epsonscan2 für Perfection V39 anstatt zu scannen stürzt sane ab
1ubuntufan1
6. Oktober 2020
Liebe Ubuntuuser,
Epson veröffentlicht Treiber für Epson Perfection V39 auf ihrer Internetseite, in neuester Version (02-2021) ist es epsonscan2-bundle 6.6.2.2.x86_64.deb. Installiert mit Ubuntu Software. Das Programm sane lässt sich starten, der Scanner bekommt dann über USB Strom, man kann den Vorschau scannen. Aber beim scan stürzt sane ab. Das Epson-Programm Epson Scan 2 gestartet mit dem icon im Menu findet den scanner nicht.
Im Terminal hatte ich die Fehlernachricht, dass libqt5widgets5 fehlt. Habe über synaptic libqt5widgets5 nachinstalliert. Hier die Terminalausgabe:
andreas@andreas-Swift-SF314-54:~$ scanimage -n
Output format is not set, using pnm as a default.
andreas@andreas-Swift-SF314-54:~$ sudo sane-find-scanner -p
[sudo] Mot de passe de andreas :
  # sane-find-scanner will now attempt to detect your scanner. If the
  # result is different from what you expected, first make sure your
  # scanner is powered up and properly connected to your computer.
  # No SCSI scanners found. If you expected something different, make sure that
  # you have loaded a kernel SCSI driver for your SCSI adapter.
found USB scanner (vendor=0x1c7a [EgisTec], product=0x0570 [EgisTec Touch Fingerprint Sensor]) at libusb:001:004
found USB scanner (vendor=0x04b8 [EPSON], product=0x013d) at libusb:001:008
  # Your USB scanner was (probably) detected. It may or may not be supported by
  # SANE. Try scanimage -L and read the backend's manpage.
  # No Mustek parallel port scanners found. If you expected something
  # different, make sure the scanner is correctly connected to your computer
  # and you have appropriate access rights.
  # Most Scanners connected to the parallel port or other proprietary ports
  # can't be detected by this program.
andreas@andreas-Swift-SF314-54:~$ sudo scanimage -L
No scanners were identified. If you were expecting something different,
check that the scanner is plugged in, turned on and detected by the
sane-find-scanner tool (if appropriate). Please read the documentation
which came with this software (README, FAQ, manpages).
Was kann ich tun, um den scanner (am besten mit sane) zum Laufen zu bringen? Vielen Dank im Voraus für die Unterstützung.
