ich hab folgendes CMake File vor mir:
set(MACOSX_BUNDLE_GUI_IDENTIFIER "org.navitproject.navit") set(MACOSX_BUNDLE_BUNDLE_NAME "Navit") message(STATUS "Building with CMake V${CMAKE_VERSION}") project(navit C) # Workaround for CMake issue 8345 / 9220, see http://trac.navit-project.org/ticket/1041 if(DEFINED CMAKE_CXX_COMPILER AND CMAKE_CXX_COMPILER MATCHES "^$") set(CMAKE_CXX_COMPILER CMAKE_CXX_COMPILER-NOTFOUND) endif(DEFINED CMAKE_CXX_COMPILER AND CMAKE_CXX_COMPILER MATCHES "^$") if (NOT DISABLE_CXX) enable_language(CXX OPTIONAL) endif(NOT DISABLE_CXX) cmake_minimum_required(VERSION 2.6 FATAL_ERROR) set(NAVIT_VERSION_MAJOR "0") set(NAVIT_VERSION_MINOR "5") set(NAVIT_VERSION_PATCH "3") set(PACKAGE_VERSION "${NAVIT_VERSION_MAJOR}.${NAVIT_VERSION_MINOR}.${NAVIT_VERSION_PATCH}") set(PACKAGE_NAME "navit-git") set(PACKAGE "navit" CACHE STRING "Navit package name") set(PACKAGE_STRING "${PACKAGE} ${PACKAGE_VERSION}") set(CMAKE_MODULE_PATH ${CMAKE_MODULE_PATH} "${CMAKE_SOURCE_DIR}/cmake/") include("${PROJECT_SOURCE_DIR}/cmake/navit_macros.cmake") IF(NOT CMAKE_BUILD_TYPE) SET(CMAKE_BUILD_TYPE RelWithDebInfo CACHE STRING "Choose the type of build, options are: None Debug Release RelWithDebInfo MinSizeRel." FORCE) ENDIF(NOT CMAKE_BUILD_TYPE) # binary name set(NAVIT_BINARY navit CACHE STRING "Navit binary name") # install path set(BIN_DIR bin CACHE PATH "Navit bin path") add_definitions ("-DBIN_DIR=\"${BIN_DIR}\"") set(SHARE_DIR share/navit CACHE PATH "Navit share path") add_definitions ("-DSHARE_DIR=\"${SHARE_DIR}\"") set(LOCALE_DIR share/locale CACHE PATH "Navit locale path") add_definitions ("-DLOCALE_DIR=\"${LOCALE_DIR}\"") set(IMAGE_DIR share/navit/icons CACHE PATH "Navit image path") add_definitions ("-DIMAGE_DIR=\"${IMAGE_DIR}\"") set(MAN_DIR share/man/man1 CACHE PATH "Navit man path") add_definitions ("-DMAN_DIR=\"${MAN_DIR}\"") # LIB_DIR IF(UNIX AND NOT ANDROID AND NOT APPLE) IF (NOT LIBDIR) MESSAGE(STATUS "LIBDIR variable is not defined. It will be autodetected now.") MESSAGE(STATUS "You can set it manually with -DLIBDIR=<value>") # check 64 bit IF (CMAKE_SIZEOF_VOID_P EQUAL 4) SET(LIB_DIR lib/${PACKAGE} CACHE PATH "Navit 32bit bin path") MESSAGE(STATUS " LIB_DIR (highest subdirectory if LIBDIR) is set to '${LIB_DIR}'") ELSE (CMAKE_SIZEOF_VOID_P EQUAL 4) SET(LIB_DIR lib64/${PACKAGE} CACHE PATH "Navit 64bit bin path") MESSAGE(STATUS " LIB_DIR (highest subdirectory if LIBDIR) is set to '${LIB_DIR}'") ENDIF (CMAKE_SIZEOF_VOID_P EQUAL 4) ELSE (NOT LIBDIR) SET (LIB_DIR ${LIBDIR}/${PACKAGE} CACHE PATH "Navit lib path") MESSAGE(STATUS " LIB_DIR is set to '${LIB_DIR}' because LIBDIR is set to ${LIBDIR}") ENDIF (NOT LIBDIR) ELSE (UNIX AND NOT ANDROID AND NOT APPLE) SET(LIB_DIR lib/navit CACHE PATH "Navit unix bin path") ENDIF (UNIX AND NOT ANDROID AND NOT APPLE) foreach(EXTRA_MODULE ${EXTRA_MODULES}) add_module(${EXTRA_MODULE} "extra module specified" TRUE) endforeach() add_definitions ("-DLIB_DIR=\"${LIB_DIR}\"") if (EXTRA_LIBS) list(APPEND NAVIT_LIBS ${EXTRA_LIBS}) endif(EXTRA_LIBS) if (EXTRA_INCLUDES) include_directories(${EXTRA_INCLUDES}) endif(EXTRA_INCLUDES) if (EXTRA_LIBDIR) link_directories(${EXTRA_LIBDIR}) endif(EXTRA_LIBDIR) ### Detect environment add_plugin(support/espeak "Default" FALSE) add_feature(INTERNAL_ESPEAK_COMPLETE "build complete internal libespeak" FALSE) add_plugin(support/ezxml "native Glib found" FALSE) add_plugin(support/glib "native Glib found" FALSE) add_plugin(support/zlib "native zlib found" FALSE) add_plugin(support/libpng "native libpng found" FALSE) add_plugin(support/wordexp "native wordexp found" FALSE) add_plugin(support/gettext_intl "native libintl found" FALSE) add_module(font/freetype "freetype not found" FALSE) add_module(graphics/android "FreeType library not found" FALSE) add_module(graphics/gd "FreeType library not found" FALSE) add_module(graphics/gtk_drawing_area "FreeType library not found" FALSE) add_module(graphics/opengl "FreeType library not found" FALSE) add_module(graphics/sdl "Required library not found" FALSE) add_module(graphics/egl "Required library not found" FALSE) add_module(graphics/qt_qpainter "Qt libraries not found" FALSE) add_module(graphics/qt5 "Qt5 libraries not found" FALSE) add_module(gui/qml "Qt Declarative not found" FALSE) add_module(gui/qt5_qml "Qt5 Declarative not found" FALSE) add_module(gui/gtk "GTK libs not found" FALSE) add_module(vehicle/gpsd "gpsd lib not found" FALSE) add_module(vehicle/gypsy "gypsy lib not found" FALSE) add_module(vehicle/maemo "Default" FALSE) add_module(binding/win32 "Default" FALSE) add_module(binding/dbus "dbus-glib-1 not found" FALSE) add_module(binding/python "python libraries not found" FALSE) add_module(speech/dbus "dbus-glib-1 not found" FALSE) add_module(speech/cmdline "neither system() nor CreateProcess() found" FALSE) add_module(speech/qt5_espeak "Qt5 multimedia not found" FALSE) add_module(vehicle/gpsd_dbus "dbus-glib-1 not found" FALSE) add_module(vehicle/qt5 "Qt5 libraries not found" FALSE) add_module(speech/speech_dispatcher "speech_dispatcher lib not found" FALSE) add_module(autoload/osso "Default" FALSE) add_module(map/garmin "Garmin library not found" FALSE) add_feature(USE_NATIVE_LANGUAGE_SUPPORT "Gettext not found and not on Windows" FALSE) set(CPACK_PROJECT_CONFIG_FILE "${CMAKE_SOURCE_DIR}/cpack.cmake") set(CPACK_PACKAGE_VENDOR "Navit team") set(CPACK_PACKAGE_VERSION_MAJOR ${NAVIT_VERSION_MAJOR}) set(CPACK_PACKAGE_VERSION_MINOR ${NAVIT_VERSION_MINOR}) set(CPACK_PACKAGE_VERSION_PATCH "${NAVIT_VERSION_PATCH}") set(CPACK_PACKAGE_DESCRIPTION_FILE "${CMAKE_SOURCE_DIR}/README.md") set(CPACK_RESOURCE_FILE_LICENSE "${CMAKE_SOURCE_DIR}/GPL-2") set(CPACK_NSIS_PACKAGE_NAME "Navit ${PACKAGE_VERSION}") set(CPACK_PACKAGE_FILE_NAME ${PACKAGE}) set(CPACK_PACKAGE_EXECUTABLES "navit;Navit") set(CPACK_NSIS_HELP_LINK "http://www.navit-project.org/?page=contact") set(CPACK_NSIS_URL_INFO_ABOUT "http://www.navit-project.org") if(WIN32) add_feature(USE_NSIS "makensis not found" FALSE) FIND_PROGRAM(NSIS_EXECUTABLE NAMES makensis makensis.exe) if(NSIS_EXECUTABLE) set_with_reason(USE_NSIS "makensis found" TRUE) endif(NSIS_EXECUTABLE) set(CPACK_GENERATOR ZIP) if(USE_NSIS) list(APPEND CPACK_GENERATOR NSIS) endif(USE_NSIS) set(CPACK_PACKAGE_INSTALL_DIRECTORY Navit) endif(WIN32) INCLUDE (CPack) INCLUDE (CheckIncludeFiles) INCLUDE (CheckLibraryExists) INCLUDE (CheckFunctionExists) INCLUDE (CheckSymbolExists) find_package(Glib) find_package(Gmodule) find_package(ZLIB) find_package(Freetype) find_library(SDL2MAIN SDL2) find_library(SDL2IMAGE SDL2_image) find_library(GLES2 GLESv2) find_package(SDL) find_package(SDL_ttf) find_package(SDL_image) find_package(OpenGL) find_package(GLUT) find_package(GTK2 2.6 COMPONENTS gtk) find_package(Gettext) find_package(PNG) find_package(DBusGLib) find_package(PythonLibs) find_package(Threads) libfind_pkg_check_modules(FONTCONFIG fontconfig) #Qt detection if (NOT DISABLE_QT) find_package(Qt5Widgets) find_package(Qt5Quick) find_package(Qt5Positioning) if (Qt5Widgets_FOUND OR Qt5Quick_FOUND OR Qt5Sensors_FOUND) add_feature (USE_QWIDGET "Qt5 Qt5Widget not found" FALSE) add_feature (USE_QML "Qt5 Qt5Quick not found" FALSE) if (Qt5Widgets_FOUND OR Qt5Quick_FOUND) find_package(Qt5Svg REQUIRED) find_package(Qt5DBus REQUIRED) find_package(Qt5Multimedia) find_package(espeak) endif (Qt5Widgets_FOUND OR Qt5Quick_FOUND) if (Qt5Positioning_FOUND) find_package(Qt5Sensors REQUIRED) endif (Qt5Positioning_FOUND) else (Qt5Widgets_FOUND OR Qt5Quick_FOUND OR Qt5Sensors_FOUND) # Unfortunately, CMake seems to ignore the "OPTIONAL_COMPONENTS" flag, # and actually requires all components to be installed. Maybe this can # be fixed later... find_package(Qt4 4.7 COMPONENTS QtCore OPTIONAL_COMPONENTS QtGui QtXml QtDeclarative QtSvg) endif (Qt5Widgets_FOUND OR Qt5Quick_FOUND OR Qt5Sensors_FOUND) endif (NOT DISABLE_QT) #pkg-config based detection find_package(PkgConfig) if(PKG_CONFIG_FOUND) pkg_check_modules(LIBLOCATION liblocation) pkg_check_modules(LIBOSSO libosso) # Accept even old versions of libgps, because N810 uses an old version (see #1179). pkg_check_modules(LIBGPS libgps) pkg_check_modules(LIBGPS19 libgps>=2.90) # libgpsd<V3.1 is buggy if LC_ALL is set. pkg_check_modules(LIBGPS_NEW libgps>=3.1) pkg_check_modules(LIBGARMIN libgarmin) pkg_check_modules(IMLIB2 imlib2) if(IMLIB2_FOUND) set(HAVE_IMLIB2 1) endif(IMLIB2_FOUND) endif(PKG_CONFIG_FOUND) #Simple checks CHECK_INCLUDE_FILES(wordexp.h HAVE_WORDEXP) CHECK_INCLUDE_FILES(endian.h HAVE_ENDIAN_H) CHECK_INCLUDE_FILES(stdint.h HAVE_STDINT_H) CHECK_INCLUDE_FILES(byteswap.h HAVE_BYTESWAP_H) CHECK_LIBRARY_EXISTS(gypsy gypsy_control_get_default "" GYPSY_FOUND) CHECK_INCLUDE_FILES(libspeechd.h HAVE_LIBSPEECHD) CHECK_INCLUDE_FILES(sys/socket.h HAVE_SOCKET) CHECK_INCLUDE_FILES(sys/shm.h HAVE_SHMEM) CHECK_FUNCTION_EXISTS(snprintf HAVE_SNPRINTF) if (NOT HAVE_SNPRINTF) CHECK_FUNCTION_EXISTS(_snprintf HAVE_DECL__SNPRINTF) if (HAVE_DECL__SNPRINTF) set(HAVE_SNPRINTF 1) endif(HAVE_DECL__SNPRINTF) endif(NOT HAVE_SNPRINTF) CHECK_INCLUDE_FILES(locale.h HAVE_LC_MESSAGES) CHECK_INCLUDE_FILES(libintl.h HAVE_LIBINTL) CHECK_INCLUDE_FILES(sys/time.h HAVE_SYS_TIME_H) CHECK_INCLUDE_FILES(getopt.h HAVE_GETOPT_H) CHECK_INCLUDE_FILES(string.h HAVE_STRING_H) CHECK_FUNCTION_EXISTS(gettimeofday HAVE_GETTIMEOFDAY) CHECK_SYMBOL_EXISTS(system stdlib.h HAVE_SYSTEM) CHECK_SYMBOL_EXISTS(CreateProcess windows.h HAVE_CREATEPROCESS) CHECK_SYMBOL_EXISTS(stpcpy string.h HAVE_STPCPY) CHECK_FUNCTION_EXISTS(sbrk HAVE_SBRK) CHECK_FUNCTION_EXISTS(getdelim HAVE_GETDELIM) CHECK_FUNCTION_EXISTS(getline HAVE_GETLINE) CHECK_FUNCTION_EXISTS(fsync HAVE_FSYNC) ### Configure build #Required libraries, supplied with navit if (NOT HAVE_LIBINTL) set_with_reason(support/gettext_intl "native libintl missing" TRUE) set(USE_LIBGNUINTL TRUE) else() CHECK_LIBRARY_EXISTS(intl libintl_fprintf "" NEEDS_LIBINTL) if (NEEDS_LIBINTL) list(APPEND NAVIT_LIBS intl) set(INTL_LIBS intl) endif(NEEDS_LIBINTL) endif(NOT HAVE_LIBINTL) if (CMAKE_USE_PTHREADS_INIT) if (NOT ANDROID) list(APPEND NAVIT_LIBS pthread) endif(NOT ANDROID) endif(CMAKE_USE_PTHREADS_INIT) if (Glib_FOUND) set(HAVE_GLIB 1) include_directories(${Glib_INCLUDE_DIRS}) list(APPEND NAVIT_LIBS ${Glib_LIBRARIES}) else(Glib_FOUND) set_with_reason(support/glib "Glib not found" TRUE ${INTL_LIBS}) endif(Glib_FOUND) if (Gmodule_FOUND) set(HAVE_GMODULE 1) include_directories(${Gmodule_INCLUDE_DIRS}) list(APPEND NAVIT_LIBS ${Gmodule_LIBRARIES}) endif(Gmodule_FOUND) if(ZLIB_FOUND) set(HAVE_ZLIB 1) include_directories(${ZLIB_INCLUDE_DIRS}) list(APPEND NAVIT_LIBS ${ZLIB_LIBRARIES}) else(ZLIB_FOUND) message(STATUS "using internal zlib") set_with_reason(support/zlib "native zlib missing" TRUE) endif(ZLIB_FOUND) if(PNG_FOUND) set(HAVE_PNG 1) include_directories(${PNG_INCLUDE_DIR}) list(APPEND NAVIT_LIBS ${PNG_LIBRARIES}) else(PNG_FOUND) message(STATUS "using internal libpng") set_with_reason(support/libpng "native libpng missing" TRUE) endif(PNG_FOUND) if (NOT HAVE_WORDEXP) message(STATUS "wordexp.h not found. use internal wordexp") set_with_reason(support/wordexp "native wordexp missing" TRUE) endif() if (NOT Glib_FOUND) set_with_reason(support/ezxml "Glib not found" TRUE) endif() if(FREETYPE_FOUND) pkg_check_modules(FRIBIDI fribidi) pkg_check_modules(FRIBIDI2 fribidi>=0.19.0) include_directories(${FREETYPE_INCLUDE_DIRS}) set_with_reason(font/freetype "freetype found" TRUE "${FREETYPE_LIBRARY};${FONTCONFIG_LDFLAGS};${FRIBIDI_LIBRARIES}") else(FREETYPE_FOUND) MESSAGE("No freetype library found, graphics modules may not be available") set_with_reason(graphics/android "FreeType library not found" FALSE) set_with_reason(graphics/gd "FreeType library not found" FALSE) set_with_reason(graphics/gtk_drawing_area "FreeType library not found" FALSE) set_with_reason(graphics/opengl "FreeType library not found" FALSE) set_with_reason(graphics/sdl "FreeType library not found" FALSE) set_with_reason(graphics/egl "FreeType library not found" FALSE) endif(FREETYPE_FOUND) if(FONTCONFIG_FOUND) set(HAVE_FONTCONFIG 1) endif(FONTCONFIG_FOUND) if (QT_FOUND) if (QT_QTCORE_FOUND AND QT_QTGUI_FOUND AND FREETYPE_FOUND) include(${QT_USE_FILE}) set_with_reason(graphics/qt_qpainter "Qt libraries found" TRUE ${QT_LIBRARIES}) if (QT_QTDECLARATIVE_FOUND AND QT_QTXML_FOUND) set_with_reason(gui/qml "Qt Declarative found" TRUE ${QT_LIBRARIES}) endif() if (QT_QTSVG_FOUND) set(HAVE_QT_SVG 1) elseif( USE_SVG AND graphics/qt_qpainter) message( WARNING "QT compiled without SVG support") endif() endif() endif(QT_FOUND) if (Qt5Widgets_FOUND OR Qt5Quick_FOUND) set(Qt5_ADDITIONAL_LIBRARIES "") if(Qt5Widgets_FOUND) set_with_reason(USE_QWIDGET "Qt5Widgets found" TRUE) if(USE_QWIDGET) set(Qt5_ADDITIONAL_LIBRARIES ${Qt5_ADDITIONAL_LIBRARIES} ${Qt5Widgets_LIBRARIES}) endif() endif() if(Qt5Quick_FOUND) set_with_reason(USE_QML "Qt5Quick found" TRUE) if(USE_QML) set(Qt5_ADDITIONAL_LIBRARIES ${Qt5_ADDITIONAL_LIBRARIES} ${Qt5Quick_LIBRARIES}) endif() set_with_reason(gui/qt5_qml "Qt5 found" TRUE ${Qt5Quick_LIBRARIES}) endif() set_with_reason(graphics/qt5 "Qt5 found" TRUE ${Qt5_ADDITIONAL_LIBRARIES} ${Qt5Svg_LIBRARIES} ${Qt5DBus_LIBRARIES}) if (Qt5Multimedia_FOUND) if (espeak_FOUND) set_with_reason(support/espeak "native espeak found" FALSE) set_with_reason(speech/qt5_espeak "Qt5Multimedia and libespeak found" TRUE ${Qt5Multimedia_LIBRARIES} ${espeak_LIBRARIES}) else() set_with_reason(support/espeak "native espeak missing" TRUE) set_with_reason(INTERNAL_ESPEAK_COMPLETE "speech_qt5_espeak requires full libespeak" TRUE) set_with_reason(speech/qt5_espeak "Qt5Multimedia found" TRUE ${Qt5Multimedia_LIBRARIES}) endif() endif() endif () if (Qt5Positioning_FOUND) set_with_reason(vehicle/qt5 "Qt5 Positioning found" TRUE ${Qt5Positioning_LIBRARIES} ${Qt5Sensors_LIBRARIES}) endif () if(GTK2_FOUND) # Include gtk.h with "SYSTEM" to avoid GCC compiler warning for gtkitemfactory.h. include_directories(SYSTEM ${GTK2_GTK_INCLUDE_DIR}) include_directories(${GTK2_INCLUDE_DIRS}) set(HAVE_GTK2 1) set_with_reason(gui/gtk "GTK libs found" TRUE ${GTK2_LIBRARIES}) if(FREETYPE_FOUND) set_with_reason(graphics/gtk_drawing_area "GTK libs found" TRUE ${GTK2_LIBRARIES}) endif(FREETYPE_FOUND) endif(GTK2_FOUND) CHECK_LIBRARY_EXISTS(freeimage FreeImage_Load "" HAVE_FREEIMAGE) if (USE_OPENGLES OR USE_OPENGLES2) CHECK_LIBRARY_EXISTS(EGL eglInitialize "" HAVE_EGL) endif(USE_OPENGLES OR USE_OPENGLES2) if (FREETYPE_FOUND) if (OPENGL_FOUND AND OPENGL_GLU_FOUND AND GLUT_FOUND AND OPENGL_INCLUDE_DIR) message (STATUS "opengl found: ${OPENGL_gl_LIBRARY}") include_directories(${OPENGL_INCLUDE_DIR}) if (USE_OPENGLES2) set(USE_OPENGLES TRUE) set(GRAPHICS_OPENGL_LIBRARY GLESv2 EGL) elseif (USE_OPENGLES) set(GRAPHICS_OPENGL_LIBRARY GLESv1_CM EGL) else() set(GRAPHICS_OPENGL_LIBRARY ${OPENGL_gl_LIBRARY};${OPENGL_glu_LIBRARY};${GLUT_glut_LIBRARY}) endif(USE_OPENGLES2) if (HAVE_FREEIMAGE) list(APPEND GRAPHICS_OPENGL_LIBRARY freeimage) endif(HAVE_FREEIMAGE) set_with_reason(graphics/opengl "Found OpenGL" TRUE ${GRAPHICS_OPENGL_LIBRARY}) else() message (STATUS "opengl not found") endif() else() message (STATUS "no Freetype found") endif(FREETYPE_FOUND) if(SDL_FOUND AND SDLIMAGE_FOUND AND FREETYPE_FOUND) set(SDL_IMAGE 1) if(SDLTTF_FOUND) set(SDL_TTF 1) list(APPEND SDL_LIBRARY ${SDLTTF_LIBRARY}) else(SDLTTF_FOUND) list(APPEND SDL_LIBRARY ${FREETYPE_LIBRARY}) endif(SDLTTF_FOUND) set_with_reason(graphics/sdl "SDL/SDL_image libs found" TRUE ${SDL_LIBRARY} ${SDLIMAGE_LIBRARY}) endif(SDL_FOUND AND SDLIMAGE_FOUND AND FREETYPE_FOUND) if(SDL2MAIN AND SDL2IMAGE AND GLES2) set_with_reason(graphics/egl "SDL2/SDL2_image libs found" TRUE ${SDL2MAIN} ${SDL2IMAGE} ${GLES2}) message(STATUS "EGL libs found : ${SDL2MAIN} ${SDL2IMAGE} ${GLES2}") endif(SDL2MAIN AND SDL2IMAGE AND GLES2) if (LIBGPS_FOUND) if (LIBGPS_NEW_FOUND) set(VEHICLE_GPSD_REASON "gpsd lib found") else(LIBGPS_NEW_FOUND) set(VEHICLE_GPSD_REASON "WARNING: old gpsd lib found, buggy if LC_ALL is set") endif(LIBGPS_NEW_FOUND) set_with_reason(vehicle/gpsd ${VEHICLE_GPSD_REASON} TRUE ${LIBGPS_LDFLAGS}) endif(LIBGPS_FOUND) if (GYPSY_FOUND) set_with_reason(vehicle/gypsy "gypsy lib found" TRUE) endif(GYPSY_FOUND) if (LIBGARMIN_FOUND) include_directories(${LIBGARMIN_INCLUDE_DIRS}) set_with_reason(map/garmin "Garmin library found" TRUE ${LIBGARMIN_LDFLAGS}) endif(LIBGARMIN_FOUND) if(DBusGLib_FOUND) include_directories(${DBusGLib_INCLUDE_DIRS}) set_with_reason(binding/dbus "dbus-glib-1 found" TRUE ${DBusGLib_LIBRARIES}) set_with_reason(speech/dbus "dbus-glib-1 found" TRUE ${DBusGLib_LIBRARIES}) set_with_reason(vehicle/gpsd_dbus "dbus-glib-1 found" TRUE ${DBusGLib_LIBRARIES}) endif() if(PYTHONLIBS_FOUND) set_with_reason(binding/python "python libraries [${PYTHONLIBS_VERSION_STRING}] found" TRUE ${PYTHON_LIBRARIES}) endif() if (HAVE_LIBSPEECHD) set_with_reason(speech/speech_dispatcher "speech_dispatcher lib found" TRUE speechd) endif(HAVE_LIBSPEECHD) if (HAVE_SYSTEM) set_with_reason(speech/cmdline "system() call is available" TRUE) endif(HAVE_SYSTEM) if (HAVE_CREATEPROCESS) set_with_reason(speech/cmdline "CreateProcess() call is available" TRUE) endif(HAVE_CREATEPROCESS) if (LIBLOCATION_FOUND) set_with_reason(vehicle/maemo "Maemo location library found" TRUE ${LIBLOCATION_LIBRARIES}) endif(LIBLOCATION_FOUND) if (LIBOSSO_FOUND) set_with_reason(autoload/osso "Maemo osso library found" TRUE ${LIBOSSO_LIBRARIES}) endif(LIBOSSO_FOUND) if (GETTEXT_FOUND) set_with_reason(USE_NATIVE_LANGUAGE_SUPPORT "Gettext found" TRUE) endif(GETTEXT_FOUND) #Independent modules add_module(graphics/null "Default" TRUE) add_module(osd/core "Default" TRUE) add_module(vehicle/demo "Default" TRUE) add_module(vehicle/file "Default" TRUE) add_module(vehicle/null "Default" FALSE) add_module(gui/internal "Default" TRUE) add_module(map/binfile "Default" TRUE) add_module(map/filter "Default" TRUE) if(NOT MSVC) add_module(map/mg "Default" TRUE) endif(NOT MSVC) add_module_plugin(support/shapefile "Default" TRUE) set(map_shapefile_INCLUDES "${CMAKE_SOURCE_DIR}/navit/support/shapefile") #set(map_shapefile_LIBRARY_DIRS "${CMAKE_BINARY_DIR}/navit/support/shapefile") set(map_shapefile_LIBS "support_shapefile") add_module(map/shapefile "Default" TRUE) add_module(map/textfile "Default" TRUE) add_module(map/csv "Default" TRUE) #Modules without test yet add_module(plugin/pedestrian "Default" FALSE) add_module(plugin/j1850 "Default" FALSE) add_module(speech/android "Default" FALSE) add_module(speech/espeak "Default" FALSE) add_module(speech/iphone "Default" FALSE) add_module(vehicle/android "Default" FALSE) add_module(vehicle/iphone "Default" FALSE) add_module(vehicle/wince "Default" FALSE) add_module(graphics/cocoa "Default" FALSE) # other features add_feature(USE_PLUGINS "default" TRUE) add_feature(USE_ROUTING "default" TRUE) add_feature(USE_SVG "default" TRUE) add_feature(SVG2PNG "default" TRUE) add_feature(SAMPLE_MAP "default" TRUE) add_feature(NETWORK_INFO "default" FALSE) IF(NOT svg2png_scaling) IF(NOT ANDROID) set(svg2png_scaling 0 16 32 48 64 96) ELSE() set(svg2png_scaling -1 24 32 48 64 96 128) ENDIF() ENDIF() IF(NOT svg2png_scaling_flag) IF(NOT ANDROID) set(svg2png_scaling_flag 32) ELSE() set(svg2png_scaling_flag -1 24 32 64 96) ENDIF() ENDIF() IF(NOT svg2png_scaling_nav) IF(NOT ANDROID) set(svg2png_scaling_nav 64) ELSE() set(svg2png_scaling_nav -1 24 32 48 64 96 128) ENDIF() ENDIF() add_feature(DBUS_USE_SYSTEM_BUS "default" FALSE) add_feature(BUILD_MAPTOOL "default" TRUE) add_feature(XSL_PROCESSING "default" TRUE) set(SUPPORTED_XSLT_PROCESSORS "saxonb-xslt;saxon;saxon8;saxon-xslt;xsltproc;transform.exe") find_program(XSLT_PROCESSOR NAMES ${SUPPORTED_XSLT_PROCESSORS}) if(XSLT_PROCESSOR) message(STATUS "Found XSLT processor: ${XSLT_PROCESSOR}") execute_process(COMMAND ${XSLT_PROCESSOR} -snone ${CMAKE_CURRENT_SOURCE_DIR}/cmake/test.xml ${CMAKE_CURRENT_SOURCE_DIR}/cmake/test.xslt RESULT_VARIABLE SAXON_ERROR OUTPUT_QUIET ERROR_QUIET) if (NOT SAXON_ERROR) set (XSLT_PROCESSOR_OPTIONS -snone) endif() # additional parameter is passed to the stylesheet processor as transformation parameter macro(compose_xslt_transform_command CMDVAR XSLT_FILE SRC_XML DEST_XML) if(${XSLT_PROCESSOR} MATCHES "xsltproc") set(${CMDVAR} COMMAND ${XSLT_PROCESSOR} ${XSLT_PROCESSOR_OPTIONS} ${XSLT_FILE} ${SRC_XML} >${DEST_XML}) else() set(${CMDVAR} COMMAND ${XSLT_PROCESSOR} ${XSLT_PROCESSOR_OPTIONS} ${SRC_XML} ${XSLT_FILE} ${ARGN} >${DEST_XML}) endif() endmacro() else() cfg_feature(XSL_PROCESSING "Saxon missing" FALSE) endif(XSLT_PROCESSOR) if (NOT XSL_PROCESSING) message(WARNING "No XSLT processor available. You have to configure " "navit.xml yourself, or install an XSLT processor (supported: " "${SUPPORTED_XSLT_PROCESSORS}).") endif() ### Platform specific settings if(NOT CACHE_SIZE) SET(CACHE_SIZE 1048576) endif(NOT CACHE_SIZE) if(WIN32 OR WINCE) SET(CMAKE_EXECUTABLE_SUFFIX ".exe") add_module(graphics/win32 "Windows detected" TRUE) add_plugin(support/win32 "Windows detected" TRUE) SET(CMAKE_RC_COMPILE_OBJECT "<CMAKE_RC_COMPILER> -O coff -I ${CMAKE_CURRENT_SOURCE_DIR}/navit/gui/win32/resources <DEFINES> -i <SOURCE> -o <OBJECT>") set_with_reason(support/ezxml "Windows detected" TRUE) set_with_reason(speech/espeak "Windows detected" TRUE) #speech/espeak does use windows threads, and therefore needs only parts of #espeak lib. INTERNAL_ESPEAK_COMPLETE controls this. set_with_reason(INTERNAL_ESPEAK_COMPLETE "Windows detected" FALSE) set_with_reason(support/espeak "Windows detected" TRUE) set_with_reason(binding/win32 "Windows detected" TRUE) # vehicle_file is broken for windows. use vehicle_wince instead # whicle_wince isn't buildable on non-CE windows ssytems # plugins currently not supported on windows set_with_reason(USE_PLUGINS "win32: currently not supported" FALSE) set(HAVE_API_WIN32_BASE 1) set(EZXML_NOMMAP 1) # Image stuff if(NOT graphics/qt_qpainter) set_with_reason(USE_SVG "win32: SVGs currently not supported" FALSE) else(NOT graphics/qt_qpainter) MESSAGE(STATUS "win32: SVGs may not be supported by every available graphics") endif(NOT graphics/qt_qpainter) set(BIN_DIR bin) set(SHARE_DIR ./) set(LOCALE_DIR locale) set(IMAGE_DIR icons) if(HAVE_GTK2 AND NOT MSVC) #GTK requires special compile flags add_definitions("-mms-bitfields") endif(HAVE_GTK2 AND NOT MSVC) if(MSVC AND support/espeak) add_definitions(-DPLATFORM_WINDOWS) endif(MSVC AND support/espeak) CHECK_LIBRARY_EXISTS(ws2_32 WSAStartup "" HAVE_WINSOCK) if(HAVE_WINSOCK) list(APPEND NAVIT_LIBS ws2_32) else() CHECK_LIBRARY_EXISTS(ws2 WSAStartup "" HAVE_WINSOCK_2) if(HAVE_WINSOCK_2) set(HAVE_WINSOCK 1) list(APPEND NAVIT_LIBS ws2) endif() endif(HAVE_WINSOCK) if(MSVC) set(HAVE_PRAGMA_PACK 1) add_plugin(support/xgetopt "Windows detected" TRUE) endif(MSVC) set_with_reason(USE_NATIVE_LANGUAGE_SUPPORT "Windows detected" TRUE) enable_language(RC) set(XSLTS "windows;${XSLTS}" CACHE STRING "define a semicolon seperated list of XSLTs to process") endif() if (WIN32 AND NOT WINCE) set(HAVE_API_WIN32 1) set(HAVE_STDINT_H 1) list(APPEND NAVIT_LIBS winmm) endif() if(WINCE) add_plugin(support/libc "wince detected" TRUE) set(HAVE_API_WIN32_CE 1) set(BUILD_MAPTOOL FALSE) # mingw32ce since gcc 4.7.0 needs HAVE_PRAGMA_PACK as __attribute__((packed)) is broken, see gcc bug 52991 set(HAVE_PRAGMA_PACK 1) set_with_reason(vehicle/file "wince: currently broken" FALSE) set_with_reason(vehicle/wince "wince detected" TRUE) endif() if (APPLE OR USE_UIKIT) set_with_reason(vehicle/iphone "apple detected" TRUE) set_with_reason(graphics/cocoa "apple detected" TRUE) if (EXISTS "${CMAKE_OSX_SYSROOT}/System/Library/PrivateFrameworks/VoiceServices.framework") set_with_reason(speech/iphone "apple detected" TRUE) endif() set(BUILD_BUNDLE TRUE CACHE BOOLEAN "build an osx bundle") endif() if(CMAKE_SIZEOF_VOID_P LESS 8) set_with_reason(BUILD_MAPTOOL "maptool works only on 64 bit architectures" FALSE) endif() set(LOCALEDIR "${LOCALE_DIR}") find_program(BZCAT NAMES bzcat) if (SAMPLE_MAP) if(CMAKE_CROSSCOMPILING) cfg_feature(SAMPLE_MAP "downloading binary map because of cross compiling" TRUE) set(DOWNLOAD_SAMPLE_MAP TRUE) elseif(NOT BZCAT) cfg_feature(SAMPLE_MAP "downloading binary map because of missing bzcat" TRUE) set(DOWNLOAD_SAMPLE_MAP TRUE) elseif(NOT BUILD_MAPTOOL) cfg_feature(SAMPLE_MAP "downloading binary map because maptool compilation is disabled" TRUE) set(DOWNLOAD_SAMPLE_MAP TRUE) endif(CMAKE_CROSSCOMPILING) endif(SAMPLE_MAP) check_symbol_exists (getifaddrs "sys/types.h;ifaddrs.h" HAS_IFADDRS) if (HAS_IFADDRS) cfg_feature(NETWORK_INFO "ifaddrs.h found" TRUE) endif(HAS_IFADDRS) if(ANDROID) message(STATUS "Using generator " ${CMAKE_GENERATOR}) if (NOT ${CMAKE_GENERATOR} STREQUAL Ninja) find_program(ANDROID_LOCATION NAMES android android.bat) find_program(ANT_LOCATION NAMES ant) if (NOT ANT_LOCATION) message_error("Could not find ant. Please install ant and add it to the search path.") else() execute_process(COMMAND ${ANT_LOCATION} WORKING_DIRECTORY ${CMAKE_CURRENT_SOURCE_DIR}/cmake RESULT_VARIABLE ANT_VERSION_OK OUTPUT_QUIET ERROR_QUIET) if(ANT_VERSION_OK GREATER 0) message(WARNING "Old ant version detected. If you need crash reporter, update to at least ant 1.8") endif() endif() if (NOT ANDROID_LOCATION) message_error( "Could not find 'Android SDK and AVD Manager'. Please install the android sdk and add the <android-sdk>/tools directory to the search path.") endif() set(XSLTS "android;${XSLTS}" CACHE STRING "define a semicolon seperated list of XSLTs to process") endif (NOT ${CMAKE_GENERATOR} STREQUAL Ninja) list(APPEND NAVIT_LIBS log) set(HAVE_API_ANDROID 1) set_with_reason(speech/cmdline "Android detected" FALSE) set_with_reason(graphics/null "Android detected" FALSE) set_with_reason(graphics/android "Android detected" TRUE) set_with_reason(speech/android "Android detected" TRUE) set_with_reason(vehicle/android "Android detected" TRUE) set_with_reason(vehicle/file "Android detected" FALSE) set_with_reason(vehicle/gpsd "Android detected" FALSE) set_with_reason(map/filter "Android detected" FALSE) set_with_reason(map/garmin "Android detected" FALSE) set_with_reason(USE_NATIVE_LANGUAGE_SUPPORT "Android detected" TRUE) # set_with_reason(plugin/pedestrian "Android detected" TRUE) set_with_reason(support/libpng "Android detected" FALSE) set(SHARED_LIBNAVIT TRUE) add_feature(XPM2PNG "Android detected" TRUE) set(NAVIT_COMPILE_FLAGS "${NAVIT_COMPILE_FLAGS} -fPIC") endif(ANDROID) if(FREETYPE_FOUND AND NOT FONTCONFIG_FOUND) add_subdirectory( "${CMAKE_CURRENT_SOURCE_DIR}/navit/fonts") endif() # Image conversion find_program(IMAGE_CONVERTER NAMES convert) execute_process(COMMAND ${IMAGE_CONVERTER} -list format OUTPUT_VARIABLE CONVERT_FORMATS) if(CONVERT_FORMATS MATCHES ".*XPM[ *][ ]*XPM[ ]*r[w-].*") set(IMAGE_CONVERTER_XPM ${IMAGE_CONVERTER}) endif() set(CMAKE_APPBUNDLE_PATH "") if (SVG2PNG) if (NOT IMAGE_CONVERTER_SVGZ) set (SVG_CONVERTER_PROGS rsvg-convert ksvgtopng ksvgtopng4 inkscape) set (CMAKE_FIND_APPBUNDLE "NEVER") find_program(IMAGE_CONVERTER_SVGZ NAMES ${SVG_CONVERTER_PROGS} PATHS /Applications/Inkscape.app/Contents/Resources/bin) if (NOT IMAGE_CONVERTER_SVGZ) if(CONVERT_FORMATS MATCHES ".*[ ]*SVG[ ]*r[w-].*") set(IMAGE_CONVERTER_SVGZ ${IMAGE_CONVERTER}) endif() endif() endif(NOT IMAGE_CONVERTER_SVGZ) if (NOT IMAGE_CONVERTER_SVG) set(IMAGE_CONVERTER_SVG ${IMAGE_CONVERTER_SVGZ}) endif(NOT IMAGE_CONVERTER_SVG) message(STATUS "SVG2PNG-Converter: ${IMAGE_CONVERTER_SVGZ}") if (NOT IMAGE_CONVERTER_SVGZ) message(WARNING "No SVG2PNG converter found. Please install one of the following tools: ${SVG_CONVERTER_PROGS}, or imagemagick with svg support") set_with_reason(SVG2PNG "no converter found" FALSE) endif(NOT IMAGE_CONVERTER_SVGZ) endif(SVG2PNG) if (XPM2PNG) message(STATUS "XPM2PNG-Converter: ${IMAGE_CONVERTER_XPM}") if (NOT IMAGE_CONVERTER_XPM) message(WARNING "No XPM2PNG converter found. Please install imagemagick with xpm support") set_with_reason(XPM2PNG "no converter found" FALSE) endif(NOT IMAGE_CONVERTER_XPM) endif(XPM2PNG) set(XSLTS ${XSLTS} CACHE STRING "define a semicolon seperated list of XSLTs to process") # Plugins if(USE_PLUGINS) set(MODULE_BUILD_TYPE "MODULE") add_definitions("-fPIC") list(APPEND NAVIT_LIBS dl) else() set(MODULE_BUILD_TYPE "STATIC") endif(USE_PLUGINS) message(STATUS "Use plugins: ${MODULE_BUILD_TYPE}") CHECK_INCLUDE_FILES (malloc.h HAVE_MALLOC_H) CHECK_INCLUDE_FILES ("sys/param.h;sys/mount.h" HAVE_SYS_MOUNT_H) CHECK_INCLUDE_FILES (unistd.h HAVE_UNISTD_H) CHECK_FUNCTION_EXISTS (getcwd HAVE_GETCWD) CHECK_FUNCTION_EXISTS (memalign HAVE_MEMALIGN) CHECK_FUNCTION_EXISTS (valloc HAVE_VALLOC) CHECK_FUNCTION_EXISTS (posix_memalign HAVE_POSIX_MEMALIGN) CHECK_FUNCTION_EXISTS (popen HAVE_POPEN) CHECK_FUNCTION_EXISTS (_atoi64 HAVE__ATOI64) CONFIGURE_FILE(${CMAKE_CURRENT_SOURCE_DIR}/config.h.cmake ${CMAKE_CURRENT_BINARY_DIR}/config.h) # Compile with -Wall -Wextra. We need all the help we can get from the compiler :-). # Disabled warnings: # -Wno-missing-field-initializers: Used a lot, does not seem problematic. # -Wno-unused-parameter: Unfortunately occurs frequently because of # functions implementing the interface of a plugin. # -Wno-sign-compare: We currently just use int almost everywhere. # Unclear if it's really worth correcting. if(CMAKE_COMPILER_IS_GNUCC OR CCMAKE_COMPILER_IS_GNUCXX) set(COMMON_COMPILER_FLAGS "-Wall -Wundef -Wcast-align -Wpointer-arith -Wno-unused-parameter -Wno-sign-compare") set(CMAKE_C_FLAGS "${CMAKE_C_FLAGS} ${COMMON_COMPILER_FLAGS}") set(CMAKE_CXX_FLAGS "${CMAKE_C_FLAGS} ${COMMON_COMPILER_FLAGS}") # flags not available in old GCC versions, or not for both C and C++ add_compiler_flag_if_available("-Wno-missing-field-initializers") add_compiler_flag_if_available("-Wextra") add_compiler_flag_if_available("-Wmissing-prototypes") add_compiler_flag_if_available("-Wstrict-prototypes") add_compiler_flag_if_available("-Wformat-security") endif() if (EXTRA_DEFINES) add_definitions("${EXTRA_DEFINES}") endif(EXTRA_DEFINES) if (NOT NAVIT_DEPENDENCY_ERROR) message("\nSummary:\n") set(SUMMARY_COMPONENTS ${ALL_PLUGINS} ${ALL_MODULE_PLUGINS} ${ALL_MODULES}) list(SORT SUMMARY_COMPONENTS) set(LAST_TYPE NONE) foreach ( SUMMARY_COMP ${SUMMARY_COMPONENTS}) # split path to type and name string(REPLACE "/" ";" SUMMARY_COMP_LIST ${SUMMARY_COMP}) list(GET SUMMARY_COMP_LIST 0 SUMMARY_COMP_TYPE) list(LENGTH SUMMARY_COMP_LIST SUMMARY_COMP_LIST_LENGTH) if ( SUMMARY_COMP_LIST_LENGTH GREATER 1 ) list(GET SUMMARY_COMP_LIST 1 SUMMARY_COMP_NAME) else() set(SUMMARY_COMP_NAME ${SUMMARY_COMP}) endif() if ( NOT ${LAST_TYPE} STREQUAL ${SUMMARY_COMP_TYPE}) message("\n--->>> ${SUMMARY_COMP_TYPE}") set(LAST_TYPE ${SUMMARY_COMP_TYPE}) endif() if (${SUMMARY_COMP}) message("Enabled ${SUMMARY_COMP_NAME} ( ${${SUMMARY_COMP}_REASON} )") else() message("Disabled ${SUMMARY_COMP_NAME} ( ${${SUMMARY_COMP}_REASON} )") endif() endforeach() list(SORT ALL_FEATURES) message("\n--->>> Features") foreach ( FEATURE ${ALL_FEATURES}) if ( ${FEATURE} ) message("Enabled ${FEATURE} ( ${${FEATURE}_REASON} )") else() message("Disabled ${FEATURE} ( ${${FEATURE}_REASON} )") endif() endforeach() if (XSL_PROCESSING) if (XSLTS) message("\nProcessing XSLT files: ${XSLTS}") else() message("\nProcessing XSLT files: NONE") endif(XSLTS) message("See navit/xslt for available XSLT files, and put them into " "cache variable 'XSLTS' (without extension .xslt).") endif(XSL_PROCESSING) message("\nTo configure your build use 'cmake -L' to find changeable variables and run cmake again with 'cmake -D <var-name>=<your value> ...'.") endif(NOT NAVIT_DEPENDENCY_ERROR) add_subdirectory (navit) add_subdirectory (man) if (USE_NATIVE_LANGUAGE_SUPPORT) add_subdirectory (po) endif(USE_NATIVE_LANGUAGE_SUPPORT)
Genau geht es um das Programm "Navit" welches ich zwar für Ubuntu kompilieren kann, jetzt aber für den Raspberry Pi kompilieren möchte, am Raspi selbst will ich - aufgrund der Dauer - nicht kompilieren.
Andere Programme hab ich für ARM schon kompiliert und auf dem Raspi ausgeführt... jetzt geht es mir um Obiges ☺
Hat da jemand einen Tipp für mich? Mit SET(CMAKE_CXX_COMPILER /path/to/my/armcompiler) funktionierts leider nicht -.-
Thx & lg
