Hallo Kellerkind,
vielen Dank für Deine Antwort. Du scheinst ja bei Druck- und Scanproblemen ja hier der Experte zu sein.
hier die Ausgabe von export SANE_DEBUG_DLL=255 && scanimage -L
[sanei_debug] Setting debug level of dll to 255.
[dll] sane_init: SANE dll backend version 1.0.13 from sane-backends 1.0.27git
[dll] sane_init/read_dlld: attempting to open directory ./dll.d'
/etc/sane.d/dll.d'
[dll] sane_init/read_dlld: using config directory /etc/sane.d/dll.d'
[dll] sane_init/read_dlld: considering /etc/sane.d/dll.d/libsane-extras
[dll] sane_init/read_config: reading dll.d/libsane-extras
[dll] add_backend: adding backend
ls5000'
[dll] sane_init/read_dlld: done.
[dll] sane_init/read_config: reading dll.conf
[dll] add_backend: adding backend net'
abaton'
[dll] add_backend: adding backend agfafocus'
apple'
[dll] add_backend: adding backend avision'
artec'
[dll] add_backend: adding backend artec_eplus48u'
as6e'
[dll] add_backend: adding backend bh'
canon'
[dll] add_backend: adding backend canon630u'
canon_dr'
[dll] add_backend: adding backend cardscan'
coolscan'
[dll] add_backend: adding backend coolscan3'
dell1600n_net'
[dll] add_backend: adding backend dmc'
epjitsu'
[dll] add_backend: adding backend epson2'
epsonds'
[dll] add_backend: adding backend fujitsu'
genesys'
[dll] add_backend: adding backend gt68xx'
hp'
[dll] add_backend: adding backend hp3900'
hpsj5s'
[dll] add_backend: adding backend hp3500'
hp4200'
[dll] add_backend: adding backend hp5400'
hp5590'
[dll] add_backend: adding backend hpljm1005'
hs2p'
[dll] add_backend: adding backend ibm'
kodak'
[dll] add_backend: adding backend kodakaio'
kvs1025'
[dll] add_backend: adding backend kvs20xx'
leo'
[dll] add_backend: adding backend lexmark'
ma1509'
[dll] add_backend: adding backend magicolor'
matsushita'
[dll] add_backend: adding backend microtek'
microtek2'
[dll] add_backend: adding backend mustek'
mustek_usb'
[dll] add_backend: adding backend mustek_usb2'
nec'
[dll] add_backend: adding backend niash'
pie'
[dll] add_backend: adding backend pint'
pixma'
[dll] add_backend: adding backend plustek'
qcam'
[dll] add_backend: adding backend ricoh'
rts8891'
[dll] add_backend: adding backend s9036'
sceptre'
[dll] add_backend: adding backend sharp'
sm3600'
[dll] add_backend: adding backend sm3840'
snapscan'
[dll] add_backend: adding backend sp15c'
tamarack'
[dll] add_backend: adding backend teco1'
teco2'
[dll] add_backend: adding backend teco3'
u12'
[dll] add_backend: adding backend umax'
umax1220u'
[dll] add_backend: adding backend v4l'
xerox_mfp'
[dll] add_backend: adding backend smfp'
[dll] sane_get_devices
[dll] load: searching backend
smfp' in /usr/lib/x86_64-linux-gnu/sane'
[dll] load: trying to load
/usr/lib/x86_64-linux-gnu/sane/libsane-smfp.so.1'
[dll] load: dlopen()ing /usr/lib/x86_64-linux-gnu/sane/libsane-smfp.so.1'
[dll] init: initializing backend
smfp'
[dll] init: backend smfp' is version 1.0.1
xerox_mfp' in /usr/lib/x86_64-linux-gnu/sane'
/usr/lib/x86_64-linux-gnu/sane/libsane-xerox_mfp.so.1'
[dll] load: dlopen()ing /usr/lib/x86_64-linux-gnu/sane/libsane-xerox_mfp.so.1'
xerox_mfp'
[dll] init: backend xerox_mfp' is version 1.0.13
v4l' in /usr/lib/x86_64-linux-gnu/sane'
/usr/lib/x86_64-linux-gnu/sane/libsane-v4l.so.1'
[dll] load: couldn't open /usr/lib/x86_64-linux-gnu/sane/libsane-v4l.so.1' (No such file or directory)
[dll] load: couldn't find backend
v4l' (No such file or directory)
[dll] load: searching backend umax1220u' in
[dll] load: trying to load /usr/lib/x86_64-linux-gnu/sane/libsane-umax1220u.so.1'
[dll] init: initializing backend umax1220u'
[dll] init: backend
umax1220u' is version 1.0.2
[dll] load: searching backend umax' in
[dll] load: trying to load /usr/lib/x86_64-linux-gnu/sane/libsane-umax.so.1'
[dll] init: initializing backend umax'
[dll] init: backend
umax' is version 1.0.45
[dll] load: searching backend u12' in
[dll] load: trying to load /usr/lib/x86_64-linux-gnu/sane/libsane-u12.so.1'
[dll] init: initializing backend u12'
[dll] init: backend
u12' is version 1.0.0
[dll] load: searching backend teco3' in
[dll] load: trying to load /usr/lib/x86_64-linux-gnu/sane/libsane-teco3.so.1'
[dll] init: initializing backend teco3'
[dll] init: backend
teco3' is version 1.0.1
[dll] load: searching backend teco2' in
[dll] load: trying to load /usr/lib/x86_64-linux-gnu/sane/libsane-teco2.so.1'
[dll] init: initializing backend teco2'
[dll] init: backend
teco2' is version 1.0.10
[dll] load: searching backend teco1' in
[dll] load: trying to load /usr/lib/x86_64-linux-gnu/sane/libsane-teco1.so.1'
[dll] init: initializing backend teco1'
[dll] init: backend
teco1' is version 1.0.10
[dll] load: searching backend tamarack' in
[dll] load: trying to load /usr/lib/x86_64-linux-gnu/sane/libsane-tamarack.so.1'
[dll] init: initializing backend tamarack'
[dll] init: backend
tamarack' is version 1.0.0
[dll] load: searching backend sp15c' in
[dll] load: trying to load /usr/lib/x86_64-linux-gnu/sane/libsane-sp15c.so.1'
[dll] init: initializing backend sp15c'
[dll] init: backend
sp15c' is version 1.0.0
[dll] load: searching backend snapscan' in
[dll] load: trying to load /usr/lib/x86_64-linux-gnu/sane/libsane-snapscan.so.1'
[dll] init: initializing backend snapscan'
[dll] init: backend
snapscan' is version 1.4.53
[dll] load: searching backend sm3840' in
[dll] load: trying to load /usr/lib/x86_64-linux-gnu/sane/libsane-sm3840.so.1'
[dll] init: initializing backend sm3840'
[dll] init: backend
sm3840' is version 1.0.0
[dll] load: searching backend sm3600' in
[dll] load: trying to load /usr/lib/x86_64-linux-gnu/sane/libsane-sm3600.so.1'
[dll] init: initializing backend sm3600'
[dll] init: backend
sm3600' is version 1.0.6
[dll] load: searching backend sharp' in
[dll] load: trying to load /usr/lib/x86_64-linux-gnu/sane/libsane-sharp.so.1'
[dll] init: initializing backend sharp'
[dll] init: backend
sharp' is version 1.0.0
[dll] load: searching backend sceptre' in
[dll] load: trying to load /usr/lib/x86_64-linux-gnu/sane/libsane-sceptre.so.1'
[dll] init: initializing backend sceptre'
[dll] init: backend
sceptre' is version 1.0.10
[dll] load: searching backend s9036' in
[dll] load: trying to load /usr/lib/x86_64-linux-gnu/sane/libsane-s9036.so.1'
[dll] init: initializing backend s9036'
[dll] init: backend
s9036' is version 1.0.0
[dll] load: searching backend rts8891' in
[dll] load: trying to load /usr/lib/x86_64-linux-gnu/sane/libsane-rts8891.so.1'
[dll] init: initializing backend rts8891'
[dll] init: backend
rts8891' is version 1.0.2401
[dll] load: searching backend ricoh' in
[dll] load: trying to load /usr/lib/x86_64-linux-gnu/sane/libsane-ricoh.so.1'
[dll] init: initializing backend ricoh'
[dll] init: backend
ricoh' is version 1.0.0
[dll] load: searching backend qcam' in
[dll] load: trying to load /usr/lib/x86_64-linux-gnu/sane/libsane-qcam.so.1'
[dll] init: initializing backend qcam'
[dll] init: backend
qcam' is version 1.0.0
[dll] load: searching backend plustek' in
[dll] load: trying to load /usr/lib/x86_64-linux-gnu/sane/libsane-plustek.so.1'
[dll] init: initializing backend plustek'
[dll] init: backend
plustek' is version 1.0.0
[dll] load: searching backend pixma' in
[dll] load: trying to load /usr/lib/x86_64-linux-gnu/sane/libsane-pixma.so.1'
[dll] init: initializing backend pixma'
[dll] init: backend
pixma' is version 1.0.18
[dll] load: searching backend pint' in
[dll] load: trying to load /usr/lib/x86_64-linux-gnu/sane/libsane-pint.so.1'
/usr/lib/x86_64-linux-gnu/sane/libsane-pint.so.1' (No such file or directory)
[dll] load: couldn't find backend pint' (No such file or directory)
pie' in /usr/lib/x86_64-linux-gnu/sane'
/usr/lib/x86_64-linux-gnu/sane/libsane-pie.so.1'
[dll] load: dlopen()ing /usr/lib/x86_64-linux-gnu/sane/libsane-pie.so.1'
pie'
[dll] init: backend pie' is version 1.0.9
niash' in /usr/lib/x86_64-linux-gnu/sane'
/usr/lib/x86_64-linux-gnu/sane/libsane-niash.so.1'
[dll] load: dlopen()ing /usr/lib/x86_64-linux-gnu/sane/libsane-niash.so.1'
niash'
[dll] init: backend niash' is version 1.0.1
nec' in /usr/lib/x86_64-linux-gnu/sane'
/usr/lib/x86_64-linux-gnu/sane/libsane-nec.so.1'
[dll] load: dlopen()ing /usr/lib/x86_64-linux-gnu/sane/libsane-nec.so.1'
nec'
[dll] init: backend nec' is version 1.0.0
mustek_usb2' in /usr/lib/x86_64-linux-gnu/sane'
/usr/lib/x86_64-linux-gnu/sane/libsane-mustek_usb2.so.1'
[dll] load: dlopen()ing /usr/lib/x86_64-linux-gnu/sane/libsane-mustek_usb2.so.1'
mustek_usb2'
[dll] init: backend mustek_usb2' is version 1.0.10
mustek_usb' in /usr/lib/x86_64-linux-gnu/sane'
/usr/lib/x86_64-linux-gnu/sane/libsane-mustek_usb.so.1'
[dll] load: dlopen()ing /usr/lib/x86_64-linux-gnu/sane/libsane-mustek_usb.so.1'
mustek_usb'
[dll] init: backend mustek_usb' is version 1.0.18
mustek' in /usr/lib/x86_64-linux-gnu/sane'
/usr/lib/x86_64-linux-gnu/sane/libsane-mustek.so.1'
[dll] load: dlopen()ing /usr/lib/x86_64-linux-gnu/sane/libsane-mustek.so.1'
mustek'
[dll] init: backend mustek' is version 1.0.138
microtek2' in /usr/lib/x86_64-linux-gnu/sane'
/usr/lib/x86_64-linux-gnu/sane/libsane-microtek2.so.1'
[dll] load: dlopen()ing /usr/lib/x86_64-linux-gnu/sane/libsane-microtek2.so.1'
microtek2'
[dll] init: backend microtek2' is version 1.0.0
microtek' in /usr/lib/x86_64-linux-gnu/sane'
/usr/lib/x86_64-linux-gnu/sane/libsane-microtek.so.1'
[dll] load: dlopen()ing /usr/lib/x86_64-linux-gnu/sane/libsane-microtek.so.1'
microtek'
[dll] init: backend microtek' is version 1.0.0
matsushita' in /usr/lib/x86_64-linux-gnu/sane'
/usr/lib/x86_64-linux-gnu/sane/libsane-matsushita.so.1'
[dll] load: dlopen()ing /usr/lib/x86_64-linux-gnu/sane/libsane-matsushita.so.1'
matsushita'
[dll] init: backend matsushita' is version 1.0.7
magicolor' in /usr/lib/x86_64-linux-gnu/sane'
/usr/lib/x86_64-linux-gnu/sane/libsane-magicolor.so.1'
[dll] load: dlopen()ing /usr/lib/x86_64-linux-gnu/sane/libsane-magicolor.so.1'
magicolor'
[dll] init: backend magicolor' is version 1.0.1
ma1509' in /usr/lib/x86_64-linux-gnu/sane'
/usr/lib/x86_64-linux-gnu/sane/libsane-ma1509.so.1'
[dll] load: dlopen()ing /usr/lib/x86_64-linux-gnu/sane/libsane-ma1509.so.1'
ma1509'
[dll] init: backend ma1509' is version 1.0.3
lexmark' in /usr/lib/x86_64-linux-gnu/sane'
/usr/lib/x86_64-linux-gnu/sane/libsane-lexmark.so.1'
[dll] load: dlopen()ing /usr/lib/x86_64-linux-gnu/sane/libsane-lexmark.so.1'
lexmark'
[dll] init: backend lexmark' is version 1.0.32
leo' in /usr/lib/x86_64-linux-gnu/sane'
/usr/lib/x86_64-linux-gnu/sane/libsane-leo.so.1'
[dll] load: dlopen()ing /usr/lib/x86_64-linux-gnu/sane/libsane-leo.so.1'
leo'
[dll] init: backend leo' is version 1.0.11
kvs20xx' in /usr/lib/x86_64-linux-gnu/sane'
/usr/lib/x86_64-linux-gnu/sane/libsane-kvs20xx.so.1'
[dll] load: dlopen()ing /usr/lib/x86_64-linux-gnu/sane/libsane-kvs20xx.so.1'
kvs20xx'
[dll] init: backend kvs20xx' is version 1.0.2
kvs1025' in /usr/lib/x86_64-linux-gnu/sane'
/usr/lib/x86_64-linux-gnu/sane/libsane-kvs1025.so.1'
[dll] load: dlopen()ing /usr/lib/x86_64-linux-gnu/sane/libsane-kvs1025.so.1'
kvs1025'
[dll] init: backend kvs1025' is version 1.0.5
kodakaio' in /usr/lib/x86_64-linux-gnu/sane'
/usr/lib/x86_64-linux-gnu/sane/libsane-kodakaio.so.1'
[dll] load: dlopen()ing /usr/lib/x86_64-linux-gnu/sane/libsane-kodakaio.so.1'
kodakaio'
[dll] init: backend kodakaio' is version 1.0.3
kodak' in /usr/lib/x86_64-linux-gnu/sane'
/usr/lib/x86_64-linux-gnu/sane/libsane-kodak.so.1'
[dll] load: dlopen()ing /usr/lib/x86_64-linux-gnu/sane/libsane-kodak.so.1'
kodak'
[dll] init: backend kodak' is version 1.0.7
ibm' in /usr/lib/x86_64-linux-gnu/sane'
/usr/lib/x86_64-linux-gnu/sane/libsane-ibm.so.1'
[dll] load: dlopen()ing /usr/lib/x86_64-linux-gnu/sane/libsane-ibm.so.1'
ibm'
[dll] init: backend ibm' is version 1.0.0
hs2p' in /usr/lib/x86_64-linux-gnu/sane'
/usr/lib/x86_64-linux-gnu/sane/libsane-hs2p.so.1'
[dll] load: dlopen()ing /usr/lib/x86_64-linux-gnu/sane/libsane-hs2p.so.1'
hs2p'
[dll] init: backend hs2p' is version 1.0.0
hpljm1005' in /usr/lib/x86_64-linux-gnu/sane'
/usr/lib/x86_64-linux-gnu/sane/libsane-hpljm1005.so.1'
[dll] load: dlopen()ing /usr/lib/x86_64-linux-gnu/sane/libsane-hpljm1005.so.1'
hpljm1005'
[dll] init: backend hpljm1005' is version 1.0.1
hp5590' in /usr/lib/x86_64-linux-gnu/sane'
/usr/lib/x86_64-linux-gnu/sane/libsane-hp5590.so.1'
[dll] load: dlopen()ing /usr/lib/x86_64-linux-gnu/sane/libsane-hp5590.so.1'
hp5590'
[dll] init: backend hp5590' is version 1.0.7
hp5400' in /usr/lib/x86_64-linux-gnu/sane'
/usr/lib/x86_64-linux-gnu/sane/libsane-hp5400.so.1'
[dll] load: dlopen()ing /usr/lib/x86_64-linux-gnu/sane/libsane-hp5400.so.1'
hp5400'
[dll] init: backend hp5400' is version 1.0.3
hp4200' in /usr/lib/x86_64-linux-gnu/sane'
/usr/lib/x86_64-linux-gnu/sane/libsane-hp4200.so.1'
[dll] load: dlopen()ing /usr/lib/x86_64-linux-gnu/sane/libsane-hp4200.so.1'
hp4200'
[dll] init: backend hp4200' is version 1.0.0
hp3500' in /usr/lib/x86_64-linux-gnu/sane'
/usr/lib/x86_64-linux-gnu/sane/libsane-hp3500.so.1'
[dll] load: dlopen()ing /usr/lib/x86_64-linux-gnu/sane/libsane-hp3500.so.1'
hp3500'
[dll] init: backend hp3500' is version 1.0.0
hpsj5s' in /usr/lib/x86_64-linux-gnu/sane'
/usr/lib/x86_64-linux-gnu/sane/libsane-hpsj5s.so.1'
[dll] load: dlopen()ing /usr/lib/x86_64-linux-gnu/sane/libsane-hpsj5s.so.1'
hpsj5s'
[dll] init: backend hpsj5s' is version 1.0.3
hp3900' in /usr/lib/x86_64-linux-gnu/sane'
/usr/lib/x86_64-linux-gnu/sane/libsane-hp3900.so.1'
[dll] load: dlopen()ing /usr/lib/x86_64-linux-gnu/sane/libsane-hp3900.so.1'
hp3900'
[dll] init: backend hp3900' is version 1.0.0
hp' in /usr/lib/x86_64-linux-gnu/sane'
/usr/lib/x86_64-linux-gnu/sane/libsane-hp.so.1'
[dll] load: dlopen()ing /usr/lib/x86_64-linux-gnu/sane/libsane-hp.so.1'
hp'
[dll] init: backend hp' is version 1.0.8
gt68xx' in /usr/lib/x86_64-linux-gnu/sane'
/usr/lib/x86_64-linux-gnu/sane/libsane-gt68xx.so.1'
[dll] load: dlopen()ing /usr/lib/x86_64-linux-gnu/sane/libsane-gt68xx.so.1'
gt68xx'
[dll] init: backend gt68xx' is version 1.0.84
genesys' in /usr/lib/x86_64-linux-gnu/sane'
/usr/lib/x86_64-linux-gnu/sane/libsane-genesys.so.1'
[dll] load: dlopen()ing /usr/lib/x86_64-linux-gnu/sane/libsane-genesys.so.1'
genesys'
[dll] init: backend genesys' is version 1.0.2511
fujitsu' in /usr/lib/x86_64-linux-gnu/sane'
/usr/lib/x86_64-linux-gnu/sane/libsane-fujitsu.so.1'
[dll] load: dlopen()ing /usr/lib/x86_64-linux-gnu/sane/libsane-fujitsu.so.1'
fujitsu'
[dll] init: backend fujitsu' is version 1.0.133
epsonds' in /usr/lib/x86_64-linux-gnu/sane'
/usr/lib/x86_64-linux-gnu/sane/libsane-epsonds.so.1'
[dll] load: dlopen()ing /usr/lib/x86_64-linux-gnu/sane/libsane-epsonds.so.1'
epsonds'
[dll] init: backend epsonds' is version 1.0.0
epson2' in /usr/lib/x86_64-linux-gnu/sane'
/usr/lib/x86_64-linux-gnu/sane/libsane-epson2.so.1'
[dll] load: dlopen()ing /usr/lib/x86_64-linux-gnu/sane/libsane-epson2.so.1'
epson2'
[dll] init: backend epson2' is version 1.0.124
epjitsu' in /usr/lib/x86_64-linux-gnu/sane'
/usr/lib/x86_64-linux-gnu/sane/libsane-epjitsu.so.1'
[dll] load: dlopen()ing /usr/lib/x86_64-linux-gnu/sane/libsane-epjitsu.so.1'
epjitsu'
[dll] init: backend epjitsu' is version 1.0.31
dmc' in /usr/lib/x86_64-linux-gnu/sane'
/usr/lib/x86_64-linux-gnu/sane/libsane-dmc.so.1'
[dll] load: dlopen()ing /usr/lib/x86_64-linux-gnu/sane/libsane-dmc.so.1'
dmc'
[dll] init: backend dmc' is version 1.0.0
dell1600n_net' in /usr/lib/x86_64-linux-gnu/sane'
/usr/lib/x86_64-linux-gnu/sane/libsane-dell1600n_net.so.1'
[dll] load: dlopen()ing /usr/lib/x86_64-linux-gnu/sane/libsane-dell1600n_net.so.1'
dell1600n_net'
[dll] init: backend dell1600n_net' is version 1.0.0
coolscan3' in /usr/lib/x86_64-linux-gnu/sane'
/usr/lib/x86_64-linux-gnu/sane/libsane-coolscan3.so.1'
[dll] load: dlopen()ing /usr/lib/x86_64-linux-gnu/sane/libsane-coolscan3.so.1'
coolscan3'
[dll] init: backend coolscan3' is version 1.0.0
coolscan' in /usr/lib/x86_64-linux-gnu/sane'
/usr/lib/x86_64-linux-gnu/sane/libsane-coolscan.so.1'
[dll] load: dlopen()ing /usr/lib/x86_64-linux-gnu/sane/libsane-coolscan.so.1'
coolscan'
[dll] init: backend coolscan' is version 1.0.0
cardscan' in /usr/lib/x86_64-linux-gnu/sane'
/usr/lib/x86_64-linux-gnu/sane/libsane-cardscan.so.1'
[dll] load: dlopen()ing /usr/lib/x86_64-linux-gnu/sane/libsane-cardscan.so.1'
cardscan'
[dll] init: backend cardscan' is version 1.0.3
canon_dr' in /usr/lib/x86_64-linux-gnu/sane'
/usr/lib/x86_64-linux-gnu/sane/libsane-canon_dr.so.1'
[dll] load: dlopen()ing /usr/lib/x86_64-linux-gnu/sane/libsane-canon_dr.so.1'
canon_dr'
[dll] init: backend canon_dr' is version 1.0.56
canon630u' in /usr/lib/x86_64-linux-gnu/sane'
/usr/lib/x86_64-linux-gnu/sane/libsane-canon630u.so.1'
[dll] load: dlopen()ing /usr/lib/x86_64-linux-gnu/sane/libsane-canon630u.so.1'
canon630u'
[dll] init: backend canon630u' is version 1.0.1
canon' in /usr/lib/x86_64-linux-gnu/sane'
/usr/lib/x86_64-linux-gnu/sane/libsane-canon.so.1'
[dll] load: dlopen()ing /usr/lib/x86_64-linux-gnu/sane/libsane-canon.so.1'
canon'
[dll] init: backend canon' is version 1.0.0
bh' in /usr/lib/x86_64-linux-gnu/sane'
/usr/lib/x86_64-linux-gnu/sane/libsane-bh.so.1'
[dll] load: dlopen()ing /usr/lib/x86_64-linux-gnu/sane/libsane-bh.so.1'
bh'
[dll] init: backend bh' is version 1.0.4
as6e' in /usr/lib/x86_64-linux-gnu/sane'
/usr/lib/x86_64-linux-gnu/sane/libsane-as6e.so.1'
[dll] load: dlopen()ing /usr/lib/x86_64-linux-gnu/sane/libsane-as6e.so.1'
as6e'
[dll] load: searching backend artec_eplus48u' in
[dll] load: trying to load /usr/lib/x86_64-linux-gnu/sane/libsane-artec_eplus48u.so.1'
[dll] init: initializing backend artec_eplus48u'
[dll] init: backend
artec_eplus48u' is version 1.0.0
[dll] load: searching backend artec' in
[dll] load: trying to load /usr/lib/x86_64-linux-gnu/sane/libsane-artec.so.1'
[dll] init: initializing backend artec'
[dll] init: backend
artec' is version 1.0.0
[dll] load: searching backend avision' in
[dll] load: trying to load /usr/lib/x86_64-linux-gnu/sane/libsane-avision.so.1'
[dll] init: initializing backend avision'
[dll] init: backend
avision' is version 1.0.297
[dll] load: searching backend apple' in
[dll] load: trying to load /usr/lib/x86_64-linux-gnu/sane/libsane-apple.so.1'
[dll] init: initializing backend apple'
[dll] init: backend
apple' is version 1.0.0
[dll] load: searching backend agfafocus' in
[dll] load: trying to load /usr/lib/x86_64-linux-gnu/sane/libsane-agfafocus.so.1'
[dll] init: initializing backend agfafocus'
[dll] init: backend
agfafocus' is version 1.0.0
[dll] load: searching backend abaton' in
[dll] load: trying to load /usr/lib/x86_64-linux-gnu/sane/libsane-abaton.so.1'
[dll] init: initializing backend abaton'
[dll] init: backend
abaton' is version 1.0.0
[dll] load: searching backend net' in
[dll] load: trying to load /usr/lib/x86_64-linux-gnu/sane/libsane-net.so.1'
[dll] init: initializing backend net'
[dll] init: backend
net' is version 1.0.27
[dll] load: searching backend ls5000' in
[dll] load: trying to load /usr/lib/x86_64-linux-gnu/sane/libsane-ls5000.so.1'
[dll] init: initializing backend ls5000'
[dll] init: backend
ls5000' is version 1.0.0
[dll] sane_get_devices: found 0 devices
No scanners were identified. If you were expecting something different,
check that the scanner is plugged in, turned on and detected by the
sane-find-scanner tool (if appropriate). Please read the documentation
which came with this software (README, FAQ, manpages).
[dll] sane_exit: exiting
[dll] sane_exit: calling backend smfp's exit function
xerox_mfp's exit function
[dll] sane_exit: calling backend umax1220u's exit function
umax's exit function
[dll] sane_exit: calling backend u12's exit function
teco3's exit function
[dll] sane_exit: calling backend teco2's exit function
teco1's exit function
[dll] sane_exit: calling backend tamarack's exit function
sp15c's exit function
[dll] sane_exit: calling backend snapscan's exit function
sm3840's exit function
[dll] sane_exit: calling backend sm3600's exit function
sharp's exit function
[dll] sane_exit: calling backend sceptre's exit function
s9036's exit function
[dll] sane_exit: calling backend rts8891's exit function
ricoh's exit function
[dll] sane_exit: calling backend qcam's exit function
plustek's exit function
[dll] sane_exit: calling backend pixma's exit function
pie's exit function
[dll] sane_exit: calling backend niash's exit function
nec's exit function
[dll] sane_exit: calling backend mustek_usb2's exit function
mustek_usb's exit function
[dll] sane_exit: calling backend mustek's exit function
microtek2's exit function
[dll] sane_exit: calling backend microtek's exit function
matsushita's exit function
[dll] sane_exit: calling backend magicolor's exit function
ma1509's exit function
[dll] sane_exit: calling backend lexmark's exit function
leo's exit function
[dll] sane_exit: calling backend kvs20xx's exit function
kvs1025's exit function
[dll] sane_exit: calling backend kodakaio's exit function
kodak's exit function
[dll] sane_exit: calling backend ibm's exit function
hs2p's exit function
[dll] sane_exit: calling backend hpljm1005's exit function
hp5590's exit function
[dll] sane_exit: calling backend hp5400's exit function
hp4200's exit function
[dll] sane_exit: calling backend hp3500's exit function
hpsj5s's exit function
[dll] sane_exit: calling backend hp3900's exit function
hp's exit function
[dll] sane_exit: calling backend gt68xx's exit function
genesys's exit function
[dll] sane_exit: calling backend fujitsu's exit function
epsonds's exit function
[dll] sane_exit: calling backend epson2's exit function
epjitsu's exit function
[dll] sane_exit: calling backend dmc's exit function
dell1600n_net's exit function
[dll] sane_exit: calling backend coolscan3's exit function
coolscan's exit function
[dll] sane_exit: calling backend cardscan's exit function
canon_dr's exit function
[dll] sane_exit: calling backend canon630u's exit function
canon's exit function
[dll] sane_exit: calling backend bh's exit function
artec_eplus48u's exit function
[dll] sane_exit: calling backend artec's exit function
avision's exit function
[dll] sane_exit: calling backend apple's exit function
agfafocus's exit function
[dll] sane_exit: calling backend abaton's exit function
net's exit function
[dll] sane_exit: calling backend ls5000's exit function
[dll] sane_exit: finished
Nochmals Danke, daß Du Dir für mein Problem die Zeit nimmst.
Mirek
