Hallo, ich will einen Drucker per IPP anbinden. Der Drucker ist an nen Druckserver mit Debian angeschlossen. Da ist er ansprechbar. Von meinem Rechner geht aber nichtmal die Einrichtung in system-config-printer. Netzwerkverkehr zum Ziel findet gar nicht erst statt, es ist also ein lokales Problem. IP passend angegeben (fd00:abcd::2).
E [08/Aug/2022:15:55:38 +0200] [CGI] ippfind (PID 27330) stopped with status 2! E [08/Aug/2022:15:55:38 +0200] [cups-deviced] PID 27327 (driverless) stopped with status 2! E [08/Aug/2022:15:55:46 +0200] [CGI] ippfind (PID 27334) stopped with status 2! E [08/Aug/2022:15:55:59 +0200] [Client 61] Returning IPP client-error-not-possible for CUPS-Add-Modify-Printer (ipp://localhost/printers/HP-Officejet-350) from localhost. m@ryz:~$
localhost - - [08/Aug/2022:15:55:35 +0200] "POST / HTTP/1.1" 200 270 Create-Printer-Subscriptions successful-ok localhost - - [08/Aug/2022:15:55:38 +0200] "POST / HTTP/1.1" 401 147 CUPS-Get-Devices successful-ok localhost - m [08/Aug/2022:15:55:38 +0200] "POST / HTTP/1.1" 200 2000 CUPS-Get-Devices - localhost - m [08/Aug/2022:15:55:38 +0200] "POST / HTTP/1.1" 200 222 CUPS-Get-Devices - localhost - - [08/Aug/2022:15:55:46 +0200] "POST / HTTP/1.1" 200 1206031 CUPS-Get-PPDs - localhost - - [08/Aug/2022:15:55:57 +0200] "POST / HTTP/1.1" 200 14707 CUPS-Get-PPD - localhost - - [08/Aug/2022:15:55:59 +0200] "POST /admin/ HTTP/1.1" 401 14724 CUPS-Add-Modify-Printer successful-ok localhost - m [08/Aug/2022:15:55:59 +0200] "POST /admin/ HTTP/1.1" 200 14724 CUPS-Add-Modify-Printer client-error-not-possible
m@ryz:~$ dpkg -l *cups* lpr* | grep ii ii cups 2.4.1op1-1ubuntu4.1 amd64 Common UNIX Printing System(tm) - PPD/driver support, web interface ii cups-client 2.4.1op1-1ubuntu4.1 amd64 Common UNIX Printing System(tm) - client programs (SysV) ii cups-common 2.4.1op1-1ubuntu4.1 all Common UNIX Printing System(tm) - common files ii cups-core-drivers 2.4.1op1-1ubuntu4.1 amd64 Common UNIX Printing System(tm) - driverless printing ii cups-daemon 2.4.1op1-1ubuntu4.1 amd64 Common UNIX Printing System(tm) - daemon ii cups-filters 1.28.15-0ubuntu1 amd64 OpenPrinting CUPS Filters - Main Package ii cups-filters-core-drivers 1.28.15-0ubuntu1 amd64 OpenPrinting CUPS Filters - Driverless printing ii cups-ipp-utils 2.4.1op1-1ubuntu4.1 amd64 Common UNIX Printing System(tm) - IPP developer/admin utilities ii cups-ppdc 2.4.1op1-1ubuntu4.1 amd64 Common UNIX Printing System(tm) - PPD manipulation utilities ii cups-server-common 2.4.1op1-1ubuntu4.1 all Common UNIX Printing System(tm) - server common files ii libcups2:amd64 2.4.1op1-1ubuntu4.1 amd64 Common UNIX Printing System(tm) - Core library ii libcups2:i386 2.4.1op1-1ubuntu4.1 i386 Common UNIX Printing System(tm) - Core library ii libcupsfilters1:amd64 1.28.15-0ubuntu1 amd64 OpenPrinting CUPS Filters - Shared library ii printer-driver-hpcups 3.21.12+dfsg0-1 amd64 HP Linux Printing and Imaging - CUPS Raster driver (hpcups) ii python3-cups:amd64 2.0.1-5build1 amd64 Python3 bindings for CUPS ii python3-cupshelpers 1.5.16-0ubuntu3 all Python utility modules around the CUPS printing system m@ryz:~$
m@ryz:~$ dpkg -l libusb* | grep ii ii libusb-1.0-0:amd64 2:1.0.25-1ubuntu2 amd64 userspace USB programming library ii libusb-1.0-0:i386 2:1.0.25-1ubuntu2 i386 userspace USB programming library ii libusbmuxd6:amd64 2.0.2-3build2 amd64 USB multiplexor daemon for iPhone and iPod Touch devices - library m@ryz:~$ m@ryz:~$ systemctl --no-pager status cups* ● cups.path - CUPS Scheduler Loaded: loaded (/lib/systemd/system/cups.path; enabled; vendor preset: enabled) Active: active (running) since Mon 2022-08-08 06:07:34 CEST; 9h ago Triggers: ● cups.service Aug 08 06:07:34 ryz systemd[1]: Stopping CUPS Scheduler... Aug 08 06:07:34 ryz systemd[1]: Started CUPS Scheduler. ● cups.service - CUPS Scheduler Loaded: loaded (/lib/systemd/system/cups.service; enabled; vendor preset: enabled) Active: active (running) since Mon 2022-08-08 06:07:55 CEST; 9h ago TriggeredBy: ● cups.socket ● cups.path Docs: man:cupsd(8) Main PID: 1342 (cupsd) Status: "Scheduler is running..." Tasks: 1 (limit: 57609) Memory: 14.7M CPU: 1.906s CGroup: /system.slice/cups.service └─1342 /usr/sbin/cupsd -l Aug 08 06:07:34 ryz systemd[1]: Starting CUPS Scheduler... Aug 08 06:07:55 ryz systemd[1]: Started CUPS Scheduler. Aug 08 15:43:22 ryz hpfax[26580]: [26580]: error: Failed to create /var/spo…plip ● cups.socket - CUPS Scheduler Loaded: loaded (/lib/systemd/system/cups.socket; enabled; vendor preset: enabled) Active: active (running) since Mon 2022-08-08 06:07:34 CEST; 9h ago Triggers: ● cups.service Listen: /run/cups/cups.sock (Stream) CGroup: /system.slice/cups.socket Aug 08 06:07:34 ryz systemd[1]: cups.socket: Deactivated successfully. Aug 08 06:07:34 ryz systemd[1]: Closed CUPS Scheduler. Aug 08 06:07:34 ryz systemd[1]: Stopping CUPS Scheduler... Aug 08 06:07:34 ryz systemd[1]: Listening on CUPS Scheduler. Hint: Some lines were ellipsized, use -l to show in full. m@ryz:~$ m@ryz:~$ lpstat -t Zeitplandienst läuft systemvoreingestelltes Ziel: efax-printer Gerät für efax-printer: socket://127.0.0.1:9900 efax-printer akzeptiert Anfragen seit So 07 Aug 2022 11:59:44 CEST Drucker efax-printer ist im Leerlauf. Aktiviert seit So 07 Aug 2022 11:59:44 CEST m@ryz:~$ m@ryz:~$ lpinfo -v file cups-brf:/ network beh serial serial:/dev/ttyS0?baud=115200 network ipps direct hp network ipp network lpd network http network socket network https direct hpfax m@ryz:~$
Gruß DJK
