Backintime lässt sich nicht mehr starten. Hat bisher tadellos funktioniert. Im Terminal erscheint nun aber folgende Meldung:
Back In Time Version: 1.1.12 Back In Time comes with ABSOLUTELY NO WARRANTY. This is free software, and you are welcome to redistribute it under certain conditions; type `backintime --license' for details. Traceback (most recent call last): File "/usr/share/backintime/common/backintime.py", line 865, in <module> start_app() File "/usr/share/backintime/common/backintime.py", line 454, in start_app return getConfig(args, False) File "/usr/share/backintime/common/backintime.py", line 575, in getConfig cfg = config.Config(args.config) File "/usr/share/backintime/common/config.py", line 189, in __init__ self.append( self._LOCAL_CONFIG_PATH ) File "/usr/share/backintime/common/configfile.py", line 393, in append super(ConfigFileWithProfiles, self).append(filename) File "/usr/share/backintime/common/configfile.py", line 115, in append lines = f.readlines() File "/usr/lib/python3.6/codecs.py", line 321, in decode (result, consumed) = self._buffer_decode(data, self.errors, final) UnicodeDecodeError: 'utf-8' codec can't decode byte 0x99 in position 3: invalid start byte
Was kann ich tun?
