Berlin_1946 schrieb:
Hallo Kugelschallfan,
bitte das mal machen:
Standard-abfragen-zur-Analyse-bei-Drucker-Problemen
Hallo Berlin,
die Abfragen haben folgendes erbracht:
~$ dpkg -l *cups* lpr* | grep ii
ii bluez-cups 5.53-0ubuntu3.5 amd64 Bluetooth printer driver for CUPS
ii cups 2.3.1-9ubuntu1.1 amd64 Common UNIX Printing System(tm) - PPD/driver support, web interface
ii cups-browsed 1.27.4-1 amd64 OpenPrinting CUPS Filters - cups-browsed
ii cups-bsd 2.3.1-9ubuntu1.1 amd64 Common UNIX Printing System(tm) - BSD commands
ii cups-client 2.3.1-9ubuntu1.1 amd64 Common UNIX Printing System(tm) - client programs (SysV)
ii cups-common 2.3.1-9ubuntu1.1 all Common UNIX Printing System(tm) - common files
ii cups-core-drivers 2.3.1-9ubuntu1.1 amd64 Common UNIX Printing System(tm) - driverless printing
ii cups-daemon 2.3.1-9ubuntu1.1 amd64 Common UNIX Printing System(tm) - daemon
ii cups-filters 1.27.4-1 amd64 OpenPrinting CUPS Filters - Main Package
ii cups-filters-core-drivers 1.27.4-1 amd64 OpenPrinting CUPS Filters - Driverless printing
ii cups-ipp-utils 2.3.1-9ubuntu1.1 amd64 Common UNIX Printing System(tm) - IPP developer/admin utilities
ii cups-pk-helper 0.2.6-1ubuntu3 amd64 PolicyKit helper to configure cups with fine-grained privileges
ii cups-ppdc 2.3.1-9ubuntu1.1 amd64 Common UNIX Printing System(tm) - PPD manipulation utilities
ii cups-server-common 2.3.1-9ubuntu1.1 all Common UNIX Printing System(tm) - server common files
ii libcups2:amd64 2.3.1-9ubuntu1.1 amd64 Common UNIX Printing System(tm) - Core library
ii libcupsfilters1:amd64 1.27.4-1 amd64 OpenPrinting CUPS Filters - Shared library
ii libcupsimage2:amd64 2.3.1-9ubuntu1.1 amd64 Common UNIX Printing System(tm) - Raster image library
ii printer-driver-hpcups 3.20.3+dfsg0-2 amd64 HP Linux Printing and Imaging - CUPS Raster driver (hpcups)
ii python3-cups 1.9.73-3build1 amd64 Python3 bindings for CUPS
ii python3-cupshelpers 1.5.12-0ubuntu1.1 all Python utility modules around the CUPS printing system
~$ dpkg -l libusb* | grep ii
ii libusb-1.0-0:amd64 2:1.0.23-2build1 amd64 userspace USB programming library
ii libusbmuxd6:amd64 2.0.1-2 amd64 USB multiplexor daemon for iPhone and iPod Touch devices - library
~$ systemctl --no-pager status cups*
● cups.socket - CUPS Scheduler
Loaded: loaded (/lib/systemd/system/cups.socket; enabled; vendor preset: enabled)
Active: active (running) since Fri 2022-05-20 13:16:34 CEST; 56min ago
Triggers: ● cups.service
Listen: /run/cups/cups.sock (Stream)
CGroup: /system.slice/cups.socket
Mai 20 13:16:34 doenitz-LIFEBOOK-A3510 systemd[1]: Listening on CUPS Scheduler.
● cups.service - CUPS Scheduler
Loaded: loaded (/lib/systemd/system/cups.service; enabled; vendor preset: enabled)
TriggeredBy: ● cups.socket
● cups.path
Docs: man:cupsd(8)
Main PID: 706 (cupsd)
Tasks: 2 (limit: 9047)
Memory: 6.4M
CGroup: /system.slice/cups.service
├─706 /usr/sbin/cupsd -l
└─864 /usr/lib/cups/notifier/dbus dbus://
Mai 20 13:16:34 doenitz-LIFEBOOK-A3510 systemd[1]: Started CUPS Scheduler.
● cups-browsed.service - Make remote CUPS printers available locally
Loaded: loaded (/lib/systemd/system/cups-browsed.service; enabled; vendor preset: enabled)
Main PID: 769 (cups-browsed)
Tasks: 3 (limit: 9047)
Memory: 3.8M
CGroup: /system.slice/cups-browsed.service
└─769 /usr/sbin/cups-browsed
Mai 20 13:16:34 doenitz-LIFEBOOK-A3510 systemd[1]: Started Make remote CUPS…ly.
● cups.path - CUPS Scheduler
Loaded: loaded (/lib/systemd/system/cups.path; enabled; vendor preset: enabled)
Hint: Some lines were ellipsized, use -l to show in full.
~$ lpstat -t
Zeitplandienst läuft
systemvoreingestelltes Ziel: TS5000_series
Gerät für TS5000_series: usb://Canon/TS5000%20series?serial=100C7E&interface=1
TS5000_series akzeptiert Anfragen seit Di 17 Mai 2022 15:29:01 CEST
Drucker TS5000_series ist im Leerlauf. Aktiviert seit Di 17 Mai 2022 15:29:01 CEST
Datei "/usr/lib/cups/filter/cmdtocanonij2" nicht verfügbar: No such file or directory
TS5000_series-11 doenitz 17408 Di 17 Mai 2022 14:37:10 CEST
TS5000_series-12 doenitz 17408 Di 17 Mai 2022 14:58:35 CEST
TS5000_series-13 doenitz 17408 Di 17 Mai 2022 15:03:15 CEST
TS5000_series-14 doenitz 17408 Di 17 Mai 2022 15:29:01 CEST
~$ lpinfo -v
network http
network socket
network beh
file cups-brf:/
network https
network ipps
direct hp
network ipp
direct usb://Canon/TS5000%20series?serial=100C7E&interface=1
network lpd
direct hpfax
network ipp://TS5000%20series._ipp._tcp.local/
~$ hp-info -i
HP Linux Imaging and Printing System (ver. 3.20.3)
Device Information Utility ver. 5.2
Copyright (c) 2001-18 HP Development Company, LP
error: No device found that support this feature.
~$ uname -rm
5.13.0-41-generic x86_64
~$ lsusb
Bus 003 Device 004: ID 04f2:b6a0 Chicony Electronics Co., Ltd FJ Camera
Bus 003 Device 003: ID 04a9:1802 Canon, Inc. TS5000 series
Bus 003 Device 005: ID 8087:0aaa Intel Corp.
Bus 003 Device 002: ID 04f3:0210 Elan Microelectronics Corp. Optical Mouse
~$ id
uid=1000(doenitz) gid=1000(doenitz) Gruppen=1000(doenitz),4(adm),24(cdrom),27(sudo),30(dip),46(plugdev),120(lpadmin),132(lxd),133(sambashare)
~$ ls -l /etc/cups/ppd/*
-rw-r----- 1 root lp 70213 Mai 17 14:15 /etc/cups/ppd/TS5000_series.ppd
~$ export SANE_DEBUG_DLL=255 && scanimage -L
[14:25:09.601402] [sanei_debug] Setting debug level of dll to 255.
[14:25:09.601481] [dll] sane_init: SANE dll backend version 1.0.13 from sane-backends 1.0.29
[14:25:09.601502] [dll] sane_init/read_dlld: attempting to open directory `./dll.d'
[14:25:09.601542] [dll] sane_init/read_dlld: attempting to open directory `/etc/sane.d/dll.d'
[14:25:09.601564] [dll] sane_init/read_dlld: using config directory `/etc/sane.d/dll.d'
[14:25:09.601590] [dll] sane_init/read_dlld: considering /etc/sane.d/dll.d/hplip
[14:25:09.601619] [dll] sane_init/read_config: reading dll.d/hplip
[14:25:09.601647] [dll] add_backend: adding backend `hpaio'
[14:25:09.601671] [dll] sane_init/read_dlld: done.
[14:25:09.601700] [dll] sane_init/read_config: reading dll.conf
[14:25:09.601723] [dll] add_backend: adding backend `net'
[14:25:09.601737] [dll] add_backend: adding backend `abaton'
[14:25:09.601770] [dll] add_backend: adding backend `agfafocus'
[14:25:09.601783] [dll] add_backend: adding backend `apple'
[14:25:09.601797] [dll] add_backend: adding backend `artec'
[14:25:09.601810] [dll] add_backend: adding backend `artec_eplus48u'
[14:25:09.601824] [dll] add_backend: adding backend `as6e'
[14:25:09.601837] [dll] add_backend: adding backend `avision'
[14:25:09.601855] [dll] add_backend: adding backend `bh'
[14:25:09.601869] [dll] add_backend: adding backend `canon'
[14:25:09.601886] [dll] add_backend: adding backend `canon630u'
[14:25:09.601902] [dll] add_backend: adding backend `canon_dr'
[14:25:09.601914] [dll] add_backend: adding backend `cardscan'
[14:25:09.601927] [dll] add_backend: adding backend `coolscan'
[14:25:09.601943] [dll] add_backend: adding backend `coolscan3'
[14:25:09.601956] [dll] add_backend: adding backend `dell1600n_net'
[14:25:09.601976] [dll] add_backend: adding backend `dmc'
[14:25:09.601988] [dll] add_backend: adding backend `epjitsu'
[14:25:09.602003] [dll] add_backend: adding backend `epson2'
[14:25:09.602014] [dll] add_backend: adding backend `epsonds'
[14:25:09.602026] [dll] add_backend: adding backend `escl'
[14:25:09.602054] [dll] add_backend: adding backend `fujitsu'
[14:25:09.602065] [dll] add_backend: adding backend `genesys'
[14:25:09.602078] [dll] add_backend: adding backend `gt68xx'
[14:25:09.602092] [dll] add_backend: adding backend `hp'
[14:25:09.602105] [dll] add_backend: adding backend `hp3500'
[14:25:09.602129] [dll] add_backend: adding backend `hp3900'
[14:25:09.602141] [dll] add_backend: adding backend `hp4200'
[14:25:09.602155] [dll] add_backend: adding backend `hp5400'
[14:25:09.602169] [dll] add_backend: adding backend `hp5590'
[14:25:09.602196] [dll] add_backend: adding backend `hpljm1005'
[14:25:09.602212] [dll] add_backend: adding backend `hpsj5s'
[14:25:09.602228] [dll] add_backend: adding backend `hs2p'
[14:25:09.602247] [dll] add_backend: adding backend `ibm'
[14:25:09.602265] [dll] add_backend: adding backend `kodak'
[14:25:09.602286] [dll] add_backend: adding backend `kodakaio'
[14:25:09.602319] [dll] add_backend: adding backend `kvs1025'
[14:25:09.602343] [dll] add_backend: adding backend `kvs20xx'
[14:25:09.602361] [dll] add_backend: adding backend `kvs40xx'
[14:25:09.602377] [dll] add_backend: adding backend `leo'
[14:25:09.602396] [dll] add_backend: adding backend `lexmark'
[14:25:09.602412] [dll] add_backend: adding backend `ma1509'
[14:25:09.602426] [dll] add_backend: adding backend `magicolor'
[14:25:09.602439] [dll] add_backend: adding backend `matsushita'
[14:25:09.602452] [dll] add_backend: adding backend `microtek'
[14:25:09.602467] [dll] add_backend: adding backend `microtek2'
[14:25:09.602484] [dll] add_backend: adding backend `mustek'
[14:25:09.602500] [dll] add_backend: adding backend `mustek_usb'
[14:25:09.602516] [dll] add_backend: adding backend `mustek_usb2'
[14:25:09.602532] [dll] add_backend: adding backend `nec'
[14:25:09.602546] [dll] add_backend: adding backend `niash'
[14:25:09.602561] [dll] add_backend: adding backend `pie'
[14:25:09.602576] [dll] add_backend: adding backend `pieusb'
[14:25:09.602592] [dll] add_backend: adding backend `pint'
[14:25:09.602608] [dll] add_backend: adding backend `pixma'
[14:25:09.602624] [dll] add_backend: adding backend `plustek'
[14:25:09.602640] [dll] add_backend: adding backend `qcam'
[14:25:09.602656] [dll] add_backend: adding backend `ricoh'
[14:25:09.602671] [dll] add_backend: adding backend `ricoh2'
[14:25:09.602691] [dll] add_backend: adding backend `rts8891'
[14:25:09.602707] [dll] add_backend: adding backend `s9036'
[14:25:09.602723] [dll] add_backend: adding backend `sceptre'
[14:25:09.602739] [dll] add_backend: adding backend `sharp'
[14:25:09.602755] [dll] add_backend: adding backend `sm3600'
[14:25:09.602770] [dll] add_backend: adding backend `sm3840'
[14:25:09.602786] [dll] add_backend: adding backend `snapscan'
[14:25:09.602800] [dll] add_backend: adding backend `sp15c'
[14:25:09.602817] [dll] add_backend: adding backend `tamarack'
[14:25:09.602832] [dll] add_backend: adding backend `teco1'
[14:25:09.602849] [dll] add_backend: adding backend `teco2'
[14:25:09.602911] [dll] add_backend: adding backend `teco3'
[14:25:09.602930] [dll] add_backend: adding backend `u12'
[14:25:09.602943] [dll] add_backend: adding backend `umax'
[14:25:09.602958] [dll] add_backend: adding backend `umax1220u'
[14:25:09.602972] [dll] add_backend: adding backend `v4l'
[14:25:09.602988] [dll] add_backend: adding backend `xerox_mfp'
[14:25:09.603039] [dll] sane_get_devices
[14:25:09.603052] [dll] load: searching backend `xerox_mfp' in `/usr/lib/x86_64-linux-gnu/sane:/usr/lib/sane:/usr/lib64/sane'
[14:25:09.603068] [dll] load: trying to load `/usr/lib/x86_64-linux-gnu/sane/libsane-xerox_mfp.so.1'
[14:25:09.603092] [dll] load: dlopen()ing `/usr/lib/x86_64-linux-gnu/sane/libsane-xerox_mfp.so.1'
[14:25:09.603309] [dll] init: initializing backend `xerox_mfp'
[14:25:09.607838] [dll] init: backend `xerox_mfp' is version 1.0.13
[14:25:09.607990] [dll] load: searching backend `v4l' in `/usr/lib/x86_64-linux-gnu/sane:/usr/lib/sane:/usr/lib64/sane'
[14:25:09.608008] [dll] load: trying to load `/usr/lib/x86_64-linux-gnu/sane/libsane-v4l.so.1'
[14:25:09.608028] [dll] load: couldn't open `/usr/lib/x86_64-linux-gnu/sane/libsane-v4l.so.1' (No such file or directory)
[14:25:09.608045] [dll] load: trying to load `/usr/lib/sane/libsane-v4l.so.1'
[14:25:09.608063] [dll] load: couldn't open `/usr/lib/sane/libsane-v4l.so.1' (No such file or directory)
[14:25:09.608079] [dll] load: trying to load `/usr/lib64/sane/libsane-v4l.so.1'
[14:25:09.608099] [dll] load: couldn't open `/usr/lib64/sane/libsane-v4l.so.1' (No such file or directory)
[14:25:09.608114] [dll] load: couldn't find backend `v4l' (No such file or directory)
[14:25:09.608130] [dll] load: searching backend `umax1220u' in `/usr/lib/x86_64-linux-gnu/sane:/usr/lib/sane:/usr/lib64/sane'
[14:25:09.608146] [dll] load: trying to load `/usr/lib/x86_64-linux-gnu/sane/libsane-umax1220u.so.1'
[14:25:09.608168] [dll] load: dlopen()ing `/usr/lib/x86_64-linux-gnu/sane/libsane-umax1220u.so.1'
[14:25:09.608361] [dll] init: initializing backend `umax1220u'
[14:25:09.610178] [dll] init: backend `umax1220u' is version 1.0.2
[14:25:09.610186] [dll] load: searching backend `umax' in `/usr/lib/x86_64-linux-gnu/sane:/usr/lib/sane:/usr/lib64/sane'
[14:25:09.610189] [dll] load: trying to load `/usr/lib/x86_64-linux-gnu/sane/libsane-umax.so.1'
[14:25:09.610198] [dll] load: dlopen()ing `/usr/lib/x86_64-linux-gnu/sane/libsane-umax.so.1'
[14:25:09.610287] [dll] init: initializing backend `umax'
[14:25:09.612298] [dll] init: backend `umax' is version 1.0.45
[14:25:09.612307] [dll] load: searching backend `u12' in `/usr/lib/x86_64-linux-gnu/sane:/usr/lib/sane:/usr/lib64/sane'
[14:25:09.612310] [dll] load: trying to load `/usr/lib/x86_64-linux-gnu/sane/libsane-u12.so.1'
[14:25:09.612315] [dll] load: dlopen()ing `/usr/lib/x86_64-linux-gnu/sane/libsane-u12.so.1'
[14:25:09.612399] [dll] init: initializing backend `u12'
[14:25:09.614295] [dll] init: backend `u12' is version 1.0.0
[14:25:09.614304] [dll] load: searching backend `teco3' in `/usr/lib/x86_64-linux-gnu/sane:/usr/lib/sane:/usr/lib64/sane'
[14:25:09.614308] [dll] load: trying to load `/usr/lib/x86_64-linux-gnu/sane/libsane-teco3.so.1'
[14:25:09.614313] [dll] load: dlopen()ing `/usr/lib/x86_64-linux-gnu/sane/libsane-teco3.so.1'
[14:25:09.614378] [dll] init: initializing backend `teco3'
[14:25:09.614540] [dll] init: backend `teco3' is version 1.0.1
[14:25:09.614547] [dll] load: searching backend `teco2' in `/usr/lib/x86_64-linux-gnu/sane:/usr/lib/sane:/usr/lib64/sane'
[14:25:09.614553] [dll] load: trying to load `/usr/lib/x86_64-linux-gnu/sane/libsane-teco2.so.1'
[14:25:09.614562] [dll] load: dlopen()ing `/usr/lib/x86_64-linux-gnu/sane/libsane-teco2.so.1'
[14:25:09.614609] [dll] init: initializing backend `teco2'
[14:25:09.614840] [dll] init: backend `teco2' is version 1.0.10
[14:25:09.614847] [dll] load: searching backend `teco1' in `/usr/lib/x86_64-linux-gnu/sane:/usr/lib/sane:/usr/lib64/sane'
[14:25:09.614853] [dll] load: trying to load `/usr/lib/x86_64-linux-gnu/sane/libsane-teco1.so.1'
[14:25:09.614861] [dll] load: dlopen()ing `/usr/lib/x86_64-linux-gnu/sane/libsane-teco1.so.1'
[14:25:09.614909] [dll] init: initializing backend `teco1'
[14:25:09.615078] [dll] init: backend `teco1' is version 1.0.10
[14:25:09.615085] [dll] load: searching backend `tamarack' in `/usr/lib/x86_64-linux-gnu/sane:/usr/lib/sane:/usr/lib64/sane'
[14:25:09.615092] [dll] load: trying to load `/usr/lib/x86_64-linux-gnu/sane/libsane-tamarack.so.1'
[14:25:09.615101] [dll] load: dlopen()ing `/usr/lib/x86_64-linux-gnu/sane/libsane-tamarack.so.1'
[14:25:09.615154] [dll] init: initializing backend `tamarack'
[14:25:09.615238] [dll] init: backend `tamarack' is version 1.0.0
[14:25:09.615244] [dll] load: searching backend `sp15c' in `/usr/lib/x86_64-linux-gnu/sane:/usr/lib/sane:/usr/lib64/sane'
[14:25:09.615251] [dll] load: trying to load `/usr/lib/x86_64-linux-gnu/sane/libsane-sp15c.so.1'
[14:25:09.615259] [dll] load: dlopen()ing `/usr/lib/x86_64-linux-gnu/sane/libsane-sp15c.so.1'
[14:25:09.615310] [dll] init: initializing backend `sp15c'
[14:25:09.615353] [dll] init: backend `sp15c' is version 1.0.0
[14:25:09.615360] [dll] load: searching backend `snapscan' in `/usr/lib/x86_64-linux-gnu/sane:/usr/lib/sane:/usr/lib64/sane'
[14:25:09.615366] [dll] load: trying to load `/usr/lib/x86_64-linux-gnu/sane/libsane-snapscan.so.1'
[14:25:09.615374] [dll] load: dlopen()ing `/usr/lib/x86_64-linux-gnu/sane/libsane-snapscan.so.1'
[14:25:09.615455] [dll] init: initializing backend `snapscan'
[14:25:09.617257] [dll] init: backend `snapscan' is version 1.4.53
[14:25:09.617265] [dll] load: searching backend `sm3840' in `/usr/lib/x86_64-linux-gnu/sane:/usr/lib/sane:/usr/lib64/sane'
[14:25:09.617268] [dll] load: trying to load `/usr/lib/x86_64-linux-gnu/sane/libsane-sm3840.so.1'
[14:25:09.617276] [dll] load: dlopen()ing `/usr/lib/x86_64-linux-gnu/sane/libsane-sm3840.so.1'
[14:25:09.617350] [dll] init: initializing backend `sm3840'
[14:25:09.619324] [dll] init: backend `sm3840' is version 1.0.0
[14:25:09.619336] [dll] load: searching backend `sm3600' in `/usr/lib/x86_64-linux-gnu/sane:/usr/lib/sane:/usr/lib64/sane'
[14:25:09.619344] [dll] load: trying to load `/usr/lib/x86_64-linux-gnu/sane/libsane-sm3600.so.1'
[14:25:09.619365] [dll] load: dlopen()ing `/usr/lib/x86_64-linux-gnu/sane/libsane-sm3600.so.1'
[14:25:09.619475] [dll] init: initializing backend `sm3600'
[14:25:09.621752] [dll] init: backend `sm3600' is version 1.0.6
[14:25:09.621770] [dll] load: searching backend `sharp' in `/usr/lib/x86_64-linux-gnu/sane:/usr/lib/sane:/usr/lib64/sane'
[14:25:09.621776] [dll] load: trying to load `/usr/lib/x86_64-linux-gnu/sane/libsane-sharp.so.1'
[14:25:09.621789] [dll] load: dlopen()ing `/usr/lib/x86_64-linux-gnu/sane/libsane-sharp.so.1'
[14:25:09.621897] [dll] init: initializing backend `sharp'
[14:25:09.622015] [dll] init: backend `sharp' is version 1.0.0
[14:25:09.622023] [dll] load: searching backend `sceptre' in `/usr/lib/x86_64-linux-gnu/sane:/usr/lib/sane:/usr/lib64/sane'
[14:25:09.622029] [dll] load: trying to load `/usr/lib/x86_64-linux-gnu/sane/libsane-sceptre.so.1'
[14:25:09.622038] [dll] load: dlopen()ing `/usr/lib/x86_64-linux-gnu/sane/libsane-sceptre.so.1'
[14:25:09.622125] [dll] init: initializing backend `sceptre'
[14:25:09.622262] [dll] init: backend `sceptre' is version 1.0.10
[14:25:09.622269] [dll] load: searching backend `s9036' in `/usr/lib/x86_64-linux-gnu/sane:/usr/lib/sane:/usr/lib64/sane'
[14:25:09.622277] [dll] load: trying to load `/usr/lib/x86_64-linux-gnu/sane/libsane-s9036.so.1'
[14:25:09.622290] [dll] load: dlopen()ing `/usr/lib/x86_64-linux-gnu/sane/libsane-s9036.so.1'
[14:25:09.622347] [dll] init: initializing backend `s9036'
[14:25:09.622419] [dll] init: backend `s9036' is version 1.0.0
[14:25:09.622427] [dll] load: searching backend `rts8891' in `/usr/lib/x86_64-linux-gnu/sane:/usr/lib/sane:/usr/lib64/sane'
[14:25:09.622433] [dll] load: trying to load `/usr/lib/x86_64-linux-gnu/sane/libsane-rts8891.so.1'
[14:25:09.622442] [dll] load: dlopen()ing `/usr/lib/x86_64-linux-gnu/sane/libsane-rts8891.so.1'
[14:25:09.622537] [dll] init: initializing backend `rts8891'
[14:25:09.624841] [dll] init: backend `rts8891' is version 1.0.2401
[14:25:09.624915] [dll] load: searching backend `ricoh2' in `/usr/lib/x86_64-linux-gnu/sane:/usr/lib/sane:/usr/lib64/sane'
[14:25:09.624925] [dll] load: trying to load `/usr/lib/x86_64-linux-gnu/sane/libsane-ricoh2.so.1'
[14:25:09.624935] [dll] load: dlopen()ing `/usr/lib/x86_64-linux-gnu/sane/libsane-ricoh2.so.1'
[14:25:09.625188] [dll] init: initializing backend `ricoh2'
[14:25:09.627257] [dll] init: backend `ricoh2' is version 1.0.0
[14:25:09.627267] [dll] load: searching backend `ricoh' in `/usr/lib/x86_64-linux-gnu/sane:/usr/lib/sane:/usr/lib64/sane'
[14:25:09.627273] [dll] load: trying to load `/usr/lib/x86_64-linux-gnu/sane/libsane-ricoh.so.1'
[14:25:09.627279] [dll] load: dlopen()ing `/usr/lib/x86_64-linux-gnu/sane/libsane-ricoh.so.1'
[14:25:09.627366] [dll] init: initializing backend `ricoh'
[14:25:09.627445] [dll] init: backend `ricoh' is version 1.0.0
[14:25:09.627452] [dll] load: searching backend `qcam' in `/usr/lib/x86_64-linux-gnu/sane:/usr/lib/sane:/usr/lib64/sane'
[14:25:09.627459] [dll] load: trying to load `/usr/lib/x86_64-linux-gnu/sane/libsane-qcam.so.1'
[14:25:09.627467] [dll] load: dlopen()ing `/usr/lib/x86_64-linux-gnu/sane/libsane-qcam.so.1'
[14:25:09.627517] [dll] init: initializing backend `qcam'
[14:25:09.627540] [dll] init: backend `qcam' is version 1.0.0
[14:25:09.627545] [dll] load: searching backend `plustek' in `/usr/lib/x86_64-linux-gnu/sane:/usr/lib/sane:/usr/lib64/sane'
[14:25:09.627552] [dll] load: trying to load `/usr/lib/x86_64-linux-gnu/sane/libsane-plustek.so.1'
[14:25:09.627560] [dll] load: dlopen()ing `/usr/lib/x86_64-linux-gnu/sane/libsane-plustek.so.1'
[14:25:09.627648] [dll] init: initializing backend `plustek'
[14:25:09.629408] [dll] init: backend `plustek' is version 1.0.0
[14:25:09.629416] [dll] load: searching backend `pixma' in `/usr/lib/x86_64-linux-gnu/sane:/usr/lib/sane:/usr/lib64/sane'
[14:25:09.629419] [dll] load: trying to load `/usr/lib/x86_64-linux-gnu/sane/libsane-pixma.so.1'
[14:25:09.629426] [dll] load: dlopen()ing `/usr/lib/x86_64-linux-gnu/sane/libsane-pixma.so.1'
[14:25:09.629526] [dll] init: initializing backend `pixma'
[14:25:09.631258] [dll] init: backend `pixma' is version 1.0.27
[14:25:10.152729] [dll] load: searching backend `pint' in `/usr/lib/x86_64-linux-gnu/sane:/usr/lib/sane:/usr/lib64/sane'
[14:25:10.152778] [dll] load: trying to load `/usr/lib/x86_64-linux-gnu/sane/libsane-pint.so.1'
[14:25:10.152819] [dll] load: couldn't open `/usr/lib/x86_64-linux-gnu/sane/libsane-pint.so.1' (No such file or directory)
[14:25:10.152835] [dll] load: trying to load `/usr/lib/sane/libsane-pint.so.1'
[14:25:10.152860] [dll] load: couldn't open `/usr/lib/sane/libsane-pint.so.1' (No such file or directory)
[14:25:10.152876] [dll] load: trying to load `/usr/lib64/sane/libsane-pint.so.1'
[14:25:10.152893] [dll] load: couldn't open `/usr/lib64/sane/libsane-pint.so.1' (No such file or directory)
[14:25:10.152904] [dll] load: couldn't find backend `pint' (No such file or directory)
[14:25:10.152915] [dll] load: searching backend `pieusb' in `/usr/lib/x86_64-linux-gnu/sane:/usr/lib/sane:/usr/lib64/sane'
[14:25:10.152929] [dll] load: trying to load `/usr/lib/x86_64-linux-gnu/sane/libsane-pieusb.so.1'
[14:25:10.152960] [dll] load: dlopen()ing `/usr/lib/x86_64-linux-gnu/sane/libsane-pieusb.so.1'
[14:25:10.153273] [dll] init: initializing backend `pieusb'
[14:25:10.157914] [dll] init: backend `pieusb' is version 1.0.1
[14:25:10.157939] [dll] load: searching backend `pie' in `/usr/lib/x86_64-linux-gnu/sane:/usr/lib/sane:/usr/lib64/sane'
[14:25:10.157947] [dll] load: trying to load `/usr/lib/x86_64-linux-gnu/sane/libsane-pie.so.1'
[14:25:10.157978] [dll] load: dlopen()ing `/usr/lib/x86_64-linux-gnu/sane/libsane-pie.so.1'
[14:25:10.158134] [dll] init: initializing backend `pie'
[14:25:10.158454] [dll] init: backend `pie' is version 1.0.9
[14:25:10.158469] [dll] load: searching backend `niash' in `/usr/lib/x86_64-linux-gnu/sane:/usr/lib/sane:/usr/lib64/sane'
[14:25:10.158484] [dll] load: trying to load `/usr/lib/x86_64-linux-gnu/sane/libsane-niash.so.1'
[14:25:10.158509] [dll] load: dlopen()ing `/usr/lib/x86_64-linux-gnu/sane/libsane-niash.so.1'
[14:25:10.158630] [dll] init: initializing backend `niash'
[14:25:10.160298] [dll] init: backend `niash' is version 1.0.1
[14:25:10.160306] [dll] load: searching backend `nec' in `/usr/lib/x86_64-linux-gnu/sane:/usr/lib/sane:/usr/lib64/sane'
[14:25:10.160310] [dll] load: trying to load `/usr/lib/x86_64-linux-gnu/sane/libsane-nec.so.1'
[14:25:10.160317] [dll] load: dlopen()ing `/usr/lib/x86_64-linux-gnu/sane/libsane-nec.so.1'
[14:25:10.160382] [dll] init: initializing backend `nec'
[14:25:10.160447] [dll] init: backend `nec' is version 1.0.0
[14:25:10.160452] [dll] load: searching backend `mustek_usb2' in `/usr/lib/x86_64-linux-gnu/sane:/usr/lib/sane:/usr/lib64/sane'
[14:25:10.160456] [dll] load: trying to load `/usr/lib/x86_64-linux-gnu/sane/libsane-mustek_usb2.so.1'
[14:25:10.160462] [dll] load: dlopen()ing `/usr/lib/x86_64-linux-gnu/sane/libsane-mustek_usb2.so.1'
[14:25:10.160534] [dll] init: initializing backend `mustek_usb2'
[14:25:10.160546] [dll] init: backend `mustek_usb2' is version 1.0.10
[14:25:10.162178] [dll] load: searching backend `mustek_usb' in `/usr/lib/x86_64-linux-gnu/sane:/usr/lib/sane:/usr/lib64/sane'
[14:25:10.162185] [dll] load: trying to load `/usr/lib/x86_64-linux-gnu/sane/libsane-mustek_usb.so.1'
[14:25:10.162195] [dll] load: dlopen()ing `/usr/lib/x86_64-linux-gnu/sane/libsane-mustek_usb.so.1'
[14:25:10.162279] [dll] init: initializing backend `mustek_usb'
[14:25:10.163929] [dll] init: backend `mustek_usb' is version 1.0.18
[14:25:10.163937] [dll] load: searching backend `mustek' in `/usr/lib/x86_64-linux-gnu/sane:/usr/lib/sane:/usr/lib64/sane'
[14:25:10.163945] [dll] load: trying to load `/usr/lib/x86_64-linux-gnu/sane/libsane-mustek.so.1'
[14:25:10.163956] [dll] load: dlopen()ing `/usr/lib/x86_64-linux-gnu/sane/libsane-mustek.so.1'
[14:25:10.164052] [dll] init: initializing backend `mustek'
[14:25:10.164209] [dll] init: backend `mustek' is version 1.0.138
[14:25:10.164215] [dll] load: searching backend `microtek2' in `/usr/lib/x86_64-linux-gnu/sane:/usr/lib/sane:/usr/lib64/sane'
[14:25:10.164219] [dll] load: trying to load `/usr/lib/x86_64-linux-gnu/sane/libsane-microtek2.so.1'
[14:25:10.164225] [dll] load: dlopen()ing `/usr/lib/x86_64-linux-gnu/sane/libsane-microtek2.so.1'
[14:25:10.164273] [dll] init: initializing backend `microtek2'
[14:25:10.164355] [dll] init: backend `microtek2' is version 1.0.0
[14:25:10.164362] [dll] load: searching backend `microtek' in `/usr/lib/x86_64-linux-gnu/sane:/usr/lib/sane:/usr/lib64/sane'
[14:25:10.164366] [dll] load: trying to load `/usr/lib/x86_64-linux-gnu/sane/libsane-microtek.so.1'
[14:25:10.164374] [dll] load: dlopen()ing `/usr/lib/x86_64-linux-gnu/sane/libsane-microtek.so.1'
[14:25:10.164423] [dll] init: initializing backend `microtek'
[14:25:10.164506] [dll] init: backend `microtek' is version 1.0.0
[14:25:10.164512] [dll] load: searching backend `matsushita' in `/usr/lib/x86_64-linux-gnu/sane:/usr/lib/sane:/usr/lib64/sane'
[14:25:10.164519] [dll] load: trying to load `/usr/lib/x86_64-linux-gnu/sane/libsane-matsushita.so.1'
[14:25:10.164527] [dll] load: dlopen()ing `/usr/lib/x86_64-linux-gnu/sane/libsane-matsushita.so.1'
[14:25:10.164572] [dll] init: initializing backend `matsushita'
[14:25:10.164730] [dll] init: backend `matsushita' is version 1.0.7
[14:25:10.164736] [dll] load: searching backend `magicolor' in `/usr/lib/x86_64-linux-gnu/sane:/usr/lib/sane:/usr/lib64/sane'
[14:25:10.164743] [dll] load: trying to load `/usr/lib/x86_64-linux-gnu/sane/libsane-magicolor.so.1'
[14:25:10.164752] [dll] load: dlopen()ing `/usr/lib/x86_64-linux-gnu/sane/libsane-magicolor.so.1'
[14:25:10.165161] [dll] init: initializing backend `magicolor'
[14:25:10.166955] [dll] init: backend `magicolor' is version 1.0.1
[14:25:11.668829] [dll] load: searching backend `ma1509' in `/usr/lib/x86_64-linux-gnu/sane:/usr/lib/sane:/usr/lib64/sane'
[14:25:11.668872] [dll] load: trying to load `/usr/lib/x86_64-linux-gnu/sane/libsane-ma1509.so.1'
[14:25:11.668897] [dll] load: dlopen()ing `/usr/lib/x86_64-linux-gnu/sane/libsane-ma1509.so.1'
[14:25:11.669291] [dll] init: initializing backend `ma1509'
[14:25:11.673719] [dll] init: backend `ma1509' is version 1.0.3
[14:25:11.673733] [dll] load: searching backend `lexmark' in `/usr/lib/x86_64-linux-gnu/sane:/usr/lib/sane:/usr/lib64/sane'
[14:25:11.673736] [dll] load: trying to load `/usr/lib/x86_64-linux-gnu/sane/libsane-lexmark.so.1'
[14:25:11.673753] [dll] load: dlopen()ing `/usr/lib/x86_64-linux-gnu/sane/libsane-lexmark.so.1'
[14:25:11.673875] [dll] init: initializing backend `lexmark'
[14:25:11.675623] [dll] init: backend `lexmark' is version 1.0.32
[14:25:11.675658] [dll] load: searching backend `leo' in `/usr/lib/x86_64-linux-gnu/sane:/usr/lib/sane:/usr/lib64/sane'
[14:25:11.675662] [dll] load: trying to load `/usr/lib/x86_64-linux-gnu/sane/libsane-leo.so.1'
[14:25:11.675667] [dll] load: dlopen()ing `/usr/lib/x86_64-linux-gnu/sane/libsane-leo.so.1'
[14:25:11.675725] [dll] init: initializing backend `leo'
[14:25:11.675847] [dll] init: backend `leo' is version 1.0.11
[14:25:11.675854] [dll] load: searching backend `kvs40xx' in `/usr/lib/x86_64-linux-gnu/sane:/usr/lib/sane:/usr/lib64/sane'
[14:25:11.675860] [dll] load: trying to load `/usr/lib/x86_64-linux-gnu/sane/libsane-kvs40xx.so.1'
[14:25:11.675869] [dll] load: dlopen()ing `/usr/lib/x86_64-linux-gnu/sane/libsane-kvs40xx.so.1'
[14:25:11.675947] [dll] init: initializing backend `kvs40xx'
[14:25:11.677789] [dll] init: backend `kvs40xx' is version 1.0.1
[14:25:11.677880] [dll] load: searching backend `kvs20xx' in `/usr/lib/x86_64-linux-gnu/sane:/usr/lib/sane:/usr/lib64/sane'
[14:25:11.677887] [dll] load: trying to load `/usr/lib/x86_64-linux-gnu/sane/libsane-kvs20xx.so.1'
[14:25:11.677895] [dll] load: dlopen()ing `/usr/lib/x86_64-linux-gnu/sane/libsane-kvs20xx.so.1'
[14:25:11.677991] [dll] init: initializing backend `kvs20xx'
[14:25:11.679679] [dll] init: backend `kvs20xx' is version 1.0.2
[14:25:11.679876] [dll] load: searching backend `kvs1025' in `/usr/lib/x86_64-linux-gnu/sane:/usr/lib/sane:/usr/lib64/sane'
[14:25:11.679884] [dll] load: trying to load `/usr/lib/x86_64-linux-gnu/sane/libsane-kvs1025.so.1'
[14:25:11.679893] [dll] load: dlopen()ing `/usr/lib/x86_64-linux-gnu/sane/libsane-kvs1025.so.1'
[14:25:11.680009] [dll] init: initializing backend `kvs1025'
[14:25:11.682356] [dll] init: backend `kvs1025' is version 1.0.5
[14:25:11.682370] [dll] load: searching backend `kodakaio' in `/usr/lib/x86_64-linux-gnu/sane:/usr/lib/sane:/usr/lib64/sane'
[14:25:11.682376] [dll] load: trying to load `/usr/lib/x86_64-linux-gnu/sane/libsane-kodakaio.so.1'
[14:25:11.682385] [dll] load: dlopen()ing `/usr/lib/x86_64-linux-gnu/sane/libsane-kodakaio.so.1'
[14:25:11.682950] [dll] init: initializing backend `kodakaio'
[14:25:11.685366] [dll] init: backend `kodakaio' is version 1.0.3
[14:25:13.452336] [dll] load: searching backend `kodak' in `/usr/lib/x86_64-linux-gnu/sane:/usr/lib/sane:/usr/lib64/sane'
[14:25:13.452362] [dll] load: trying to load `/usr/lib/x86_64-linux-gnu/sane/libsane-kodak.so.1'
[14:25:13.452380] [dll] load: dlopen()ing `/usr/lib/x86_64-linux-gnu/sane/libsane-kodak.so.1'
[14:25:13.452516] [dll] init: initializing backend `kodak'
[14:25:13.452529] [dll] init: backend `kodak' is version 1.0.7
[14:25:13.452618] [dll] load: searching backend `ibm' in `/usr/lib/x86_64-linux-gnu/sane:/usr/lib/sane:/usr/lib64/sane'
[14:25:13.452627] [dll] load: trying to load `/usr/lib/x86_64-linux-gnu/sane/libsane-ibm.so.1'
[14:25:13.452637] [dll] load: dlopen()ing `/usr/lib/x86_64-linux-gnu/sane/libsane-ibm.so.1'
[14:25:13.452710] [dll] init: initializing backend `ibm'
[14:25:13.452805] [dll] init: backend `ibm' is version 1.0.0
[14:25:13.452815] [dll] load: searching backend `hs2p' in `/usr/lib/x86_64-linux-gnu/sane:/usr/lib/sane:/usr/lib64/sane'
[14:25:13.452824] [dll] load: trying to load `/usr/lib/x86_64-linux-gnu/sane/libsane-hs2p.so.1'
[14:25:13.452834] [dll] load: dlopen()ing `/usr/lib/x86_64-linux-gnu/sane/libsane-hs2p.so.1'
[14:25:13.452902] [dll] init: initializing backend `hs2p'
[14:25:13.453023] [dll] init: backend `hs2p' is version 1.0.0
[14:25:13.453033] [dll] load: searching backend `hpsj5s' in `/usr/lib/x86_64-linux-gnu/sane:/usr/lib/sane:/usr/lib64/sane'
[14:25:13.453039] [dll] load: trying to load `/usr/lib/x86_64-linux-gnu/sane/libsane-hpsj5s.so.1'
[14:25:13.453047] [dll] load: dlopen()ing `/usr/lib/x86_64-linux-gnu/sane/libsane-hpsj5s.so.1'
[14:25:13.453121] [dll] init: initializing backend `hpsj5s'
[14:25:13.453151] [dll] init: backend `hpsj5s' is version 1.0.3
[14:25:13.453159] [dll] load: searching backend `hpljm1005' in `/usr/lib/x86_64-linux-gnu/sane:/usr/lib/sane:/usr/lib64/sane'
[14:25:13.453164] [dll] load: trying to load `/usr/lib/x86_64-linux-gnu/sane/libsane-hpljm1005.so.1'
[14:25:13.453173] [dll] load: dlopen()ing `/usr/lib/x86_64-linux-gnu/sane/libsane-hpljm1005.so.1'
[14:25:13.453272] [dll] init: initializing backend `hpljm1005'
[14:25:13.456124] [dll] init: backend `hpljm1005' is version 1.0.1
[14:25:13.456139] [dll] load: searching backend `hp5590' in `/usr/lib/x86_64-linux-gnu/sane:/usr/lib/sane:/usr/lib64/sane'
[14:25:13.456145] [dll] load: trying to load `/usr/lib/x86_64-linux-gnu/sane/libsane-hp5590.so.1'
[14:25:13.456154] [dll] load: dlopen()ing `/usr/lib/x86_64-linux-gnu/sane/libsane-hp5590.so.1'
[14:25:13.456308] [dll] init: initializing backend `hp5590'
[14:25:13.459042] [dll] init: backend `hp5590' is version 1.0.8
[14:25:13.459056] [dll] load: searching backend `hp5400' in `/usr/lib/x86_64-linux-gnu/sane:/usr/lib/sane:/usr/lib64/sane'
[14:25:13.459062] [dll] load: trying to load `/usr/lib/x86_64-linux-gnu/sane/libsane-hp5400.so.1'
[14:25:13.459071] [dll] load: dlopen()ing `/usr/lib/x86_64-linux-gnu/sane/libsane-hp5400.so.1'
[14:25:13.459212] [dll] init: initializing backend `hp5400'
[14:25:13.461983] [dll] init: backend `hp5400' is version 1.0.3
[14:25:13.462000] [dll] load: searching backend `hp4200' in `/usr/lib/x86_64-linux-gnu/sane:/usr/lib/sane:/usr/lib64/sane'
[14:25:13.462011] [dll] load: trying to load `/usr/lib/x86_64-linux-gnu/sane/libsane-hp4200.so.1'
[14:25:13.462021] [dll] load: dlopen()ing `/usr/lib/x86_64-linux-gnu/sane/libsane-hp4200.so.1'
[14:25:13.462174] [dll] init: initializing backend `hp4200'
[14:25:13.465250] [dll] init: backend `hp4200' is version 1.0.0
[14:25:13.465267] [dll] load: searching backend `hp3900' in `/usr/lib/x86_64-linux-gnu/sane:/usr/lib/sane:/usr/lib64/sane'
[14:25:13.465276] [dll] load: trying to load `/usr/lib/x86_64-linux-gnu/sane/libsane-hp3900.so.1'
[14:25:13.465287] [dll] load: dlopen()ing `/usr/lib/x86_64-linux-gnu/sane/libsane-hp3900.so.1'
[14:25:13.465702] [dll] init: initializing backend `hp3900'
[14:25:13.468992] [dll] init: backend `hp3900' is version 1.0.0
[14:25:13.469009] [dll] load: searching backend `hp3500' in `/usr/lib/x86_64-linux-gnu/sane:/usr/lib/sane:/usr/lib64/sane'
[14:25:13.469019] [dll] load: trying to load `/usr/lib/x86_64-linux-gnu/sane/libsane-hp3500.so.1'
[14:25:13.469031] [dll] load: dlopen()ing `/usr/lib/x86_64-linux-gnu/sane/libsane-hp3500.so.1'
[14:25:13.469213] [dll] init: initializing backend `hp3500'
[14:25:13.472126] [dll] init: backend `hp3500' is version 1.0.0
[14:25:13.472143] [dll] load: searching backend `hp' in `/usr/lib/x86_64-linux-gnu/sane:/usr/lib/sane:/usr/lib64/sane'
[14:25:13.472149] [dll] load: trying to load `/usr/lib/x86_64-linux-gnu/sane/libsane-hp.so.1'
[14:25:13.472158] [dll] load: dlopen()ing `/usr/lib/x86_64-linux-gnu/sane/libsane-hp.so.1'
[14:25:13.472342] [dll] init: initializing backend `hp'
[14:25:13.472365] [dll] init: backend `hp' is version 1.0.8
[14:25:13.475226] [dll] load: searching backend `gt68xx' in `/usr/lib/x86_64-linux-gnu/sane:/usr/lib/sane:/usr/lib64/sane'
[14:25:13.475238] [dll] load: trying to load `/usr/lib/x86_64-linux-gnu/sane/libsane-gt68xx.so.1'
[14:25:13.475246] [dll] load: dlopen()ing `/usr/lib/x86_64-linux-gnu/sane/libsane-gt68xx.so.1'
[14:25:13.475408] [dll] init: initializing backend `gt68xx'
[14:25:13.478174] [dll] init: backend `gt68xx' is version 1.0.84
[14:25:13.478280] [dll] load: searching backend `genesys' in `/usr/lib/x86_64-linux-gnu/sane:/usr/lib/sane:/usr/lib64/sane'
[14:25:13.478291] [dll] load: trying to load `/usr/lib/x86_64-linux-gnu/sane/libsane-genesys.so.1'
[14:25:13.478302] [dll] load: dlopen()ing `/usr/lib/x86_64-linux-gnu/sane/libsane-genesys.so.1'
[14:25:13.478709] [dll] init: initializing backend `genesys'
[14:25:13.482514] [dll] init: backend `genesys' is version 1.0.0
[14:25:13.482616] [dll] load: searching backend `fujitsu' in `/usr/lib/x86_64-linux-gnu/sane:/usr/lib/sane:/usr/lib64/sane'
[14:25:13.482628] [dll] load: trying to load `/usr/lib/x86_64-linux-gnu/sane/libsane-fujitsu.so.1'
[14:25:13.482638] [dll] load: dlopen()ing `/usr/lib/x86_64-linux-gnu/sane/libsane-fujitsu.so.1'
[14:25:13.482828] [dll] init: initializing backend `fujitsu'
[14:25:13.482845] [dll] init: backend `fujitsu' is version 1.0.134
[14:25:13.486571] [dll] load: searching backend `escl' in `/usr/lib/x86_64-linux-gnu/sane:/usr/lib/sane:/usr/lib64/sane'
[14:25:13.486587] [dll] load: trying to load `/usr/lib/x86_64-linux-gnu/sane/libsane-escl.so.1'
[14:25:13.486597] [dll] load: dlopen()ing `/usr/lib/x86_64-linux-gnu/sane/libsane-escl.so.1'
[14:25:13.492396] [dll] init: initializing backend `escl'
[14:25:13.492485] [dll] init: backend `escl' is version 1.0.0
[14:25:14.495584] [dll] load: searching backend `epsonds' in `/usr/lib/x86_64-linux-gnu/sane:/usr/lib/sane:/usr/lib64/sane'
[14:25:14.495619] [dll] load: trying to load `/usr/lib/x86_64-linux-gnu/sane/libsane-epsonds.so.1'
[14:25:14.495641] [dll] load: dlopen()ing `/usr/lib/x86_64-linux-gnu/sane/libsane-epsonds.so.1'
[14:25:14.495901] [dll] init: initializing backend `epsonds'
[14:25:14.497978] [dll] init: backend `epsonds' is version 1.0.0
[14:25:14.498040] [dll] load: searching backend `epson2' in `/usr/lib/x86_64-linux-gnu/sane:/usr/lib/sane:/usr/lib64/sane'
[14:25:14.498047] [dll] load: trying to load `/usr/lib/x86_64-linux-gnu/sane/libsane-epson2.so.1'
[14:25:14.498057] [dll] load: dlopen()ing `/usr/lib/x86_64-linux-gnu/sane/libsane-epson2.so.1'
[14:25:14.498218] [dll] init: initializing backend `epson2'
[14:25:14.500032] [dll] init: backend `epson2' is version 1.0.124
[14:25:15.501291] [dll] load: searching backend `epjitsu' in `/usr/lib/x86_64-linux-gnu/sane:/usr/lib/sane:/usr/lib64/sane'
[14:25:15.501333] [dll] load: trying to load `/usr/lib/x86_64-linux-gnu/sane/libsane-epjitsu.so.1'
[14:25:15.501357] [dll] load: dlopen()ing `/usr/lib/x86_64-linux-gnu/sane/libsane-epjitsu.so.1'
[14:25:15.501696] [dll] init: initializing backend `epjitsu'
[14:25:15.501731] [dll] init: backend `epjitsu' is version 1.0.31
[14:25:15.505119] [dll] load: searching backend `dmc' in `/usr/lib/x86_64-linux-gnu/sane:/usr/lib/sane:/usr/lib64/sane'
[14:25:15.505133] [dll] load: trying to load `/usr/lib/x86_64-linux-gnu/sane/libsane-dmc.so.1'
[14:25:15.505141] [dll] load: dlopen()ing `/usr/lib/x86_64-linux-gnu/sane/libsane-dmc.so.1'
[14:25:15.505241] [dll] init: initializing backend `dmc'
[14:25:15.505311] [dll] init: backend `dmc' is version 1.0.0
[14:25:15.505318] [dll] load: searching backend `dell1600n_net' in `/usr/lib/x86_64-linux-gnu/sane:/usr/lib/sane:/usr/lib64/sane'
[14:25:15.505324] [dll] load: trying to load `/usr/lib/x86_64-linux-gnu/sane/libsane-dell1600n_net.so.1'
[14:25:15.505331] [dll] load: dlopen()ing `/usr/lib/x86_64-linux-gnu/sane/libsane-dell1600n_net.so.1'
[14:25:15.505405] [dll] init: initializing backend `dell1600n_net'
[14:25:15.505411] [dll] init: backend `dell1600n_net' is version 1.0.0
[14:25:15.805790] [dll] load: searching backend `coolscan3' in `/usr/lib/x86_64-linux-gnu/sane:/usr/lib/sane:/usr/lib64/sane'
[14:25:15.805811] [dll] load: trying to load `/usr/lib/x86_64-linux-gnu/sane/libsane-coolscan3.so.1'
[14:25:15.805825] [dll] load: dlopen()ing `/usr/lib/x86_64-linux-gnu/sane/libsane-coolscan3.so.1'
[14:25:15.805962] [dll] init: initializing backend `coolscan3'
[14:25:15.807913] [dll] init: backend `coolscan3' is version 1.0.0
[14:25:15.807998] [dll] load: searching backend `coolscan' in `/usr/lib/x86_64-linux-gnu/sane:/usr/lib/sane:/usr/lib64/sane'
[14:25:15.808008] [dll] load: trying to load `/usr/lib/x86_64-linux-gnu/sane/libsane-coolscan.so.1'
[14:25:15.808018] [dll] load: dlopen()ing `/usr/lib/x86_64-linux-gnu/sane/libsane-coolscan.so.1'
[14:25:15.808155] [dll] init: initializing backend `coolscan'
[14:25:15.808251] [dll] init: backend `coolscan' is version 1.0.0
[14:25:15.808259] [dll] load: searching backend `cardscan' in `/usr/lib/x86_64-linux-gnu/sane:/usr/lib/sane:/usr/lib64/sane'
[14:25:15.808267] [dll] load: trying to load `/usr/lib/x86_64-linux-gnu/sane/libsane-cardscan.so.1'
[14:25:15.808276] [dll] load: dlopen()ing `/usr/lib/x86_64-linux-gnu/sane/libsane-cardscan.so.1'
[14:25:15.808366] [dll] init: initializing backend `cardscan'
[14:25:15.810243] [dll] init: backend `cardscan' is version 1.0.3
[14:25:15.810290] [dll] load: searching backend `canon_dr' in `/usr/lib/x86_64-linux-gnu/sane:/usr/lib/sane:/usr/lib64/sane'
[14:25:15.810296] [dll] load: trying to load `/usr/lib/x86_64-linux-gnu/sane/libsane-canon_dr.so.1'
[14:25:15.810306] [dll] load: dlopen()ing `/usr/lib/x86_64-linux-gnu/sane/libsane-canon_dr.so.1'
[14:25:15.810444] [dll] init: initializing backend `canon_dr'
[14:25:15.810457] [dll] init: backend `canon_dr' is version 1.0.58
[14:25:15.812382] [dll] load: searching backend `canon630u' in `/usr/lib/x86_64-linux-gnu/sane:/usr/lib/sane:/usr/lib64/sane'
[14:25:15.812394] [dll] load: trying to load `/usr/lib/x86_64-linux-gnu/sane/libsane-canon630u.so.1'
[14:25:15.812406] [dll] load: dlopen()ing `/usr/lib/x86_64-linux-gnu/sane/libsane-canon630u.so.1'
[14:25:15.812530] [dll] init: initializing backend `canon630u'
[14:25:15.814498] [dll] init: backend `canon630u' is version 1.0.1
[14:25:15.814512] [dll] load: searching backend `canon' in `/usr/lib/x86_64-linux-gnu/sane:/usr/lib/sane:/usr/lib64/sane'
[14:25:15.814522] [dll] load: trying to load `/usr/lib/x86_64-linux-gnu/sane/libsane-canon.so.1'
[14:25:15.814531] [dll] load: dlopen()ing `/usr/lib/x86_64-linux-gnu/sane/libsane-canon.so.1'
[14:25:15.814629] [dll] init: initializing backend `canon'
[14:25:15.814690] [dll] init: backend `canon' is version 1.0.0
[14:25:15.814698] [dll] load: searching backend `bh' in `/usr/lib/x86_64-linux-gnu/sane:/usr/lib/sane:/usr/lib64/sane'
[14:25:15.814704] [dll] load: trying to load `/usr/lib/x86_64-linux-gnu/sane/libsane-bh.so.1'
[14:25:15.814714] [dll] load: dlopen()ing `/usr/lib/x86_64-linux-gnu/sane/libsane-bh.so.1'
[14:25:15.814770] [dll] init: initializing backend `bh'
[14:25:15.814859] [dll] init: backend `bh' is version 1.0.4
[14:25:15.814865] [dll] load: searching backend `avision' in `/usr/lib/x86_64-linux-gnu/sane:/usr/lib/sane:/usr/lib64/sane'
[14:25:15.814872] [dll] load: trying to load `/usr/lib/x86_64-linux-gnu/sane/libsane-avision.so.1'
[14:25:15.814881] [dll] load: dlopen()ing `/usr/lib/x86_64-linux-gnu/sane/libsane-avision.so.1'
[14:25:15.814979] [dll] init: initializing backend `avision'
[14:25:15.818887] [dll] init: backend `avision' is version 1.0.297
[14:25:15.820824] [dll] load: searching backend `as6e' in `/usr/lib/x86_64-linux-gnu/sane:/usr/lib/sane:/usr/lib64/sane'
[14:25:15.820843] [dll] load: trying to load `/usr/lib/x86_64-linux-gnu/sane/libsane-as6e.so.1'
[14:25:15.820852] [dll] load: dlopen()ing `/usr/lib/x86_64-linux-gnu/sane/libsane-as6e.so.1'
[14:25:15.820965] [dll] init: initializing backend `as6e'
[14:25:15.820996] [dll] load: searching backend `artec_eplus48u' in `/usr/lib/x86_64-linux-gnu/sane:/usr/lib/sane:/usr/lib64/sane'
[14:25:15.821001] [dll] load: trying to load `/usr/lib/x86_64-linux-gnu/sane/libsane-artec_eplus48u.so.1'
[14:25:15.821010] [dll] load: dlopen()ing `/usr/lib/x86_64-linux-gnu/sane/libsane-artec_eplus48u.so.1'
[14:25:15.821121] [dll] init: initializing backend `artec_eplus48u'
[14:25:15.823427] [dll] init: backend `artec_eplus48u' is version 1.0.0
[14:25:15.823442] [dll] load: searching backend `artec' in `/usr/lib/x86_64-linux-gnu/sane:/usr/lib/sane:/usr/lib64/sane'
[14:25:15.823451] [dll] load: trying to load `/usr/lib/x86_64-linux-gnu/sane/libsane-artec.so.1'
[14:25:15.823460] [dll] load: dlopen()ing `/usr/lib/x86_64-linux-gnu/sane/libsane-artec.so.1'
[14:25:15.823558] [dll] init: initializing backend `artec'
[14:25:15.823658] [dll] init: backend `artec' is version 1.0.0
[14:25:15.823665] [dll] load: searching backend `apple' in `/usr/lib/x86_64-linux-gnu/sane:/usr/lib/sane:/usr/lib64/sane'
[14:25:15.823672] [dll] load: trying to load `/usr/lib/x86_64-linux-gnu/sane/libsane-apple.so.1'
[14:25:15.823683] [dll] load: dlopen()ing `/usr/lib/x86_64-linux-gnu/sane/libsane-apple.so.1'
[14:25:15.823745] [dll] init: initializing backend `apple'
[14:25:15.823828] [dll] init: backend `apple' is version 1.0.0
[14:25:15.823836] [dll] load: searching backend `agfafocus' in `/usr/lib/x86_64-linux-gnu/sane:/usr/lib/sane:/usr/lib64/sane'
[14:25:15.823843] [dll] load: trying to load `/usr/lib/x86_64-linux-gnu/sane/libsane-agfafocus.so.1'
[14:25:15.823852] [dll] load: dlopen()ing `/usr/lib/x86_64-linux-gnu/sane/libsane-agfafocus.so.1'
[14:25:15.823911] [dll] init: initializing backend `agfafocus'
[14:25:15.823976] [dll] init: backend `agfafocus' is version 1.0.0
[14:25:15.823982] [dll] load: searching backend `abaton' in `/usr/lib/x86_64-linux-gnu/sane:/usr/lib/sane:/usr/lib64/sane'
[14:25:15.823988] [dll] load: trying to load `/usr/lib/x86_64-linux-gnu/sane/libsane-abaton.so.1'
[14:25:15.823997] [dll] load: dlopen()ing `/usr/lib/x86_64-linux-gnu/sane/libsane-abaton.so.1'
[14:25:15.824051] [dll] init: initializing backend `abaton'
[14:25:15.824137] [dll] init: backend `abaton' is version 1.0.0
[14:25:15.824142] [dll] load: searching backend `net' in `/usr/lib/x86_64-linux-gnu/sane:/usr/lib/sane:/usr/lib64/sane'
[14:25:15.824147] [dll] load: trying to load `/usr/lib/x86_64-linux-gnu/sane/libsane-net.so.1'
[14:25:15.824156] [dll] load: dlopen()ing `/usr/lib/x86_64-linux-gnu/sane/libsane-net.so.1'
[14:25:15.824243] [dll] init: initializing backend `net'
[14:25:15.825561] [dll] init: backend `net' is version 1.0.29
[14:25:15.825584] [dll] load: searching backend `hpaio' in `/usr/lib/x86_64-linux-gnu/sane:/usr/lib/sane:/usr/lib64/sane'
[14:25:15.825592] [dll] load: trying to load `/usr/lib/x86_64-linux-gnu/sane/libsane-hpaio.so.1'
[14:25:15.825603] [dll] load: dlopen()ing `/usr/lib/x86_64-linux-gnu/sane/libsane-hpaio.so.1'
[14:25:15.826226] [dll] init: initializing backend `hpaio'
[14:25:15.826818] [dll] init: backend `hpaio' is version 1.0.0
[14:25:17.226565] [dll] sane_get_devices: found 1 devices
device `pixma:04A91802' is a CANON Canon PIXMA TS5000 Series multi-function peripheral
[14:25:17.226661] [dll] sane_exit: exiting
[14:25:17.226671] [dll] sane_exit: calling backend `xerox_mfp's exit function
[14:25:17.226769] [dll] sane_exit: calling backend `umax1220u's exit function
[14:25:17.226814] [dll] sane_exit: calling backend `umax's exit function
[14:25:17.226853] [dll] sane_exit: calling backend `u12's exit function
[14:25:17.226884] [dll] sane_exit: calling backend `teco3's exit function
[14:25:17.226912] [dll] sane_exit: calling backend `teco2's exit function
[14:25:17.226937] [dll] sane_exit: calling backend `teco1's exit function
[14:25:17.226963] [dll] sane_exit: calling backend `tamarack's exit function
[14:25:17.226989] [dll] sane_exit: calling backend `sp15c's exit function
[14:25:17.227014] [dll] sane_exit: calling backend `snapscan's exit function
[14:25:17.227045] [dll] sane_exit: calling backend `sm3840's exit function
[14:25:17.227073] [dll] sane_exit: calling backend `sm3600's exit function
[14:25:17.227102] [dll] sane_exit: calling backend `sharp's exit function
[14:25:17.227127] [dll] sane_exit: calling backend `sceptre's exit function
[14:25:17.227151] [dll] sane_exit: calling backend `s9036's exit function
[14:25:17.227176] [dll] sane_exit: calling backend `rts8891's exit function
[14:25:17.227205] [dll] sane_exit: calling backend `ricoh2's exit function
[14:25:17.227250] [dll] sane_exit: calling backend `ricoh's exit function
[14:25:17.227276] [dll] sane_exit: calling backend `qcam's exit function
[14:25:17.227299] [dll] sane_exit: calling backend `plustek's exit function
[14:25:17.227335] [dll] sane_exit: calling backend `pixma's exit function
[14:25:17.227370] [dll] sane_exit: calling backend `pieusb's exit function
[14:25:17.227403] [dll] sane_exit: calling backend `pie's exit function
[14:25:17.227428] [dll] sane_exit: calling backend `niash's exit function
[14:25:17.227454] [dll] sane_exit: calling backend `nec's exit function
[14:25:17.227481] [dll] sane_exit: calling backend `mustek_usb2's exit function
[14:25:17.227511] [dll] sane_exit: calling backend `mustek_usb's exit function
[14:25:17.227545] [dll] sane_exit: calling backend `mustek's exit function
[14:25:17.227576] [dll] sane_exit: calling backend `microtek2's exit function
[14:25:17.227605] [dll] sane_exit: calling backend `microtek's exit function
[14:25:17.227633] [dll] sane_exit: calling backend `matsushita's exit function
[14:25:17.227657] [dll] sane_exit: calling backend `magicolor's exit function
[14:25:17.227685] [dll] sane_exit: calling backend `ma1509's exit function
[14:25:17.227715] [dll] sane_exit: calling backend `lexmark's exit function
[14:25:17.227755] [dll] sane_exit: calling backend `leo's exit function
[14:25:17.227780] [dll] sane_exit: calling backend `kvs40xx's exit function
[14:25:17.227809] [dll] sane_exit: calling backend `kvs20xx's exit function
[14:25:17.227841] [dll] sane_exit: calling backend `kvs1025's exit function
[14:25:17.227874] [dll] sane_exit: calling backend `kodakaio's exit function
[14:25:17.227910] [dll] sane_exit: calling backend `kodak's exit function
[14:25:17.227943] [dll] sane_exit: calling backend `ibm's exit function
[14:25:17.227970] [dll] sane_exit: calling backend `hs2p's exit function
[14:25:17.228001] [dll] sane_exit: calling backend `hpsj5s's exit function
[14:25:17.228038] [dll] sane_exit: calling backend `hpljm1005's exit function
[14:25:17.228067] [dll] sane_exit: calling backend `hp5590's exit function
[14:25:17.228098] [dll] sane_exit: calling backend `hp5400's exit function
[14:25:17.228127] [dll] sane_exit: calling backend `hp4200's exit function
[14:25:17.228154] [dll] sane_exit: calling backend `hp3900's exit function
[14:25:17.228189] [dll] sane_exit: calling backend `hp3500's exit function
[14:25:17.228216] [dll] sane_exit: calling backend `hp's exit function
[14:25:17.228246] [dll] sane_exit: calling backend `gt68xx's exit function
[14:25:17.228285] [dll] sane_exit: calling backend `genesys's exit function
[14:25:17.228418] [dll] sane_exit: calling backend `fujitsu's exit function
[14:25:17.228451] [dll] sane_exit: calling backend `escl's exit function
[14:25:17.228808] [dll] sane_exit: calling backend `epsonds's exit function
[14:25:17.228850] [dll] sane_exit: calling backend `epson2's exit function
[14:25:17.228885] [dll] sane_exit: calling backend `epjitsu's exit function
[14:25:17.228918] [dll] sane_exit: calling backend `dmc's exit function
[14:25:17.228947] [dll] sane_exit: calling backend `dell1600n_net's exit function
[14:25:17.229005] [dll] sane_exit: calling backend `coolscan3's exit function
[14:25:17.229033] [dll] sane_exit: calling backend `coolscan's exit function
[14:25:17.229058] [dll] sane_exit: calling backend `cardscan's exit function
[14:25:17.229082] [dll] sane_exit: calling backend `canon_dr's exit function
[14:25:17.229110] [dll] sane_exit: calling backend `canon630u's exit function
[14:25:17.229133] [dll] sane_exit: calling backend `canon's exit function
[14:25:17.229155] [dll] sane_exit: calling backend `bh's exit function
[14:25:17.229176] [dll] sane_exit: calling backend `avision's exit function
[14:25:17.229213] [dll] sane_exit: calling backend `artec_eplus48u's exit function
[14:25:17.229236] [dll] sane_exit: calling backend `artec's exit function
[14:25:17.229259] [dll] sane_exit: calling backend `apple's exit function
[14:25:17.229279] [dll] sane_exit: calling backend `agfafocus's exit function
[14:25:17.229304] [dll] sane_exit: calling backend `abaton's exit function
[14:25:17.229329] [dll] sane_exit: calling backend `net's exit function
[14:25:17.229657] [dll] sane_exit: calling backend `hpaio's exit function
[14:25:17.230228] [dll] sane_exit: finished
~$ dpkg -l *sane* | grep ii
ii libsane:amd64 1.0.29-0ubuntu5.2 amd64 API library for scanners
ii libsane-common 1.0.29-0ubuntu5.2 all API library for scanners -- documentation and support files
ii libsane-hpaio:amd64 3.20.3+dfsg0-2 amd64 HP SANE backend for multi-function peripherals
ii sane-utils 1.0.29-0ubuntu5.2 amd64 API library for scanners -- utilities
~$ dpkg -l | egrep 'scangear*|cnij*'
Bei der Abfrage zu Canon, gab es kein Ergebnis.
~$ systemctl --no-pager status sane* cups*
Active: active (running) since Fri 2022-05-20 13:16:34 CEST; 1h 15min ago
● cups.path
Docs: man:cupsd(8)
Memory: 9.3M
Mai 20 14:16:38 doenitz-LIFEBOOK-A3510 /hpfax[8103]: [8103]: error: Failed t…lip
Memory: 3.8M
Mai 20 13:16:34 doenitz-LIFEBOOK-A3510 systemd[1]: Started Make remote CUPS …ly.
~$ dmesg | grep printer
[ 2.195606] usblp 3-2:1.1: usblp0: USB Bidirectional printer dev 3 if 1 alt 0 proto 2 vid 0x04A9 pid 0x1802
[ 2518.379498] usblp 3-2:1.1: usblp0: USB Bidirectional printer dev 3 if 1 alt 0 proto 2 vid 0x04A9 pid 0x1802
Die, die einen erkennbaren Bezug zu anderen Marken haben, habe ich weggelassen. Ich hoffe, es ist aufschlussreiches dabei. Ich selber kann dem nicht wirklich viel entnehmen.
