Das hat leider nicht funktioniert:
Hier meine Abänderung
; This file is part of the LibreOffice project.
; This Source Code Form is subject to the terms of the Mozilla Public
; License, v. 2.0. If a copy of the MPL was not distributed with this
; file, You can obtain one at http://mozilla.org/MPL/2.0/.
; This file incorporates work covered by the following license notice:
; Licensed to the Apache Software Foundation (ASF) under one or more
; contributor license agreements. See the NOTICE file distributed
; with this work for additional information regarding copyright
; ownership. The ASF licenses this file to you under the Apache
; License, Version 2.0 (the "License"); you may not use this file
; except in compliance with the License. You may obtain a copy of
; the License at http://www.apache.org/licenses/LICENSE-2.0 .
[__Global_Printer_Defaults__]
; Copies: the default number of copies produced
; if key is absent the default is 1
; Copies=1
; Orientation: the default orientation of pages
; possible Values: Portrait, Landscape
; if key is absent the default is Portrait
; Orientation=Portrait
; Scale: the default scaling of output in percent
; if key is absent the default is 100
; Scale=100
; MarginAdjust: the default adjustment to driver margins in 1/100 mm
; MarginAdjust contains corrections for the driver defined margins
; the values are comma separated
; the order is: left,right,top,bottom
; if key is absent the default is 0,0,0,0
; MarginAdjust=0,0,0,0
; ColorDepth: the default colordepth of the device in bits
; possible values: 1, 8, 24
; if key is absent the default is 24
; ColorDepth=24
; ColorDevice: the default setting whether the device is color capable
; possible values: 0: driver setting, -1: grey scale, 1: color
; ColorDepth=0
; PSLevel: the default setting of the PostScript level of the output
; possible values: 0: driver setting, 1: level 1, 2: level2
; PSLevel=0
; PPD_PageSize: the default page size to use. If a specific printer does
; not support this page size its default is used instead.
; possible values: A0, A1, A2, A3, A4, A5, A6, B4, B5, B6,
; Legal, Letter, Executive, Statement, Tabloid,
; Ledger, AnsiC, AnsiD, ARCHA, ARCHB, ARCHC,
; ARCHD, ARCHE, EnvMonarch, EnvC4, EnvC5, EnvC6,
; Env10, EnvC65, Folio
; if key is absent the default value is driver specific
; PPD_PageSize=A4
[Brother Fax]
; for every printer a group with at least the keys
; "Printer" and "Command" is required
; Printer: contains the base name of the PPD and the Printer name separated by /
Printer=SGENPRT/Brother Fax
; DefaultPrinter: marks the default printer
DefaultPrinter=1
; Location: a user readable string that will be shown in the print dialog
Location=
; Comment: a user readable string that will be shown in the print dialog
Comment=
; Command: a command line that accepts PostScript as standard input (pipe)
; note: a shell will be started for the command
Command=brpcfax
; QuickCommand: a command line that accepts PostScript as standard input (pipe)
; this command line will be used instead of the command line given in the
; "Command" key, if the user presses the direct print button. In this case
; no print dialog should be shown, neither form the printing applcation nor
; from the command line (example "kprinter --nodialog --stdin")
;QuickCommand=brpcfax
; Features: a string containing additional comma separated properties of a printer
; currently valid properties:
; fax for a Fax printer queue
; pdf=<dir> for a PDF printer where <dir> is the base directory for output files
; external_dialog to notify that the print command of a printer will show a dialog
; and therefore the application should not show its own dialog.
;Features=fax
Hier das Original:
; Copies=1
; Scale=100
; ColorDepth=24
; ColorDepth=0
; PSLevel=0
; PPD_PageSize=A4
[Generic Printer]
Printer=SGENPRT/Generic Printer
DefaultPrinter=1
Location=
Comment=
Command=
;QuickCommand=
;Features=
Ist nach wie vor das selbe geblieben beim Ausführen, rührt sich nichts. Das Kommando brpcfax wird nicht ausgeführt.
Oben steht Druckvorgang wird gestartet, fertig ohne Ergebnis und Reaktion
Auch diese Version hat nicht geholfen:
; Copies=1
; Scale=100
; ColorDepth=24
; ColorDepth=0
; PSLevel=0
; PPD_PageSize=A4
[Generic Printer]
[Brother Fax]
DefaultPrinter=1
Location=
Comment=
Command=brpcfax
;Features=fax
