Ich habe ein kleines Python-Skript geschrieben, das mir den aktuellen Ladestand des Akkus in Prozent ausgibt. Es war eine kleine Einsteigerübung, und ich bin offen für Kritik. Gut möglich, dass es nicht mit jeder Hardware funktioniert; ich benutze das überwiegend auf einem Netbook. Vielleicht kann es jemand brauchen. ☺
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 | #!/usr/bin/env python # -*- coding: utf-8 -*- import sys def get_state_path(): """Return a list of battery state paths""" state_files = ['charge_now', 'charge_full'] state_dir = '/sys/class/power_supply/BAT0/' state_path = [] for state in state_files: state_path.append(state_dir+state) return state_path def get_battery_states(): """Return battery states as tuple""" first_path, second_path = get_state_path() with open(first_path) as charge: charge_state = charge.read() with open(second_path) as full: full_charge = full.read() return charge_state, full_charge def main(): """Print battery state in percent to stdout or exit if the battery state cannot be read """ try: charge_state, battery_full = get_battery_states() except IOError, message: sys.exit(message) battery_quotient = float(charge_state) / float(battery_full) print '{:.2%}'.format(battery_quotient) if __name__=="__main__": main() |
