Hi,
danke für die antwort.
gksu /usr/sbin/synaptic
^bei dem Befehl kommt nichts in der Konsole.Das bild taucht kurz auf und ist dann wieder weg.
dmesg hat das ausgespuckt:
[ 0.000000] ACPI: IRQ0 used by override.
[ 0.000000] ACPI: IRQ2 used by override.
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] Enabling APIC mode: Flat. Using 1 I/O APICs
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] Allocating PCI resources starting at 50000000 (gap: 40000000:bec00000)
[ 0.000000] swsusp: Registered nosave memory region: 00000000000a0000 - 00000000000f0000
[ 0.000000] swsusp: Registered nosave memory region: 00000000000f0000 - 0000000000100000
[ 0.000000] Real-Time Preemption Support (C) 2004-2007 Ingo Molnar
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 258545
[ 0.000000] Kernel command line: root=UUID=cdb967fd-5bed-4c7f-9d96-5d1bcc21a998 ro quiet splash locale=de_DE
[ 0.000000] mapped APIC to ffffb000 (fee00000)
[ 0.000000] mapped IOAPIC to ffffa000 (fec00000)
[ 0.000000] Enabling fast FPU save and restore... done.
[ 0.000000] Enabling unmasked SIMD FPU exception support... done.
[ 0.000000] Initializing CPU#0
[ 0.000000] PID hash table entries: 4096 (order: 12, 16384 bytes)
[ 0.000000] Detected 2411.684 MHz processor.
[ 22.731979] Console: colour VGA+ 80x25
[ 22.731984] console [tty0] enabled
[ 22.732798] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 22.733616] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 22.782181] Memory: 1020956k/1048512k available (2225k kernel code, 26832k reserved, 1059k data, 368k init, 131008k highmem)
[ 22.782193] virtual kernel memory layout:
[ 22.782195] fixmap : 0xfff4b000 - 0xfffff000 ( 720 kB)
[ 22.782196] pkmap : 0xff800000 - 0xffc00000 (4096 kB)
[ 22.782197] vmalloc : 0xf8800000 - 0xff7fe000 ( 111 MB)
[ 22.782199] lowmem : 0xc0000000 - 0xf8000000 ( 896 MB)
[ 22.782200] .init : 0xc043b000 - 0xc0497000 ( 368 kB)
[ 22.782201] .data : 0xc032c6f0 - 0xc0435324 (1059 kB)
[ 22.782202] .text : 0xc0100000 - 0xc032c6f0 (2225 kB)
[ 22.782206] Checking if this processor honours the WP bit even in supervisor mode... Ok.
[ 22.842349] Calibrating delay using timer specific routine.. 4825.15 BogoMIPS (lpj=2412579)
[ 22.842413] Security Framework initialized
[ 22.842425] SELinux: Disabled at boot.
[ 22.842438] AppArmor: AppArmor initialized
[ 22.842443] Failure registering capabilities with primary security module.
[ 22.842464] Mount-cache hash table entries: 512
[ 22.842694] Initializing cgroup subsys ns
[ 22.842702] Initializing cgroup subsys cpuacct
[ 22.842721] CPU: After generic identify, caps: bfebfbff 00000000 00000000 00000000 00000400 00000000 00000000 00000000
[ 22.842738] CPU: Trace cache: 12K uops, L1 D cache: 8K
[ 22.842742] CPU: L2 cache: 512K
[ 22.842745] CPU: Hyper-Threading is disabled
[ 22.842748] CPU: After all inits, caps: bfebfbff 00000000 00000000 0000b080 00000400 00000000 00000000 00000000
[ 22.842765] Compat vDSO mapped to ffffe000.
[ 22.842784] Checking 'hlt' instruction... OK.
[ 22.846812] SMP alternatives: switching to UP code
[ 22.848191] Freeing SMP alternatives: 9k freed
[ 22.848377] Early unpacking initramfs... done
[ 23.211541] ACPI: Core revision 20070126
[ 23.211624] ACPI: Looking for DSDT in initramfs... error, file /DSDT.aml not found.
[ 23.329098] CPU0: Intel(R) Pentium(R) 4 CPU 2.40GHz stepping 07
[ 23.329147] Total of 1 processors activated (4825.15 BogoMIPS).
[ 23.329256] ENABLING IO-APIC IRQs
[ 23.329444] ..TIMER: vector=0x31 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 23.440969] Brought up 1 CPUs
[ 23.441001] CPU0 attaching sched-domain:
[ 23.441005] domain 0: span 01
[ 23.441007] groups: 01
[ 23.441297] net_namespace: 76 bytes
[ 23.441310] Booting paravirtualized kernel on bare hardware
[ 23.441990] Time: 14:18:53 Date: 09/08/08
[ 23.442044] NET: Registered protocol family 16
[ 23.442358] EISA bus registered
[ 23.442387] ACPI: bus type pci registered
[ 23.455362] PCI: PCI BIOS revision 2.10 entry at 0xfac50, last bus=1
[ 23.455366] PCI: Using configuration type 1
[ 23.455389] Setting up standard PCI resources
[ 23.457960] ACPI: EC: Look up EC in DSDT
[ 23.461555] ACPI: Interpreter enabled
[ 23.461559] ACPI: (supports S0 S3 S4 S5)
[ 23.461575] ACPI: Using IOAPIC for interrupt routing
[ 23.467175] ACPI: PCI Root Bridge [PCI0] (0000:00)
[ 23.467443] Enabling SiS 96x SMBus.
[ 23.468230] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 23.486505] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 9 10 11 *12 14 15)
[ 23.486617] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 7 9 10 11 12 14 15) *0, disabled.
[ 23.486728] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 *5 6 7 9 10 11 12 14 15)
[ 23.486837] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 7 9 10 *11 12 14 15)
[ 23.486945] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 *5 6 7 9 10 11 12 14 15)
[ 23.487057] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 7 9 10 11 *12 14 15)
[ 23.487168] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 7 9 10 *11 12 14 15)
[ 23.487278] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 7 *9 10 11 12 14 15)
[ 23.487466] Linux Plug and Play Support v0.97 (c) Adam Belay
[ 23.487515] pnp: PnP ACPI init
[ 23.487528] ACPI: bus type pnp registered
[ 23.491272] pnp: PnP ACPI: found 14 devices
[ 23.491276] ACPI: ACPI bus type pnp unregistered
[ 23.491284] PnPBIOS: Disabled by ACPI PNP
[ 23.491659] PCI: Using ACPI for IRQ routing
[ 23.491663] PCI: If a device doesn't work, try "pci=routeirq". If it helps, post a report
[ 23.530275] NET: Registered protocol family 8
[ 23.530279] NET: Registered protocol family 20
[ 23.530408] AppArmor: AppArmor Filesystem Enabled
[ 23.542315] system 00:00: iomem range 0xcd000-0xcffff has been reserved
[ 23.542320] system 00:00: iomem range 0xf0000-0xf7fff could not be reserved
[ 23.542323] system 00:00: iomem range 0xf8000-0xfbfff could not be reserved
[ 23.542326] system 00:00: iomem range 0xfc000-0xfffff could not be reserved
[ 23.542329] system 00:00: iomem range 0x3fff0000-0x3fffffff could not be reserved
[ 23.542332] system 00:00: iomem range 0xffff0000-0xffffffff could not be reserved
[ 23.542335] system 00:00: iomem range 0x0-0x9ffff could not be reserved
[ 23.542338] system 00:00: iomem range 0x100000-0x3ffeffff could not be reserved
[ 23.542341] system 00:00: iomem range 0xffee0000-0xffefffff has been reserved
[ 23.542344] system 00:00: iomem range 0xfffe0000-0xfffeffff has been reserved
[ 23.542348] system 00:00: iomem range 0xfec00000-0xfec00fff could not be reserved
[ 23.542351] system 00:00: iomem range 0xfee00000-0xfeefffff could not be reserved
[ 23.542360] system 00:02: ioport range 0x4d0-0x4d1 has been reserved
[ 23.542363] system 00:02: ioport range 0x800-0x805 has been reserved
[ 23.572946] PCI: Bridge: 0000:00:01.0
[ 23.572951] IO window: c000-cfff
[ 23.572958] MEM window: ec000000-edffffff
[ 23.572964] PREFETCH window: e0000000-e7ffffff
[ 23.573005] NET: Registered protocol family 2
[ 23.608247] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 23.608715] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 23.610342] TCP bind hash table entries: 65536 (order: 9, 2359296 bytes)
[ 23.614249] TCP: Hash tables configured (established 131072 bind 65536)
[ 23.614260] TCP reno registered
[ 23.626378] checking if image is initramfs... it is
[ 24.335300] Freeing initrd memory: 7389k freed
[ 24.336210] audit: initializing netlink socket (disabled)
[ 24.336233] audit(1220883533.325:1): initialized
[ 24.336359] krcupreemptd setsched 0
[ 24.336362] prio = 98
[ 24.336566] highmem bounce pool size: 64 pages
[ 24.336657] VFS: Disk quotas dquot_6.5.1
[ 24.336689] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 24.336809] io scheduler noop registered
[ 24.336812] io scheduler anticipatory registered
[ 24.336814] io scheduler deadline registered
[ 24.336823] io scheduler cfq registered (default)
[ 24.336882] Boot video device is 0000:01:00.0
[ 24.337303] isapnp: Scanning for PnP cards...
[ 24.694267] isapnp: No Plug & Play device found
[ 24.743935] Real Time Clock Driver v1.12ac
[ 24.744077] Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing enabled
[ 24.744228] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 24.744475] serial8250: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
[ 24.745520] 00:08: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 24.746192] 00:09: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
[ 24.747394] RAMDISK driver initialized: 16 RAM disks of 65536K size 1024 blocksize
[ 24.747492] input: Macintosh mouse button emulation as /devices/virtual/input/input0
[ 24.747716] PNP: No PS/2 controller found. Probing ports directly.
[ 24.785460] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 24.796853] mice: PS/2 mouse device common for all mice
[ 24.797030] EISA: Probing bus 0 at eisa.0
[ 24.797039] Cannot allocate resource for EISA slot 1
[ 24.797054] Cannot allocate resource for EISA slot 5
[ 24.797067] EISA: Detected 0 cards.
[ 24.797072] cpuidle: using governor ladder
[ 24.797191] NET: Registered protocol family 1
[ 24.797232] Using IPI No-Shortcut mode
[ 24.797296] registered taskstats version 1
[ 24.797390] Magic number: 8:374:333
[ 24.797513] hash matches device tty54
[ 24.797550] BIOS EDD facility v0.16 2004-Jun-25, 0 devices found
[ 24.797553] EDD information not available.
[ 24.798062] Freeing unused kernel memory: 368k freed
[ 26.130734] fuse init (API version 7.9)
[ 26.929355] SCSI subsystem initialized
[ 26.988110] usbcore: registered new interface driver usbfs
[ 26.988145] usbcore: registered new interface driver hub
[ 27.017025] usbcore: registered new device driver usb
[ 27.050960] libata version 3.00 loaded.
[ 27.061314] ohci_hcd: 2006 August 04 USB 1.1 'Open' Host Controller (OHCI) Driver
[ 27.061409] ACPI: PCI Interrupt 0000:00:03.0[A] -> GSI 20 (level, low) -> IRQ 16
[ 27.061427] ohci_hcd 0000:00:03.0: OHCI Host Controller
[ 27.061956] ohci_hcd 0000:00:03.0: new USB bus registered, assigned bus number 1
[ 27.070936] ohci_hcd 0000:00:03.0: irq 16, io mem 0xef001000
[ 27.074939] 8139too Fast Ethernet driver 0.9.28
[ 27.125995] usb usb1: configuration #1 chosen from 1 choice
[ 27.126028] hub 1-0:1.0: USB hub found
[ 27.126044] hub 1-0:1.0: 2 ports detected
[ 27.171918] Floppy drive(s): fd0 is 1.44M
[ 27.197563] FDC 0 is a post-1991 82077
[ 27.226925] ACPI: PCI Interrupt 0000:00:03.1[B] -> GSI 21 (level, low) -> IRQ 17
[ 27.226945] ohci_hcd 0000:00:03.1: OHCI Host Controller
[ 27.226977] ohci_hcd 0000:00:03.1: new USB bus registered, assigned bus number 2
[ 27.234773] ohci_hcd 0000:00:03.1: irq 17, io mem 0xef002000
[ 27.287812] usb usb2: configuration #1 chosen from 1 choice
[ 27.287848] hub 2-0:1.0: USB hub found
[ 27.287863] hub 2-0:1.0: 2 ports detected
[ 27.388706] ACPI: PCI Interrupt 0000:00:03.2[C] -> GSI 22 (level, low) -> IRQ 18
[ 27.388727] ohci_hcd 0000:00:03.2: OHCI Host Controller
[ 27.388764] ohci_hcd 0000:00:03.2: new USB bus registered, assigned bus number 3
[ 27.390576] ohci_hcd 0000:00:03.2: irq 18, io mem 0xef003000
[ 27.445572] usb usb3: configuration #1 chosen from 1 choice
[ 27.445605] hub 3-0:1.0: USB hub found
[ 27.445619] hub 3-0:1.0: 2 ports detected
[ 27.487422] usb 1-1: new low speed USB device using ohci_hcd and address 2
[ 27.547879] ACPI: PCI Interrupt 0000:00:03.3[D] -> GSI 23 (level, low) -> IRQ 19
[ 27.547901] ehci_hcd 0000:00:03.3: EHCI Host Controller
[ 27.547951] ehci_hcd 0000:00:03.3: new USB bus registered, assigned bus number 4
[ 27.547996] PCI: cache line size of 128 is not supported by device 0000:00:03.3
[ 27.550090] ehci_hcd 0000:00:03.3: irq 19, io mem 0xef004000
[ 27.652185] ehci_hcd 0000:00:03.3: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004
[ 27.652360] usb usb4: configuration #1 chosen from 1 choice
[ 27.652392] hub 4-0:1.0: USB hub found
[ 27.652404] hub 4-0:1.0: 6 ports detected
[ 27.753220] ACPI: PCI Interrupt 0000:00:0f.0[A] -> GSI 19 (level, low) -> IRQ 20
[ 27.753909] eth0: RealTek RTL8139 at 0xe000, 00:20:ed:55:52:2e, IRQ 20
[ 27.753912] eth0: Identified 8139 chip type 'RTL-8100B/8139D'
[ 27.759292] pata_sis 0000:00:02.5: version 0.5.2
[ 27.767401] 8139cp: 10/100 PCI Ethernet driver v1.3 (Mar 22, 2004)
[ 27.770170] scsi0 : pata_sis
[ 27.771567] scsi1 : pata_sis
[ 27.772257] ata1: PATA max UDMA/133 cmd 0x1f0 ctl 0x3f6 bmdma 0xf000 irq 14
[ 27.772260] ata2: PATA max UDMA/133 cmd 0x170 ctl 0x376 bmdma 0xf008 irq 15
[ 27.996212] ata1.00: ATA-7: ExcelStor Technology J8160, P22OA8BA, max UDMA/133
[ 27.996218] ata1.00: 312581808 sectors, multi 16: LBA48
[ 27.996662] ata1.01: ATA-6: ST380023A, 3.30, max UDMA/100
[ 27.996666] ata1.01: 156301488 sectors, multi 16: LBA
[ 28.003215] ata1.00: configured for UDMA/133
[ 28.025179] ata1.01: configured for UDMA/100
[ 28.049680] usb 1-1: device not accepting address 2, error -62
[ 28.329557] ata2.00: ATAPI: TSSTcorpCD/DVDW SH-S182M, SB03, max UDMA/33
[ 28.486367] ata2.00: configured for UDMA/33
[ 28.486554] scsi 0:0:0:0: Direct-Access ATA ExcelStor Techno P22O PQ: 0 ANSI: 5
[ 28.487216] scsi 0:0:1:0: Direct-Access ATA ST380023A 3.30 PQ: 0 ANSI: 5
[ 28.488294] scsi 1:0:0:0: CD-ROM TSSTcorp CD/DVDW SH-S182M SB03 PQ: 0 ANSI: 5
[ 28.509290] Driver 'sd' needs updating - please use bus_type methods
[ 28.509409] sd 0:0:0:0: [sda] 312581808 512-byte hardware sectors (160042 MB)
[ 28.509427] sd 0:0:0:0: [sda] Write Protect is off
[ 28.509430] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 28.509456] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 28.509523] sd 0:0:0:0: [sda] 312581808 512-byte hardware sectors (160042 MB)
[ 28.509538] sd 0:0:0:0: [sda] Write Protect is off
[ 28.509541] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 28.509565] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 28.509569] sda:
[ 28.518532] sd 0:0:0:0: [sda] Attached SCSI disk
[ 28.518619] sd 0:0:1:0: [sdb] 156301488 512-byte hardware sectors (80026 MB)
[ 28.518637] sd 0:0:1:0: [sdb] Write Protect is off
[ 28.518641] sd 0:0:1:0: [sdb] Mode Sense: 00 3a 00 00
[ 28.518666] sd 0:0:1:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 28.518727] sd 0:0:1:0: [sdb] 156301488 512-byte hardware sectors (80026 MB)
[ 28.518742] sd 0:0:1:0: [sdb] Write Protect is off
[ 28.518745] sd 0:0:1:0: [sdb] Mode Sense: 00 3a 00 00
[ 28.518769] sd 0:0:1:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 28.518772] sdb:<4>Driver 'sr' needs updating - please use bus_type methods
[ 28.533135] sdb1 sdb2 < sdb5 >
[ 28.548171] sd 0:0:1:0: [sdb] Attached SCSI disk
[ 28.556798] sr0: scsi3-mmc drive: 48x/48x writer dvd-ram cd/rw xa/form2 cdda tray
[ 28.556806] Uniform CD-ROM driver Revision: 3.20
[ 28.556888] sr 1:0:0:0: Attached scsi CD-ROM sr0
[ 28.568845] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 28.568871] sd 0:0:1:0: Attached scsi generic sg1 type 0
[ 28.568894] sr 1:0:0:0: Attached scsi generic sg2 type 5
[ 28.929576] usb 1-1: new low speed USB device using ohci_hcd and address 4
[ 28.944243] Attempting manual resume
[ 28.944248] swsusp: Resume From Partition 8:21
[ 28.944250] PM: Checking swsusp image.
[ 28.944490] PM: Resume from disk failed.
[ 28.991874] EXT3-fs: mounted filesystem with ordered data mode.
[ 28.991967] kjournald starting. Commit interval 5 seconds
[ 29.122060] usb 1-1: configuration #1 chosen from 1 choice
[ 29.396970] usb 3-1: new full speed USB device using ohci_hcd and address 2
[ 29.586435] usb 3-1: configuration #1 chosen from 1 choice
[ 39.214872] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 39.302523] Linux agpgart interface v0.102
[ 39.359504] sis96x_smbus 0000:00:02.1: SiS96x SMBus base address: 0x5c00
[ 39.426449] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 39.463396] agpgart: Detected SiS chipset - id:1606
[ 39.468516] agpgart: AGP aperture is 64M @ 0xe8000000
[ 39.813083] input: Power Button (FF) as /devices/virtual/input/input1
[ 39.821837] ACPI: Power Button (FF) [PWRF]
[ 39.821976] input: Power Button (CM) as /devices/virtual/input/input2
[ 39.833814] ACPI: Power Button (CM) [PWRB]
[ 39.833985] input: Sleep Button (CM) as /devices/virtual/input/input3
[ 39.845793] ACPI: Sleep Button (CM) [FUTS]
[ 40.142642] input: PC Speaker as /devices/platform/pcspkr/input/input4
[ 41.757533] ACPI: PCI Interrupt 0000:00:02.7[C] -> GSI 18 (level, low) -> IRQ 21
[ 41.966543] usbcore: registered new interface driver hiddev
[ 41.972467] input: MLK MTS2118 Wireless Desktop as /devices/pci0000:00/0000:00:03.0/usb1/1-1/1-1:1.0/input/input5
[ 41.982236] input,hidraw0: USB HID v1.00 Keyboard [MLK MTS2118 Wireless Desktop] on usb-0000:00:03.0-1
[ 41.990672] input: MLK MTS2118 Wireless Desktop as /devices/pci0000:00/0000:00:03.0/usb1/1-1/1-1:1.1/input/input6
[ 42.014334] input,hiddev96,hidraw1: USB HID v1.00 Mouse [MLK MTS2118 Wireless Desktop] on usb-0000:00:03.0-1
[ 42.027229] input: WALTOP International Corp. Slim Tablet as /devices/pci0000:00/0000:00:03.2/usb3/3-1/3-1:1.0/input/input7
[ 42.038232] input,hiddev97,hidraw2: USB HID v1.10 Mouse [WALTOP International Corp. Slim Tablet] on usb-0000:00:03.2-1
[ 42.038261] usbcore: registered new interface driver usbhid
[ 42.038267] /build/buildd/linux-2.6.24/debian/build/custom-source-rt/drivers/hid/usbhid/hid-core.c: v2.6:USB HID core driver
[ 42.105936] intel8x0_measure_ac97_clock: measured 50792 usecs
[ 42.105943] intel8x0: clocking to 48000
[ 42.772324] parport_pc 00:0a: reported by Plug and Play ACPI
[ 42.772355] parport0: PC-style at 0x378, irq 7 [PCSPP,TRISTATE,EPP]
[ 46.078397] lp0: using parport0 (interrupt-driven).
[ 46.163270] Adding 3028212k swap on /dev/sdb5. Priority:-1 extents:1 across:3028212k
[ 46.752428] EXT3 FS on sdb1, internal journal
[ 48.104301] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 48.680763] No dock devices found.
[ 50.340724] apm: BIOS version 1.2 Flags 0x07 (Driver version 1.16ac)
[ 50.340732] apm: overridden by ACPI.
[ 50.625736] ppdev: user-space parallel port driver
[ 50.805574] audit(1220883560.885:2): type=1503 operation="inode_permission" requested_mask="a::" denied_mask="a::" name="/dev/tty" pid=4770 profile="/usr/sbin/cupsd" namespace="default"
[ 53.002293] eth0: link up, 100Mbps, full-duplex, lpa 0x41E1
[ 53.144770] Bluetooth: Core ver 2.11
[ 53.145809] NET: Registered protocol family 31
[ 53.145816] Bluetooth: HCI device and connection manager initialized
[ 53.145821] Bluetooth: HCI socket layer initialized
[ 53.202989] Bluetooth: L2CAP ver 2.9
[ 53.203296] Bluetooth: L2CAP socket layer initialized
[ 53.265715] Bluetooth: RFCOMM socket layer initialized
[ 53.274211] Bluetooth: RFCOMM TTY layer initialized
[ 53.274735] Bluetooth: RFCOMM ver 1.8
[ 55.407033] [drm] Initialized drm 1.1.0 20060810
[ 55.421896] ACPI: PCI Interrupt 0000:01:00.0[A] -> GSI 16 (level, low) -> IRQ 22
[ 55.422019] [drm] Initialized radeon 1.28.0 20060524 on minor 0
[ 56.341028] NET: Registered protocol family 17
[ 57.090074] agpgart: Found an AGP 2.0 compliant device at 0000:00:00.0.
[ 57.090101] agpgart: Putting AGP V2 device at 0000:00:00.0 into 4x mode
[ 57.090156] agpgart: Putting AGP V2 device at 0000:01:00.0 into 4x mode
[ 57.478618] [drm] Setting GART location based on new memory map
[ 57.478632] [drm] Loading R200 Microcode
[ 57.478665] [drm] writeback test succeeded in 1 usecs
[ 59.364473] NET: Registered protocol family 10
[ 59.365090] lo: Disabled Privacy Extensions
[ 69.887880] eth0: no IPv6 routers present
[ 2246.044031] usb 4-4: new high speed USB device using ehci_hcd and address 4
[ 2246.160040] usb 4-4: configuration #1 chosen from 2 choices
[ 2246.262438] usbcore: registered new interface driver libusual
[ 2246.311192] Initializing USB Mass Storage driver...
[ 2246.326295] scsi2 : SCSI emulation for USB Mass Storage devices
[ 2246.328474] usbcore: registered new interface driver usb-storage
[ 2246.328485] USB Mass Storage support registered.
[ 2246.329258] usb-storage: device found at 4
[ 2246.329431] usb-storage: waiting for device to settle before scanning
[ 2251.322583] usb-storage: device scan complete
[ 2251.323304] scsi 2:0:0:0: Direct-Access Apple iPod 2.70 PQ: 0 ANSI: 2
[ 2251.325904] sd 2:0:0:0: [sdc] 495616 2048-byte hardware sectors (1015 MB)
[ 2251.326520] sd 2:0:0:0: [sdc] Write Protect is off
[ 2251.326527] sd 2:0:0:0: [sdc] Mode Sense: 64 00 00 08
[ 2251.326530] sd 2:0:0:0: [sdc] Assuming drive cache: write through
[ 2251.329023] sd 2:0:0:0: [sdc] 495616 2048-byte hardware sectors (1015 MB)
[ 2251.329763] sd 2:0:0:0: [sdc] Write Protect is off
[ 2251.329769] sd 2:0:0:0: [sdc] Mode Sense: 64 00 00 08
[ 2251.329772] sd 2:0:0:0: [sdc] Assuming drive cache: write through
[ 2251.329779] sdc: unknown partition table
[ 2251.360538] sd 2:0:0:0: [sdc] Attached SCSI removable disk
[ 2251.360611] sd 2:0:0:0: Attached scsi generic sg3 type 0
[14057.789814] blender-bin[17392]: segfault at 00000200 eip b7f2ebad esp bfb07e00 error 4
[14086.629619] blender-bin[25426]: segfault at 00000200 eip b7ff1bad esp bfd5bb50 error 4
[14089.166094] mtrr: no MTRR for e0000000,4000000 found
[14091.715368] agpgart: Found an AGP 2.0 compliant device at 0000:00:00.0.
[14091.715764] agpgart: Putting AGP V2 device at 0000:00:00.0 into 4x mode
[14091.716018] agpgart: Putting AGP V2 device at 0000:01:00.0 into 4x mode
[14092.068684] [drm] Setting GART location based on new memory map
[14092.069001] [drm] Loading R200 Microcode
[14092.069215] [drm] writeback test succeeded in 1 usecs
[14135.383709] mtrr: no MTRR for e0000000,4000000 found
[14137.927534] agpgart: Found an AGP 2.0 compliant device at 0000:00:00.0.
[14137.927879] agpgart: Putting AGP V2 device at 0000:00:00.0 into 4x mode
[14137.928138] agpgart: Putting AGP V2 device at 0000:01:00.0 into 4x mode
[14138.280778] [drm] Setting GART location based on new memory map
[14138.281116] [drm] Loading R200 Microcode
[14138.281296] [drm] writeback test succeeded in 1 usecs
[14230.359709] apt-check[28355]: segfault at cf8a1fa0 eip b7c94de9 esp bf8c8490 error 5
[14253.794421] update-manager[28760]: segfault at cd8f0fa0 eip b6c7dde9 esp bfafa610 error 5
[14288.660046] synaptic[29316]: segfault at ce5f1fa0 eip b7eadde9 esp bfe3c940 error 5
[14295.349205] update-manager[29483]: segfault at cd892fa0 eip b6c1fde9 esp bff23a40 error 5
[14305.078986] synaptic[29694]: segfault at ce5b0fa0 eip b7e6cde9 esp bfd985c0 error 5
[14309.888106] update-manager[29768]: segfault at cd8f3fa0 eip b6c80de9 esp bfe5f170 error 5
[14317.004614] synaptic[29919]: segfault at ce7cefa0 eip b7e9fde9 esp bfc6cbd0 error 5
[14355.594298] apt-get[30481]: segfault at cf860fa0 eip b7eabde9 esp bf8f1c70 error 5
[14377.424861] usb 4-4: USB disconnect, address 4
[14377.503442] scsi 2:0:0:0: rejecting I/O to dead device
[14426.309209] mtrr: no MTRR for e0000000,4000000 found
[14428.856833] agpgart: Found an AGP 2.0 compliant device at 0000:00:00.0.
[14428.857178] agpgart: Putting AGP V2 device at 0000:00:00.0 into 4x mode
[14428.857480] agpgart: Putting AGP V2 device at 0000:01:00.0 into 4x mode
[14429.210052] [drm] Setting GART location based on new memory map
[14429.210359] [drm] Loading R200 Microcode
[14429.210567] [drm] writeback test succeeded in 1 usecs
[14475.500157] synaptic[306]: segfault at ce602fa0 eip b7eabde9 esp bfd02080 error 5
[14480.629640] synaptic[398]: segfault at ce5b1fa0 eip b7e5ade9 esp bffa17d0 error 5
[14494.292944] synaptic[471]: segfault at ce607fa0 eip b7ec6de9 esp bfbcb580 error 5
[14527.350630] gnome-apt[1231]: segfault at ce537fa0 eip b752dde9 esp bfe8c9b0 error 5
[14535.228457] gdebi-gtk[1358]: segfault at ce1acfa0 eip b7c3cde9 esp bf87ef30 error 5
[14589.865901] update-manager[2328]: segfault at cd9b6fa0 eip b6d37de9 esp bfb57f30 error 5
[14781.543878] synaptic[5825]: segfault at ce5edfa0 eip b7e96de9 esp bf9fe230 error 5
[14796.297756] synaptic[6098]: segfault at ce5e3fa0 eip b7e8cde9 esp bf81c040 error 5
[15198.756060] apt-get[13150]: segfault at cf879fa0 eip b7ec4de9 esp bfa310d0 error 5
[15362.048735] apt-get[16130]: segfault at cf8cffa0 eip b7f1ade9 esp bff075b0 error 5
[15409.180117] agpgart: Found an AGP 2.0 compliant device at 0000:00:00.0.
[15409.180147] agpgart: Putting AGP V2 device at 0000:00:00.0 into 4x mode
[15409.180202] agpgart: Putting AGP V2 device at 0000:01:00.0 into 4x mode
[15409.180211] [drm] Loading R200 Microcode
[15417.158484] mtrr: no MTRR for e0000000,4000000 found
[15419.715204] agpgart: Found an AGP 2.0 compliant device at 0000:00:00.0.
[15419.715575] agpgart: Putting AGP V2 device at 0000:00:00.0 into 4x mode
[15419.715830] agpgart: Putting AGP V2 device at 0000:01:00.0 into 4x mode
[15420.068618] [drm] Setting GART location based on new memory map
[15420.068928] [drm] Loading R200 Microcode
[15420.069132] [drm] writeback test succeeded in 1 usecs
[15477.423766] apt-get[18254]: segfault at cf7effa0 eip b7e3ade9 esp bfd043a0 error 5
[15497.161686] mtrr: no MTRR for e0000000,4000000 found
[15499.703425] agpgart: Found an AGP 2.0 compliant device at 0000:00:00.0.
[15499.703807] agpgart: Putting AGP V2 device at 0000:00:00.0 into 4x mode
[15499.704056] agpgart: Putting AGP V2 device at 0000:01:00.0 into 4x mode
[15500.056695] [drm] Setting GART location based on new memory map
[15500.057010] [drm] Loading R200 Microcode
[15500.057216] [drm] writeback test succeeded in 1 usecs
[18898.602937] synaptic[12468]: segfault at ce678fa0 eip b7f21de9 esp bfc01450 error 5
[18921.957053] mtrr: no MTRR for e0000000,4000000 found
[18924.513323] agpgart: Found an AGP 2.0 compliant device at 0000:00:00.0.
[18924.513673] agpgart: Putting AGP V2 device at 0000:00:00.0 into 4x mode
[18924.513978] agpgart: Putting AGP V2 device at 0000:01:00.0 into 4x mode
[18924.866622] [drm] Setting GART location based on new memory map
[18924.866948] [drm] Loading R200 Microcode
[18924.867133] [drm] writeback test succeeded in 1 usecs
[19008.017736] synaptic[14667]: segfault at ce63cfa0 eip b7ef8de9 esp bfc75850 error 5
[19012.332263] apt-check[14819]: segfault at cf801fa0 eip b7bf4de9 esp bf8dbc90 error 5
Wie kann ich dann Fluxbox Entfernen wenn das ein Winmasanger ist.
MFG
