [10/Oct/2019:12:35:56 +0200] [Job 138] Before copy_setup - %%Page: 1 1
D [10/Oct/2019:12:35:56 +0200] [Job 138] Before page loop - %%Page: 1 1
D [10/Oct/2019:12:35:56 +0200] [Job 138] Copying page 1...
D [10/Oct/2019:12:35:56 +0200] [Job 138] pagew = 559.0, pagel = 770.0
D [10/Oct/2019:12:35:56 +0200] [Job 138] bboxx = 0, bboxy = 0, bboxw = 595, bboxl = 842
D [10/Oct/2019:12:35:56 +0200] [Job 138] PageLeft = 18.0, PageRight = 577.0
D [10/Oct/2019:12:35:56 +0200] [Job 138] PageTop = 806.0, PageBottom = 36.0
D [10/Oct/2019:12:35:56 +0200] [Job 138] PageWidth = 595.0, PageLength = 842.0
D [10/Oct/2019:12:35:56 +0200] [Job 138] Found: %%EndProlog
D [10/Oct/2019:12:35:56 +0200] [Job 138] Found: %%BeginSetup
D [10/Oct/2019:12:35:56 +0200] [Job 138] Found: %%BeginFeature: *Resolution 600x600dpi
D [10/Oct/2019:12:35:56 +0200] [Job 138] Option: Resolution=600x600dpi
D [10/Oct/2019:12:35:56 +0200] [Job 138] --> Option will be set by PostScript interpreter
D [10/Oct/2019:12:35:56 +0200] [Job 138] Found: %%BeginFeature: *PageSize A4
D [10/Oct/2019:12:35:56 +0200] [Job 138] Option: PageSize=A4
D [10/Oct/2019:12:35:56 +0200] [Job 138] Found: %%BeginFeature: *InputSlot Default
D [10/Oct/2019:12:35:56 +0200] [Job 138] Option: InputSlot=Default
D [10/Oct/2019:12:35:56 +0200] [Job 138] Found: %%BeginFeature: *Duplex None
D [10/Oct/2019:12:35:56 +0200] [Job 138] Option: Duplex=None
D [10/Oct/2019:12:35:56 +0200] [Job 138] Found: %%EndSetup
D [10/Oct/2019:12:35:56 +0200] [Job 138] New page: %%Page: 1 1
D [10/Oct/2019:12:35:56 +0200] [Job 138] \"Setup\" section is missing, inserting it.
D [10/Oct/2019:12:35:56 +0200] [Job 138] Inserting option code into \"Setup\" section.
D [10/Oct/2019:12:35:56 +0200] [Job 138] Found: %%BeginPageSetup
D [10/Oct/2019:12:35:56 +0200] [Job 138] Inserting option code into \"PageSetup\" section.
D [10/Oct/2019:12:35:56 +0200] [Job 138] PID 18217 (gs) exited with no errors.
D [10/Oct/2019:12:35:56 +0200] [Job 138] Wrote 1 pages...
D [10/Oct/2019:12:35:56 +0200] [Job 138] PID 18218 (pstops) exited with no errors.
D [10/Oct/2019:12:35:56 +0200] [Job 138] Flushing FIFO.
D [10/Oct/2019:12:35:56 +0200] [Job 138] Starting renderer with command: \"cat\"
D [10/Oct/2019:12:35:56 +0200] [Job 138] Starting process \"kid3\" (generation 1)
D [10/Oct/2019:12:35:56 +0200] [Job 138] Starting process \"kid4\" (generation 2)
D [10/Oct/2019:12:35:56 +0200] [Job 138] Starting process \"renderer\" (generation 2)
D [10/Oct/2019:12:35:56 +0200] [Job 138] JCL: \033%-12345X@PJL
D [10/Oct/2019:12:35:56 +0200] [Job 138] <job data>
D [10/Oct/2019:12:35:56 +0200] [Job 138] STATE: +connecting-to-device
D [10/Oct/2019:12:35:56 +0200] [Job 138] PID 18214 (/usr/lib/cups/backend/hp) stopped with status 1.
D [10/Oct/2019:12:35:56 +0200] [Job 138] Hint: Try setting the LogLevel to "debug" to find out more.
D [10/Oct/2019:12:35:56 +0200] [Job 138] prnt/backend/hp.c 824: ERROR: open device failed stat=12: hp:/usb/hp_LaserJet_1320_series?serial=00CNHW55TGZ5
D [10/Oct/2019:12:35:56 +0200] [Job 138] renderer exited with status 141
D [10/Oct/2019:12:35:56 +0200] [Job 138] A filter used in addition to the renderer itself may have failed.Process is dying with \"Encountered error Broken pipe during fwrite\", exit stat 1
D [10/Oct/2019:12:35:56 +0200] [Job 138] Cleaning up...
D [10/Oct/2019:12:35:56 +0200] [Job 138] Killing pdf-to-ps
D [10/Oct/2019:12:35:56 +0200] [Job 138] Killing kid3
D [10/Oct/2019:12:35:56 +0200] [Job 138] PID 18213 (/usr/lib/cups/filter/foomatic-rip) stopped with status 1.
D [10/Oct/2019:12:35:56 +0200] [Job 138] Backend returned status 1 (failed)
D [10/Oct/2019:12:35:56 +0200] [Job 138] time-at-completed=1570703756
D [10/Oct/2019:12:35:56 +0200] [Job 138] End of messages
D [10/Oct/2019:12:35:56 +0200] [Job 138] printer-state=3(idle)
D [10/Oct/2019:12:35:56 +0200] [Job 138] printer-state-message="Filter failed"
D [10/Oct/2019:12:35:56 +0200] [Job 138] printer-state-reasons=none
W [10/Oct/2019:12:36:01 +0200] CreateProfile failed: org.freedesktop.ColorManager.AlreadyExists:profile id \'hp_LaserJet_1320-Gray..\' already exists Die beiden neueren Jobs in der Warteschlange – 139 und 140 – tauchen da merkwürdigerweise nicht auf.
$ hp-check -r
Saving output in log file: /home/ich/hp-check.log
Dependency/Version Check Utility ver. 15.1
Note: hp-check can be run in three modes:
1. Compile-time check mode (-c or --compile): Use this mode before compiling the
HPLIP supplied tarball (.tar.gz or .run) to determine if the proper dependencies
are installed to successfully compile HPLIP.
2. Run-time check mode (-r or --run): Use this mode to determine if a distro
supplied package (.deb, .rpm, etc) or an already built HPLIP supplied tarball
has the proper dependencies installed to successfully run.
3. Both compile- and run-time check mode (-b or --both) (Default): This mode
will check both of the above cases (both compile- and run-time dependencies).
Check types:
a. EXTERNALDEP - External Dependencies
b. GENERALDEP - General Dependencies (required both at compile and run time)
c. COMPILEDEP - Compile time Dependencies
d. [All are run-time checks]
PYEXT SCANCONF QUEUES PERMISSION
Status Types:
OK
MISSING - Missing Dependency or Permission or Plug-in
INCOMPAT - Incompatible dependency-version or Plugin-version
\Gtk-Message: 12:44:25.894: Failed to load module "canberra-gtk-module"
warning: 12-18.04 version is not supported. Using 12-17.04 versions dependencies to verify and install...
| SYSTEM INFO |
Kernel: 4.15.0-65-generic #74-Ubuntu SMP Tue Sep 17 17:06:04 UTC 2019 GNU/Linux
Host: T500
Proc: 4.15.0-65-generic #74-Ubuntu SMP Tue Sep 17 17:06:04 UTC 2019 GNU/Linux
Distribution: 12 18.04
Bitness: 64 bit
| HPLIP CONFIGURATION |
HPLIP-Version: HPLIP 3.17.10
HPLIP-Home: /usr/share/hplip
warning: HPLIP-Installation: Auto installation is not supported for 12 distro 18.04 version
Current contents of '/etc/hp/hplip.conf' file:
# hplip.conf. Generated from hplip.conf.in by configure.
[hplip]
version=3.17.10
[dirs]
home=/usr/share/hplip
run=/var/run
ppd=/usr/share/ppd/hplip/HP
ppdbase=/usr/share/ppd/hplip
doc=/usr/share/doc/hplip
html=/usr/share/doc/hplip-doc
icon=no
cupsbackend=/usr/lib/cups/backend
cupsfilter=/usr/lib/cups/filter
drv=/usr/share/cups/drv
bin=/usr/bin
apparmor=/etc/apparmor.d
# Following values are determined at configure time and cannot be changed.
[configure]
network-build=yes
libusb01-build=no
pp-build=yes
gui-build=yes
scanner-build=yes
fax-build=yes
dbus-build=yes
cups11-build=no
doc-build=yes
shadow-build=no
hpijs-install=yes
foomatic-drv-install=yes
foomatic-ppd-install=yes
foomatic-rip-hplip-install=no
hpcups-install=yes
cups-drv-install=yes
cups-ppd-install=no
internal-tag=3.17.10
restricted-build=no
ui-toolkit=qt5
qt3=no
qt4=no
qt5=yes
policy-kit=yes
lite-build=no
udev_sysfs_rules=no
hpcups-only-build=no
hpijs-only-build=no
apparmor_build=no
Current contents of '/var/lib/hp/hplip.state' file:
Plugins are not installed. Could not access file: No such file or directory
Current contents of '~/.hplip/hplip.conf' file:
[commands]
scan = /usr/bin/simple-scan %SANE_URI%
[fax]
email_address =
voice_phone =
[last_used]
device_uri = hp:/usb/hp_LaserJet_1320_series?serial=00CNHW55TGZ5
printer_name = hp_LaserJet_1320
working_dir = .
[polling]
device_list =
enable = false
interval = 5
[refresh]
enable = false
rate = 30
type = 1
[settings]
systray_messages = 0
systray_visible = 0
[upgrade]
last_upgraded_time = 1570658566
notify_upgrade = false
pending_upgrade_time = 0
[installation]
date_time = 10/10/19 12:44:27
version = 3.17.10
<Package-name> <Package-Desc> <Required/Optional> <Min-Version> <Installed-Version> <Status> <Comment>
| External Dependencies |
error: cups CUPS - Common Unix Printing System REQUIRED 1.1 - INCOMPAT 'CUPS may not be installed or not running'
gs GhostScript - PostScript and PDF language interpreter and previewer REQUIRED 7.05 9.26 OK -
Gtk-Message: 12:44:28.316: Failed to load module "canberra-gtk-module"
Gtk-Message: 12:44:28.371: Failed to load module "canberra-gtk-module"
xsane xsane - Graphical scanner frontend for SANE OPTIONAL 0.9 0.999 OK -
scanimage scanimage - Shell scanning program OPTIONAL 1.0 1.0.27 OK -
dbus DBus - Message bus system REQUIRED - 1.12.2 OK -
policykit PolicyKit - Administrative policy framework OPTIONAL - 0.105 OK -
network network -wget OPTIONAL - 1.19.4 OK -
avahi-utils avahi-utils OPTIONAL - 0.7 OK -
| General Dependencies |
error: libjpeg libjpeg - JPEG library REQUIRED - - MISSING 'libjpeg needs to be installed'
error: cups-devel CUPS devel- Common Unix Printing System development files REQUIRED - - MISSING 'cups-devel needs to be installed'
error: cups-image CUPS image - CUPS image development files REQUIRED - - MISSING 'cups-image needs to be installed'
libpthread libpthread - POSIX threads library REQUIRED - b'2.27' OK -
error: libusb libusb - USB library REQUIRED - 1.0 MISSING 'libusb needs to be installed'
sane SANE - Scanning library REQUIRED - - OK -
error: sane-devel SANE - Scanning library development files REQUIRED - - MISSING 'sane-devel needs to be installed'
error: libnetsnmp-devel libnetsnmp-devel - SNMP networking library development files REQUIRED 5.0.9 - MISSING 'libnetsnmp-devel needs to be installed'
error: libcrypto libcrypto - OpenSSL cryptographic library REQUIRED - 1.1.1 MISSING 'libcrypto needs to be installed'
python3X Python 2.2 or greater - Python programming language REQUIRED 2.2 3.6.8 OK -
python3-notify2 Python libnotify - Python bindings for the libnotify Desktop notifications OPTIONAL - - OK -
error: python3-pyqt4-dbus PyQt 4 DBus - DBus Support for PyQt4 OPTIONAL 4.0 - MISSING 'python3-pyqt4-dbus needs to be installed'
error: python3-pyqt4 PyQt 4- Qt interface for Python (for Qt version 4.x) REQUIRED 4.0 - MISSING 'python3-pyqt4 needs to be installed'
python3-dbus Python DBus - Python bindings for DBus REQUIRED 0.80.0 1.2.6 OK -
python3-xml Python XML libraries REQUIRED - 2.2.5 OK -
error: python3-devel Python devel - Python development files REQUIRED 2.2 3.6.8 MISSING 'python3-devel needs to be installed'
python3-pil PIL - Python Imaging Library (required for commandline scanning with hp-scan) OPTIONAL - 1.1.7 OK -
python3-reportlab Reportlab - PDF library for Python OPTIONAL 2.0 3.4.0 OK -
| COMPILEDEP |
error: libtool libtool - Library building support services REQUIRED - - MISSING 'libtool needs to be installed'
gcc gcc - GNU Project C and C++ Compiler REQUIRED - 7.4.0 OK -
make make - GNU make utility to maintain groups of programs REQUIRED 3.0 4.1 OK -
| Python Extentions |
cupsext CUPS-Extension REQUIRED - 3.17.10 OK -
hpmudext IO-Extension REQUIRED - 3.17.10 OK -
| Scan Configuration |
'/etc/sane.d/dll.d/hpaio' not found.
hpaio HPLIP-SANE-Backend REQUIRED - 3.17.10 OK 'hpaio found in /etc/sane.d/dll.conf'
scanext Scan-SANE-Extension REQUIRED - 3.17.10 OK -
| DISCOVERED SCANNER DEVICES |
No Scanner found.
| DISCOVERED USB DEVICES |
Device URI Model
hp:/usb/hp_LaserJet_1320_series? HP LaserJet 1320 series
serial=00CNHW55TGZ5
| INSTALLED CUPS PRINTER QUEUES |
Type: Unknown
Device URI: socket://fritz.box:9100
PPD: /etc/cups/ppd/Canon-MX880-3.50-1_FRITZ!Box.ppd
warning: Failed to read /etc/cups/ppd/Canon-MX880-3.50-1_FRITZ!Box.ppd ppd file
PPD Description:
Printer status: Drucker Canon-MX880-3.50-1_FRITZ!Box ist im Leerlauf. Aktiviert seit So 23 Sep 2018 04:08:10 CEST
warning: Printer is not HPLIP installed. Printers must use the hp: or hpfax: CUPS backend for HP-Devices.
Type: Unknown
Device URI: cnijusb:/dev/usb/lp0
PPD: /etc/cups/ppd/Canon-MX880-3.50-1_USB.ppd
warning: Failed to read /etc/cups/ppd/Canon-MX880-3.50-1_USB.ppd ppd file
PPD Description:
Printer status: Drucker Canon-MX880-3.50-1_USB ist im Leerlauf. Aktiviert seit So 23 Sep 2018 04:00:16 CEST
Type: Unknown
PPD: /etc/cups/ppd/Canon-MX880-3.90_FRITZ!Box.ppd
warning: Failed to read /etc/cups/ppd/Canon-MX880-3.90_FRITZ!Box.ppd ppd file
PPD Description:
Printer status: Drucker Canon-MX880-3.90_FRITZ!Box ist im Leerlauf. Aktiviert seit Do 08 Nov 2018 14:55:34 CET
Type: Unknown
Device URI: usb://Canon/MX880%20series?serial=10283A&interface=1
PPD: /etc/cups/ppd/Canon-MX880-3.90_USB.ppd
warning: Failed to read /etc/cups/ppd/Canon-MX880-3.90_USB.ppd ppd file
PPD Description:
Printer status: Drucker Canon-MX880-3.90_USB ist im Leerlauf. Aktiviert seit So 23 Sep 2018 02:49:32 CEST
Epson-WF-2630_USB
Type: Unknown
Device URI: usb://EPSON/WF-2630%20Series?serial=554D43593237333652&interface=1
PPD: /etc/cups/ppd/Epson-WF-2630_USB.ppd
warning: Failed to read /etc/cups/ppd/Epson-WF-2630_USB.ppd ppd file
PPD Description:
Printer status: Drucker Epson-WF-2630_USB ist im Leerlauf. Aktiviert seit Do 13 Jun 2019 23:44:31 CEST
hp_LaserJet_1320
Type: Printer
Device URI: hp:/usb/hp_LaserJet_1320_series?serial=00CNHW55TGZ5
PPD: /etc/cups/ppd/hp_LaserJet_1320.ppd
warning: Failed to read /etc/cups/ppd/hp_LaserJet_1320.ppd ppd file
PPD Description:
Printer status: Drucker hp_LaserJet_1320 ist im Leerlauf. Aktiviert seit Do 10 Okt 2019 12:43:48 CEST
Communication status: Good
Type: Unknown
PPD: /etc/cups/ppd/MX880-series_FRITZ!Box.ppd
warning: Failed to read /etc/cups/ppd/MX880-series_FRITZ!Box.ppd ppd file
PPD Description:
Printer status: Drucker MX880-series_FRITZ!Box ist im Leerlauf. Aktiviert seit So 23 Sep 2018 04:10:31 CEST
MX880-series_USB
Type: Unknown
PPD: /etc/cups/ppd/MX880-series_USB.ppd
warning: Failed to read /etc/cups/ppd/MX880-series_USB.ppd ppd file
PPD Description:
Printer status: Drucker MX880-series_USB ist im Leerlauf. Aktiviert seit So 23 Sep 2018 02:06:02 CEST
| PERMISSION |
USB hp_LaserJet_1320 Required - - OK Node:'/dev/bus/usb/003/007' Perm:' root saned rw- rw- rw- rw- r--'
| SUMMARY |
Missing Required Dependencies
error: 'libcups2' package is missing/incompatible
error: 'libjpeg-dev' package is missing/incompatible
error: 'libcups2-dev' package is missing/incompatible
error: 'cups-bsd' package is missing/incompatible
error: 'cups-client' package is missing/incompatible
error: 'libcupsimage2-dev' package is missing/incompatible
error: 'libusb-1.0.0-dev' package is missing/incompatible
error: 'libsane-dev' package is missing/incompatible
error: 'libsnmp-dev' package is missing/incompatible
error: 'snmp-mibs-downloader' package is missing/incompatible
error: 'openssl' package is missing/incompatible
error: 'python3-pyqt4' package is missing/incompatible
error: 'gtk2-engines-pixbuf' package is missing/incompatible
error: 'python3-dev' package is missing/incompatible
error: 'libtool' package is missing/incompatible
error: 'libtool-bin' package is missing/incompatible
Missing Optional Dependencies
error: 'python3-dbus.mainloop.qt' package is missing/incompatible
Total Errors: 12
Total Warnings: 7
Done. $ systemctl --no-pager status cups*
● cups.socket - CUPS Scheduler
Loaded: loaded (/lib/systemd/system/cups.socket; enabled; vendor preset: enabled)
Active: active (running) since Thu 2019-10-10 00:08:43 CEST; 12h ago
Listen: /run/cups/cups.sock (Stream)
CGroup: /system.slice/cups.socket
Failed to dump process list, ignoring: No such file or directory
Okt 10 00:08:43 T500 systemd[1]: Stopping CUPS Scheduler.
Okt 10 00:08:43 T500 systemd[1]: Listening on CUPS Scheduler.
● cups.path - CUPS Scheduler
Loaded: loaded (/lib/systemd/system/cups.path; enabled; vendor preset: enabled)
Okt 10 00:08:43 T500 systemd[1]: Started CUPS Scheduler.
● cups.service - CUPS Scheduler
Loaded: loaded (/lib/systemd/system/cups.service; enabled; vendor preset: enabled)
Docs: man:cupsd(8)
Main PID: 29419 (cupsd)
Tasks: 2 (limit: 4915)
CGroup: /system.slice/cups.service
├─29419 /usr/sbin/cupsd -l
└─29649 /usr/lib/cups/notifier/dbus dbus://
Okt 10 12:43:47 T500 hp[18400]: io/hpmud/musb.c 595: invalid usb_open: Perm…nied
Okt 10 12:43:47 T500 hp[18400]: io/hpmud/musb.c 1152: unable to open hp:/us…TGZ5
Okt 10 12:43:47 T500 hp[18400]: prnt/backend/hp.c 824: ERROR: open device f…TGZ5
Okt 10 12:46:18 T500 hp[18653]: io/hpmud/musb.c 595: invalid usb_open: Perm…nied
Okt 10 12:46:18 T500 hp[18653]: io/hpmud/musb.c 1152: unable to open hp:/us…TGZ5
Okt 10 12:46:18 T500 hp[18653]: prnt/backend/hp.c 824: ERROR: open device f…TGZ5
● cups-browsed.service - Make remote CUPS printers available locally
Loaded: loaded (/lib/systemd/system/cups-browsed.service; enabled; vendor preset: enabled)
Main PID: 29420 (cups-browsed)
Tasks: 3 (limit: 4915)
CGroup: /system.slice/cups-browsed.service
└─29420 /usr/sbin/cups-browsed
Okt 10 00:08:43 T500 systemd[1]: Started Make remote CUPS printers availabl…lly.
Hint: Some lines were ellipsized, use -l to show in full.
UlfZibis
UlfZibis schrieb: Die beiden neueren Jobs in der Warteschlange – 139 und 140 – tauchen da merkwürdigerweise nicht auf.
Job 140 (der mit dem wieder eingesetzten HP-Treiber) lässt weiter auf sich warten, aber hier ist nun Job 139: $ tail -n 150 /var/log/cups/error_log
E [10/Oct/2019:12:46:18 +0200] [Job 139] Job aborted after 5 unsuccessful attempts.
D [10/Oct/2019:12:46:18 +0200] [Job 139] The following messages were recorded from 12:46:17 to 12:46:18
D [10/Oct/2019:12:46:18 +0200] [Job 139] Job submission timed out.
D [10/Oct/2019:12:46:18 +0200] [Job 139] time-at-processing=1570704377
D [10/Oct/2019:12:46:18 +0200] [Job 139] 4 filters for job:
D [10/Oct/2019:12:46:18 +0200] [Job 139] bannertopdf (application/vnd.cups-pdf-banner to application/pdf, cost 32)
D [10/Oct/2019:12:46:18 +0200] [Job 139] pdftopdf (application/pdf to application/vnd.cups-pdf, cost 66)
D [10/Oct/2019:12:46:18 +0200] [Job 139] pdftops (application/vnd.cups-pdf to application/vnd.cups-postscript, cost 100)
D [10/Oct/2019:12:46:18 +0200] [Job 139] - (application/vnd.cups-postscript to printer/hp_LaserJet_1320, cost 0)
D [10/Oct/2019:12:46:18 +0200] [Job 139] job-sheets=none,none
D [10/Oct/2019:12:46:18 +0200] [Job 139] argv[0]="hp_LaserJet_1320"
D [10/Oct/2019:12:46:18 +0200] [Job 139] argv[1]="139"
D [10/Oct/2019:12:46:18 +0200] [Job 139] argv[2]="ich"
D [10/Oct/2019:12:46:18 +0200] [Job 139] argv[3]="Test Page"
D [10/Oct/2019:12:46:18 +0200] [Job 139] argv[4]="1"
D [10/Oct/2019:12:46:18 +0200] [Job 139] argv[5]="job-uuid=urn:uuid:c62c1e12-346c-3f51-4947-c86c52490bef job-originating-host-name=localhost date-time-at-creation= date-time-at-processing= time-at-creation=1570702792 time-at-processing=1570704377"
D [10/Oct/2019:12:46:18 +0200] [Job 139] argv[6]="/var/spool/cups/d00139-001"
D [10/Oct/2019:12:46:18 +0200] [Job 139] envp[0]="CUPS_CACHEDIR=/var/cache/cups"
D [10/Oct/2019:12:46:18 +0200] [Job 139] envp[1]="CUPS_DATADIR=/usr/share/cups"
D [10/Oct/2019:12:46:18 +0200] [Job 139] envp[2]="CUPS_DOCROOT=/usr/share/cups/doc-root"
D [10/Oct/2019:12:46:18 +0200] [Job 139] envp[3]="CUPS_FONTPATH=/usr/share/cups/fonts"
D [10/Oct/2019:12:46:18 +0200] [Job 139] envp[4]="CUPS_REQUESTROOT=/var/spool/cups"
D [10/Oct/2019:12:46:18 +0200] [Job 139] envp[5]="CUPS_SERVERBIN=/usr/lib/cups"
D [10/Oct/2019:12:46:18 +0200] [Job 139] envp[6]="CUPS_SERVERROOT=/etc/cups"
D [10/Oct/2019:12:46:18 +0200] [Job 139] envp[7]="CUPS_STATEDIR=/run/cups"
D [10/Oct/2019:12:46:18 +0200] [Job 139] envp[8]="HOME=/var/spool/cups/tmp"
D [10/Oct/2019:12:46:18 +0200] [Job 139] envp[9]="PATH=/usr/lib/cups/filter:/usr/bin:/usr/sbin:/bin:/usr/bin"
D [10/Oct/2019:12:46:18 +0200] [Job 139] envp[10]="SERVER_ADMIN=root@T500"
D [10/Oct/2019:12:46:18 +0200] [Job 139] envp[11]="SOFTWARE=CUPS/2.2.7"
D [10/Oct/2019:12:46:18 +0200] [Job 139] envp[12]="TMPDIR=/var/spool/cups/tmp"
D [10/Oct/2019:12:46:18 +0200] [Job 139] envp[13]="USER=root"
D [10/Oct/2019:12:46:18 +0200] [Job 139] envp[14]="CUPS_MAX_MESSAGE=2047"
D [10/Oct/2019:12:46:18 +0200] [Job 139] envp[15]="CUPS_SERVER=/run/cups/cups.sock"
D [10/Oct/2019:12:46:18 +0200] [Job 139] envp[16]="CUPS_ENCRYPTION=IfRequested"
D [10/Oct/2019:12:46:18 +0200] [Job 139] envp[17]="IPP_PORT=631"
D [10/Oct/2019:12:46:18 +0200] [Job 139] envp[18]="CHARSET=utf-8"
D [10/Oct/2019:12:46:18 +0200] [Job 139] envp[19]="LANG=de_DE.UTF-8"
D [10/Oct/2019:12:46:18 +0200] [Job 139] envp[20]="PPD=/etc/cups/ppd/hp_LaserJet_1320.ppd"
D [10/Oct/2019:12:46:18 +0200] [Job 139] envp[21]="RIP_MAX_CACHE=128m"
D [10/Oct/2019:12:46:18 +0200] [Job 139] envp[22]="CONTENT_TYPE=application/vnd.cups-pdf-banner"
D [10/Oct/2019:12:46:18 +0200] [Job 139] envp[23]="DEVICE_URI=hp:/usb/hp_LaserJet_1320_series?serial=00CNHW55TGZ5"
D [10/Oct/2019:12:46:18 +0200] [Job 139] envp[24]="PRINTER_INFO="
D [10/Oct/2019:12:46:18 +0200] [Job 139] envp[25]="PRINTER_LOCATION="
D [10/Oct/2019:12:46:18 +0200] [Job 139] envp[26]="PRINTER=hp_LaserJet_1320"
D [10/Oct/2019:12:46:18 +0200] [Job 139] envp[27]="PRINTER_STATE_REASONS=none"
D [10/Oct/2019:12:46:18 +0200] [Job 139] envp[28]="CUPS_FILETYPE=document"
D [10/Oct/2019:12:46:18 +0200] [Job 139] envp[29]="FINAL_CONTENT_TYPE=application/vnd.cups-postscript"
D [10/Oct/2019:12:46:18 +0200] [Job 139] envp[30]="AUTH_I****"
D [10/Oct/2019:12:46:18 +0200] [Job 139] Started filter /usr/lib/cups/filter/bannertopdf (PID 18650)
D [10/Oct/2019:12:46:18 +0200] [Job 139] Started filter /usr/lib/cups/filter/pdftopdf (PID 18651)
D [10/Oct/2019:12:46:18 +0200] [Job 139] Started filter /usr/lib/cups/filter/pdftops (PID 18652)
D [10/Oct/2019:12:46:18 +0200] [Job 139] Started backend /usr/lib/cups/backend/hp (PID 18653)
D [10/Oct/2019:12:46:18 +0200] [Job 139] pdftopdf: Last filter determined by the PPD: None; FINAL_CONTENT_TYPE: application/vnd.cups-postscript => pdftopdf will not log pages in page_log.
D [10/Oct/2019:12:46:18 +0200] [Job 139] pdftops - copying to temp print file \"/tmp/048dc5d9f50c2\"
D [10/Oct/2019:12:46:18 +0200] [Job 139] PDF template file doesn\'t have form. It\'s okay.
D [10/Oct/2019:12:46:18 +0200] [Job 139] PID 18650 (/usr/lib/cups/filter/bannertopdf) exited with no errors.
D [10/Oct/2019:12:46:18 +0200] [Job 139] PID 18651 (/usr/lib/cups/filter/pdftopdf) exited with no errors.
D [10/Oct/2019:12:46:18 +0200] [Job 139] Printer make and model: HP HP LaserJet 1320 series
D [10/Oct/2019:12:46:18 +0200] [Job 139] Switching to Poppler\'s pdftops instead of Ghostscript for old HP LaserJet (\"LaserJet <number>\", no letters before <number>) printers to work around bugs in the printer\'s PS interpreters
D [10/Oct/2019:12:46:18 +0200] [Job 139] Running command line for pstops: pstops 139 ich \'Test Page\' 1 \'job-uuid=urn:uuid:c62c1e12-346c-3f51-4947-c86c52490bef job-originating-host-name=localhost date-time-at-creation= date-time-at-processing= time-at-creation=1570702792 time-at-processing=1570704377\'
D [10/Oct/2019:12:46:18 +0200] [Job 139] Using image rendering resolution 600 dpi
D [10/Oct/2019:12:46:18 +0200] [Job 139] Running command line for pdftops: pdftops -level2 -origpagesizes -nocenter -r 600 /tmp/048dc5d9f50c2 -
D [10/Oct/2019:12:46:18 +0200] [Job 139] Started filter pdftops (PID 18654)
D [10/Oct/2019:12:46:18 +0200] [Job 139] Started filter pstops (PID 18655)
D [10/Oct/2019:12:46:18 +0200] [Job 139] Page = 595x842; 12,12 to 583,829
D [10/Oct/2019:12:46:18 +0200] [Job 139] slow_collate=0, slow_duplex=0, slow_order=0
D [10/Oct/2019:12:46:18 +0200] [Job 139] Before copy_comments - %!PS-Adobe-3.0
D [10/Oct/2019:12:46:18 +0200] [Job 139] %!PS-Adobe-3.0
D [10/Oct/2019:12:46:18 +0200] [Job 139] %Produced by poppler pdftops version: 0.62.0 (http://poppler.freedesktop.org)
D [10/Oct/2019:12:46:18 +0200] [Job 139] %%LanguageLevel: 2
D [10/Oct/2019:12:46:18 +0200] [Job 139] %%DocumentSuppliedResources: (atend)
D [10/Oct/2019:12:46:18 +0200] [Job 139] %%DocumentMedia: A4 595 842 0 () ()
D [10/Oct/2019:12:46:18 +0200] [Job 139] %%BoundingBox: 0 0 595 842
D [10/Oct/2019:12:46:18 +0200] [Job 139] %%Pages: 1
D [10/Oct/2019:12:46:18 +0200] [Job 139] %%EndComments
D [10/Oct/2019:12:46:18 +0200] [Job 139] Before copy_prolog - %%BeginProlog
D [10/Oct/2019:12:46:18 +0200] [Job 139] STATE: +connecting-to-device
D [10/Oct/2019:12:46:18 +0200] [Job 139] Syntax Warning: Unknown font type: \'???\'
D [10/Oct/2019:12:46:18 +0200] [Job 139] Before copy_setup - %%BeginSetup
D [10/Oct/2019:12:46:18 +0200] [Job 139] prnt/backend/hp.c 824: ERROR: open device failed stat=12: hp:/usb/hp_LaserJet_1320_series?serial=00CNHW55TGZ5
D [10/Oct/2019:12:46:18 +0200] [Job 139] PID 18653 (/usr/lib/cups/backend/hp) stopped with status 1.
D [10/Oct/2019:12:46:18 +0200] [Job 139] Hint: Try setting the LogLevel to "debug" to find out more.
D [10/Oct/2019:12:46:18 +0200] [Job 139] Syntax Warning: Substituting font \'Times-Roman\' for \'null\'
D [10/Oct/2019:12:46:18 +0200] [Job 139] Before page loop - %%Page: 1 1
D [10/Oct/2019:12:46:18 +0200] [Job 139] Copying page 1...
D [10/Oct/2019:12:46:18 +0200] [Job 139] PAGE: 1 1
D [10/Oct/2019:12:46:18 +0200] [Job 139] pagew = 571.0, pagel = 817.4
D [10/Oct/2019:12:46:18 +0200] [Job 139] bboxx = 0, bboxy = 0, bboxw = 595, bboxl = 842
D [10/Oct/2019:12:46:18 +0200] [Job 139] PageLeft = 12.0, PageRight = 583.0
D [10/Oct/2019:12:46:18 +0200] [Job 139] PageTop = 829.4, PageBottom = 12.0
D [10/Oct/2019:12:46:18 +0200] [Job 139] PageWidth = 595.0, PageLength = 842.0
D [10/Oct/2019:12:46:18 +0200] [Job 139] Wrote 1 pages...
D [10/Oct/2019:12:46:18 +0200] [Job 139] PID 18655 (pstops) exited with no errors.
D [10/Oct/2019:12:46:18 +0200] [Job 139] PID 18654 (pdftops) exited with no errors.
D [10/Oct/2019:12:46:18 +0200] [Job 139] PID 18652 (/usr/lib/cups/filter/pdftops) exited with no errors.
D [10/Oct/2019:12:46:18 +0200] [Job 139] Backend returned status 1 (failed)
D [10/Oct/2019:12:46:18 +0200] [Job 139] time-at-completed=1570704378
D [10/Oct/2019:12:46:18 +0200] [Job 139] End of messages
D [10/Oct/2019:12:46:18 +0200] [Job 139] printer-state=3(idle)
D [10/Oct/2019:12:46:18 +0200] [Job 139] printer-state-message=""
D [10/Oct/2019:12:46:18 +0200] [Job 139] printer-state-reasons=none
Kellerkind_2009
Muss jetzt los – aber Okt 10 12:46:18 T500 hp[18653]: prnt/backend/hp.c 824: ERROR: open device f…TGZ5 Print Backend kommt von HP. Sowie D [10/Oct/2019:12:35:56 +0200] [Job 138] printer-state-message="Filter failed" Entferne mal alles von HPLIP. Hat er in 16.04 noch Funktioniert? Wäre dann HPLIP 3.16.... 😉 D [10/Oct/2019:12:46:18 +0200] [Job 139] prnt/backend/hp.c 824: ERROR: open device failed stat=12: hp:/usb/hp_LaserJet_1320_series?serial=00CNHW55TGZ5
UlfZibis
UlfZibis schrieb: Job 140 (der mit dem wieder eingesetzten HP-Treiber) lässt weiter auf sich warten, ...
Da ist er nun endlich (der log-Eintrag erscheint wohl erst, wenn der Job von der Warteschlange aufgegeben und dort automatisch entfernt wurde nach ca. 20 Minuten): $ tail -n 150 /var/log/cups/error_log
E [10/Oct/2019:13:03:53 +0200] [Job 140] Job aborted after 5 unsuccessful attempts.
D [10/Oct/2019:13:03:53 +0200] [Job 140] The following messages were recorded from 13:03:53 to 13:03:53
D [10/Oct/2019:13:03:53 +0200] [Job 140] Job submission timed out.
D [10/Oct/2019:13:03:53 +0200] [Job 140] time-at-processing=1570705433
D [10/Oct/2019:13:03:53 +0200] [Job 140] 4 filters for job:
D [10/Oct/2019:13:03:53 +0200] [Job 140] bannertopdf (application/vnd.cups-pdf-banner to application/pdf, cost 32)
D [10/Oct/2019:13:03:53 +0200] [Job 140] pdftopdf (application/pdf to application/vnd.cups-pdf, cost 66)
D [10/Oct/2019:13:03:53 +0200] [Job 140] pdftops (application/vnd.cups-pdf to application/vnd.cups-postscript, cost 100)
D [10/Oct/2019:13:03:53 +0200] [Job 140] - (application/vnd.cups-postscript to printer/hp_LaserJet_1320, cost 0)
D [10/Oct/2019:13:03:53 +0200] [Job 140] job-sheets=none,none
D [10/Oct/2019:13:03:53 +0200] [Job 140] argv[0]="hp_LaserJet_1320"
D [10/Oct/2019:13:03:53 +0200] [Job 140] argv[1]="140"
D [10/Oct/2019:13:03:53 +0200] [Job 140] argv[2]="ich"
D [10/Oct/2019:13:03:53 +0200] [Job 140] argv[3]="Test Page"
D [10/Oct/2019:13:03:53 +0200] [Job 140] argv[4]="1"
D [10/Oct/2019:13:03:53 +0200] [Job 140] argv[5]="job-uuid=urn:uuid:e747999a-56a9-3286-6efd-364910639888 job-originating-host-name=localhost date-time-at-creation= date-time-at-processing= time-at-creation=1570703916 time-at-processing=1570705433"
D [10/Oct/2019:13:03:53 +0200] [Job 140] argv[6]="/var/spool/cups/d00140-001"
D [10/Oct/2019:13:03:53 +0200] [Job 140] envp[0]="CUPS_CACHEDIR=/var/cache/cups"
D [10/Oct/2019:13:03:53 +0200] [Job 140] envp[1]="CUPS_DATADIR=/usr/share/cups"
D [10/Oct/2019:13:03:53 +0200] [Job 140] envp[2]="CUPS_DOCROOT=/usr/share/cups/doc-root"
D [10/Oct/2019:13:03:53 +0200] [Job 140] envp[3]="CUPS_FONTPATH=/usr/share/cups/fonts"
D [10/Oct/2019:13:03:53 +0200] [Job 140] envp[4]="CUPS_REQUESTROOT=/var/spool/cups"
D [10/Oct/2019:13:03:53 +0200] [Job 140] envp[5]="CUPS_SERVERBIN=/usr/lib/cups"
D [10/Oct/2019:13:03:53 +0200] [Job 140] envp[6]="CUPS_SERVERROOT=/etc/cups"
D [10/Oct/2019:13:03:53 +0200] [Job 140] envp[7]="CUPS_STATEDIR=/run/cups"
D [10/Oct/2019:13:03:53 +0200] [Job 140] envp[8]="HOME=/var/spool/cups/tmp"
D [10/Oct/2019:13:03:53 +0200] [Job 140] envp[9]="PATH=/usr/lib/cups/filter:/usr/bin:/usr/sbin:/bin:/usr/bin"
D [10/Oct/2019:13:03:53 +0200] [Job 140] envp[10]="SERVER_ADMIN=root@T500"
D [10/Oct/2019:13:03:53 +0200] [Job 140] envp[11]="SOFTWARE=CUPS/2.2.7"
D [10/Oct/2019:13:03:53 +0200] [Job 140] envp[12]="TMPDIR=/var/spool/cups/tmp"
D [10/Oct/2019:13:03:53 +0200] [Job 140] envp[13]="USER=root"
D [10/Oct/2019:13:03:53 +0200] [Job 140] envp[14]="CUPS_MAX_MESSAGE=2047"
D [10/Oct/2019:13:03:53 +0200] [Job 140] envp[15]="CUPS_SERVER=/run/cups/cups.sock"
D [10/Oct/2019:13:03:53 +0200] [Job 140] envp[16]="CUPS_ENCRYPTION=IfRequested"
D [10/Oct/2019:13:03:53 +0200] [Job 140] envp[17]="IPP_PORT=631"
D [10/Oct/2019:13:03:53 +0200] [Job 140] envp[18]="CHARSET=utf-8"
D [10/Oct/2019:13:03:53 +0200] [Job 140] envp[19]="LANG=de_DE.UTF-8"
D [10/Oct/2019:13:03:53 +0200] [Job 140] envp[20]="PPD=/etc/cups/ppd/hp_LaserJet_1320.ppd"
D [10/Oct/2019:13:03:53 +0200] [Job 140] envp[21]="RIP_MAX_CACHE=128m"
D [10/Oct/2019:13:03:53 +0200] [Job 140] envp[22]="CONTENT_TYPE=application/vnd.cups-pdf-banner"
D [10/Oct/2019:13:03:53 +0200] [Job 140] envp[23]="DEVICE_URI=hp:/usb/hp_LaserJet_1320_series?serial=00CNHW55TGZ5"
D [10/Oct/2019:13:03:53 +0200] [Job 140] envp[24]="PRINTER_INFO="
D [10/Oct/2019:13:03:53 +0200] [Job 140] envp[25]="PRINTER_LOCATION="
D [10/Oct/2019:13:03:53 +0200] [Job 140] envp[26]="PRINTER=hp_LaserJet_1320"
D [10/Oct/2019:13:03:53 +0200] [Job 140] envp[27]="PRINTER_STATE_REASONS=none"
D [10/Oct/2019:13:03:53 +0200] [Job 140] envp[28]="CUPS_FILETYPE=document"
D [10/Oct/2019:13:03:53 +0200] [Job 140] envp[29]="FINAL_CONTENT_TYPE=application/vnd.cups-postscript"
D [10/Oct/2019:13:03:53 +0200] [Job 140] envp[30]="AUTH_I****"
D [10/Oct/2019:13:03:53 +0200] [Job 140] Started filter /usr/lib/cups/filter/bannertopdf (PID 20185)
D [10/Oct/2019:13:03:53 +0200] [Job 140] Started filter /usr/lib/cups/filter/pdftopdf (PID 20186)
D [10/Oct/2019:13:03:53 +0200] [Job 140] Started filter /usr/lib/cups/filter/pdftops (PID 20187)
D [10/Oct/2019:13:03:53 +0200] [Job 140] Started backend /usr/lib/cups/backend/hp (PID 20188)
D [10/Oct/2019:13:03:53 +0200] [Job 140] pdftops - copying to temp print file \"/tmp/04edb5da221e3\"
D [10/Oct/2019:13:03:53 +0200] [Job 140] pdftopdf: Last filter determined by the PPD: None; FINAL_CONTENT_TYPE: application/vnd.cups-postscript => pdftopdf will not log pages in page_log.
D [10/Oct/2019:13:03:53 +0200] [Job 140] PDF template file doesn\'t have form. It\'s okay.
D [10/Oct/2019:13:03:53 +0200] [Job 140] Printer make and model: HP HP LaserJet 1320 series
D [10/Oct/2019:13:03:53 +0200] [Job 140] Switching to Poppler\'s pdftops instead of Ghostscript for old HP LaserJet (\"LaserJet <number>\", no letters before <number>) printers to work around bugs in the printer\'s PS interpreters
D [10/Oct/2019:13:03:53 +0200] [Job 140] Running command line for pstops: pstops 140 ich \'Test Page\' 1 \'job-uuid=urn:uuid:e747999a-56a9-3286-6efd-364910639888 job-originating-host-name=localhost date-time-at-creation= date-time-at-processing= time-at-creation=1570703916 time-at-processing=1570705433\'
D [10/Oct/2019:13:03:53 +0200] [Job 140] Using image rendering resolution 600 dpi
D [10/Oct/2019:13:03:53 +0200] [Job 140] Running command line for pdftops: pdftops -level2 -origpagesizes -nocenter -r 600 /tmp/04edb5da221e3 -
D [10/Oct/2019:13:03:53 +0200] [Job 140] PID 20186 (/usr/lib/cups/filter/pdftopdf) exited with no errors.
D [10/Oct/2019:13:03:53 +0200] [Job 140] Started filter pdftops (PID 20189)
D [10/Oct/2019:13:03:53 +0200] [Job 140] Started filter pstops (PID 20190)
D [10/Oct/2019:13:03:53 +0200] [Job 140] PID 20185 (/usr/lib/cups/filter/bannertopdf) exited with no errors.
D [10/Oct/2019:13:03:53 +0200] [Job 140] Syntax Warning: Unknown font type: \'???\'
D [10/Oct/2019:13:03:53 +0200] [Job 140] Syntax Warning: Substituting font \'Times-Roman\' for \'null\'
D [10/Oct/2019:13:03:53 +0200] [Job 140] Page = 595x842; 12,12 to 583,829
D [10/Oct/2019:13:03:53 +0200] [Job 140] slow_collate=0, slow_duplex=0, slow_order=0
D [10/Oct/2019:13:03:53 +0200] [Job 140] Before copy_comments - %!PS-Adobe-3.0
D [10/Oct/2019:13:03:53 +0200] [Job 140] %!PS-Adobe-3.0
D [10/Oct/2019:13:03:53 +0200] [Job 140] %Produced by poppler pdftops version: 0.62.0 (http://poppler.freedesktop.org)
D [10/Oct/2019:13:03:53 +0200] [Job 140] %%LanguageLevel: 2
D [10/Oct/2019:13:03:53 +0200] [Job 140] %%DocumentSuppliedResources: (atend)
D [10/Oct/2019:13:03:53 +0200] [Job 140] %%DocumentMedia: A4 595 842 0 () ()
D [10/Oct/2019:13:03:53 +0200] [Job 140] %%BoundingBox: 0 0 595 842
D [10/Oct/2019:13:03:53 +0200] [Job 140] %%Pages: 1
D [10/Oct/2019:13:03:53 +0200] [Job 140] %%EndComments
D [10/Oct/2019:13:03:53 +0200] [Job 140] Before copy_prolog - %%BeginProlog
D [10/Oct/2019:13:03:53 +0200] [Job 140] STATE: +connecting-to-device
D [10/Oct/2019:13:03:53 +0200] [Job 140] Before copy_setup - %%BeginSetup
D [10/Oct/2019:13:03:53 +0200] [Job 140] Before page loop - %%Page: 1 1
D [10/Oct/2019:13:03:53 +0200] [Job 140] Copying page 1...
D [10/Oct/2019:13:03:53 +0200] [Job 140] PAGE: 1 1
D [10/Oct/2019:13:03:53 +0200] [Job 140] pagew = 571.0, pagel = 817.4
D [10/Oct/2019:13:03:53 +0200] [Job 140] bboxx = 0, bboxy = 0, bboxw = 595, bboxl = 842
D [10/Oct/2019:13:03:53 +0200] [Job 140] PageLeft = 12.0, PageRight = 583.0
D [10/Oct/2019:13:03:53 +0200] [Job 140] PageTop = 829.4, PageBottom = 12.0
D [10/Oct/2019:13:03:53 +0200] [Job 140] PageWidth = 595.0, PageLength = 842.0
D [10/Oct/2019:13:03:53 +0200] [Job 140] prnt/backend/hp.c 824: ERROR: open device failed stat=12: hp:/usb/hp_LaserJet_1320_series?serial=00CNHW55TGZ5
D [10/Oct/2019:13:03:53 +0200] [Job 140] PID 20188 (/usr/lib/cups/backend/hp) stopped with status 1.
D [10/Oct/2019:13:03:53 +0200] [Job 140] Hint: Try setting the LogLevel to "debug" to find out more.
D [10/Oct/2019:13:03:53 +0200] [Job 140] Wrote 1 pages...
D [10/Oct/2019:13:03:53 +0200] [Job 140] PID 20190 (pstops) exited with no errors.
D [10/Oct/2019:13:03:53 +0200] [Job 140] PID 20189 (pdftops) exited with no errors.
D [10/Oct/2019:13:03:53 +0200] [Job 140] PID 20187 (/usr/lib/cups/filter/pdftops) exited with no errors.
D [10/Oct/2019:13:03:53 +0200] [Job 140] Backend returned status 1 (failed)
D [10/Oct/2019:13:03:53 +0200] [Job 140] time-at-completed=1570705433
D [10/Oct/2019:13:03:53 +0200] [Job 140] End of messages
D [10/Oct/2019:13:03:53 +0200] [Job 140] printer-state=3(idle)
D [10/Oct/2019:13:03:53 +0200] [Job 140] printer-state-message=""
D [10/Oct/2019:13:03:53 +0200] [Job 140] printer-state-reasons=none
UlfZibis
Kellerkind_2009 schrieb: Muss jetzt los –
muss jetzt auch was anderes machen, gerne später oder morgen wieder ... aber Okt 10 12:46:18 T500 hp[18653]: prnt/backend/hp.c 824: ERROR: open device f…TGZ5 Print Backend kommt von HP. Sowie D [10/Oct/2019:12:35:56 +0200] [Job 138] printer-state-message="Filter failed"
Was soll mir das sagen?
Du meinst sudo apt --purge remove hplip hplip-gui ? Hat er in 16.04 noch Funktioniert? Wäre dann HPLIP 3.16....
Das weiß ich nicht mehr so genau, aber ich meine, er ging irgendwann mal. Hab' den Drucker mal vom Sperrmüll gefischt, da er wasserfest, schneller und mehr Seiten druckt und auch billiger im Gegensatz zu meinem Epson Tintenspritzer, und um ihn als Reserve zu haben, falls der Epson mal streikt. Bin gerade am Aufräumen. Deshalb will ich ihn testen. Sollte er kaputt sein, kann er weg. Kann aber eigentlich nicht sein, denn sonst würde er die interne Testseite nicht tadellos drucken.
Hm, aber was bedeutet das, und was kann ich da machen?
UlfZibis
Kellerkind_2009 schrieb: Hat er in 16.04 noch Funktioniert? Wäre dann HPLIP 3.16....
Hab' auf einem alten Desktop-Rechner noch Xubuntu 16.04 installiert. Da funktioniert der Drucker tatsächlich noch ...
hp-info liefert da aber einen Error in `/usr/bin/python3' : $ hp-info
HP Linux Imaging and Printing System (ver. 3.16.3)
error: No device found that support this feature.
ich@Dellinux:~$ hp-info
System Tray Status Service ver. 2.0
Done.
*** Error in `/usr/bin/python3': corrupted size vs. prev_size: 0x0a8000e0 ***
======= Backtrace: =========
/lib/i386-linux-gnu/libc.so.6(+0x67377)[0xb7570377]
/lib/i386-linux-gnu/libc.so.6(+0x6d2f7)[0xb75762f7]
/lib/i386-linux-gnu/libc.so.6(+0x6d6ce)[0xb75766ce]
/lib/i386-linux-gnu/libc.so.6(+0x6f1af)[0xb75781af]
/lib/i386-linux-gnu/libc.so.6(__libc_calloc+0xb8)[0xb757a8c8]
/lib/i386-linux-gnu/libglib-2.0.so.0(g_malloc0+0x2b)[0xb457a2db]
/lib/i386-linux-gnu/libglib-2.0.so.0(g_malloc0_n+0x68)[0xb457a568]
/lib/i386-linux-gnu/libglib-2.0.so.0(+0x3455b)[0xb456255b]
/lib/i386-linux-gnu/libglib-2.0.so.0(+0x34deb)[0xb4562deb]
/usr/lib/i386-linux-gnu/libgobject-2.0.so.0(g_signal_handler_disconnect+0xb5)[0xb4412e85]
/usr/lib/i386-linux-gnu/libgobject-2.0.so.0(+0x1e82e)[0xb441282e]
/usr/lib/i386-linux-gnu/libgobject-2.0.so.0(g_signal_handlers_disconnect_matched+0x9a)[0xb441b5da]
/usr/lib/i386-linux-gnu/libgtk-x11-2.0.so.0(+0x2a072f)[0xb1e4672f]
/usr/lib/i386-linux-gnu/libgobject-2.0.so.0(g_cclosure_marshal_VOID__VOID+0x6c)[0xb44037ec]
/usr/lib/i386-linux-gnu/libgobject-2.0.so.0(+0xc404)[0xb4400404]
/usr/lib/i386-linux-gnu/libgobject-2.0.so.0(g_closure_invoke+0xa5)[0xb4401ac5]
/usr/lib/i386-linux-gnu/libgobject-2.0.so.0(+0x20535)[0xb4414535]
/usr/lib/i386-linux-gnu/libgobject-2.0.so.0(g_signal_emit_valist+0xe16)[0xb441cc96]
/usr/lib/i386-linux-gnu/libgobject-2.0.so.0(g_signal_emit+0x25)[0xb441cfc5]
/usr/lib/i386-linux-gnu/libgtk-x11-2.0.so.0(+0x148872)[0xb1cee872]
/usr/lib/i386-linux-gnu/libgtk-x11-2.0.so.0(+0x2486a8)[0xb1dee6a8]
/usr/lib/i386-linux-gnu/libgobject-2.0.so.0(g_object_run_dispose+0x68)[0xb4408118]
/usr/lib/i386-linux-gnu/libgtk-x11-2.0.so.0(gtk_object_destroy+0x6f)[0xb1cef53f]
/usr/lib/i386-linux-gnu/libgtk-x11-2.0.so.0(+0xdc54d)[0xb1c8254d]
/usr/lib/i386-linux-gnu/libgtk-x11-2.0.so.0(gtk_container_foreach+0x88)[0xb1c473d8]
/usr/lib/i386-linux-gnu/libgtk-x11-2.0.so.0(+0xa2458)[0xb1c48458]
/usr/lib/i386-linux-gnu/libgtk-x11-2.0.so.0(+0x695fa)[0xb1c0f5fa]
/usr/lib/i386-linux-gnu/libgtk-x11-2.0.so.0(+0x258a6c)[0xb1dfea6c]
/usr/lib/i386-linux-gnu/libgobject-2.0.so.0(g_closure_invoke+0x14b)[0xb4401b6b]
/usr/lib/i386-linux-gnu/libgtk-x11-2.0.so.0(+0x253772)[0xb1df9772]
/usr/lib/i386-linux-gnu/libQtGui.so.4(+0x51d8f4)[0xb50568f4]
/usr/lib/i386-linux-gnu/libQtGui.so.4(+0x522c25)[0xb505bc25]
/usr/lib/i386-linux-gnu/libQtCore.so.4(_Z21qt_call_post_routinesv+0x77)[0xb49bbba7]
/usr/lib/i386-linux-gnu/libQtGui.so.4(_ZN12QApplicationD1Ev+0x88)[0xb4c703e8]
/usr/lib/python3/dist-packages/PyQt4/QtGui.cpython-35m-i386-linux-gnu.so(+0x49f6bb)[0xb5b0c6bb]
/usr/lib/python3/dist-packages/PyQt4/QtGui.cpython-35m-i386-linux-gnu.so(+0x49f6fa)[0xb5b0c6fa]
/usr/lib/python3/dist-packages/PyQt4/QtGui.cpython-35m-i386-linux-gnu.so(+0x49f82a)[0xb5b0c82a]
/usr/lib/python3/dist-packages/PyQt4/QtGui.cpython-35m-i386-linux-gnu.so(+0x49f89a)[0xb5b0c89a]
/usr/lib/python3/dist-packages/sip.cpython-35m-i386-linux-gnu.so(+0x5849)[0xb41ad849]
/usr/lib/python3/dist-packages/sip.cpython-35m-i386-linux-gnu.so(+0xbd7b)[0xb41b3d7b]
/usr/bin/python3[0x81a6c97]
/usr/bin/python3[0x81dd81d]
======= Memory map: ========
08048000-0845c000 r-xp 00000000 08:02 131430 /usr/bin/python3.5
0845c000-0845d000 r--p 00413000 08:02 131430 /usr/bin/python3.5
0845d000-084d6000 rw-p 00414000 08:02 131430 /usr/bin/python3.5
084d6000-084f7000 rw-p 00000000 00:00 0
0a218000-0a9e7000 rw-p 00000000 00:00 0 [heap]
ae000000-ae021000 rw-p 00000000 00:00 0
ae021000-ae100000 ---p 00000000 00:00 0
ae1ff000-ae200000 ---p 00000000 00:00 0
ae200000-aea00000 rw-p 00000000 00:00 0
aea00000-aea21000 rw-p 00000000 00:00 0
aea21000-aeb00000 ---p 00000000 00:00 0
aeb1a000-aeb7a000 rw-s 00000000 00:05 1343500 /SYSV00000000 (deleted)
aeb7a000-aeb7b000 ---p 00000000 00:00 0
aeb7b000-af37b000 rw-p 00000000 00:00 0
af37b000-af37c000 ---p 00000000 00:00 0
af37c000-afb7c000 rw-p 00000000 00:00 0
afb7c000-afbc8000 r--p 00000000 08:02 33030 /usr/share/fonts/truetype/noto/NotoSans-Bold.ttf
afbc8000-afbd3000 r-xp 00000000 08:02 137498 /usr/lib/i386-linux-gnu/libjbig.so.0
afbd3000-afbd4000 r--p 0000a000 08:02 137498 /usr/lib/i386-linux-gnu/libjbig.so.0
afbd4000-afbd7000 rw-p 0000b000 08:02 137498 /usr/lib/i386-linux-gnu/libjbig.so.0
afbd7000-afc4f000 r-xp 00000000 08:02 133672 /usr/lib/i386-linux-gnu/libtiff.so.5.2.4
afc4f000-afc50000 r--p 00077000 08:02 133672 /usr/lib/i386-linux-gnu/libtiff.so.5.2.4
afc50000-afc52000 rw-p 00078000 08:02 133672 /usr/lib/i386-linux-gnu/libtiff.so.5.2.4
afc52000-afc53000 rw-p 00000000 00:00 0
afc53000-afca7000 r-xp 00000000 08:02 156242 /usr/lib/i386-linux-gnu/libQtSvg.so.4.8.7
afca7000-afca8000 ---p 00054000 08:02 156242 /usr/lib/i386-linux-gnu/libQtSvg.so.4.8.7
afca8000-afca9000 r--p 00054000 08:02 156242 /usr/lib/i386-linux-gnu/libQtSvg.so.4.8.7
afca9000-afcaa000 rw-p 00055000 08:02 156242 /usr/lib/i386-linux-gnu/libQtSvg.so.4.8.7
afcc7000-afd21000 r-xp 00000000 08:02 133677 /usr/lib/i386-linux-gnu/liblcms2.so.2.0.6
afd21000-afd22000 ---p 0005a000 08:02 133677 /usr/lib/i386-linux-gnu/liblcms2.so.2.0.6
afd22000-afd23000 r--p 0005a000 08:02 133677 /usr/lib/i386-linux-gnu/liblcms2.so.2.0.6
afd23000-afd27000 rw-p 0005b000 08:02 133677 /usr/lib/i386-linux-gnu/liblcms2.so.2.0.6
afd27000-afda2000 r-xp 00000000 08:02 164451 /usr/lib/i386-linux-gnu/libmng.so.2.0.2
afda2000-afda3000 r--p 0007b000 08:02 164451 /usr/lib/i386-linux-gnu/libmng.so.2.0.2
afda3000-afda4000 rw-p 0007c000 08:02 164451 /usr/lib/i386-linux-gnu/libmng.so.2.0.2
afdb1000-afdb8000 r-xp 00000000 08:02 155531 /usr/lib/i386-linux-gnu/qt4/plugins/imageformats/libqtiff.so
afdb8000-afdb9000 r--p 00006000 08:02 155531 /usr/lib/i386-linux-gnu/qt4/plugins/imageformats/libqtiff.so
afdb9000-afdba000 rw-p 00007000 08:02 155531 /usr/lib/i386-linux-gnu/qt4/plugins/imageformats/libqtiff.so
afdba000-afdbf000 r-xp 00000000 08:02 156237 /usr/lib/i386-linux-gnu/qt4/plugins/imageformats/libqsvg.so
afdbf000-afdc0000 r--p 00004000 08:02 156237 /usr/lib/i386-linux-gnu/qt4/plugins/imageformats/libqsvg.so
afdc0000-afdc1000 rw-p 00005000 08:02 156237 /usr/lib/i386-linux-gnu/qt4/plugins/imageformats/libqsvg.so
afdc1000-afdc6000 r-xp 00000000 08:02 155527 /usr/lib/i386-linux-gnu/qt4/plugins/imageformats/libqmng.so
afdc6000-afdc7000 r--p 00004000 08:02 155527 /usr/lib/i386-linux-gnu/qt4/plugins/imageformats/libqmng.so
afdc7000-afdc8000 rw-p 00005000 08:02 155527 /usr/lib/i386-linux-gnu/qt4/plugins/imageformats/libqmng.so
afdc8000-afe28000 r-xp 00000000 08:02 137924 /usr/lib/i386-linux-gnu/libwebp.so.5.0.4
afe28000-afe29000 ---p 00060000 08:02 137924 /usr/lib/i386-linux-gnu/libwebp.so.5.0.4
afe29000-afe2a000 r--p 00060000 08:02 137924 /usr/lib/i386-linux-gnu/libwebp.so.5.0.4
afe2a000-afe2c000 rw-p 00061000 08:02 137924 /usr/lib/i386-linux-gnu/libwebp.so.5.0.4
afe2f000-afe36000 r-xp 00000000 08:02 155532 /usr/lib/i386-linux-gnu/qt4/plugins/imageformats/libqjpeg.so
afe36000-afe37000 r--p 00006000 08:02 155532 /usr/lib/i386-linux-gnu/qt4/plugins/imageformats/libqjpeg.so
afe37000-afe38000 rw-p 00007000 08:02 155532 /usr/lib/i386-linux-gnu/qt4/plugins/imageformats/libqjpeg.so
afe38000-afe3f000 r-xp 00000000 08:02 155528 /usr/lib/i386-linux-gnu/qt4/plugins/imageformats/libqico.so
afe3f000-afe40000 r--p 00006000 08:02 155528 /usr/lib/i386-linux-gnu/qt4/plugins/imageformats/libqico.so
afe40000-afe41000 rw-p 00007000 08:02 155528 /usr/lib/i386-linux-gnu/qt4/plugins/imageformats/libqico.so
afe41000-afe47000 r-xp 00000000 08:02 155533 /usr/lib/i386-linux-gnu/qt4/plugins/imageformats/libqgif.so
afe47000-afe48000 r--p 00005000 08:02 155533 /usr/lib/i386-linux-gnu/qt4/plugins/imageformats/libqgif.so
afe48000-afe49000 rw-p 00006000 08:02 155533 /usr/lib/i386-linux-gnu/qt4/plugins/imageformats/libqgif.so
afe49000-afe4d000 r-xp 00000000 08:02 156675 /usr/lib/kde4/plugins/imageformats/kimg_webp.so
afe4d000-afe4e000 r--p 00003000 08:02 156675 /usr/lib/kde4/plugins/imageformats/kimg_webp.so
afe4e000-afe4f000 rw-p 00004000 08:02 156675 /usr/lib/kde4/plugins/imageformats/kimg_webp.so
afe4f000-afe53000 r-xp 00000000 08:02 141465 /usr/lib/kde4/plugins/imageformats/kimg_xview.so
afe53000-afe54000 r--p 00003000 08:02 141465 /usr/lib/kde4/plugins/imageformats/kimg_xview.so
afe54000-afe55000 rw-p 00004000 08:02 141465 /usr/lib/kde4/plugins/imageformats/kimg_xview.so
afe55000-afe66000 r-xp 00000000 08:02 141467 /usr/lib/kde4/plugins/imageformats/kimg_xcf.so
afe66000-afe67000 r--p 00010000 08:02 141467 /usr/lib/kde4/plugins/imageformats/kimg_xcf.so
afe67000-afe68000 rw-p 00011000 08:02 141467 /usr/lib/kde4/plugins/imageformats/kimg_xcf.so
afe68000-afe6c000 rw-p 00000000 00:00 0
afe6c000-afe71000 r-xp 00000000 08:02 141457 /usr/lib/kde4/plugins/imageformats/kimg_tga.so
afe71000-afe72000 r--p 00004000 08:02 141457 /usr/lib/kde4/plugins/imageformats/kimg_tga.so
afe72000-afe73000 rw-p 00005000 08:02 141457 /usr/lib/kde4/plugins/imageformats/kimg_tga.so
afe73000-afed0000 r-xp 00000000 08:02 133883 /usr/lib/i386-linux-gnu/libjpeg.so.8.0.2
afed0000-afed1000 r--p 0005c000 08:02 133883 /usr/lib/i386-linux-gnu/libjpeg.so.8.0.2
afed1000-afed2000 rw-p 0005d000 08:02 133883 /usr/lib/i386-linux-gnu/libjpeg.so.8.0.2
afed2000-aff21000 r-xp 00000000 08:02 149944 /usr/lib/i386-linux-gnu/libjasper.so.1.0.0
aff21000-aff22000 r--p 0004e000 08:02 149944 /usr/lib/i386-linux-gnu/libjasper.so.1.0.0
aff22000-aff25000 rw-p 0004f000 08:02 149944 /usr/lib/i386-linux-gnu/libjasper.so.1.0.0
aff25000-aff2b000 rw-p 00000000 00:00 0
aff2d000-aff37000 r-xp 00000000 08:02 141458 /usr/lib/kde4/plugins/imageformats/kimg_rgb.so
aff37000-aff38000 ---p 0000a000 08:02 141458 /usr/lib/kde4/plugins/imageformats/kimg_rgb.so
aff38000-aff39000 r--p 0000a000 08:02 141458 /usr/lib/kde4/plugins/imageformats/kimg_rgb.so
aff39000-aff3a000 rw-p 0000b000 08:02 141458 /usr/lib/kde4/plugins/imageformats/kimg_rgb.so
aff3a000-aff3f000 r-xp 00000000 08:02 141464 /usr/lib/kde4/plugins/imageformats/kimg_ras.so
aff3f000-aff40000 r--p 00004000 08:02 141464 /usr/lib/kde4/plugins/imageformats/kimg_ras.so
aff40000-aff41000 rw-p 00005000 08:02 141464 /usr/lib/kde4/plugins/imageformats/kimg_ras.so
aff41000-aff45000 r-xp 00000000 08:02 141461 /usr/lib/kde4/plugins/imageformats/kimg_psd.so
aff45000-aff46000 ---p 00004000 08:02 141461 /usr/lib/kde4/plugins/imageformats/kimg_psd.so
aff46000-aff47000 r--p 00004000 08:02 141461 /usr/lib/kde4/plugins/imageformats/kimg_psd.so
aff47000-aff48000 rw-p 00005000 08:02 141461 /usr/lib/kde4/plugins/imageformats/kimg_psd.so
aff48000-aff4d000 r-xp 00000000 08:02 134269 /usr/lib/i386-linux-gnu/libIlmThread-2_2.so.12.0.0
aff4d000-aff4e000 r--p 00004000 08:02 134269 /usr/lib/i386-linux-gnu/libIlmThread-2_2.so.12.0.0
aff4e000-aff4f000 rw-p 00005000 08:02 134269 /usr/lib/i386-linux-gnu/libIlmThread-2_2.so.12.0.0
aff4f000-aff91000 r-xp 00000000 08:02 134267 /usr/lib/i386-linux-gnu/libHalf.so.12.0.0
aff91000-aff92000 r--p 00041000 08:02 134267 /usr/lib/i386-linux-gnu/libHalf.so.12.0.0
aff92000-aff93000 rw-p 00042000 08:02 134267 /usr/lib/i386-linux-gnu/libHalf.so.12.0.0
aff93000-b015e000 r-xp 00000000 08:02 134297 /usr/lib/i386-linux-gnu/libIlmImf-2_2.so.22.0.0
b015e000-b0160000 r--p 001ca000 08:02 134297 /usr/lib/i386-linux-gnu/libIlmImf-2_2.so.22.0.0
b0160000-b0261000 rw-p 001cc000 08:02 134297 /usr/lib/i386-linux-gnu/libIlmImf-2_2.so.22.0.0
b0265000-b026a000 r-xp 00000000 08:02 141463 /usr/lib/kde4/plugins/imageformats/kimg_pic.so
b026a000-b026b000 r--p 00004000 08:02 141463 /usr/lib/kde4/plugins/imageformats/kimg_pic.so
b026b000-b026c000 rw-p 00005000 08:02 141463 /usr/lib/kde4/plugins/imageformats/kimg_pic.so
b026c000-b0276000 r-xp 00000000 08:02 141462 /usr/lib/kde4/plugins/imageformats/kimg_pcx.so
b0276000-b0277000 r--p 00009000 08:02 141462 /usr/lib/kde4/plugins/imageformats/kimg_pcx.so
b0277000-b0278000 rw-p 0000a000 08:02 141462 /usr/lib/kde4/plugins/imageformats/kimg_pcx.so
b0278000-b027c000 r-xp 00000000 08:02 141459 /usr/lib/kde4/plugins/imageformats/kimg_jp2.so
b027c000-b027d000 r--p 00003000 08:02 141459 /usr/lib/kde4/plugins/imageformats/kimg_jp2.so
b027d000-b027e000 rw-p 00004000 08:02 141459 /usr/lib/kde4/plugins/imageformats/kimg_jp2.so
b027e000-b05c5000 r-xp 00000000 08:02 141569 /usr/lib/libkdecore.so.5.14.16
b05c5000-b05c6000 ---p 00347000 08:02 141569 /usr/lib/libkdecore.so.5.14.16
b05c6000-b05ce000 r--p 00347000 08:02 141569 /usr/lib/libkdecore.so.5.14.16
b05ce000-b05d1000 rw-p 0034f000 08:02 141569 /usr/lib/libkdecore.so.5.14.16
b05d1000-b0611000 rw-p 00000000 00:00 0
b0611000-b065c000 r--p 00000000 08:02 32998 /usr/share/fonts/truetype/noto/NotoSans-Regular.ttf
b065c000-b07b1000 r-xp 00000000 08:02 155487 /usr/lib/i386-linux-gnu/libQtNetwork.so.4.8.7
b07b1000-b07b2000 ---p 00155000 08:02 155487 /usr/lib/i386-linux-gnu/libQtNetwork.so.4.8.7
b07b2000-b07b5000 r--p 00155000 08:02 155487 /usr/lib/i386-linux-gnu/libQtNetwork.so.4.8.7
b07b5000-b07b6000 rw-p 00158000 08:02 155487 /usr/lib/i386-linux-gnu/libQtNetwork.so.4.8.7
b07b6000-b0bd6000 r-xp 00000000 08:02 155502 /usr/lib/i386-linux-gnu/libQtXmlPatterns.so.4.8.7
b0bd6000-b0bd7000 ---p 00420000 08:02 155502 /usr/lib/i386-linux-gnu/libQtXmlPatterns.so.4.8.7
b0bd7000-b0bf2000 r--p 00420000 08:02 155502 /usr/lib/i386-linux-gnu/libQtXmlPatterns.so.4.8.7
b0bf2000-b0bf3000 rw-p 0043b000 08:02 155502 /usr/lib/i386-linux-gnu/libQtXmlPatterns.so.4.8.7
b0bf3000-b0c32000 r-xp 00000000 08:02 155499 /usr/lib/i386-linux-gnu/libQtSql.so.4.8.7
b0c32000-b0c33000 r--p 0003e000 08:02 155499 /usr/lib/i386-linux-gnu/libQtSql.so.4.8.7
b0c33000-b0c34000 rw-p 0003f000 08:02 155499 /usr/lib/i386-linux-gnu/libQtSql.so.4.8.7
b0c34000-b0ecc000 r-xp 00000000 08:02 155492 /usr/lib/i386-linux-gnu/libQtScript.so.4.8.7
b0ecc000-b0ed5000 r--p 00297000 08:02 155492 /usr/lib/i386-linux-gnu/libQtScript.so.4.8.7
b0ed5000-b0ed6000 rw-p 002a0000 08:02 155492 /usr/lib/i386-linux-gnu/libQtScript.so.4.8.7
b0ed6000-b0ee6000 rw-p 00000000 00:00 0
b0ee6000-b1284000 r-xp 00000000 08:02 155507 /usr/lib/i386-linux-gnu/libQtDeclarative.so.4.8.7
b1284000-b1285000 ---p 0039e000 08:02 155507 /usr/lib/i386-linux-gnu/libQtDeclarative.so.4.8.7
b1285000-b1294000 r--p 0039e000 08:02 155507 /usr/lib/i386-linux-gnu/libQtDeclarative.so.4.8.7
b1294000-b1296000 rw-p 003ad000 08:02 155507 /usr/lib/i386-linux-gnu/libQtDeclarative.so.4.8.7
b1296000-b12e3000 r-xp 00000000 08:02 155524 /usr/lib/i386-linux-gnu/qt4/plugins/accessible/libqtaccessiblewidgets.so
b12e3000-b12e6000 r--p 0004c000 08:02 155524 /usr/lib/i386-linux-gnu/qt4/plugins/accessible/libqtaccessiblewidgets.so
b12e6000-b12e7000 rw-p 0004f000 08:02 155524 /usr/lib/i386-linux-gnu/qt4/plugins/accessible/libqtaccessiblewidgets.so
b12e7000-b136c000 r-xp 00000000 08:02 155480 /usr/lib/i386-linux-gnu/libQtDBus.so.4.8.7
b136c000-b136d000 r--p 00084000 08:02 155480 /usr/lib/i386-linux-gnu/libQtDBus.so.4.8.7
b136d000-b136e000 rw-p 00085000 08:02 155480 /usr/lib/i386-linux-gnu/libQtDBus.so.4.8.7
b136e000-b13c5000 rw-p 00000000 00:00 0
b13c7000-b13de000 r-xp 00000000 08:02 134268 /usr/lib/i386-linux-gnu/libIex-2_2.so.12.0.0
b13de000-b13e0000 r--p 00016000 08:02 134268 /usr/lib/i386-linux-gnu/libIex-2_2.so.12.0.0
b13e0000-b13e1000 rw-p 00018000 08:02 134268 /usr/lib/i386-linux-gnu/libIex-2_2.so.12.0.0
b13e1000-b13e6000 r-xp 00000000 08:02 141460 /usr/lib/kde4/plugins/imageformats/kimg_exr.so
b13e6000-b13e7000 r--p 00004000 08:02 141460 /usr/lib/kde4/plugins/imageformats/kimg_exr.so
b13e7000-b13e8000 rw-p 00005000 08:02 141460 /usr/lib/kde4/plugins/imageformats/kimg_exr.so
b13e8000-b142a000 r-xp 00000000 08:02 155477 /usr/lib/i386-linux-gnu/libQtXml.so.4.8.7
b142a000-b142b000 ---p 00042000 08:02 155477 /usr/lib/i386-linux-gnu/libQtXml.so.4.8.7
b142b000-b142c000 r--p 00042000 08:02 155477 /usr/lib/i386-linux-gnu/libQtXml.so.4.8.7
b142c000-b142d000 rw-p 00043000 08:02 155477 /usr/lib/i386-linux-gnu/libQtXml.so.4.8.7
b1432000-b143a000 r-xp 00000000 08:02 141456 /usr/lib/kde4/plugins/imageformats/kimg_eps.so
b143a000-b143b000 r--p 00007000 08:02 141456 /usr/lib/kde4/plugins/imageformats/kimg_eps.so
b143b000-b143c000 rw-p 00008000 08:02 141456 /usr/lib/kde4/plugins/imageformats/kimg_eps.so
b143c000-b143f000 r-xp 00000000 08:02 156222 /usr/lib/libdlrestrictions.so.1.0.0
b143f000-b1440000 r--p 00002000 08:02 156222 /usr/lib/libdlrestrictions.so.1.0.0
b1440000-b1441000 rw-p 00003000 08:02 156222 /usr/lib/libdlrestrictions.so.1.0.0
b1441000-b1448000 r-xp 00000000 08:02 141466 /usr/lib/kde4/plugins/imageformats/kimg_dds.so
b1448000-b1449000 r--p 00006000 08:02 141466 /usr/lib/kde4/plugins/imageformats/kimg_dds.so
b1449000-b144a000 rw-p 00007000 08:02 141466 /usr/lib/kde4/plugins/imageformats/kimg_dds.so
b144a000-b1487000 r-xp 00000000 08:02 155766 /usr/lib/i386-linux-gnu/qt4/plugins/accessiblebridge/libqspiaccessiblebridge.so
b1487000-b1488000 r--p 0003c000 08:02 155766 /usr/lib/i386-linux-gnu/qt4/plugins/accessiblebridge/libqspiaccessiblebridge.so
b1488000-b1489000 rw-p 0003d000 08:02 155766 /usr/lib/i386-linux-gnu/qt4/plugins/accessiblebridge/libqspiaccessiblebridge.so
b1489000-b1490000 r-xp 00000000 08:02 316003 /usr/lib/i386-linux-gnu/gtk-2.0/2.10.0/immodules/im-xim.so
b1490000-b1491000 r--p 00006000 08:02 316003 /usr/lib/i386-linux-gnu/gtk-2.0/2.10.0/immodules/im-xim.so
b1491000-b1492000 rw-p 00007000 08:02 316003 /usr/lib/i386-linux-gnu/gtk-2.0/2.10.0/immodules/im-xim.so
b1492000-b14dd000 r--p 00000000 08:02 32998 /usr/share/fonts/truetype/noto/NotoSans-Regular.ttf
b14dd000-b14e0000 r--p 00000000 08:02 325351 /usr/share/locale-langpack/de/LC_MESSAGES/atk10.mo
b14e0000-b151c000 r-xp 00000000 08:02 276823 /usr/lib/i386-linux-gnu/gtk-2.0/2.10.0/engines/libmurrine.so
b151c000-b151d000 r--p 0003b000 08:02 276823 /usr/lib/i386-linux-gnu/gtk-2.0/2.10.0/engines/libmurrine.so
b151d000-b151e000 rw-p 0003c000 08:02 276823 /usr/lib/i386-linux-gnu/gtk-2.0/2.10.0/engines/libmurrine.so
b151e000-b1547000 r--p 00000000 08:02 325358 /usr/share/locale-langpack/de/LC_MESSAGES/gtk20-properties.mo
b1547000-b1570000 r-xp 00000000 08:02 137115 /usr/lib/i386-linux-gnu/libdbus-glib-1.so.2.3.3
b1570000-b1571000 ---p 00029000 08:02 137115 /usr/lib/i386-linux-gnu/libdbus-glib-1.so.2.3.3
b1571000-b1572000 r--p 00029000 08:02 137115 /usr/lib/i386-linux-gnu/libdbus-glib-1.so.2.3.3
b1572000-b1573000 rw-p 0002a000 08:02 137115 /usr/lib/i386-linux-gnu/libdbus-glib-1.so.2.3.3
b1573000-b15a6000 r-xp 00000000 08:02 137266 /usr/lib/i386-linux-gnu/libgconf-2.so.4.1.5
b15a6000-b15a7000 r--p 00032000 08:02 137266 /usr/lib/i386-linux-gnu/libgconf-2.so.4.1.5
b15a7000-b15a8000 rw-p 00033000 08:02 137266 /usr/lib/i386-linux-gnu/libgconf-2.so.4.1.5
b15a8000-b15af000 r-xp 00000000 08:02 137112 /usr/lib/i386-linux-gnu/libdatrie.so.1.3.3
b15af000-b15b0000 ---p 00007000 08:02 137112 /usr/lib/i386-linux-gnu/libdatrie.so.1.3.3
b15b0000-b15b1000 r--p 00007000 08:02 137112 /usr/lib/i386-linux-gnu/libdatrie.so.1.3.3
b15b1000-b15b2000 rw-p 00008000 08:02 137112 /usr/lib/i386-linux-gnu/libdatrie.so.1.3.3
b15b2000-b15d7000 r-xp 00000000 08:02 138067 /usr/lib/i386-linux-gnu/libgraphite2.so.3.0.1
b15d7000-b15d8000 ---p 00025000 08:02 138067 /usr/lib/i386-linux-gnu/libgraphite2.so.3.0.1
b15d8000-b15d9000 r--p 00025000 08:02 138067 /usr/lib/i386-linux-gnu/libgraphite2.so.3.0.1
b15d9000-b15da000 rw-p 00026000 08:02 138067 /usr/lib/i386-linux-gnu/libgraphite2.so.3.0.1
b15da000-b15e3000 r-xp 00000000 08:02 137848 /usr/lib/i386-linux-gnu/libthai.so.0.2.4
b15e3000-b15e4000 r--p 00008000 08:02 137848 /usr/lib/i386-linux-gnu/libthai.so.0.2.4
b15e4000-b15e5000 rw-p 00009000 08:02 137848 /usr/lib/i386-linux-gnu/libthai.so.0.2.4
b15e5000-b1647000 r-xp 00000000 08:02 137105 /usr/lib/i386-linux-gnu/libharfbuzz.so.0.10000.1
b1647000-b1648000 r--p 00061000 08:02 137105 /usr/lib/i386-linux-gnu/libharfbuzz.so.0.10000.1
b1648000-b1649000 rw-p 00062000 08:02 137105 /usr/lib/i386-linux-gnu/libharfbuzz.so.0.10000.1
b1649000-b1652000 r-xp 00000000 08:02 137962 /usr/lib/i386-linux-gnu/libxcb-render.so.0.0.0
b1652000-b1653000 r--p 00008000 08:02 137962 /usr/lib/i386-linux-gnu/libxcb-render.so.0.0.0
b1653000-b1654000 rw-p 00009000 08:02 137962 /usr/lib/i386-linux-gnu/libxcb-render.so.0.0.0
b1654000-b1656000 r-xp 00000000 08:02 137966 /usr/lib/i386-linux-gnu/libxcb-shm.so.0.0.0
b1656000-b1657000 r--p 00001000 08:02 137966 /usr/lib/i386-linux-gnu/libxcb-shm.so.0.0.0
b1657000-b1658000 rw-p 00002000 08:02 137966 /usr/lib/i386-linux-gnu/libxcb-shm.so.0.0.0
b1658000-b1701000 r-xp 00000000 08:02 137681 /usr/lib/i386-linux-gnu/libpixman-1.so.0.33.6
b1701000-b1707000 r--p 000a8000 08:02 137681 /usr/lib/i386-linux-gnu/libpixman-1.so.0.33.6
b1707000-b1708000 rw-p 000ae000 08:02 137681 /usr/lib/i386-linux-gnu/libpixman-1.so.0.33.6Abgebrochen (Speicherabzug geschrieben) aber ohne GUI geht: $ hp-info -i
Device Information Utility ver. 5.2
Copyright (c) 2001-15 HP Development Company, LP
Device Parameters (dynamic data):
Parameter Value(s)
agent1-ack False
agent1-desc Black toner cartridge
agent1-dvc 0
agent1-health 0
agent1-health-desc Good/OK
agent1-hp-ink False
agent1-id 0
agent1-kind 4
agent1-known False
agent1-level 72
agent1-level-trigger 0
agent1-sku Q5949A/Q5949X
agent1-type 1
agent1-virgin False
back-end hp
cups-printers ['Hewlett-Packard-hp-LaserJet-1320-series']
cups-uri hp:/usb/hp_LaserJet_1320_series?serial=00CNHW55TGZ5
dev-file
device-state 1
device-uri hp:/usb/hp_LaserJet_1320_series?serial=00CNHW55TGZ5
deviceid MFG:Hewlett-Packard;CMD:PJL,MLC,BIDI-ECP,PCL,POSTSCRIPT,PC
LXL;MDL:hp LaserJet 1320
series;CLS:PRINTER;DES:Hewlett-Packard LaserJet 1320
series;MEM:9MB;COMMENT:RES=10x1;1;
duplexer 1
error-state 0
host
in-tray1 1
in-tray2 1
is-hp True
media-path 1
panel 1
panel-line1 b'Ready'
panel-line2 b''
photo-tray 0
port 1
r 0
revision 254
rg 000
rr 000000
rs 000000000
serial 00CNHW55TGZ5
status-code 1000
status-desc Idle
supply-door 1
top-door 4
Model Parameters (static data):
Parameter Value(s)
align-type 0
clean-type 0
color-cal-type 0
copy-type 0
embedded-server-type 1
fax-type 0
fw-download False
io-mfp-mode 6
io-mode 1
io-support 6
job-storage 0
linefeed-cal-type 0
model hp_LaserJet_1320_series
model-ui HP LaserJet 1320 Series
model1 HP LaserJet 1320 Series Printer
monitor-type 0
panel-check-type 1
pcard-type 0
plugin 0
plugin-reason 0
power-settings 0
pq-diag-type 0
r-type 0
r0-agent1-kind 4
r0-agent1-sku Q5949A/Q5949X
r0-agent1-type 1
scan-src 0
scan-type 0
status-battery-check 0
status-dynamic-counters 0
status-type 3
support-released True
support-subtype 14852
support-type 2
support-ver 0.9.5
tech-class ['LJMono', 'Postscript']
tech-subclass ['Normal']
tech-type 3
usb-pid 7447
usb-vid 1008
wifi-config 0
Status History (most recent first):
Date/Time Code Status Description User Job ID
10/10/19 14:17:22 1000 Idle ich 0
10/10/19 14:03:35 501 Print job has completed ich 1
10/10/19 14:03:21 500 Started a print job ich 1
10/10/19 14:02:23 1000 Idle ich 0
Done.
Jetzt fragt sich, was ich da auf meinem Laptop mit 18.04 machen kann. Kann ich da die Version 3.16.... parallel installieren?
swkh
Anmeldungsdatum: 10. April 2015
Auf meinem Desktop-Rechner läuft der HP LaserJet 1320 einwandfrei unter Xubuntu 18.04. $ hp-info -i
HP Linux Imaging and Printing System (ver. 3.17.10)
hp:/usb/hp_LaserJet_1320_series?serial=00CNBW4CHHQT
Parameter Value(s)
agent1-ack False
agent1-dvc 0
agent1-health 0
agent1-hp-ink False
agent1-id 0
agent1-kind 4
agent1-known False
agent1-level 88
agent1-type 1
agent1-virgin False
back-end hp
cups-uri hp:/usb/hp_LaserJet_1320_series?serial=00CNBW4CHHQT
dev-file
device-state 1
device-uri hp:/usb/hp_LaserJet_1320_series?serial=00CNBW4CHHQT
series;MEM:9MB;COMMENT:R=1200x1;1;
duplexer 1
error-state 0
host
in-tray1 1
in-tray2 1
is-hp True
media-path 1
panel 1
panel-line2 b''
photo-tray 0
port 1
r 0
revision 254
rg 000
rr 000000
rs 000000000
serial 00CNBW4CHHQT
status-code 1000
status-desc Idle
supply-door 1
top-door 4
Parameter Value(s)
align-type 0
clean-type 0
color-cal-type 0
copy-type 0
fax-type 0
fw-download False
io-mfp-mode 6
io-mode 1
io-support 6
job-storage 0
linefeed-cal-type 0
monitor-type 0
panel-check-type 1
pcard-type 0
plugin 0
plugin-reason 0
power-settings 0
pq-diag-type 0
r-type 0
r0-agent1-kind 4
r0-agent1-type 1
scan-src 0
scan-type 0
status-type 3
support-type 2
support-ver 0.9.5
tech-type 3
usb-pid 7447
usb-vid 1008
wifi-config 0
10/10/19 16:06:14 1000 Idle bill 0
