Dmesg Hardware Error - CPU Defekt?
Bolle
23. Februar 2006
Hallo
Folgende Ausgabe zeigt Dmesg beim booten von Live USB bzw im Terminal. Es handelt sich um ein Notebook mit i5-430M CPU
[    0.076024] mce: [Hardware Error]: CPU 3: Machine Check: 0 Bank 5: cc4001c000100151
[    0.076030] mce: [Hardware Error]: TSC 45582fb16 ADDR 11afc2d00 MISC 69b2
[    0.076039] mce: [Hardware Error]: PROCESSOR 0:20652 TIME 1521198291 SOCKET 0 APIC 5 microcode 9
[    0.076042] mce: [Hardware Error]: CPU 3: Machine Check: 0 Bank 5: cc40020000100151
[    0.076049] mce: [Hardware Error]: TSC 455835867 ADDR 63a49e00 MISC 6832
[    0.076052] mce: [Hardware Error]: PROCESSOR 0:20652 TIME 1521198291 SOCKET 0 APIC 5 microcode 9
[    0.076054] mce: [Hardware Error]: CPU 3: Machine Check: 0 Bank 5: cc40008000100151
[    0.076058] mce: [Hardware Error]: TSC 455836de5 ADDR 63af95c0 MISC 3032
[    0.076064] mce: [Hardware Error]: PROCESSOR 0:20652 TIME 1521198291 SOCKET 0 APIC 5 microcode 9
[    0.076067] mce: [Hardware Error]: CPU 3: Machine Check: 0 Bank 5: cc4000c000100151
[    0.076071] mce: [Hardware Error]: TSC 455838611 ADDR 63a49e00 MISC 6832
[    0.076074] mce: [Hardware Error]: PROCESSOR 0:20652 TIME 1521198291 SOCKET 0 APIC 5 microcode 9
[    0.076076] mce: [Hardware Error]: CPU 3: Machine Check: 0 Bank 5: cc40008000100151
[    0.076077] mce: [Hardware Error]: TSC 455839e75 ADDR 64403a00 MISC 7832
[    0.076080] mce: [Hardware Error]: PROCESSOR 0:20652 TIME 1521198291 SOCKET 0 APIC 5 microcode 9
[    0.076082] mce: [Hardware Error]: CPU 3: Machine Check: 0 Bank 5: 8c40004000100151
[    0.076084] mce: [Hardware Error]: TSC 45583b220 ADDR 63b12f98 MISC 5832
[    0.076087] mce: [Hardware Error]: PROCESSOR 0:20652 TIME 1521198291 SOCKET 0 APIC 5 microcode 9
[    0.076089] mce: [Hardware Error]: CPU 3: Machine Check: 0 Bank 5: cc4000c000100151
[    0.076090] mce: [Hardware Error]: TSC 45583da8c ADDR 63af9500 MISC 2132
[    0.076093] mce: [Hardware Error]: PROCESSOR 0:20652 TIME 1521198291 SOCKET 0 APIC 5 microcode 9
[    0.076096] mce: [Hardware Error]: CPU 3: Machine Check: 0 Bank 5: cc4000c000100119
[    0.076097] mce: [Hardware Error]: TSC 455841384 ADDR 6430ad80 MISC 70a1
[    0.076100] mce: [Hardware Error]: PROCESSOR 0:20652 TIME 1521198291 SOCKET 0 APIC 5 microcode 9
[    0.076102] mce: [Hardware Error]: CPU 3: Machine Check: 0 Bank 5: cc40014000100151
[    0.076103] mce: [Hardware Error]: TSC 455844785 ADDR 63b129c0 MISC 3832
[    0.076107] mce: [Hardware Error]: PROCESSOR 0:20652 TIME 1521198291 SOCKET 0 APIC 5 microcode 9
[    0.076109] mce: [Hardware Error]: CPU 3: Machine Check: 0 Bank 5: cc40010000100151
[    0.076110] mce: [Hardware Error]: TSC 4558479d4 ADDR 63b129c0 MISC 3832
[    0.076113] mce: [Hardware Error]: PROCESSOR 0:20652 TIME 1521198291 SOCKET 0 APIC 5 microcode 9
[    0.076115] mce: [Hardware Error]: CPU 3: Machine Check: 0 Bank 5: cc4000c000100151
[    0.076116] mce: [Hardware Error]: TSC 45584b9f0 ADDR 64403a00 MISC 3832
[    0.076120] mce: [Hardware Error]: PROCESSOR 0:20652 TIME 1521198291 SOCKET 0 APIC 5 microcode 9
[    0.076122] mce: [Hardware Error]: CPU 3: Machine Check: 0 Bank 5: cc4000c000100151
[    0.076123] mce: [Hardware Error]: TSC 45584d1c0 ADDR 63af95c0 MISC 30b2
[    0.076126] mce: [Hardware Error]: PROCESSOR 0:20652 TIME 1521198291 SOCKET 0 APIC 5 microcode 9
[    0.076128] mce: [Hardware Error]: CPU 3: Machine Check: 0 Bank 5: cc4000c000100151
[    0.076129] mce: [Hardware Error]: TSC 45585262f ADDR 63af94e0 MISC 2132
[    0.076132] mce: [Hardware Error]: PROCESSOR 0:20652 TIME 1521198291 SOCKET 0 APIC 5 microcode 9
[    0.076135] mce: [Hardware Error]: CPU 3: Machine Check: 0 Bank 5: cc40008000100151
[    0.076136] mce: [Hardware Error]: TSC 455855414 ADDR 64403a00 MISC 7832
[    0.076139] mce: [Hardware Error]: PROCESSOR 0:20652 TIME 1521198291 SOCKET 0
Doc_Symbiosis
Avatar von Doc_Symbiosis
11. Oktober 2006
Installiere am Besten mcelog und schaue dann in die Datei /var/log/mcelog. Dort stehen dann genauere Informationen drin: https://www.thomas-krenn.com/de/wiki/Mcelog
Bzw. vielleicht ist das eh schon installiert und Du hast die mcelog Datei schon...
Bolle
23. Februar 2006
Ok hab ich gemacht... Irgendwie bremst mcelog das ganze System aus, kann das sein? Hier das Logfile: https://paste.ubuntuusers.de/423757/
Doc_Symbiosis
11. Oktober 2006
Hm, dass das mcelog das System ausbremst habe ich bisher noch nie erlebt. Aber Du hast jetzt ja die Info und kannst es auch wieder deinstallieren.
Wenn Du nach der Nachricht "mcelog: failed to prefill DIMM database from DMI data" suchst, findest Du heraus, dass man diesen Fehler ruhig ignorieren kann: http://www.mcelog.org/faq.html#11
Bolle
23. Februar 2006
Ok vielen Dank ☺ Und Du meinst die ganzen Hardware Errors aus dem Anfangspost resultieren darauf?
Gruß Bolle
Doc_Symbiosis
11. Oktober 2006
Ja, ich denke, die kannst Du alle ruhig alle ignorieren...
frostschutz
Avatar von frostschutz
18. November 2010
Ähnliches Problem: https://ubuntuforums.org/showthread.php?t=2372232
Leider auch nichts zur Lösung...
Hören die Fehler irgendwann mal auf? Wenn du memtester (das Linuxprogramm) auf den verfügbaren Speicher laufen lässt ist alles okay oder noch mehr Fehler? Dann würde ich auf defektes RAM tippen (Auch wenn memtester keine Fehler findet.)
CPU 3 on socket 0 has large number of corrected cache errors in Level-1 Data
Hmmm... oder doch die CPU selbst. Ich weiß nicht ob man das einfach so ignorieren kann/sollte.
Bolle
23. Februar 2006
Am RAM liegts nicht... Hab die einzeln getestet in beiden Bänken mit den selben Meldungen... Memtester? Meinst Du Memtest von Live CD bzw beim Start auswählen (Grub) Hab ich mal 2 Stunden laufen lassen - Keine Fehler.
Bolle
23. Februar 2006
Vorerst bleibt mir erstmal nix anderes übrig, solange sich "der Fehler" nicht auswirkt.
frostschutz
18. November 2010
Temperaturen im grünen Bereich?
Du könntest mal für kurze Zeit die CPU / CPU-Cache Tests hier laufen lassen: http://kernel.ubuntu.com/~cking/stress-ng/
Bolle
23. Februar 2006
Welchen Befehl genau ?
axt
22. November 2006
Noch nie einen Streßtest durchgeführt? Sind Beispiele (examples) aufgeführt.
Sollte man aber unter Beobachtung haben (bspw. wenn die Temperatur zu stark hochgeht - Frostschutz brauchst Du da jedenfalls nicht 😀).
